[mapguide-commits] r1313 - trunk/MgDev/Server/src/Services/Mapping
Walt Welton-Lair
walt.welton-lair at autodesk.com
Wed Mar 21 07:22:42 EDT 2007
Log should have been:
The server was crashing in MgStylizationUtil::StylizeLayers when
processing
line layers which were missing spatial context information. The
problem was
that the TransformCache object was NULL (which is ok), but not all
places
that using it were checking for NULL.
-----Original Message-----
[mailto:mapguide-commits-bounces at lists.osgeo.org] On Behalf Of
svn_mapguide at osgeo.org
Sent: Wednesday, March 21, 2007 12:22 PM
To: mapguide-commits at lists.osgeo.org
Subject: [mapguide-commits] r1313 -
Author: waltweltonlair
Date: 2007-03-21 07:21:43 -0400 (Wed, 21 Mar 2007)
New Revision: 1313
trunk/MgDev/Server/src/Services/Mapping/StylizationUtil.cpp
Fix crash in StylizationUtil for line laye
Modified: trunk/MgDev/Server/src/Services/Mapping/StylizationUtil.cpp
--- trunk/MgDev/Server/src/Services/Mapping/StylizationUtil.cpp
2007-03-21 03:55:05 UTC (rev 1312)
+++ trunk/MgDev/Server/src/Services/Mapping/StylizationUtil.cpp
2007-03-21 11:21:43 UTC (rev 1313)
@@ -133,12 +133,12 @@
RSMgFeatureReader*
MgStylizationUtil::ExecuteFeatureQuery(MgFeatureService* svcFeature,
- RS_Bounds&
extent,
MdfModel::VectorLayerDefinition* vl,
- const wchar_t*
overrideFilter,
MgCoordinateSystem* mapCs,
MgCoordinateSystem* layerCs,
- TransformCache*
cache)
+ RS_Bounds&
extent,
+ const
wchar_t* overrideFilter,
TransformCache* cache)
#ifdef _DEBUG
long dwStart = GetTickCount();
@@ -672,6 +672,8 @@
//get a transform from layer coord sys to map coord
sys
TransformCache* item =
GetLayerToMapTransform(transformCache, vl->GetFeatureName(), featResId,
dstCs, csFactory, svcFeature);
+ MgCoordinateSystem* layerCs = item?
item->GetCoordSys() : NULL;
+ MgCSTrans* xformer = item? item->GetTransform() :
NULL;
//extract hyperlink and tooltip info
if (!vl->GetToolTip().empty())
legendInfo.hastooltips() = true;
@@ -747,10 +749,10 @@
//we are not drawing the actual geometry
if (maxStrokes == 0)
- RSMgFeatureReader* rdr =
ExecuteFeatureQuery(svcFeature, extent, vl, overrideFilter.c_str(),
dstCs, item ? item->GetCoordSys() : NULL, item);
+ RSMgFeatureReader* rdr =
dstCs, layerCs, item);
if (rdr)
- ds->StylizeVectorLayer(vl, dr, rdr,
item->GetTransform(), NULL, NULL);
+ ds->StylizeVectorLayer(vl, dr, rdr,
xformer, NULL, NULL);
delete rdr;
@@ -781,10 +783,10 @@
syms->Adopt(syms2->GetAt(min(i,
syms2->GetCount()-1)));
if (rdr)
delete rdr;
@@ -825,12 +827,12 @@
else
if (rdr)
//stylize into output format
dr->StartLayer(&legendInfo, &fcinfo);
- ds->StylizeVectorLayer(vl, dr, rdr, item ?
item->GetTransform() : NULL, NULL, NULL);
dr->EndLayer();
delete rdr;
@@ -874,6 +876,8 @@
sys
GetLayerToMapTransform(transformCache, gl->GetFeatureName(), featResId,
NULL;
//grid layer does not yet have hyperlink or tooltip
@@ -917,12 +921,12 @@
//perform the raster query
ExecuteRasterQuery(svcFeature, extent, gl, overrideFilter.c_str(),
dstCs, item ? item->GetCoordSys() : NULL, width, height);
dstCs, layerCs, width, height);
if (rdr)
//stylize into a dwf
- ds->StylizeGridLayer(gl, dr, rdr,
+ ds->StylizeGridLayer(gl, dr, rdr, xformer,
NULL, NULL);
dr->EndLayer();
delete rdr;
mapguide-commits mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-commits
More information about the mapguide-commits
