[mapguide-commits] r1259 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Fri Mar 16 14:08:15 EDT 2007
Author: waltweltonlair
Date: 2007-03-16 14:08:15 -0400 (Fri, 16 Mar 2007)
New Revision: 1259
trunk/MgDev/Common/Stylization/RS_FeatureReader.h
trunk/MgDev/Common/Stylization/StylizationEngine.cpp
trunk/MgDev/Common/Stylization/StylizationEngine.h
Add support for rendering passes. We start with render pass 0, and draw all
styles whose pass evaluates to 0. If a style has a pass which doesn't evaluate
to 0 we keep track of that for the next pass (we find the next requested pass
after 0). Then we do the next pass using the next requested pass value. Again
we keep track of what the next pass needs to be. We keep drawing passes like
this until no more are required.
Modified: trunk/MgDev/Common/Stylization/RS_FeatureReader.h
--- trunk/MgDev/Common/Stylization/RS_FeatureReader.h 2007-03-16 18:03:09 UTC (rev 1258)
+++ trunk/MgDev/Common/Stylization/RS_FeatureReader.h 2007-03-16 18:08:15 UTC (rev 1259)
@@ -27,33 +27,32 @@
class RS_FeatureReader
public:
+ virtual bool ReadNext() = 0;
+ virtual void Close () = 0;
+ virtual void Reset () = 0;
- virtual bool ReadNext () = 0;
- virtual void Close () = 0;
- virtual bool IsNull (const wchar_t* propertyName) = 0;
- virtual bool GetBoolean (const wchar_t* propertyName) = 0;
- virtual unsigned char GetByte (const wchar_t* propertyName) = 0;
- virtual FdoDateTime GetDateTime (const wchar_t* propertyName) = 0;
- virtual float GetSingle (const wchar_t* propertyName) = 0;
- virtual double GetDouble (const wchar_t* propertyName) = 0;
- virtual short GetInt16 (const wchar_t* propertyName) = 0;
- virtual int GetInt32 (const wchar_t* propertyName) = 0;
- virtual long long GetInt64 (const wchar_t* propertyName) = 0;
- virtual const wchar_t* GetString (const wchar_t* propertyName) = 0;
- virtual LineBuffer* GetGeometry (const wchar_t* propertyName,
- LineBuffer* lb,
- CSysTransformer* xformer
- ) = 0;
- virtual RS_Raster* GetRaster (const wchar_t* propertyName) = 0;
- virtual const wchar_t* GetAsString (const wchar_t* propertyName) = 0;
- virtual RS_InputStream* GetBLOB (const wchar_t* propertyName) = 0;
- virtual RS_InputStream* GetCLOB (const wchar_t* propertyName) = 0;
-// virtual MgFeatureReader* GetFeatureObject(std::wstring& propertyName) = 0;
- virtual int GetPropertyType(const wchar_t* propertyName) = 0;
- virtual const wchar_t* GetGeomPropName() = 0;
- virtual const wchar_t* GetRasterPropName() = 0;
- virtual const wchar_t*const* GetIdentPropNames(int& count) = 0;
- virtual const wchar_t*const* GetPropNames(int& count) = 0;
+ virtual bool IsNull (const wchar_t* propertyName) = 0;
+ virtual bool GetBoolean (const wchar_t* propertyName) = 0;
+ virtual unsigned char GetByte (const wchar_t* propertyName) = 0;
+ virtual FdoDateTime GetDateTime (const wchar_t* propertyName) = 0;
+ virtual float GetSingle (const wchar_t* propertyName) = 0;
+ virtual double GetDouble (const wchar_t* propertyName) = 0;
+ virtual short GetInt16 (const wchar_t* propertyName) = 0;
+ virtual int GetInt32 (const wchar_t* propertyName) = 0;
+ virtual long long GetInt64 (const wchar_t* propertyName) = 0;
+ virtual const wchar_t* GetString (const wchar_t* propertyName) = 0;
+ virtual LineBuffer* GetGeometry (const wchar_t* propertyName, LineBuffer* lb, CSysTransformer* xformer) = 0;
+ virtual RS_Raster* GetRaster (const wchar_t* propertyName) = 0;
+ virtual const wchar_t* GetAsString (const wchar_t* propertyName) = 0;
+ virtual RS_InputStream* GetBLOB (const wchar_t* propertyName) = 0;
+ virtual RS_InputStream* GetCLOB (const wchar_t* propertyName) = 0;
+// virtual MgFeatureReader* GetFeatureObject(const wchar_t* propertyName) = 0;
+ virtual int GetPropertyType (const wchar_t* propertyName) = 0;
+ virtual const wchar_t* GetGeomPropName () = 0;
+ virtual const wchar_t* GetRasterPropName() = 0;
+ virtual const wchar_t* const* GetIdentPropNames(int& count) = 0;
+ virtual const wchar_t* const* GetPropNames (int& count) = 0;
#endif
Modified: trunk/MgDev/Common/Stylization/StylizationEngine.cpp
--- trunk/MgDev/Common/Stylization/StylizationEngine.cpp 2007-03-16 18:03:09 UTC (rev 1258)
+++ trunk/MgDev/Common/Stylization/StylizationEngine.cpp 2007-03-16 18:08:15 UTC (rev 1259)
@@ -92,62 +92,75 @@
bool bClip = renderer->RequiresClipping();
+ // we always start with rendering pass 0
+ int renderingPass = 0;
+ int nextRenderingPass = -1;
#ifdef _DEBUG
int nFeatures = 0;
#endif
//main loop over feature data
- while (reader->ReadNext())
+ while (renderingPass >= 0)
- #ifdef _DEBUG
- nFeatures++;
- #endif
+ // for all but the first pass we need to reset the reader
+ if (renderingPass > 0)
+ reader->Reset();
- LineBuffer* lb = NULL;
+ while (reader->ReadNext())
+ #ifdef _DEBUG
+ if (renderingPass == 0)
+ nFeatures++;
+ #endif
- //get the geometry just once
- //all types of geometry
- lb = m_lbPool->NewLineBuffer(8);
- reader->GetGeometry(gpName, lb, xformer);
+ //get the geometry just once
+ //all types of geometry
+ LineBuffer* lb = m_lbPool->NewLineBuffer(8);
+ reader->GetGeometry(gpName, lb, xformer);
- if (lb && bClip)
- //clip geometry to given map request extents
- //TODO: is this the right place to do so?
- LineBuffer* lbc = lb->Clip(renderer->GetBounds(), LineBuffer::ctAGF, m_lbPool);
+ if (lb && bClip)
+ //clip geometry to given map request extents
+ //TODO: is this the right place to do so?
+ LineBuffer* lbc = lb->Clip(renderer->GetBounds(), LineBuffer::ctAGF, m_lbPool);
- //did geom require clipping?
- //free original line buffer
- //note original geometry is still accessible to the
- //user from the RS_FeatureReader::GetGeometry
- if (lbc != lb)
+ //did geom require clipping?
+ //free original line buffer
+ //note original geometry is still accessible to the
+ //user from the RS_FeatureReader::GetGeometry
+ if (lbc != lb)
+ m_lbPool->FreeLineBuffer(lb);
+ lb = lbc;
+ if (!lb) continue;
+ //need to clear out the filter execution engine cache
+ //some feature attributes may be cached while executing theming
+ //expressions and this call flushes that
+ executor->Reset();
+ // we need to stylize once for each FeatureTypeStyle that matches
+ // the geometry type (Note: this may have to change to match
+ // feature classes)
+ for (int i=0; i<ftsc->GetCount(); i++)
- m_lbPool->FreeLineBuffer(lb);
- lb = lbc;
+ MdfModel::FeatureTypeStyle* fts = ftsc->GetAt(i);
+ if (FeatureTypeStyleVisitor::DetermineFeatureTypeStyle(fts) == FeatureTypeStyleVisitor::ftsComposite)
+ Stylize(reader, executor, lb, (CompositeTypeStyle*)fts, &seTip, &seUrl, NULL, renderingPass, nextRenderingPass);
- if (!lb) continue;
+ if (lb)
+ m_lbPool->FreeLineBuffer(lb); // free geometry when done stylizing
- //need to clear out the filter execution engine cache
- //some feature attributes may be cached while executing theming
- //expressions and this call flushes that
- executor->Reset();
- // we need to stylize once for each FeatureTypeStyle that matches
- // the geometry type (Note: this may have to change to match
- // feature classes)
- for (int i=0; i<ftsc->GetCount(); i++)
- MdfModel::FeatureTypeStyle* fts = ftsc->GetAt(i);
- if (FeatureTypeStyleVisitor::DetermineFeatureTypeStyle(fts) == FeatureTypeStyleVisitor::ftsComposite)
- Stylize(reader, executor, lb, (CompositeTypeStyle*)fts, &seTip, &seUrl, NULL);
+ if (cancel && cancel(userData)) break;
- if (lb)
- m_lbPool->FreeLineBuffer(lb); // free geometry when done stylizing
- if (cancel && cancel(userData)) break;
+ renderingPass = nextRenderingPass;
+ nextRenderingPass = -1;
#ifdef _DEBUG
@@ -162,7 +175,9 @@
CompositeTypeStyle* style,
SE_String* seTip,
SE_String* seUrl,
- RS_ElevationSettings* /*elevSettings*/)
+ RS_ElevationSettings* /*elevSettings*/,
+ int renderingPass,
+ int& nextRenderingPass)
double mm2pxs = m_serenderer->GetPixelsPerMillimeterScreen();
double mm2pxw = m_serenderer->GetPixelsPerMillimeterWorld();
@@ -222,18 +237,22 @@
std::vector<SE_Symbolization*>* symbolization = &rule->symbolization;
- // TODO: eliminate the need to do dynamic casts on these renderers. We should
- // probably ultimately have just one renderer interface class...
- Renderer* renderer = dynamic_cast<Renderer*>(m_serenderer);
- if (renderer)
+ // only call StartFeature for the initial rendering pass
- const wchar_t* strTip = seTip->evaluate(executor);
- const wchar_t* strUrl = seUrl->evaluate(executor);
- RS_String rs_tip = strTip? strTip : L"";
- RS_String rs_url = strUrl? strUrl : L"";
- RS_String& rs_thm = rule->legendLabel;
+ // TODO: eliminate the need to do dynamic casts on these renderers. We should
+ // probably ultimately have just one renderer interface class...
+ Renderer* renderer = dynamic_cast<Renderer*>(m_serenderer);
+ if (renderer)
+ const wchar_t* strTip = seTip->evaluate(executor);
+ const wchar_t* strUrl = seUrl->evaluate(executor);
+ RS_String rs_tip = strTip? strTip : L"";
+ RS_String rs_url = strUrl? strUrl : L"";
+ RS_String& rs_thm = rule->legendLabel;
- renderer->StartFeature(reader, rs_tip.empty()? NULL : &rs_tip, rs_url.empty()? NULL : &rs_url, rs_thm.empty()? NULL : &rs_thm);
+ renderer->StartFeature(reader, rs_tip.empty()? NULL : &rs_tip, rs_url.empty()? NULL : &rs_url, rs_thm.empty()? NULL : &rs_thm);
/* TODO: Obey the indices--Get rid of the indices altogther--single pass! */
@@ -246,14 +265,37 @@
SE_Matrix xform;
xform.setTransform( sym->scale[0].evaluate(executor),
sym->scale[1].evaluate(executor),
- sym->absOffset[0].evaluate(executor)*mm2px,
- sym->absOffset[1].evaluate(executor)*mm2px );
+ sym->absOffset[0].evaluate(executor),
+ sym->absOffset[1].evaluate(executor) );
xform.scale(mm2px, mm2px);
for (std::vector<SE_Style*>::const_iterator siter = sym->styles.begin(); siter != sym->styles.end(); siter++)
SE_Style* style = *siter;
+ // process the rendering pass - negative rendering passes are rendered with pass 0
+ int styleRenderPass = style->renderPass.evaluate(executor);
+ if (styleRenderPass < 0)
+ styleRenderPass = 0;
+ // If the rendering pass for the style doesn't match the current pass
+ // then don't render using it.
+ // TODO - how does DrawLast affect the logic?
+ if (styleRenderPass != renderingPass)
+ // if the style's rendering pass is greater than the current pass,
+ // then update nextRenderingPass to account for it
+ if (styleRenderPass > renderingPass)
+ // update nextRenderingPass if it hasn't yet been set, or if
+ // the style's pass is less than the current next pass
+ if (nextRenderingPass == -1 || styleRenderPass < nextRenderingPass)
+ nextRenderingPass = styleRenderPass;
+ continue;
SE_Matrix tmpxform(xform); //TODO: this is lame, but necessary since the xform can be modified
//when we evalute the style, in the case of point style set on a
//non-point geometry
@@ -275,7 +317,7 @@
//evaluate values that are common to all styles
- rstyle->renderPass = style->renderPass.evaluate(executor);
+ rstyle->renderPass = styleRenderPass;
rstyle->addToExclusionRegions = sym->addToExclusionRegions.evaluate(executor);
rstyle->checkExclusionRegions = sym->checkExclusionRegions.evaluate(executor);
rstyle->drawLast = sym->drawLast.evaluate(executor);
Modified: trunk/MgDev/Common/Stylization/StylizationEngine.h
--- trunk/MgDev/Common/Stylization/StylizationEngine.h 2007-03-16 18:03:09 UTC (rev 1258)
+++ trunk/MgDev/Common/Stylization/StylizationEngine.h 2007-03-16 18:08:15 UTC (rev 1259)
@@ -73,7 +73,9 @@
SE_String* seTip,
SE_String* seUrl,
- RS_ElevationSettings* elevSettings);
+ RS_ElevationSettings* elevSettings,
+ int& nextRenderingPass);
void ClearCache();
More information about the mapguide-commits
