[mapguide-commits] r1271 - trunk/MgDev/Web/src/mapviewernet
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Mar 16 23:00:33 EDT 2007
Author: waltweltonlair
Date: 2007-03-16 23:00:33 -0400 (Fri, 16 Mar 2007)
New Revision: 1271
   trunk/MgDev/Web/src/mapviewernet/ajaxviewerabout.aspx
   trunk/MgDev/Web/src/mapviewernet/buffer.aspx
   trunk/MgDev/Web/src/mapviewernet/bufferui.aspx
   trunk/MgDev/Web/src/mapviewernet/colorpicker.aspx
   trunk/MgDev/Web/src/mapviewernet/common.aspx
   trunk/MgDev/Web/src/mapviewernet/dwfviewer.aspx
   trunk/MgDev/Web/src/mapviewernet/formframe.aspx
   trunk/MgDev/Web/src/mapviewernet/gettingstarted.aspx
   trunk/MgDev/Web/src/mapviewernet/legend.aspx
   trunk/MgDev/Web/src/mapviewernet/legendctrl.aspx
   trunk/MgDev/Web/src/mapviewernet/legendui.aspx
   trunk/MgDev/Web/src/mapviewernet/mainframe.aspx
   trunk/MgDev/Web/src/mapviewernet/mapframe.aspx
   trunk/MgDev/Web/src/mapviewernet/measure.aspx
   trunk/MgDev/Web/src/mapviewernet/measureui.aspx
   trunk/MgDev/Web/src/mapviewernet/printablepage.aspx
   trunk/MgDev/Web/src/mapviewernet/printablepageui.aspx
   trunk/MgDev/Web/src/mapviewernet/product.aspx
   trunk/MgDev/Web/src/mapviewernet/propertyctrl.aspx
   trunk/MgDev/Web/src/mapviewernet/search.aspx
   trunk/MgDev/Web/src/mapviewernet/searchprompt.aspx
   trunk/MgDev/Web/src/mapviewernet/selectwithin.aspx
   trunk/MgDev/Web/src/mapviewernet/selectwithinui.aspx
   trunk/MgDev/Web/src/mapviewernet/serveradminhelper.aspx
   trunk/MgDev/Web/src/mapviewernet/setselection.aspx
   trunk/MgDev/Web/src/mapviewernet/statusbar.aspx
   trunk/MgDev/Web/src/mapviewernet/taskbar.aspx
   trunk/MgDev/Web/src/mapviewernet/taskframe.aspx
   trunk/MgDev/Web/src/mapviewernet/tasklist.aspx
   trunk/MgDev/Web/src/mapviewernet/taskpane.aspx
   trunk/MgDev/Web/src/mapviewernet/toolbar.aspx
   trunk/MgDev/Web/src/mapviewernet/viewoptions.aspx
Update more source code copyright notices to use 2007
Modified: trunk/MgDev/Web/src/mapviewernet/ajaxviewerabout.aspx
--- trunk/MgDev/Web/src/mapviewernet/ajaxviewerabout.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/ajaxviewerabout.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
-Copyright (C) 2004-2006  Autodesk, Inc.
+Copyright (C) 2004-2007 by Autodesk, Inc.
 This library is free software; you can redistribute it and/or
 modify it under the terms of version 2.1 of the GNU Lesser
 General Public License as published by the Free Software Foundation.
Modified: trunk/MgDev/Web/src/mapviewernet/buffer.aspx
--- trunk/MgDev/Web/src/mapviewernet/buffer.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/buffer.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewernet/bufferui.aspx
--- trunk/MgDev/Web/src/mapviewernet/bufferui.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/bufferui.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewernet/colorpicker.aspx
--- trunk/MgDev/Web/src/mapviewernet/colorpicker.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/colorpicker.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewernet/common.aspx
--- trunk/MgDev/Web/src/mapviewernet/common.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/common.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewernet/dwfviewer.aspx
--- trunk/MgDev/Web/src/mapviewernet/dwfviewer.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/dwfviewer.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewernet/formframe.aspx
--- trunk/MgDev/Web/src/mapviewernet/formframe.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/formframe.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewernet/gettingstarted.aspx
--- trunk/MgDev/Web/src/mapviewernet/gettingstarted.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/gettingstarted.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
@@ -14,7 +14,7 @@
 Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
-<%@ Page language="c#"  %>
+<%@ Page language="c#" %>
 <%@ Import Namespace="System" %>
 <%@ Import Namespace="System.IO" %>
 <%@ Import Namespace="System.Collections.Specialized" %>
Modified: trunk/MgDev/Web/src/mapviewernet/legend.aspx
--- trunk/MgDev/Web/src/mapviewernet/legend.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/legend.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewernet/legendctrl.aspx
--- trunk/MgDev/Web/src/mapviewernet/legendctrl.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/legendctrl.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewernet/legendui.aspx
--- trunk/MgDev/Web/src/mapviewernet/legendui.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/legendui.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewernet/mainframe.aspx
--- trunk/MgDev/Web/src/mapviewernet/mainframe.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/mainframe.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewernet/mapframe.aspx
--- trunk/MgDev/Web/src/mapviewernet/mapframe.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/mapframe.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewernet/measure.aspx
--- trunk/MgDev/Web/src/mapviewernet/measure.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/measure.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewernet/measureui.aspx
--- trunk/MgDev/Web/src/mapviewernet/measureui.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/measureui.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
@@ -14,7 +14,7 @@
-<%@ Page language="c#"%>
Modified: trunk/MgDev/Web/src/mapviewernet/printablepage.aspx
--- trunk/MgDev/Web/src/mapviewernet/printablepage.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/printablepage.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewernet/printablepageui.aspx
--- trunk/MgDev/Web/src/mapviewernet/printablepageui.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/printablepageui.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewernet/product.aspx
--- trunk/MgDev/Web/src/mapviewernet/product.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/product.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewernet/propertyctrl.aspx
--- trunk/MgDev/Web/src/mapviewernet/propertyctrl.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/propertyctrl.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewernet/search.aspx
--- trunk/MgDev/Web/src/mapviewernet/search.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/search.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewernet/searchprompt.aspx
--- trunk/MgDev/Web/src/mapviewernet/searchprompt.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/searchprompt.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewernet/selectwithin.aspx
--- trunk/MgDev/Web/src/mapviewernet/selectwithin.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/selectwithin.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
@@ -15,7 +15,6 @@
 <%@ Page language="c#" validateRequest="false" %>
 <%@ Import Namespace="System.Collections" %>
Modified: trunk/MgDev/Web/src/mapviewernet/selectwithinui.aspx
--- trunk/MgDev/Web/src/mapviewernet/selectwithinui.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/selectwithinui.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewernet/serveradminhelper.aspx
--- trunk/MgDev/Web/src/mapviewernet/serveradminhelper.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/serveradminhelper.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
@@ -14,7 +14,7 @@
Modified: trunk/MgDev/Web/src/mapviewernet/setselection.aspx
--- trunk/MgDev/Web/src/mapviewernet/setselection.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/setselection.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewernet/statusbar.aspx
--- trunk/MgDev/Web/src/mapviewernet/statusbar.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/statusbar.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewernet/taskbar.aspx
--- trunk/MgDev/Web/src/mapviewernet/taskbar.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/taskbar.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewernet/taskframe.aspx
--- trunk/MgDev/Web/src/mapviewernet/taskframe.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/taskframe.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewernet/tasklist.aspx
--- trunk/MgDev/Web/src/mapviewernet/tasklist.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/tasklist.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewernet/taskpane.aspx
--- trunk/MgDev/Web/src/mapviewernet/taskpane.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/taskpane.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewernet/toolbar.aspx
--- trunk/MgDev/Web/src/mapviewernet/toolbar.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/toolbar.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewernet/viewoptions.aspx
--- trunk/MgDev/Web/src/mapviewernet/viewoptions.aspx	2007-03-17 02:56:46 UTC (rev 1270)
+++ trunk/MgDev/Web/src/mapviewernet/viewoptions.aspx	2007-03-17 03:00:33 UTC (rev 1271)
@@ -1,5 +1,5 @@
More information about the mapguide-commits mailing list
