[mapguide-commits] r1262 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Fri Mar 16 16:08:16 EDT 2007
Author: traianstanev
Date: 2007-03-16 16:08:16 -0400 (Fri, 16 Mar 2007)
New Revision: 1262
Added:
trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp
Code cleanup. Made proxy objects self-evaluating, so that the Style Engine class itself doesn't have to think about them too much. This was done via addition of virtual functions. Some stuff still needs to be cleaned up, in particular code related to the computation of the sizebox.
Added: trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp
--- trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp (rev 0)
+++ trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp 2007-03-16 20:08:16 UTC (rev 1262)
@@ -0,0 +1,434 @@
+// Copyright (C) 2007 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#include "stdafx.h"
+#include "SE_SymbolDefProxies.h"
+#include "SE_RenderProxies.h"
+#include "SE_Renderer.h"
+#include "RS_FontEngine.h"
+#include "SE_ConvexHull.h"
+#include "SE_SymbolManager.h"
+#include <algorithm>
+#include <functional>
+SE_RenderPrimitive* SE_Polyline::evaluate(SE_EvalContext* cxt)
+ SE_RenderPolyline* ret = new SE_RenderPolyline();
+ ret->resize = (resize == GraphicElement::AdjustToResizeBox);
+ double wx = weightScalable.evaluate(cxt->exec)? cxt->mm2pxw : cxt->mm2pxs;
+ ret->weight = weight.evaluate(cxt->exec) * wx;
+ ret->geometry = geometry->Clone();
+ ret->color = color.evaluate(cxt->exec);
+ if (!cxt->useBox)
+ ret->geometry->Transform(*cxt->xform, ret->weight);
+ ret->bounds = ret->geometry->xf_bounds()->Clone();
+ else
+ ret->bounds = NULL;
+ return ret;
+SE_RenderPrimitive* SE_Polygon::evaluate(SE_EvalContext* cxt)
+ SE_RenderPolygon* ret = new SE_RenderPolygon();
+ ret->fill = fill.evaluate(cxt->exec);
+ if (!cxt->useBox)
+ else
+ return ret;
+SE_RenderPrimitive* SE_Text::evaluate(SE_EvalContext* cxt)
+ SE_RenderText* ret = new SE_RenderText();
+ ret->text = textExpr.evaluate(cxt->exec);
+ ret->position[0] = position[0].evaluate(cxt->exec);
+ ret->position[1] = position[1].evaluate(cxt->exec);
+ cxt->xform->transform(ret->position[0], ret->position[1]);
+ ret->tdef.rotation() = angle.evaluate(cxt->exec);
+ int style = RS_FontStyle_Regular;
+ if (underlined.evaluate(cxt->exec)) style |= (int)RS_FontStyle_Underline;
+ if (italic.evaluate(cxt->exec)) style |= (int)RS_FontStyle_Italic;
+ if (bold.evaluate(cxt->exec)) style |= (int)RS_FontStyle_Bold;
+ ret->tdef.font().style() = (RS_FontStyle_Mask)style;
+ ret->tdef.font().name() = fontExpr.evaluate(cxt->exec);
+ ret->tdef.font().height() = size.evaluate(cxt->exec)*0.001*cxt->xform->y1/cxt->mm2px; //convert mm to meters which is what RS_TextDef expects
+ ret->tdef.linespace() = lineSpacing.evaluate(cxt->exec);
+ ret->tdef.color() = RS_Color::FromARGB(textColor.evaluate(cxt->exec));
+ ret->tdef.bgcolor() = RS_Color::FromARGB(ghostColor.evaluate(cxt->exec));
+ const wchar_t* hAlign = hAlignment.evaluate(cxt->exec);
+ if (hAlign)
+ if (wcscmp(hAlign, L"Left") == 0)
+ ret->tdef.halign() = RS_HAlignment_Left;
+ else if (wcscmp(hAlign, L"Center") == 0)
+ ret->tdef.halign() = RS_HAlignment_Center;
+ else if (wcscmp(hAlign, L"Right") == 0)
+ ret->tdef.halign() = RS_HAlignment_Right;
+ const wchar_t* vAlign = vAlignment.evaluate(cxt->exec);
+ if (vAlign)
+ if (wcscmp(vAlign, L"Bottom") == 0)
+ ret->tdef.valign() = RS_VAlignment_Descent;
+ else if (wcscmp(vAlign, L"Baseline") == 0)
+ ret->tdef.valign() = RS_VAlignment_Base;
+ else if (wcscmp(vAlign, L"Halfline") == 0)
+ ret->tdef.valign() = RS_VAlignment_Half;
+ else if (wcscmp(vAlign, L"Capline") == 0)
+ ret->tdef.valign() = RS_VAlignment_Cap;
+ else if (wcscmp(vAlign, L"Top") == 0)
+ ret->tdef.valign() = RS_VAlignment_Ascent;
+ RS_TextMetrics tm;
+ SE_Matrix txf;
+ cxt->fonte->GetTextMetrics(ret->text, ret->tdef, tm, false);
+ txf.rotate(ret->tdef.rotation() * M_PI180);
+ txf.translate(ret->position[0], ret->position[1]);
+ double* buffer = (double*)alloca(tm.line_pos.size()*sizeof(double)*8);
+ double* ptr = buffer;
+ for(size_t k = 0; k < tm.line_pos.size(); k++)
+ const RS_F_Point* pts = tm.line_pos[k].ext;
+ txf.transform(pts[0].x, pts[0].y, ptr[0], ptr[1]);
+ txf.transform(pts[1].x, pts[1].y, ptr[2], ptr[3]);
+ txf.transform(pts[2].x, pts[2].y, ptr[4], ptr[5]);
+ txf.transform(pts[3].x, pts[3].y, ptr[6], ptr[7]);
+ ptr += 8;
+ std::sort((std::pair<double,double>*)buffer, (std::pair<double,double>*)(ptr - 2), PointLess( ));
+ ret->bounds = AndrewHull<std::pair<double,double>*,SimplePOINT>
+ ((std::pair<double,double>*)buffer,
+ ((std::pair<double,double>*)ptr) - 1,
+ (int)tm.line_pos.size()*4, cxt->pool);
+ return ret;
+SE_RenderPrimitive* SE_Raster::evaluate(SE_EvalContext* cxt)
+ SE_RenderRaster* ret = new SE_RenderRaster();
+ if (!pngPtr)
+ ret->pngPtr = cxt->resources->GetImageData(pngPath.evaluate(cxt->exec), ret->pngSize);
+ else
+ ret->pngPtr = pngPtr;
+ ret->pngSize = pngSize;
+ ret->extent[0] = extent[0].evaluate(cxt->exec)*cxt->xform->x0;
+ ret->extent[1] = extent[1].evaluate(cxt->exec)*cxt->xform->y1;
+ ret->angle = angle.evaluate(cxt->exec) * M_PI180;
+ SE_Matrix rxf;
+ rxf.rotate(ret->angle);
+ rxf.translate(ret->position[0], ret->position[1]);
+ double w = 0.5 * ret->extent[0];
+ double h = 0.5 * ret->extent[1];
+ RS_F_Point pts[4];
+ rxf.transform( w, h, pts[0].x, pts[0].y);
+ rxf.transform( w, -h, pts[1].x, pts[1].y);
+ rxf.transform(-w, -h, pts[2].x, pts[2].y);
+ rxf.transform(-w, h, pts[3].x, pts[3].y);
+ std::sort((std::pair<double,double>*)pts, (std::pair<double,double>*)(pts + 3), PointLess( ));
+ ((std::pair<double,double>*)pts,
+ ((std::pair<double,double>*)(pts+3)) - 1,
+ 4, cxt->pool);
+ return ret;
+void SE_Style::evaluate_common(SE_EvalContext* cxt, SE_RenderStyle* ret)
+ //evaluate values that are common to all styles
+ ret->renderPass = renderPass.evaluate(cxt->exec);
+ //evaluation of all primitives and also resize box stuff
+ double dx, dy, sx, sy;
+ double minx, maxx, miny, maxy;
+ double growx, growy;
+ SE_Matrix growxform;
+ if (useBox)
+ dx = resizePosition[0].evaluate(cxt->exec);
+ dy = resizePosition[1].evaluate(cxt->exec);
+ sx = resizeSize[0].evaluate(cxt->exec)/2.0;
+ sy = resizeSize[1].evaluate(cxt->exec)/2.0;
+ cxt->xform->transform(dx - sx, dy - sy, minx, miny);
+ cxt->xform->transform(dx + sx, dy + sy, maxx, maxy);
+ cxt->xform->transform(dx, dy);
+ growx = 0.0;
+ growy = 0.0;
+ //TODO: find a way to reorg the size box code to get rid of this flag
+ cxt->useBox = true;
+ else
+ cxt->useBox = false;
+ for (SE_PrimitiveList::const_iterator src = symbol.begin(); src != symbol.end(); src++)
+ SE_Primitive* sym = *src;
+ //evaluate the render primitive
+ SE_RenderPrimitive* rsym = sym->evaluate(cxt);
+ //add the primitive bounds to the overall render style bounds
+ if (rsym)
+ if (!rsym->resize)
+ if (ret->bounds)
+ SE_Bounds* bounds = ret->bounds;
+ ret->bounds = bounds->Union(rsym->bounds);
+ bounds->Free();
+ else
+ ret->bounds = rsym->bounds->Clone();
+ ret->symbol.push_back(rsym);
+ if (useBox && sym->resize == GraphicElement::AddToResizeBox)
+ rsym->bounds->Contained(minx, miny, maxx, maxy, growx, growy);
+ if (useBox)
+ switch(resize)
+ case ResizeBox::GrowInX:
+ growy = 0.0;
+ break;
+ case ResizeBox::GrowInY:
+ growx = 0.0;
+ break;
+ case ResizeBox::GrowInXYMaintainAspect:
+ if (growy > growx)
+ growx = growy;
+ else if (growx > growy)
+ growy = growx;
+ SE_Matrix totalxf(*cxt->xform);
+ SE_Matrix growxf;
+ growxf.translate(-dx, -dy);
+ growxf.scale(1.0 + growx, 1.0 + growy);
+ growxf.translate(dx, dy);
+ totalxf.premultiply(growxf);
+ for (SE_RenderPrimitiveList::iterator rs = ret->symbol.begin(); rs != ret->symbol.end(); rs++)
+ SE_RenderPrimitive* rsym = *rs;
+ if (rsym->resize)
+ switch(rsym->type)
+ case SE_PolygonPrimitive:
+ case SE_PolylinePrimitive:
+ SE_RenderPolyline* rp = (SE_RenderPolyline*)rsym;
+ rp->geometry->Transform(totalxf, rp->weight);
+ rp->bounds = rp->geometry->xf_bounds()->Clone();
+ break;
+ case SE_TextPrimitive:
+ SE_RenderText* rt = (SE_RenderText*)rsym;
+ growxf.transform(rt->position[0], rt->position[1]);
+ rt->tdef.font().height() *= growxf.y1;
+ rt->bounds->Transform(growxf);
+ break;
+ case SE_RasterPrimitive:
+ SE_RenderRaster* rr = (SE_RenderRaster*)rsym;
+ growxf.transform(rr->position[0], rr->position[1]);
+ rr->extent[0] *= growxf.x0;
+ rr->extent[1] *= growxf.y1;
+ rr->bounds->Transform(growxf);
+ break;
+ if (ret->bounds)
+ bounds->Free();
+ else
+SE_RenderStyle* SE_PointStyle::evaluate(SE_EvalContext* cxt)
+ SE_RenderPointStyle* render = new SE_RenderPointStyle();
+ LineBuffer::GeomOperationType type;
+ switch(cxt->geometry->geom_type())
+ case FdoGeometryType_LineString:
+ case FdoGeometryType_MultiLineString:
+ type = LineBuffer::ctLine;
+ break;
+ case FdoGeometryType_Polygon:
+ case FdoGeometryType_MultiPolygon:
+ type = LineBuffer::ctArea;
+ break;
+ case FdoGeometryType_Point:
+ case FdoGeometryType_MultiPoint:
+ type = LineBuffer::ctPoint;
+ break;
+ default:
+ type = LineBuffer::ctNone;
+ break;
+ double angle = 0.0;
+ const wchar_t* angleControl = this->angleControl.evaluate(cxt->exec);
+ if (wcscmp(L"FromGeometry", angleControl) == 0)
+ if (type == LineBuffer::ctLine || type == LineBuffer::ctArea)
+ double x0, y0;
+ double slope_rad = 0.0;
+ cxt->geometry->Centroid(LineBuffer::ctLine, &x0, &y0, &slope_rad);
+ angle = slope_rad;
+ //TODO: do we really need to invert this in case of y-down?
+ if (cxt->xform->y1 < 0)
+ angle = -angle;
+ else
+ angle = this->angle.evaluate(cxt->exec) * M_PI180;
+ double originOffsetX = originOffset[0].evaluate(cxt->exec)*cxt->mm2px;
+ double originOffsetY = originOffset[1].evaluate(cxt->exec)*cxt->mm2px;
+ SE_Matrix sxform;
+ sxform.translate(originOffsetX, originOffsetY);
+ sxform.rotate(angle);
+ sxform.premultiply(*cxt->xform);
+ *cxt->xform = sxform; //BAD here we modify the passed in transform -- figure out a way to avoid this
+ //evaluate all the primitives too
+ evaluate_common(cxt, render);
+ return render;
+SE_RenderStyle* SE_LineStyle::evaluate(SE_EvalContext* cxt)
+ SE_RenderLineStyle* render = new SE_RenderLineStyle();
+ render->angleControl = angleControl.evaluate(cxt->exec);
+ render->unitsControl = unitsControl.evaluate(cxt->exec);
+ render->vertexControl = vertexControl.evaluate(cxt->exec);
+// render->join = style->join.evaluate(m_exec);
+ render->angle = angle.evaluate(cxt->exec) * M_PI180;
+ render->startOffset = startOffset.evaluate(cxt->exec)*cxt->mm2px;
+ render->endOffset = endOffset.evaluate(cxt->exec)*cxt->mm2px;
+ render->repeat = repeat.evaluate(cxt->exec)*cxt->mm2px;
+ render->vertexAngleLimit = vertexAngleLimit.evaluate(cxt->exec) * M_PI180;
+ return render;
+SE_RenderStyle* SE_AreaStyle::evaluate(SE_EvalContext* cxt)
+ SE_RenderAreaStyle* render = new SE_RenderAreaStyle();
+ render->originControl = originControl.evaluate(cxt->exec);
+ render->clippingControl = clippingControl.evaluate(cxt->exec);
+ render->origin[0] = origin[0].evaluate(cxt->exec);
+ render->origin[1] = origin[1].evaluate(cxt->exec);
+ render->repeat[0] = repeat[0].evaluate(cxt->exec);
+ render->repeat[1] = repeat[1].evaluate(cxt->exec);
+ render->bufferWidth = bufferWidth.evaluate(cxt->exec);
+ return render;
More information about the mapguide-commits
