[mapguide-commits] r1290 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Mon Mar 19 14:25:04 EDT 2007
Author: traianstanev
Date: 2007-03-19 14:25:04 -0400 (Mon, 19 Mar 2007)
New Revision: 1290
trunk/MgDev/Common/Stylization/SE_ExpressionBase.cpp
trunk/MgDev/Common/Stylization/SE_ExpressionBase.h
trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp
trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp
trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.h
MapGuideRfc14
Implemented caching of evaluated styles. Custom styles which are detected to be constant will not be evaluated for every feature, but only once for the whole layer.
Modified: trunk/MgDev/Common/Stylization/SE_ExpressionBase.cpp
--- trunk/MgDev/Common/Stylization/SE_ExpressionBase.cpp 2007-03-19 18:06:15 UTC (rev 1289)
+++ trunk/MgDev/Common/Stylization/SE_ExpressionBase.cpp 2007-03-19 18:25:04 UTC (rev 1290)
@@ -237,11 +237,11 @@
if (len == 0)
- val = 0;
+ val.value.argb = 0;
return;
- int ret = swscanf(cstr, L"%X%n", &val.argb(), &chars);
+ int ret = swscanf(cstr, L"%X%n", &val.value.argb, &chars);
if (ret == 1 && chars == len)
Modified: trunk/MgDev/Common/Stylization/SE_ExpressionBase.h
--- trunk/MgDev/Common/Stylization/SE_ExpressionBase.h 2007-03-19 18:06:15 UTC (rev 1289)
+++ trunk/MgDev/Common/Stylization/SE_ExpressionBase.h 2007-03-19 18:25:04 UTC (rev 1290)
@@ -26,10 +26,18 @@
struct SE_Color
- unsigned char b, g, r, a; // argb, but little endian
+ union
+ struct
+ unsigned char b, g, r, a; // argb, but little endian
+ } comps;
+ unsigned int argb;
+ } value; //g++ doesn't like nameless structs, otherwise things would be far cleaner
FdoExpression* expression;
- SE_INLINE SE_Color() : expression(NULL) { *((unsigned int*)this) = 0; }
+ SE_INLINE SE_Color() : expression(NULL) { value.argb = 0; }
~SE_Color() { if (expression) expression->Release(); }
// Retrieve argb color
@@ -40,7 +48,7 @@
try
expression->Process(processor);
- *((unsigned int*)this) = (unsigned int)processor->GetInt64Result();
+ value.argb = (unsigned int)processor->GetInt64Result();
catch (FdoException* e)
@@ -48,16 +56,15 @@
processor->Reset();
// set a default
- *((unsigned int*)this) = 0xff000000;
+ value.argb = 0xff000000;
- return *((unsigned int*)this);
+ return value.argb;
- SE_INLINE void operator=(unsigned int val) { *((unsigned int*)this) = val; }
- SE_INLINE bool empty() { return (*(unsigned int*)this) == 0 && expression == NULL; }
- SE_INLINE unsigned int& argb() { return (*(unsigned int*)this); }
+ SE_INLINE bool empty() { return value.argb == 0 && expression == NULL; }
+ SE_INLINE void operator=(unsigned int argb) { value.argb = argb; }
@@ -172,7 +179,7 @@
struct SE_String
- const wchar_t* value;
+ wchar_t* value;
SE_INLINE SE_String() : value(NULL), expression(NULL) { }
@@ -190,8 +197,7 @@
~SE_String()
- if (value)
- delete[] value;
+ delete[] value;
if (expression)
@@ -200,11 +206,8 @@
if (expression)
- if (value)
- delete[] value;
- value = NULL;
+ delete[] value;
+ value = NULL;
try
@@ -229,8 +232,7 @@
SE_INLINE void operator=(const wchar_t* s)
- if (value)
- delete[] value;
+ delete[] value;
if (s)
Modified: trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp
--- trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp 2007-03-19 18:06:15 UTC (rev 1289)
+++ trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp 2007-03-19 18:25:04 UTC (rev 1290)
@@ -60,6 +60,13 @@
ParseDoubleExpression(pointUsage.GetOriginOffsetX(), style->originOffset[0]);
ParseDoubleExpression(pointUsage.GetOriginOffsetY(), style->originOffset[1]);
ParseStringExpression(pointUsage.GetAngleControl(), style->angleControl);
+ //set flag if all properties are constant
+ style->cacheable = ! (style->angle.expression
+ || style->angleControl.expression
+ || style->originOffset[0].expression
+ || style->originOffset[1].expression);
return style;
@@ -75,6 +82,18 @@
ParseDoubleExpression(lineUsage.GetEndOffset(), style->endOffset);
ParseDoubleExpression(lineUsage.GetRepeat(), style->repeat);
ParseDoubleExpression(lineUsage.GetVertexAngleLimit(), style->vertexAngleLimit);
+ style->cacheable = ! ( style->angle.expression
+ || style->unitsControl.expression
+ || style->vertexControl.expression
+ || style->angle.expression
+ || style->startOffset.expression
+ || style->endOffset.expression
+ || style->repeat.expression
+ || style->vertexAngleLimit.expression);
return style;
@@ -90,6 +109,19 @@
ParseDoubleExpression(areaUsage.GetRepeatX(), style->repeat[0]);
ParseDoubleExpression(areaUsage.GetRepeatY(), style->repeat[1]);
ParseDoubleExpression(areaUsage.GetBufferWidth(), style->bufferWidth);
+ style->cacheable = !( style->angle.expression
+ || style->originControl.expression
+ || style->clippingControl.expression
+ || style->origin[0].expression
+ || style->origin[1].expression
+ || style->repeat[0].expression
+ || style->repeat[1].expression
+ || style->bufferWidth.expression);
return style;
@@ -394,8 +426,8 @@
/* If the color is transparent, there is no point in drawing this path,
* so we will change it to black. */
- if (line->color.argb() == 0)
- line->color.a = 255;
+ if (line->color.value.argb == 0)
+ line->color.value.comps.a = 255;
line->cacheable = !(line->weight.expression ||
line->color.expression ||
line->weightScalable.expression);
@@ -431,7 +463,7 @@
//TODO: Disallow expressions for now since
//ParseStringExpression(image.GetReference(), primitive->pngPath);
- primitive->pngPath.value = image.GetReference().c_str();
+ primitive->pngPath = image.GetReference().c_str();
primitive->pngPath.expression = NULL;
if (primitive->pngPath.expression == NULL) // constant path
@@ -526,6 +558,9 @@
m_primitive->resize = elem->GetResizeControl();
m_style->symbol.push_back(m_primitive);
+ //also update the style's cacheable flag to take into account the primitive's flag
+ m_style->cacheable = m_style->cacheable && m_primitive->cacheable;
m_primitive = NULL;
@@ -540,6 +575,12 @@
ParseDoubleExpression(box->GetPositionX(), m_style->resizePosition[0]);
ParseDoubleExpression(box->GetPositionY(), m_style->resizePosition[1]);
m_style->resize = box->GetGrowControl();
+ ! ( m_style->resizeSize[0].expression
+ || m_style->resizeSize[1].expression
+ || m_style->resizePosition[0].expression
+ || m_style->resizePosition[1].expression);
m_symbolization->styles.push_back(m_style);
Modified: trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp
--- trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp 2007-03-19 18:06:15 UTC (rev 1289)
+++ trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp 2007-03-19 18:25:04 UTC (rev 1290)
@@ -341,8 +341,20 @@
void SE_PointStyle::evaluate(SE_EvalContext* cxt)
- SE_RenderPointStyle* render = new SE_RenderPointStyle();
+ SE_RenderPointStyle* render;
+ if (cacheable && rstyle)
+ //style is constant and has been evluated once -- we can skip out of evaluation
+ return;
+ else
+ render = new SE_RenderPointStyle();
+ delete rstyle;
+ rstyle = render;
LineBuffer::GeomOperationType type;
switch(cxt->geometry->geom_type())
@@ -392,19 +404,26 @@
sxform.premultiply(*cxt->xform);
*cxt->xform = sxform; //BAD here we modify the passed in transform -- figure out a way to avoid this
- //set the cached renderStyle member variable
- //TODO: cache constant render styles
- delete rstyle;
- rstyle = render;
//evaluate all the primitives too
SE_Style::evaluate(cxt);
void SE_LineStyle::evaluate(SE_EvalContext* cxt)
- SE_RenderLineStyle* render = new SE_RenderLineStyle();
+ SE_RenderLineStyle* render;
+ return;
+ else
+ render = new SE_RenderLineStyle();
+ delete rstyle;
+ rstyle = render;
render->angleControl = angleControl.evaluate(cxt->exec);
render->unitsControl = unitsControl.evaluate(cxt->exec);
render->vertexControl = vertexControl.evaluate(cxt->exec);
@@ -416,18 +435,24 @@
render->repeat = repeat.evaluate(cxt->exec)*cxt->mm2px;
render->vertexAngleLimit = vertexAngleLimit.evaluate(cxt->exec) * M_PI180;
- delete rstyle;
- rstyle = render;
void SE_AreaStyle::evaluate(SE_EvalContext* cxt)
- SE_RenderAreaStyle* render = new SE_RenderAreaStyle();
+ SE_RenderAreaStyle* render;
+ return;
+ else
+ render = new SE_RenderAreaStyle();
+ delete rstyle;
+ rstyle = render;
render->originControl = originControl.evaluate(cxt->exec);
@@ -440,11 +465,6 @@
render->repeat[1] = repeat[1].evaluate(cxt->exec);
render->bufferWidth = bufferWidth.evaluate(cxt->exec);
- delete rstyle;
- rstyle = render;
Modified: trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.h
--- trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.h 2007-03-19 18:06:15 UTC (rev 1289)
+++ trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.h 2007-03-19 18:25:04 UTC (rev 1290)
@@ -132,6 +132,7 @@
struct SE_Style
SE_RenderStyle* rstyle; // cached evaluated RenderStyle
+ bool cacheable;
SE_PrimitiveList symbol;
SE_Integer renderPass;
@@ -140,7 +141,7 @@
SE_Double resizeSize[2];
ResizeBox::GrowControl resize;
- SE_INLINE SE_Style() : rstyle(NULL) { }
+ SE_INLINE SE_Style() : rstyle(NULL), cacheable(false) { }
virtual ~SE_Style();
@@ -212,8 +213,6 @@
~SE_Symbolization()
for (std::vector<SE_Style*>::iterator iter = styles.begin(); iter != styles.end(); iter++)
- //TODO: SE_Styles have no virtual destructor but they don't seem to need
- //to free stuff specific to the derived classes
delete *iter;
styles.clear();
@@ -224,9 +223,11 @@
struct SE_Rule
std::vector<SE_Symbolization*> symbolization;
- RS_String legendLabel; // no expressions on this guy
+ RS_String legendLabel; // no expressions on this guy?
FdoFilter* filter;
+ SE_Rule() : filter(NULL) { }
~SE_Rule()
if (filter) filter->Release();
More information about the mapguide-commits
