[mapguide-commits] r1243 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Thu Mar 15 14:43:23 EDT 2007
Author: traianstanev
Date: 2007-03-15 14:43:22 -0400 (Thu, 15 Mar 2007)
New Revision: 1243
trunk/MgDev/Common/Stylization/GDRenderer.cpp
trunk/MgDev/Common/Stylization/GDRenderer.h
trunk/MgDev/Common/Stylization/GDW2DRewriter.cpp
trunk/MgDev/Common/Stylization/RS_FontEngine.cpp
trunk/MgDev/Common/Stylization/SE_LineBuffer.cpp
trunk/MgDev/Common/Stylization/SE_LineBuffer.h
trunk/MgDev/Common/Stylization/SE_Renderer.cpp
trunk/MgDev/Common/Stylization/SE_Renderer.h
Further simplified SE_LineBuffer. Removed the internally managed transformed instance LineBuffer. Instead, the non-transformed instance is used for drawing and the correct transform is applied to the points at render time.
Modified: trunk/MgDev/Common/Stylization/GDRenderer.cpp
--- trunk/MgDev/Common/Stylization/GDRenderer.cpp 2007-03-15 16:46:45 UTC (rev 1242)
+++ trunk/MgDev/Common/Stylization/GDRenderer.cpp 2007-03-15 18:43:22 UTC (rev 1243)
@@ -2124,22 +2124,39 @@
-void GDRenderer::_TransferPoints(double* src, int numpts)
+void GDRenderer::_TransferPoints(double* src, int numpts, const SE_Matrix* xform)
EnsureBufferSize(numpts);
int* pts = (int*)m_wtPointBuffer;
- for (int i=0; i<numpts; i++)
+ if (!xform)
- *pts++ = (int)(*src);
- src++;
- src++;
+ for (int i=0; i<numpts; i++)
+ *pts++ = (int)(*src);
+ src++;
+ src++;
+ else
+ double x, y;
+ xform->transform(src[0], src[1], x, y);
+ pts[0] = (int)x;
+ pts[1] = (int)y;
+ src += 2;
+ pts += 2;
//copied from WritePolylines, except it doesn't do to screen trasnform -- we should refactor.
-void GDRenderer::DrawScreenPolyline(LineBuffer* srclb, unsigned int color, double weightpx)
+void GDRenderer::DrawScreenPolyline(LineBuffer* srclb, const SE_Matrix* xform, unsigned int color, double weightpx)
RS_Color c((color >> 16) & 0xFF, (color >> 8) & 0xFF, color & 0xFF, (color >> 24) & 0xFF);
@@ -2165,7 +2182,7 @@
int cntr_size = srclb->cntrs()[i];
//convert to integer coords
- _TransferPoints(srclb->points() + index, cntr_size);
+ _TransferPoints(srclb->points() + index, cntr_size, xform);
if (cntr_size > 1)
@@ -2190,7 +2207,7 @@
-void GDRenderer::DrawScreenPolygon(LineBuffer* polygon, unsigned int color)
+void GDRenderer::DrawScreenPolygon(LineBuffer* polygon, const SE_Matrix* xform, unsigned int color)
@@ -2212,7 +2229,7 @@
- _TransferPoints(polygon->points(), polygon->point_count());
+ _TransferPoints(polygon->points(), polygon->point_count(), xform);
//call the new rasterizer
m_polyrasterizer->FillPolygon((Point*)m_wtPointBuffer, polygon->point_count(), polygon->cntrs(), polygon->cntr_count(),
Modified: trunk/MgDev/Common/Stylization/GDRenderer.h
--- trunk/MgDev/Common/Stylization/GDRenderer.h 2007-03-15 16:46:45 UTC (rev 1242)
+++ trunk/MgDev/Common/Stylization/GDRenderer.h 2007-03-15 18:43:22 UTC (rev 1243)
@@ -147,8 +147,8 @@
// SE_Renderer
- virtual void DrawScreenPolyline(LineBuffer* geom, unsigned int color, double weight); // px
- virtual void DrawScreenPolygon(LineBuffer* geom, unsigned int fill);
+ virtual void DrawScreenPolyline(LineBuffer* geom, const SE_Matrix* xform, unsigned int color, double weight); // px
+ virtual void DrawScreenPolygon(LineBuffer* geom, const SE_Matrix* xform, unsigned int fill);
virtual void DrawScreenRaster(unsigned char* data, int length, RS_ImageFormat format, int native_width, int native_height,
double x, double y, double w, double h, double angledeg);
virtual void DrawScreenText(const RS_String& txt, RS_TextDef& tdef, double insx, double insy, double* path, int npts, double param_position);
@@ -206,7 +206,7 @@
inline int _TY(double y);
void _TransformPointsNoClamp(double* inpts, int numpts);
- void _TransferPoints(double* inpts, int numpts);
+ void _TransferPoints(double* inpts, int numpts, const SE_Matrix* xform);
RS_Color m_bgcolor;
RS_Bounds m_extents;
Modified: trunk/MgDev/Common/Stylization/GDW2DRewriter.cpp
--- trunk/MgDev/Common/Stylization/GDW2DRewriter.cpp 2007-03-15 16:46:45 UTC (rev 1242)
+++ trunk/MgDev/Common/Stylization/GDW2DRewriter.cpp 2007-03-15 18:43:22 UTC (rev 1243)
@@ -202,7 +202,7 @@
- rewriter->DrawScreenPolygon(&lb, color.argb());
+ rewriter->DrawScreenPolygon(&lb, NULL, color.argb());
return WT_Result::Success;
Modified: trunk/MgDev/Common/Stylization/RS_FontEngine.cpp
--- trunk/MgDev/Common/Stylization/RS_FontEngine.cpp 2007-03-15 16:46:45 UTC (rev 1242)
+++ trunk/MgDev/Common/Stylization/RS_FontEngine.cpp 2007-03-15 18:43:22 UTC (rev 1243)
@@ -524,7 +524,7 @@
lb.LineTo(fpts[3].x, fpts[3].y);
lb.Close();
- m_serenderer->DrawScreenPolygon(&lb, tdef.bgcolor().argb());
+ m_serenderer->DrawScreenPolygon(&lb, NULL, tdef.bgcolor().argb());
for (size_t k=0; k<tm.line_pos.size(); ++k)
@@ -580,7 +580,7 @@
lb.MoveTo(x0, y0);
lb.LineTo(x1, y1);
- m_serenderer->DrawScreenPolyline(&lb, tdef.color().argb(), line_width);
+ m_serenderer->DrawScreenPolyline(&lb, NULL, tdef.color().argb(), line_width);
@@ -667,7 +667,7 @@
lb.MoveTo(sx, sy);
lb.LineTo(ex, ey);
last_x = ex;
last_y = ey;
Modified: trunk/MgDev/Common/Stylization/SE_LineBuffer.cpp
--- trunk/MgDev/Common/Stylization/SE_LineBuffer.cpp 2007-03-15 16:46:45 UTC (rev 1242)
+++ trunk/MgDev/Common/Stylization/SE_LineBuffer.cpp 2007-03-15 18:43:22 UTC (rev 1243)
@@ -357,13 +357,11 @@
m_xf_tol(-1.0),
m_xf_weight(-1.0),
m_xf_bounds(NULL),
- m_inst_bounds(NULL),
m_compute_bounds(true)
m_pts = new double[size*2];
m_segs = new SE_LB_SegType[size];
m_xf_buf = new SE_LineStorage(size);
- m_inst_buf = new SE_LineStorage(size);
SE_LineBuffer::~SE_LineBuffer()
@@ -371,7 +369,6 @@
delete[] m_pts;
delete[] m_segs;
delete m_xf_buf;
- delete m_inst_buf;
void SE_LineBuffer::MoveTo(double x, double y)
@@ -478,15 +475,9 @@
m_xf_bounds->Free();
m_xf_bounds = NULL;
- if (m_inst_bounds)
- m_inst_bounds->Free();
- m_inst_bounds = NULL;
m_xf_tol = m_xf_weight = -1.0;
m_xf.setIdentity();
m_xf_buf->Reset();
- m_inst_buf->Reset();
void SE_LineBuffer::ResizeBuffer(void** buffer, int unitsize, int mininc, int cur_pts, int& max_pts)
@@ -637,26 +628,6 @@
return m_xf_buf;
-LineBuffer* SE_LineBuffer::TransformInstance(const SE_Matrix& xform)
- m_inst_buf->SetToTransform(xform, m_xf_buf);
- if (m_xf_bounds && m_compute_bounds)
- m_inst_bounds = m_pool->NewBounds(m_xf_bounds->size);
- m_inst_bounds->Transform(xform, m_xf_bounds);
- m_inst_buf->SetBounds(m_inst_bounds);
- return m_inst_buf;
bool SE_LineBuffer::Empty()
return m_npts == 0;
@@ -730,10 +701,7 @@
clone->m_xf_weight = m_xf_weight;
if (m_xf_bounds)
clone->m_xf_bounds = m_xf_bounds->Clone();
- clone->m_inst_bounds = m_inst_bounds->Clone();
clone->m_xf_buf->SetToCopy(m_xf_buf);
- clone->m_inst_buf->SetToCopy(m_inst_buf);
int grow_segs = m_nsegs - clone->m_max_segs;
if (grow_segs > 0)
ResizeBuffer((void**)&clone->m_segs, sizeof(double), grow_segs, clone->m_nsegs, clone->m_max_segs);
Modified: trunk/MgDev/Common/Stylization/SE_LineBuffer.h
--- trunk/MgDev/Common/Stylization/SE_LineBuffer.h 2007-03-15 16:46:45 UTC (rev 1242)
+++ trunk/MgDev/Common/Stylization/SE_LineBuffer.h 2007-03-15 18:43:22 UTC (rev 1243)
@@ -61,13 +61,10 @@
STYLIZATION_API void Free();
STYLIZATION_API LineBuffer* Transform(const SE_Matrix& xform, double weight = 0.0, double tolerance = .25);
- STYLIZATION_API LineBuffer* TransformInstance(const SE_Matrix& xform);
STYLIZATION_API SE_INLINE bool& compute_bounds() { return m_compute_bounds; }
STYLIZATION_API SE_INLINE LineBuffer* xf_buffer() { return (LineBuffer*)m_xf_buf; }
- STYLIZATION_API SE_INLINE LineBuffer* inst_buffer() { return (LineBuffer*)m_inst_buf; }
STYLIZATION_API SE_INLINE SE_Bounds* xf_bounds() { return m_xf_bounds; }
- STYLIZATION_API SE_INLINE SE_Bounds* inst_bounds() { return m_inst_bounds; }
STYLIZATION_API SE_LineBuffer* Clone();
@@ -97,9 +94,6 @@
SE_Bounds* m_xf_bounds;
SE_LineStorage* m_xf_buf;
- SE_Bounds* m_inst_bounds;
- SE_LineStorage* m_inst_buf;
/* TODO: write a stack based allocator for this, or replace it */
std::set<std::pair<double, double>, PointLess> m_ch_ptbuf;
Modified: trunk/MgDev/Common/Stylization/SE_Renderer.cpp
--- trunk/MgDev/Common/Stylization/SE_Renderer.cpp 2007-03-15 16:46:45 UTC (rev 1242)
+++ trunk/MgDev/Common/Stylization/SE_Renderer.cpp 2007-03-15 18:43:22 UTC (rev 1243)
@@ -235,7 +235,9 @@
//ok, it's only a solid line, just draw it and bail out of the
//layout function
- DrawScreenPolyline(geometry, rp->color, rp->weight);
+ SE_Matrix m;
+ GetWorldToScreenTransform(m);
+ DrawScreenPolyline(geometry, &m, rp->color, rp->weight);
return;
@@ -341,21 +343,21 @@
SE_RenderPolyline* pl = (SE_RenderPolyline*)primitive;
- LineBuffer* geometry = pl->geometry->TransformInstance(posxform);
+ LineBuffer* geometry = pl->geometry->xf_buffer();
if (m_bSelectionMode)
if (primitive->type == SE_PolygonPrimitive)
- DrawScreenPolygon( geometry, m_selFill);
+ DrawScreenPolygon( geometry, &posxform, m_selFill);
- DrawScreenPolyline( geometry, m_selColor, m_selWeight );
+ DrawScreenPolyline( geometry, &posxform, m_selColor, m_selWeight );
else
- DrawScreenPolygon( geometry, ((SE_RenderPolygon*)primitive)->fill );
+ DrawScreenPolygon( geometry, &posxform, ((SE_RenderPolygon*)primitive)->fill );
- DrawScreenPolyline( geometry, pl->color, pl->weight );
+ DrawScreenPolyline( geometry, &posxform, pl->color, pl->weight );
else if (primitive->type == SE_TextPrimitive)
Modified: trunk/MgDev/Common/Stylization/SE_Renderer.h
--- trunk/MgDev/Common/Stylization/SE_Renderer.h 2007-03-15 16:46:45 UTC (rev 1242)
+++ trunk/MgDev/Common/Stylization/SE_Renderer.h 2007-03-15 18:43:22 UTC (rev 1243)
@@ -36,8 +36,8 @@
STYLIZATION_API virtual void DrawSymbol(SE_RenderPrimitiveList& symbol, const SE_Matrix& xform, double anglerad);
- virtual void DrawScreenPolyline(LineBuffer* polyline, unsigned int color, double weight) = 0; // px
- virtual void DrawScreenPolygon(LineBuffer* polygon, unsigned int fill) = 0;
+ virtual void DrawScreenPolyline(LineBuffer* polyline, const SE_Matrix* xform, unsigned int color, double weight) = 0; // px
+ virtual void DrawScreenPolygon(LineBuffer* polygon, const SE_Matrix* xform, unsigned int fill) = 0;
double x, double y, double w, double h, double angledeg) = 0;
virtual void DrawScreenText(const RS_String& txt, RS_TextDef& tdef, double insx, double insy, double* path, int npts, double param_position) = 0;
More information about the mapguide-commits
