[mapguide-commits] r1248 - trunk/MgDev/Common/MdfParser
svn_mapguide at osgeo.org
Fri Mar 16 00:48:09 EDT 2007
Author: ronnielouie
Date: 2007-03-16 00:48:08 -0400 (Fri, 16 Mar 2007)
New Revision: 1248
trunk/MgDev/Common/MdfParser/IOAreaRule.cpp
trunk/MgDev/Common/MdfParser/IOAreaRule.h
trunk/MgDev/Common/MdfParser/IOAreaSymbolization2D.cpp
trunk/MgDev/Common/MdfParser/IOAreaSymbolization2D.h
trunk/MgDev/Common/MdfParser/IOAreaTypeStyle.cpp
trunk/MgDev/Common/MdfParser/IOAreaTypeStyle.h
trunk/MgDev/Common/MdfParser/IOLineRule.cpp
trunk/MgDev/Common/MdfParser/IOLineRule.h
trunk/MgDev/Common/MdfParser/IOLineSymbolization2D.cpp
trunk/MgDev/Common/MdfParser/IOLineSymbolization2D.h
trunk/MgDev/Common/MdfParser/IOLineTypeStyle.cpp
trunk/MgDev/Common/MdfParser/IOLineTypeStyle.h
trunk/MgDev/Common/MdfParser/IOMarkSymbol.cpp
trunk/MgDev/Common/MdfParser/IOMarkSymbol.h
trunk/MgDev/Common/MdfParser/IOPointRule.cpp
trunk/MgDev/Common/MdfParser/IOPointRule.h
trunk/MgDev/Common/MdfParser/IOPointSymbolization2D.cpp
trunk/MgDev/Common/MdfParser/IOPointSymbolization2D.h
trunk/MgDev/Common/MdfParser/IOPointTypeStyle.cpp
trunk/MgDev/Common/MdfParser/IOPointTypeStyle.h
trunk/MgDev/Common/MdfParser/IOStroke.cpp
trunk/MgDev/Common/MdfParser/IOStroke.h
trunk/MgDev/Common/MdfParser/IOVectorLayerDefinition.cpp
trunk/MgDev/Common/MdfParser/IOVectorScaleRange.cpp
trunk/MgDev/Common/MdfParser/IOVectorScaleRange.h
When writing to a previous version layer definition, only those elements that are defined in that version's schema should be output. This submission handles the SizeContext which is new to the Stroke type in LayerDefinition-1.1.0.xsd.
Modified: trunk/MgDev/Common/MdfParser/IOAreaRule.cpp
--- trunk/MgDev/Common/MdfParser/IOAreaRule.cpp 2007-03-16 00:10:53 UTC (rev 1247)
+++ trunk/MgDev/Common/MdfParser/IOAreaRule.cpp 2007-03-16 04:48:08 UTC (rev 1248)
@@ -108,7 +108,7 @@
-void IOAreaRule::Write(MdfStream &fd, AreaRule *areaRule)
+void IOAreaRule::Write(MdfStream &fd, AreaRule *areaRule, Version *version)
fd << tab() << "<AreaRule>" << std::endl; // NOXLATE
inctab();
@@ -137,7 +137,7 @@
//Property: Symbolization
AreaSymbolization2D *symbolization = areaRule->GetSymbolization();
IOAreaSymbolization2D *IO = new IOAreaSymbolization2D();
- IO->Write(fd, symbolization);
+ IO->Write(fd, symbolization, version);
delete IO;
// Write any previously found unknown XML
Modified: trunk/MgDev/Common/MdfParser/IOAreaRule.h
--- trunk/MgDev/Common/MdfParser/IOAreaRule.h 2007-03-16 00:10:53 UTC (rev 1247)
+++ trunk/MgDev/Common/MdfParser/IOAreaRule.h 2007-03-16 04:48:08 UTC (rev 1248)
@@ -21,6 +21,7 @@
#include "SAX2ElementHandler.h"
#include "AreaRule.h"
#include "AreaTypeStyle.h"
+#include "Version.h"
using namespace XERCES_CPP_NAMESPACE;
using namespace MDFMODEL_NAMESPACE;
@@ -37,7 +38,7 @@
IOAreaRule();
IOAreaRule(AreaTypeStyle * areaTypeStyle);
~IOAreaRule();
- void Write(MdfStream &fd, AreaRule *areaRule);
+ void Write(MdfStream &fd, AreaRule *areaRule, Version *version = NULL);
virtual void StartElement(const wchar_t *name, HandlerStack *handlerStack);
virtual void ElementChars(const wchar_t *ch);
Modified: trunk/MgDev/Common/MdfParser/IOAreaSymbolization2D.cpp
--- trunk/MgDev/Common/MdfParser/IOAreaSymbolization2D.cpp 2007-03-16 00:10:53 UTC (rev 1247)
+++ trunk/MgDev/Common/MdfParser/IOAreaSymbolization2D.cpp 2007-03-16 04:48:08 UTC (rev 1248)
@@ -109,7 +109,7 @@
-void IOAreaSymbolization2D::Write(MdfStream &fd, AreaSymbolization2D * areaSymbolization)
+void IOAreaSymbolization2D::Write(MdfStream &fd, AreaSymbolization2D * areaSymbolization, Version* version)
fd << tab() << "<AreaSymbolization2D>" << std::endl; // NOXLATE
inctab();
@@ -120,7 +120,7 @@
//Property: Edge
if (areaSymbolization != NULL && areaSymbolization->GetEdge() != NULL)
- IOStroke::Write(fd, areaSymbolization->GetEdge(), "Stroke"); // NOXLATE
+ IOStroke::Write(fd, areaSymbolization->GetEdge(), "Stroke", version); // NOXLATE
if (areaSymbolization != NULL && !areaSymbolization->GetUnknownXml().empty())
Modified: trunk/MgDev/Common/MdfParser/IOAreaSymbolization2D.h
--- trunk/MgDev/Common/MdfParser/IOAreaSymbolization2D.h 2007-03-16 00:10:53 UTC (rev 1247)
+++ trunk/MgDev/Common/MdfParser/IOAreaSymbolization2D.h 2007-03-16 04:48:08 UTC (rev 1248)
@@ -21,6 +21,7 @@
#include "AreaSymbolization2D.h"
@@ -36,7 +37,7 @@
IOAreaSymbolization2D(AreaRule * areaRule);
~IOAreaSymbolization2D();
- void Write(MdfStream &fd, AreaSymbolization2D * areaSymbolization);
+ void Write(MdfStream &fd, AreaSymbolization2D * areaSymbolization, Version *version = NULL);
Modified: trunk/MgDev/Common/MdfParser/IOAreaTypeStyle.cpp
--- trunk/MgDev/Common/MdfParser/IOAreaTypeStyle.cpp 2007-03-16 00:10:53 UTC (rev 1247)
+++ trunk/MgDev/Common/MdfParser/IOAreaTypeStyle.cpp 2007-03-16 04:48:08 UTC (rev 1248)
@@ -93,7 +93,7 @@
-void IOAreaTypeStyle::Write(MdfStream &fd, AreaTypeStyle * areaTypeStyle)
+void IOAreaTypeStyle::Write(MdfStream &fd, AreaTypeStyle * areaTypeStyle, Version *version)
fd << tab() << "<AreaTypeStyle>" << std::endl; // NOXLATE
inctab();
@@ -102,7 +102,7 @@
for (int x = 0; x < areaTypeStyle->GetRules()->GetCount(); x++)
IOAreaRule *IO = new IOAreaRule();
- IO->Write(fd, static_cast<AreaRule*>(areaTypeStyle->GetRules()->GetAt(x)));
+ IO->Write(fd, static_cast<AreaRule*>(areaTypeStyle->GetRules()->GetAt(x)), version);
delete IO;
Modified: trunk/MgDev/Common/MdfParser/IOAreaTypeStyle.h
--- trunk/MgDev/Common/MdfParser/IOAreaTypeStyle.h 2007-03-16 00:10:53 UTC (rev 1247)
+++ trunk/MgDev/Common/MdfParser/IOAreaTypeStyle.h 2007-03-16 04:48:08 UTC (rev 1248)
@@ -21,6 +21,7 @@
#include "VectorScaleRange.h"
@@ -36,7 +37,7 @@
IOAreaTypeStyle();
IOAreaTypeStyle(VectorScaleRange * scaleRange);
~IOAreaTypeStyle();
- void Write(MdfStream &fd, AreaTypeStyle * areaTypeStyle);
+ void Write(MdfStream &fd, AreaTypeStyle * areaTypeStyle, Version *version = NULL);
Modified: trunk/MgDev/Common/MdfParser/IOLineRule.cpp
--- trunk/MgDev/Common/MdfParser/IOLineRule.cpp 2007-03-16 00:10:53 UTC (rev 1247)
+++ trunk/MgDev/Common/MdfParser/IOLineRule.cpp 2007-03-16 04:48:08 UTC (rev 1248)
@@ -108,7 +108,7 @@
-void IOLineRule::Write(MdfStream &fd, LineRule *lineRule)
+void IOLineRule::Write(MdfStream &fd, LineRule *lineRule, Version *version)
fd << tab() << "<LineRule>" << std::endl; // NOXLATE
inctab();
@@ -137,7 +137,7 @@
for (int x = 0; x < lineRule->GetSymbolizations()->GetCount(); x++)
IOLineSymbolization2D *IO = new IOLineSymbolization2D();
- IO->Write(fd, lineRule->GetSymbolizations()->GetAt(x));
+ IO->Write(fd, lineRule->GetSymbolizations()->GetAt(x), version);
delete IO;
Modified: trunk/MgDev/Common/MdfParser/IOLineRule.h
--- trunk/MgDev/Common/MdfParser/IOLineRule.h 2007-03-16 00:10:53 UTC (rev 1247)
+++ trunk/MgDev/Common/MdfParser/IOLineRule.h 2007-03-16 04:48:08 UTC (rev 1248)
@@ -21,6 +21,7 @@
#include "LineRule.h"
#include "LineTypeStyle.h"
@@ -36,7 +37,7 @@
IOLineRule();
IOLineRule(LineTypeStyle * lineTypeStyle);
~IOLineRule();
- void Write(MdfStream &fd, LineRule *lineRule);
+ void Write(MdfStream &fd, LineRule *lineRule, Version *version = NULL);
Modified: trunk/MgDev/Common/MdfParser/IOLineSymbolization2D.cpp
--- trunk/MgDev/Common/MdfParser/IOLineSymbolization2D.cpp 2007-03-16 00:10:53 UTC (rev 1247)
+++ trunk/MgDev/Common/MdfParser/IOLineSymbolization2D.cpp 2007-03-16 04:48:08 UTC (rev 1248)
@@ -29,6 +29,7 @@
ELEM_MAP_ENTRY(3, Thickness);
ELEM_MAP_ENTRY(4, Color);
ELEM_MAP_ENTRY(5, Unit);
+ELEM_MAP_ENTRY(6, SizeContext);
IOLineSymbolization2D::IOLineSymbolization2D()
@@ -80,6 +81,13 @@
LengthUnit unit = LengthConverter::EnglishToUnit(ch);
this->_lineSymbolization->GetStroke()->SetUnit(unit);
+ else if (m_currElemName == L"SizeContext") // NOXLATE
+ if (::wcscmp(ch, L"MappingUnits") == 0) // NOXLATE
+ this->_lineSymbolization->GetStroke()->SetSizeContext(MdfModel::MappingUnits);
+ else if (::wcscmp(ch, L"DeviceUnits") == 0) // NOXLATE
+ this->_lineSymbolization->GetStroke()->SetSizeContext(MdfModel::DeviceUnits);
void IOLineSymbolization2D::EndElement(const wchar_t *name, HandlerStack *handlerStack)
@@ -98,7 +106,7 @@
-void IOLineSymbolization2D::Write(MdfStream &fd, LineSymbolization2D *lineSymbolization)
+void IOLineSymbolization2D::Write(MdfStream &fd, LineSymbolization2D *lineSymbolization, Version *version)
//Property: Stroke
if (lineSymbolization->GetStroke())
@@ -127,6 +135,32 @@
fd << EncodeString(*str);
fd << endStr(sUnit) << std::endl;
+ //Property: SizeContext
+ // Only write SizeContext if the version is not less than 1.1
+ bool bWriteSizeContext = true;
+ if (version != NULL)
+ int nMajor = version->GetMajor();
+ int nMinor = version->GetMinor();
+ double scalerMajorMinorVersion = ( (double)version->GetMajor() ) * 1.0 + ( (double)version->GetMinor() ) * 0.1;
+ bWriteSizeContext = (scalerMajorMinorVersion >= 1.1);
+ if (bWriteSizeContext)
+ fd << tab() << "<SizeContext>"; // NOXLATE
+ if(lineSymbolization->GetStroke()->GetSizeContext() == MdfModel::MappingUnits)
+ fd << "MappingUnits"; // NOXLATE
+ else
+ fd << "DeviceUnits"; // NOXLATE
+ fd << "</SizeContext>" << std::endl; // NOXLATE
if (!lineSymbolization->GetUnknownXml().empty())
Modified: trunk/MgDev/Common/MdfParser/IOLineSymbolization2D.h
--- trunk/MgDev/Common/MdfParser/IOLineSymbolization2D.h 2007-03-16 00:10:53 UTC (rev 1247)
+++ trunk/MgDev/Common/MdfParser/IOLineSymbolization2D.h 2007-03-16 04:48:08 UTC (rev 1248)
@@ -21,6 +21,7 @@
#include "LineSymbolization2D.h"
@@ -37,7 +38,7 @@
IOLineSymbolization2D(LineRule * lineRule);
~IOLineSymbolization2D();
- void Write(MdfStream &fd, LineSymbolization2D *lineSymbolization);
+ void Write(MdfStream &fd, LineSymbolization2D *lineSymbolization, Version *version = NULL);
Modified: trunk/MgDev/Common/MdfParser/IOLineTypeStyle.cpp
--- trunk/MgDev/Common/MdfParser/IOLineTypeStyle.cpp 2007-03-16 00:10:53 UTC (rev 1247)
+++ trunk/MgDev/Common/MdfParser/IOLineTypeStyle.cpp 2007-03-16 04:48:08 UTC (rev 1248)
@@ -93,7 +93,7 @@
-void IOLineTypeStyle::Write(MdfStream &fd, LineTypeStyle *lineTypeStyle)
+void IOLineTypeStyle::Write(MdfStream &fd, LineTypeStyle *lineTypeStyle, Version *version)
fd << tab() << "<LineTypeStyle>" << std::endl; // NOXLATE
inctab();
@@ -102,7 +102,7 @@
for (int x = 0; x < lineTypeStyle->GetRules()->GetCount(); x++)
IOLineRule *IO = new IOLineRule();
- IO->Write(fd, static_cast<LineRule*>(lineTypeStyle->GetRules()->GetAt(x)));
+ IO->Write(fd, static_cast<LineRule*>(lineTypeStyle->GetRules()->GetAt(x)), version);
delete IO;
Modified: trunk/MgDev/Common/MdfParser/IOLineTypeStyle.h
--- trunk/MgDev/Common/MdfParser/IOLineTypeStyle.h 2007-03-16 00:10:53 UTC (rev 1247)
+++ trunk/MgDev/Common/MdfParser/IOLineTypeStyle.h 2007-03-16 04:48:08 UTC (rev 1248)
@@ -21,6 +21,7 @@
@@ -37,7 +38,7 @@
IOLineTypeStyle();
IOLineTypeStyle(VectorScaleRange * scaleRange);
~IOLineTypeStyle();
- void Write(MdfStream &fd, LineTypeStyle *lineTypeStyle);
+ void Write(MdfStream &fd, LineTypeStyle *lineTypeStyle, Version *version);
Modified: trunk/MgDev/Common/MdfParser/IOMarkSymbol.cpp
--- trunk/MgDev/Common/MdfParser/IOMarkSymbol.cpp 2007-03-16 00:10:53 UTC (rev 1247)
+++ trunk/MgDev/Common/MdfParser/IOMarkSymbol.cpp 2007-03-16 04:48:08 UTC (rev 1248)
@@ -130,7 +130,7 @@
-void IOMarkSymbol::Write(MdfStream &fd, MarkSymbol *symbol)
+void IOMarkSymbol::Write(MdfStream &fd, MarkSymbol *symbol, Version *version)
fd << tab() << "<Mark>" << std::endl; // NOXLATE
inctab();
@@ -159,7 +159,7 @@
//Property: Edge
if (symbol->GetEdge() != NULL)
- IOStroke::Write(fd, symbol->GetEdge(), "Edge"); // NOXLATE
+ IOStroke::Write(fd, symbol->GetEdge(), "Edge", version); // NOXLATE
if (!symbol->GetUnknownXml().empty())
Modified: trunk/MgDev/Common/MdfParser/IOMarkSymbol.h
--- trunk/MgDev/Common/MdfParser/IOMarkSymbol.h 2007-03-16 00:10:53 UTC (rev 1247)
+++ trunk/MgDev/Common/MdfParser/IOMarkSymbol.h 2007-03-16 04:48:08 UTC (rev 1248)
@@ -40,7 +40,7 @@
virtual void EndElement(const wchar_t *name, HandlerStack *handlerStack);
- static void Write(MdfStream &fd, MarkSymbol *markSymbol);
+ static void Write(MdfStream &fd, MarkSymbol *markSymbol, Version *version = NULL);
END_NAMESPACE_MDFPARSER
Modified: trunk/MgDev/Common/MdfParser/IOPointRule.cpp
--- trunk/MgDev/Common/MdfParser/IOPointRule.cpp 2007-03-16 00:10:53 UTC (rev 1247)
+++ trunk/MgDev/Common/MdfParser/IOPointRule.cpp 2007-03-16 04:48:08 UTC (rev 1248)
@@ -108,7 +108,7 @@
-void IOPointRule::Write(MdfStream &fd, PointRule *pointRule)
+void IOPointRule::Write(MdfStream &fd, PointRule *pointRule, Version *version)
fd << tab() << "<PointRule>" << std::endl; // NOXLATE
inctab();
@@ -138,7 +138,7 @@
if (symbolization2d != NULL)
IOPointSymbolization2D *IO = new IOPointSymbolization2D();
- IO->Write(fd, symbolization2d);
+ IO->Write(fd, symbolization2d, version);
delete IO;
Modified: trunk/MgDev/Common/MdfParser/IOPointRule.h
--- trunk/MgDev/Common/MdfParser/IOPointRule.h 2007-03-16 00:10:53 UTC (rev 1247)
+++ trunk/MgDev/Common/MdfParser/IOPointRule.h 2007-03-16 04:48:08 UTC (rev 1248)
@@ -21,6 +21,7 @@
#include "PointRule.h"
#include "PointTypeStyle.h"
@@ -37,7 +38,7 @@
IOPointRule();
IOPointRule(PointTypeStyle * pointTypeStyle);
~IOPointRule();
- void Write(MdfStream &fd, PointRule * pointRule);
+ void Write(MdfStream &fd, PointRule * pointRule, Version *version = NULL);
Modified: trunk/MgDev/Common/MdfParser/IOPointSymbolization2D.cpp
--- trunk/MgDev/Common/MdfParser/IOPointSymbolization2D.cpp 2007-03-16 00:10:53 UTC (rev 1247)
+++ trunk/MgDev/Common/MdfParser/IOPointSymbolization2D.cpp 2007-03-16 04:48:08 UTC (rev 1248)
@@ -125,7 +125,7 @@
-void IOPointSymbolization2D::Write(MdfStream &fd, PointSymbolization2D *PointSymbolization2D)
+void IOPointSymbolization2D::Write(MdfStream &fd, PointSymbolization2D *PointSymbolization2D, Version *version)
fd << tab() << "<PointSymbolization2D>" << std::endl; // NOXLATE
inctab();
@@ -137,7 +137,7 @@
W2DSymbol* w2DSymbol = dynamic_cast<W2DSymbol*>(PointSymbolization2D->GetSymbol());
BlockSymbol* blockSymbol = dynamic_cast<BlockSymbol*>(PointSymbolization2D->GetSymbol());
if (markSymbol)
- IOMarkSymbol::Write(fd, markSymbol);
+ IOMarkSymbol::Write(fd, markSymbol, version);
else if (imageSymbol)
IOImageSymbol::Write(fd, imageSymbol);
else if (fontSymbol)
Modified: trunk/MgDev/Common/MdfParser/IOPointSymbolization2D.h
--- trunk/MgDev/Common/MdfParser/IOPointSymbolization2D.h 2007-03-16 00:10:53 UTC (rev 1247)
+++ trunk/MgDev/Common/MdfParser/IOPointSymbolization2D.h 2007-03-16 04:48:08 UTC (rev 1248)
@@ -22,6 +22,7 @@
#include "PointSymbolization2D.h"
#include "IOSymbol.h"
@@ -39,7 +40,7 @@
IOPointSymbolization2D(PointRule * pointRule);
~IOPointSymbolization2D();
- void Write(MdfStream &fd, PointSymbolization2D * PointSymbolization2D);
+ void Write(MdfStream &fd, PointSymbolization2D * PointSymbolization2D, Version *version = NULL);
Modified: trunk/MgDev/Common/MdfParser/IOPointTypeStyle.cpp
--- trunk/MgDev/Common/MdfParser/IOPointTypeStyle.cpp 2007-03-16 00:10:53 UTC (rev 1247)
+++ trunk/MgDev/Common/MdfParser/IOPointTypeStyle.cpp 2007-03-16 04:48:08 UTC (rev 1248)
@@ -98,7 +98,7 @@
-void IOPointTypeStyle::Write(MdfStream &fd, PointTypeStyle *pointTypeStyle)
+void IOPointTypeStyle::Write(MdfStream &fd, PointTypeStyle *pointTypeStyle, Version *version)
fd << tab() << "<PointTypeStyle>" << std::endl; // NOXLATE
inctab();
@@ -117,7 +117,7 @@
for (int x = 0; x < pointTypeStyle->GetRules()->GetCount(); x++)
IOPointRule *IO = new IOPointRule();
- IO->Write(fd, static_cast<PointRule*>(pointTypeStyle->GetRules()->GetAt(x)));
+ IO->Write(fd, static_cast<PointRule*>(pointTypeStyle->GetRules()->GetAt(x)), version);
delete IO;
Modified: trunk/MgDev/Common/MdfParser/IOPointTypeStyle.h
--- trunk/MgDev/Common/MdfParser/IOPointTypeStyle.h 2007-03-16 00:10:53 UTC (rev 1247)
+++ trunk/MgDev/Common/MdfParser/IOPointTypeStyle.h 2007-03-16 04:48:08 UTC (rev 1248)
@@ -21,6 +21,7 @@
@@ -37,7 +38,7 @@
IOPointTypeStyle();
IOPointTypeStyle(VectorScaleRange * scaleRange);
~IOPointTypeStyle();
- void Write(MdfStream &fd, PointTypeStyle * pointTypeStyle);
+ void Write(MdfStream &fd, PointTypeStyle * pointTypeStyle, Version *version = NULL);
Modified: trunk/MgDev/Common/MdfParser/IOStroke.cpp
--- trunk/MgDev/Common/MdfParser/IOStroke.cpp 2007-03-16 00:10:53 UTC (rev 1247)
+++ trunk/MgDev/Common/MdfParser/IOStroke.cpp 2007-03-16 04:48:08 UTC (rev 1248)
@@ -111,7 +111,7 @@
-void IOStroke::Write(MdfStream &fd, Stroke *stroke, std::string name)
+void IOStroke::Write(MdfStream &fd, Stroke *stroke, std::string name, Version *version)
fd << tab() << "<" << name << ">" << std::endl; // NOXLATE
inctab();
@@ -138,16 +138,30 @@
fd << "</Unit>" << std::endl; // NOXLATE
- fd << tab() << "<SizeContext>"; // NOXLATE
- if(stroke->GetSizeContext() == MdfModel::MappingUnits)
- fd << "MappingUnits"; // NOXLATE
- else
- fd << "DeviceUnits"; // NOXLATE
+ if(stroke->GetSizeContext() == MdfModel::MappingUnits)
+ else
- fd << "</SizeContext>" << std::endl; // NOXLATE
if (!stroke->GetUnknownXml().empty())
Modified: trunk/MgDev/Common/MdfParser/IOStroke.h
--- trunk/MgDev/Common/MdfParser/IOStroke.h 2007-03-16 00:10:53 UTC (rev 1247)
+++ trunk/MgDev/Common/MdfParser/IOStroke.h 2007-03-16 04:48:08 UTC (rev 1248)
@@ -20,6 +20,7 @@
#include "Stroke.h"
@@ -36,7 +37,7 @@
IOStroke(std::wstring elementName);
IOStroke(Stroke * stroke, std::wstring elementName);
~IOStroke();
- static void Write(MdfStream &fd, Stroke *stroke, std::string name);
+ static void Write(MdfStream &fd, Stroke *stroke, std::string name, Version *version = NULL);
Modified: trunk/MgDev/Common/MdfParser/IOVectorLayerDefinition.cpp
--- trunk/MgDev/Common/MdfParser/IOVectorLayerDefinition.cpp 2007-03-16 00:10:53 UTC (rev 1247)
+++ trunk/MgDev/Common/MdfParser/IOVectorLayerDefinition.cpp 2007-03-16 04:48:08 UTC (rev 1248)
@@ -232,7 +232,7 @@
for (int x = 0; x < featureLayer->GetScaleRanges()->GetCount(); x++)
IOVectorScaleRange * IO = new IOVectorScaleRange();
- IO->Write(fd, featureLayer->GetScaleRanges()->GetAt(x));
+ IO->Write(fd, featureLayer->GetScaleRanges()->GetAt(x), version);
delete IO;
Modified: trunk/MgDev/Common/MdfParser/IOVectorScaleRange.cpp
--- trunk/MgDev/Common/MdfParser/IOVectorScaleRange.cpp 2007-03-16 00:10:53 UTC (rev 1247)
+++ trunk/MgDev/Common/MdfParser/IOVectorScaleRange.cpp 2007-03-16 04:48:08 UTC (rev 1248)
@@ -140,7 +140,7 @@
-void IOVectorScaleRange::Write(MdfStream &fd, VectorScaleRange *scaleRange)
+void IOVectorScaleRange::Write(MdfStream &fd, VectorScaleRange *scaleRange, Version* version)
fd << tab() << "<VectorScaleRange>" << std::endl; // NOXLATE
inctab();
@@ -167,19 +167,19 @@
if (dynamic_cast<AreaTypeStyle*>(scaleRange->GetFeatureTypeStyles()->GetAt(x)) != 0)
IOAreaTypeStyle * IO = new IOAreaTypeStyle();
- IO->Write(fd, dynamic_cast<AreaTypeStyle*>(scaleRange->GetFeatureTypeStyles()->GetAt(x)));
+ IO->Write(fd, dynamic_cast<AreaTypeStyle*>(scaleRange->GetFeatureTypeStyles()->GetAt(x)), version);
delete IO;
else if (dynamic_cast<LineTypeStyle*>(scaleRange->GetFeatureTypeStyles()->GetAt(x)) != 0)
IOLineTypeStyle * IO = new IOLineTypeStyle();
- IO->Write(fd, dynamic_cast<LineTypeStyle*>(scaleRange->GetFeatureTypeStyles()->GetAt(x)));
+ IO->Write(fd, dynamic_cast<LineTypeStyle*>(scaleRange->GetFeatureTypeStyles()->GetAt(x)), version);
delete IO;
else if (dynamic_cast<PointTypeStyle*>(scaleRange->GetFeatureTypeStyles()->GetAt(x)) != 0)
IOPointTypeStyle * IO = new IOPointTypeStyle();
- IO->Write(fd, dynamic_cast<PointTypeStyle*>(scaleRange->GetFeatureTypeStyles()->GetAt(x)));
+ IO->Write(fd, dynamic_cast<PointTypeStyle*>(scaleRange->GetFeatureTypeStyles()->GetAt(x)), version);
delete IO;
else if (dynamic_cast<CompositeTypeStyle*>(scaleRange->GetFeatureTypeStyles()->GetAt(x)) != 0)
Modified: trunk/MgDev/Common/MdfParser/IOVectorScaleRange.h
--- trunk/MgDev/Common/MdfParser/IOVectorScaleRange.h 2007-03-16 00:10:53 UTC (rev 1247)
+++ trunk/MgDev/Common/MdfParser/IOVectorScaleRange.h 2007-03-16 04:48:08 UTC (rev 1248)
@@ -21,6 +21,7 @@
#include "VectorLayerDefinition.h"
@@ -37,7 +38,7 @@
IOVectorScaleRange(VectorLayerDefinition * layer);
~IOVectorScaleRange();
- void Write(MdfStream &fd, VectorScaleRange *scaleRange);
+ void Write(MdfStream &fd, VectorScaleRange *scaleRange, Version *version = NULL);
More information about the mapguide-commits
