[mapguide-commits] r1286 - in trunk/MgDev:
Common/Foundation/Exception Common/Foundation/System
Common/MapGuideCommon/System Server/src/Common/Base
Server/src/Common/Manager Server/src/Core
Server/src/Services/Mapping Server/src/UnitTesting
Web/src/WebSupport
svn_mapguide at osgeo.org
Mon Mar 19 13:25:35 EDT 2007
Author: brucedechant
Date: 2007-03-19 13:25:35 -0400 (Mon, 19 Mar 2007)
New Revision: 1286
trunk/MgDev/Common/Foundation/Exception/Exception.cpp
trunk/MgDev/Common/Foundation/System/FoundationConfigProperties.cpp
trunk/MgDev/Common/Foundation/System/FoundationConfigProperties.h
trunk/MgDev/Common/Foundation/System/Resources.cpp
trunk/MgDev/Common/Foundation/System/Resources.h
trunk/MgDev/Common/Foundation/System/Util.cpp
trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp
trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h
trunk/MgDev/Common/MapGuideCommon/System/UserInformation.cpp
trunk/MgDev/Server/src/Common/Base/ClientHandler.cpp
trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp
trunk/MgDev/Server/src/Common/Manager/LoadBalanceManager.cpp
trunk/MgDev/Server/src/Common/Manager/LogThread.cpp
trunk/MgDev/Server/src/Common/Manager/ServerManager.cpp
trunk/MgDev/Server/src/Common/Manager/ServerManager.h
trunk/MgDev/Server/src/Common/Manager/WorkerThread.cpp
trunk/MgDev/Server/src/Core/OperationThread.cpp
trunk/MgDev/Server/src/Core/Server.cpp
trunk/MgDev/Server/src/Core/TimedEventHandler.cpp
trunk/MgDev/Server/src/Core/main.cpp
trunk/MgDev/Server/src/Core/serverconfig.ini
trunk/MgDev/Server/src/Services/Mapping/StylizationUtil.cpp
trunk/MgDev/Server/src/UnitTesting/TestServerManager.cpp
trunk/MgDev/Server/src/UnitTesting/TestServerManager.h
trunk/MgDev/Web/src/WebSupport/InitializeWebTier.cpp
Implement RFC 18 - Localization (MapGuideRfc18)
Modified: trunk/MgDev/Common/Foundation/Exception/Exception.cpp
--- trunk/MgDev/Common/Foundation/Exception/Exception.cpp 2007-03-19 17:03:01 UTC (rev 1285)
+++ trunk/MgDev/Common/Foundation/Exception/Exception.cpp 2007-03-19 17:25:35 UTC (rev 1286)
@@ -102,16 +102,16 @@
configuration->GetStringValue(
MgFoundationConfigProperties::GeneralPropertiesSection,
- MgFoundationConfigProperties::GeneralPropertyDefaultLocale,
+ MgFoundationConfigProperties::GeneralPropertyDefaultMessageLocale,
locale,
- MgFoundationConfigProperties::DefaultGeneralPropertyDefaultLocale);
+ MgFoundationConfigProperties::DefaultGeneralPropertyDefaultMessageLocale);
MG_CATCH_AND_RELEASE()
if (locale.empty())
- locale = MgResources::DefaultLocale;
+ locale = MgResources::DefaultMessageLocale;
@@ -267,12 +267,12 @@
- if (message.empty() && NULL != resources && locale != MgResources::DefaultLocale)
+ if (message.empty() && NULL != resources && locale != MgResources::DefaultMessageLocale)
MG_TRY()
// try using the default locale as a backup
- STRING resourceStr = resources->GetStringResource(MgResources::DefaultLocale, section,
+ STRING resourceStr = resources->GetStringResource(MgResources::DefaultMessageLocale, section,
resourceId);
message = resources->FormatMessage(resourceStr, arguments);
Modified: trunk/MgDev/Common/Foundation/System/FoundationConfigProperties.cpp
--- trunk/MgDev/Common/Foundation/System/FoundationConfigProperties.cpp 2007-03-19 17:03:01 UTC (rev 1285)
+++ trunk/MgDev/Common/Foundation/System/FoundationConfigProperties.cpp 2007-03-19 17:25:35 UTC (rev 1286)
@@ -45,8 +45,10 @@
// General Properties
const STRING MgFoundationConfigProperties::GeneralPropertiesSection = L"GeneralProperties";
-const STRING MgFoundationConfigProperties::GeneralPropertyDefaultLocale = L"DefaultLocale";
-const STRING MgFoundationConfigProperties::DefaultGeneralPropertyDefaultLocale = L"en"; // ISO 639-1 name
+const STRING MgFoundationConfigProperties::GeneralPropertyLocale = L"Locale";
+const STRING MgFoundationConfigProperties::DefaultGeneralPropertyLocale = L"";
+const STRING MgFoundationConfigProperties::GeneralPropertyDefaultMessageLocale = L"DefaultMessageLocale";
+const STRING MgFoundationConfigProperties::DefaultGeneralPropertyDefaultMessageLocale = L"en"; // ISO 639-1 name
const STRING MgFoundationConfigProperties::GeneralPropertyResourcesPath = L"ResourcesPath";
const STRING MgFoundationConfigProperties::DefaultGeneralPropertyResourcesPath = L"Resources/";
const STRING MgFoundationConfigProperties::GeneralPropertyTempPath = L"TempPath";
@@ -59,7 +61,8 @@
const MgConfigValidationInfo MgFoundationConfigProperties::sm_cviGeneralProperties[] =
- { MgFoundationConfigProperties::GeneralPropertyDefaultLocale , MgPropertyType::String , MG_CONFIG_MIN_LOCALE_LENGTH , MG_CONFIG_MAX_LOCALE_LENGTH , L"" },
+ { MgFoundationConfigProperties::GeneralPropertyLocale , MgPropertyType::String , MG_CONFIG_MIN_OPTIONAL_STRING_LENGTH , MG_CONFIG_MAX_OPTIONAL_STRING_LENGTH , L"" },
+ { MgFoundationConfigProperties::GeneralPropertyDefaultMessageLocale, MgPropertyType::String , MG_CONFIG_MIN_LOCALE_LENGTH , MG_CONFIG_MAX_LOCALE_LENGTH , L"" },
{ MgFoundationConfigProperties::GeneralPropertyResourcesPath , MgPropertyType::String , MG_CONFIG_MIN_PATH_LENGTH , MG_CONFIG_MAX_PATH_LENGTH , MG_CONFIG_PATH_RESERVED_CHARACTERS },
{ MgFoundationConfigProperties::GeneralPropertyTempPath , MgPropertyType::String , MG_CONFIG_MIN_PATH_LENGTH , MG_CONFIG_MAX_PATH_LENGTH , MG_CONFIG_PATH_RESERVED_CHARACTERS },
{ MgFoundationConfigProperties::GeneralPropertyTcpIpMtu , MgPropertyType::Int32 , 1 , 65535 , L"" },
Modified: trunk/MgDev/Common/Foundation/System/FoundationConfigProperties.h
--- trunk/MgDev/Common/Foundation/System/FoundationConfigProperties.h 2007-03-19 17:03:01 UTC (rev 1285)
+++ trunk/MgDev/Common/Foundation/System/FoundationConfigProperties.h 2007-03-19 17:25:35 UTC (rev 1286)
@@ -42,10 +42,14 @@
/// General application properties
static const STRING GeneralPropertiesSection; /// value("GeneralProperties")
- /// Application's default locale
- static const STRING GeneralPropertyDefaultLocale; /// value("DefaultLocale")
- static const STRING DefaultGeneralPropertyDefaultLocale; /// value("en")
+ /// Application's locale
+ static const STRING GeneralPropertyLocale; /// value("Locale")
+ static const STRING DefaultGeneralPropertyLocale; /// value("")
+ /// Application's default message locale
+ static const STRING GeneralPropertyDefaultMessageLocale; /// value("DefaultMessageLocale")
+ static const STRING DefaultGeneralPropertyDefaultMessageLocale; /// value("en")
/// Root folder for application's localization resources
static const STRING GeneralPropertyResourcesPath; /// value("ResourcesPath")
static const STRING DefaultGeneralPropertyResourcesPath; /// value("Resources/")
Modified: trunk/MgDev/Common/Foundation/System/Resources.cpp
--- trunk/MgDev/Common/Foundation/System/Resources.cpp 2007-03-19 17:03:01 UTC (rev 1285)
+++ trunk/MgDev/Common/Foundation/System/Resources.cpp 2007-03-19 17:25:35 UTC (rev 1286)
@@ -20,7 +20,7 @@
// Process-wide MgResources
Ptr<MgResources> MgResources::m_resources = (MgResources*)NULL;
-const STRING MgResources::DefaultLocale = L"en"; // Do not translate (ISO 639-1)
+const STRING MgResources::DefaultMessageLocale = L"en"; // Do not translate (ISO 639-1)
const STRING MgResources::ResourceFilenameExtension = L".res"; // Do not translate
const STRING MgResources::ResourceFilenameUnderscore = L"_"; // Do not translate
const STRING MgResources::ResourceComponent = L"mapguide"; // Do not translate
@@ -547,7 +547,7 @@
MG_RESOURCES_TRY()
- STRING locale = DefaultLocale;
+ STRING locale = DefaultMessageLocale;
MgConfiguration* configuration = MgConfiguration::GetInstance();
ACE_ASSERT(NULL != configuration);
@@ -555,9 +555,9 @@
locale,
STRING resourceStr = GetStringResource(locale, section, resourceId);
Modified: trunk/MgDev/Common/Foundation/System/Resources.h
--- trunk/MgDev/Common/Foundation/System/Resources.h 2007-03-19 17:03:01 UTC (rev 1285)
+++ trunk/MgDev/Common/Foundation/System/Resources.h 2007-03-19 17:25:35 UTC (rev 1286)
@@ -169,7 +169,7 @@
static const STRING ResourceComponent;
/// Default locale
- static const STRING DefaultLocale;
+ static const STRING DefaultMessageLocale;
static const STRING ServerServiceName;
static const STRING ServerServiceDisplayName;
Modified: trunk/MgDev/Common/Foundation/System/Util.cpp
--- trunk/MgDev/Common/Foundation/System/Util.cpp 2007-03-19 17:03:01 UTC (rev 1285)
+++ trunk/MgDev/Common/Foundation/System/Util.cpp 2007-03-19 17:25:35 UTC (rev 1286)
@@ -763,9 +763,9 @@
locale,
str = resources->GetStringResource(locale, section, messageId);
// If no message is found, we do not fail.
Modified: trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp
--- trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp 2007-03-19 17:03:01 UTC (rev 1285)
+++ trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp 2007-03-19 17:25:35 UTC (rev 1286)
@@ -115,8 +115,10 @@
const INT32 MgConfigProperties::DefaultGeneralPropertyConnectionTimeout = 120;
const STRING MgConfigProperties::GeneralPropertyConnectionTimerInterval = L"ConnectionTimerInterval";
const INT32 MgConfigProperties::DefaultGeneralPropertyConnectionTimerInterval = 60;
-const STRING MgConfigProperties::GeneralPropertyDefaultLocale = L"DefaultLocale";
-const STRING MgConfigProperties::DefaultGeneralPropertyDefaultLocale = L"en"; // ISO 639-1 name
+const STRING MgConfigProperties::GeneralPropertyLocale = L"Locale";
+const STRING MgConfigProperties::DefaultGeneralPropertyLocale = L"";
+const STRING MgConfigProperties::GeneralPropertyDefaultMessageLocale = L"DefaultMessageLocale";
+const STRING MgConfigProperties::DefaultGeneralPropertyDefaultMessageLocale = L"en"; // ISO 639-1 name
const STRING MgConfigProperties::GeneralPropertyDisplayName = L"DisplayName";
const STRING MgConfigProperties::DefaultGeneralPropertyDisplayName = L"";
const STRING MgConfigProperties::GeneralPropertyFdoPath = L"FdoPath";
@@ -440,7 +442,8 @@
{ MgConfigProperties::GeneralPropertyConnectionTimeout , MgPropertyType::Int32 , MG_CONFIG_MIN_TIMEOUT , MG_CONFIG_MAX_TIMEOUT , L"" },
{ MgConfigProperties::GeneralPropertyConnectionTimerInterval , MgPropertyType::Int32 , MG_CONFIG_MIN_TIMER_INTERVAL , MG_CONFIG_MAX_TIMER_INTERVAL , L"" },
- { MgConfigProperties::GeneralPropertyDefaultLocale , MgPropertyType::String , MG_CONFIG_MIN_LOCALE_LENGTH , MG_CONFIG_MAX_LOCALE_LENGTH , L"" },
+ { MgConfigProperties::GeneralPropertyLocale , MgPropertyType::String , MG_CONFIG_MIN_OPTIONAL_STRING_LENGTH , MG_CONFIG_MAX_OPTIONAL_STRING_LENGTH , L"" },
+ { MgConfigProperties::GeneralPropertyDefaultMessageLocale , MgPropertyType::String , MG_CONFIG_MIN_LOCALE_LENGTH , MG_CONFIG_MAX_LOCALE_LENGTH , L"" },
{ MgConfigProperties::GeneralPropertyDisplayName , MgPropertyType::String , MG_CONFIG_MIN_OPTIONAL_STRING_LENGTH , MG_CONFIG_MAX_OPTIONAL_STRING_LENGTH , MG_CONFIG_FILE_NAME_RESERVED_CHARACTERS },
{ MgConfigProperties::GeneralPropertyFdoPath , MgPropertyType::String , MG_CONFIG_MIN_PATH_LENGTH , MG_CONFIG_MAX_PATH_LENGTH , MG_CONFIG_PATH_RESERVED_CHARACTERS },
{ MgConfigProperties::GeneralPropertyLicenseServerPath , MgPropertyType::String , MG_CONFIG_MIN_OPTIONAL_STRING_LENGTH , MG_CONFIG_MAX_OPTIONAL_STRING_LENGTH , L"" },
Modified: trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h
--- trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h 2007-03-19 17:03:01 UTC (rev 1285)
+++ trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h 2007-03-19 17:25:35 UTC (rev 1286)
@@ -54,10 +54,14 @@
static const STRING GeneralPropertyConnectionTimerInterval; /// value("ConnectionTimerInterval")
static const INT32 DefaultGeneralPropertyConnectionTimerInterval; /// value(60)
- /// Server's default locale
+ /// Server's locale
+ /// Server's default message locale
/// Server's display name
static const STRING GeneralPropertyDisplayName; /// value("DisplayName")
static const STRING DefaultGeneralPropertyDisplayName; /// value("")
Modified: trunk/MgDev/Common/MapGuideCommon/System/UserInformation.cpp
--- trunk/MgDev/Common/MapGuideCommon/System/UserInformation.cpp 2007-03-19 17:03:01 UTC (rev 1285)
+++ trunk/MgDev/Common/MapGuideCommon/System/UserInformation.cpp 2007-03-19 17:25:35 UTC (rev 1286)
@@ -211,7 +211,7 @@
MgUtil::GenerateUuid(uuid);
// TODO: Pull default locale from MgConfiguration within a try/catch
- STRING locale = m_locale.empty() ? MgResources::DefaultLocale : m_locale;
+ STRING locale = m_locale.empty() ? MgResources::DefaultMessageLocale : m_locale;
uuid.append(L"_");
uuid.append(locale);
Modified: trunk/MgDev/Server/src/Common/Base/ClientHandler.cpp
--- trunk/MgDev/Server/src/Common/Base/ClientHandler.cpp 2007-03-19 17:03:01 UTC (rev 1285)
+++ trunk/MgDev/Server/src/Common/Base/ClientHandler.cpp 2007-03-19 17:25:35 UTC (rev 1286)
@@ -191,9 +191,9 @@
stream = new MgMapGuideStream( m_pStreamHelper );
// TODO: use locale from client connection
- mgException->GetMessage(MgResources::DefaultLocale);
- mgException->GetDetails(MgResources::DefaultLocale);
- mgException->GetStackTrace(MgResources::DefaultLocale);
+ mgException->GetMessage(MgResources::DefaultMessageLocale);
+ mgException->GetDetails(MgResources::DefaultMessageLocale);
+ mgException->GetStackTrace(MgResources::DefaultMessageLocale);
stream->WriteResponseHeader(MgPacketParser::mecFailure, 1);
stream->WriteObject(mgException);
Modified: trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp
--- trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp 2007-03-19 17:03:01 UTC (rev 1285)
+++ trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp 2007-03-19 17:25:35 UTC (rev 1286)
@@ -213,7 +213,7 @@
if (m_argsRead && NULL != except && m_stream != NULL)
// Log the exception using Server locale or User locale if it exists
- STRING locale = MgResources::DefaultLocale;
+ STRING locale = MgResources::DefaultMessageLocale;
MgUserInformation* currUserInfo = MgUserInformation::GetCurrentUserInfo();
if (NULL != currUserInfo)
@@ -224,7 +224,7 @@
MgServerManager* serverManager = MgServerManager::GetInstance();
if (NULL != serverManager)
- locale = serverManager->GetDefaultLocale();
+ locale = serverManager->GetDefaultMessageLocale();
Modified: trunk/MgDev/Server/src/Common/Manager/LoadBalanceManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/LoadBalanceManager.cpp 2007-03-19 17:03:01 UTC (rev 1285)
+++ trunk/MgDev/Server/src/Common/Manager/LoadBalanceManager.cpp 2007-03-19 17:25:35 UTC (rev 1286)
@@ -662,7 +662,7 @@
catch (MgException* e)
// Server is down or request gets timed out? Log the message.
- STRING locale = m_serverManager->GetDefaultLocale();
+ STRING locale = m_serverManager->GetDefaultMessageLocale();
ACE_DEBUG((LM_ERROR, ACE_TEXT("(%P|%t) %W\n"), e->GetDetails(locale).c_str()));
MG_LOG_SYSTEM_ENTRY(LM_ERROR, e->GetDetails(locale).c_str());
@@ -752,7 +752,7 @@
@@ -955,7 +955,7 @@
@@ -1560,7 +1560,7 @@
@@ -1630,7 +1630,7 @@
@@ -1732,7 +1732,7 @@
@@ -1759,7 +1759,7 @@
@@ -1826,7 +1826,7 @@
@@ -1854,7 +1854,7 @@
Modified: trunk/MgDev/Server/src/Common/Manager/LogThread.cpp
--- trunk/MgDev/Server/src/Common/Manager/LogThread.cpp 2007-03-19 17:03:01 UTC (rev 1285)
+++ trunk/MgDev/Server/src/Common/Manager/LogThread.cpp 2007-03-19 17:25:35 UTC (rev 1286)
@@ -97,8 +97,8 @@
MgServerManager* pServerManager = MgServerManager::GetInstance();
- ACE_DEBUG ((LM_ERROR, ACE_TEXT("(%P|%t) %W\n"), e->GetDetails(pServerManager->GetDefaultLocale()).c_str()));
- MG_LOG_EXCEPTION_ENTRY(e->GetMessage(pServerManager->GetDefaultLocale()).c_str(), e->GetStackTrace(pServerManager->GetDefaultLocale()).c_str());
+ ACE_DEBUG ((LM_ERROR, ACE_TEXT("(%P|%t) %W\n"), e->GetDetails(pServerManager->GetDefaultMessageLocale()).c_str()));
+ MG_LOG_EXCEPTION_ENTRY(e->GetMessage(pServerManager->GetDefaultMessageLocale()).c_str(), e->GetStackTrace(pServerManager->GetDefaultMessageLocale()).c_str());
SAFE_RELEASE(e);
@@ -117,8 +117,8 @@
mgException = new MgFdoException(L"MgLogThread.svc", __LINE__, __WFILE__, NULL, messageId, &arguments);
- ACE_DEBUG ((LM_ERROR, ACE_TEXT("(%P|%t) %W\n"), mgException->GetDetails(pServerManager->GetDefaultLocale()).c_str()));
- MG_LOG_EXCEPTION_ENTRY(mgException->GetMessage(pServerManager->GetDefaultLocale()).c_str(), mgException->GetStackTrace(pServerManager->GetDefaultLocale()).c_str());
+ ACE_DEBUG ((LM_ERROR, ACE_TEXT("(%P|%t) %W\n"), mgException->GetDetails(pServerManager->GetDefaultMessageLocale()).c_str()));
+ MG_LOG_EXCEPTION_ENTRY(mgException->GetMessage(pServerManager->GetDefaultMessageLocale()).c_str(), mgException->GetStackTrace(pServerManager->GetDefaultMessageLocale()).c_str());
FDO_SAFE_RELEASE(e);
@@ -127,16 +127,16 @@
mgException = MgSystemException::Create(e, L"MgLogThread.svc", __LINE__, __WFILE__);
catch(...)
mgException = new MgUnclassifiedException(L"MgLogThread.svc", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -151,8 +151,8 @@
SAFE_RELEASE(e);
@@ -163,8 +163,8 @@
nResult = -1;
@@ -173,8 +173,8 @@
nResult = -1;
Modified: trunk/MgDev/Server/src/Common/Manager/ServerManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/ServerManager.cpp 2007-03-19 17:03:01 UTC (rev 1285)
+++ trunk/MgDev/Server/src/Common/Manager/ServerManager.cpp 2007-03-19 17:25:35 UTC (rev 1286)
@@ -44,7 +44,7 @@
m_pWorkerThreads(NULL)
m_localServerAddress = MgConfigProperties::DefaultGeneralPropertyMachineIp;
- m_defaultLocale = MgConfigProperties::DefaultGeneralPropertyDefaultLocale;
+ m_defaultMessageLocale = MgConfigProperties::DefaultGeneralPropertyDefaultMessageLocale;
m_displayName = MgConfigProperties::DefaultGeneralPropertyDisplayName;
// Admin
@@ -127,8 +127,8 @@
MG_LOG_TRACE_ENTRY(L"MgServerManager::Initialize()");
- // Set the locale
- m_defaultLocale = locale;
+ // Set the message locale
+ m_defaultMessageLocale = locale;
m_pClientHandles = new ACE_Unbounded_Set<ACE_HANDLE>;
@@ -264,9 +264,9 @@
MG_CATCH_AND_THROW(L"MgServerManager.LoadConfigurationProperties")
-CREFSTRING MgServerManager::GetDefaultLocale()
+CREFSTRING MgServerManager::GetDefaultMessageLocale()
- return m_defaultLocale;
+ return m_defaultMessageLocale;
Modified: trunk/MgDev/Server/src/Common/Manager/ServerManager.h
--- trunk/MgDev/Server/src/Common/Manager/ServerManager.h 2007-03-19 17:03:01 UTC (rev 1285)
+++ trunk/MgDev/Server/src/Common/Manager/ServerManager.h 2007-03-19 17:25:35 UTC (rev 1286)
@@ -53,7 +53,7 @@
void Initialize(CREFSTRING locale);
void LoadConfigurationProperties();
- CREFSTRING GetDefaultLocale();
+ CREFSTRING GetDefaultMessageLocale();
MgPropertyCollection* GetConfigurationProperties(CREFSTRING propertySection);
void SetConfigurationProperties(CREFSTRING propertySection, MgPropertyCollection* properties);
@@ -155,7 +155,7 @@
ServerStatus m_ssServerStatus;
bool m_isSiteServer;
STRING m_localServerAddress;
- STRING m_defaultLocale;
+ STRING m_defaultMessageLocale;
STRING m_displayName;
// Admin Properties
Modified: trunk/MgDev/Server/src/Common/Manager/WorkerThread.cpp
--- trunk/MgDev/Server/src/Common/Manager/WorkerThread.cpp 2007-03-19 17:03:01 UTC (rev 1285)
+++ trunk/MgDev/Server/src/Common/Manager/WorkerThread.cpp 2007-03-19 17:25:35 UTC (rev 1286)
@@ -103,8 +103,8 @@
SAFE_RELEASE(e);
@@ -123,8 +123,8 @@
mgException = new MgFdoException(L"MgWorkerThread.svc", __LINE__, __WFILE__, NULL, messageId, &arguments);
@@ -133,16 +133,16 @@
mgException = MgSystemException::Create(e, L"MgWorkerThread.svc", __LINE__, __WFILE__);
catch(...)
mgException = new MgUnclassifiedException(L"MgWorkerThread.svc", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -157,8 +157,8 @@
SAFE_RELEASE(e);
@@ -169,8 +169,8 @@
nResult = -1;
@@ -179,8 +179,8 @@
nResult = -1;
Modified: trunk/MgDev/Server/src/Core/OperationThread.cpp
--- trunk/MgDev/Server/src/Core/OperationThread.cpp 2007-03-19 17:03:01 UTC (rev 1285)
+++ trunk/MgDev/Server/src/Core/OperationThread.cpp 2007-03-19 17:25:35 UTC (rev 1286)
@@ -153,7 +153,7 @@
STRING locale = (NULL == serverManager) ?
- MgResources::DefaultLocale : serverManager->GetDefaultLocale();
+ MgResources::DefaultMessageLocale : serverManager->GetDefaultMessageLocale();
STRING message = mgException->GetMessage(locale);
STRING details = mgException->GetDetails(locale);
STRING stackTrace = mgException->GetStackTrace(locale);
@@ -279,7 +279,7 @@
@@ -432,7 +432,7 @@
Modified: trunk/MgDev/Server/src/Core/Server.cpp
--- trunk/MgDev/Server/src/Core/Server.cpp 2007-03-19 17:03:01 UTC (rev 1285)
+++ trunk/MgDev/Server/src/Core/Server.cpp 2007-03-19 17:25:35 UTC (rev 1286)
@@ -349,7 +349,7 @@
ACE_DEBUG((LM_ERROR, ACE_TEXT("Unable to run all the unit tests.\n")));
- ACE_DEBUG((LM_ERROR, ACE_TEXT("%W\n"), e->GetStackTrace(pServerManager->GetDefaultLocale()).c_str()));
+ ACE_DEBUG((LM_ERROR, ACE_TEXT("%W\n"), e->GetStackTrace(pServerManager->GetDefaultMessageLocale()).c_str()));
SAFE_RELEASE(e);
nResult = -1;
@@ -452,7 +452,7 @@
ACE_DEBUG((LM_ERROR, ACE_TEXT("Unable to run all the FDO unit tests.\n")));
SAFE_RELEASE(e);
nResult = -1;
@@ -635,10 +635,10 @@
STRING message;
- message = e->GetDetails(pServerManager->GetDefaultLocale());
+ message = e->GetDetails(pServerManager->GetDefaultMessageLocale());
ACE_DEBUG((LM_ERROR, ACE_TEXT("(%P|%t) %W\n"), message.c_str()));
- ACE_DEBUG((LM_ERROR, ACE_TEXT("(%P|%t) %W\n"), e->GetStackTrace(pServerManager->GetDefaultLocale()).c_str()));
+ ACE_DEBUG((LM_ERROR, ACE_TEXT("(%P|%t) %W\n"), e->GetStackTrace(pServerManager->GetDefaultMessageLocale()).c_str()));
MG_LOG_SYSTEM_ENTRY(LM_ERROR, message.c_str());
MG_LOG_ERROR_ENTRY(message.c_str());
@@ -710,10 +710,33 @@
STRING resourcesPath;
pConfiguration->GetStringValue(MgConfigProperties::GeneralPropertiesSection, MgConfigProperties::GeneralPropertyResourcesPath, resourcesPath, MgConfigProperties::DefaultGeneralPropertyResourcesPath);
- // Get the default locale.
- STRING defaultLocale;
- pConfiguration->GetStringValue(MgConfigProperties::GeneralPropertiesSection, MgConfigProperties::GeneralPropertyDefaultLocale, defaultLocale, MgConfigProperties::DefaultGeneralPropertyDefaultLocale);
+ // Get the default message locale.
+ STRING defaultMessageLocale;
+ pConfiguration->GetStringValue(MgConfigProperties::GeneralPropertiesSection, MgConfigProperties::GeneralPropertyDefaultMessageLocale, defaultMessageLocale, MgConfigProperties::DefaultGeneralPropertyDefaultMessageLocale);
+ // Get the server locale.
+ STRING locale;
+ pConfiguration->GetStringValue(MgConfigProperties::GeneralPropertiesSection, MgConfigProperties::GeneralPropertyLocale, locale, MgConfigProperties::DefaultGeneralPropertyLocale);
+ char* serverLocale = NULL;
+ // If the server configuration property is defined use it
+ if(!locale.empty())
+ string localeTemp = MgUtil::WideCharToMultiByte(locale);
+ serverLocale = ::setlocale(LC_ALL, localeTemp.c_str());
+ else
+ // Set the locale to the system default
+ serverLocale = ::setlocale(LC_ALL, "");
+ STRING strLocale = MgUtil::MultiByteToWideChar(string(serverLocale));
+ // Always use the "C" locale when dealing with numbers
+ ::setlocale(LC_NUMERIC, "C");
// Initialize the Log Manager
ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::open() - Initializing Log Manager.\n")));
MgLogManager* pLogManager = MgLogManager::GetInstance();
@@ -730,7 +753,7 @@
// If that fails then we will not start the server because we need our resources.
try
- pResources->LoadResources(defaultLocale);
+ pResources->LoadResources(defaultMessageLocale);
catch(MgException* e)
@@ -738,24 +761,24 @@
// Log error message about failing to load the specified locale resources
MgStringCollection arguments;
- arguments.Add(pResources->GetResourceFilename(defaultLocale));
- arguments.Add(defaultLocale);
+ arguments.Add(pResources->GetResourceFilename(defaultMessageLocale));
+ arguments.Add(defaultMessageLocale);
STRING message = pResources->FormatMessage(MgResources::FailedToLoadResourcesFile, &arguments);
ACE_DEBUG((LM_INFO, ACE_TEXT("(%P|%t) %W\n"), message.c_str()));
// Check to see if we were attempting to load the "en" locale resources.
- if(MgResources::DefaultLocale == defaultLocale)
+ if(MgResources::DefaultMessageLocale == defaultMessageLocale)
- // The server needs to fail to start because the specified default locale was
+ // The server needs to fail to start because the specified default message locale was
// the same as "en"
nResult = -1;
else
// Try loading the "en" locale resources instead
- defaultLocale = MgResources::DefaultLocale;
+ defaultMessageLocale = MgResources::DefaultMessageLocale;
try
@@ -764,7 +787,7 @@
@@ -773,8 +796,8 @@
// We also failed to load the default "en" resource
@@ -806,7 +829,7 @@
// Initialize the Server Manager
ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::open() - Initializing Server Manager.\n")));
- pServerManager->Initialize(defaultLocale);
+ pServerManager->Initialize(defaultMessageLocale);
// We cannot add trace statements until the log manager is initialized.
MG_LOG_TRACE_ENTRY(L"MgServer::open() - Start");
@@ -954,7 +977,7 @@
#ifdef _DEBUG
MgEventTimer& connectionTimer = m_eventTimerManager.GetEventTimer(MgEventTimer::ConnectionTimeout);
- STRING strResourceFilename = pResources->GetResourceFilename(pServerManager->GetDefaultLocale());
+ STRING strResourceFilename = pResources->GetResourceFilename(pServerManager->GetDefaultMessageLocale());
ACE_DEBUG ((LM_DEBUG, ACE_TEXT("Server Information:\n")));
ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Commandline Options:\n")));
@@ -962,10 +985,11 @@
ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Test Mode : %s\n"), m_bTestMode == true ? ACE_TEXT("true") : ACE_TEXT("false")));
ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Test FDO : %s\n"), m_bTestFdo == true ? ACE_TEXT("true") : ACE_TEXT("false")));
ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n General Properties:\n")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Locale : %s\n"), MG_WCHAR_TO_TCHAR(strLocale)));
ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Machine IP : %s\n"), MG_WCHAR_TO_TCHAR(loadBalanceManager->GetLocalServerAddress())));
ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Fdo path : %s\n"), MG_WCHAR_TO_TCHAR(fdoPath)));
ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Logs path : %s\n"), MG_WCHAR_TO_TCHAR(pLogManager->GetLogsPath())));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Locale (Default) : %s\n"), MG_WCHAR_TO_TCHAR(pServerManager->GetDefaultLocale())));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Default Message Locale : %s\n"), MG_WCHAR_TO_TCHAR(pServerManager->GetDefaultMessageLocale())));
ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Locale Resources File Loaded : %s\n"), MG_WCHAR_TO_TCHAR(strResourceFilename)));
ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Client Service Properties:\n")));
ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Connection Timeout : %d\n"), connectionTimer.GetEventTimeout()));
@@ -1037,7 +1061,7 @@
Modified: trunk/MgDev/Server/src/Core/TimedEventHandler.cpp
--- trunk/MgDev/Server/src/Core/TimedEventHandler.cpp 2007-03-19 17:03:01 UTC (rev 1285)
+++ trunk/MgDev/Server/src/Core/TimedEventHandler.cpp 2007-03-19 17:25:35 UTC (rev 1286)
@@ -143,10 +143,10 @@
- CREFSTRING defaultLocale = serverManager->GetDefaultLocale();
+ CREFSTRING locale = serverManager->GetDefaultMessageLocale();
- ACE_DEBUG((LM_ERROR, ACE_TEXT("(%P|%t) %W\n"), e.GetDetails(defaultLocale).c_str()));
- MG_LOG_EXCEPTION_ENTRY(e.GetMessage(defaultLocale).c_str(), e.GetStackTrace(defaultLocale).c_str());
+ ACE_DEBUG((LM_ERROR, ACE_TEXT("(%P|%t) %W\n"), e.GetDetails(locale).c_str()));
+ MG_LOG_EXCEPTION_ENTRY(e.GetMessage(locale).c_str(), e.GetStackTrace(locale).c_str());
Modified: trunk/MgDev/Server/src/Core/main.cpp
--- trunk/MgDev/Server/src/Core/main.cpp 2007-03-19 17:03:01 UTC (rev 1285)
+++ trunk/MgDev/Server/src/Core/main.cpp 2007-03-19 17:25:35 UTC (rev 1286)
@@ -66,9 +66,6 @@
#endif
#endif
- // Set the locale to the C locale
- ::setlocale(LC_ALL, "C");
ACE::init();
// we need initialize Xerces before BDB
@@ -359,7 +356,7 @@
ACE_DEBUG((LM_ERROR, ACE_TEXT("(%P|%t) %W\n"), details.c_str()));
Modified: trunk/MgDev/Server/src/Core/serverconfig.ini
--- trunk/MgDev/Server/src/Core/serverconfig.ini 2007-03-19 17:03:01 UTC (rev 1285)
+++ trunk/MgDev/Server/src/Core/serverconfig.ini 2007-03-19 17:25:35 UTC (rev 1286)
@@ -38,7 +38,7 @@
# ConnectionTimerInterval Time interval in seconds for when the server
# checks for idle connections
# 0 < Value <= 2147483647
-# DefaultLocale ISO 639-1 name for the locale
+# DefaultMessageLocale ISO 639-1 name for the message locale
# Length = 2
# DisplayName Display name of the server
# 0 <= Length <= 255
@@ -46,6 +46,8 @@
# FdoPath Path where FDO is installed
# LicenseServerPath The path to the License server (not used by MapGuide Open Source)
+# Locale The server's locale. If left blank it will default to the operating system locale
+# 0 <= Length <= 255
# LogsDelimiter Delimiter that separates the data fields in
# the log files
# 0 < Length <= 128
@@ -75,10 +77,11 @@
-DefaultLocale = en
+DefaultMessageLocale = en
DisplayName =
FdoPath = FDO/
LicenseServerPath = @localhost
+Locale =
LogsDelimiter = \t
LogsPath = Logs/
MachineIp = 127.0.0.1
Modified: trunk/MgDev/Server/src/Services/Mapping/StylizationUtil.cpp
--- trunk/MgDev/Server/src/Services/Mapping/StylizationUtil.cpp 2007-03-19 17:03:01 UTC (rev 1285)
+++ trunk/MgDev/Server/src/Services/Mapping/StylizationUtil.cpp 2007-03-19 17:25:35 UTC (rev 1286)
@@ -1001,7 +1001,7 @@
// TODO: Eventually this should be used to indicate visually to the client what
// layer failed in addition to logging the error.
- STRING locale = (NULL == serverManager) ? MgResources::DefaultLocale : serverManager->GetDefaultLocale();
+ STRING locale = (NULL == serverManager) ? MgResources::DefaultMessageLocale : serverManager->GetDefaultMessageLocale();
// Get the layer that failed
Modified: trunk/MgDev/Server/src/UnitTesting/TestServerManager.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestServerManager.cpp 2007-03-19 17:03:01 UTC (rev 1285)
+++ trunk/MgDev/Server/src/UnitTesting/TestServerManager.cpp 2007-03-19 17:25:35 UTC (rev 1286)
@@ -59,12 +59,12 @@
/// Test Case Description:
-/// This test case checks the default locale.
+/// This test case checks the default message locale.
-void TestServerManager::TestCase_GetDefaultLocale()
+void TestServerManager::TestCase_GetDefaultMessageLocale()
MgServerManager* pMgServerManager = MgServerManager::GetInstance();
- CREFSTRING locale = pMgServerManager->GetDefaultLocale();
+ CREFSTRING locale = pMgServerManager->GetDefaultMessageLocale();
CPPUNIT_ASSERT(wcscmp(locale.c_str(), TEST_LOCALE.c_str()) == 0);
Modified: trunk/MgDev/Server/src/UnitTesting/TestServerManager.h
--- trunk/MgDev/Server/src/UnitTesting/TestServerManager.h 2007-03-19 17:03:01 UTC (rev 1285)
+++ trunk/MgDev/Server/src/UnitTesting/TestServerManager.h 2007-03-19 17:25:35 UTC (rev 1286)
@@ -26,7 +26,7 @@
CPPUNIT_TEST(TestStart); // This must be the very first unit test
CPPUNIT_TEST(TestCase_ValidServerManager);
- CPPUNIT_TEST(TestCase_GetDefaultLocale);
+ CPPUNIT_TEST(TestCase_GetDefaultMessageLocale);
CPPUNIT_TEST(TestCase_GetAdminPort);
CPPUNIT_TEST(TestCase_GetClientPort);
CPPUNIT_TEST(TestCase_GetSitePort);
@@ -45,7 +45,7 @@
void TestEnd();
void TestCase_ValidServerManager();
- void TestCase_GetDefaultLocale();
+ void TestCase_GetDefaultMessageLocale();
void TestCase_GetAdminPort();
void TestCase_GetClientPort();
void TestCase_GetSitePort();
Modified: trunk/MgDev/Web/src/WebSupport/InitializeWebTier.cpp
--- trunk/MgDev/Web/src/WebSupport/InitializeWebTier.cpp 2007-03-19 17:03:01 UTC (rev 1285)
+++ trunk/MgDev/Web/src/WebSupport/InitializeWebTier.cpp 2007-03-19 17:25:35 UTC (rev 1286)
@@ -46,7 +46,7 @@
config->GetStringValue(MgConfigProperties::GeneralPropertiesSection, MgConfigProperties::GeneralPropertyResourcesPath, resourcesPath, MgConfigProperties::DefaultGeneralPropertyResourcesPath);
STRING locale;
- config->GetStringValue(MgConfigProperties::GeneralPropertiesSection, MgConfigProperties::GeneralPropertyDefaultLocale, locale, MgConfigProperties::DefaultGeneralPropertyDefaultLocale);
+ config->GetStringValue(MgConfigProperties::GeneralPropertiesSection, MgConfigProperties::GeneralPropertyDefaultMessageLocale, locale, MgConfigProperties::DefaultGeneralPropertyDefaultMessageLocale);
resources->Initialize(resourcesPath);
resources->LoadResources(locale);
More information about the mapguide-commits
