[mapguide-commits] r1320 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Wed Mar 21 16:22:21 EDT 2007
Author: traianstanev
Date: 2007-03-21 16:22:21 -0400 (Wed, 21 Mar 2007)
New Revision: 1320
trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp
trunk/MgDev/Common/Stylization/SE_StyleVisitor.h
trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp
trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.h
Part 2 of fix for image resources. Also added support for image name being an expression and also fixed problems with fetching images when they are attached to the symbol definition resources.
Modified: trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp
--- trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp 2007-03-21 20:21:10 UTC (rev 1319)
+++ trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp 2007-03-21 20:22:21 UTC (rev 1320)
@@ -454,6 +454,10 @@
SE_Raster* primitive = new SE_Raster();
m_primitive = primitive;
+ //remember the parent symbol's res ID so that we can use it later for getting the raster data
+ //in case the image name is an expression
+ primitive->resId = m_resIdStack.back();
if (image.GetContent().size())
/* Handle this; Base64 as MdfString is not a particularly inspired plan */
@@ -461,13 +465,10 @@
else
- //TODO: Disallow expressions for now since
- //ParseStringExpression(image.GetReference(), primitive->pngPath);
- primitive->pngPath = image.GetReference().c_str();
- primitive->pngPath.expression = NULL;
+ ParseStringExpression(image.GetReference(), primitive->pngPath);
if (primitive->pngPath.expression == NULL) // constant path
- primitive->pngPtr = m_resources? m_resources->GetImageData(image.GetReference().c_str(), primitive->pngSize) : NULL;
+ primitive->pngPtr = m_resources? m_resources->GetImageData(primitive->resId, primitive->pngPath.value, primitive->pngSize) : NULL;
else
primitive->pngPtr = NULL;
@@ -594,6 +595,8 @@
SimpleSymbol* sym = symbols->GetAt(i);
+ bool isRef = false;
// get the symbol definition, either inlined or by reference
SimpleSymbolDefinition* def = sym->GetSymbolDefinition();
if (def == NULL)
@@ -605,12 +608,20 @@
def = dynamic_cast<SimpleSymbolDefinition*>(m_resources->GetSymbolDefinition(ref.c_str()));
if (def == NULL)
return;
+ //remember the current symbol resource id, in case it references an
+ //attached png image resource
+ isRef = true;
+ m_resIdStack.push_back(ref.c_str());
VisitSimpleSymbolDefinition(*def);
if (m_style)
ParseIntegerExpression(sym->GetRenderingPass(), m_style->renderPass);
+ if (isRef)
+ m_resIdStack.pop_back();
@@ -619,6 +630,8 @@
if (symbolization == NULL)
return;
+ m_resIdStack.clear();
SymbolInstanceCollection* symbols = symbolization->GetSymbolCollection();
int nSymbols = symbols->GetCount();
@@ -628,6 +641,8 @@
SetParameterValues(instance->GetParameterOverrides());
SymbolDefinition* def = instance->GetSymbolDefinition();
if (def == NULL)
@@ -639,6 +654,11 @@
def = m_resources->GetSymbolDefinition(ref.c_str());
if (def == NULL)
continue;
+ isRef = true;
m_symbolization = new SE_Symbolization();
@@ -658,7 +678,10 @@
ParseDoubleExpression(instance->GetInsertionOffsetY(), m_symbolization->absOffset[1]);
def->AcceptVisitor(*this);
+ result.push_back(m_symbolization);
- result.push_back(m_symbolization);
+ if (isRef)
Modified: trunk/MgDev/Common/Stylization/SE_StyleVisitor.h
--- trunk/MgDev/Common/Stylization/SE_StyleVisitor.h 2007-03-21 20:21:10 UTC (rev 1319)
+++ trunk/MgDev/Common/Stylization/SE_StyleVisitor.h 2007-03-21 20:22:21 UTC (rev 1320)
@@ -64,6 +64,7 @@
SE_Symbolization* m_symbolization;
SE_Style* m_style;
SE_Primitive* m_primitive;
+ std::vector<const wchar_t*> m_resIdStack;
#endif // SE_STYLEVISITOR_H
Modified: trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp
--- trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp 2007-03-21 20:21:10 UTC (rev 1319)
+++ trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp 2007-03-21 20:22:21 UTC (rev 1320)
@@ -257,7 +257,7 @@
if (!pngPtr)
- ret->pngPtr = cxt->resources->GetImageData(pngPath.evaluate(cxt->exec), ret->pngSize);
+ ret->pngPtr = cxt->resources->GetImageData(resId, pngPath.evaluate(cxt->exec), ret->pngSize);
else
Modified: trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.h
--- trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.h 2007-03-21 20:21:10 UTC (rev 1319)
+++ trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.h 2007-03-21 20:22:21 UTC (rev 1320)
@@ -110,6 +110,7 @@
struct SE_Raster : public SE_Primitive
SE_String pngPath;
+ const wchar_t* resId;
const unsigned char* pngPtr;
int pngSize;
SE_Double position[2];
More information about the mapguide-commits
