[mapguide-commits] r1304 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Tue Mar 20 15:05:34 EDT 2007
Author: traianstanev
Date: 2007-03-20 15:05:34 -0400 (Tue, 20 Mar 2007)
New Revision: 1304
trunk/MgDev/Common/Stylization/KmlRenderer.cpp
trunk/MgDev/Common/Stylization/KmlRenderer.h
The KML renderer will now output something (as opposed to nothing) when new SE composite styles are encountered. Basically I made KmlRenderer implement SE_Renderer and then overloaded some key virtual functions to pipe output of the new StyleEngine into the old Renderer APIs.
Modified: trunk/MgDev/Common/Stylization/KmlRenderer.cpp
--- trunk/MgDev/Common/Stylization/KmlRenderer.cpp 2007-03-20 19:03:47 UTC (rev 1303)
+++ trunk/MgDev/Common/Stylization/KmlRenderer.cpp 2007-03-20 19:05:34 UTC (rev 1304)
@@ -592,3 +592,132 @@
return number * scale_factor;
+// SE_Renderer implementation
+void KmlRenderer::DrawScreenPolyline(LineBuffer* geom, const SE_Matrix* xform, unsigned int color, double weight)
+void KmlRenderer::DrawScreenPolygon(LineBuffer* geom, const SE_Matrix* xform, unsigned int fill)
+void KmlRenderer::DrawScreenRaster(unsigned char* data, int length, RS_ImageFormat format, int native_width, int native_height,
+ double x, double y, double w, double h, double angledeg)
+void KmlRenderer::DrawScreenText(const RS_String& txt, RS_TextDef& tdef, double insx, double insy, double* path, int npts, double param_position)
+void KmlRenderer::GetWorldToScreenTransform(SE_Matrix& xform)
+void KmlRenderer::WorldToScreenPoint(double& inx, double& iny, double& ox, double& oy)
+void KmlRenderer::ScreenToWorldPoint(double& inx, double& iny, double& ox, double& oy)
+double KmlRenderer::GetPixelsPerMillimeterScreen()
+ return 96.0 / 25.4; //wrong but not currently used
+double KmlRenderer::GetPixelsPerMillimeterWorld()
+ return 96.0 / 25.4 / m_mapScale; //wrong but not currently used
+RS_FontEngine* KmlRenderer::GetFontEngine()
+ return NULL;
+void KmlRenderer::ProcessLabelGroup(SE_LabelInfo* labels,
+ int nlabels,
+ RS_OverpostType type,
+ bool exclude,
+ LineBuffer* path)
+void KmlRenderer::AddExclusionRegion(RS_F_Point* fpts, int npts)
+void KmlRenderer::ProcessPoint(LineBuffer* geometry, SE_RenderPointStyle* style)
+ RS_FillStyle fs;
+ RS_MarkerDef mdef(1.0, 1.0, 0.5, 0.5, 0.0, RS_Units_Device, L"", L"", fs);
+ ProcessMarker(geometry, mdef, !style->addToExclusionRegions, NULL);
+// TODO: If we want true composite styles generated by the SE_Renderer
+// these 3 functions need to be removed and instead the above DrawScreen*
+// functions should be implemented. The risk of fully styling all features
+// in the kml renderer is the insanely huge resulting KML files. So the solution
+// right now is to just pipe all features that come from the SE_Renderer
+// directly into the old Renderer APIs using arbitrary styles based on
+// information obtained from cursory examination of the SE composite style.
+void KmlRenderer::ProcessLine(LineBuffer* geometry, SE_RenderLineStyle* style)
+ RS_LineStroke ls(RS_Color(0,0,0,255), 0.0, L"Solid", RS_Units_Device);
+ //try to get some line style information from the SE symbol
+ if (style->symbol.size())
+ for (int i=0; i<style->symbol.size(); i++)
+ SE_RenderPrimitive* rp = style->symbol[i];
+ if (rp->type == SE_RenderPolylinePrimitive)
+ ls.color() = RS_Color::FromARGB(((SE_RenderPolyline*)rp)->color);
+ ls.width() = ((SE_RenderPolyline*)rp)->weight / GetPixelsPerMillimeterScreen() * 0.001; //convert from pixels to meters
+ //forward the feature to the regular ProcessPolyline API
+ ProcessPolyline(geometry, ls);
+void KmlRenderer::ProcessArea(LineBuffer* geometry, SE_RenderAreaStyle* style)
+ //not implemented upstream yet, but let's do something anyway
+ RS_FillStyle fs;
+ fs.color() = RS_Color(0,0,0,255);
+ //try to get some fill style information from the SE symbol
+ if (rp->type == SE_RenderPolygonPrimitive)
+ fs.color() = RS_Color::FromARGB(((SE_RenderPolygon*)rp)->fill);
+ fs.outline().color() = RS_Color::FromARGB(((SE_RenderPolygon*)rp)->color);
+ ProcessPolygon(geometry, fs);
Modified: trunk/MgDev/Common/Stylization/KmlRenderer.h
--- trunk/MgDev/Common/Stylization/KmlRenderer.h 2007-03-20 19:03:47 UTC (rev 1303)
+++ trunk/MgDev/Common/Stylization/KmlRenderer.h 2007-03-20 19:05:34 UTC (rev 1304)
@@ -30,6 +30,7 @@
#include <map>
#include "Renderer.h"
+#include "SE_Renderer.h"
#include "KmlContent.h"
typedef std::map<RS_String, KmlContent*> ThemeMap;
@@ -38,7 +39,7 @@
const double METERS_PER_INCH = 0.0254;
-class KmlRenderer : public Renderer
+class KmlRenderer : public Renderer, public SE_Renderer
public:
STYLIZATION_API KmlRenderer(KmlContent* kmlContent, RS_Bounds& extents,
@@ -116,6 +117,37 @@
STYLIZATION_API virtual bool RequiresClipping();
+ // SE_Renderer
+ virtual void DrawScreenPolyline(LineBuffer* geom, const SE_Matrix* xform, unsigned int color, double weight); // px
+ virtual void DrawScreenPolygon(LineBuffer* geom, const SE_Matrix* xform, unsigned int fill);
+ virtual void DrawScreenRaster(unsigned char* data, int length, RS_ImageFormat format, int native_width, int native_height,
+ double x, double y, double w, double h, double angledeg);
+ virtual void DrawScreenText(const RS_String& txt, RS_TextDef& tdef, double insx, double insy, double* path, int npts, double param_position);
+ virtual void GetWorldToScreenTransform(SE_Matrix& xform);
+ virtual void WorldToScreenPoint(double& inx, double& iny, double& ox, double& oy);
+ virtual void ScreenToWorldPoint(double& inx, double& iny, double& ox, double& oy);
+ virtual double GetPixelsPerMillimeterScreen();
+ virtual double GetPixelsPerMillimeterWorld();
+ virtual RS_FontEngine* GetFontEngine();
+ virtual void ProcessLabelGroup(SE_LabelInfo* labels,
+ int nlabels,
+ bool exclude,
+ LineBuffer* path = NULL);
+ virtual void AddExclusionRegion(RS_F_Point* fpts, int npts);
+ virtual void ProcessPoint(LineBuffer* geometry, SE_RenderPointStyle* style);
+ virtual void ProcessLine(LineBuffer* geometry, SE_RenderLineStyle* style);
+ virtual void ProcessArea(LineBuffer* geometry, SE_RenderAreaStyle* style);
private:
// Unimplemented Constructors/Methods
KmlRenderer(const KmlRenderer&);
More information about the mapguide-commits
