[mapguide-commits] r1325 - trunk/MgDev/Common/MdfParser
    svn_mapguide at osgeo.org
    Wed Mar 21 16:49:58 EDT 2007
Author: ronnielouie
Date: 2007-03-21 16:49:58 -0400 (Wed, 21 Mar 2007)
New Revision: 1325
   trunk/MgDev/Common/MdfParser/IOElevationSettings.cpp
ElevationSettings in the layer definition xml was not output correctly.  This submission fixes the string encoding and the order for the ZOffsetType element.
Modified: trunk/MgDev/Common/MdfParser/IOElevationSettings.cpp
--- trunk/MgDev/Common/MdfParser/IOElevationSettings.cpp	2007-03-21 20:38:08 UTC (rev 1324)
+++ trunk/MgDev/Common/MdfParser/IOElevationSettings.cpp	2007-03-21 20:49:58 UTC (rev 1325)
@@ -128,29 +128,29 @@
     fd << EncodeString(elevationSettings->GetZExtrusionExpression());
     fd << "</ZExtrusion>" << std::endl; // NOXLATE
-    fd << tab() << "<Unit>"; // NOXLATE
-    std::auto_ptr<MdfString> str(LengthConverter::UnitToEnglish(elevationSettings->GetUnit()));
-    fd << EncodeString(*str);
-    fd << "</Unit>" << std::endl; // NOXLATE
     fd << tab() << "<ZOffsetType>"; // NOXLATE
     ElevationSettings::ElevationType elevType = elevationSettings->GetElevationType();
     switch(elevType)
     case ElevationSettings::Absolute:
-            fd << ELEV_TYPE_ABSOLUTE;
+            fd << EncodeString(ELEV_TYPE_ABSOLUTE);
             break;
     case ElevationSettings::RelativeToGround:
     default:
-            fd << ELEV_TYPE_RELATIVE_TO_GROUND;
+            fd << EncodeString(ELEV_TYPE_RELATIVE_TO_GROUND);
             break;
     fd << "</ZOffsetType>" << std::endl; // NOXLATE
+    fd << tab() << "<Unit>"; // NOXLATE
+    std::auto_ptr<MdfString> str(LengthConverter::UnitToEnglish(elevationSettings->GetUnit()));
+    fd << EncodeString(*str);
+    fd << "</Unit>" << std::endl; // NOXLATE
     // Write any previously found unknown XML
     if (!elevationSettings->GetUnknownXml().empty())
More information about the mapguide-commits
