[mapguide-commits] r1312 - trunk/MgDev/Oem/proj-4.5.0/src
svn_mapguide at osgeo.org
Tue Mar 20 23:55:05 EDT 2007
Author: stevedang
Date: 2007-03-20 23:55:05 -0400 (Tue, 20 Mar 2007)
New Revision: 1312
Added:
trunk/MgDev/Oem/proj-4.5.0/src/proj.vcproj
trunk/MgDev/Oem/proj-4.5.0/src/PJ_gn_sinu.c
trunk/MgDev/Oem/proj-4.5.0/src/PJ_laea.c
trunk/MgDev/Oem/proj-4.5.0/src/makefile.vc
PROJ 4.5.0 upgrade (part 1):
- Fix MapGuide crashing problem on debug Windows.
- Incorporate changes made to PROJ 4.4.9 (e.g. running MT tool to add manifest to DLL, removing duplicate calls to pj_enfn(), freeing data allocated in pj_authset(), using a relative path for PROJ_LIB_DIR, fixing compiler settings to produce correct PDB).
Modified: trunk/MgDev/Oem/proj-4.5.0/src/PJ_gn_sinu.c
--- trunk/MgDev/Oem/proj-4.5.0/src/PJ_gn_sinu.c 2007-03-21 02:47:39 UTC (rev 1311)
+++ trunk/MgDev/Oem/proj-4.5.0/src/PJ_gn_sinu.c 2007-03-21 03:55:05 UTC (rev 1312)
@@ -75,7 +75,6 @@
if (!(P->en = pj_enfn(P->es)))
E_ERROR_0;
if (P->es) {
- P->en = pj_enfn(P->es);
P->inv = e_inverse;
P->fwd = e_forward;
} else {
Modified: trunk/MgDev/Oem/proj-4.5.0/src/PJ_laea.c
--- trunk/MgDev/Oem/proj-4.5.0/src/PJ_laea.c 2007-03-21 02:47:39 UTC (rev 1311)
+++ trunk/MgDev/Oem/proj-4.5.0/src/PJ_laea.c 2007-03-21 03:55:05 UTC (rev 1312)
@@ -179,8 +179,14 @@
0. : atan2(xy.x, xy.y);
return (lp);
-FREEUP; if (P) pj_dalloc(P); }
-ENTRY0(laea)
+FREEUP;
+ if (P) {
+ if (P->apa)
+ pj_dalloc(P->apa);
+ pj_dalloc(P);
+ENTRY1(laea, apa)
double t;
if (fabs((t = fabs(P->phi0)) - HALFPI) < EPS10)
Modified: trunk/MgDev/Oem/proj-4.5.0/src/makefile.vc
--- trunk/MgDev/Oem/proj-4.5.0/src/makefile.vc 2007-03-21 02:47:39 UTC (rev 1311)
+++ trunk/MgDev/Oem/proj-4.5.0/src/makefile.vc 2007-03-21 03:55:05 UTC (rev 1312)
@@ -5,11 +5,11 @@
# be adjusted. It is also possible to leave this, and define the
# PROJ_LIB environment variable to point to the NAD directory.
-PROJ_LIB_DIR=C:/PROJ/NAD
+PROJ_LIB_DIR=../NAD
# Uncomment the first for an optimized build, or the second for debug.
-OPTFLAGS= /nologo /Ox /MD
-#OPTFLAGS= /nologo /Zi /MD /Fdproj.pdb
+OPTFLAGS= /nologo /Ox /MD /Zi /Fdprojvc.pdb
+#OPTFLAGS= /nologo /Od /MDd /Zi /Fdprojvc.pdb
# Uncomment the first for linking exes against DLL or second for static
EXE_PROJ = proj_i.lib
@@ -88,7 +88,8 @@
proj_i.lib: $(LIBOBJ)
link /debug /dll /def:proj.def /out:$(PROJ_DLL) /implib:proj_i.lib \
- $(LIBOBJ)
+ /manifest /manifestfile:proj.dll.manifest $(LIBOBJ)
+ mt -manifest proj.dll.manifest -outputresource:$(PROJ_DLL);2
proj.exe: $(PROJEXE_OBJ) $(EXE_PROJ)
cl $(PROJEXE_OBJ) $(EXE_PROJ)
Added: trunk/MgDev/Oem/proj-4.5.0/src/proj.vcproj
--- trunk/MgDev/Oem/proj-4.5.0/src/proj.vcproj (rev 0)
+++ trunk/MgDev/Oem/proj-4.5.0/src/proj.vcproj 2007-03-21 03:55:05 UTC (rev 1312)
@@ -0,0 +1,70 @@
+<?xml version="1.0" encoding="Windows-1252"?>
+<VisualStudioProject
+ ProjectType="Visual C++"
+ Version="8.00"
+ Name="PROJ"
+ ProjectGUID="{E8F6DBAE-C078-4826-B774-01EFA74219F6}"
+ Keyword="MakeFileProj"
+ <Platforms>
+ <Platform
+ Name="Win32"
+ </Platforms>
+ <ToolFiles>
+ </ToolFiles>
+ <Configurations>
+ <Configuration
+ Name="Debug|Win32"
+ OutputDirectory="Debug"
+ IntermediateDirectory="Debug"
+ ConfigurationType="0"
+ InheritedPropertySheets="$(VCInstallDir)VCProjectDefaults\UpgradeFromVC71.vsprops"
+ <Tool
+ Name="VCNMakeTool"
+ BuildCommandLine="nmake /f makefile.vc proj_i.lib"
+ ReBuildCommandLine="nmake /f makefile.vc clean all"
+ CleanCommandLine="nmake /f makefile.vc clean"
+ Output=""
+ PreprocessorDefinitions=""
+ IncludeSearchPath=""
+ ForcedIncludes=""
+ AssemblySearchPath=""
+ ForcedUsingAssemblies=""
+ CompileAsManaged=""
+ </Configuration>
+ <Configuration
+ Name="Release|Win32"
+ OutputDirectory="Release"
+ IntermediateDirectory="Release"
+ <Tool
+ Output=""
+ ForcedIncludes=""
+ </Configuration>
+ </Configurations>
+ <References>
+ </References>
+ <Files>
+ <File
+ RelativePath=".\makefile.vc"
+ </File>
+ </Files>
+ <Globals>
+ </Globals>
+</VisualStudioProject>
Property changes on: trunk/MgDev/Oem/proj-4.5.0/src/proj.vcproj
___________________________________________________________________
+ native
More information about the mapguide-commits
