[mapguide-commits] r1338 - trunk/MgDev
svn_mapguide at osgeo.org
Wed Mar 21 19:34:04 EDT 2007
Author: stevedang
Date: 2007-03-21 19:34:03 -0400 (Wed, 21 Mar 2007)
New Revision: 1338
trunk/MgDev/configure
trunk/MgDev/configure.in
GDAL 1.4.0 and PROJ 4.5.0 upgrades.
Modified: trunk/MgDev/configure
--- trunk/MgDev/configure 2007-03-21 23:28:35 UTC (rev 1337)
+++ trunk/MgDev/configure 2007-03-21 23:34:03 UTC (rev 1338)
@@ -243,18 +243,7 @@
$as_unset CDPATH
-# Find the correct PATH separator. Usually this is `:', but
-# DJGPP uses `;' like DOS.
-if test "X${PATH_SEPARATOR+set}" != Xset; then
- UNAME=${UNAME-`uname 2>/dev/null`}
- case X$UNAME in
- *-DOS) lt_cv_sys_path_separator=';' ;;
- *) lt_cv_sys_path_separator=':' ;;
- esac
- PATH_SEPARATOR=$lt_cv_sys_path_separator
-fi
# Check that we are running under the correct shell.
SHELL=${CONFIG_SHELL-/bin/sh}
@@ -272,7 +261,7 @@
elif test "X$1" = X--fallback-echo; then
# Avoid inline document here, it may be left over
-elif test "X`($echo '\t') 2>/dev/null`" = 'X\t'; then
+elif test "X`($echo '\t') 2>/dev/null`" = 'X\t' ; then
# Yippee, $echo works!
else
@@ -284,7 +273,7 @@
# used as fallback echo
shift
cat <<EOF
EOF
exit 0
fi
@@ -318,8 +307,9 @@
# So, first we look for a working echo in the user's PATH.
- IFS="${IFS= }"; save_ifs="$IFS"; IFS=$PATH_SEPARATOR
+ lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
for dir in $PATH /usr/ucb; do
+ IFS="$lt_save_ifs"
if (test -f $dir/echo || test -f $dir/echo$ac_exeext) &&
test "X`($dir/echo '\t') 2>/dev/null`" = 'X\t' &&
echo_testing_string=`($dir/echo "$echo_test_string") 2>/dev/null` &&
@@ -328,7 +318,7 @@
break
fi
done
- IFS="$save_ifs"
if test "X$echo" = Xecho; then
# We didn't find a better echo, so look for alternatives.
@@ -402,6 +392,11 @@
+tagnames=${tagnames+${tagnames},}CXX
+tagnames=${tagnames+${tagnames},}F77
# Name of the host.
# hostname on some systems (SVR3.2, Linux) returns a bogus exit status,
# so uname gets run too.
@@ -471,9 +466,9 @@
# include <unistd.h>
#endif"
-ac_subdirs_all="$ac_subdirs_all Oem/proj-4.4.9"
-ac_subdirs_all="$ac_subdirs_all Oem/gdal-1.3.0"
-ac_subst_vars='SHELL PATH_SEPARATOR PACKAGE_NAME PACKAGE_TARNAME PACKAGE_VERSION PACKAGE_STRING PACKAGE_BUGREPORT exec_prefix prefix program_transform_name bindir sbindir libexecdir datadir sysconfdir sharedstatedir localstatedir libdir includedir oldincludedir infodir mandir build_alias host_alias target_alias DEFS ECHO_C ECHO_N ECHO_T LIBS INSTALL_PROGRAM INSTALL_SCRIPT INSTALL_DATA PACKAGE VERSION ACLOCAL AUTOCONF AUTOMAKE AUTOHEADER MAKEINFO AMTAR install_sh STRIP ac_ct_STRIP INSTALL_STRIP_PROGRAM AWK SET_MAKE CC CFLAGS LDFLAGS CPPFLAGS ac_ct_CC EXEEXT OBJEXT DEPDIR am__include am__quote AMDEP_TRUE AMDEP_FALSE AMDEPBACKSLASH CCDEPMODE CXX CXXFLAGS ac_ct_CXX CXXDEPMODE build build_cpu build_vendor build_os host host_cpu host_vendor host_os LN_S ECHO RANLIB ac_ct_RANLIB CXXCPP EGREP LIBTOOL map_coordsys_dir map_coordsys_dir_path map_coordsys_include_path map_unittesting_dir map_fdo_include map_fdo_lib subdirs map_proj_prefix map_gdal_prefix map_opt_oem_subdirs map_opt_oem_distsubdirs map_toplevel_subdirs map_srcdir LIBOBJS LTLIBOBJS'
+ac_subdirs_all="$ac_subdirs_all Oem/proj-4.5.0"
+ac_subdirs_all="$ac_subdirs_all Oem/gdal-1.4.0"
+ac_subst_vars='SHELL PATH_SEPARATOR PACKAGE_NAME PACKAGE_TARNAME PACKAGE_VERSION PACKAGE_STRING PACKAGE_BUGREPORT exec_prefix prefix program_transform_name bindir sbindir libexecdir datadir sysconfdir sharedstatedir localstatedir libdir includedir oldincludedir infodir mandir build_alias host_alias target_alias DEFS ECHO_C ECHO_N ECHO_T LIBS INSTALL_PROGRAM INSTALL_SCRIPT INSTALL_DATA CYGPATH_W PACKAGE VERSION ACLOCAL AUTOCONF AUTOMAKE AUTOHEADER MAKEINFO install_sh STRIP ac_ct_STRIP INSTALL_STRIP_PROGRAM mkdir_p AWK SET_MAKE am__leading_dot AMTAR am__tar am__untar CC CFLAGS LDFLAGS CPPFLAGS ac_ct_CC EXEEXT OBJEXT DEPDIR am__include am__quote AMDEP_TRUE AMDEP_FALSE AMDEPBACKSLASH CCDEPMODE am__fastdepCC_TRUE am__fastdepCC_FALSE CXX CXXFLAGS ac_ct_CXX CXXDEPMODE am__fastdepCXX_TRUE am__fastdepCXX_FALSE build build_cpu build_vendor build_os host host_cpu host_vendor host_os EGREP LN_S ECHO AR ac_ct_AR RANLIB ac_ct_RANLIB CPP CXXCPP F77 FFLAGS ac_ct_F77 LIBTOOL map_coordsys_dir map_coordsys_dir_path map_coordsys_include_path map_unittesting_dir map_fdo_include map_fdo_lib subdirs map_proj_prefix map_gdal_prefix map_opt_oem_subdirs map_opt_oem_distsubdirs map_toplevel_subdirs map_srcdir LIBOBJS LTLIBOBJS'
ac_subst_files=''
# Initialize some variables set by options.
@@ -938,10 +933,22 @@
ac_env_CXXFLAGS_value=$CXXFLAGS
ac_cv_env_CXXFLAGS_set=${CXXFLAGS+set}
ac_cv_env_CXXFLAGS_value=$CXXFLAGS
+ac_env_CPP_set=${CPP+set}
+ac_env_CPP_value=$CPP
+ac_cv_env_CPP_set=${CPP+set}
+ac_cv_env_CPP_value=$CPP
ac_env_CXXCPP_set=${CXXCPP+set}
ac_env_CXXCPP_value=$CXXCPP
ac_cv_env_CXXCPP_set=${CXXCPP+set}
ac_cv_env_CXXCPP_value=$CXXCPP
+ac_env_F77_set=${F77+set}
+ac_env_F77_value=$F77
+ac_cv_env_F77_set=${F77+set}
+ac_cv_env_F77_value=$F77
+ac_env_FFLAGS_set=${FFLAGS+set}
+ac_env_FFLAGS_value=$FFLAGS
+ac_cv_env_FFLAGS_set=${FFLAGS+set}
+ac_cv_env_FFLAGS_value=$FFLAGS
# Report the --help message.
@@ -1023,11 +1030,14 @@
Optional Features:
--disable-FEATURE do not include FEATURE (same as --enable-FEATURE=no)
--enable-FEATURE[=ARG] include FEATURE [ARG=yes]
- --disable-dependency-tracking Speeds up one-time builds
- --enable-dependency-tracking Do not reject slow dependency extractors
- --enable-shared=PKGS build shared libraries default=yes
- --enable-static=PKGS build static libraries default=yes
- --enable-fast-install=PKGS optimize for fast installation default=yes
+ --disable-dependency-tracking speeds up one-time build
+ --enable-dependency-tracking do not reject slow dependency extractors
+ --enable-shared[=PKGS]
+ build shared libraries [default=yes]
+ --enable-static[=PKGS]
+ build static libraries [default=yes]
+ --enable-fast-install[=PKGS]
+ optimize for fast installation [default=yes]
--disable-libtool-lock avoid locking (might break parallel builds)
--enable-optimized enable optimized build default=no
--enable-server enable server build default=yes
@@ -1036,8 +1046,11 @@
Optional Packages:
--with-PACKAGE[=ARG] use PACKAGE [ARG=yes]
--without-PACKAGE do not use PACKAGE (same as --with-PACKAGE=no)
- --with-gnu-ld assume the C compiler uses GNU ld default=no
- --with-pic try to use only PIC/non-PIC objects default=use both
+ --with-gnu-ld assume the C compiler uses GNU ld [default=no]
+ --with-pic try to use only PIC/non-PIC objects [default=use
+ both]
+ --with-tags[=TAGS]
+ include additional configurations [automatic]
--with-php specify php headers dir prefix as args default=no
--with-fdo-include specifies custom dir for fdo include files
default=DEFAULT
@@ -1045,7 +1058,7 @@
default=DEFAULT
--with-proj ignores Oem/proj4.4.9 specify installed dir prefix
default=DEFAULT
- --with-gdal ignores Oem/gdal-1.3.0 specify install dir prefix
+ --with-gdal ignores Oem/gdal-1.4.0 specify install dir prefix
default=no
Some influential environment variables:
@@ -1057,7 +1070,10 @@
headers in a nonstandard directory <include dir>
CXX C++ compiler command
CXXFLAGS C++ compiler flags
+ CPP C preprocessor
CXXCPP C++ preprocessor
+ F77 Fortran 77 compiler command
+ FFLAGS Fortran 77 compiler flags
Use these variables to override the choices made by `configure' or to help
it to find libraries and programs with nonstandard names/locations.
@@ -1509,7 +1525,7 @@
-am__api_version="1.6"
+am__api_version="1.9"
ac_aux_dir=
for ac_dir in $srcdir $srcdir/.. $srcdir/../..; do
if test -f $ac_dir/install-sh; then
@@ -1672,7 +1688,6 @@
program_transform_name=`echo $program_transform_name | sed -f conftest.sed`
rm conftest.sed
# expand $ac_aux_dir to an absolute path
am_aux_dir=`cd $ac_aux_dir && pwd`
@@ -1686,6 +1701,39 @@
echo "$as_me: WARNING: \`missing' script is too old or missing" >&2;}
fi
+if mkdir -p --version . >/dev/null 2>&1 && test ! -d ./--version; then
+ # We used to keeping the `.' as first argument, in order to
+ # allow $(mkdir_p) to be used without argument. As in
+ # $(mkdir_p) $(somedir)
+ # where $(somedir) is conditionally defined. However this is wrong
+ # for two reasons:
+ # 1. if the package is installed by a user who cannot write `.'
+ # make install will fail,
+ # 2. the above comment should most certainly read
+ # $(mkdir_p) $(DESTDIR)$(somedir)
+ # so it does not work when $(somedir) is undefined and
+ # $(DESTDIR) is not.
+ # To support the latter case, we have to write
+ # test -z "$(somedir)" || $(mkdir_p) $(DESTDIR)$(somedir),
+ # so the `.' trick is pointless.
+ mkdir_p='mkdir -p --'
+else
+ # On NextStep and OpenStep, the `mkdir' command does not
+ # recognize any option. It will interpret all options as
+ # directories to create, and then abort because `.' already
+ # exists.
+ for d in ./-p ./--version;
+ do
+ test -d $d && rmdir $d
+ done
+ # $(mkinstalldirs) is defined by Automake if mkinstalldirs exists.
+ if test -f "$ac_aux_dir/mkinstalldirs"; then
+ mkdir_p='$(mkinstalldirs)'
+ else
+ mkdir_p='$(install_sh) -d'
+ fi
+fi
for ac_prog in gawk mawk nawk awk
do
# Extract the first word of "$ac_prog", so it can be a program name with args.
@@ -1755,7 +1803,16 @@
SET_MAKE="MAKE=${MAKE-make}"
fi
- # test to see if srcdir already configured
+rm -rf .tst 2>/dev/null
+mkdir .tst 2>/dev/null
+if test -d .tst; then
+ am__leading_dot=.
+else
+ am__leading_dot=_
+fi
+rmdir .tst 2>/dev/null
+# test to see if srcdir already configured
if test "`cd $srcdir && pwd`" != "`pwd`" &&
test -f $srcdir/config.status; then
{ { echo "$as_me:$LINENO: error: source directory already configured; run \"make distclean\" there first" >&5
@@ -1763,9 +1820,19 @@
{ (exit 1); exit 1; }; }
fi
+# test whether we have cygpath
+if test -z "$CYGPATH_W"; then
+ if (cygpath --version) >/dev/null 2>/dev/null; then
+ CYGPATH_W='cygpath -w'
+ else
+ CYGPATH_W=echo
+ fi
+fi
# Define the identity of the package.
- PACKAGE=mapguide
- VERSION=1.2.0
+ PACKAGE='mapguide'
+ VERSION='1.2.0'
cat >>confdefs.h <<_ACEOF
@@ -1793,9 +1860,156 @@
MAKEINFO=${MAKEINFO-"${am_missing_run}makeinfo"}
+install_sh=${install_sh-"$am_aux_dir/install-sh"}
+# Installed binaries are usually stripped using `strip' when the user
+# run `make install-strip'. However `strip' might not be the right
+# tool to use in cross-compilation environments, therefore Automake
+# will honor the `STRIP' environment variable to overrule this program.
+if test "$cross_compiling" != no; then
+ if test -n "$ac_tool_prefix"; then
+ # Extract the first word of "${ac_tool_prefix}strip", so it can be a program name with args.
+set dummy ${ac_tool_prefix}strip; ac_word=$2
+echo "$as_me:$LINENO: checking for $ac_word" >&5
+echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6
+if test "${ac_cv_prog_STRIP+set}" = set; then
+ echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+ if test -n "$STRIP"; then
+ ac_cv_prog_STRIP="$STRIP" # Let the user override the test.
+else
+as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+for as_dir in $PATH
+do
+ IFS=$as_save_IFS
+ test -z "$as_dir" && as_dir=.
+ for ac_exec_ext in '' $ac_executable_extensions; do
+ if $as_executable_p "$as_dir/$ac_word$ac_exec_ext"; then
+ ac_cv_prog_STRIP="${ac_tool_prefix}strip"
+ echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5
+ break 2
+ fi
+done
+done
+fi
+fi
+STRIP=$ac_cv_prog_STRIP
+if test -n "$STRIP"; then
+ echo "$as_me:$LINENO: result: $STRIP" >&5
+echo "${ECHO_T}$STRIP" >&6
+else
+ echo "$as_me:$LINENO: result: no" >&5
+echo "${ECHO_T}no" >&6
+fi
+fi
+if test -z "$ac_cv_prog_STRIP"; then
+ ac_ct_STRIP=$STRIP
+ # Extract the first word of "strip", so it can be a program name with args.
+set dummy strip; ac_word=$2
+if test "${ac_cv_prog_ac_ct_STRIP+set}" = set; then
+else
+ if test -n "$ac_ct_STRIP"; then
+ ac_cv_prog_ac_ct_STRIP="$ac_ct_STRIP" # Let the user override the test.
+else
+do
+ IFS=$as_save_IFS
+ ac_cv_prog_ac_ct_STRIP="strip"
+ break 2
+ fi
+done
+done
+ test -z "$ac_cv_prog_ac_ct_STRIP" && ac_cv_prog_ac_ct_STRIP=":"
+fi
+fi
+ac_ct_STRIP=$ac_cv_prog_ac_ct_STRIP
+if test -n "$ac_ct_STRIP"; then
+ echo "$as_me:$LINENO: result: $ac_ct_STRIP" >&5
+echo "${ECHO_T}$ac_ct_STRIP" >&6
+else
+fi
+ STRIP=$ac_ct_STRIP
+else
+ STRIP="$ac_cv_prog_STRIP"
+fi
+fi
+INSTALL_STRIP_PROGRAM="\${SHELL} \$(install_sh) -c -s"
+# We need awk for the "check" target. The system "awk" is bad on
+# some platforms.
+# Always define AMTAR for backward compatibility.
AMTAR=${AMTAR-"${am_missing_run}tar"}
+am__tar='${AMTAR} chof - "$$tardir"'; am__untar='${AMTAR} xf -'
+if test "`cd $srcdir && pwd`" != "`pwd`" &&
+ test -f $srcdir/config.status; then
+ { { echo "$as_me:$LINENO: error: source directory already configured; run \"make distclean\" there first" >&5
+echo "$as_me: error: source directory already configured; run \"make distclean\" there first" >&2;}
+ { (exit 1); exit 1; }; }
+fi
+ else
+ CYGPATH_W=echo
+ fi
+fi
+# Define the identity of the package.
+ VERSION='1.2.0'
+cat >>confdefs.h <<_ACEOF
+#define PACKAGE "$PACKAGE"
+_ACEOF
+#define VERSION "$VERSION"
+_ACEOF
+# Some tools Automake needs.
+ACLOCAL=${ACLOCAL-"${am_missing_run}aclocal-${am__api_version}"}
+AUTOCONF=${AUTOCONF-"${am_missing_run}autoconf"}
+AUTOMAKE=${AUTOMAKE-"${am_missing_run}automake-${am__api_version}"}
+AUTOHEADER=${AUTOHEADER-"${am_missing_run}autoheader"}
+MAKEINFO=${MAKEINFO-"${am_missing_run}makeinfo"}
@@ -1888,12 +2102,100 @@
# some platforms.
+AMTAR=${AMTAR-"${am_missing_run}tar"}
+echo "$as_me:$LINENO: checking how to create a ustar tar archive" >&5
+echo $ECHO_N "checking how to create a ustar tar archive... $ECHO_C" >&6
+# Loop over all known methods to create a tar archive until one works.
+_am_tools='gnutar plaintar pax cpio none'
+_am_tools=${am_cv_prog_tar_ustar-$_am_tools}
+# Do not fold the above two line into one, because Tru64 sh and
+# Solaris sh will not grok spaces in the rhs of `-'.
+for _am_tool in $_am_tools
+do
+ case $_am_tool in
+ gnutar)
+ for _am_tar in tar gnutar gtar;
+ do
+ { echo "$as_me:$LINENO: $_am_tar --version" >&5
+ ($_am_tar --version) >&5 2>&5
+ ac_status=$?
+ echo "$as_me:$LINENO: \$? = $ac_status" >&5
+ (exit $ac_status); } && break
+ done
+ am__tar="$_am_tar --format=ustar -chf - "'"$$tardir"'
+ am__tar_="$_am_tar --format=ustar -chf - "'"$tardir"'
+ am__untar="$_am_tar -xf -"
+ plaintar)
+ # Must skip GNU tar: if it does not support --format= it doesn't create
+ # ustar tarball either.
+ (tar --version) >/dev/null 2>&1 && continue
+ am__tar='tar chf - "$$tardir"'
+ am__tar_='tar chf - "$tardir"'
+ am__untar='tar xf -'
+ pax)
+ am__tar='pax -L -x ustar -w "$$tardir"'
+ am__tar_='pax -L -x ustar -w "$tardir"'
+ am__untar='pax -r'
+ cpio)
+ am__tar='find "$$tardir" -print | cpio -o -H ustar -L'
+ am__tar_='find "$tardir" -print | cpio -o -H ustar -L'
+ am__untar='cpio -i -H ustar -d'
+ none)
+ am__tar=false
+ am__tar_=false
+ am__untar=false
+ esac
+ # If the value was cached, stop now. We just wanted to have am__tar
+ # and am__untar set.
+ test -n "${am_cv_prog_tar_ustar}" && break
+ # tar/untar a dummy directory, and stop if the command works
+ rm -rf conftest.dir
+ mkdir conftest.dir
+ echo GrepMe > conftest.dir/file
+ { echo "$as_me:$LINENO: tardir=conftest.dir && eval $am__tar_ >conftest.tar" >&5
+ (tardir=conftest.dir && eval $am__tar_ >conftest.tar) >&5 2>&5
+ ac_status=$?
+ if test -s conftest.tar; then
+ { echo "$as_me:$LINENO: $am__untar <conftest.tar" >&5
+ ($am__untar <conftest.tar) >&5 2>&5
+ ac_status=$?
+ grep GrepMe conftest.dir/file >/dev/null 2>&1 && break
+ fi
+done
+rm -rf conftest.dir
+if test "${am_cv_prog_tar_ustar+set}" = set; then
+else
+ am_cv_prog_tar_ustar=$_am_tool
+fi
+echo "$as_me:$LINENO: result: $am_cv_prog_tar_ustar" >&5
+echo "${ECHO_T}$am_cv_prog_tar_ustar" >&6
ac_ext=c
ac_cpp='$CPP $CPPFLAGS'
ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
@@ -2829,24 +3131,16 @@
ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
ac_compiler_gnu=$ac_cv_c_compiler_gnu
-rm -f .deps 2>/dev/null
-mkdir .deps 2>/dev/null
-if test -d .deps; then
- DEPDIR=.deps
-else
- # MS-DOS does not allow filenames that begin with a dot.
- DEPDIR=_deps
-fi
-rmdir .deps 2>/dev/null
+DEPDIR="${am__leading_dot}deps"
ac_config_commands="$ac_config_commands depfiles"
am_make=${MAKE-make}
cat > confinc << 'END'
-doit:
+am__doit:
@echo done
+.PHONY: am__doit
END
# If we don't find an include directive, just comment out the code.
echo "$as_me:$LINENO: checking for style of include used by $am_make" >&5
@@ -2861,7 +3155,7 @@
# In particular we don't look at `^make:' because GNU make might
# be invoked under some other name (usually "gmake"), in which
# case it prints its new name instead of `make'.
-if test "`$am_make -s -f confmf 2> /dev/null | fgrep -v 'ing directory'`" = "done"; then
+if test "`$am_make -s -f confmf 2> /dev/null | grep -v 'ing directory'`" = "done"; then
am__include=include
am__quote=
_am_result=GNU
@@ -2921,18 +3215,34 @@
# using a relative directory.
cp "$am_depcomp" conftest.dir
cd conftest.dir
+ # We will build objects and dependencies in a subdirectory because
+ # it helps to detect inapplicable dependency modes. For instance
+ # both Tru64's cc and ICC support -MD to output dependencies as a
+ # side effect of compilation, but ICC will put the dependencies in
+ # the current directory while Tru64 will put them in the object
+ # directory.
+ mkdir sub
am_cv_CC_dependencies_compiler_type=none
if test "$am_compiler_list" = ""; then
am_compiler_list=`sed -n 's/^#*\([a-zA-Z0-9]*\))$/\1/p' < ./depcomp`
fi
for depmode in $am_compiler_list; do
+ # Setup a source with many dependencies, because some compilers
+ # like to wrap large dependency lists on column 80 (with \), and
+ # we should not choose a depcomp mode which is confused by this.
# We need to recreate these files for each test, as the compiler may
# overwrite some of them when testing with obscure command lines.
# This happens at least with the AIX C compiler.
- echo '#include "conftest.h"' > conftest.c
- echo 'int i;' > conftest.h
- echo "${am__include} ${am__quote}conftest.Po${am__quote}" > confmf
+ : > sub/conftest.c
+ for i in 1 2 3 4 5 6; do
+ echo '#include "conftst'$i'.h"' >> sub/conftest.c
+ # Using `: > sub/conftst$i.h' creates only sub/conftst1.h with
+ # Solaris 8's {/usr,}/bin/sh.
+ touch sub/conftst$i.h
+ done
+ echo "${am__include} ${am__quote}sub/conftest.Po${am__quote}" > confmf
case $depmode in
nosideeffect)
@@ -2950,13 +3260,25 @@
# mode. It turns out that the SunPro C++ compiler does not properly
# handle `-M -o', and we need to detect this.
if depmode=$depmode \
- source=conftest.c object=conftest.o \
- depfile=conftest.Po tmpdepfile=conftest.TPo \
- $SHELL ./depcomp $depcc -c conftest.c -o conftest.o >/dev/null 2>&1 &&
- grep conftest.h conftest.Po > /dev/null 2>&1 &&
+ source=sub/conftest.c object=sub/conftest.${OBJEXT-o} \
+ depfile=sub/conftest.Po tmpdepfile=sub/conftest.TPo \
+ $SHELL ./depcomp $depcc -c -o sub/conftest.${OBJEXT-o} sub/conftest.c \
+ >/dev/null 2>conftest.err &&
+ grep sub/conftst6.h sub/conftest.Po > /dev/null 2>&1 &&
+ grep sub/conftest.${OBJEXT-o} sub/conftest.Po > /dev/null 2>&1 &&
${MAKE-make} -s -f confmf > /dev/null 2>&1; then
- am_cv_CC_dependencies_compiler_type=$depmode
- break
+ # icc doesn't choke on unknown options, it will just issue warnings
+ # or remarks (even with -Werror). So we grep stderr for any message
+ # that says an option was ignored or not supported.
+ # When given -MP, icc 7.0 and 7.1 complain thusly:
+ # icc: Command line warning: ignoring option '-M'; no argument required
+ # The diagnosis changed in icc 8.0:
+ # icc: Command line remark: option '-MP' not supported
+ if (grep 'ignoring option' conftest.err ||
+ grep 'not supported' conftest.err) >/dev/null 2>&1; then :; else
+ am_cv_CC_dependencies_compiler_type=$depmode
+ break
+ fi
fi
done
@@ -2972,6 +3294,127 @@
CCDEPMODE=depmode=$am_cv_CC_dependencies_compiler_type
+if
+ test "x$enable_dependency_tracking" != xno \
+ && test "$am_cv_CC_dependencies_compiler_type" = gcc3; then
+ am__fastdepCC_TRUE=
+ am__fastdepCC_FALSE='#'
+else
+ am__fastdepCC_TRUE='#'
+fi
+depcc="$CC" am_compiler_list=
+echo "$as_me:$LINENO: checking dependency style of $depcc" >&5
+echo $ECHO_N "checking dependency style of $depcc... $ECHO_C" >&6
+if test "${am_cv_CC_dependencies_compiler_type+set}" = set; then
+else
+ if test -z "$AMDEP_TRUE" && test -f "$am_depcomp"; then
+ # We make a subdir and do the tests there. Otherwise we can end up
+ # making bogus files that we don't know about and never remove. For
+ # instance it was reported that on HP-UX the gcc test will end up
+ # making a dummy file named `D' -- because `-MD' means `put the output
+ # in D'.
+ # Copy depcomp to subdir because otherwise we won't find it if we're
+ # using a relative directory.
+ cp "$am_depcomp" conftest.dir
+ cd conftest.dir
+ # directory.
+ mkdir sub
+ am_cv_CC_dependencies_compiler_type=none
+ if test "$am_compiler_list" = ""; then
+ am_compiler_list=`sed -n 's/^#*\([a-zA-Z0-9]*\))$/\1/p' < ./depcomp`
+ fi
+ for depmode in $am_compiler_list; do
+ # We need to recreate these files for each test, as the compiler may
+ # overwrite some of them when testing with obscure command lines.
+ # This happens at least with the AIX C compiler.
+ done
+ case $depmode in
+ nosideeffect)
+ # after this tag, mechanisms are not by side-effect, so they'll
+ # only be used when explicitly requested
+ if test "x$enable_dependency_tracking" = xyes; then
+ continue
+ else
+ break
+ fi
+ none) break ;;
+ esac
+ # We check with `-c' and `-o' for the sake of the "dashmstdout"
+ # mode. It turns out that the SunPro C++ compiler does not properly
+ # handle `-M -o', and we need to detect this.
+ if depmode=$depmode \
+ ${MAKE-make} -s -f confmf > /dev/null 2>&1; then
+ break
+ fi
+ fi
+ done
+ cd ..
+else
+fi
+fi
+echo "$as_me:$LINENO: result: $am_cv_CC_dependencies_compiler_type" >&5
+echo "${ECHO_T}$am_cv_CC_dependencies_compiler_type" >&6
+CCDEPMODE=depmode=$am_cv_CC_dependencies_compiler_type
+if
+else
+fi
ac_ext=cc
ac_cpp='$CXXCPP $CPPFLAGS'
ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
@@ -3351,18 +3794,34 @@
cd conftest.dir
+ # directory.
+ mkdir sub
am_cv_CXX_dependencies_compiler_type=none
fi
+ done
case $depmode in
nosideeffect)
@@ -3380,13 +3839,25 @@
- am_cv_CXX_dependencies_compiler_type=$depmode
- break
+ am_cv_CXX_dependencies_compiler_type=$depmode
+ break
+ fi
fi
done
@@ -3402,72 +3873,199 @@
CXXDEPMODE=depmode=$am_cv_CXX_dependencies_compiler_type
+if
+ && test "$am_cv_CXX_dependencies_compiler_type" = gcc3; then
+ am__fastdepCXX_TRUE=
+ am__fastdepCXX_FALSE='#'
+else
+ am__fastdepCXX_TRUE='#'
+fi
+depcc="$CXX" am_compiler_list=
+if test "${am_cv_CXX_dependencies_compiler_type+set}" = set; then
+else
+ # in D'.
+ cd conftest.dir
+ # directory.
+ mkdir sub
+ am_cv_CXX_dependencies_compiler_type=none
+ fi
+ done
+ case $depmode in
+ nosideeffect)
+ continue
+ else
+ break
+ fi
+ none) break ;;
+ esac
+ break
+ fi
+ fi
+ done
+ cd ..
+else
+fi
+fi
+echo "$as_me:$LINENO: result: $am_cv_CXX_dependencies_compiler_type" >&5
+echo "${ECHO_T}$am_cv_CXX_dependencies_compiler_type" >&6
+CXXDEPMODE=depmode=$am_cv_CXX_dependencies_compiler_type
+if
+else
+fi
# Check whether --enable-shared or --disable-shared was given.
if test "${enable_shared+set}" = set; then
enableval="$enable_shared"
p=${PACKAGE-default}
-case $enableval in
-yes) enable_shared=yes ;;
-no) enable_shared=no ;;
- enable_shared=no
- # Look at the argument we got. We use all the common list separators.
- IFS="${IFS= }"; ac_save_ifs="$IFS"; IFS="${IFS}:,"
- for pkg in $enableval; do
- if test "X$pkg" = "X$p"; then
- enable_shared=yes
- fi
- done
- IFS="$ac_save_ifs"
-esac
+ case $enableval in
+ yes) enable_shared=yes ;;
+ no) enable_shared=no ;;
+ enable_shared=no
+ # Look at the argument we got. We use all the common list separators.
+ lt_save_ifs="$IFS"; IFS="${IFS}$PATH_SEPARATOR,"
+ for pkg in $enableval; do
+ if test "X$pkg" = "X$p"; then
+ enable_shared=yes
+ fi
+ done
+ esac
else
enable_shared=yes
fi;
# Check whether --enable-static or --disable-static was given.
if test "${enable_static+set}" = set; then
enableval="$enable_static"
-case $enableval in
-yes) enable_static=yes ;;
-no) enable_static=no ;;
- enable_static=no
- enable_static=yes
- fi
- done
-esac
+ yes) enable_static=yes ;;
+ no) enable_static=no ;;
+ enable_static=no
+ enable_static=yes
+ fi
+ done
+ esac
else
enable_static=yes
fi;
# Check whether --enable-fast-install or --disable-fast-install was given.
if test "${enable_fast_install+set}" = set; then
enableval="$enable_fast_install"
-case $enableval in
-yes) enable_fast_install=yes ;;
-no) enable_fast_install=no ;;
- enable_fast_install=no
- enable_fast_install=yes
- fi
- done
-esac
+ yes) enable_fast_install=yes ;;
+ no) enable_fast_install=no ;;
+ enable_fast_install=no
+ enable_fast_install=yes
+ fi
+ done
+ esac
else
fi;
# Make sure we can run config.sub.
$ac_config_sub sun4 >/dev/null 2>&1 ||
{ { echo "$as_me:$LINENO: error: cannot run $ac_config_sub" >&5
@@ -3522,18 +4120,79 @@
host_os=`echo $ac_cv_host | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\3/'`
- case X$UNAME in
- esac
+echo "$as_me:$LINENO: checking for a sed that does not truncate output" >&5
+echo $ECHO_N "checking for a sed that does not truncate output... $ECHO_C" >&6
+if test "${lt_cv_path_SED+set}" = set; then
+else
+ # Loop through the user's path and test for sed and gsed.
+# Then use that list of sed's as ones to test for truncation.
+do
+ IFS=$as_save_IFS
+ for lt_ac_prog in sed gsed; do
+ if $as_executable_p "$as_dir/$lt_ac_prog$ac_exec_ext"; then
+ lt_ac_sed_list="$lt_ac_sed_list $as_dir/$lt_ac_prog$ac_exec_ext"
+ fi
+ done
+ done
+done
+lt_ac_max=0
+lt_ac_count=0
+# Add /usr/xpg4/bin/sed as it is typically found on Solaris
+# along with /bin/sed that truncates output.
+for lt_ac_sed in $lt_ac_sed_list /usr/xpg4/bin/sed; do
+ test ! -f $lt_ac_sed && break
+ cat /dev/null > conftest.in
+ lt_ac_count=0
+ echo $ECHO_N "0123456789$ECHO_C" >conftest.in
+ # Check for GNU sed and select it if it is found.
+ if "$lt_ac_sed" --version 2>&1 < /dev/null | grep 'GNU' > /dev/null; then
+ lt_cv_path_SED=$lt_ac_sed
+ break
+ fi
+ while true; do
+ cat conftest.in conftest.in >conftest.tmp
+ mv conftest.tmp conftest.in
+ cp conftest.in conftest.nl
+ echo >>conftest.nl
+ $lt_ac_sed -e 's/a$//' < conftest.nl >conftest.out || break
+ cmp -s conftest.out conftest.nl || break
+ # 10000 chars as input seems more than enough
+ test $lt_ac_count -gt 10 && break
+ lt_ac_count=`expr $lt_ac_count + 1`
+ if test $lt_ac_count -gt $lt_ac_max; then
+ lt_ac_max=$lt_ac_count
+ fi
+ done
+done
+SED=$lt_cv_path_SED
fi
+echo "$as_me:$LINENO: result: $SED" >&5
+echo "${ECHO_T}$SED" >&6
+echo "$as_me:$LINENO: checking for egrep" >&5
+echo $ECHO_N "checking for egrep... $ECHO_C" >&6
+if test "${ac_cv_prog_egrep+set}" = set; then
+else
+ if echo a | (grep -E '(a|b)') >/dev/null 2>&1
+ then ac_cv_prog_egrep='grep -E'
+ else ac_cv_prog_egrep='egrep'
+ fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_prog_egrep" >&5
+echo "${ECHO_T}$ac_cv_prog_egrep" >&6
+ EGREP=$ac_cv_prog_egrep
# Check whether --with-gnu-ld or --without-gnu-ld was given.
if test "${with_gnu_ld+set}" = set; then
withval="$with_gnu_ld"
@@ -3544,8 +4203,8 @@
ac_prog=ld
if test "$GCC" = yes; then
# Check if gcc -print-prog-name=ld gives a path.
- echo "$as_me:$LINENO: checking for ld used by GCC" >&5
-echo $ECHO_N "checking for ld used by GCC... $ECHO_C" >&6
+ echo "$as_me:$LINENO: checking for ld used by $CC" >&5
+echo $ECHO_N "checking for ld used by $CC... $ECHO_C" >&6
case $host in
*-*-mingw*)
# gcc leaves a trailing carriage return which upsets mingw
@@ -3555,12 +4214,12 @@
esac
case $ac_prog in
# Accept absolute paths.
- [\\/]* | [A-Za-z]:[\\/]*)
re_direlt='/[^/][^/]*/\.\./'
- # Canonicalize the path of ld
- ac_prog=`echo $ac_prog| sed 's%\\\\%/%g'`
+ # Canonicalize the pathname of ld
+ ac_prog=`echo $ac_prog| $SED 's%\\\\%/%g'`
while echo $ac_prog | grep "$re_direlt" > /dev/null 2>&1; do
- ac_prog=`echo $ac_prog| sed "s%$re_direlt%/%"`
+ ac_prog=`echo $ac_prog| $SED "s%$re_direlt%/%"`
done
test -z "$LD" && LD="$ac_prog"
@@ -3584,22 +4243,26 @@
else
if test -z "$LD"; then
- IFS="${IFS= }"; ac_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
for ac_dir in $PATH; do
test -z "$ac_dir" && ac_dir=.
if test -f "$ac_dir/$ac_prog" || test -f "$ac_dir/$ac_prog$ac_exeext"; then
lt_cv_path_LD="$ac_dir/$ac_prog"
# Check to see if the program is GNU ld. I'd rather use --version,
# but apparently some GNU ld's only accept -v.
# Break only if it was the GNU/non-GNU ld that we prefer.
- if "$lt_cv_path_LD" -v 2>&1 < /dev/null | egrep '(GNU|with BFD)' > /dev/null; then
+ case `"$lt_cv_path_LD" -v 2>&1 </dev/null` in
+ *GNU* | *'with BFD'*)
test "$with_gnu_ld" != no && break
- else
test "$with_gnu_ld" != yes && break
- fi
+ esac
fi
done
else
lt_cv_path_LD="$LD" # Let the user override the test with a path.
fi
@@ -3622,12 +4285,15 @@
else
# I'd rather use --version here, but apparently some GNU ld's only accept -v.
-if $LD -v 2>&1 </dev/null | egrep '(GNU|with BFD)' 1>&5; then
+case `$LD -v 2>&1 </dev/null` in
+*GNU* | *'with BFD'*)
lt_cv_prog_gnu_ld=yes
-else
lt_cv_prog_gnu_ld=no
+esac
fi
-fi
echo "$as_me:$LINENO: result: $lt_cv_prog_gnu_ld" >&5
echo "${ECHO_T}$lt_cv_prog_gnu_ld" >&6
with_gnu_ld=$lt_cv_prog_gnu_ld
@@ -3643,7 +4309,11 @@
echo "$as_me:$LINENO: result: $lt_cv_ld_reload_flag" >&5
echo "${ECHO_T}$lt_cv_ld_reload_flag" >&6
reload_flag=$lt_cv_ld_reload_flag
-test -n "$reload_flag" && reload_flag=" $reload_flag"
+case $reload_flag in
+*) reload_flag=" $reload_flag" ;;
+esac
+reload_cmds='$LD$reload_flag -o $output$reload_objs'
echo "$as_me:$LINENO: checking for BSD-compatible nm" >&5
echo $ECHO_N "checking for BSD-compatible nm... $ECHO_C" >&6
@@ -3654,121 +4324,43 @@
lt_cv_path_NM="$NM"
else
for ac_dir in $PATH /usr/ccs/bin /usr/ucb /bin; do
- tmp_nm=$ac_dir/${ac_tool_prefix}nm
- if test -f $tmp_nm || test -f $tmp_nm$ac_exeext ; then
+ tmp_nm="$ac_dir/${ac_tool_prefix}nm"
+ if test -f "$tmp_nm" || test -f "$tmp_nm$ac_exeext" ; then
# Check to see if the nm accepts a BSD-compat flag.
# Adding the `sed 1q' prevents false positives on HP-UX, which says:
# nm: unknown option "B" ignored
# Tru64's nm complains that /dev/null is an invalid object file
- if ($tmp_nm -B /dev/null 2>&1 | sed '1q'; exit 0) | egrep '(/dev/null|Invalid file or object type)' >/dev/null; then
+ case `"$tmp_nm" -B /dev/null 2>&1 | sed '1q'` in
+ */dev/null* | *'Invalid file or object type'*)
lt_cv_path_NM="$tmp_nm -B"
break
- elif ($tmp_nm -p /dev/null 2>&1 | sed '1q'; exit 0) | egrep /dev/null >/dev/null; then
- lt_cv_path_NM="$tmp_nm -p"
- break
- else
- lt_cv_path_NM=${lt_cv_path_NM="$tmp_nm"} # keep the first match, but
- continue # so that we can try to find one that supports BSD flags
- fi
+ case `"$tmp_nm" -p /dev/null 2>&1 | sed '1q'` in
+ */dev/null*)
+ lt_cv_path_NM="$tmp_nm -p"
+ break
+ lt_cv_path_NM=${lt_cv_path_NM="$tmp_nm"} # keep the first match, but
+ continue # so that we can try to find one that supports BSD flags
+ esac
+ esac
fi
done
test -z "$lt_cv_path_NM" && lt_cv_path_NM=nm
fi
fi
+echo "$as_me:$LINENO: result: $lt_cv_path_NM" >&5
+echo "${ECHO_T}$lt_cv_path_NM" >&6
NM="$lt_cv_path_NM"
-echo "$as_me:$LINENO: result: $NM" >&5
-echo "${ECHO_T}$NM" >&6
-echo "$as_me:$LINENO: checking for a sed that does not truncate output" >&5
-echo $ECHO_N "checking for a sed that does not truncate output... $ECHO_C" >&6
-if test "${lt_cv_path_SED+set}" = set; then
- echo $ECHO_N "(cached) $ECHO_C" >&6
-else
- # Loop through the user's path and test for sed and gsed.
-# Then use that list of sed's as ones to test for truncation.
-as_executable_p="test -f"
-as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-for as_dir in $PATH
-do
- IFS=$as_save_IFS
- test -z "$as_dir" && as_dir=.
- for ac_prog in sed gsed; do
- for ac_exec_ext in '' $ac_executable_extensions; do
- if $as_executable_p "$as_dir/$ac_prog$ac_exec_ext"; then
- _sed_list="$_sed_list $as_dir/$ac_prog$ac_exec_ext"
- fi
- done
- done
-done
- # Create a temporary directory, and hook for its removal unless debugging.
-$debug ||
- trap 'exit_status=$?; rm -rf $tmp && exit $exit_status' 0
- trap '{ (exit 1); exit 1; }' 1 2 13 15
-# Create a (secure) tmp directory for tmp files.
-: ${TMPDIR=/tmp}
- tmp=`(umask 077 && mktemp -d -q "$TMPDIR/sedXXXXXX") 2>/dev/null` &&
- test -n "$tmp" && test -d "$tmp"
- tmp=$TMPDIR/sed$$-$RANDOM
- (umask 077 && mkdir $tmp)
- echo "$me: cannot create a temporary directory in $TMPDIR" >&2
- { (exit 1); exit 1; }
- _max=0
- _count=0
- # Add /usr/xpg4/bin/sed as it is typically found on Solaris
- # along with /bin/sed that truncates output.
- for _sed in $_sed_list /usr/xpg4/bin/sed; do
- test ! -f ${_sed} && break
- cat /dev/null > "$tmp/sed.in"
- _count=0
- echo ${ECHO_N-$ac_n} "0123456789${ECHO_C-$ac_c}" >"$tmp/sed.in"
- # Check for GNU sed and select it if it is found.
- if "${_sed}" --version 2>&1 < /dev/null | egrep '(GNU)' > /dev/null; then
- lt_cv_path_SED=${_sed}
- break
- fi
- while true; do
- cat "$tmp/sed.in" "$tmp/sed.in" >"$tmp/sed.tmp"
- mv "$tmp/sed.tmp" "$tmp/sed.in"
- cp "$tmp/sed.in" "$tmp/sed.nl"
- echo >>"$tmp/sed.nl"
- ${_sed} -e 's/a$//' < "$tmp/sed.nl" >"$tmp/sed.out" || break
- cmp -s "$tmp/sed.out" "$tmp/sed.nl" || break
- # 40000 chars as input seems more than enough
- test $_count -gt 10 && break
- _count=`expr $_count + 1`
- if test $_count -gt $_max; then
- _max=$_count
- lt_cv_path_SED=$_sed
- fi
- done
- done
- rm -rf "$tmp"
-fi
-if test "X$SED" != "X"; then
- lt_cv_path_SED=$SED
-else
- SED=$lt_cv_path_SED
-fi
-echo "$as_me:$LINENO: result: $SED" >&5
-echo "${ECHO_T}$SED" >&6
echo "$as_me:$LINENO: checking whether ln -s works" >&5
echo $ECHO_N "checking whether ln -s works... $ECHO_C" >&6
LN_S=$as_ln_s
@@ -3795,7 +4387,7 @@
# 'pass_all' -- all dependencies passed with no checks.
# 'test_compile' -- check by making test program.
# 'file_magic [[regex]]' -- check by looking for files in library path
-# which responds to the $file_magic_cmd with a given egrep regex.
+# which responds to the $file_magic_cmd with a given extended regex.
# If you have `file' or equivalent on your system and you're not sure
# whether `pass_all' will *always* work, you probably want this one.
@@ -3814,25 +4406,24 @@
lt_cv_file_magic_test_file=/shlib/libc.so
-cygwin* | mingw* | pw32*)
+cygwin*)
+ # func_win32_libid is a shell function defined in ltmain.sh
+ lt_cv_deplibs_check_method='file_magic ^x86 archive import|^x86 DLL'
+ lt_cv_file_magic_cmd='func_win32_libid'
+mingw* | pw32*)
+ # Base MSYS/MinGW do not provide the 'file' command needed by
+ # func_win32_libid shell function, so use a weaker test based on 'objdump'.
lt_cv_deplibs_check_method='file_magic file format pei*-i386(.*architecture: i386)?'
lt_cv_file_magic_cmd='$OBJDUMP -f'
darwin* | rhapsody*)
- lt_cv_deplibs_check_method='file_magic Mach-O dynamically linked shared library'
- lt_cv_file_magic_cmd='/usr/bin/file -L'
- case "$host_os" in
- rhapsody* | darwin1.[012])
- lt_cv_file_magic_test_file=`echo /System/Library/Frameworks/System.framework/Versions/*/System | head -1`
- *) # Darwin 1.3 on
- lt_cv_file_magic_test_file='/usr/lib/libSystem.dylib'
- esac
+ lt_cv_deplibs_check_method=pass_all
-freebsd*)
+freebsd* | kfreebsd*-gnu)
if echo __ELF__ | $CC -E - | grep __ELF__ > /dev/null; then
case $host_cpu in
i*86 )
@@ -3852,50 +4443,53 @@
-hpux10.20*|hpux11*)
- lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|PA-RISC[0-9].[0-9]) shared library'
+hpux10.20* | hpux11*)
lt_cv_file_magic_cmd=/usr/bin/file
- lt_cv_file_magic_test_file=/usr/lib/libc.sl
-irix5* | irix6* | nonstopux*)
- case $host_os in
- irix5* | nonstopux*)
- # this will be overridden with pass_all, but let us keep it just in case
- lt_cv_deplibs_check_method="file_magic ELF 32-bit MSB dynamic lib MIPS - version 1"
+ case "$host_cpu" in
+ ia64*)
+ lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|ELF-[0-9][0-9]) shared object file - IA64'
+ lt_cv_file_magic_test_file=/usr/lib/hpux32/libc.so
+ hppa*64*)
+ lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|ELF-[0-9][0-9]) shared object file - PA-RISC [0-9].[0-9]'
+ lt_cv_file_magic_test_file=/usr/lib/pa20_64/libc.sl
- case $LD in
- *-32|*"-32 ") libmagic=32-bit;;
- *-n32|*"-n32 ") libmagic=N32;;
- *-64|*"-64 ") libmagic=64-bit;;
- *) libmagic=never-match;;
- esac
- lt_cv_deplibs_check_method="file_magic ELF ${libmagic} MSB mips-[1234] dynamic lib MIPS - version 1"
+ lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|PA-RISC[0-9].[0-9]) shared library'
+ lt_cv_file_magic_test_file=/usr/lib/libc.sl
esac
- lt_cv_file_magic_test_file=`echo /lib${libsuff}/libc.so*`
+irix5* | irix6* | nonstopux*)
+ case $LD in
+ *-32|*"-32 ") libmagic=32-bit;;
+ *-n32|*"-n32 ") libmagic=N32;;
+ *-64|*"-64 ") libmagic=64-bit;;
+ *) libmagic=never-match;;
+ esac
# This must be Linux ELF.
-linux-gnu*)
+linux*)
case $host_cpu in
- alpha* | hppa* | i*86 | mips | mipsel | powerpc* | sparc* | ia64* | s390* | x86_64*)
+ alpha*|hppa*|i*86|ia64*|m68*|mips*|powerpc*|sparc*|s390*|sh*|x86_64*)
lt_cv_deplibs_check_method=pass_all ;;
# glibc up to 2.1.1 does not perform some relocations on ARM
+ # this will be overridden with pass_all, but let us keep it just in case
lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [LM]SB (shared object|dynamic lib )' ;;
esac
lt_cv_file_magic_test_file=`echo /lib/libc.so* /lib/libc-*.so`
netbsd*)
- lt_cv_deplibs_check_method='match_pattern /lib[^/\.]+\.so\.[0-9]+\.[0-9]+$'
+ lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so\.[0-9]+\.[0-9]+|_pic\.a)$'
else
- lt_cv_deplibs_check_method='match_pattern /lib[^/\.]+\.so$'
+ lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so|_pic\.a)$'
fi
@@ -3905,6 +4499,10 @@
lt_cv_file_magic_test_file=/usr/lib/libnls.so
+nto-qnx*)
+ lt_cv_deplibs_check_method=unknown
openbsd*)
lt_cv_file_magic_test_file=`echo /usr/lib/libc.so.*`
@@ -3916,9 +4514,6 @@
osf3* | osf4* | osf5*)
- lt_cv_deplibs_check_method='file_magic COFF format alpha shared library'
- lt_cv_file_magic_test_file=/shlib/libc.so
@@ -3928,13 +4523,8 @@
solaris*)
- lt_cv_file_magic_test_file=/lib/libc.so
-sysv5uw[78]* | sysv4*uw2*)
- lt_cv_deplibs_check_method=pass_all
sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
case $host_vendor in
motorola)
@@ -3958,6 +4548,10 @@
esac
+sysv5OpenUNIX8* | sysv5UnixWare7* | sysv5uw[78]* | unixware7* | sysv4*uw2*)
esac
fi
@@ -3965,229 +4559,231 @@
echo "${ECHO_T}$lt_cv_deplibs_check_method" >&6
file_magic_cmd=$lt_cv_file_magic_cmd
deplibs_check_method=$lt_cv_deplibs_check_method
+test -z "$deplibs_check_method" && deplibs_check_method=unknown
+# If no C compiler was specified, use CC.
+LTCC=${LTCC-"$CC"}
+# Allow CC to be a program name with arguments.
+compiler=$CC
+# Check whether --enable-libtool-lock or --disable-libtool-lock was given.
+if test "${enable_libtool_lock+set}" = set; then
+ enableval="$enable_libtool_lock"
-# Check for command to grab the raw symbol name followed by C symbol from nm.
-echo "$as_me:$LINENO: checking command to parse $NM output" >&5
-echo $ECHO_N "checking command to parse $NM output... $ECHO_C" >&6
-if test "${lt_cv_sys_global_symbol_pipe+set}" = set; then
-else
+fi;
+test "x$enable_libtool_lock" != xno && enable_libtool_lock=yes
-# These are sane defaults that work on at least a few old systems.
-# [They come from Ultrix. What could be older than Ultrix?!! ;)]
-# Character class describing NM global symbol codes.
-symcode='[BCDEGRST]'
-# Regexp to match symbols that can be accessed directly from C.
-sympat='\([_A-Za-z][_A-Za-z0-9]*\)'
-# Transform the above into a raw symbol and a C symbol.
-symxfrm='\1 \2\3 \3'
-# Transform an extracted symbol line into a proper C declaration
-lt_cv_global_symbol_to_cdecl="sed -n -e 's/^. .* \(.*\)$/extern char \1;/p'"
-# Transform an extracted symbol line into symbol name and symbol address
-lt_cv_global_symbol_to_c_name_address="sed -n -e 's/^: \([^ ]*\) $/ {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode \([^ ]*\) \([^ ]*\)$/ {\"\2\", (lt_ptr) \&\2},/p'"
-# Define system-specific variables.
-case $host_os in
-aix*)
- symcode='[BCDT]'
+# Some flags need to be propagated to the compiler or linker for good
+# libtool support.
+case $host in
+ia64-*-hpux*)
+ # Find out which ABI we are using.
+ echo 'int i;' > conftest.$ac_ext
+ if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+ (eval $ac_compile) 2>&5
+ ac_status=$?
+ (exit $ac_status); }; then
+ case `/usr/bin/file conftest.$ac_objext` in
+ *ELF-32*)
+ HPUX_IA64_MODE="32"
+ *ELF-64*)
+ HPUX_IA64_MODE="64"
+ esac
+ fi
+ rm -rf conftest*
- symcode='[ABCDGISTW]'
+*-*-irix6*)
+ echo '#line 4605 "configure"' > conftest.$ac_ext
+ ac_status=$?
+ if test "$lt_cv_prog_gnu_ld" = yes; then
+ *32-bit*)
+ LD="${LD-ld} -melf32bsmip"
+ *N32*)
+ LD="${LD-ld} -melf32bmipn32"
+ *64-bit*)
+ LD="${LD-ld} -melf64bmip"
+ esac
+ else
+ *32-bit*)
+ LD="${LD-ld} -32"
+ *N32*)
+ LD="${LD-ld} -n32"
+ *64-bit*)
+ LD="${LD-ld} -64"
+ esac
+ fi
+ fi
+ rm -rf conftest*
-hpux*) # Its linker distinguishes data from code symbols
- lt_cv_global_symbol_to_cdecl="sed -n -e 's/^T .* \(.*\)$/extern char \1();/p' -e 's/^$symcode* .* \(.*\)$/extern char \1;/p'"
- lt_cv_global_symbol_to_c_name_address="sed -n -e 's/^: \([^ ]*\) $/ {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode* \([^ ]*\) \([^ ]*\)$/ {\"\2\", (lt_ptr) \&\2},/p'"
-irix* | nonstopux*)
- symcode='[BCDEGRST]'
-osf*)
- symcode='[BCDEGQRST]'
-solaris* | sysv5*)
- symcode='[BDT]'
-sysv4)
- symcode='[DFNSTU]'
-esac
-# Handle CRLF in mingw tool chain
-opt_cr=
-case $host_os in
-mingw*)
- opt_cr=`echo 'x\{0,1\}' | tr x '\015'` # option cr in regexp
-esac
-# If we're using GNU nm, then use its standard symbol codes.
-if $NM -V 2>&1 | egrep '(GNU|with BFD)' > /dev/null; then
-fi
-# Try without a prefix undercore, then with it.
-for ac_symprfx in "" "_"; do
- # Write the raw and C identifiers.
-lt_cv_sys_global_symbol_pipe="sed -n -e 's/^.*[ ]\($symcode$symcode*\)[ ][ ]*\($ac_symprfx\)$sympat$opt_cr$/$symxfrm/p'"
- # Check to see that the pipe works correctly.
- pipe_works=no
- rm -f conftest*
- cat > conftest.$ac_ext <<EOF
-#ifdef __cplusplus
-extern "C" {
-#endif
-char nm_test_var;
-void nm_test_func(){}
-#ifdef __cplusplus
-#endif
-int main(){nm_test_var='a';nm_test_func();return(0);}
-EOF
+x86_64-*linux*|ppc*-*linux*|powerpc*-*linux*|s390*-*linux*|sparc*-*linux*)
ac_status=$?
- # Now try to grab the symbols.
- nlist=conftest.nm
- if { (eval echo "$as_me:$LINENO: \"$NM conftest.$ac_objext \| $lt_cv_sys_global_symbol_pipe \> $nlist\"") >&5
- (eval $NM conftest.$ac_objext \| $lt_cv_sys_global_symbol_pipe \> $nlist) 2>&5
- ac_status=$?
- echo "$as_me:$LINENO: \$? = $ac_status" >&5
- (exit $ac_status); } && test -s "$nlist"; then
- # Try sorting and uniquifying the output.
- if sort "$nlist" | uniq > "$nlist"T; then
- mv -f "$nlist"T "$nlist"
- else
- rm -f "$nlist"T
- fi
+ case "`/usr/bin/file conftest.o`" in
+ *32-bit*)
+ case $host in
+ x86_64-*linux*)
+ LD="${LD-ld} -m elf_i386"
+ ppc64-*linux*|powerpc64-*linux*)
+ LD="${LD-ld} -m elf32ppclinux"
+ s390x-*linux*)
+ LD="${LD-ld} -m elf_s390"
+ sparc64-*linux*)
+ LD="${LD-ld} -m elf32_sparc"
+ esac
+ *64-bit*)
+ case $host in
+ x86_64-*linux*)
+ LD="${LD-ld} -m elf_x86_64"
+ ppc*-*linux*|powerpc*-*linux*)
+ LD="${LD-ld} -m elf64ppc"
+ s390*-*linux*)
+ LD="${LD-ld} -m elf64_s390"
+ sparc*-*linux*)
+ LD="${LD-ld} -m elf64_sparc"
+ esac
+ esac
+ fi
+ rm -rf conftest*
- # Make sure that we snagged all the symbols we need.
- if egrep ' nm_test_var$' "$nlist" >/dev/null; then
- if egrep ' nm_test_func$' "$nlist" >/dev/null; then
- cat <<EOF > conftest.$ac_ext
-#ifdef __cplusplus
-extern "C" {
-#endif
+*-*-sco3.2v5*)
+ # On SCO OpenServer 5, we need -belf to get full-featured binaries.
+ SAVE_CFLAGS="$CFLAGS"
+ CFLAGS="$CFLAGS -belf"
+ echo "$as_me:$LINENO: checking whether the C compiler needs -belf" >&5
+echo $ECHO_N "checking whether the C compiler needs -belf... $ECHO_C" >&6
+if test "${lt_cv_cc_needs_belf+set}" = set; then
+else
+ ac_ext=c
+ac_cpp='$CPP $CPPFLAGS'
+ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_c_compiler_gnu
-EOF
- # Now generate the symbol file.
- eval "$lt_cv_global_symbol_to_cdecl"' < "$nlist" >> conftest.$ac_ext'
+ cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h. */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h. */
- cat <<EOF >> conftest.$ac_ext
-#if defined (__STDC__) && __STDC__
-# define lt_ptr void *
-#else
-# define lt_ptr char *
-# define const
-#endif
-/* The mapping between symbol names and symbols. */
-const struct {
- const char *name;
- lt_ptr address;
-lt_preloaded_symbols[] =
+int
+main ()
-EOF
- sed "s/^$symcode$symcode* \(.*\) \(.*\)$/ {\"\2\", (lt_ptr) \&\2},/" < "$nlist" >> conftest.$ac_ext
- cat <<\EOF >> conftest.$ac_ext
- {0, (lt_ptr) 0}
-#ifdef __cplusplus
+ return 0;
-#endif
-EOF
- # Now try linking the two files.
- mv conftest.$ac_objext conftstm.$ac_objext
- save_LIBS="$LIBS"
- save_CFLAGS="$CFLAGS"
- LIBS="conftstm.$ac_objext"
- CFLAGS="$CFLAGS$no_builtin_flag"
- if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
- (eval $ac_link) 2>&5
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+ (eval $ac_link) 2>conftest.er1
ac_status=$?
+ grep -v '^ *+' conftest.er1 >conftest.err
+ rm -f conftest.er1
+ cat conftest.err >&5
- (exit $ac_status); } && test -s conftest$ac_exeext; then
- pipe_works=yes
- fi
- LIBS="$save_LIBS"
- CFLAGS="$save_CFLAGS"
- else
- echo "cannot find nm_test_func in $nlist" >&5
- fi
- else
- echo "cannot find nm_test_var in $nlist" >&5
- fi
- else
- echo "cannot run $lt_cv_sys_global_symbol_pipe" >&5
- fi
- else
- echo "$progname: failed program was:" >&5
- cat conftest.$ac_ext >&5
- fi
- rm -f conftest* conftst*
+ { ac_try='test -z "$ac_c_werror_flag"
+ || test ! -s conftest.err'
+ { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+ (eval $ac_try) 2>&5
+ ac_status=$?
+ (exit $ac_status); }; } &&
+ { ac_try='test -s conftest$ac_exeext'
+ ac_status=$?
+ (exit $ac_status); }; }; then
+ lt_cv_cc_needs_belf=yes
+else
+ echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
- # Do not use the global_symbol_pipe unless it works.
- if test "$pipe_works" = yes; then
- break
- else
- lt_cv_sys_global_symbol_pipe=
- fi
-done
+lt_cv_cc_needs_belf=no
fi
+rm -f conftest.err conftest.$ac_objext \
+ conftest$ac_exeext conftest.$ac_ext
+ ac_ext=c
-global_symbol_pipe="$lt_cv_sys_global_symbol_pipe"
-if test -z "$lt_cv_sys_global_symbol_pipe"; then
- global_symbol_to_cdecl=
- global_symbol_to_c_name_address=
-else
- global_symbol_to_cdecl="$lt_cv_global_symbol_to_cdecl"
- global_symbol_to_c_name_address="$lt_cv_global_symbol_to_c_name_address"
fi
-if test -z "$global_symbol_pipe$global_symbol_to_cdec$global_symbol_to_c_name_address";
-then
- echo "$as_me:$LINENO: result: failed" >&5
-echo "${ECHO_T}failed" >&6
-else
- echo "$as_me:$LINENO: result: ok" >&5
-echo "${ECHO_T}ok" >&6
-fi
+echo "$as_me:$LINENO: result: $lt_cv_cc_needs_belf" >&5
+echo "${ECHO_T}$lt_cv_cc_needs_belf" >&6
+ if test x"$lt_cv_cc_needs_belf" != x"yes"; then
+ # this is probably gcc 2.8.0, egcs 1.0 or newer; no need for -belf
+ CFLAGS="$SAVE_CFLAGS"
+ fi
+esac
-ac_ext=cc
-ac_cpp='$CXXCPP $CPPFLAGS'
-ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
-echo "$as_me:$LINENO: checking how to run the C++ preprocessor" >&5
-echo $ECHO_N "checking how to run the C++ preprocessor... $ECHO_C" >&6
-if test -z "$CXXCPP"; then
- if test "${ac_cv_prog_CXXCPP+set}" = set; then
+need_locks="$enable_libtool_lock"
+ac_ext=c
+echo "$as_me:$LINENO: checking how to run the C preprocessor" >&5
+echo $ECHO_N "checking how to run the C preprocessor... $ECHO_C" >&6
+# On Suns, sometimes $CPP names a directory.
+if test -n "$CPP" && test -d "$CPP"; then
+ CPP=
+fi
+if test -z "$CPP"; then
+ if test "${ac_cv_prog_CPP+set}" = set; then
else
- # Double quotes because CXXCPP needs to be expanded
- for CXXCPP in "$CXX -E" "/lib/cpp"
+ # Double quotes because CPP needs to be expanded
+ for CPP in "$CC -E" "$CC -E -traditional-cpp" "/lib/cpp"
do
ac_preproc_ok=false
-for ac_cxx_preproc_warn_flag in '' yes
+for ac_c_preproc_warn_flag in '' yes
do
# Use a header file that comes with gcc, so configuring glibc
# with a fresh cross-compiler works.
@@ -4217,8 +4813,8 @@
(exit $ac_status); } >/dev/null; then
if test -s conftest.err; then
- ac_cpp_err=$ac_cxx_preproc_warn_flag
- ac_cpp_err=$ac_cpp_err$ac_cxx_werror_flag
+ ac_cpp_err=$ac_c_preproc_warn_flag
+ ac_cpp_err=$ac_cpp_err$ac_c_werror_flag
else
ac_cpp_err=
fi
@@ -4255,8 +4851,8 @@
else
ac_cpp_err=
fi
@@ -4284,17 +4880,17 @@
fi
done
- ac_cv_prog_CXXCPP=$CXXCPP
+ ac_cv_prog_CPP=$CPP
fi
- CXXCPP=$ac_cv_prog_CXXCPP
+ CPP=$ac_cv_prog_CPP
else
fi
-echo "$as_me:$LINENO: result: $CXXCPP" >&5
-echo "${ECHO_T}$CXXCPP" >&6
+echo "$as_me:$LINENO: result: $CPP" >&5
+echo "${ECHO_T}$CPP" >&6
ac_preproc_ok=false
do
@@ -4324,8 +4920,8 @@
else
ac_cpp_err=
fi
@@ -4362,8 +4958,8 @@
else
ac_cpp_err=
fi
@@ -4389,35 +4985,20 @@
if $ac_preproc_ok; then
else
- { { echo "$as_me:$LINENO: error: C++ preprocessor \"$CXXCPP\" fails sanity check
+ { { echo "$as_me:$LINENO: error: C preprocessor \"$CPP\" fails sanity check
See \`config.log' for more details." >&5
-echo "$as_me: error: C++ preprocessor \"$CXXCPP\" fails sanity check
+echo "$as_me: error: C preprocessor \"$CPP\" fails sanity check
See \`config.log' for more details." >&2;}
fi
-ac_ext=cc
+ac_ext=c
-echo "$as_me:$LINENO: checking for egrep" >&5
-echo $ECHO_N "checking for egrep... $ECHO_C" >&6
-if test "${ac_cv_prog_egrep+set}" = set; then
-else
- if echo a | (grep -E '(a|b)') >/dev/null 2>&1
- then ac_cv_prog_egrep='grep -E'
- else ac_cv_prog_egrep='egrep'
- fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_prog_egrep" >&5
-echo "${ECHO_T}$ac_cv_prog_egrep" >&6
- EGREP=$ac_cv_prog_egrep
echo "$as_me:$LINENO: checking for ANSI C header files" >&5
echo $ECHO_N "checking for ANSI C header files... $ECHO_C" >&6
if test "${ac_cv_header_stdc+set}" = set; then
@@ -4451,7 +5032,7 @@
- { ac_try='test -z "$ac_cxx_werror_flag"
(eval $ac_try) 2>&5
@@ -4622,7 +5203,7 @@
(eval $ac_try) 2>&5
@@ -4690,7 +5271,7 @@
(eval $ac_try) 2>&5
@@ -4734,8 +5315,8 @@
else
ac_cpp_err=
fi
@@ -4755,7 +5336,7 @@
echo "${ECHO_T}$ac_header_preproc" >&6
# So? What about this header?
-case $ac_header_compiler:$ac_header_preproc:$ac_cxx_preproc_warn_flag in
+case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in
yes:no: )
{ echo "$as_me:$LINENO: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&5
echo "$as_me: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&2;}
@@ -4806,149 +5387,893 @@
done
+ac_ext=cc
+ac_cpp='$CXXCPP $CPPFLAGS'
+ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
+echo "$as_me:$LINENO: checking how to run the C++ preprocessor" >&5
+echo $ECHO_N "checking how to run the C++ preprocessor... $ECHO_C" >&6
+if test -z "$CXXCPP"; then
+ if test "${ac_cv_prog_CXXCPP+set}" = set; then
+else
+ # Double quotes because CXXCPP needs to be expanded
+ for CXXCPP in "$CXX -E" "/lib/cpp"
+ do
+ ac_preproc_ok=false
+for ac_cxx_preproc_warn_flag in '' yes
+do
+ # Use a header file that comes with gcc, so configuring glibc
+ # with a fresh cross-compiler works.
+ # Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
+ # <limits.h> exists even on freestanding compilers.
+ # On the NeXT, cc -E runs the code through the compiler's parser,
+ # not just through cpp. "Syntax error" is here to catch this case.
+/* confdefs.h. */
+_ACEOF
+#ifdef __STDC__
+# include <limits.h>
+#else
+# include <assert.h>
+#endif
+ Syntax error
+_ACEOF
+if { (eval echo "$as_me:$LINENO: \"$ac_cpp conftest.$ac_ext\"") >&5
+ (eval $ac_cpp conftest.$ac_ext) 2>conftest.er1
+ ac_status=$?
+ (exit $ac_status); } >/dev/null; then
+ if test -s conftest.err; then
+ ac_cpp_err=$ac_cxx_preproc_warn_flag
+ ac_cpp_err=$ac_cpp_err$ac_cxx_werror_flag
+ else
+ ac_cpp_err=
+ fi
+else
+ ac_cpp_err=yes
+fi
+if test -z "$ac_cpp_err"; then
+else
+ # Broken: fails on valid input.
+continue
+fi
+rm -f conftest.err conftest.$ac_ext
+ # OK, works on sane cases. Now check whether non-existent headers
+ # can be detected and how.
+/* confdefs.h. */
+_ACEOF
+#include <ac_nonexistent.h>
+_ACEOF
+ ac_status=$?
+ else
+ ac_cpp_err=
+ fi
+else
+ ac_cpp_err=yes
+fi
+ # Broken: success on invalid input.
+continue
+else
+ # Passes both tests.
+ac_preproc_ok=:
+break
+fi
+done
+# Because of `break', _AC_PREPROC_IFELSE's cleaning code was skipped.
+if $ac_preproc_ok; then
+ break
+fi
-# Only perform the check for file, if the check method requires it
-case $deplibs_check_method in
-file_magic*)
- if test "$file_magic_cmd" = '$MAGIC_CMD'; then
- echo "$as_me:$LINENO: checking for ${ac_tool_prefix}file" >&5
-echo $ECHO_N "checking for ${ac_tool_prefix}file... $ECHO_C" >&6
-if test "${lt_cv_path_MAGIC_CMD+set}" = set; then
+ done
+ ac_cv_prog_CXXCPP=$CXXCPP
+fi
+ CXXCPP=$ac_cv_prog_CXXCPP
+else
+fi
+echo "$as_me:$LINENO: result: $CXXCPP" >&5
+echo "${ECHO_T}$CXXCPP" >&6
+ac_preproc_ok=false
+do
+/* confdefs.h. */
+_ACEOF
+#ifdef __STDC__
+#else
+#endif
+ Syntax error
+_ACEOF
+ ac_status=$?
+ else
+ ac_cpp_err=
+ fi
+else
+ ac_cpp_err=yes
+fi
+else
+continue
+fi
+/* confdefs.h. */
+_ACEOF
+_ACEOF
+ ac_status=$?
+ else
+ ac_cpp_err=
+ fi
+else
+ ac_cpp_err=yes
+fi
+continue
+else
+ac_preproc_ok=:
+break
+fi
+done
+else
+ { { echo "$as_me:$LINENO: error: C++ preprocessor \"$CXXCPP\" fails sanity check
+See \`config.log' for more details." >&5
+echo "$as_me: error: C++ preprocessor \"$CXXCPP\" fails sanity check
+See \`config.log' for more details." >&2;}
+fi
+ac_ext=cc
+ac_ext=f
+ac_compile='$F77 -c $FFLAGS conftest.$ac_ext >&5'
+ac_link='$F77 -o conftest$ac_exeext $FFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_f77_compiler_gnu
+if test -n "$ac_tool_prefix"; then
+ for ac_prog in g77 f77 xlf frt pgf77 fort77 fl32 af77 f90 xlf90 pgf90 epcf90 f95 fort xlf95 ifc efc pgf95 lf95 gfortran
+ do
+ # Extract the first word of "$ac_tool_prefix$ac_prog", so it can be a program name with args.
+set dummy $ac_tool_prefix$ac_prog; ac_word=$2
+if test "${ac_cv_prog_F77+set}" = set; then
else
- case $MAGIC_CMD in
- lt_cv_path_MAGIC_CMD="$MAGIC_CMD" # Let the user override the test with a path.
- lt_cv_path_MAGIC_CMD="$MAGIC_CMD" # Let the user override the test with a dos path.
- ac_save_MAGIC_CMD="$MAGIC_CMD"
- IFS="${IFS= }"; ac_save_ifs="$IFS"; IFS=":"
- ac_dummy="/usr/bin:$PATH"
- for ac_dir in $ac_dummy; do
- test -z "$ac_dir" && ac_dir=.
- if test -f $ac_dir/${ac_tool_prefix}file; then
- lt_cv_path_MAGIC_CMD="$ac_dir/${ac_tool_prefix}file"
- if test -n "$file_magic_test_file"; then
- case $deplibs_check_method in
- "file_magic "*)
- file_magic_regex="`expr \"$deplibs_check_method\" : \"file_magic \(.*\)\"`"
- MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
- if eval $file_magic_cmd \$file_magic_test_file 2> /dev/null |
- egrep "$file_magic_regex" > /dev/null; then
- else
- cat <<EOF 1>&2
+ if test -n "$F77"; then
+ ac_cv_prog_F77="$F77" # Let the user override the test.
+else
+do
+ IFS=$as_save_IFS
+ ac_cv_prog_F77="$ac_tool_prefix$ac_prog"
+ break 2
+ fi
+done
+done
-*** Warning: the command libtool uses to detect shared libraries,
-*** $file_magic_cmd, produces output that libtool cannot recognize.
-*** The result is that libtool may fail to recognize shared libraries
-*** as such. This will affect the creation of libtool libraries that
-*** depend on shared libraries, but programs linked with such libtool
-*** libraries will work regardless of this problem. Nevertheless, you
-*** may want to report the problem to your system manager and/or to
-*** bug-libtool at gnu.org
+fi
+fi
+F77=$ac_cv_prog_F77
+if test -n "$F77"; then
+ echo "$as_me:$LINENO: result: $F77" >&5
+echo "${ECHO_T}$F77" >&6
+else
+fi
-EOF
- fi ;;
- esac
- fi
- break
- fi
+ test -n "$F77" && break
done
- MAGIC_CMD="$ac_save_MAGIC_CMD"
-esac
fi
+if test -z "$F77"; then
+ ac_ct_F77=$F77
+do
+ # Extract the first word of "$ac_prog", so it can be a program name with args.
+set dummy $ac_prog; ac_word=$2
+if test "${ac_cv_prog_ac_ct_F77+set}" = set; then
+else
+ if test -n "$ac_ct_F77"; then
+ ac_cv_prog_ac_ct_F77="$ac_ct_F77" # Let the user override the test.
+else
+do
+ IFS=$as_save_IFS
+ ac_cv_prog_ac_ct_F77="$ac_prog"
+ break 2
+ fi
+done
+done
-MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
-if test -n "$MAGIC_CMD"; then
- echo "$as_me:$LINENO: result: $MAGIC_CMD" >&5
-echo "${ECHO_T}$MAGIC_CMD" >&6
+fi
+fi
+ac_ct_F77=$ac_cv_prog_ac_ct_F77
+if test -n "$ac_ct_F77"; then
+ echo "$as_me:$LINENO: result: $ac_ct_F77" >&5
+echo "${ECHO_T}$ac_ct_F77" >&6
else
fi
-if test -z "$lt_cv_path_MAGIC_CMD"; then
- if test -n "$ac_tool_prefix"; then
- echo "$as_me:$LINENO: checking for file" >&5
-echo $ECHO_N "checking for file... $ECHO_C" >&6
+ test -n "$ac_ct_F77" && break
+done
+ F77=$ac_ct_F77
+fi
+# Provide some information about the compiler.
+echo "$as_me:5713:" \
+ "checking for Fortran 77 compiler version" >&5
+ac_compiler=`set X $ac_compile; echo $2`
+{ (eval echo "$as_me:$LINENO: \"$ac_compiler --version </dev/null >&5\"") >&5
+ (eval $ac_compiler --version </dev/null >&5) 2>&5
+ ac_status=$?
+{ (eval echo "$as_me:$LINENO: \"$ac_compiler -v </dev/null >&5\"") >&5
+ (eval $ac_compiler -v </dev/null >&5) 2>&5
+ ac_status=$?
+{ (eval echo "$as_me:$LINENO: \"$ac_compiler -V </dev/null >&5\"") >&5
+ (eval $ac_compiler -V </dev/null >&5) 2>&5
+ ac_status=$?
+rm -f a.out
+# If we don't use `.F' as extension, the preprocessor is not run on the
+# input file. (Note that this only needs to work for GNU compilers.)
+ac_save_ext=$ac_ext
+ac_ext=F
+echo "$as_me:$LINENO: checking whether we are using the GNU Fortran 77 compiler" >&5
+echo $ECHO_N "checking whether we are using the GNU Fortran 77 compiler... $ECHO_C" >&6
+if test "${ac_cv_f77_compiler_gnu+set}" = set; then
else
+ program main
+#ifndef __GNUC__
+ choke me
+#endif
+ end
+_ACEOF
+if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+ (eval $ac_compile) 2>conftest.er1
+ ac_status=$?
+ { ac_try='test -z "$ac_f77_werror_flag"
+ ac_status=$?
+ { ac_try='test -s conftest.$ac_objext'
+ ac_status=$?
+ ac_compiler_gnu=yes
+else
+ac_compiler_gnu=no
+fi
+rm -f conftest.err conftest.$ac_objext conftest.$ac_ext
+ac_cv_f77_compiler_gnu=$ac_compiler_gnu
+fi
+echo "$as_me:$LINENO: result: $ac_cv_f77_compiler_gnu" >&5
+echo "${ECHO_T}$ac_cv_f77_compiler_gnu" >&6
+ac_ext=$ac_save_ext
+ac_test_FFLAGS=${FFLAGS+set}
+ac_save_FFLAGS=$FFLAGS
+FFLAGS=
+echo "$as_me:$LINENO: checking whether $F77 accepts -g" >&5
+echo $ECHO_N "checking whether $F77 accepts -g... $ECHO_C" >&6
+if test "${ac_cv_prog_f77_g+set}" = set; then
+else
+ FFLAGS=-g
+cat >conftest.$ac_ext <<_ACEOF
+ program main
+ end
+_ACEOF
+ ac_status=$?
+ ac_status=$?
+ ac_status=$?
+ ac_cv_prog_f77_g=yes
+else
+ac_cv_prog_f77_g=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_prog_f77_g" >&5
+echo "${ECHO_T}$ac_cv_prog_f77_g" >&6
+if test "$ac_test_FFLAGS" = set; then
+ FFLAGS=$ac_save_FFLAGS
+elif test $ac_cv_prog_f77_g = yes; then
+ if test "x$ac_cv_f77_compiler_gnu" = xyes; then
+ FFLAGS="-g -O2"
+ else
+ FFLAGS="-g"
+ fi
+else
+ FFLAGS="-O2"
+ else
+ FFLAGS=
+ fi
+fi
+G77=`test $ac_compiler_gnu = yes && echo yes`
+ac_ext=cc
+# Autoconf 2.13's AC_OBJEXT and AC_EXEEXT macros only works for C compilers!
+# find the maximum length of command line arguments
+echo "$as_me:$LINENO: checking the maximum length of command line arguments" >&5
+echo $ECHO_N "checking the maximum length of command line arguments... $ECHO_C" >&6
+if test "${lt_cv_sys_max_cmd_len+set}" = set; then
+else
+ i=0
+ teststring="ABCD"
+ case $build_os in
+ msdosdjgpp*)
+ # On DJGPP, this test can blow up pretty badly due to problems in libc
+ # (any single argument exceeding 2000 bytes causes a buffer overrun
+ # during glob expansion). Even if it were fixed, the result of this
+ # check would be larger than it should be.
+ lt_cv_sys_max_cmd_len=12288; # 12K is about right
+ gnu*)
+ # Under GNU Hurd, this test is not required because there is
+ # no limit to the length of command line arguments.
+ # Libtool will interpret -1 as no limit whatsoever
+ lt_cv_sys_max_cmd_len=-1;
+ cygwin* | mingw*)
+ # On Win9x/ME, this test blows up -- it succeeds, but takes
+ # about 5 minutes as the teststring grows exponentially.
+ # Worse, since 9x/ME are not pre-emptively multitasking,
+ # you end up with a "frozen" computer, even though with patience
+ # the test eventually succeeds (with a max line length of 256k).
+ # Instead, let's just punt: use the minimum linelength reported by
+ # all of the supported platforms: 8192 (on NT/2K/XP).
+ lt_cv_sys_max_cmd_len=8192;
+ amigaos*)
+ # On AmigaOS with pdksh, this test takes hours, literally.
+ # So we just punt and use a minimum line length of 8192.
+ # If test is not a shell built-in, we'll probably end up computing a
+ # maximum length that is only half of the actual maximum length, but
+ # we can't tell.
+ while (test "X"`$CONFIG_SHELL $0 --fallback-echo "X$teststring" 2>/dev/null` \
+ = "XX$teststring") >/dev/null 2>&1 &&
+ new_result=`expr "X$teststring" : ".*" 2>&1` &&
+ lt_cv_sys_max_cmd_len=$new_result &&
+ test $i != 17 # 1/2 MB should be enough
+ do
+ i=`expr $i + 1`
+ teststring=$teststring$teststring
+ done
+ teststring=
+ # Add a significant safety factor because C++ compilers can tack on massive
+ # amounts of additional arguments before passing them to the linker.
+ # It appears as though 1/2 is a usable value.
+ lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \/ 2`
+ esac
+fi
+if test -n $lt_cv_sys_max_cmd_len ; then
+ echo "$as_me:$LINENO: result: $lt_cv_sys_max_cmd_len" >&5
+echo "${ECHO_T}$lt_cv_sys_max_cmd_len" >&6
+else
+ echo "$as_me:$LINENO: result: none" >&5
+echo "${ECHO_T}none" >&6
+fi
+# Check for command to grab the raw symbol name followed by C symbol from nm.
+echo "$as_me:$LINENO: checking command to parse $NM output from $compiler object" >&5
+echo $ECHO_N "checking command to parse $NM output from $compiler object... $ECHO_C" >&6
+if test "${lt_cv_sys_global_symbol_pipe+set}" = set; then
+else
+# These are sane defaults that work on at least a few old systems.
+# [They come from Ultrix. What could be older than Ultrix?!! ;)]
+# Character class describing NM global symbol codes.
+symcode='[BCDEGRST]'
+# Regexp to match symbols that can be accessed directly from C.
+sympat='\([_A-Za-z][_A-Za-z0-9]*\)'
+# Transform the above into a raw symbol and a C symbol.
+symxfrm='\1 \2\3 \3'
+# Transform an extracted symbol line into a proper C declaration
+lt_cv_sys_global_symbol_to_cdecl="sed -n -e 's/^. .* \(.*\)$/extern int \1;/p'"
+# Transform an extracted symbol line into symbol name and symbol address
+lt_cv_sys_global_symbol_to_c_name_address="sed -n -e 's/^: \([^ ]*\) $/ {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode \([^ ]*\) \([^ ]*\)$/ {\"\2\", (lt_ptr) \&\2},/p'"
+# Define system-specific variables.
+case $host_os in
+aix*)
+ symcode='[BCDT]'
+cygwin* | mingw* | pw32*)
+ symcode='[ABCDGISTW]'
- if test -f $ac_dir/file; then
- lt_cv_path_MAGIC_CMD="$ac_dir/file"
- "file_magic "*)
- else
- cat <<EOF 1>&2
+hpux*) # Its linker distinguishes data from code symbols
+ if test "$host_cpu" = ia64; then
+ symcode='[ABCDEGRST]'
+ fi
+ lt_cv_sys_global_symbol_to_cdecl="sed -n -e 's/^T .* \(.*\)$/extern int \1();/p' -e 's/^$symcode* .* \(.*\)$/extern char \1;/p'"
+ lt_cv_sys_global_symbol_to_c_name_address="sed -n -e 's/^: \([^ ]*\) $/ {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode* \([^ ]*\) \([^ ]*\)$/ {\"\2\", (lt_ptr) \&\2},/p'"
+irix* | nonstopux*)
+ symcode='[BCDEGRST]'
+osf*)
+ symcode='[BCDEGQRST]'
+solaris* | sysv5*)
+ symcode='[BDRT]'
+sysv4)
+ symcode='[DFNSTU]'
+esac
+# Handle CRLF in mingw tool chain
+opt_cr=
+case $build_os in
+mingw*)
+ opt_cr=`echo 'x\{0,1\}' | tr x '\015'` # option cr in regexp
+esac
+# If we're using GNU nm, then use its standard symbol codes.
+case `$NM -V 2>&1` in
+ symcode='[ABCDGIRSTW]' ;;
+esac
+# Try without a prefix undercore, then with it.
+for ac_symprfx in "" "_"; do
+ # Write the raw and C identifiers.
+ lt_cv_sys_global_symbol_pipe="sed -n -e 's/^.*[ ]\($symcode$symcode*\)[ ][ ]*\($ac_symprfx\)$sympat$opt_cr$/$symxfrm/p'"
+ # Check to see that the pipe works correctly.
+ pipe_works=no
+ rm -f conftest*
+ cat > conftest.$ac_ext <<EOF
+#ifdef __cplusplus
+extern "C" {
+#endif
+char nm_test_var;
+void nm_test_func(){}
+#ifdef __cplusplus
+#endif
+int main(){nm_test_var='a';nm_test_func();return(0);}
EOF
- fi ;;
- esac
+ ac_status=$?
+ # Now try to grab the symbols.
+ nlist=conftest.nm
+ if { (eval echo "$as_me:$LINENO: \"$NM conftest.$ac_objext \| $lt_cv_sys_global_symbol_pipe \> $nlist\"") >&5
+ (eval $NM conftest.$ac_objext \| $lt_cv_sys_global_symbol_pipe \> $nlist) 2>&5
+ ac_status=$?
+ (exit $ac_status); } && test -s "$nlist"; then
+ # Try sorting and uniquifying the output.
+ if sort "$nlist" | uniq > "$nlist"T; then
+ mv -f "$nlist"T "$nlist"
+ else
+ rm -f "$nlist"T
fi
- break
+ # Make sure that we snagged all the symbols we need.
+ if grep ' nm_test_var$' "$nlist" >/dev/null; then
+ if grep ' nm_test_func$' "$nlist" >/dev/null; then
+ cat <<EOF > conftest.$ac_ext
+#ifdef __cplusplus
+extern "C" {
+#endif
+EOF
+ # Now generate the symbol file.
+ eval "$lt_cv_sys_global_symbol_to_cdecl"' < "$nlist" | grep -v main >> conftest.$ac_ext'
+ cat <<EOF >> conftest.$ac_ext
+#if defined (__STDC__) && __STDC__
+# define lt_ptr_t void *
+#else
+# define lt_ptr_t char *
+# define const
+#endif
+/* The mapping between symbol names and symbols. */
+const struct {
+ const char *name;
+ lt_ptr_t address;
+lt_preloaded_symbols[] =
+EOF
+ $SED "s/^$symcode$symcode* \(.*\) \(.*\)$/ {\"\2\", (lt_ptr_t) \&\2},/" < "$nlist" | grep -v main >> conftest.$ac_ext
+ cat <<\EOF >> conftest.$ac_ext
+ {0, (lt_ptr_t) 0}
+#ifdef __cplusplus
+#endif
+EOF
+ # Now try linking the two files.
+ mv conftest.$ac_objext conftstm.$ac_objext
+ lt_save_LIBS="$LIBS"
+ lt_save_CFLAGS="$CFLAGS"
+ LIBS="conftstm.$ac_objext"
+ CFLAGS="$CFLAGS$lt_prog_compiler_no_builtin_flag"
+ if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+ (eval $ac_link) 2>&5
+ ac_status=$?
+ (exit $ac_status); } && test -s conftest${ac_exeext}; then
+ pipe_works=yes
+ fi
+ LIBS="$lt_save_LIBS"
+ CFLAGS="$lt_save_CFLAGS"
+ else
+ echo "cannot find nm_test_func in $nlist" >&5
+ fi
+ else
+ echo "cannot find nm_test_var in $nlist" >&5
+ fi
+ else
+ echo "cannot run $lt_cv_sys_global_symbol_pipe" >&5
fi
- done
+ else
+ echo "$progname: failed program was:" >&5
+ cat conftest.$ac_ext >&5
+ fi
+ rm -f conftest* conftst*
+ # Do not use the global_symbol_pipe unless it works.
+ if test "$pipe_works" = yes; then
+ break
+ else
+ fi
+done
+fi
+if test -z "$lt_cv_sys_global_symbol_pipe"; then
+fi
+if test -z "$lt_cv_sys_global_symbol_pipe$lt_cv_sys_global_symbol_to_cdecl"; then
+ echo "$as_me:$LINENO: result: failed" >&5
+echo "${ECHO_T}failed" >&6
+else
+ echo "$as_me:$LINENO: result: ok" >&5
+echo "${ECHO_T}ok" >&6
+fi
+echo "$as_me:$LINENO: checking for objdir" >&5
+echo $ECHO_N "checking for objdir... $ECHO_C" >&6
+if test "${lt_cv_objdir+set}" = set; then
+else
+ rm -f .libs 2>/dev/null
+mkdir .libs 2>/dev/null
+if test -d .libs; then
+ lt_cv_objdir=.libs
+else
+ # MS-DOS does not allow filenames that begin with a dot.
+ lt_cv_objdir=_libs
+fi
+rmdir .libs 2>/dev/null
+fi
+echo "$as_me:$LINENO: result: $lt_cv_objdir" >&5
+echo "${ECHO_T}$lt_cv_objdir" >&6
+objdir=$lt_cv_objdir
+case $host_os in
+aix3*)
+ # AIX sometimes has problems with the GCC collect2 program. For some
+ # reason, if we set the COLLECT_NAMES environment variable, the problems
+ # vanish in a puff of smoke.
+ if test "X${COLLECT_NAMES+set}" != Xset; then
+ COLLECT_NAMES=
+ export COLLECT_NAMES
+ fi
esac
-fi
+# Sed substitution that helps us do robust quoting. It backslashifies
+# metacharacters that are still active within double-quoted strings.
+Xsed='sed -e s/^X//'
+sed_quote_subst='s/\([\\"\\`$\\\\]\)/\\\1/g'
+# Same as above, but do not quote variable references.
+double_quote_subst='s/\([\\"\\`\\\\]\)/\\\1/g'
+# Sed substitution to delay expansion of an escaped shell variable in a
+# double_quote_subst'ed string.
+delay_variable_subst='s/\\\\\\\\\\\$/\\\\\\$/g'
+# Sed substitution to avoid accidental globbing in evaled expressions
+no_glob_subst='s/\*/\\\*/g'
+# Constants:
+rm="rm -f"
+# Global variables:
+default_ofile=libtool
+can_build_shared=yes
+# All known linkers require a `.a' archive for static linking (except M$VC,
+# which needs '.lib').
+libext=a
+ltmain="$ac_aux_dir/ltmain.sh"
+ofile="$default_ofile"
+with_gnu_ld="$lt_cv_prog_gnu_ld"
+ # Extract the first word of "${ac_tool_prefix}ar", so it can be a program name with args.
+set dummy ${ac_tool_prefix}ar; ac_word=$2
+if test "${ac_cv_prog_AR+set}" = set; then
else
+ if test -n "$AR"; then
+ ac_cv_prog_AR="$AR" # Let the user override the test.
+else
+do
+ IFS=$as_save_IFS
+ ac_cv_prog_AR="${ac_tool_prefix}ar"
+ break 2
+ fi
+done
+done
+fi
+fi
+AR=$ac_cv_prog_AR
+if test -n "$AR"; then
+ echo "$as_me:$LINENO: result: $AR" >&5
+echo "${ECHO_T}$AR" >&6
+else
fi
- else
- MAGIC_CMD=:
+fi
+if test -z "$ac_cv_prog_AR"; then
+ ac_ct_AR=$AR
+ # Extract the first word of "ar", so it can be a program name with args.
+set dummy ar; ac_word=$2
+if test "${ac_cv_prog_ac_ct_AR+set}" = set; then
+else
+ if test -n "$ac_ct_AR"; then
+ ac_cv_prog_ac_ct_AR="$ac_ct_AR" # Let the user override the test.
+else
+do
+ IFS=$as_save_IFS
+ ac_cv_prog_ac_ct_AR="ar"
+ break 2
fi
+done
+done
+ test -z "$ac_cv_prog_ac_ct_AR" && ac_cv_prog_ac_ct_AR="false"
fi
+fi
+ac_ct_AR=$ac_cv_prog_ac_ct_AR
+if test -n "$ac_ct_AR"; then
+ echo "$as_me:$LINENO: result: $ac_ct_AR" >&5
+echo "${ECHO_T}$ac_ct_AR" >&6
+else
+fi
- fi
-esac
+ AR=$ac_ct_AR
+else
+ AR="$ac_cv_prog_AR"
+fi
# Extract the first word of "${ac_tool_prefix}ranlib", so it can be a program name with args.
@@ -5111,150 +6436,6 @@
fi
-enable_dlopen=no
-enable_win32_dll=no
-# Check whether --enable-libtool-lock or --disable-libtool-lock was given.
-if test "${enable_libtool_lock+set}" = set; then
- enableval="$enable_libtool_lock"
-fi;
-test "x$enable_libtool_lock" != xno && enable_libtool_lock=yes
-# Some flags need to be propagated to the compiler or linker for good
-# libtool support.
-case $host in
-*-*-irix6*)
- # Find out which ABI we are using.
- echo '#line 5129 "configure"' > conftest.$ac_ext
- if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
- (eval $ac_compile) 2>&5
- ac_status=$?
- (exit $ac_status); }; then
- case `/usr/bin/file conftest.$ac_objext` in
- *32-bit*)
- LD="${LD-ld} -32"
- *N32*)
- LD="${LD-ld} -n32"
- *64-bit*)
- LD="${LD-ld} -64"
- esac
- fi
- rm -rf conftest*
-*-*-sco3.2v5*)
- # On SCO OpenServer 5, we need -belf to get full-featured binaries.
- SAVE_CFLAGS="$CFLAGS"
- CFLAGS="$CFLAGS -belf"
- echo "$as_me:$LINENO: checking whether the C compiler needs -belf" >&5
-echo $ECHO_N "checking whether the C compiler needs -belf... $ECHO_C" >&6
-if test "${lt_cv_cc_needs_belf+set}" = set; then
-else
- ac_ext=c
-ac_cpp='$CPP $CPPFLAGS'
-ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_c_compiler_gnu
- cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h. */
-_ACEOF
-cat confdefs.h >>conftest.$ac_ext
-cat >>conftest.$ac_ext <<_ACEOF
-/* end confdefs.h. */
-int
-main ()
- return 0;
-_ACEOF
-rm -f conftest.$ac_objext conftest$ac_exeext
-if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
- (eval $ac_link) 2>conftest.er1
- ac_status=$?
- grep -v '^ *+' conftest.er1 >conftest.err
- rm -f conftest.er1
- cat conftest.err >&5
- { ac_try='test -z "$ac_c_werror_flag"
- || test ! -s conftest.err'
- { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
- (eval $ac_try) 2>&5
- ac_status=$?
- (exit $ac_status); }; } &&
- { ac_try='test -s conftest$ac_exeext'
- ac_status=$?
- (exit $ac_status); }; }; then
- lt_cv_cc_needs_belf=yes
-else
- echo "$as_me: failed program was:" >&5
-sed 's/^/| /' conftest.$ac_ext >&5
-lt_cv_cc_needs_belf=no
-fi
-rm -f conftest.err conftest.$ac_objext \
- conftest$ac_exeext conftest.$ac_ext
- ac_ext=cc
-fi
-echo "$as_me:$LINENO: result: $lt_cv_cc_needs_belf" >&5
-echo "${ECHO_T}$lt_cv_cc_needs_belf" >&6
- if test x"$lt_cv_cc_needs_belf" != x"yes"; then
- # this is probably gcc 2.8.0, egcs 1.0 or newer; no need for -belf
- CFLAGS="$SAVE_CFLAGS"
- fi
-esac
-# Sed substitution that helps us do robust quoting. It backslashifies
-# metacharacters that are still active within double-quoted strings.
-Xsed='sed -e s/^X//'
-sed_quote_subst='s/\([\\"\\`$\\\\]\)/\\\1/g'
-# Same as above, but do not quote variable references.
-double_quote_subst='s/\([\\"\\`\\\\]\)/\\\1/g'
-# Sed substitution to delay expansion of an escaped shell variable in a
-# double_quote_subst'ed string.
-delay_variable_subst='s/\\\\\\\\\\\$/\\\\\\$/g'
-# Constants:
-rm="rm -f"
-# Global variables:
-default_ofile=libtool
-can_build_shared=yes
-# All known linkers require a `.a' archive for static linking (except M$VC,
-# which needs '.lib').
-libext=a
-ltmain="$ac_aux_dir/ltmain.sh"
-ofile="$default_ofile"
-with_gnu_ld="$lt_cv_prog_gnu_ld"
-need_locks="$enable_libtool_lock"
old_CC="$CC"
old_CFLAGS="$CFLAGS"
@@ -5263,40 +6444,18 @@
test -z "$AR_FLAGS" && AR_FLAGS=cru
test -z "$AS" && AS=as
test -z "$CC" && CC=cc
+test -z "$LTCC" && LTCC=$CC
test -z "$DLLTOOL" && DLLTOOL=dlltool
test -z "$LD" && LD=ld
test -z "$LN_S" && LN_S="ln -s"
test -z "$MAGIC_CMD" && MAGIC_CMD=file
test -z "$NM" && NM=nm
+test -z "$SED" && SED=sed
test -z "$OBJDUMP" && OBJDUMP=objdump
test -z "$RANLIB" && RANLIB=:
test -z "$STRIP" && STRIP=:
test -z "$ac_objext" && ac_objext=o
-if test x"$host" != x"$build"; then
- ac_tool_prefix=${host_alias}-
-else
- ac_tool_prefix=
-fi
-# Transform linux* to *-*-linux-gnu*, to support old configure scripts.
-case $host_os in
-linux-gnu*) ;;
-linux*) host=`echo $host | sed 's/^\(.*-.*-linux\)\(.*\)$/\1-gnu\2/'`
-esac
-case $host_os in
-aix3*)
- # AIX sometimes has problems with the GCC collect2 program. For some
- # reason, if we set the COLLECT_NAMES environment variable, the problems
- # vanish in a puff of smoke.
- if test "X${COLLECT_NAMES+set}" != Xset; then
- COLLECT_NAMES=
- export COLLECT_NAMES
- fi
-esac
# Determine commands to create old-style static archives.
old_archive_cmds='$AR $AR_FLAGS $oldlib$oldobjs$old_deplibs'
old_postinstall_cmds='chmod 644 $oldlib'
@@ -5314,26 +6473,152 @@
old_archive_cmds="$old_archive_cmds~\$RANLIB \$oldlib"
fi
-# Allow CC to be a program name with arguments.
-set dummy $CC
-compiler="$2"
+# Only perform the check for file, if the check method requires it
+case $deplibs_check_method in
+file_magic*)
+ if test "$file_magic_cmd" = '$MAGIC_CMD'; then
+ echo "$as_me:$LINENO: checking for ${ac_tool_prefix}file" >&5
+echo $ECHO_N "checking for ${ac_tool_prefix}file... $ECHO_C" >&6
+if test "${lt_cv_path_MAGIC_CMD+set}" = set; then
+ echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+ case $MAGIC_CMD in
+ lt_cv_path_MAGIC_CMD="$MAGIC_CMD" # Let the user override the test with a path.
+ lt_save_MAGIC_CMD="$MAGIC_CMD"
+ lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
+ ac_dummy="/usr/bin$PATH_SEPARATOR$PATH"
+ for ac_dir in $ac_dummy; do
+ IFS="$lt_save_ifs"
+ test -z "$ac_dir" && ac_dir=.
+ if test -f $ac_dir/${ac_tool_prefix}file; then
+ lt_cv_path_MAGIC_CMD="$ac_dir/${ac_tool_prefix}file"
+ if test -n "$file_magic_test_file"; then
+ case $deplibs_check_method in
+ "file_magic "*)
+ file_magic_regex="`expr \"$deplibs_check_method\" : \"file_magic \(.*\)\"`"
+ MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
+ if eval $file_magic_cmd \$file_magic_test_file 2> /dev/null |
+ $EGREP "$file_magic_regex" > /dev/null; then
+ else
+ cat <<EOF 1>&2
-echo "$as_me:$LINENO: checking for objdir" >&5
-echo $ECHO_N "checking for objdir... $ECHO_C" >&6
-rm -f .libs 2>/dev/null
-mkdir .libs 2>/dev/null
-if test -d .libs; then
- objdir=.libs
+*** Warning: the command libtool uses to detect shared libraries,
+*** $file_magic_cmd, produces output that libtool cannot recognize.
+*** The result is that libtool may fail to recognize shared libraries
+*** as such. This will affect the creation of libtool libraries that
+*** depend on shared libraries, but programs linked with such libtool
+*** libraries will work regardless of this problem. Nevertheless, you
+*** may want to report the problem to your system manager and/or to
+*** bug-libtool at gnu.org
+EOF
+ fi ;;
+ esac
+ fi
+ break
+ fi
+ done
+ MAGIC_CMD="$lt_save_MAGIC_CMD"
+esac
+fi
+MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
+if test -n "$MAGIC_CMD"; then
+ echo "$as_me:$LINENO: result: $MAGIC_CMD" >&5
+echo "${ECHO_T}$MAGIC_CMD" >&6
else
- # MS-DOS does not allow filenames that begin with a dot.
- objdir=_libs
+ echo "$as_me:$LINENO: result: no" >&5
+echo "${ECHO_T}no" >&6
fi
-rmdir .libs 2>/dev/null
-echo "$as_me:$LINENO: result: $objdir" >&5
-echo "${ECHO_T}$objdir" >&6
+if test -z "$lt_cv_path_MAGIC_CMD"; then
+ if test -n "$ac_tool_prefix"; then
+ echo "$as_me:$LINENO: checking for file" >&5
+echo $ECHO_N "checking for file... $ECHO_C" >&6
+else
+ if test -f $ac_dir/file; then
+ lt_cv_path_MAGIC_CMD="$ac_dir/file"
+ "file_magic "*)
+ else
+ cat <<EOF 1>&2
+EOF
+ fi ;;
+ esac
+ fi
+ break
+ fi
+ done
+esac
+fi
+else
+fi
+ else
+ MAGIC_CMD=:
+ fi
+fi
+ fi
+esac
+enable_dlopen=no
+enable_win32_dll=no
+fi;
# Check whether --with-pic or --without-pic was given.
if test "${with_pic+set}" = set; then
withval="$with_pic"
@@ -5343,167 +6628,783 @@
fi;
test -z "$pic_mode" && pic_mode=default
-# We assume here that the value for lt_cv_prog_cc_pic will not be cached
-# in isolation, and that seeing it set (from the cache) indicates that
-# the associated values are set (in the cache) correctly too.
-echo "$as_me:$LINENO: checking for $compiler option to produce PIC" >&5
-echo $ECHO_N "checking for $compiler option to produce PIC... $ECHO_C" >&6
-if test "${lt_cv_prog_cc_pic+set}" = set; then
+# Use C for the default configuration in the libtool script
+tagname=
+lt_save_CC="$CC"
+ac_ext=c
+# Source file extension for C test sources.
+ac_ext=c
+# Object file extension for compiled C test sources.
+objext=o
+objext=$objext
+# Code to be used in simple compile tests
+lt_simple_compile_test_code="int some_variable = 0;\n"
+# Code to be used in simple link tests
+lt_simple_link_test_code='int main(){return(0);}\n'
+LTCC=${LTCC-"$CC"}
+compiler=$CC
+# Check for any special shared library compilation flags.
+lt_prog_cc_shlib=
+if test "$GCC" = no; then
+ case $host_os in
+ sco3.2v5*)
+ lt_prog_cc_shlib='-belf'
+ esac
+fi
+if test -n "$lt_prog_cc_shlib"; then
+ { echo "$as_me:$LINENO: WARNING: \`$CC' requires \`$lt_prog_cc_shlib' to build shared libraries" >&5
+echo "$as_me: WARNING: \`$CC' requires \`$lt_prog_cc_shlib' to build shared libraries" >&2;}
+ if echo "$old_CC $old_CFLAGS " | grep "[ ]$lt_prog_cc_shlib[ ]" >/dev/null; then :
+ else
+ { echo "$as_me:$LINENO: WARNING: add \`$lt_prog_cc_shlib' to the CC or CFLAGS env variable and reconfigure" >&5
+echo "$as_me: WARNING: add \`$lt_prog_cc_shlib' to the CC or CFLAGS env variable and reconfigure" >&2;}
+ lt_cv_prog_cc_can_build_shared=no
+ fi
+fi
+# Check to make sure the static flag actually works.
+echo "$as_me:$LINENO: checking if $compiler static flag $lt_prog_compiler_static works" >&5
+echo $ECHO_N "checking if $compiler static flag $lt_prog_compiler_static works... $ECHO_C" >&6
+if test "${lt_prog_compiler_static_works+set}" = set; then
else
- lt_cv_prog_cc_pic=
- lt_cv_prog_cc_shlib=
- lt_cv_prog_cc_wl=
- lt_cv_prog_cc_static=
- lt_cv_prog_cc_no_builtin=
- lt_cv_prog_cc_can_build_shared=$can_build_shared
+ lt_prog_compiler_static_works=no
+ save_LDFLAGS="$LDFLAGS"
+ LDFLAGS="$LDFLAGS $lt_prog_compiler_static"
+ printf "$lt_simple_link_test_code" > conftest.$ac_ext
+ if (eval $ac_link 2>conftest.err) && test -s conftest$ac_exeext; then
+ # The compiler can only warn and ignore the option if not recognized
+ # So say no if there are warnings
+ # Append any errors to the config.log.
+ cat conftest.err 1>&5
+ else
+ lt_prog_compiler_static_works=yes
+ fi
+ fi
+ $rm conftest*
+ LDFLAGS="$save_LDFLAGS"
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_static_works" >&5
+echo "${ECHO_T}$lt_prog_compiler_static_works" >&6
+if test x"$lt_prog_compiler_static_works" = xyes; then
+else
+ lt_prog_compiler_static=
+fi
+lt_prog_compiler_no_builtin_flag=
+if test "$GCC" = yes; then
+ lt_prog_compiler_no_builtin_flag=' -fno-builtin'
+echo "$as_me:$LINENO: checking if $compiler supports -fno-rtti -fno-exceptions" >&5
+echo $ECHO_N "checking if $compiler supports -fno-rtti -fno-exceptions... $ECHO_C" >&6
+if test "${lt_cv_prog_compiler_rtti_exceptions+set}" = set; then
+else
+ lt_cv_prog_compiler_rtti_exceptions=no
+ ac_outfile=conftest.$ac_objext
+ printf "$lt_simple_compile_test_code" > conftest.$ac_ext
+ lt_compiler_flag="-fno-rtti -fno-exceptions"
+ # Insert the option either (1) after the last *FLAGS variable, or
+ # (2) before a word containing "conftest.", or (3) at the end.
+ # Note that $ac_compile itself does not contain backslashes and begins
+ # with a dollar sign (not a hyphen), so the echo should work correctly.
+ # The option is referenced via a variable to avoid confusing sed.
+ lt_compile=`echo "$ac_compile" | $SED \
+ -e 's:.*FLAGS}? :&$lt_compiler_flag :; t' \
+ -e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
+ -e 's:$: $lt_compiler_flag:'`
+ (eval echo "\"\$as_me:6747: $lt_compile\"" >&5)
+ (eval "$lt_compile" 2>conftest.err)
+ ac_status=$?
+ echo "$as_me:6751: \$? = $ac_status" >&5
+ if (exit $ac_status) && test -s "$ac_outfile"; then
+ if test ! -s conftest.err; then
+ lt_cv_prog_compiler_rtti_exceptions=yes
+ fi
+ fi
+ $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_rtti_exceptions" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_rtti_exceptions" >&6
+if test x"$lt_cv_prog_compiler_rtti_exceptions" = xyes; then
+ lt_prog_compiler_no_builtin_flag="$lt_prog_compiler_no_builtin_flag -fno-rtti -fno-exceptions"
+else
+fi
+fi
+lt_prog_compiler_wl=
+lt_prog_compiler_pic=
+lt_prog_compiler_static=
+echo "$as_me:$LINENO: checking for $compiler option to produce PIC" >&5
+echo $ECHO_N "checking for $compiler option to produce PIC... $ECHO_C" >&6
- lt_cv_prog_cc_wl='-Wl,'
- lt_cv_prog_cc_static='-static'
+ lt_prog_compiler_wl='-Wl,'
+ lt_prog_compiler_static='-static'
case $host_os in
- aix*)
- # Below there is a dirty hack to force normal static linking with -ldl
- # The problem is because libdl dynamically linked with both libc and
- # libC (AIX C++ library), which obviously doesn't included in libraries
- # list by gcc. This cause undefined symbols with -static flags.
- # This hack allows C programs to be linked with "-static -ldl", but
- # not sure about C++ programs.
- lt_cv_prog_cc_static="$lt_cv_prog_cc_static ${lt_cv_prog_cc_wl}-lC"
+ aix*)
+ # All AIX code is PIC.
+ # AIX 5 now supports IA64 processor
+ lt_prog_compiler_static='-Bstatic'
+ fi
amigaos*)
# FIXME: we need at least 68020 code to build shared libraries, but
# adding the `-m68020' flag to GCC prevents building anything better,
# like `-m68040'.
- lt_cv_prog_cc_pic='-m68020 -resident32 -malways-restore-a4'
+ lt_prog_compiler_pic='-m68020 -resident32 -malways-restore-a4'
- beos* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
+ beos* | cygwin* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
# PIC is the default for these OSes.
+ mingw* | pw32* | os2*)
+ # This hack is so that the source file can tell whether it is being
+ # built for inclusion in a dll (and should export symbols for example).
+ lt_prog_compiler_pic='-DDLL_EXPORT'
# PIC is the default on this platform
# Common symbols not allowed in MH_DYLIB files
- lt_cv_prog_cc_pic='-fno-common'
+ lt_prog_compiler_pic='-fno-common'
- cygwin* | mingw* | pw32* | os2*)
- # This hack is so that the source file can tell whether it is being
- # built for inclusion in a dll (and should export symbols for example).
- lt_cv_prog_cc_pic='-DDLL_EXPORT'
+ msdosdjgpp*)
+ # Just because we use GCC doesn't mean we suddenly get shared libraries
+ # on systems that don't support them.
+ lt_prog_compiler_can_build_shared=no
+ enable_shared=no
sysv4*MP*)
if test -d /usr/nec; then
- lt_cv_prog_cc_pic=-Kconform_pic
+ lt_prog_compiler_pic=-Kconform_pic
fi
+ hpux*)
+ # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
+ # not for PA HP-UX.
+ hppa*64*|ia64*)
+ # +Z the default
+ lt_prog_compiler_pic='-fPIC'
+ esac
- lt_cv_prog_cc_pic='-fPIC'
esac
else
- # PORTME Check for PIC flags for the system compiler.
+ # PORTME Check for flag to pass linker flags through the system compiler.
case $host_os in
- aix3* | aix4* | aix5*)
- # All AIX code is PIC.
+ aix*)
- lt_cv_prog_cc_static='-Bstatic'
else
- lt_cv_prog_cc_static='-bnso -bI:/lib/syscalls.exp'
+ lt_prog_compiler_static='-bnso -bI:/lib/syscalls.exp'
fi
hpux9* | hpux10* | hpux11*)
- # Is there a better lt_cv_prog_cc_static that works with the bundled CC?
- lt_cv_prog_cc_static="${lt_cv_prog_cc_wl}-a ${lt_cv_prog_cc_wl}archive"
- lt_cv_prog_cc_pic='+Z'
+ hppa*64*|ia64*)
+ # +Z the default
+ lt_prog_compiler_pic='+Z'
+ esac
+ # Is there a better lt_prog_compiler_static that works with the bundled CC?
+ lt_prog_compiler_static='${wl}-a ${wl}archive'
- lt_cv_prog_cc_static='-non_shared'
# PIC (with -KPIC) is the default.
+ lt_prog_compiler_static='-non_shared'
+ newsos6)
+ lt_prog_compiler_pic='-KPIC'
- newsos6)
- lt_cv_prog_cc_pic='-KPIC'
+ linux*)
+ case $CC in
+ icc* | ecc*)
+ ccc*)
+ # All Alpha code is PIC.
+ esac
# All OSF/1 code is PIC.
sco3.2v5*)
- lt_cv_prog_cc_pic='-Kpic'
- lt_cv_prog_cc_static='-dn'
- lt_cv_prog_cc_shlib='-belf'
+ lt_prog_compiler_pic='-Kpic'
+ lt_prog_compiler_static='-dn'
solaris*)
sunos4*)
- lt_cv_prog_cc_pic='-PIC'
- lt_cv_prog_cc_wl='-Qoption ld '
+ lt_prog_compiler_wl='-Qoption ld '
+ lt_prog_compiler_pic='-PIC'
- uts4*)
- lt_cv_prog_cc_pic='-pic'
sysv4*MP*)
if test -d /usr/nec ;then
- lt_cv_prog_cc_pic='-Kconform_pic'
+ lt_prog_compiler_pic='-Kconform_pic'
fi
+ uts4*)
+ lt_prog_compiler_pic='-pic'
- lt_cv_prog_cc_can_build_shared=no
esac
fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic" >&6
+# Check to make sure the PIC flag actually works.
+if test -n "$lt_prog_compiler_pic"; then
+echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic works" >&5
+echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic works... $ECHO_C" >&6
+if test "${lt_prog_compiler_pic_works+set}" = set; then
+else
+ lt_prog_compiler_pic_works=no
+ lt_compiler_flag="$lt_prog_compiler_pic -DPIC"
+ (eval echo "\"\$as_me:6980: $lt_compile\"" >&5)
+ ac_status=$?
+ echo "$as_me:6984: \$? = $ac_status" >&5
+ lt_prog_compiler_pic_works=yes
+ fi
+ fi
+ $rm conftest*
fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_works" >&6
-if test -z "$lt_cv_prog_cc_pic"; then
- echo "$as_me:$LINENO: result: none" >&5
-echo "${ECHO_T}none" >&6
+if test x"$lt_prog_compiler_pic_works" = xyes; then
+ case $lt_prog_compiler_pic in
+ *) lt_prog_compiler_pic=" $lt_prog_compiler_pic" ;;
+ esac
else
- echo "$as_me:$LINENO: result: $lt_cv_prog_cc_pic" >&5
-echo "${ECHO_T}$lt_cv_prog_cc_pic" >&6
+fi
- # Check to make sure the pic_flag actually works.
- echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_cv_prog_cc_pic works" >&5
-echo $ECHO_N "checking if $compiler PIC flag $lt_cv_prog_cc_pic works... $ECHO_C" >&6
- if test "${lt_cv_prog_cc_pic_works+set}" = set; then
+fi
+case "$host_os" in
+ # For platforms which do not support PIC, -DPIC is meaningless:
+ *djgpp*)
+ lt_prog_compiler_pic="$lt_prog_compiler_pic -DPIC"
+esac
+echo "$as_me:$LINENO: checking if $compiler supports -c -o file.$ac_objext" >&5
+echo $ECHO_N "checking if $compiler supports -c -o file.$ac_objext... $ECHO_C" >&6
+if test "${lt_cv_prog_compiler_c_o+set}" = set; then
else
- CFLAGS="$CFLAGS $lt_cv_prog_cc_pic -DPIC"
+ lt_cv_prog_compiler_c_o=no
+ $rm -r conftest 2>/dev/null
+ mkdir conftest
+ cd conftest
+ mkdir out
+ lt_compiler_flag="-o out/conftest2.$ac_objext"
+ (eval echo "\"\$as_me:7040: $lt_compile\"" >&5)
+ (eval "$lt_compile" 2>out/conftest.err)
+ ac_status=$?
+ cat out/conftest.err >&5
+ echo "$as_me:7044: \$? = $ac_status" >&5
+ if (exit $ac_status) && test -s out/conftest2.$ac_objext
+ then
+ if test ! -s out/conftest.err; then
+ lt_cv_prog_compiler_c_o=yes
+ fi
+ fi
+ chmod u+w .
+ $rm conftest*
+ # SGI C++ compiler will create directory out/ii_files/ for
+ # template instantiation
+ test -d out/ii_files && $rm out/ii_files/* && rmdir out/ii_files
+ $rm out/* && rmdir out
+ cd ..
+ rmdir conftest
+ $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_c_o" >&6
+hard_links="nottested"
+if test "$lt_cv_prog_compiler_c_o" = no && test "$need_locks" != no; then
+ # do not overwrite the value of need_locks provided by the user
+ echo "$as_me:$LINENO: checking if we can lock with hard links" >&5
+echo $ECHO_N "checking if we can lock with hard links... $ECHO_C" >&6
+ hard_links=yes
+ $rm conftest*
+ ln conftest.a conftest.b 2>/dev/null && hard_links=no
+ touch conftest.a
+ ln conftest.a conftest.b 2>&5 || hard_links=no
+ echo "$as_me:$LINENO: result: $hard_links" >&5
+echo "${ECHO_T}$hard_links" >&6
+ if test "$hard_links" = no; then
+ { echo "$as_me:$LINENO: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
+echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
+ need_locks=warn
+ fi
+else
+ need_locks=no
+fi
+echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
+echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
+ runpath_var=
+ allow_undefined_flag=
+ enable_shared_with_static_runtimes=no
+ archive_cmds=
+ archive_expsym_cmds=
+ old_archive_From_new_cmds=
+ old_archive_from_expsyms_cmds=
+ export_dynamic_flag_spec=
+ whole_archive_flag_spec=
+ thread_safe_flag_spec=
+ hardcode_libdir_flag_spec=
+ hardcode_libdir_flag_spec_ld=
+ hardcode_libdir_separator=
+ hardcode_direct=no
+ hardcode_minus_L=no
+ hardcode_shlibpath_var=unsupported
+ link_all_deplibs=unknown
+ hardcode_automatic=no
+ module_cmds=
+ module_expsym_cmds=
+ always_export_symbols=no
+ export_symbols_cmds='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
+ # include_expsyms should be a list of space-separated symbols to be *always*
+ # included in the symbol list
+ include_expsyms=
+ # exclude_expsyms can be an extended regexp of symbols to exclude
+ # it will be wrapped by ` (' and `)$', so one must not match beginning or
+ # end of line. Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
+ # as well as any symbol that contains `d'.
+ exclude_expsyms="_GLOBAL_OFFSET_TABLE_"
+ # Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
+ # platforms (ab)use it in PIC code, but their linkers get confused if
+ # the symbol is explicitly referenced. Since portable code cannot
+ # rely on this symbol name, it's probably fine to never include it in
+ # preloaded symbol tables.
+ extract_expsyms_cmds=
+ case $host_os in
+ cygwin* | mingw* | pw32*)
+ # FIXME: the MSVC++ port hasn't been tested in a loooong time
+ # When not using gcc, we currently assume that we are using
+ # Microsoft Visual C++.
+ if test "$GCC" != yes; then
+ with_gnu_ld=no
+ fi
+ openbsd*)
+ with_gnu_ld=no
+ esac
+ ld_shlibs=yes
+ if test "$with_gnu_ld" = yes; then
+ # If archive_cmds runs LD, not CC, wlarc should be empty
+ wlarc='${wl}'
+ # See if GNU ld supports shared libraries.
+ case $host_os in
+ aix3* | aix4* | aix5*)
+ # On AIX/PPC, the GNU linker is very broken
+ if test "$host_cpu" != ia64; then
+ ld_shlibs=no
+ cat <<EOF 1>&2
+*** Warning: the GNU linker, at least up to release 2.9.1, is reported
+*** to be unable to reliably create shared libraries on AIX.
+*** Therefore, libtool is disabling shared libraries support. If you
+*** really care for shared libraries, you may want to modify your PATH
+*** so that a non-GNU linker is found, and then restart.
+EOF
+ fi
+ amigaos*)
+ archive_cmds='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
+ hardcode_libdir_flag_spec='-L$libdir'
+ hardcode_minus_L=yes
+ # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
+ # that the semantics of dynamic libraries on AmigaOS, at least up
+ # to version 4, is to share data among multiple programs linked
+ # with the same dynamic library. Since this doesn't match the
+ # behavior of shared libraries on other platforms, we can't use
+ # them.
+ ld_shlibs=no
+ beos*)
+ if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+ allow_undefined_flag=unsupported
+ # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
+ # support --undefined. This deserves some investigation. FIXME
+ archive_cmds='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+ else
+ ld_shlibs=no
+ fi
+ # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, ) is actually meaningless,
+ # as there is no search path for DLLs.
+ enable_shared_with_static_runtimes=yes
+ export_symbols_cmds='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGS] /s/.* \([^ ]*\)/\1 DATA/'\'' | $SED -e '\''/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
+ if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
+ archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--image-base=0x10000000 ${wl}--out-implib,$lib'
+ # If the export-symbols file already is a .def file (1st line
+ # is EXPORTS), use it as is; otherwise, prepend...
+ archive_expsym_cmds='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
+ cp $export_symbols $output_objdir/$soname.def;
+ else
+ echo EXPORTS > $output_objdir/$soname.def;
+ cat $export_symbols >> $output_objdir/$soname.def;
+ fi~
+ $CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--image-base=0x10000000 ${wl}--out-implib,$lib'
+ else
+ ld_shlibs=no
+ fi
+ netbsd*)
+ if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
+ archive_cmds='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
+ wlarc=
+ else
+ archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+ archive_expsym_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+ fi
+ solaris* | sysv5*)
+ if $LD -v 2>&1 | grep 'BFD 2\.8' > /dev/null; then
+ ld_shlibs=no
+ cat <<EOF 1>&2
+*** Warning: The releases 2.8.* of the GNU linker cannot reliably
+*** create shared libraries on Solaris systems. Therefore, libtool
+*** is disabling shared libraries support. We urge you to upgrade GNU
+*** binutils to release 2.9.1 or newer. Another option is to modify
+*** your PATH or compiler configuration so that the native linker is
+*** used, and then restart.
+EOF
+ elif $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+ else
+ ld_shlibs=no
+ fi
+ sunos4*)
+ archive_cmds='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+ wlarc=
+ hardcode_direct=yes
+ hardcode_shlibpath_var=no
+ linux*)
+ tmp_archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+ archive_cmds="$tmp_archive_cmds"
+ supports_anon_versioning=no
+ case `$LD -v 2>/dev/null` in
+ *\ 01.* | *\ 2.[0-9].* | *\ 2.10.*) ;; # catch versions < 2.11
+ *\ 2.11.93.0.2\ *) supports_anon_versioning=yes ;; # RH7.3 ...
+ *\ 2.11.92.0.12\ *) supports_anon_versioning=yes ;; # Mandrake 8.2 ...
+ *\ 2.11.*) ;; # other 2.11 versions
+ *) supports_anon_versioning=yes ;;
+ esac
+ if test $supports_anon_versioning = yes; then
+ archive_expsym_cmds='$echo "{ global:" > $output_objdir/$libname.ver~
+cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $output_objdir/$libname.ver~
+$echo "local: *; };" >> $output_objdir/$libname.ver~
+ $CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
+ else
+ archive_expsym_cmds="$tmp_archive_cmds"
+ fi
+ else
+ ld_shlibs=no
+ fi
+ else
+ ld_shlibs=no
+ fi
+ esac
+ if test "$ld_shlibs" = yes; then
+ runpath_var=LD_RUN_PATH
+ hardcode_libdir_flag_spec='${wl}--rpath ${wl}$libdir'
+ export_dynamic_flag_spec='${wl}--export-dynamic'
+ # ancient GNU ld didn't support --whole-archive et. al.
+ if $LD --help 2>&1 | grep 'no-whole-archive' > /dev/null; then
+ whole_archive_flag_spec="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
+ else
+ fi
+ fi
+ else
+ # PORTME fill in a description of your system's linker (not GNU ld)
+ case $host_os in
+ aix3*)
+ always_export_symbols=yes
+ archive_expsym_cmds='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
+ # Note: this linker hardcodes the directories in LIBPATH if there
+ # are no directories specified by -L.
+ if test "$GCC" = yes && test -z "$link_static_flag"; then
+ # Neither direct hardcoding nor static linking is supported with a
+ # broken collect2.
+ hardcode_direct=unsupported
+ fi
+ aix4* | aix5*)
+ # On IA64, the linker does run time linking by default, so we don't
+ # have to do anything special.
+ aix_use_runtimelinking=no
+ exp_sym_flag='-Bexport'
+ no_entry_flag=""
+ else
+ # If we're using GNU nm, then we don't want the "-C" option.
+ # -C means demangle to AIX nm, but means don't demangle with GNU nm
+ if $NM -V 2>&1 | grep 'GNU' > /dev/null; then
+ export_symbols_cmds='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+ else
+ export_symbols_cmds='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+ fi
+ # Test if we are trying to use run time linking or normal
+ # AIX style linking. If -brtl is somewhere in LDFLAGS, we
+ # need to do runtime linking.
+ case $host_os in aix4.[23]|aix4.[23].*|aix5*)
+ for ld_flag in $LDFLAGS; do
+ if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
+ aix_use_runtimelinking=yes
+ break
+ fi
+ done
+ esac
+ exp_sym_flag='-bexport'
+ no_entry_flag='-bnoentry'
+ fi
+ # When large executables or shared objects are built, AIX ld can
+ # have problems creating the table of contents. If linking a library
+ # or program results in "error TOC overflow" add -mminimal-toc to
+ # CXXFLAGS/CFLAGS for g++/gcc. In the cases where that is not
+ # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
+ archive_cmds=''
+ hardcode_libdir_separator=':'
+ link_all_deplibs=yes
+ if test "$GCC" = yes; then
+ case $host_os in aix4.012|aix4.012.*)
+ # We only want to do this on AIX 4.2 and lower, the check
+ # below for broken collect2 doesn't work under 4.3+
+ collect2name=`${CC} -print-prog-name=collect2`
+ if test -f "$collect2name" && \
+ strings "$collect2name" | grep resolve_lib_name >/dev/null
+ then
+ # We have reworked collect2
+ else
+ # We have old collect2
+ # It fails to find uninstalled libraries when the uninstalled
+ # path is not listed in the libpath. Setting hardcode_minus_L
+ # to unsupported forces relinking
+ fi
+ esac
+ shared_flag='-shared'
+ else
+ # not using gcc
+ # VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
+ # chokes on -Wl,-G. The following line is correct:
+ shared_flag='-G'
+ else
+ if test "$aix_use_runtimelinking" = yes; then
+ shared_flag='${wl}-G'
+ else
+ shared_flag='${wl}-bM:SRE'
+ fi
+ fi
+ fi
+ # It seems that -bexpall does not export symbols beginning with
+ # underscore (_), so it is better to generate a list of symbols to export.
+ # Warning - without using the other runtime loading flags (-brtl),
+ # -berok will link without error, but may produce a broken library.
+ allow_undefined_flag='-berok'
+ # Determine the default libpath from the value encoded in an empty executable.
/* confdefs.h. */
_ACEOF
@@ -5518,99 +7419,1276 @@
return 0;
_ACEOF
-if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
- (eval $ac_compile) 2>conftest.er1
ac_status=$?
rm -f conftest.er1
(eval $ac_try) 2>&5
ac_status=$?
- { ac_try='test -s conftest.$ac_objext'
(eval $ac_try) 2>&5
ac_status=$?
- case $host_os in
- hpux9* | hpux10* | hpux11*)
- # On HP-UX, both CC and GCC only warn that PIC is supported... then
- # they create non-PIC objects. So, if there were any warnings, we
- # assume that PIC is not supported.
- if test -s conftest.err; then
- lt_cv_prog_cc_pic_works=no
+aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
+# Check for a 64-bit object if we didn't find anything.
+if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
+}'`; fi
+else
+fi
+if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
+ hardcode_libdir_flag_spec='${wl}-blibpath:$libdir:'"$aix_libpath"
+ archive_expsym_cmds="\$CC"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols $shared_flag"
+ else
+ hardcode_libdir_flag_spec='${wl}-R $libdir:/usr/lib:/lib'
+ allow_undefined_flag="-z nodefs"
+ archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols"
else
- lt_cv_prog_cc_pic_works=yes
+/* confdefs.h. */
+_ACEOF
+int
+main ()
+ return 0;
+_ACEOF
+ ac_status=$?
+ echo "$as_me:$LINENO: \$? = $ac_status" >&5
+ ac_status=$?
+ ac_status=$?
+}'`; fi
+else
+fi
+ # Warning - without using the other run time loading flags,
+ no_undefined_flag=' ${wl}-bernotok'
+ allow_undefined_flag=' ${wl}-berok'
+ # -bexpall does not export symbols beginning with underscore (_)
+ # Exported symbols can be pulled into shared objects from archives
+ whole_archive_flag_spec=' '
+ archive_cmds_need_lc=yes
+ # This is similar to how AIX traditionally builds it's shared libraries.
+ archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${wl}-bE:$export_symbols ${wl}-bnoentry${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
fi
+ fi
+ amigaos*)
+ # see comment about different semantics on the GNU ld section
+ ld_shlibs=no
+ bsdi4*)
+ export_dynamic_flag_spec=-rdynamic
+ # hardcode_libdir_flag_spec is actually meaningless, as there is
+ # no search path for DLLs.
+ hardcode_libdir_flag_spec=' '
+ # Tell ltmain to make .lib files, not .a files.
+ libext=lib
+ # Tell ltmain to make .dll files, not .so files.
+ shrext_cmds=".dll"
+ # FIXME: Setting linknames here is a bad hack.
+ archive_cmds='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | $SED -e '\''s/ -lc$//'\''` -link -dll~linknames='
+ # The linker will automatically build a .lib file if we build a DLL.
+ old_archive_From_new_cmds='true'
+ # FIXME: Should let the user specify the lib program.
+ old_archive_cmds='lib /OUT:$oldlib$oldobjs$old_deplibs'
+ fix_srcfile_path='`cygpath -w "$srcfile"`'
+ darwin* | rhapsody*)
+ if test "$GXX" = yes ; then
+ archive_cmds_need_lc=no
+ case "$host_os" in
+ rhapsody* | darwin1.[012])
+ allow_undefined_flag='-undefined suppress'
+ *) # Darwin 1.3 on
+ if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
+ allow_undefined_flag='-flat_namespace -undefined suppress'
+ else
+ case ${MACOSX_DEPLOYMENT_TARGET} in
+ 10.[012])
+ 10.*)
+ allow_undefined_flag='-undefined dynamic_lookup'
+ esac
+ fi
esac
+ lt_int_apple_cc_single_mod=no
+ output_verbose_link_cmd='echo'
+ if $CC -dumpspecs 2>&1 | grep 'single_module' >/dev/null ; then
+ lt_int_apple_cc_single_mod=yes
+ fi
+ if test "X$lt_int_apple_cc_single_mod" = Xyes ; then
+ archive_cmds='$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+ else
+ archive_cmds='$CC -r ${wl}-bind_at_load -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+ fi
+ module_cmds='$CC ${wl}-bind_at_load $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
+ # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin ld's
+ archive_expsym_cmds='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+ else
+ archive_expsym_cmds='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -r ${wl}-bind_at_load -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+ fi
+ module_expsym_cmds='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+ hardcode_automatic=yes
+ whole_archive_flag_spec='-all_load $convenience'
+ else
+ ld_shlibs=no
+ fi
-else
+ dgux*)
+ archive_cmds='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
+ freebsd1*)
+ ld_shlibs=no
+ # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
+ # support. Future versions do this automatically, but an explicit c++rt0.o
+ # does not break anything, and helps significantly (at the cost of a little
+ # extra space).
+ freebsd2.2*)
+ archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
+ hardcode_libdir_flag_spec='-R$libdir'
+ # Unfortunately, older versions of FreeBSD 2 do not have this feature.
+ freebsd2*)
+ archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+ # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
+ freebsd* | kfreebsd*-gnu)
+ archive_cmds='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
+ hpux9*)
+ archive_cmds='$rm $output_objdir/$soname~$CC -shared -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $libobjs $deplibs $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+ else
+ archive_cmds='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+ fi
+ hardcode_libdir_flag_spec='${wl}+b ${wl}$libdir'
+ hardcode_libdir_separator=:
+ # hardcode_minus_L: Not really in the search PATH,
+ # but as the default location of the library.
+ export_dynamic_flag_spec='${wl}-E'
+ hpux10* | hpux11*)
+ if test "$GCC" = yes -a "$with_gnu_ld" = no; then
+ case "$host_cpu" in
+ hppa*64*|ia64*)
+ archive_cmds='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ archive_cmds='$CC -shared -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+ esac
+ else
+ hppa*64*|ia64*)
+ archive_cmds='$LD -b +h $soname -o $lib $libobjs $deplibs $linker_flags'
+ archive_cmds='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
+ esac
+ fi
+ if test "$with_gnu_ld" = no; then
+ hppa*64*)
+ hardcode_libdir_flag_spec_ld='+b $libdir'
+ ia64*)
+ esac
+ fi
+ irix5* | irix6* | nonstopux*)
+ archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+ else
+ archive_cmds='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+ hardcode_libdir_flag_spec_ld='-rpath $libdir'
+ fi
+ hardcode_libdir_flag_spec='${wl}-rpath ${wl}$libdir'
+ netbsd*)
+ archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags' # a.out
+ else
+ archive_cmds='$LD -shared -o $lib $libobjs $deplibs $linker_flags' # ELF
+ fi
+ newsos6)
+ openbsd*)
+ if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
+ archive_cmds='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
+ hardcode_libdir_flag_spec='${wl}-rpath,$libdir'
+ else
+ case $host_os in
+ openbsd[01].* | openbsd2.[0-7] | openbsd2.[0-7].*)
+ esac
+ fi
+ os2*)
+ archive_cmds='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
+ old_archive_From_new_cmds='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
+ osf3*)
+ allow_undefined_flag=' ${wl}-expect_unresolved ${wl}\*'
+ archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+ else
+ allow_undefined_flag=' -expect_unresolved \*'
+ archive_cmds='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+ fi
+ osf4* | osf5*) # as osf3* with the addition of -msym flag
+ archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+ else
+ archive_cmds='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+ archive_expsym_cmds='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
+ $LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${objdir}/so_locations -o $lib~$rm $lib.exp'
+ # Both c and cxx compiler support -rpath directly
+ hardcode_libdir_flag_spec='-rpath $libdir'
+ fi
+ sco3.2v5*)
+ export_dynamic_flag_spec='${wl}-Bexport'
+ hardcode_runpath_var=yes
+ solaris*)
+ no_undefined_flag=' -z text'
+ archive_cmds='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ archive_expsym_cmds='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
+ $CC -shared ${wl}-M ${wl}$lib.exp ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags~$rm $lib.exp'
+ else
+ archive_cmds='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
+ $LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
+ fi
+ case $host_os in
+ solaris2.[0-5] | solaris2.[0-5].*) ;;
+ *) # Supported since Solaris 2.6 (maybe 2.5.1?)
+ whole_archive_flag_spec='-z allextract$convenience -z defaultextract' ;;
+ esac
+ sunos4*)
+ if test "x$host_vendor" = xsequent; then
+ # Use $CC to link under sequent, because it throws in some extra .o
+ # files that make .init and .fini sections work.
+ archive_cmds='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
+ else
+ archive_cmds='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
+ fi
+ sysv4)
+ case $host_vendor in
+ sni)
+ hardcode_direct=yes # is this really true???
+ siemens)
+ ## LD is ld it makes a PLAMLIB
+ ## CC just makes a GrossModule.
+ archive_cmds='$LD -G -o $lib $libobjs $deplibs $linker_flags'
+ reload_cmds='$CC -r -o $output$reload_objs'
+ motorola)
+ hardcode_direct=no #Motorola manual says yes, but my tests say they lie
+ esac
+ runpath_var='LD_RUN_PATH'
+ sysv4.3*)
+ export_dynamic_flag_spec='-Bexport'
+ sysv4*MP*)
+ if test -d /usr/nec; then
+ ld_shlibs=yes
+ fi
+ sysv4.2uw2*)
+ sysv5OpenUNIX8* | sysv5UnixWare7* | sysv5uw[78]* | unixware7*)
+ no_undefined_flag='${wl}-z ${wl}text'
+ else
+ archive_cmds='$CC -G ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ fi
+ sysv5*)
+ # $CC -shared without GNU ld will not create a library from C++
+ # object files and a static libstdc++, better avoid it by now
+ uts4*)
+ ld_shlibs=no
+ esac
+ fi
+echo "$as_me:$LINENO: result: $ld_shlibs" >&5
+echo "${ECHO_T}$ld_shlibs" >&6
+test "$ld_shlibs" = no && can_build_shared=no
+variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
+ variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
fi
-rm -f conftest.err conftest.$ac_objext conftest.$ac_ext
- CFLAGS="$save_CFLAGS"
+# Do we need to explicitly link libc?
+case "x$archive_cmds_need_lc" in
+x|xyes)
+ # Assume -lc should be added
+ if test "$enable_shared" = yes && test "$GCC" = yes; then
+ case $archive_cmds in
+ # FIXME: we may have to deal with multi-command sequences.
+ '$CC '*)
+ # Test whether the compiler implicitly links with -lc since on some
+ # systems, -lgcc has to come before -lc. If gcc already passes -lc
+ # to ld, don't add -lc before -lgcc.
+ echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
+echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
+ $rm conftest*
+ if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+ (eval $ac_compile) 2>&5
+ ac_status=$?
+ (exit $ac_status); } 2>conftest.err; then
+ soname=conftest
+ lib=conftest
+ libobjs=conftest.$ac_objext
+ deplibs=
+ wl=$lt_prog_compiler_wl
+ compiler_flags=-v
+ linker_flags=-v
+ verstring=
+ output_objdir=.
+ libname=conftest
+ lt_save_allow_undefined_flag=$allow_undefined_flag
+ if { (eval echo "$as_me:$LINENO: \"$archive_cmds 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
+ (eval $archive_cmds 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
+ ac_status=$?
+ then
+ else
+ fi
+ allow_undefined_flag=$lt_save_allow_undefined_flag
+ else
+ fi
+ $rm conftest*
+ echo "$as_me:$LINENO: result: $archive_cmds_need_lc" >&5
+echo "${ECHO_T}$archive_cmds_need_lc" >&6
+ esac
+ fi
+esac
+echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
+echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
+library_names_spec=
+libname_spec='lib$name'
+soname_spec=
+shrext_cmds=".so"
+postinstall_cmds=
+postuninstall_cmds=
+finish_cmds=
+finish_eval=
+shlibpath_var=
+shlibpath_overrides_runpath=unknown
+version_type=none
+dynamic_linker="$host_os ld.so"
+sys_lib_dlsearch_path_spec="/lib /usr/lib"
+ sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
+ if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
+ # if the path contains ";" then we assume it to be the separator
+ # otherwise default to the standard path separator (i.e. ":") - it is
+ # assumed that no part of a normal pathname contains ";" but that should
+ # okay in the real world where ";" in dirpaths is itself problematic.
+ sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
+ else
+ sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
+ fi
+else
+ sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
fi
+need_lib_prefix=unknown
+hardcode_into_libs=no
+# when you set need_version to no, make sure it does not cause -set_version
+# flags to be left without arguments
+need_version=unknown
- if test "X$lt_cv_prog_cc_pic_works" = Xno; then
+case $host_os in
+aix3*)
+ version_type=linux
+ library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
+ shlibpath_var=LIBPATH
+ # AIX 3 has no versioning support, so we append a major version to the name.
+ soname_spec='${libname}${release}${shared_ext}$major'
+aix4* | aix5*)
+ need_lib_prefix=no
+ need_version=no
+ hardcode_into_libs=yes
+ # AIX 5 supports IA64
+ library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
+ shlibpath_var=LD_LIBRARY_PATH
else
- lt_cv_prog_cc_pic=" $lt_cv_prog_cc_pic"
+ # With GCC up to 2.95.x, collect2 would create an import file
+ # for dependence libraries. The import file would start with
+ # the line `#! .'. This would cause the generated library to
+ # depend on `.', always an invalid library. This was fixed in
+ # development snapshots of GCC prior to 3.0.
+ case $host_os in
+ aix4 | aix4.[01] | aix4.[01].*)
+ if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
+ echo ' yes '
+ echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
+ else
+ can_build_shared=no
+ fi
+ esac
+ # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
+ # soname into executable. Probably we can add versioning support to
+ # collect2, so additional links can be useful in future.
+ # If using run time linking (on AIX 4.2 or later) use lib<name>.so
+ # instead of lib<name>.a to let people know that these are not
+ # typical AIX shared libraries.
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
+ else
+ # We preserve .a as extension for shared libraries through AIX4.2
+ # and later when we are not doing run time linking.
+ library_names_spec='${libname}${release}.a $libname.a'
+ fi
fi
- echo "$as_me:$LINENO: result: $lt_cv_prog_cc_pic_works" >&5
-echo "${ECHO_T}$lt_cv_prog_cc_pic_works" >&6
-fi
+amigaos*)
+ library_names_spec='$libname.ixlibrary $libname.a'
+ # Create ${libname}_ixlibrary.a entries in /sys/libs.
+ finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
-# Check for any special shared library compilation flags.
-if test -n "$lt_cv_prog_cc_shlib"; then
- { echo "$as_me:$LINENO: WARNING: \`$CC' requires \`$lt_cv_prog_cc_shlib' to build shared libraries" >&5
-echo "$as_me: WARNING: \`$CC' requires \`$lt_cv_prog_cc_shlib' to build shared libraries" >&2;}
- if echo "$old_CC $old_CFLAGS " | egrep -e "[ ]$lt_cv_prog_cc_shlib[ ]" >/dev/null; then :
+beos*)
+ library_names_spec='${libname}${shared_ext}'
+ dynamic_linker="$host_os ld.so"
+ shlibpath_var=LIBRARY_PATH
+bsdi4*)
+ need_version=no
+ finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
+ sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
+ sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
+ # the default ld.so.conf also contains /usr/contrib/lib and
+ # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
+ # libtool to hard-code these into programs
+ version_type=windows
+ need_version=no
+ case $GCC,$host_os in
+ yes,cygwin* | yes,mingw* | yes,pw32*)
+ library_names_spec='$libname.dll.a'
+ # DLL is installed to $(libdir)/../bin by postinstall_cmds
+ postinstall_cmds='base_file=`basename \${file}`~
+ dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
+ dldir=$destdir/`dirname \$dlpath`~
+ test -d \$dldir || mkdir -p \$dldir~
+ $install_prog $dir/$dlname \$dldir/$dlname'
+ postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
+ dlpath=$dir/\$dldll~
+ $rm \$dlpath'
+ shlibpath_overrides_runpath=yes
+ case $host_os in
+ cygwin*)
+ # Cygwin DLLs use 'cyg' prefix rather than 'lib'
+ soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+ sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
+ mingw*)
+ # MinGW DLLs use traditional 'lib' prefix
+ soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+ if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
+ # It is most probably a Windows format PATH printed by
+ # mingw gcc, but we are running on Cygwin. Gcc prints its search
+ # path with ; separators, and with drive letters. We can handle the
+ # drive letters (cygwin fileutils understands them), so leave them,
+ # especially as we might pass files found there to a mingw objdump,
+ # which wouldn't understand a cygwinified path. Ahh.
+ else
+ fi
+ pw32*)
+ # pw32 DLLs use 'pw' prefix rather than 'lib'
+ library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/./-/g'`${versuffix}${shared_ext}'
+ esac
+ library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
+ esac
+ dynamic_linker='Win32 ld.exe'
+ # FIXME: first we should search . and the directory the executable is in
+ shlibpath_var=PATH
+darwin* | rhapsody*)
+ dynamic_linker="$host_os dyld"
+ version_type=darwin
+ need_version=no
+ library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
+ soname_spec='${libname}${release}${major}$shared_ext'
+ shlibpath_var=DYLD_LIBRARY_PATH
+ shrext_cmds='$(test .$module = .yes && echo .so || echo .dylib)'
+ # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
+ sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
else
- { echo "$as_me:$LINENO: WARNING: add \`$lt_cv_prog_cc_shlib' to the CC or CFLAGS env variable and reconfigure" >&5
-echo "$as_me: WARNING: add \`$lt_cv_prog_cc_shlib' to the CC or CFLAGS env variable and reconfigure" >&2;}
+ sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
fi
+ sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
+dgux*)
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
+freebsd1*)
+ dynamic_linker=no
+kfreebsd*-gnu)
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
+ shlibpath_overrides_runpath=no
+ dynamic_linker='GNU ld.so'
+freebsd*)
+ objformat=`test -x /usr/bin/objformat && /usr/bin/objformat || echo aout`
+ version_type=freebsd-$objformat
+ case $version_type in
+ freebsd-elf*)
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
+ need_version=no
+ freebsd-*)
+ library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
+ need_version=yes
+ esac
+ case $host_os in
+ freebsd2*)
+ freebsd3.01* | freebsdelf3.01*)
+ *) # from 3.2 on
+ esac
+gnu*)
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
+hpux9* | hpux10* | hpux11*)
+ # Give a soname corresponding to the major version so that dld.sl refuses to
+ # link against other versions.
+ version_type=sunos
+ need_version=no
+ ia64*)
+ shrext_cmds='.so'
+ dynamic_linker="$host_os dld.so"
+ shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
+ if test "X$HPUX_IA64_MODE" = X32; then
+ sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
+ else
+ sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
+ fi
+ sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
+ hppa*64*)
+ shrext_cmds='.sl'
+ dynamic_linker="$host_os dld.sl"
+ shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
+ sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
+ shrext_cmds='.sl'
+ shlibpath_var=SHLIB_PATH
+ shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
+ esac
+ # HP-UX runs *really* slowly unless shared libraries are mode 555.
+ postinstall_cmds='chmod 555 $lib'
+irix5* | irix6* | nonstopux*)
+ case $host_os in
+ nonstopux*) version_type=nonstopux ;;
+ if test "$lt_cv_prog_gnu_ld" = yes; then
+ else
+ version_type=irix
+ fi ;;
+ esac
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
+ case $host_os in
+ irix5* | nonstopux*)
+ libsuff= shlibsuff=
+ case $LD in # libtool.m4 will add one of these switches to LD
+ *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
+ libsuff= shlibsuff= libmagic=32-bit;;
+ *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
+ libsuff=32 shlibsuff=N32 libmagic=N32;;
+ *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
+ libsuff=64 shlibsuff=64 libmagic=64-bit;;
+ *) libsuff= shlibsuff= libmagic=never-match;;
+ esac
+ esac
+ shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
+ sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
+ sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
+# No shared lib support for Linux oldld, aout, or coff.
+linux*oldld* | linux*aout* | linux*coff*)
+ dynamic_linker=no
+# This must be Linux ELF.
+linux*)
+ need_version=no
+ finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
+ # This implies no fast_install, which is unacceptable.
+ # Some rework will be needed to allow for fast_install
+ # before this can be enabled.
+ # find out which ABI we are using
+ libsuff=
+ x86_64*|s390x*|powerpc64*)
+ echo '#line 8374 "configure"' > conftest.$ac_ext
+ ac_status=$?
+ (exit $ac_status); }; then
+ case `/usr/bin/file conftest.$ac_objext` in
+ *64-bit*)
+ libsuff=64
+ sys_lib_search_path_spec="/lib${libsuff} /usr/lib${libsuff} /usr/local/lib${libsuff}"
+ esac
+ fi
+ rm -rf conftest*
+ esac
+ # Append ld.so.conf contents to the search path
+ if test -f /etc/ld.so.conf; then
+ lt_ld_extra=`$SED -e 's/:,\t/ /g;s/=^=*$//;s/=^= * / /g' /etc/ld.so.conf | tr '\n' ' '`
+ sys_lib_dlsearch_path_spec="/lib${libsuff} /usr/lib${libsuff} $lt_ld_extra"
+ fi
+ # We used to test for /lib/ld.so.1 and disable shared libraries on
+ # powerpc, because MkLinux only supported shared libraries with the
+ # GNU dynamic linker. Since this was broken with cross compilers,
+ # most powerpc-linux boxes support dynamic linking these days and
+ # people can always --disable-shared, the test was removed, and we
+ # assume the GNU/Linux dynamic linker is in use.
+ dynamic_linker='GNU/Linux ld.so'
+knetbsd*-gnu)
+ need_version=no
+netbsd*)
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
+ finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
+ dynamic_linker='NetBSD (a.out) ld.so'
+ else
+ dynamic_linker='NetBSD ld.elf_so'
+ fi
+newsos6)
+nto-qnx*)
+ need_version=no
+openbsd*)
+ need_version=yes
+ case $host_os in
+ openbsd2.[89] | openbsd2.[89].*)
+ esac
+ else
+ fi
+os2*)
+ libname_spec='$name'
+ library_names_spec='$libname${shared_ext} $libname.a'
+ dynamic_linker='OS/2 ld.exe'
+osf3* | osf4* | osf5*)
+ version_type=osf
+ need_version=no
+ sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
+ sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
+sco3.2v5*)
+ version_type=osf
+solaris*)
+ need_version=no
+ # ldd complains unless libraries are executable
+ postinstall_cmds='chmod +x $lib'
+sunos4*)
+ finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
+ fi
+ need_version=yes
+sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
+ sni)
+ export_dynamic_flag_spec='${wl}-Blargedynsym'
+ siemens)
+ motorola)
+ need_version=no
+ sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
+ esac
+sysv4*MP*)
+ if test -d /usr/nec ;then
+ library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
+ soname_spec='$libname${shared_ext}.$major'
+ fi
+uts4*)
+ dynamic_linker=no
+esac
+echo "$as_me:$LINENO: result: $dynamic_linker" >&5
+echo "${ECHO_T}$dynamic_linker" >&6
+test "$dynamic_linker" = no && can_build_shared=no
+echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
+echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
+hardcode_action=
+if test -n "$hardcode_libdir_flag_spec" || \
+ test -n "$runpath_var " || \
+ test "X$hardcode_automatic"="Xyes" ; then
+ # We can hardcode non-existant directories.
+ if test "$hardcode_direct" != no &&
+ # If the only mechanism to avoid hardcoding is shlibpath_var, we
+ # have to relink, otherwise we might link with an installed library
+ # when we should be linking with a yet-to-be-installed one
+ ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, )" != no &&
+ test "$hardcode_minus_L" != no; then
+ # Linking always hardcodes the temporary library directory.
+ hardcode_action=relink
+ else
+ # We can link without hardcoding, and we can hardcode nonexisting dirs.
+ hardcode_action=immediate
+ fi
+else
+ # We cannot hardcode anything, or else we can only hardcode existing
+ # directories.
+ hardcode_action=unsupported
fi
+echo "$as_me:$LINENO: result: $hardcode_action" >&5
+echo "${ECHO_T}$hardcode_action" >&6
-echo "$as_me:$LINENO: checking if $compiler static flag $lt_cv_prog_cc_static works" >&5
-echo $ECHO_N "checking if $compiler static flag $lt_cv_prog_cc_static works... $ECHO_C" >&6
-if test "${lt_cv_prog_cc_static_works+set}" = set; then
+if test "$hardcode_action" = relink; then
+ # Fast installation is not supported
+ enable_fast_install=no
+elif test "$shlibpath_overrides_runpath" = yes ||
+ test "$enable_shared" = no; then
+ # Fast installation is not necessary
+ enable_fast_install=needless
+fi
+striplib=
+old_striplib=
+echo "$as_me:$LINENO: checking whether stripping libraries is possible" >&5
+echo $ECHO_N "checking whether stripping libraries is possible... $ECHO_C" >&6
+if test -n "$STRIP" && $STRIP -V 2>&1 | grep "GNU strip" >/dev/null; then
+ test -z "$old_striplib" && old_striplib="$STRIP --strip-debug"
+ test -z "$striplib" && striplib="$STRIP --strip-unneeded"
+ echo "$as_me:$LINENO: result: yes" >&5
+echo "${ECHO_T}yes" >&6
+else
+# FIXME - insert some real tests, host_os isn't really good enough
+ case $host_os in
+ darwin*)
+ if test -n "$STRIP" ; then
+ striplib="$STRIP -x"
+ else
+fi
+ esac
+fi
+if test "x$enable_dlopen" != xyes; then
+ enable_dlopen=unknown
+ enable_dlopen_self=unknown
+ enable_dlopen_self_static=unknown
+else
+ lt_cv_dlopen=no
+ lt_cv_dlopen_libs=
+ case $host_os in
+ beos*)
+ lt_cv_dlopen="load_add_on"
+ lt_cv_dlopen_self=yes
+ mingw* | pw32*)
+ lt_cv_dlopen="LoadLibrary"
+ cygwin*)
+ lt_cv_dlopen="dlopen"
+ darwin*)
+ # if libdl is installed we need to link against it
+ echo "$as_me:$LINENO: checking for dlopen in -ldl" >&5
+echo $ECHO_N "checking for dlopen in -ldl... $ECHO_C" >&6
+if test "${ac_cv_lib_dl_dlopen+set}" = set; then
else
- lt_cv_prog_cc_static_works=no
- save_LDFLAGS="$LDFLAGS"
- LDFLAGS="$LDFLAGS $lt_cv_prog_cc_static"
- cat >conftest.$ac_ext <<_ACEOF
+ ac_check_lib_save_LIBS=$LIBS
+LIBS="-ldl $LIBS"
+cat >conftest.$ac_ext <<_ACEOF
/* confdefs.h. */
_ACEOF
cat confdefs.h >>conftest.$ac_ext
cat >>conftest.$ac_ext <<_ACEOF
/* end confdefs.h. */
+/* Override any gcc2 internal prototype to avoid an error. */
+#ifdef __cplusplus
+extern "C"
+#endif
+/* We use char because int might match the return type of a gcc2
+ builtin and then its argument prototype would still apply. */
+char dlopen ();
int
main ()
+dlopen ();
return 0;
@@ -5624,7 +8702,7 @@
cat conftest.err >&5
(exit $ac_status); } &&
- { ac_try='test -z "$ac_cxx_werror_flag"
+ { ac_try='test -z "$ac_c_werror_flag"
|| test ! -s conftest.err'
{ (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
(eval $ac_try) 2>&5
@@ -5637,514 +8715,1595 @@
ac_status=$?
(exit $ac_status); }; }; then
- lt_cv_prog_cc_static_works=yes
+ ac_cv_lib_dl_dlopen=yes
else
echo "$as_me: failed program was:" >&5
sed 's/^/| /' conftest.$ac_ext >&5
+ac_cv_lib_dl_dlopen=no
fi
rm -f conftest.err conftest.$ac_objext \
conftest$ac_exeext conftest.$ac_ext
- LDFLAGS="$save_LDFLAGS"
+LIBS=$ac_check_lib_save_LIBS
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_dl_dlopen" >&5
+echo "${ECHO_T}$ac_cv_lib_dl_dlopen" >&6
+if test $ac_cv_lib_dl_dlopen = yes; then
+ lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-ldl"
+else
+ lt_cv_dlopen="dyld"
fi
-# Belt *and* braces to stop my trousers falling down:
-test "X$lt_cv_prog_cc_static_works" = Xno && lt_cv_prog_cc_static=
-echo "$as_me:$LINENO: result: $lt_cv_prog_cc_static_works" >&5
-echo "${ECHO_T}$lt_cv_prog_cc_static_works" >&6
+ echo "$as_me:$LINENO: checking for shl_load" >&5
+echo $ECHO_N "checking for shl_load... $ECHO_C" >&6
+if test "${ac_cv_func_shl_load+set}" = set; then
+else
+ cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h. */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h. */
+/* Define shl_load to an innocuous variant, in case <limits.h> declares shl_load.
+ For example, HP-UX 11i <limits.h> declares gettimeofday. */
+#define shl_load innocuous_shl_load
-pic_flag="$lt_cv_prog_cc_pic"
-special_shlib_compile_flags="$lt_cv_prog_cc_shlib"
-wl="$lt_cv_prog_cc_wl"
-link_static_flag="$lt_cv_prog_cc_static"
-no_builtin_flag="$lt_cv_prog_cc_no_builtin"
-can_build_shared="$lt_cv_prog_cc_can_build_shared"
+/* System header to define __stub macros and hopefully few prototypes,
+ which can conflict with char shl_load (); below.
+ Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
+ <limits.h> exists even on freestanding compilers. */
+#ifdef __STDC__
+# include <limits.h>
+#else
+# include <assert.h>
+#endif
-# Check to see if options -o and -c are simultaneously supported by compiler
-echo "$as_me:$LINENO: checking if $compiler supports -c -o file.$ac_objext" >&5
-echo $ECHO_N "checking if $compiler supports -c -o file.$ac_objext... $ECHO_C" >&6
-if test "${lt_cv_compiler_c_o+set}" = set; then
+#undef shl_load
+#ifdef __cplusplus
+extern "C"
+#endif
+char shl_load ();
+/* The GNU C library defines this for functions which it implements
+ to always fail with ENOSYS. Some functions are actually named
+ something starting with __ and the normal name is an alias. */
+#if defined (__stub_shl_load) || defined (__stub___shl_load)
+choke me
+#else
+char (*f) () = shl_load;
+#endif
+#ifdef __cplusplus
+#endif
+int
+main ()
+return f != shl_load;
+ return 0;
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+ (eval $ac_link) 2>conftest.er1
+ ac_status=$?
+ grep -v '^ *+' conftest.er1 >conftest.err
+ rm -f conftest.er1
+ cat conftest.err >&5
+ (exit $ac_status); } &&
+ || test ! -s conftest.err'
+ { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+ (eval $ac_try) 2>&5
+ ac_status=$?
+ (exit $ac_status); }; } &&
+ { ac_try='test -s conftest$ac_exeext'
+ ac_status=$?
+ (exit $ac_status); }; }; then
+ ac_cv_func_shl_load=yes
+else
+ echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+ac_cv_func_shl_load=no
+fi
+rm -f conftest.err conftest.$ac_objext \
+ conftest$ac_exeext conftest.$ac_ext
+fi
+echo "$as_me:$LINENO: result: $ac_cv_func_shl_load" >&5
+echo "${ECHO_T}$ac_cv_func_shl_load" >&6
+if test $ac_cv_func_shl_load = yes; then
+ lt_cv_dlopen="shl_load"
+else
+ echo "$as_me:$LINENO: checking for shl_load in -ldld" >&5
+echo $ECHO_N "checking for shl_load in -ldld... $ECHO_C" >&6
+if test "${ac_cv_lib_dld_shl_load+set}" = set; then
echo $ECHO_N "(cached) $ECHO_C" >&6
else
+LIBS="-ldld $LIBS"
+/* confdefs.h. */
+_ACEOF
-$rm -r conftest 2>/dev/null
-mkdir conftest
-cd conftest
-echo "int some_variable = 0;" > conftest.$ac_ext
-mkdir out
-# According to Tom Tromey, Ian Lance Taylor reported there are C compilers
-# that will create temporary files in the current directory regardless of
-# the output directory. Thus, making CWD read-only will cause this test
-# to fail, enabling locking or at least warning the user not to do parallel
-# builds.
-chmod -w .
-save_CFLAGS="$CFLAGS"
-CFLAGS="$CFLAGS -o out/conftest2.$ac_objext"
-compiler_c_o=no
-if { (eval echo configure:5687: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>out/conftest.err; } && test -s out/conftest2.$ac_objext; then
- # The compiler can only warn and ignore the option if not recognized
- # So say no if there are warnings
- if test -s out/conftest.err; then
- lt_cv_compiler_c_o=no
- else
- lt_cv_compiler_c_o=yes
- fi
+#ifdef __cplusplus
+extern "C"
+#endif
+char shl_load ();
+int
+main ()
+shl_load ();
+ return 0;
+_ACEOF
+ ac_status=$?
+ ac_status=$?
+ ac_status=$?
+ ac_cv_lib_dld_shl_load=yes
else
- # Append any errors to the config.log.
- cat out/conftest.err 1>&5
-fi
-CFLAGS="$save_CFLAGS"
-chmod u+w .
-$rm conftest* out/*
-rmdir out
-cd ..
-rmdir conftest
+ac_cv_lib_dld_shl_load=no
fi
-compiler_c_o=$lt_cv_compiler_c_o
-echo "$as_me:$LINENO: result: $compiler_c_o" >&5
-echo "${ECHO_T}$compiler_c_o" >&6
-if test x"$compiler_c_o" = x"yes"; then
- # Check to see if we can write to a .lo
- echo "$as_me:$LINENO: checking if $compiler supports -c -o file.lo" >&5
-echo $ECHO_N "checking if $compiler supports -c -o file.lo... $ECHO_C" >&6
- if test "${lt_cv_compiler_o_lo+set}" = set; then
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_dld_shl_load" >&5
+echo "${ECHO_T}$ac_cv_lib_dld_shl_load" >&6
+if test $ac_cv_lib_dld_shl_load = yes; then
+ lt_cv_dlopen="shl_load" lt_cv_dlopen_libs="-dld"
+else
+ echo "$as_me:$LINENO: checking for dlopen" >&5
+echo $ECHO_N "checking for dlopen... $ECHO_C" >&6
+if test "${ac_cv_func_dlopen+set}" = set; then
else
- lt_cv_compiler_o_lo=no
- save_CFLAGS="$CFLAGS"
- CFLAGS="$CFLAGS -c -o conftest.lo"
- save_objext="$ac_objext"
- ac_objext=lo
/* confdefs.h. */
_ACEOF
+/* Define dlopen to an innocuous variant, in case <limits.h> declares dlopen.
+#define dlopen innocuous_dlopen
+ which can conflict with char dlopen (); below.
+#ifdef __STDC__
+#else
+#endif
+#undef dlopen
+#ifdef __cplusplus
+extern "C"
+#endif
+char dlopen ();
+#if defined (__stub_dlopen) || defined (__stub___dlopen)
+choke me
+#else
+char (*f) () = dlopen;
+#endif
+#ifdef __cplusplus
+#endif
int
main ()
-int some_variable = 0;
+return f != dlopen;
return 0;
_ACEOF
-rm -f conftest.$ac_objext
ac_status=$?
rm -f conftest.er1
(eval $ac_try) 2>&5
ac_status=$?
(eval $ac_try) 2>&5
ac_status=$?
- else
- lt_cv_compiler_o_lo=yes
- fi
+ ac_cv_func_dlopen=yes
else
+ac_cv_func_dlopen=no
fi
- ac_objext="$save_objext"
fi
+echo "$as_me:$LINENO: result: $ac_cv_func_dlopen" >&5
+echo "${ECHO_T}$ac_cv_func_dlopen" >&6
+if test $ac_cv_func_dlopen = yes; then
+else
+ echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+LIBS="-ldl $LIBS"
+/* confdefs.h. */
+_ACEOF
- compiler_o_lo=$lt_cv_compiler_o_lo
- echo "$as_me:$LINENO: result: $compiler_o_lo" >&5
-echo "${ECHO_T}$compiler_o_lo" >&6
+#ifdef __cplusplus
+extern "C"
+#endif
+char dlopen ();
+int
+main ()
+dlopen ();
+ return 0;
+_ACEOF
+ ac_status=$?
+ ac_status=$?
+ ac_status=$?
else
- compiler_o_lo=no
fi
+fi
+else
+ echo "$as_me:$LINENO: checking for dlopen in -lsvld" >&5
+echo $ECHO_N "checking for dlopen in -lsvld... $ECHO_C" >&6
+if test "${ac_cv_lib_svld_dlopen+set}" = set; then
+else
+LIBS="-lsvld $LIBS"
+/* confdefs.h. */
+_ACEOF
-# Check to see if we can do hard links to lock some files if needed
-hard_links="nottested"
-if test "$compiler_c_o" = no && test "$need_locks" != no; then
- # do not overwrite the value of need_locks provided by the user
- echo "$as_me:$LINENO: checking if we can lock with hard links" >&5
-echo $ECHO_N "checking if we can lock with hard links... $ECHO_C" >&6
- hard_links=yes
- $rm conftest*
- ln conftest.a conftest.b 2>/dev/null && hard_links=no
- touch conftest.a
- ln conftest.a conftest.b 2>&5 || hard_links=no
- echo "$as_me:$LINENO: result: $hard_links" >&5
-echo "${ECHO_T}$hard_links" >&6
- if test "$hard_links" = no; then
- { echo "$as_me:$LINENO: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
-echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
- need_locks=warn
- fi
+#ifdef __cplusplus
+extern "C"
+#endif
+char dlopen ();
+int
+main ()
+dlopen ();
+ return 0;
+_ACEOF
+ ac_status=$?
+ ac_status=$?
+ ac_status=$?
+ ac_cv_lib_svld_dlopen=yes
else
- need_locks=no
+ac_cv_lib_svld_dlopen=no
fi
-if test "$GCC" = yes; then
- # Check to see if options -fno-rtti -fno-exceptions are supported by compiler
- echo "$as_me:$LINENO: checking if $compiler supports -fno-rtti -fno-exceptions" >&5
-echo $ECHO_N "checking if $compiler supports -fno-rtti -fno-exceptions... $ECHO_C" >&6
- echo "int some_variable = 0;" > conftest.$ac_ext
- CFLAGS="$CFLAGS -fno-rtti -fno-exceptions -c conftest.$ac_ext"
- compiler_rtti_exceptions=no
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_svld_dlopen" >&5
+echo "${ECHO_T}$ac_cv_lib_svld_dlopen" >&6
+if test $ac_cv_lib_svld_dlopen = yes; then
+ lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-lsvld"
+else
+ echo "$as_me:$LINENO: checking for dld_link in -ldld" >&5
+echo $ECHO_N "checking for dld_link in -ldld... $ECHO_C" >&6
+if test "${ac_cv_lib_dld_dld_link+set}" = set; then
+else
+LIBS="-ldld $LIBS"
/* confdefs.h. */
_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char dld_link ();
int
main ()
+dld_link ();
return 0;
_ACEOF
ac_status=$?
rm -f conftest.er1
(eval $ac_try) 2>&5
ac_status=$?
(eval $ac_try) 2>&5
ac_status=$?
- else
- compiler_rtti_exceptions=yes
- fi
+ ac_cv_lib_dld_dld_link=yes
else
+ac_cv_lib_dld_dld_link=no
fi
- echo "$as_me:$LINENO: result: $compiler_rtti_exceptions" >&5
-echo "${ECHO_T}$compiler_rtti_exceptions" >&6
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_dld_dld_link" >&5
+echo "${ECHO_T}$ac_cv_lib_dld_dld_link" >&6
+if test $ac_cv_lib_dld_dld_link = yes; then
+ lt_cv_dlopen="dld_link" lt_cv_dlopen_libs="-dld"
+fi
- if test "$compiler_rtti_exceptions" = "yes"; then
- no_builtin_flag=' -fno-builtin -fno-rtti -fno-exceptions'
+fi
+fi
+fi
+fi
+fi
+ esac
+ if test "x$lt_cv_dlopen" != xno; then
+ enable_dlopen=yes
else
- no_builtin_flag=' -fno-builtin'
+ enable_dlopen=no
fi
-fi
-# See if the linker supports building shared libraries.
-echo "$as_me:$LINENO: checking whether the linker ($LD) supports shared libraries" >&5
-echo $ECHO_N "checking whether the linker ($LD) supports shared libraries... $ECHO_C" >&6
+ case $lt_cv_dlopen in
+ dlopen)
+ save_CPPFLAGS="$CPPFLAGS"
+ test "x$ac_cv_header_dlfcn_h" = xyes && CPPFLAGS="$CPPFLAGS -DHAVE_DLFCN_H"
-allow_undefined_flag=
-no_undefined_flag=
-need_lib_prefix=unknown
-need_version=unknown
-# when you set need_version to no, make sure it does not cause -set_version
-# flags to be left without arguments
-archive_cmds=
-archive_expsym_cmds=
-old_archive_from_new_cmds=
-old_archive_from_expsyms_cmds=
-export_dynamic_flag_spec=
-whole_archive_flag_spec=
-thread_safe_flag_spec=
-hardcode_into_libs=no
-hardcode_libdir_flag_spec=
-hardcode_libdir_separator=
-hardcode_direct=no
-hardcode_minus_L=no
-hardcode_shlibpath_var=unsupported
-runpath_var=
-link_all_deplibs=unknown
-always_export_symbols=no
-export_symbols_cmds='$NM $libobjs $convenience | $global_symbol_pipe | sed '\''s/.* //'\'' | sort | uniq > $export_symbols'
-# include_expsyms should be a list of space-separated symbols to be *always*
-# included in the symbol list
-include_expsyms=
-# exclude_expsyms can be an egrep regular expression of symbols to exclude
-# it will be wrapped by ` (' and `)$', so one must not match beginning or
-# end of line. Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
-# as well as any symbol that contains `d'.
-exclude_expsyms="_GLOBAL_OFFSET_TABLE_"
-# Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
-# platforms (ab)use it in PIC code, but their linkers get confused if
-# the symbol is explicitly referenced. Since portable code cannot
-# rely on this symbol name, it's probably fine to never include it in
-# preloaded symbol tables.
-extract_expsyms_cmds=
+ save_LDFLAGS="$LDFLAGS"
+ eval LDFLAGS=\"\$LDFLAGS $export_dynamic_flag_spec\"
-case $host_os in
-cygwin* | mingw* | pw32*)
- # FIXME: the MSVC++ port hasn't been tested in a loooong time
- # When not using gcc, we currently assume that we are using
- # Microsoft Visual C++.
- if test "$GCC" != yes; then
- with_gnu_ld=no
+ save_LIBS="$LIBS"
+ LIBS="$lt_cv_dlopen_libs $LIBS"
+ echo "$as_me:$LINENO: checking whether a program can dlopen itself" >&5
+echo $ECHO_N "checking whether a program can dlopen itself... $ECHO_C" >&6
+if test "${lt_cv_dlopen_self+set}" = set; then
+else
+ if test "$cross_compiling" = yes; then :
+ lt_cv_dlopen_self=cross
+else
+ lt_dlunknown=0; lt_dlno_uscore=1; lt_dlneed_uscore=2
+ lt_status=$lt_dlunknown
+ cat > conftest.$ac_ext <<EOF
+#line 9245 "configure"
+#include "confdefs.h"
+#if HAVE_DLFCN_H
+#include <dlfcn.h>
+#endif
+#include <stdio.h>
+#ifdef RTLD_GLOBAL
+# define LT_DLGLOBAL RTLD_GLOBAL
+#else
+# ifdef DL_GLOBAL
+# define LT_DLGLOBAL DL_GLOBAL
+# else
+# define LT_DLGLOBAL 0
+# endif
+#endif
+/* We may have to define LT_DLLAZY_OR_NOW in the command line if we
+ find out it does not work in some platform. */
+#ifndef LT_DLLAZY_OR_NOW
+# ifdef RTLD_LAZY
+# define LT_DLLAZY_OR_NOW RTLD_LAZY
+# else
+# ifdef DL_LAZY
+# define LT_DLLAZY_OR_NOW DL_LAZY
+# else
+# ifdef RTLD_NOW
+# define LT_DLLAZY_OR_NOW RTLD_NOW
+# else
+# ifdef DL_NOW
+# define LT_DLLAZY_OR_NOW DL_NOW
+# else
+# define LT_DLLAZY_OR_NOW 0
+# endif
+# endif
+# endif
+# endif
+#endif
+#ifdef __cplusplus
+extern "C" void exit (int);
+#endif
+void fnord() { int i=42;}
+int main ()
+ void *self = dlopen (0, LT_DLGLOBAL|LT_DLLAZY_OR_NOW);
+ int status = $lt_dlunknown;
+ if (self)
+ if (dlsym (self,"fnord")) status = $lt_dlno_uscore;
+ else if (dlsym( self,"_fnord")) status = $lt_dlneed_uscore;
+ /* dlclose (self); */
+ exit (status);
+EOF
+ if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+ (eval $ac_link) 2>&5
+ ac_status=$?
+ (exit $ac_status); } && test -s conftest${ac_exeext} 2>/dev/null; then
+ (./conftest; exit; ) 2>/dev/null
+ lt_status=$?
+ case x$lt_status in
+ x$lt_dlno_uscore) lt_cv_dlopen_self=yes ;;
+ x$lt_dlneed_uscore) lt_cv_dlopen_self=yes ;;
+ x$lt_unknown|x*) lt_cv_dlopen_self=no ;;
+ esac
+ else :
+ # compilation failed
+ lt_cv_dlopen_self=no
fi
-openbsd*)
- with_gnu_ld=no
-esac
+fi
+rm -fr conftest*
-ld_shlibs=yes
-if test "$with_gnu_ld" = yes; then
- # If archive_cmds runs LD, not CC, wlarc should be empty
- wlarc='${wl}'
- # See if GNU ld supports shared libraries.
- case $host_os in
- aix3* | aix4* | aix5*)
- # On AIX, the GNU linker is very broken
- # Note:Check GNU linker on AIX 5-IA64 when/if it becomes available.
- ld_shlibs=no
- cat <<EOF 1>&2
+fi
+echo "$as_me:$LINENO: result: $lt_cv_dlopen_self" >&5
+echo "${ECHO_T}$lt_cv_dlopen_self" >&6
-*** Warning: the GNU linker, at least up to release 2.9.1, is reported
-*** to be unable to reliably create shared libraries on AIX.
-*** Therefore, libtool is disabling shared libraries support. If you
-*** really care for shared libraries, you may want to modify your PATH
-*** so that a non-GNU linker is found, and then restart.
+ if test "x$lt_cv_dlopen_self" = xyes; then
+ LDFLAGS="$LDFLAGS $link_static_flag"
+ echo "$as_me:$LINENO: checking whether a statically linked program can dlopen itself" >&5
+echo $ECHO_N "checking whether a statically linked program can dlopen itself... $ECHO_C" >&6
+if test "${lt_cv_dlopen_self_static+set}" = set; then
+else
+ lt_cv_dlopen_self_static=cross
+else
+#line 9343 "configure"
+#if HAVE_DLFCN_H
+#include <dlfcn.h>
+#endif
+#include <stdio.h>
+#ifdef RTLD_GLOBAL
+#else
+# ifdef DL_GLOBAL
+# else
+# endif
+#endif
+# ifdef RTLD_LAZY
+# else
+# ifdef DL_LAZY
+# else
+# ifdef RTLD_NOW
+# else
+# ifdef DL_NOW
+# else
+# endif
+# endif
+# endif
+# endif
+#endif
+#ifdef __cplusplus
+#endif
+int main ()
+ if (self)
+ exit (status);
EOF
+ ac_status=$?
+ lt_status=$?
+ x$lt_dlno_uscore) lt_cv_dlopen_self_static=yes ;;
+ x$lt_dlneed_uscore) lt_cv_dlopen_self_static=yes ;;
+ x$lt_unknown|x*) lt_cv_dlopen_self_static=no ;;
+ esac
+ else :
+ lt_cv_dlopen_self_static=no
+ fi
+fi
+rm -fr conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_dlopen_self_static" >&5
+echo "${ECHO_T}$lt_cv_dlopen_self_static" >&6
+ fi
+ CPPFLAGS="$save_CPPFLAGS"
+ LDFLAGS="$save_LDFLAGS"
+ LIBS="$save_LIBS"
+ esac
- amigaos*)
- archive_cmds='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
- hardcode_libdir_flag_spec='-L$libdir'
- hardcode_minus_L=yes
+ case $lt_cv_dlopen_self in
+ yes|no) enable_dlopen_self=$lt_cv_dlopen_self ;;
+ *) enable_dlopen_self=unknown ;;
+ esac
- # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
- # that the semantics of dynamic libraries on AmigaOS, at least up
- # to version 4, is to share data among multiple programs linked
- # with the same dynamic library. Since this doesn't match the
- # behavior of shared libraries on other platforms, we can use
- # them.
+ case $lt_cv_dlopen_self_static in
+ yes|no) enable_dlopen_self_static=$lt_cv_dlopen_self_static ;;
+ *) enable_dlopen_self_static=unknown ;;
+ esac
+fi
+# Report which librarie types wil actually be built
+echo "$as_me:$LINENO: checking if libtool supports shared libraries" >&5
+echo $ECHO_N "checking if libtool supports shared libraries... $ECHO_C" >&6
+echo "$as_me:$LINENO: result: $can_build_shared" >&5
+echo "${ECHO_T}$can_build_shared" >&6
+echo "$as_me:$LINENO: checking whether to build shared libraries" >&5
+echo $ECHO_N "checking whether to build shared libraries... $ECHO_C" >&6
+test "$can_build_shared" = "no" && enable_shared=no
+# On AIX, shared libraries and static libraries use the same namespace, and
+# are all built from PIC.
+case "$host_os" in
+aix3*)
+ test "$enable_shared" = yes && enable_static=no
+ if test -n "$RANLIB"; then
+ archive_cmds="$archive_cmds~\$RANLIB \$lib"
+ postinstall_cmds='$RANLIB $lib'
+ fi
+aix4* | aix5*)
+ if test "$host_cpu" != ia64 && test "$aix_use_runtimelinking" = no ; then
+ fi
+ else
+ 10.[012])
+ 10.*)
+ esac
+ fi
+ esac
+ archive_cmds='$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs$compiler_flags -install_name $rpath/$soname $verstring'
+ module_cmds='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
+ archive_expsym_cmds='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs$compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+ hardcode_shlibpath_var=unsupported
+ else
ld_shlibs=no
+ fi
+esac
+echo "$as_me:$LINENO: result: $enable_shared" >&5
+echo "${ECHO_T}$enable_shared" >&6
- beos*)
- if $LD --help 2>&1 | egrep ': supported targets:.* elf' > /dev/null; then
- allow_undefined_flag=unsupported
- # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
- # support --undefined. This deserves some investigation. FIXME
- archive_cmds='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- else
- ld_shlibs=no
- fi
+echo "$as_me:$LINENO: checking whether to build static libraries" >&5
+echo $ECHO_N "checking whether to build static libraries... $ECHO_C" >&6
+# Make sure either enable_shared or enable_static is yes.
+test "$enable_shared" = yes || enable_static=yes
+echo "$as_me:$LINENO: result: $enable_static" >&5
+echo "${ECHO_T}$enable_static" >&6
+# The else clause should only fire when bootstrapping the
+# libtool distribution, otherwise you forgot to ship ltmain.sh
+# with your package, and you will get complaints that there are
+# no rules to generate ltmain.sh.
+if test -f "$ltmain"; then
+ # See if we are running on zsh, and set the options which allow our commands through
+ # without removal of \ escapes.
+ if test -n "${ZSH_VERSION+set}" ; then
+ setopt NO_GLOB_SUBST
+ fi
+ # Now quote all the things that may contain metacharacters while being
+ # careful not to overquote the AC_SUBSTed values. We take copies of the
+ # variables and quote the copies for generation of the libtool script.
+ for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC NM \
+ SED SHELL STRIP \
+ libname_spec library_names_spec soname_spec extract_expsyms_cmds \
+ old_striplib striplib file_magic_cmd finish_cmds finish_eval \
+ deplibs_check_method reload_flag reload_cmds need_locks \
+ lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
+ lt_cv_sys_global_symbol_to_c_name_address \
+ sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
+ old_postinstall_cmds old_postuninstall_cmds \
+ compiler \
+ CC \
+ LD \
+ lt_prog_compiler_wl \
+ lt_prog_compiler_pic \
+ lt_prog_compiler_static \
+ lt_prog_compiler_no_builtin_flag \
+ export_dynamic_flag_spec \
+ thread_safe_flag_spec \
+ whole_archive_flag_spec \
+ enable_shared_with_static_runtimes \
+ old_archive_cmds \
+ old_archive_from_new_cmds \
+ predep_objects \
+ postdep_objects \
+ predeps \
+ postdeps \
+ compiler_lib_search_path \
+ archive_cmds \
+ archive_expsym_cmds \
+ postinstall_cmds \
+ postuninstall_cmds \
+ old_archive_from_expsyms_cmds \
+ allow_undefined_flag \
+ no_undefined_flag \
+ export_symbols_cmds \
+ hardcode_libdir_flag_spec \
+ hardcode_libdir_flag_spec_ld \
+ hardcode_libdir_separator \
+ hardcode_automatic \
+ module_cmds \
+ module_expsym_cmds \
+ lt_cv_prog_compiler_c_o \
+ exclude_expsyms \
+ include_expsyms; do
+ case $var in
+ old_archive_cmds | \
+ old_archive_from_new_cmds | \
+ archive_cmds | \
+ archive_expsym_cmds | \
+ module_cmds | \
+ module_expsym_cmds | \
+ old_archive_from_expsyms_cmds | \
+ export_symbols_cmds | \
+ extract_expsyms_cmds | reload_cmds | finish_cmds | \
+ postinstall_cmds | postuninstall_cmds | \
+ old_postinstall_cmds | old_postuninstall_cmds | \
+ sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
+ # Double-quote double-evaled strings.
+ eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
+ eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
+ esac
+ done
+ case $lt_echo in
+ *'\$0 --fallback-echo"')
+ lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
+ esac
- cygwin* | mingw* | pw32*)
- # hardcode_libdir_flag_spec is actually meaningless, as there is
- # no search path for DLLs.
- always_export_symbols=yes
+cfgfile="${ofile}T"
+ trap "$rm \"$cfgfile\"; exit 1" 1 2 15
+ $rm -f "$cfgfile"
+ { echo "$as_me:$LINENO: creating $ofile" >&5
+echo "$as_me: creating $ofile" >&6;}
- extract_expsyms_cmds='test -f $output_objdir/impgen.c || \
- sed -e "/^# \/\* impgen\.c starts here \*\//,/^# \/\* impgen.c ends here \*\// { s/^# //;s/^# *$//; p; }" -e d < $''0 > $output_objdir/impgen.c~
- test -f $output_objdir/impgen.exe || (cd $output_objdir && \
- if test "x$HOST_CC" != "x" ; then $HOST_CC -o impgen impgen.c ; \
- else $CC -o impgen impgen.c ; fi)~
- $output_objdir/impgen $dir/$soroot > $output_objdir/$soname-def'
+ cat <<__EOF__ >> "$cfgfile"
+#! $SHELL
- old_archive_from_expsyms_cmds='$DLLTOOL --as=$AS --dllname $soname --def $output_objdir/$soname-def --output-lib $output_objdir/$newlib'
+# `$echo "$cfgfile" | sed 's%^.*/%%'` - Provide generalized library-building support services.
+# Generated automatically by $PROGRAM (GNU $PACKAGE $VERSION$TIMESTAMP)
+# NOTE: Changes made to this file will be lost: look at ltmain.sh.
+# Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001
+# Free Software Foundation, Inc.
+# This file is part of GNU Libtool:
+# Originally by Gordon Matzigkeit <gord at gnu.ai.mit.edu>, 1996
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2 of the License, or
+# (at your option) any later version.
+# This program is distributed in the hope that it will be useful, but
+# WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+# General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+# As a special exception to the GNU General Public License, if you
+# distribute this file as part of a program that contains a
+# configuration script generated by Autoconf, you may include it under
+# the same distribution terms that you use for the rest of that program.
- # cygwin and mingw dlls have different entry points and sets of symbols
- # to exclude.
- # FIXME: what about values for MSVC?
- dll_entry=__cygwin_dll_entry at 12
- dll_exclude_symbols=DllMain at 12,_cygwin_dll_entry at 12,_cygwin_noncygwin_dll_entry at 12~
- case $host_os in
- mingw*)
- # mingw values
- dll_entry=_DllMainCRTStartup at 12
- dll_exclude_symbols=DllMain at 12,DllMainCRTStartup at 12,DllEntryPoint at 12~
- esac
+# A sed program that does not truncate output.
+SED=$lt_SED
- # mingw and cygwin differ, and it's simplest to just exclude the union
- # of the two symbol sets.
- dll_exclude_symbols=DllMain at 12,_cygwin_dll_entry at 12,_cygwin_noncygwin_dll_entry at 12,DllMainCRTStartup at 12,DllEntryPoint at 12
+# Sed that helps us avoid accidentally triggering echo(1) options like -n.
+Xsed="$SED -e s/^X//"
- # recent cygwin and mingw systems supply a stub DllMain which the user
- # can override, but on older systems we have to supply one (in ltdll.c)
- if test "x$lt_cv_need_dllmain" = "xyes"; then
- ltdll_obj='$output_objdir/$soname-ltdll.'"$ac_objext "
- ltdll_cmds='test -f $output_objdir/$soname-ltdll.c || sed -e "/^# \/\* ltdll\.c starts here \*\//,/^# \/\* ltdll.c ends here \*\// { s/^# //; p; }" -e d < $''0 > $output_objdir/$soname-ltdll.c~
- test -f $output_objdir/$soname-ltdll.$ac_objext || (cd $output_objdir && $CC -c $soname-ltdll.c)~'
- else
- ltdll_obj=
- ltdll_cmds=
- fi
+# The HP-UX ksh and POSIX shell print the target directory to stdout
+# if CDPATH is set.
+if test "X\${CDPATH+set}" = Xset; then CDPATH=:; export CDPATH; fi
- # Extract the symbol export list from an `--export-all' def file,
- # then regenerate the def file from the symbol export list, so that
- # the compiled dll only exports the symbol export list.
- # Be careful not to strip the DATA tag left be newer dlltools.
- export_symbols_cmds="$ltdll_cmds"'
- $DLLTOOL --export-all --exclude-symbols '$dll_exclude_symbols' --output-def $output_objdir/$soname-def '$ltdll_obj'$libobjs $convenience~
- sed -e "1,/EXPORTS/d" -e "s/ @ [0-9]*//" -e "s/ *;.*$//" < $output_objdir/$soname-def > $export_symbols'
+# The names of the tagged configurations supported by this script.
+available_tags=
- # If the export-symbols file already is a .def file (1st line
- # is EXPORTS), use it as is.
- # If DATA tags from a recent dlltool are present, honour them!
- archive_expsym_cmds='if test "x`sed 1q $export_symbols`" = xEXPORTS; then
- cp $export_symbols $output_objdir/$soname-def;
- else
- echo EXPORTS > $output_objdir/$soname-def;
- _lt_hint=1;
- cat $export_symbols | while read symbol; do
- set dummy \$symbol;
- case \$# in
- 2) echo " \$2 @ \$_lt_hint ; " >> $output_objdir/$soname-def;;
- 4) echo " \$2 \$3 \$4 ; " >> $output_objdir/$soname-def; _lt_hint=`expr \$_lt_hint - 1`;;
- *) echo " \$2 @ \$_lt_hint \$3 ; " >> $output_objdir/$soname-def;;
- esac;
- _lt_hint=`expr 1 + \$_lt_hint`;
- done;
- fi~
- '"$ltdll_cmds"'
- $CC -Wl,--base-file,$output_objdir/$soname-base '$lt_cv_cc_dll_switch' -Wl,-e,'$dll_entry' -o $output_objdir/$soname '$ltdll_obj'$libobjs $deplibs $compiler_flags~
- $DLLTOOL --as=$AS --dllname $soname --exclude-symbols '$dll_exclude_symbols' --def $output_objdir/$soname-def --base-file $output_objdir/$soname-base --output-exp $output_objdir/$soname-exp~
- $CC -Wl,--base-file,$output_objdir/$soname-base $output_objdir/$soname-exp '$lt_cv_cc_dll_switch' -Wl,-e,'$dll_entry' -o $output_objdir/$soname '$ltdll_obj'$libobjs $deplibs $compiler_flags~
- $DLLTOOL --as=$AS --dllname $soname --exclude-symbols '$dll_exclude_symbols' --def $output_objdir/$soname-def --base-file $output_objdir/$soname-base --output-exp $output_objdir/$soname-exp --output-lib $output_objdir/$libname.dll.a~
- $CC $output_objdir/$soname-exp '$lt_cv_cc_dll_switch' -Wl,-e,'$dll_entry' -o $output_objdir/$soname '$ltdll_obj'$libobjs $deplibs $compiler_flags'
+# ### BEGIN LIBTOOL CONFIG
+# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
+# Shell to use when invoking shell scripts.
+SHELL=$lt_SHELL
+# Whether or not to build shared libraries.
+build_libtool_libs=$enable_shared
+# Whether or not to build static libraries.
+build_old_libs=$enable_static
+# Whether or not to add -lc for building shared libraries.
+build_libtool_need_lc=$archive_cmds_need_lc
+# Whether or not to disallow shared libs when runtime libs are static
+allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes
+# Whether or not to optimize for fast installation.
+fast_install=$enable_fast_install
+# The host system.
+host_alias=$host_alias
+host=$host
+# An echo program that does not interpret backslashes.
+echo=$lt_echo
+# The archiver.
+AR=$lt_AR
+AR_FLAGS=$lt_AR_FLAGS
+# A C compiler.
+LTCC=$lt_LTCC
+# A language-specific compiler.
+CC=$lt_compiler
+# Is the compiler the GNU C compiler?
+with_gcc=$GCC
+# An ERE matcher.
+EGREP=$lt_EGREP
+# The linker used to build libraries.
+LD=$lt_LD
+# Whether we need hard or soft links.
+LN_S=$lt_LN_S
+# A BSD-compatible nm program.
+NM=$lt_NM
+# A symbol stripping program
+STRIP=$lt_STRIP
+# Used to examine libraries when file_magic_cmd begins "file"
+MAGIC_CMD=$MAGIC_CMD
+# Used on cygwin: DLL creation program.
+DLLTOOL="$DLLTOOL"
+# Used on cygwin: object dumper.
+OBJDUMP="$OBJDUMP"
+# Used on cygwin: assembler.
+AS="$AS"
+# The name of the directory that contains temporary libtool files.
+objdir=$objdir
+# How to create reloadable object files.
+reload_flag=$lt_reload_flag
+reload_cmds=$lt_reload_cmds
+# How to pass a linker flag through the compiler.
+wl=$lt_lt_prog_compiler_wl
+# Object file suffix (normally "o").
+objext="$ac_objext"
+# Old archive suffix (normally "a").
+libext="$libext"
+# Shared library suffix (normally ".so").
+shrext_cmds='$shrext_cmds'
+# Executable file suffix (normally "").
+exeext="$exeext"
+# Additional compiler flags for building library objects.
+pic_flag=$lt_lt_prog_compiler_pic
+pic_mode=$pic_mode
+# What is the maximum length of a command?
+max_cmd_len=$lt_cv_sys_max_cmd_len
+# Does compiler simultaneously support -c and -o options?
+compiler_c_o=$lt_lt_cv_prog_compiler_c_o
+# Must we lock files when doing compilation ?
+need_locks=$lt_need_locks
+# Do we need the lib prefix for modules?
+need_lib_prefix=$need_lib_prefix
+# Do we need a version for libraries?
+need_version=$need_version
+# Whether dlopen is supported.
+dlopen_support=$enable_dlopen
+# Whether dlopen of programs is supported.
+dlopen_self=$enable_dlopen_self
+# Whether dlopen of statically linked programs is supported.
+dlopen_self_static=$enable_dlopen_self_static
+# Compiler flag to prevent dynamic linking.
+link_static_flag=$lt_lt_prog_compiler_static
+# Compiler flag to turn off builtin functions.
+no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag
+# Compiler flag to allow reflexive dlopens.
+export_dynamic_flag_spec=$lt_export_dynamic_flag_spec
+# Compiler flag to generate shared objects directly from archives.
+whole_archive_flag_spec=$lt_whole_archive_flag_spec
+# Compiler flag to generate thread-safe objects.
+thread_safe_flag_spec=$lt_thread_safe_flag_spec
+# Library versioning type.
+version_type=$version_type
+# Format of library name prefix.
+libname_spec=$lt_libname_spec
+# List of archive names. First name is the real one, the rest are links.
+# The last name is the one that the linker finds with -lNAME.
+library_names_spec=$lt_library_names_spec
+# The coded name of the library, if different from the real name.
+soname_spec=$lt_soname_spec
+# Commands used to build and install an old-style archive.
+RANLIB=$lt_RANLIB
+old_archive_cmds=$lt_old_archive_cmds
+old_postinstall_cmds=$lt_old_postinstall_cmds
+old_postuninstall_cmds=$lt_old_postuninstall_cmds
+# Create an old-style archive from a shared archive.
+old_archive_from_new_cmds=$lt_old_archive_from_new_cmds
+# Create a temporary old-style archive to link instead of a shared archive.
+old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds
+# Commands used to build and install a shared archive.
+archive_cmds=$lt_archive_cmds
+archive_expsym_cmds=$lt_archive_expsym_cmds
+postinstall_cmds=$lt_postinstall_cmds
+postuninstall_cmds=$lt_postuninstall_cmds
+# Commands used to build a loadable module (assumed same as above if empty)
+module_cmds=$lt_module_cmds
+module_expsym_cmds=$lt_module_expsym_cmds
+# Commands to strip libraries.
+old_striplib=$lt_old_striplib
+striplib=$lt_striplib
+# Dependencies to place before the objects being linked to create a
+# shared library.
+predep_objects=$lt_predep_objects
+# Dependencies to place after the objects being linked to create a
+# shared library.
+postdep_objects=$lt_postdep_objects
+# shared library.
+predeps=$lt_predeps
+# shared library.
+postdeps=$lt_postdeps
+# The library search path used internally by the compiler when linking
+# a shared library.
+compiler_lib_search_path=$lt_compiler_lib_search_path
+# Method to check whether dependent libraries are shared objects.
+deplibs_check_method=$lt_deplibs_check_method
+# Command to use when deplibs_check_method == file_magic.
+file_magic_cmd=$lt_file_magic_cmd
+# Flag that allows shared libraries with undefined symbols to be built.
+allow_undefined_flag=$lt_allow_undefined_flag
+# Flag that forces no undefined symbols.
+no_undefined_flag=$lt_no_undefined_flag
+# Commands used to finish a libtool library installation in a directory.
+finish_cmds=$lt_finish_cmds
+# Same as above, but a single script fragment to be evaled but not shown.
+finish_eval=$lt_finish_eval
+# Take the output of nm and produce a listing of raw symbols and C names.
+global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
+# Transform the output of nm in a proper C declaration
+global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
+# Transform the output of nm in a C name address pair
+global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
+# This is the shared library runtime path variable.
+runpath_var=$runpath_var
+# This is the shared library path variable.
+shlibpath_var=$shlibpath_var
+# Is shlibpath searched before the hard-coded library search path?
+shlibpath_overrides_runpath=$shlibpath_overrides_runpath
+# How to hardcode a shared library path into an executable.
+hardcode_action=$hardcode_action
+# Whether we should hardcode library paths into libraries.
+hardcode_into_libs=$hardcode_into_libs
+# Flag to hardcode \$libdir into a binary during linking.
+# This must work even if \$libdir does not exist.
+hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec
+# If ld is used when linking, flag to hardcode \$libdir into
+# a binary during linking. This must work even if \$libdir does
+# not exist.
+hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld
+# Whether we need a single -rpath flag with a separated argument.
+hardcode_libdir_separator=$lt_hardcode_libdir_separator
+# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
+# resulting binary.
+hardcode_direct=$hardcode_direct
+# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
+hardcode_minus_L=$hardcode_minus_L
+# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
+# the resulting binary.
+hardcode_shlibpath_var=$hardcode_shlibpath_var
+# Set to yes if building a shared library automatically hardcodes DIR into the library
+# and all subsequent libraries and executables linked against it.
+hardcode_automatic=$hardcode_automatic
+# Variables whose values should be saved in libtool wrapper scripts and
+# restored at relink time.
+variables_saved_for_relink="$variables_saved_for_relink"
+# Whether libtool must link a program against all its dependency libraries.
+link_all_deplibs=$link_all_deplibs
+# Compile-time system search path for libraries
+sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
+# Run-time system search path for libraries
+sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
+# Fix the shell variable \$srcfile for the compiler.
+fix_srcfile_path="$fix_srcfile_path"
+# Set to yes if exported symbols are required.
+always_export_symbols=$always_export_symbols
+# The commands to list exported symbols.
+export_symbols_cmds=$lt_export_symbols_cmds
+# The commands to extract the exported symbol list from a shared archive.
+extract_expsyms_cmds=$lt_extract_expsyms_cmds
+# Symbols that should not be listed in the preloaded symbols.
+exclude_expsyms=$lt_exclude_expsyms
+# Symbols that must always be exported.
+include_expsyms=$lt_include_expsyms
+# ### END LIBTOOL CONFIG
+__EOF__
+ case $host_os in
+ aix3*)
+ cat <<\EOF >> "$cfgfile"
+# AIX sometimes has problems with the GCC collect2 program. For some
+# reason, if we set the COLLECT_NAMES environment variable, the problems
+# vanish in a puff of smoke.
+if test "X${COLLECT_NAMES+set}" != Xset; then
+ COLLECT_NAMES=
+ export COLLECT_NAMES
+fi
+EOF
+ esac
- netbsd*)
- if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
- archive_cmds='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
- wlarc=
+ # We use sed instead of cat because bash on DJGPP gets confused if
+ # if finds mixed CR/LF and LF-only lines. Since sed operates in
+ # text mode, it properly converts lines to CR/LF. This bash problem
+ # is reportedly fixed, but why not run on old versions too?
+ sed '$q' "$ltmain" >> "$cfgfile" || (rm -f "$cfgfile"; exit 1)
+ mv -f "$cfgfile" "$ofile" || \
+ (rm -f "$ofile" && cp "$cfgfile" "$ofile" && rm -f "$cfgfile")
+ chmod +x "$ofile"
+else
+ # If there is no Makefile yet, we rely on a make rule to execute
+ # `config.status --recheck' to rerun these tests and create the
+ # libtool script then.
+ ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
+ if test -f "$ltmain_in"; then
+ test -f Makefile && make "$ltmain"
+ fi
+fi
+ac_ext=cc
+ac_cpp='$CXXCPP $CPPFLAGS'
+ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
+CC="$lt_save_CC"
+# Check whether --with-tags or --without-tags was given.
+if test "${with_tags+set}" = set; then
+ withval="$with_tags"
+ tagnames="$withval"
+fi;
+if test -f "$ltmain" && test -n "$tagnames"; then
+ if test ! -f "${ofile}"; then
+ { echo "$as_me:$LINENO: WARNING: output file \`$ofile' does not exist" >&5
+echo "$as_me: WARNING: output file \`$ofile' does not exist" >&2;}
+ fi
+ if test -z "$LTCC"; then
+ eval "`$SHELL ${ofile} --config | grep '^LTCC='`"
+ { echo "$as_me:$LINENO: WARNING: output file \`$ofile' does not look like a libtool script" >&5
+echo "$as_me: WARNING: output file \`$ofile' does not look like a libtool script" >&2;}
else
- archive_cmds='$CC -shared -nodefaultlibs $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- archive_expsym_cmds='$CC -shared -nodefaultlibs $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+ { echo "$as_me:$LINENO: WARNING: using \`LTCC=$LTCC', extracted from \`$ofile'" >&5
+echo "$as_me: WARNING: using \`LTCC=$LTCC', extracted from \`$ofile'" >&2;}
fi
+ fi
- solaris* | sysv5*)
- if $LD -v 2>&1 | egrep 'BFD 2\.8' > /dev/null; then
- ld_shlibs=no
- cat <<EOF 1>&2
+ # Extract list of available tagged configurations in $ofile.
+ # Note that this assumes the entire list is on one line.
+ available_tags=`grep "^available_tags=" "${ofile}" | $SED -e 's/available_tags=\(.*$\)/\1/' -e 's/\"//g'`
-*** Warning: The releases 2.8.* of the GNU linker cannot reliably
-*** create shared libraries on Solaris systems. Therefore, libtool
-*** is disabling shared libraries support. We urge you to upgrade GNU
-*** binutils to release 2.9.1 or newer. Another option is to modify
-*** your PATH or compiler configuration so that the native linker is
-*** used, and then restart.
+ lt_save_ifs="$IFS"; IFS="${IFS}$PATH_SEPARATOR,"
+ for tagname in $tagnames; do
+ IFS="$lt_save_ifs"
+ # Check whether tagname contains only valid characters
+ case `$echo "X$tagname" | $Xsed -e 's:[-_ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz1234567890,/]::g'` in
+ *) { { echo "$as_me:$LINENO: error: invalid tag name: $tagname" >&5
+echo "$as_me: error: invalid tag name: $tagname" >&2;}
+ { (exit 1); exit 1; }; }
+ esac
-EOF
- elif $LD --help 2>&1 | egrep ': supported targets:.* elf' > /dev/null; then
- archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- archive_expsym_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- else
- ld_shlibs=no
+ if grep "^# ### BEGIN LIBTOOL TAG CONFIG: $tagname$" < "${ofile}" > /dev/null
+ then
+ { { echo "$as_me:$LINENO: error: tag name \"$tagname\" already exists" >&5
+echo "$as_me: error: tag name \"$tagname\" already exists" >&2;}
fi
- sunos4*)
- archive_cmds='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- wlarc=
- hardcode_direct=yes
- hardcode_shlibpath_var=no
+ # Update the list of available tags.
+ if test -n "$tagname"; then
+ echo appending configuration tag \"$tagname\" to $ofile
+ case $tagname in
+ CXX)
+ if test -n "$CXX" && test "X$CXX" != "Xno"; then
+ ac_ext=cc
+archive_cmds_need_lc_CXX=no
+allow_undefined_flag_CXX=
+always_export_symbols_CXX=no
+archive_expsym_cmds_CXX=
+export_dynamic_flag_spec_CXX=
+hardcode_direct_CXX=no
+hardcode_libdir_flag_spec_CXX=
+hardcode_libdir_flag_spec_ld_CXX=
+hardcode_libdir_separator_CXX=
+hardcode_minus_L_CXX=no
+hardcode_automatic_CXX=no
+module_cmds_CXX=
+module_expsym_cmds_CXX=
+link_all_deplibs_CXX=unknown
+old_archive_cmds_CXX=$old_archive_cmds
+no_undefined_flag_CXX=
+whole_archive_flag_spec_CXX=
+enable_shared_with_static_runtimes_CXX=no
+# Dependencies to place before and after the object being linked:
+predep_objects_CXX=
+postdep_objects_CXX=
+predeps_CXX=
+postdeps_CXX=
+compiler_lib_search_path_CXX=
+# Source file extension for C++ test sources.
+ac_ext=cc
+# Object file extension for compiled C++ test sources.
+objext=o
+objext_CXX=$objext
+# Code to be used in simple compile tests
+lt_simple_compile_test_code="int some_variable = 0;\n"
+# Code to be used in simple link tests
+lt_simple_link_test_code='int main(int, char *) { return(0); }\n'
+# ltmain only uses $CC for tagged configurations so make sure $CC is set.
+# If no C compiler was specified, use CC.
+LTCC=${LTCC-"$CC"}
+# Allow CC to be a program name with arguments.
+compiler=$CC
+lt_save_CC=$CC
+lt_save_LD=$LD
+lt_save_GCC=$GCC
+GCC=$GXX
+lt_save_with_gnu_ld=$with_gnu_ld
+lt_save_path_LD=$lt_cv_path_LD
+if test -n "${lt_cv_prog_gnu_ldcxx+set}"; then
+ lt_cv_prog_gnu_ld=$lt_cv_prog_gnu_ldcxx
+else
+ unset lt_cv_prog_gnu_ld
+fi
+if test -n "${lt_cv_path_LDCXX+set}"; then
+ lt_cv_path_LD=$lt_cv_path_LDCXX
+else
+ unset lt_cv_path_LD
+fi
+test -z "${LDCXX+set}" || LD=$LDCXX
+CC=${CXX-"c++"}
+compiler=$CC
+compiler_CXX=$CC
+cc_basename=`$echo X"$compiler" | $Xsed -e 's%^.*/%%'`
+# We don't want -fno-exception wen compiling C++ code, so set the
+# no_builtin_flag separately
+if test "$GXX" = yes; then
+ lt_prog_compiler_no_builtin_flag_CXX=' -fno-builtin'
+else
+fi
+ # Set up default GNU C++ configuration
+# Check whether --with-gnu-ld or --without-gnu-ld was given.
+if test "${with_gnu_ld+set}" = set; then
+ withval="$with_gnu_ld"
+ test "$withval" = no || with_gnu_ld=yes
+else
+ with_gnu_ld=no
+fi;
+ac_prog=ld
+if test "$GCC" = yes; then
+ # Check if gcc -print-prog-name=ld gives a path.
+ echo "$as_me:$LINENO: checking for ld used by $CC" >&5
+echo $ECHO_N "checking for ld used by $CC... $ECHO_C" >&6
+ case $host in
+ *-*-mingw*)
+ # gcc leaves a trailing carriage return which upsets mingw
+ ac_prog=`($CC -print-prog-name=ld) 2>&5 | tr -d '\015'` ;;
- else
- ld_shlibs=no
- fi
+ ac_prog=`($CC -print-prog-name=ld) 2>&5` ;;
+ esac
+ case $ac_prog in
+ # Accept absolute paths.
+ re_direlt='/[^/][^/]*/\.\./'
+ # Canonicalize the pathname of ld
+ ac_prog=`echo $ac_prog| $SED 's%\\\\%/%g'`
+ while echo $ac_prog | grep "$re_direlt" > /dev/null 2>&1; do
+ ac_prog=`echo $ac_prog| $SED "s%$re_direlt%/%"`
+ done
+ test -z "$LD" && LD="$ac_prog"
+ # If it fails, then pretend we aren't using GCC.
+ ac_prog=ld
+ # If it is relative, then search for the first ld in PATH.
+ with_gnu_ld=unknown
esac
+elif test "$with_gnu_ld" = yes; then
+ echo "$as_me:$LINENO: checking for GNU ld" >&5
+echo $ECHO_N "checking for GNU ld... $ECHO_C" >&6
+else
+ echo "$as_me:$LINENO: checking for non-GNU ld" >&5
+echo $ECHO_N "checking for non-GNU ld... $ECHO_C" >&6
+fi
+if test "${lt_cv_path_LD+set}" = set; then
+else
+ if test -z "$LD"; then
+ lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
+ for ac_dir in $PATH; do
+ test -z "$ac_dir" && ac_dir=.
+ if test -f "$ac_dir/$ac_prog" || test -f "$ac_dir/$ac_prog$ac_exeext"; then
+ lt_cv_path_LD="$ac_dir/$ac_prog"
+ # Check to see if the program is GNU ld. I'd rather use --version,
+ # but apparently some GNU ld's only accept -v.
+ # Break only if it was the GNU/non-GNU ld that we prefer.
+ case `"$lt_cv_path_LD" -v 2>&1 </dev/null` in
+ *GNU* | *'with BFD'*)
+ test "$with_gnu_ld" != no && break
+ test "$with_gnu_ld" != yes && break
+ esac
+ fi
+ done
+else
+ lt_cv_path_LD="$LD" # Let the user override the test with a path.
+fi
+fi
- if test "$ld_shlibs" = yes; then
- runpath_var=LD_RUN_PATH
- hardcode_libdir_flag_spec='${wl}--rpath ${wl}$libdir'
- export_dynamic_flag_spec='${wl}--export-dynamic'
- case $host_os in
- # dlltool doesn't understand --whole-archive et. al.
- whole_archive_flag_spec=
- # ancient GNU ld didn't support --whole-archive et. al.
- if $LD --help 2>&1 | egrep 'no-whole-archive' > /dev/null; then
- whole_archive_flag_spec="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
- else
- fi
- esac
+LD="$lt_cv_path_LD"
+if test -n "$LD"; then
+ echo "$as_me:$LINENO: result: $LD" >&5
+echo "${ECHO_T}$LD" >&6
+else
+ echo "$as_me:$LINENO: result: no" >&5
+echo "${ECHO_T}no" >&6
+fi
+test -z "$LD" && { { echo "$as_me:$LINENO: error: no acceptable ld found in \$PATH" >&5
+echo "$as_me: error: no acceptable ld found in \$PATH" >&2;}
+echo "$as_me:$LINENO: checking if the linker ($LD) is GNU ld" >&5
+echo $ECHO_N "checking if the linker ($LD) is GNU ld... $ECHO_C" >&6
+if test "${lt_cv_prog_gnu_ld+set}" = set; then
+else
+ # I'd rather use --version here, but apparently some GNU ld's only accept -v.
+case `$LD -v 2>&1 </dev/null` in
+*GNU* | *'with BFD'*)
+ lt_cv_prog_gnu_ld=yes
+ lt_cv_prog_gnu_ld=no
+esac
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_gnu_ld" >&5
+echo "${ECHO_T}$lt_cv_prog_gnu_ld" >&6
+with_gnu_ld=$lt_cv_prog_gnu_ld
+ # Check if GNU C++ uses GNU ld as the underlying linker, since the
+ # archiving commands below assume that GNU ld is being used.
+ if test "$with_gnu_ld" = yes; then
+ archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib'
+ archive_expsym_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+ hardcode_libdir_flag_spec_CXX='${wl}--rpath ${wl}$libdir'
+ export_dynamic_flag_spec_CXX='${wl}--export-dynamic'
+ # If archive_cmds runs LD, not CC, wlarc should be empty
+ # XXX I think wlarc can be eliminated in ltcf-cxx, but I need to
+ # investigate it a little bit more. (MM)
+ wlarc='${wl}'
+ # ancient GNU ld didn't support --whole-archive et. al.
+ if eval "`$CC -print-prog-name=ld` --help 2>&1" | \
+ grep 'no-whole-archive' > /dev/null; then
+ whole_archive_flag_spec_CXX="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
+ else
+ fi
+ else
+ with_gnu_ld=no
+ wlarc=
+ # A generic and very simple default shared library creation
+ # command for GNU C++ for the case where it uses the native
+ # linker, instead of GNU ld. If possible, this setting should
+ # overridden to take advantage of the native linker features on
+ # the platform it is being used on.
+ archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $lib'
fi
+ # Commands to make compiler produce verbose output that lists
+ # what "hidden" libraries, object files and flags are used when
+ # linking a shared library.
+ output_verbose_link_cmd='$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep "\-L"'
else
- # PORTME fill in a description of your system's linker (not GNU ld)
- case $host_os in
+ GXX=no
+ with_gnu_ld=no
+ wlarc=
+fi
+# PORTME: fill in a description of your system's C++ link characteristics
+echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
+echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
+ld_shlibs_CXX=yes
+case $host_os in
aix3*)
- archive_expsym_cmds='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
- # Note: this linker hardcodes the directories in LIBPATH if there
- # are no directories specified by -L.
- if test "$GCC" = yes && test -z "$link_static_flag"; then
- # Neither direct hardcoding nor static linking is supported with a
- # broken collect2.
- hardcode_direct=unsupported
- fi
+ # FIXME: insert proper C++ library support
+ ld_shlibs_CXX=no
aix4* | aix5*)
if test "$host_cpu" = ia64; then
# On IA64, the linker does run time linking by default, so we don't
@@ -6164,7 +10323,7 @@
*-brtl*)
aix_use_runtimelinking=yes
break
esac
done
esac
@@ -6179,34 +10338,39 @@
# CXXFLAGS/CFLAGS for g++/gcc. In the cases where that is not
# enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
- archive_cmds=''
- hardcode_libdir_separator=':'
- if test "$GCC" = yes; then
- case $host_os in aix4.[012]|aix4.[012].*)
+ archive_cmds_CXX=''
+ hardcode_direct_CXX=yes
+ hardcode_libdir_separator_CXX=':'
+ link_all_deplibs_CXX=yes
+ if test "$GXX" = yes; then
+ case $host_os in aix4.012|aix4.012.*)
+ # We only want to do this on AIX 4.2 and lower, the check
+ # below for broken collect2 doesn't work under 4.3+
collect2name=`${CC} -print-prog-name=collect2`
if test -f "$collect2name" && \
- strings "$collect2name" | grep resolve_lib_name >/dev/null
+ strings "$collect2name" | grep resolve_lib_name >/dev/null
then
# We have reworked collect2
else
# We have old collect2
+ hardcode_direct_CXX=unsupported
# It fails to find uninstalled libraries when the uninstalled
# path is not listed in the libpath. Setting hardcode_minus_L
# to unsupported forces relinking
+ hardcode_minus_L_CXX=yes
+ hardcode_libdir_flag_spec_CXX='-L$libdir'
fi
esac
shared_flag='-shared'
else
# not using gcc
- shared_flag='${wl}-G'
+ # VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
+ # chokes on -Wl,-G. The following line is correct:
+ shared_flag='-G'
else
if test "$aix_use_runtimelinking" = yes; then
@@ -6216,398 +10380,5123 @@
fi
fi
- # It seems that -bexpall can do strange things, so it is better to
- # generate a list of symbols to export.
+ # It seems that -bexpall does not export symbols beginning with
+ # underscore (_), so it is better to generate a list of symbols to export.
+ always_export_symbols_CXX=yes
# Warning - without using the other runtime loading flags (-brtl),
# -berok will link without error, but may produce a broken library.
- allow_undefined_flag='-berok'
- hardcode_libdir_flag_spec='${wl}-blibpath:$libdir:/usr/lib:/lib'
- archive_expsym_cmds="\$CC"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols $shared_flag"
- else
+ allow_undefined_flag_CXX='-berok'
+ # Determine the default libpath from the value encoded in an empty executable.
+/* confdefs.h. */
+_ACEOF
+int
+main ()
+ return 0;
+_ACEOF
+ ac_status=$?
+ echo "$as_me:$LINENO: \$? = $ac_status" >&5
+ { ac_try='test -z "$ac_cxx_werror_flag"
+ ac_status=$?
+ ac_status=$?
+aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
+# Check for a 64-bit object if we didn't find anything.
+if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
+}'`; fi
+else
+fi
+if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
+ hardcode_libdir_flag_spec_CXX='${wl}-blibpath:$libdir:'"$aix_libpath"
+ archive_expsym_cmds_CXX="\$CC"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols $shared_flag"
+ else
- hardcode_libdir_flag_spec='${wl}-R $libdir:/usr/lib:/lib'
- allow_undefined_flag="-z nodefs"
- archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname ${wl}-h$soname $libobjs $deplibs $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols"
+ hardcode_libdir_flag_spec_CXX='${wl}-R $libdir:/usr/lib:/lib'
+ allow_undefined_flag_CXX="-z nodefs"
+ archive_expsym_cmds_CXX="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols"
else
- hardcode_libdir_flag_spec='${wl}-bnolibpath ${wl}-blibpath:$libdir:/usr/lib:/lib'
+/* confdefs.h. */
+_ACEOF
+int
+main ()
+ return 0;
+_ACEOF
+ ac_status=$?
+ ac_status=$?
+ ac_status=$?
+}'`; fi
+else
+fi
# Warning - without using the other run time loading flags,
- allow_undefined_flag='${wl}-berok'
- # This is a bit strange, but is similar to how AIX traditionally builds
- # it's shared libraries.
- archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${allow_undefined_flag} '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols"' ~$AR -crlo $objdir/$libname$release.a $objdir/$soname'
+ no_undefined_flag_CXX=' ${wl}-bernotok'
+ allow_undefined_flag_CXX=' ${wl}-berok'
+ # -bexpall does not export symbols beginning with underscore (_)
+ # Exported symbols can be pulled into shared objects from archives
+ whole_archive_flag_spec_CXX=' '
+ archive_cmds_need_lc_CXX=yes
+ # This is similar to how AIX traditionally builds it's shared libraries.
+ archive_expsym_cmds_CXX="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${wl}-bE:$export_symbols ${wl}-bnoentry${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
fi
fi
- amigaos*)
- # see comment about different semantics on the GNU ld section
- ld_shlibs=no
+ chorus*)
+ case $cc_basename in
+ ld_shlibs_CXX=no
+ esac
- hardcode_libdir_flag_spec=' '
- # Tell ltmain to make .lib files, not .a files.
- libext=lib
- # FIXME: Setting linknames here is a bad hack.
- archive_cmds='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | sed -e '\''s/ -lc$//'\''` -link -dll~linknames='
- # The linker will automatically build a .lib file if we build a DLL.
- old_archive_from_new_cmds='true'
- # FIXME: Should let the user specify the lib program.
- old_archive_cmds='lib /OUT:$oldlib$oldobjs$old_deplibs'
- fix_srcfile_path='`cygpath -w "$srcfile"`'
+ # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, CXX) is actually meaningless,
+ # as there is no search path for DLLs.
+ allow_undefined_flag_CXX=unsupported
+ always_export_symbols_CXX=no
+ enable_shared_with_static_runtimes_CXX=yes
+ if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
+ archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--image-base=0x10000000 ${wl}--out-implib,$lib'
+ # If the export-symbols file already is a .def file (1st line
+ # is EXPORTS), use it as is; otherwise, prepend...
+ archive_expsym_cmds_CXX='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
+ cp $export_symbols $output_objdir/$soname.def;
+ else
+ echo EXPORTS > $output_objdir/$soname.def;
+ cat $export_symbols >> $output_objdir/$soname.def;
+ fi~
+ $CC -shared -nostdlib $output_objdir/$soname.def $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--image-base=0x10000000 ${wl}--out-implib,$lib'
+ else
+ ld_shlibs_CXX=no
+ fi
darwin* | rhapsody*)
+ archive_cmds_need_lc_CXX=no
case "$host_os" in
rhapsody* | darwin1.[012])
- allow_undefined_flag='-undefined suppress'
+ allow_undefined_flag_CXX='-undefined suppress'
*) # Darwin 1.3 on
- allow_undefined_flag='-flat_namespace -undefined suppress'
+ if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
+ allow_undefined_flag_CXX='-flat_namespace -undefined suppress'
+ else
+ case ${MACOSX_DEPLOYMENT_TARGET} in
+ 10.[012])
+ 10.*)
+ allow_undefined_flag_CXX='-undefined dynamic_lookup'
+ esac
+ fi
esac
- # FIXME: Relying on posixy $() will cause problems for
- # cross-compilation, but unfortunately the echo tests do not
- # yet detect zsh echo's removal of \ escapes. Also zsh mangles
- # `"' quotes if we put them in here... so don't!
- archive_cmds='$CC -r -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs && $CC $(test .$module = .yes && echo -bundle || echo -dynamiclib) $allow_undefined_flag -o $lib ${lib}-master.o $deplibs$linker_flags $(test .$module != .yes && echo -install_name $rpath/$soname $verstring)'
- # We need to add '_' to the symbols in $export_symbols first
- #archive_expsym_cmds="$archive_cmds"' && strip -s $export_symbols'
- whole_archive_flag_spec='-all_load $convenience'
+ lt_int_apple_cc_single_mod=no
+ output_verbose_link_cmd='echo'
+ if $CC -dumpspecs 2>&1 | grep 'single_module' >/dev/null ; then
+ lt_int_apple_cc_single_mod=yes
+ fi
+ if test "X$lt_int_apple_cc_single_mod" = Xyes ; then
+ archive_cmds_CXX='$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+ else
+ archive_cmds_CXX='$CC -r ${wl}-bind_at_load -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+ fi
+ module_cmds_CXX='$CC ${wl}-bind_at_load $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
+ # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin ld's
+ archive_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+ else
+ archive_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -r ${wl}-bind_at_load -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+ fi
+ module_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+ hardcode_direct_CXX=no
+ hardcode_automatic_CXX=yes
+ hardcode_shlibpath_var_CXX=unsupported
+ whole_archive_flag_spec_CXX='-all_load $convenience'
+ else
+ ld_shlibs_CXX=no
+ fi
- freebsd1*)
- ld_shlibs=no
+ dgux*)
+ ec++)
+ ld_shlibs_CXX=no
+ ghcx)
+ # Green Hills C++ Compiler
+ ld_shlibs_CXX=no
+ ld_shlibs_CXX=no
+ esac
+ freebsd12*)
+ # C++ shared libraries reported to be fairly broken before switch to ELF
+ ld_shlibs_CXX=no
+ freebsd-elf*)
+ freebsd* | kfreebsd*-gnu)
+ # FreeBSD 3 and later use GNU C++ and GNU ld with standard ELF
+ # conventions
+ ld_shlibs_CXX=yes
+ gnu*)
+ hpux9*)
+ hardcode_libdir_flag_spec_CXX='${wl}+b ${wl}$libdir'
+ hardcode_libdir_separator_CXX=:
+ export_dynamic_flag_spec_CXX='${wl}-E'
+ hardcode_minus_L_CXX=yes # Not in the search PATH,
+ # but as the default
+ # location of the library.
- # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
- # support. Future versions do this automatically, but an explicit c++rt0.o
- # does not break anything, and helps significantly (at the cost of a little
- # extra space).
- freebsd2.2*)
- archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
- hardcode_libdir_flag_spec='-R$libdir'
+ CC)
+ ld_shlibs_CXX=no
+ aCC)
+ archive_cmds_CXX='$rm $output_objdir/$soname~$CC -b ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+ # There doesn't appear to be a way to prevent this compiler from
+ # explicitly linking system object files so we need to strip them
+ # from the output so that they don't get included in the library
+ # dependencies.
+ output_verbose_link_cmd='templist=`($CC -b $CFLAGS -v conftest.$objext 2>&1) | grep "-L"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
+ archive_cmds_CXX='$rm $output_objdir/$soname~$CC -shared -nostdlib -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+ else
+ ld_shlibs_CXX=no
+ fi
+ esac
+ hpux10*|hpux11*)
+ if test $with_gnu_ld = no; then
+ case "$host_cpu" in
+ hppa*64*)
+ hardcode_libdir_flag_spec_ld_CXX='+b $libdir'
+ ia64*)
+ esac
+ fi
+ hppa*64*)
+ hardcode_shlibpath_var_CXX=no
+ ia64*)
+ esac
- # Unfortunately, older versions of FreeBSD 2 do not have this feature.
- freebsd2*)
- archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+ CC)
+ ld_shlibs_CXX=no
+ aCC)
+ hppa*64*|ia64*)
+ archive_cmds_CXX='$LD -b +h $soname -o $lib $linker_flags $libobjs $deplibs'
+ archive_cmds_CXX='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+ esac
+ # dependencies.
+ output_verbose_link_cmd='templist=`($CC -b $CFLAGS -v conftest.$objext 2>&1) | grep "\-L"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
+ ia64*|hppa*64*)
+ archive_cmds_CXX='$CC -shared -nostdlib -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+ esac
+ fi
+ else
+ ld_shlibs_CXX=no
+ fi
+ esac
+ irix5* | irix6*)
+ CC)
+ # SGI C++
+ archive_cmds_CXX='$CC -shared -all -multigot $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${objdir}/so_locations -o $lib'
- # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
- freebsd*)
- archive_cmds='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
+ # Archives containing C++ object files must be created using
+ # "CC -ar", where "CC" is the IRIX C++ compiler. This is
+ # necessary to make sure instantiated templates are included
+ # in the archive.
+ old_archive_cmds_CXX='$CC -ar -WR,-u -o $oldlib $oldobjs'
+ if test "$with_gnu_ld" = no; then
+ archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${objdir}/so_locations -o $lib'
+ else
+ archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` -o $lib'
+ fi
+ fi
+ esac
+ hardcode_libdir_flag_spec_CXX='${wl}-rpath ${wl}$libdir'
+ linux*)
+ KCC)
+ # Kuck and Associates, Inc. (KAI) C++ Compiler
- hpux9* | hpux10* | hpux11*)
+ # KCC will only create a shared library if the output file
+ # ends with ".so" (or ".sl" for HP-UX), so rename the library
+ # to its proper name (with version) after linking.
+ archive_cmds_CXX='tempext=`echo $shared_ext | $SED -e '\''s/\([^()0-9A-Za-z{}]\)/\\\\\1/g'\''`; templib=`echo $lib | $SED -e "s/\${tempext}\..*/.so/"`; $CC $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags --soname $soname -o \$templib; mv \$templib $lib'
+ archive_expsym_cmds_CXX='tempext=`echo $shared_ext | $SED -e '\''s/\([^()0-9A-Za-z{}]\)/\\\\\1/g'\''`; templib=`echo $lib | $SED -e "s/\${tempext}\..*/.so/"`; $CC $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags --soname $soname -o \$templib ${wl}-retain-symbols-file,$export_symbols; mv \$templib $lib'
+ # dependencies.
+ output_verbose_link_cmd='templist=`$CC $CFLAGS -v conftest.$objext -o libconftest$shared_ext 2>&1 | grep "ld"`; rm -f libconftest$shared_ext; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
+ hardcode_libdir_flag_spec_CXX='${wl}--rpath,$libdir'
+ # "CC -Bstatic", where "CC" is the KAI C++ compiler.
+ old_archive_cmds_CXX='$CC -Bstatic -o $oldlib $oldobjs'
+ icpc)
+ # Intel C++
+ with_gnu_ld=yes
+ archive_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib'
+ archive_expsym_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+ hardcode_libdir_flag_spec_CXX='${wl}-rpath,$libdir'
+ whole_archive_flag_spec_CXX='${wl}--whole-archive$convenience ${wl}--no-whole-archive'
+ cxx)
+ # Compaq C++
+ archive_expsym_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib ${wl}-retain-symbols-file $wl$export_symbols'
+ runpath_var=LD_RUN_PATH
+ hardcode_libdir_flag_spec_CXX='-rpath $libdir'
+ # dependencies.
+ output_verbose_link_cmd='templist=`$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep "ld"`; templist=`echo $templist | $SED "s/\(^.*ld.*\)\( .*ld .*$\)/\1/"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
+ esac
+ lynxos*)
+ ld_shlibs_CXX=no
+ m88k*)
+ ld_shlibs_CXX=no
+ mvs*)
+ cxx)
+ ld_shlibs_CXX=no
+ ld_shlibs_CXX=no
+ esac
+ netbsd*)
+ if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
+ archive_cmds_CXX='$LD -Bshareable -o $lib $predep_objects $libobjs $deplibs $postdep_objects $linker_flags'
+ wlarc=
+ hardcode_libdir_flag_spec_CXX='-R$libdir'
+ fi
+ # Workaround some broken pre-1.5 toolchains
+ output_verbose_link_cmd='$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep conftest.$objext | $SED -e "s:-lgcc -lc -lgcc::"'
+ osf3*)
+ KCC)
+ RCC)
+ # Rational C++ 2.4.1
+ ld_shlibs_CXX=no
+ cxx)
+ allow_undefined_flag_CXX=' ${wl}-expect_unresolved ${wl}\*'
+ archive_cmds_CXX='$CC -shared${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $soname `test -n "$verstring" && echo ${wl}-set_version $verstring` -update_registry ${objdir}/so_locations -o $lib'
+ # dependencies.
+ output_verbose_link_cmd='templist=`$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep "ld" | grep -v "ld:"`; templist=`echo $templist | $SED "s/\(^.*ld.*\)\( .*ld.*$\)/\1/"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
+ if test "$GXX" = yes && test "$with_gnu_ld" = no; then
+ archive_cmds_CXX='$CC -shared -nostdlib ${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${objdir}/so_locations -o $lib'
+ else
+ ld_shlibs_CXX=no
+ fi
+ esac
+ osf4* | osf5*)
+ KCC)
+ # the KAI C++ compiler.
+ old_archive_cmds_CXX='$CC -o $oldlib $oldobjs'
+ RCC)
+ ld_shlibs_CXX=no
+ cxx)
+ allow_undefined_flag_CXX=' -expect_unresolved \*'
+ archive_cmds_CXX='$CC -shared${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${objdir}/so_locations -o $lib'
+ archive_expsym_cmds_CXX='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done~
+ echo "-hidden">> $lib.exp~
+ $CC -shared$allow_undefined_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -msym -soname $soname -Wl,-input -Wl,$lib.exp `test -n "$verstring" && echo -set_version $verstring` -update_registry $objdir/so_locations -o $lib~
+ $rm $lib.exp'
+ # dependencies.
+ archive_cmds_CXX='$CC -shared -nostdlib ${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${objdir}/so_locations -o $lib'
+ else
+ ld_shlibs_CXX=no
+ fi
+ esac
+ psos*)
+ ld_shlibs_CXX=no
+ sco*)
+ CC)
+ ld_shlibs_CXX=no
+ ld_shlibs_CXX=no
+ esac
+ sunos4*)
+ CC)
+ # Sun C++ 4.x
+ ld_shlibs_CXX=no
+ lcc)
+ # Lucid
+ ld_shlibs_CXX=no
+ ld_shlibs_CXX=no
+ esac
+ solaris*)
+ CC)
+ # Sun C++ 4.2, 5.x and Centerline C++
+ no_undefined_flag_CXX=' -zdefs'
+ archive_cmds_CXX='$CC -G${allow_undefined_flag} -nolib -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+ archive_expsym_cmds_CXX='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
+ $CC -G${allow_undefined_flag} -nolib ${wl}-M ${wl}$lib.exp -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
+ case $host_os in
+ solaris2.0-5 | solaris2.0-5.*) ;;
+ # The C++ compiler is used as linker so we must use $wl
+ # flag to pass the commands to the underlying system
+ # linker.
+ # Supported since Solaris 2.6 (maybe 2.5.1?)
+ whole_archive_flag_spec_CXX='${wl}-z ${wl}allextract$convenience ${wl}-z ${wl}defaultextract'
+ esac
+ # dependencies.
+ output_verbose_link_cmd='templist=`$CC -G $CFLAGS -v conftest.$objext 2>&1 | grep "\-[LR]"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
+ # "CC -xar", where "CC" is the Sun C++ compiler. This is
+ # in the archive.
+ old_archive_cmds_CXX='$CC -xar -o $oldlib $oldobjs'
+ gcx)
+ archive_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
+ # The C++ compiler must be used to create the archive.
+ old_archive_cmds_CXX='$CC $LDFLAGS -archive -o $oldlib $oldobjs'
+ # GNU C++ compiler with Solaris linker
+ no_undefined_flag_CXX=' ${wl}-z ${wl}defs'
+ if $CC --version | grep -v '^2\.7' > /dev/null; then
+ archive_cmds_CXX='$CC -shared -nostdlib $LDFLAGS $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
+ $CC -shared -nostdlib ${wl}-M $wl$lib.exp -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
+ output_verbose_link_cmd="$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep \"\-L\""
+ else
+ # g++ 2.7 appears to require `-G' NOT `-shared' on this
+ # platform.
+ archive_cmds_CXX='$CC -G -nostdlib $LDFLAGS $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
+ $CC -G -nostdlib ${wl}-M $wl$lib.exp -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
+ output_verbose_link_cmd="$CC -G $CFLAGS -v conftest.$objext 2>&1 | grep \"\-L\""
+ fi
+ hardcode_libdir_flag_spec_CXX='${wl}-R $wl$libdir'
+ fi
+ esac
+ sysv5OpenUNIX8* | sysv5UnixWare7* | sysv5uw[78]* | unixware7*)
+ tandem*)
+ NCC)
+ # NonStop-UX NCC 3.20
+ ld_shlibs_CXX=no
+ ld_shlibs_CXX=no
+ esac
+ vxworks*)
+ ld_shlibs_CXX=no
+ ld_shlibs_CXX=no
+esac
+echo "$as_me:$LINENO: result: $ld_shlibs_CXX" >&5
+echo "${ECHO_T}$ld_shlibs_CXX" >&6
+test "$ld_shlibs_CXX" = no && can_build_shared=no
+GCC_CXX="$GXX"
+LD_CXX="$LD"
+cat > conftest.$ac_ext <<EOF
+class Foo
+public:
+ Foo (void) { a = 0; }
+private:
+ int a;
+EOF
+if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+ (eval $ac_compile) 2>&5
+ ac_status=$?
+ (exit $ac_status); }; then
+ # Parse the compiler output and extract the necessary
+ # objects, libraries and library flags.
+ # Sentinel used to keep track of whether or not we are before
+ # the conftest object file.
+ pre_test_object_deps_done=no
+ # The `*' in the case matches for architectures that use `case' in
+ # $output_verbose_cmd can trigger glob expansion during the loop
+ # eval without this substitution.
+ output_verbose_link_cmd="`$echo \"X$output_verbose_link_cmd\" | $Xsed -e \"$no_glob_subst\"`"
+ for p in `eval $output_verbose_link_cmd`; do
+ case $p in
+ -L* | -R* | -l*)
+ # Some compilers place space between "-{L,R}" and the path.
+ # Remove the space.
+ if test $p = "-L" \
+ || test $p = "-R"; then
+ prev=$p
+ continue
+ else
+ prev=
+ fi
+ if test "$pre_test_object_deps_done" = no; then
+ case $p in
+ -L* | -R*)
+ # Internal compiler library paths should come after those
+ # provided the user. The postdeps already come after the
+ # user supplied libs so there is no need to process them.
+ if test -z "$compiler_lib_search_path_CXX"; then
+ compiler_lib_search_path_CXX="${prev}${p}"
+ else
+ compiler_lib_search_path_CXX="${compiler_lib_search_path_CXX} ${prev}${p}"
+ fi
+ # The "-l" case would never come before the object being
+ # linked, so don't bother handling this case.
+ esac
+ else
+ if test -z "$postdeps_CXX"; then
+ postdeps_CXX="${prev}${p}"
+ else
+ postdeps_CXX="${postdeps_CXX} ${prev}${p}"
+ fi
+ fi
+ *.$objext)
+ # This assumes that the test object file only shows up
+ # once in the compiler output.
+ if test "$p" = "conftest.$objext"; then
+ pre_test_object_deps_done=yes
+ continue
+ fi
+ if test -z "$predep_objects_CXX"; then
+ predep_objects_CXX="$p"
+ else
+ predep_objects_CXX="$predep_objects_CXX $p"
+ fi
+ else
+ if test -z "$postdep_objects_CXX"; then
+ postdep_objects_CXX="$p"
+ else
+ postdep_objects_CXX="$postdep_objects_CXX $p"
+ fi
+ fi
+ *) ;; # Ignore the rest.
+ esac
+ done
+ # Clean up.
+ rm -f a.out a.exe
+else
+ echo "libtool.m4: error: problem compiling CXX test program"
+fi
+$rm -f confest.$objext
+case " $postdeps_CXX " in
+*" -lc "*) archive_cmds_need_lc_CXX=no ;;
+esac
+lt_prog_compiler_wl_CXX=
+lt_prog_compiler_pic_CXX=
+lt_prog_compiler_static_CXX=
+echo "$as_me:$LINENO: checking for $compiler option to produce PIC" >&5
+echo $ECHO_N "checking for $compiler option to produce PIC... $ECHO_C" >&6
+ # C++ specific cases for pic, static, wl, etc.
+ lt_prog_compiler_wl_CXX='-Wl,'
+ lt_prog_compiler_static_CXX='-static'
case $host_os in
- hpux9*) archive_cmds='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib' ;;
- *) archive_cmds='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags' ;;
+ aix*)
+ # All AIX code is PIC.
+ if test "$host_cpu" = ia64; then
+ # AIX 5 now supports IA64 processor
+ lt_prog_compiler_static_CXX='-Bstatic'
+ fi
+ amigaos*)
+ # FIXME: we need at least 68020 code to build shared libraries, but
+ # adding the `-m68020' flag to GCC prevents building anything better,
+ # like `-m68040'.
+ lt_prog_compiler_pic_CXX='-m68020 -resident32 -malways-restore-a4'
+ beos* | cygwin* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
+ # PIC is the default for these OSes.
+ mingw* | os2* | pw32*)
+ # This hack is so that the source file can tell whether it is being
+ # built for inclusion in a dll (and should export symbols for example).
+ lt_prog_compiler_pic_CXX='-DDLL_EXPORT'
+ darwin* | rhapsody*)
+ # PIC is the default on this platform
+ # Common symbols not allowed in MH_DYLIB files
+ lt_prog_compiler_pic_CXX='-fno-common'
+ *djgpp*)
+ # DJGPP does not support shared libraries at all
+ sysv4*MP*)
+ if test -d /usr/nec; then
+ lt_prog_compiler_pic_CXX=-Kconform_pic
+ fi
+ hpux*)
+ # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
+ # not for PA HP-UX.
+ hppa*64*|ia64*)
+ lt_prog_compiler_pic_CXX='-fPIC'
+ esac
esac
- hardcode_libdir_flag_spec='${wl}+b ${wl}$libdir'
- hardcode_libdir_separator=:
- hardcode_minus_L=yes # Not in the search PATH, but as the default
- # location of the library.
- export_dynamic_flag_spec='${wl}-E'
+ else
+ case $host_os in
+ aix4* | aix5*)
+ else
+ lt_prog_compiler_static_CXX='-bnso -bI:/lib/syscalls.exp'
+ fi
+ chorus*)
+ cxch68)
+ # _LT_AC_TAGVAR(lt_prog_compiler_static, CXX)="--no_auto_instantiation -u __main -u __premain -u _abort -r $COOL_DIR/lib/libOrb.a $MVME_DIR/lib/CC/libC.a $MVME_DIR/lib/classix/libcx.s.a"
+ esac
+ dgux*)
+ ec++)
+ lt_prog_compiler_pic_CXX='-KPIC'
+ ghcx)
+ lt_prog_compiler_pic_CXX='-pic'
+ esac
+ # FreeBSD uses GNU C++
+ hpux9* | hpux10* | hpux11*)
+ CC)
+ lt_prog_compiler_static_CXX="${ac_cv_prog_cc_wl}-a ${ac_cv_prog_cc_wl}archive"
+ if test "$host_cpu" != ia64; then
+ lt_prog_compiler_pic_CXX='+Z'
+ fi
+ aCC)
+ hppa*64*|ia64*)
+ # +Z the default
+ esac
+ esac
+ irix5* | irix6* | nonstopux*)
+ CC)
+ lt_prog_compiler_static_CXX='-non_shared'
+ # CC pic flag -KPIC is the default.
+ esac
+ linux*)
+ KCC)
+ # KAI C++ Compiler
+ lt_prog_compiler_wl_CXX='--backend -Wl,'
+ icpc)
+ # Intel C++
+ cxx)
+ # Compaq C++
+ # Make sure the PIC flag is empty. It appears that all Alpha
+ # Linux and Compaq Tru64 Unix objects are PIC.
+ esac
+ lynxos*)
+ m88k*)
+ mvs*)
+ cxx)
+ lt_prog_compiler_pic_CXX='-W c,exportall'
+ esac
+ netbsd*)
+ osf3* | osf4* | osf5*)
+ KCC)
+ RCC)
+ cxx)
+ # Digital/Compaq C++
+ esac
+ psos*)
+ sco*)
+ CC)
+ esac
+ solaris*)
+ CC)
+ lt_prog_compiler_wl_CXX='-Qoption ld '
+ gcx)
+ lt_prog_compiler_pic_CXX='-PIC'
+ esac
+ sunos4*)
+ CC)
+ # Sun C++ 4.x
+ lcc)
+ # Lucid
+ esac
+ tandem*)
+ NCC)
+ esac
+ unixware*)
+ vxworks*)
+ lt_prog_compiler_can_build_shared_CXX=no
+ esac
+ fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_CXX" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_CXX" >&6
+# Check to make sure the PIC flag actually works.
+if test -n "$lt_prog_compiler_pic_CXX"; then
+echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic_CXX works" >&5
+echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic_CXX works... $ECHO_C" >&6
+if test "${lt_prog_compiler_pic_works_CXX+set}" = set; then
+ echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+ lt_prog_compiler_pic_works_CXX=no
+ ac_outfile=conftest.$ac_objext
+ printf "$lt_simple_compile_test_code" > conftest.$ac_ext
+ lt_compiler_flag="$lt_prog_compiler_pic_CXX -DPIC"
+ # Insert the option either (1) after the last *FLAGS variable, or
+ # (2) before a word containing "conftest.", or (3) at the end.
+ # Note that $ac_compile itself does not contain backslashes and begins
+ # with a dollar sign (not a hyphen), so the echo should work correctly.
+ # The option is referenced via a variable to avoid confusing sed.
+ lt_compile=`echo "$ac_compile" | $SED \
+ -e 's:.*FLAGS}? :&$lt_compiler_flag :; t' \
+ -e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
+ -e 's:$: $lt_compiler_flag:'`
+ (eval echo "\"\$as_me:11522: $lt_compile\"" >&5)
+ (eval "$lt_compile" 2>conftest.err)
+ ac_status=$?
+ cat conftest.err >&5
+ echo "$as_me:11526: \$? = $ac_status" >&5
+ if (exit $ac_status) && test -s "$ac_outfile"; then
+ # The compiler can only warn and ignore the option if not recognized
+ # So say no if there are warnings
+ if test ! -s conftest.err; then
+ lt_prog_compiler_pic_works_CXX=yes
+ fi
+ fi
+ $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works_CXX" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_works_CXX" >&6
+if test x"$lt_prog_compiler_pic_works_CXX" = xyes; then
+ case $lt_prog_compiler_pic_CXX in
+ *) lt_prog_compiler_pic_CXX=" $lt_prog_compiler_pic_CXX" ;;
+ esac
+else
+fi
+fi
+case "$host_os" in
+ # For platforms which do not support PIC, -DPIC is meaningless:
+ *djgpp*)
+ lt_prog_compiler_pic_CXX="$lt_prog_compiler_pic_CXX -DPIC"
+esac
- irix5* | irix6* | nonstopux*)
- archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- hardcode_libdir_flag_spec='${wl}-rpath ${wl}$libdir'
+echo "$as_me:$LINENO: checking if $compiler supports -c -o file.$ac_objext" >&5
+echo $ECHO_N "checking if $compiler supports -c -o file.$ac_objext... $ECHO_C" >&6
+if test "${lt_cv_prog_compiler_c_o_CXX+set}" = set; then
+else
+ lt_cv_prog_compiler_c_o_CXX=no
+ $rm -r conftest 2>/dev/null
+ mkdir conftest
+ cd conftest
+ mkdir out
+ lt_compiler_flag="-o out/conftest2.$ac_objext"
+ (eval echo "\"\$as_me:11582: $lt_compile\"" >&5)
+ (eval "$lt_compile" 2>out/conftest.err)
+ ac_status=$?
+ cat out/conftest.err >&5
+ echo "$as_me:11586: \$? = $ac_status" >&5
+ if (exit $ac_status) && test -s out/conftest2.$ac_objext
+ then
+ if test ! -s out/conftest.err; then
+ lt_cv_prog_compiler_c_o_CXX=yes
+ fi
+ fi
+ chmod u+w .
+ $rm conftest*
+ # SGI C++ compiler will create directory out/ii_files/ for
+ # template instantiation
+ test -d out/ii_files && $rm out/ii_files/* && rmdir out/ii_files
+ $rm out/* && rmdir out
+ cd ..
+ rmdir conftest
+ $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o_CXX" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_c_o_CXX" >&6
+hard_links="nottested"
+if test "$lt_cv_prog_compiler_c_o_CXX" = no && test "$need_locks" != no; then
+ # do not overwrite the value of need_locks provided by the user
+ echo "$as_me:$LINENO: checking if we can lock with hard links" >&5
+echo $ECHO_N "checking if we can lock with hard links... $ECHO_C" >&6
+ hard_links=yes
+ $rm conftest*
+ ln conftest.a conftest.b 2>/dev/null && hard_links=no
+ touch conftest.a
+ ln conftest.a conftest.b 2>&5 || hard_links=no
+ echo "$as_me:$LINENO: result: $hard_links" >&5
+echo "${ECHO_T}$hard_links" >&6
+ if test "$hard_links" = no; then
+ { echo "$as_me:$LINENO: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
+echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
+ need_locks=warn
+ fi
+else
+ need_locks=no
+fi
+ export_symbols_cmds_CXX='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
+ case $host_os in
+ aix4* | aix5*)
+ # If we're using GNU nm, then we don't want the "-C" option.
+ # -C means demangle to AIX nm, but means don't demangle with GNU nm
+ if $NM -V 2>&1 | grep 'GNU' > /dev/null; then
+ export_symbols_cmds_CXX='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
else
- archive_cmds='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- hardcode_libdir_flag_spec='-rpath $libdir'
+ export_symbols_cmds_CXX='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
fi
- link_all_deplibs=yes
+ pw32*)
+ export_symbols_cmds_CXX="$ltdll_cmds"
+ cygwin* | mingw*)
+ export_symbols_cmds_CXX='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGS] /s/.* \([^ ]*\)/\1 DATA/'\'' | $SED -e '\''/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
+ esac
- netbsd*)
- archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags' # a.out
+variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
+ variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
+fi
+# Do we need to explicitly link libc?
+case "x$archive_cmds_need_lc_CXX" in
+x|xyes)
+ # Assume -lc should be added
+ if test "$enable_shared" = yes && test "$GCC" = yes; then
+ case $archive_cmds_CXX in
+ # FIXME: we may have to deal with multi-command sequences.
+ '$CC '*)
+ # Test whether the compiler implicitly links with -lc since on some
+ # systems, -lgcc has to come before -lc. If gcc already passes -lc
+ # to ld, don't add -lc before -lgcc.
+ echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
+echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
+ $rm conftest*
+ if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+ ac_status=$?
+ (exit $ac_status); } 2>conftest.err; then
+ soname=conftest
+ lib=conftest
+ libobjs=conftest.$ac_objext
+ deplibs=
+ wl=$lt_prog_compiler_wl_CXX
+ compiler_flags=-v
+ linker_flags=-v
+ verstring=
+ output_objdir=.
+ libname=conftest
+ lt_save_allow_undefined_flag=$allow_undefined_flag_CXX
+ if { (eval echo "$as_me:$LINENO: \"$archive_cmds_CXX 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
+ (eval $archive_cmds_CXX 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
+ ac_status=$?
+ then
+ else
+ fi
+ allow_undefined_flag_CXX=$lt_save_allow_undefined_flag
+ else
+ cat conftest.err 1>&5
+ fi
+ $rm conftest*
+ echo "$as_me:$LINENO: result: $archive_cmds_need_lc_CXX" >&5
+echo "${ECHO_T}$archive_cmds_need_lc_CXX" >&6
+ esac
+ fi
+esac
+echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
+echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
+libname_spec='lib$name'
+soname_spec=
+shrext_cmds=".so"
+postinstall_cmds=
+finish_cmds=
+finish_eval=
+shlibpath_var=
+shlibpath_overrides_runpath=unknown
+version_type=none
+dynamic_linker="$host_os ld.so"
+sys_lib_dlsearch_path_spec="/lib /usr/lib"
+ sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
+ if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
+ # if the path contains ";" then we assume it to be the separator
+ # otherwise default to the standard path separator (i.e. ":") - it is
+ # assumed that no part of a normal pathname contains ";" but that should
+ # okay in the real world where ";" in dirpaths is itself problematic.
+ sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
+ else
+ sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
+ fi
+else
+ sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
+fi
+need_lib_prefix=unknown
+hardcode_into_libs=no
+# when you set need_version to no, make sure it does not cause -set_version
+# flags to be left without arguments
+need_version=unknown
+case $host_os in
+aix3*)
+ version_type=linux
+ library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
+ shlibpath_var=LIBPATH
+ # AIX 3 has no versioning support, so we append a major version to the name.
+ soname_spec='${libname}${release}${shared_ext}$major'
+aix4* | aix5*)
+ need_lib_prefix=no
+ need_version=no
+ hardcode_into_libs=yes
+ # AIX 5 supports IA64
+ library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
+ shlibpath_var=LD_LIBRARY_PATH
+ else
+ # With GCC up to 2.95.x, collect2 would create an import file
+ # for dependence libraries. The import file would start with
+ # the line `#! .'. This would cause the generated library to
+ # depend on `.', always an invalid library. This was fixed in
+ # development snapshots of GCC prior to 3.0.
+ case $host_os in
+ aix4 | aix4.[01] | aix4.[01].*)
+ if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
+ echo ' yes '
+ echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
+ else
+ can_build_shared=no
+ fi
+ esac
+ # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
+ # soname into executable. Probably we can add versioning support to
+ # collect2, so additional links can be useful in future.
+ if test "$aix_use_runtimelinking" = yes; then
+ # If using run time linking (on AIX 4.2 or later) use lib<name>.so
+ # instead of lib<name>.a to let people know that these are not
+ # typical AIX shared libraries.
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
else
- archive_cmds='$LD -shared -o $lib $libobjs $deplibs $linker_flags' # ELF
+ # We preserve .a as extension for shared libraries through AIX4.2
+ # and later when we are not doing run time linking.
+ library_names_spec='${libname}${release}.a $libname.a'
fi
+ fi
+amigaos*)
+ library_names_spec='$libname.ixlibrary $libname.a'
+ # Create ${libname}_ixlibrary.a entries in /sys/libs.
+ finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
+beos*)
+ library_names_spec='${libname}${shared_ext}'
+ dynamic_linker="$host_os ld.so"
+ shlibpath_var=LIBRARY_PATH
+bsdi4*)
+ need_version=no
+ finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
+ sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
+ sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
+ # the default ld.so.conf also contains /usr/contrib/lib and
+ # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
+ # libtool to hard-code these into programs
+cygwin* | mingw* | pw32*)
+ version_type=windows
+ shrext_cmds=".dll"
+ need_version=no
+ case $GCC,$host_os in
+ yes,cygwin* | yes,mingw* | yes,pw32*)
+ library_names_spec='$libname.dll.a'
+ # DLL is installed to $(libdir)/../bin by postinstall_cmds
+ postinstall_cmds='base_file=`basename \${file}`~
+ dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
+ dldir=$destdir/`dirname \$dlpath`~
+ test -d \$dldir || mkdir -p \$dldir~
+ $install_prog $dir/$dlname \$dldir/$dlname'
+ postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
+ dlpath=$dir/\$dldll~
+ $rm \$dlpath'
+ shlibpath_overrides_runpath=yes
+ case $host_os in
+ cygwin*)
+ # Cygwin DLLs use 'cyg' prefix rather than 'lib'
+ soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+ sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
+ mingw*)
+ # MinGW DLLs use traditional 'lib' prefix
+ soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+ if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
+ # It is most probably a Windows format PATH printed by
+ # mingw gcc, but we are running on Cygwin. Gcc prints its search
+ # path with ; separators, and with drive letters. We can handle the
+ # drive letters (cygwin fileutils understands them), so leave them,
+ # especially as we might pass files found there to a mingw objdump,
+ # which wouldn't understand a cygwinified path. Ahh.
+ else
+ fi
+ pw32*)
+ # pw32 DLLs use 'pw' prefix rather than 'lib'
+ library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/./-/g'`${versuffix}${shared_ext}'
+ esac
- newsos6)
- archive_cmds='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
+ library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
+ esac
+ dynamic_linker='Win32 ld.exe'
+ # FIXME: first we should search . and the directory the executable is in
+ shlibpath_var=PATH
- openbsd*)
- if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
- archive_cmds='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
- hardcode_libdir_flag_spec='${wl}-rpath,$libdir'
+darwin* | rhapsody*)
+ dynamic_linker="$host_os dyld"
+ version_type=darwin
+ need_version=no
+ library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
+ soname_spec='${libname}${release}${major}$shared_ext'
+ shlibpath_var=DYLD_LIBRARY_PATH
+ shrext_cmds='$(test .$module = .yes && echo .so || echo .dylib)'
+ # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
+ if test "$GCC" = yes; then
+ sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
+ else
+ sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
+ fi
+ sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
+dgux*)
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
+freebsd1*)
+ dynamic_linker=no
+kfreebsd*-gnu)
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
+ shlibpath_overrides_runpath=no
+ dynamic_linker='GNU ld.so'
+freebsd*)
+ objformat=`test -x /usr/bin/objformat && /usr/bin/objformat || echo aout`
+ version_type=freebsd-$objformat
+ case $version_type in
+ freebsd-elf*)
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
+ need_version=no
+ freebsd-*)
+ library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
+ need_version=yes
+ esac
+ case $host_os in
+ freebsd2*)
+ freebsd3.01* | freebsdelf3.01*)
+ *) # from 3.2 on
+ esac
+gnu*)
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
+hpux9* | hpux10* | hpux11*)
+ # Give a soname corresponding to the major version so that dld.sl refuses to
+ # link against other versions.
+ version_type=sunos
+ need_version=no
+ ia64*)
+ shrext_cmds='.so'
+ dynamic_linker="$host_os dld.so"
+ shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
+ if test "X$HPUX_IA64_MODE" = X32; then
+ sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
else
- case "$host_os" in
- openbsd[01].* | openbsd2.[0-7] | openbsd2.[0-7].*)
+ sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
+ fi
+ sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
+ hppa*64*)
+ shrext_cmds='.sl'
+ dynamic_linker="$host_os dld.sl"
+ shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
+ sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
+ shrext_cmds='.sl'
+ shlibpath_var=SHLIB_PATH
+ shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
+ esac
+ # HP-UX runs *really* slowly unless shared libraries are mode 555.
+ postinstall_cmds='chmod 555 $lib'
+irix5* | irix6* | nonstopux*)
+ case $host_os in
+ nonstopux*) version_type=nonstopux ;;
+ if test "$lt_cv_prog_gnu_ld" = yes; then
+ else
+ version_type=irix
+ fi ;;
+ esac
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
+ case $host_os in
+ irix5* | nonstopux*)
+ libsuff= shlibsuff=
+ case $LD in # libtool.m4 will add one of these switches to LD
+ *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
+ libsuff= shlibsuff= libmagic=32-bit;;
+ *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
+ libsuff=32 shlibsuff=N32 libmagic=N32;;
+ *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
+ libsuff=64 shlibsuff=64 libmagic=64-bit;;
+ *) libsuff= shlibsuff= libmagic=never-match;;
+ esac
+ esac
+ shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
+ sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
+ sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
+# No shared lib support for Linux oldld, aout, or coff.
+linux*oldld* | linux*aout* | linux*coff*)
+ dynamic_linker=no
+# This must be Linux ELF.
+linux*)
+ need_version=no
+ finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
+ # This implies no fast_install, which is unacceptable.
+ # Some rework will be needed to allow for fast_install
+ # before this can be enabled.
+ # find out which ABI we are using
+ libsuff=
+ x86_64*|s390x*|powerpc64*)
+ echo '#line 12093 "configure"' > conftest.$ac_ext
+ ac_status=$?
+ case `/usr/bin/file conftest.$ac_objext` in
+ *64-bit*)
+ libsuff=64
+ sys_lib_search_path_spec="/lib${libsuff} /usr/lib${libsuff} /usr/local/lib${libsuff}"
esac
fi
+ rm -rf conftest*
+ esac
- os2*)
- hardcode_libdir_flag_spec='-L$libdir'
- allow_undefined_flag=unsupported
- archive_cmds='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
- old_archive_from_new_cmds='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
+ # Append ld.so.conf contents to the search path
+ if test -f /etc/ld.so.conf; then
+ lt_ld_extra=`$SED -e 's/:,\t/ /g;s/=^=*$//;s/=^= * / /g' /etc/ld.so.conf | tr '\n' ' '`
+ sys_lib_dlsearch_path_spec="/lib${libsuff} /usr/lib${libsuff} $lt_ld_extra"
+ fi
+ # We used to test for /lib/ld.so.1 and disable shared libraries on
+ # powerpc, because MkLinux only supported shared libraries with the
+ # GNU dynamic linker. Since this was broken with cross compilers,
+ # most powerpc-linux boxes support dynamic linking these days and
+ # people can always --disable-shared, the test was removed, and we
+ # assume the GNU/Linux dynamic linker is in use.
+ dynamic_linker='GNU/Linux ld.so'
+knetbsd*-gnu)
+ need_version=no
+netbsd*)
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
+ finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
+ dynamic_linker='NetBSD (a.out) ld.so'
+ else
+ dynamic_linker='NetBSD ld.elf_so'
+ fi
+newsos6)
+nto-qnx*)
+ need_version=no
+openbsd*)
+ need_version=yes
+ if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
+ case $host_os in
+ openbsd2.[89] | openbsd2.[89].*)
+ esac
+ else
+ fi
+os2*)
+ libname_spec='$name'
+ library_names_spec='$libname${shared_ext} $libname.a'
+ dynamic_linker='OS/2 ld.exe'
+osf3* | osf4* | osf5*)
+ version_type=osf
+ need_version=no
+ sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
+ sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
+sco3.2v5*)
+ version_type=osf
+solaris*)
+ need_version=no
+ # ldd complains unless libraries are executable
+ postinstall_cmds='chmod +x $lib'
+sunos4*)
+ finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
+ fi
+ need_version=yes
+sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
+ case $host_vendor in
+ sni)
+ export_dynamic_flag_spec='${wl}-Blargedynsym'
+ siemens)
+ motorola)
+ need_version=no
+ sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
+ esac
+sysv4*MP*)
+ if test -d /usr/nec ;then
+ library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
+ soname_spec='$libname${shared_ext}.$major'
+ fi
+uts4*)
+ dynamic_linker=no
+esac
+echo "$as_me:$LINENO: result: $dynamic_linker" >&5
+echo "${ECHO_T}$dynamic_linker" >&6
+test "$dynamic_linker" = no && can_build_shared=no
+echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
+echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
+hardcode_action_CXX=
+if test -n "$hardcode_libdir_flag_spec_CXX" || \
+ test -n "$runpath_var CXX" || \
+ test "X$hardcode_automatic_CXX"="Xyes" ; then
+ # We can hardcode non-existant directories.
+ if test "$hardcode_direct_CXX" != no &&
+ # If the only mechanism to avoid hardcoding is shlibpath_var, we
+ # have to relink, otherwise we might link with an installed library
+ # when we should be linking with a yet-to-be-installed one
+ ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, CXX)" != no &&
+ test "$hardcode_minus_L_CXX" != no; then
+ # Linking always hardcodes the temporary library directory.
+ hardcode_action_CXX=relink
+ else
+ # We can link without hardcoding, and we can hardcode nonexisting dirs.
+ hardcode_action_CXX=immediate
+ fi
+else
+ # We cannot hardcode anything, or else we can only hardcode existing
+ # directories.
+ hardcode_action_CXX=unsupported
+fi
+echo "$as_me:$LINENO: result: $hardcode_action_CXX" >&5
+echo "${ECHO_T}$hardcode_action_CXX" >&6
+if test "$hardcode_action_CXX" = relink; then
+ # Fast installation is not supported
+ enable_fast_install=no
+elif test "$shlibpath_overrides_runpath" = yes ||
+ test "$enable_shared" = no; then
+ # Fast installation is not necessary
+ enable_fast_install=needless
+fi
+striplib=
+old_striplib=
+echo "$as_me:$LINENO: checking whether stripping libraries is possible" >&5
+echo $ECHO_N "checking whether stripping libraries is possible... $ECHO_C" >&6
+if test -n "$STRIP" && $STRIP -V 2>&1 | grep "GNU strip" >/dev/null; then
+ test -z "$old_striplib" && old_striplib="$STRIP --strip-debug"
+ test -z "$striplib" && striplib="$STRIP --strip-unneeded"
+ echo "$as_me:$LINENO: result: yes" >&5
+echo "${ECHO_T}yes" >&6
+else
+# FIXME - insert some real tests, host_os isn't really good enough
+ case $host_os in
+ darwin*)
+ if test -n "$STRIP" ; then
+ striplib="$STRIP -x"
+ else
+fi
+ esac
+fi
- osf3*)
- allow_undefined_flag=' ${wl}-expect_unresolved ${wl}\*'
- archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- allow_undefined_flag=' -expect_unresolved \*'
- archive_cmds='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- fi
+if test "x$enable_dlopen" != xyes; then
+ enable_dlopen=unknown
+ enable_dlopen_self=unknown
+ enable_dlopen_self_static=unknown
+else
+ lt_cv_dlopen=no
+ lt_cv_dlopen_libs=
+ case $host_os in
+ beos*)
+ lt_cv_dlopen="load_add_on"
+ lt_cv_dlopen_self=yes
- osf4* | osf5*) # as osf3* with the addition of -msym flag
- archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- archive_cmds='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- archive_expsym_cmds='for i in `cat $export_symbols`; do printf "-exported_symbol " >> $lib.exp; echo "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
- $LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${objdir}/so_locations -o $lib~$rm $lib.exp'
+ mingw* | pw32*)
+ lt_cv_dlopen="LoadLibrary"
- #Both c and cxx compiler support -rpath directly
+ cygwin*)
+ lt_cv_dlopen="dlopen"
+ darwin*)
+ # if libdl is installed we need to link against it
+ echo "$as_me:$LINENO: checking for dlopen in -ldl" >&5
+echo $ECHO_N "checking for dlopen in -ldl... $ECHO_C" >&6
+if test "${ac_cv_lib_dl_dlopen+set}" = set; then
+else
+ ac_check_lib_save_LIBS=$LIBS
+LIBS="-ldl $LIBS"
+cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h. */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h. */
+/* Override any gcc2 internal prototype to avoid an error. */
+#ifdef __cplusplus
+extern "C"
+#endif
+/* We use char because int might match the return type of a gcc2
+ builtin and then its argument prototype would still apply. */
+char dlopen ();
+int
+main ()
+dlopen ();
+ return 0;
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+ (eval $ac_link) 2>conftest.er1
+ ac_status=$?
+ grep -v '^ *+' conftest.er1 >conftest.err
+ rm -f conftest.er1
+ (exit $ac_status); } &&
+ || test ! -s conftest.err'
+ { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+ (eval $ac_try) 2>&5
+ ac_status=$?
+ (exit $ac_status); }; } &&
+ { ac_try='test -s conftest$ac_exeext'
+ ac_status=$?
+ (exit $ac_status); }; }; then
+ ac_cv_lib_dl_dlopen=yes
+else
+ echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+ac_cv_lib_dl_dlopen=no
+fi
+rm -f conftest.err conftest.$ac_objext \
+ conftest$ac_exeext conftest.$ac_ext
+LIBS=$ac_check_lib_save_LIBS
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_dl_dlopen" >&5
+echo "${ECHO_T}$ac_cv_lib_dl_dlopen" >&6
+if test $ac_cv_lib_dl_dlopen = yes; then
+ lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-ldl"
+else
+ lt_cv_dlopen="dyld"
+fi
+ echo "$as_me:$LINENO: checking for shl_load" >&5
+echo $ECHO_N "checking for shl_load... $ECHO_C" >&6
+if test "${ac_cv_func_shl_load+set}" = set; then
+else
+ cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h. */
+_ACEOF
+/* Define shl_load to an innocuous variant, in case <limits.h> declares shl_load.
+ For example, HP-UX 11i <limits.h> declares gettimeofday. */
+#define shl_load innocuous_shl_load
+/* System header to define __stub macros and hopefully few prototypes,
+ which can conflict with char shl_load (); below.
+ Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
+ <limits.h> exists even on freestanding compilers. */
+#ifdef __STDC__
+# include <limits.h>
+#else
+# include <assert.h>
+#endif
+#undef shl_load
+#ifdef __cplusplus
+extern "C"
+#endif
+char shl_load ();
+/* The GNU C library defines this for functions which it implements
+ to always fail with ENOSYS. Some functions are actually named
+ something starting with __ and the normal name is an alias. */
+#if defined (__stub_shl_load) || defined (__stub___shl_load)
+choke me
+#else
+char (*f) () = shl_load;
+#endif
+#ifdef __cplusplus
+#endif
+int
+main ()
+return f != shl_load;
+ return 0;
+_ACEOF
+ ac_status=$?
+ ac_status=$?
+ ac_status=$?
+ ac_cv_func_shl_load=yes
+else
+ac_cv_func_shl_load=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_func_shl_load" >&5
+echo "${ECHO_T}$ac_cv_func_shl_load" >&6
+if test $ac_cv_func_shl_load = yes; then
+ lt_cv_dlopen="shl_load"
+else
+ echo "$as_me:$LINENO: checking for shl_load in -ldld" >&5
+echo $ECHO_N "checking for shl_load in -ldld... $ECHO_C" >&6
+if test "${ac_cv_lib_dld_shl_load+set}" = set; then
+else
+LIBS="-ldld $LIBS"
+/* confdefs.h. */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char shl_load ();
+int
+main ()
+shl_load ();
+ return 0;
+_ACEOF
+ ac_status=$?
+ ac_status=$?
+ ac_status=$?
+ ac_cv_lib_dld_shl_load=yes
+else
+ac_cv_lib_dld_shl_load=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_dld_shl_load" >&5
+echo "${ECHO_T}$ac_cv_lib_dld_shl_load" >&6
+if test $ac_cv_lib_dld_shl_load = yes; then
+ lt_cv_dlopen="shl_load" lt_cv_dlopen_libs="-dld"
+else
+ echo "$as_me:$LINENO: checking for dlopen" >&5
+echo $ECHO_N "checking for dlopen... $ECHO_C" >&6
+if test "${ac_cv_func_dlopen+set}" = set; then
+else
+/* confdefs.h. */
+_ACEOF
+/* Define dlopen to an innocuous variant, in case <limits.h> declares dlopen.
+#define dlopen innocuous_dlopen
+ which can conflict with char dlopen (); below.
+#ifdef __STDC__
+#else
+#endif
+#undef dlopen
+#ifdef __cplusplus
+extern "C"
+#endif
+char dlopen ();
+#if defined (__stub_dlopen) || defined (__stub___dlopen)
+choke me
+#else
+char (*f) () = dlopen;
+#endif
+#ifdef __cplusplus
+#endif
+int
+main ()
+return f != dlopen;
+ return 0;
+_ACEOF
+ ac_status=$?
+ ac_status=$?
+ ac_status=$?
+ ac_cv_func_dlopen=yes
+else
+ac_cv_func_dlopen=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_func_dlopen" >&5
+echo "${ECHO_T}$ac_cv_func_dlopen" >&6
+if test $ac_cv_func_dlopen = yes; then
+else
+else
+LIBS="-ldl $LIBS"
+/* confdefs.h. */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char dlopen ();
+int
+main ()
+dlopen ();
+ return 0;
+_ACEOF
+ ac_status=$?
+ ac_status=$?
+ ac_status=$?
+else
+fi
+fi
+else
+ echo "$as_me:$LINENO: checking for dlopen in -lsvld" >&5
+echo $ECHO_N "checking for dlopen in -lsvld... $ECHO_C" >&6
+if test "${ac_cv_lib_svld_dlopen+set}" = set; then
+else
+LIBS="-lsvld $LIBS"
+/* confdefs.h. */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char dlopen ();
+int
+main ()
+dlopen ();
+ return 0;
+_ACEOF
+ ac_status=$?
+ ac_status=$?
+ ac_status=$?
+ ac_cv_lib_svld_dlopen=yes
+else
+ac_cv_lib_svld_dlopen=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_svld_dlopen" >&5
+echo "${ECHO_T}$ac_cv_lib_svld_dlopen" >&6
+if test $ac_cv_lib_svld_dlopen = yes; then
+ lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-lsvld"
+else
+ echo "$as_me:$LINENO: checking for dld_link in -ldld" >&5
+echo $ECHO_N "checking for dld_link in -ldld... $ECHO_C" >&6
+if test "${ac_cv_lib_dld_dld_link+set}" = set; then
+else
+LIBS="-ldld $LIBS"
+/* confdefs.h. */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char dld_link ();
+int
+main ()
+dld_link ();
+ return 0;
+_ACEOF
+ ac_status=$?
+ ac_status=$?
+ ac_status=$?
+ ac_cv_lib_dld_dld_link=yes
+else
+ac_cv_lib_dld_dld_link=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_dld_dld_link" >&5
+echo "${ECHO_T}$ac_cv_lib_dld_dld_link" >&6
+if test $ac_cv_lib_dld_dld_link = yes; then
+ lt_cv_dlopen="dld_link" lt_cv_dlopen_libs="-dld"
+fi
+fi
+fi
+fi
+fi
+fi
+ esac
+ if test "x$lt_cv_dlopen" != xno; then
+ enable_dlopen=yes
+ else
+ enable_dlopen=no
+ fi
+ case $lt_cv_dlopen in
+ dlopen)
+ save_CPPFLAGS="$CPPFLAGS"
+ test "x$ac_cv_header_dlfcn_h" = xyes && CPPFLAGS="$CPPFLAGS -DHAVE_DLFCN_H"
+ save_LDFLAGS="$LDFLAGS"
+ eval LDFLAGS=\"\$LDFLAGS $export_dynamic_flag_spec\"
+ save_LIBS="$LIBS"
+ LIBS="$lt_cv_dlopen_libs $LIBS"
+ echo "$as_me:$LINENO: checking whether a program can dlopen itself" >&5
+echo $ECHO_N "checking whether a program can dlopen itself... $ECHO_C" >&6
+if test "${lt_cv_dlopen_self+set}" = set; then
+else
+ if test "$cross_compiling" = yes; then :
+ lt_cv_dlopen_self=cross
+else
+ lt_dlunknown=0; lt_dlno_uscore=1; lt_dlneed_uscore=2
+ lt_status=$lt_dlunknown
+ cat > conftest.$ac_ext <<EOF
+#line 12964 "configure"
+#include "confdefs.h"
+#if HAVE_DLFCN_H
+#include <dlfcn.h>
+#endif
+#include <stdio.h>
+#ifdef RTLD_GLOBAL
+# define LT_DLGLOBAL RTLD_GLOBAL
+#else
+# ifdef DL_GLOBAL
+# define LT_DLGLOBAL DL_GLOBAL
+# else
+# define LT_DLGLOBAL 0
+# endif
+#endif
+/* We may have to define LT_DLLAZY_OR_NOW in the command line if we
+ find out it does not work in some platform. */
+#ifndef LT_DLLAZY_OR_NOW
+# ifdef RTLD_LAZY
+# define LT_DLLAZY_OR_NOW RTLD_LAZY
+# else
+# ifdef DL_LAZY
+# define LT_DLLAZY_OR_NOW DL_LAZY
+# else
+# ifdef RTLD_NOW
+# define LT_DLLAZY_OR_NOW RTLD_NOW
+# else
+# ifdef DL_NOW
+# define LT_DLLAZY_OR_NOW DL_NOW
+# else
+# define LT_DLLAZY_OR_NOW 0
+# endif
+# endif
+# endif
+# endif
+#endif
+#ifdef __cplusplus
+extern "C" void exit (int);
+#endif
+void fnord() { int i=42;}
+int main ()
+ void *self = dlopen (0, LT_DLGLOBAL|LT_DLLAZY_OR_NOW);
+ int status = $lt_dlunknown;
+ if (self)
+ if (dlsym (self,"fnord")) status = $lt_dlno_uscore;
+ else if (dlsym( self,"_fnord")) status = $lt_dlneed_uscore;
+ /* dlclose (self); */
+ exit (status);
+EOF
+ if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+ (eval $ac_link) 2>&5
+ ac_status=$?
+ echo "$as_me:$LINENO: \$? = $ac_status" >&5
+ (exit $ac_status); } && test -s conftest${ac_exeext} 2>/dev/null; then
+ (./conftest; exit; ) 2>/dev/null
+ lt_status=$?
+ case x$lt_status in
+ x$lt_dlno_uscore) lt_cv_dlopen_self=yes ;;
+ x$lt_dlneed_uscore) lt_cv_dlopen_self=yes ;;
+ x$lt_unknown|x*) lt_cv_dlopen_self=no ;;
+ esac
+ else :
+ # compilation failed
+ lt_cv_dlopen_self=no
+ fi
+fi
+rm -fr conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_dlopen_self" >&5
+echo "${ECHO_T}$lt_cv_dlopen_self" >&6
+ if test "x$lt_cv_dlopen_self" = xyes; then
+ LDFLAGS="$LDFLAGS $link_static_flag"
+ echo "$as_me:$LINENO: checking whether a statically linked program can dlopen itself" >&5
+echo $ECHO_N "checking whether a statically linked program can dlopen itself... $ECHO_C" >&6
+if test "${lt_cv_dlopen_self_static+set}" = set; then
+else
+ lt_cv_dlopen_self_static=cross
+else
+#line 13062 "configure"
+#if HAVE_DLFCN_H
+#include <dlfcn.h>
+#endif
+#include <stdio.h>
+#ifdef RTLD_GLOBAL
+#else
+# ifdef DL_GLOBAL
+# else
+# endif
+#endif
+# ifdef RTLD_LAZY
+# else
+# ifdef DL_LAZY
+# else
+# ifdef RTLD_NOW
+# else
+# ifdef DL_NOW
+# else
+# endif
+# endif
+# endif
+# endif
+#endif
+#ifdef __cplusplus
+#endif
+int main ()
+ if (self)
+ exit (status);
+EOF
+ ac_status=$?
+ lt_status=$?
+ x$lt_dlno_uscore) lt_cv_dlopen_self_static=yes ;;
+ x$lt_dlneed_uscore) lt_cv_dlopen_self_static=yes ;;
+ x$lt_unknown|x*) lt_cv_dlopen_self_static=no ;;
+ esac
+ else :
+ lt_cv_dlopen_self_static=no
+ fi
+fi
+rm -fr conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_dlopen_self_static" >&5
+echo "${ECHO_T}$lt_cv_dlopen_self_static" >&6
fi
+ CPPFLAGS="$save_CPPFLAGS"
+ LDFLAGS="$save_LDFLAGS"
+ LIBS="$save_LIBS"
+ esac
- sco3.2v5*)
- hardcode_shlibpath_var=no
- runpath_var=LD_RUN_PATH
- hardcode_runpath_var=yes
- export_dynamic_flag_spec='${wl}-Bexport'
+ case $lt_cv_dlopen_self in
+ yes|no) enable_dlopen_self=$lt_cv_dlopen_self ;;
+ *) enable_dlopen_self=unknown ;;
+ esac
+ case $lt_cv_dlopen_self_static in
+ yes|no) enable_dlopen_self_static=$lt_cv_dlopen_self_static ;;
+ *) enable_dlopen_self_static=unknown ;;
+ esac
+fi
+# The else clause should only fire when bootstrapping the
+# libtool distribution, otherwise you forgot to ship ltmain.sh
+# with your package, and you will get complaints that there are
+# no rules to generate ltmain.sh.
+if test -f "$ltmain"; then
+ # See if we are running on zsh, and set the options which allow our commands through
+ # without removal of \ escapes.
+ if test -n "${ZSH_VERSION+set}" ; then
+ setopt NO_GLOB_SUBST
+ fi
+ # Now quote all the things that may contain metacharacters while being
+ # careful not to overquote the AC_SUBSTed values. We take copies of the
+ # variables and quote the copies for generation of the libtool script.
+ for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC NM \
+ SED SHELL STRIP \
+ libname_spec library_names_spec soname_spec extract_expsyms_cmds \
+ old_striplib striplib file_magic_cmd finish_cmds finish_eval \
+ deplibs_check_method reload_flag reload_cmds need_locks \
+ lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
+ lt_cv_sys_global_symbol_to_c_name_address \
+ sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
+ old_postinstall_cmds old_postuninstall_cmds \
+ compiler_CXX \
+ CC_CXX \
+ LD_CXX \
+ lt_prog_compiler_wl_CXX \
+ lt_prog_compiler_pic_CXX \
+ lt_prog_compiler_static_CXX \
+ lt_prog_compiler_no_builtin_flag_CXX \
+ export_dynamic_flag_spec_CXX \
+ thread_safe_flag_spec_CXX \
+ whole_archive_flag_spec_CXX \
+ enable_shared_with_static_runtimes_CXX \
+ old_archive_cmds_CXX \
+ old_archive_from_new_cmds_CXX \
+ predep_objects_CXX \
+ postdep_objects_CXX \
+ predeps_CXX \
+ postdeps_CXX \
+ compiler_lib_search_path_CXX \
+ archive_cmds_CXX \
+ archive_expsym_cmds_CXX \
+ postinstall_cmds_CXX \
+ postuninstall_cmds_CXX \
+ old_archive_from_expsyms_cmds_CXX \
+ allow_undefined_flag_CXX \
+ no_undefined_flag_CXX \
+ export_symbols_cmds_CXX \
+ hardcode_libdir_flag_spec_CXX \
+ hardcode_libdir_flag_spec_ld_CXX \
+ hardcode_libdir_separator_CXX \
+ hardcode_automatic_CXX \
+ module_cmds_CXX \
+ module_expsym_cmds_CXX \
+ lt_cv_prog_compiler_c_o_CXX \
+ exclude_expsyms_CXX \
+ include_expsyms_CXX; do
+ case $var in
+ old_archive_cmds_CXX | \
+ old_archive_from_new_cmds_CXX | \
+ archive_cmds_CXX | \
+ archive_expsym_cmds_CXX | \
+ module_cmds_CXX | \
+ module_expsym_cmds_CXX | \
+ old_archive_from_expsyms_cmds_CXX | \
+ export_symbols_cmds_CXX | \
+ extract_expsyms_cmds | reload_cmds | finish_cmds | \
+ postinstall_cmds | postuninstall_cmds | \
+ old_postinstall_cmds | old_postuninstall_cmds | \
+ sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
+ # Double-quote double-evaled strings.
+ eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
+ eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
+ esac
+ done
+ case $lt_echo in
+ *'\$0 --fallback-echo"')
+ lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
+ esac
- solaris*)
- # gcc --version < 3.0 without binutils cannot create self contained
- # shared libraries reliably, requiring libgcc.a to resolve some of
- # the object symbols generated in some cases. Libraries that use
- # assert need libgcc.a to resolve __eprintf, for example. Linking
- # a copy of libgcc.a into every shared library to guarantee resolving
- # such symbols causes other problems: According to Tim Van Holder
- # <tim.van.holder at pandora.be>, C++ libraries end up with a separate
- # (to the application) exception stack for one thing.
- no_undefined_flag=' -z defs'
- if test "$GCC" = yes; then
- case `$CC --version 2>/dev/null` in
- [12].*)
- cat <<EOF 1>&2
+cfgfile="$ofile"
-*** Warning: Releases of GCC earlier than version 3.0 cannot reliably
-*** create self contained shared libraries on Solaris systems, without
-*** introducing a dependency on libgcc.a. Therefore, libtool is disabling
-*** -no-undefined support, which will at least allow you to build shared
-*** libraries. However, you may find that when you link such libraries
-*** into an application without using GCC, you have to manually add
-*** \`gcc --print-libgcc-file-name\` to the link command. We urge you to
-*** upgrade to a newer version of GCC. Another option is to rebuild your
-*** current GCC to use the GNU linker from GNU binutils 2.9.1 or newer.
+ cat <<__EOF__ >> "$cfgfile"
+# ### BEGIN LIBTOOL TAG CONFIG: $tagname
-EOF
+# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
+# Shell to use when invoking shell scripts.
+SHELL=$lt_SHELL
+# Whether or not to build shared libraries.
+build_libtool_libs=$enable_shared
+# Whether or not to build static libraries.
+build_old_libs=$enable_static
+# Whether or not to add -lc for building shared libraries.
+build_libtool_need_lc=$archive_cmds_need_lc_CXX
+# Whether or not to disallow shared libs when runtime libs are static
+allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_CXX
+# Whether or not to optimize for fast installation.
+fast_install=$enable_fast_install
+# The host system.
+host_alias=$host_alias
+host=$host
+# An echo program that does not interpret backslashes.
+echo=$lt_echo
+# The archiver.
+AR=$lt_AR
+AR_FLAGS=$lt_AR_FLAGS
+# A C compiler.
+LTCC=$lt_LTCC
+# A language-specific compiler.
+CC=$lt_compiler_CXX
+# Is the compiler the GNU C compiler?
+with_gcc=$GCC_CXX
+# An ERE matcher.
+EGREP=$lt_EGREP
+# The linker used to build libraries.
+LD=$lt_LD_CXX
+# Whether we need hard or soft links.
+LN_S=$lt_LN_S
+# A BSD-compatible nm program.
+NM=$lt_NM
+# A symbol stripping program
+STRIP=$lt_STRIP
+# Used to examine libraries when file_magic_cmd begins "file"
+MAGIC_CMD=$MAGIC_CMD
+# Used on cygwin: DLL creation program.
+DLLTOOL="$DLLTOOL"
+# Used on cygwin: object dumper.
+OBJDUMP="$OBJDUMP"
+# Used on cygwin: assembler.
+AS="$AS"
+# The name of the directory that contains temporary libtool files.
+objdir=$objdir
+# How to create reloadable object files.
+reload_flag=$lt_reload_flag
+reload_cmds=$lt_reload_cmds
+# How to pass a linker flag through the compiler.
+wl=$lt_lt_prog_compiler_wl_CXX
+# Object file suffix (normally "o").
+objext="$ac_objext"
+# Old archive suffix (normally "a").
+libext="$libext"
+# Shared library suffix (normally ".so").
+shrext_cmds='$shrext_cmds'
+# Executable file suffix (normally "").
+exeext="$exeext"
+# Additional compiler flags for building library objects.
+pic_flag=$lt_lt_prog_compiler_pic_CXX
+pic_mode=$pic_mode
+# What is the maximum length of a command?
+max_cmd_len=$lt_cv_sys_max_cmd_len
+# Does compiler simultaneously support -c and -o options?
+compiler_c_o=$lt_lt_cv_prog_compiler_c_o_CXX
+# Must we lock files when doing compilation ?
+need_locks=$lt_need_locks
+# Do we need the lib prefix for modules?
+need_lib_prefix=$need_lib_prefix
+# Do we need a version for libraries?
+need_version=$need_version
+# Whether dlopen is supported.
+dlopen_support=$enable_dlopen
+# Whether dlopen of programs is supported.
+dlopen_self=$enable_dlopen_self
+# Whether dlopen of statically linked programs is supported.
+dlopen_self_static=$enable_dlopen_self_static
+# Compiler flag to prevent dynamic linking.
+link_static_flag=$lt_lt_prog_compiler_static_CXX
+# Compiler flag to turn off builtin functions.
+no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_CXX
+# Compiler flag to allow reflexive dlopens.
+export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_CXX
+# Compiler flag to generate shared objects directly from archives.
+whole_archive_flag_spec=$lt_whole_archive_flag_spec_CXX
+# Compiler flag to generate thread-safe objects.
+thread_safe_flag_spec=$lt_thread_safe_flag_spec_CXX
+# Library versioning type.
+version_type=$version_type
+# Format of library name prefix.
+libname_spec=$lt_libname_spec
+# List of archive names. First name is the real one, the rest are links.
+# The last name is the one that the linker finds with -lNAME.
+library_names_spec=$lt_library_names_spec
+# The coded name of the library, if different from the real name.
+soname_spec=$lt_soname_spec
+# Commands used to build and install an old-style archive.
+RANLIB=$lt_RANLIB
+old_archive_cmds=$lt_old_archive_cmds_CXX
+old_postinstall_cmds=$lt_old_postinstall_cmds
+old_postuninstall_cmds=$lt_old_postuninstall_cmds
+# Create an old-style archive from a shared archive.
+old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_CXX
+# Create a temporary old-style archive to link instead of a shared archive.
+old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_CXX
+# Commands used to build and install a shared archive.
+archive_cmds=$lt_archive_cmds_CXX
+archive_expsym_cmds=$lt_archive_expsym_cmds_CXX
+postinstall_cmds=$lt_postinstall_cmds
+postuninstall_cmds=$lt_postuninstall_cmds
+# Commands used to build a loadable module (assumed same as above if empty)
+module_cmds=$lt_module_cmds_CXX
+module_expsym_cmds=$lt_module_expsym_cmds_CXX
+# Commands to strip libraries.
+old_striplib=$lt_old_striplib
+striplib=$lt_striplib
+# Dependencies to place before the objects being linked to create a
+# shared library.
+predep_objects=$lt_predep_objects_CXX
+# Dependencies to place after the objects being linked to create a
+# shared library.
+postdep_objects=$lt_postdep_objects_CXX
+# shared library.
+predeps=$lt_predeps_CXX
+# shared library.
+postdeps=$lt_postdeps_CXX
+# The library search path used internally by the compiler when linking
+# a shared library.
+compiler_lib_search_path=$lt_compiler_lib_search_path_CXX
+# Method to check whether dependent libraries are shared objects.
+deplibs_check_method=$lt_deplibs_check_method
+# Command to use when deplibs_check_method == file_magic.
+file_magic_cmd=$lt_file_magic_cmd
+# Flag that allows shared libraries with undefined symbols to be built.
+allow_undefined_flag=$lt_allow_undefined_flag_CXX
+# Flag that forces no undefined symbols.
+no_undefined_flag=$lt_no_undefined_flag_CXX
+# Commands used to finish a libtool library installation in a directory.
+finish_cmds=$lt_finish_cmds
+# Same as above, but a single script fragment to be evaled but not shown.
+finish_eval=$lt_finish_eval
+# Take the output of nm and produce a listing of raw symbols and C names.
+global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
+# Transform the output of nm in a proper C declaration
+global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
+# Transform the output of nm in a C name address pair
+global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
+# This is the shared library runtime path variable.
+runpath_var=$runpath_var
+# This is the shared library path variable.
+shlibpath_var=$shlibpath_var
+# Is shlibpath searched before the hard-coded library search path?
+shlibpath_overrides_runpath=$shlibpath_overrides_runpath
+# How to hardcode a shared library path into an executable.
+hardcode_action=$hardcode_action_CXX
+# Whether we should hardcode library paths into libraries.
+hardcode_into_libs=$hardcode_into_libs
+# Flag to hardcode \$libdir into a binary during linking.
+# This must work even if \$libdir does not exist.
+hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_CXX
+# If ld is used when linking, flag to hardcode \$libdir into
+# a binary during linking. This must work even if \$libdir does
+# not exist.
+hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_CXX
+# Whether we need a single -rpath flag with a separated argument.
+hardcode_libdir_separator=$lt_hardcode_libdir_separator_CXX
+# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
+# resulting binary.
+hardcode_direct=$hardcode_direct_CXX
+# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
+hardcode_minus_L=$hardcode_minus_L_CXX
+# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
+# the resulting binary.
+hardcode_shlibpath_var=$hardcode_shlibpath_var_CXX
+# Set to yes if building a shared library automatically hardcodes DIR into the library
+# and all subsequent libraries and executables linked against it.
+hardcode_automatic=$hardcode_automatic_CXX
+# Variables whose values should be saved in libtool wrapper scripts and
+# restored at relink time.
+variables_saved_for_relink="$variables_saved_for_relink"
+# Whether libtool must link a program against all its dependency libraries.
+link_all_deplibs=$link_all_deplibs_CXX
+# Compile-time system search path for libraries
+sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
+# Run-time system search path for libraries
+sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
+# Fix the shell variable \$srcfile for the compiler.
+fix_srcfile_path="$fix_srcfile_path_CXX"
+# Set to yes if exported symbols are required.
+always_export_symbols=$always_export_symbols_CXX
+# The commands to list exported symbols.
+export_symbols_cmds=$lt_export_symbols_cmds_CXX
+# The commands to extract the exported symbol list from a shared archive.
+extract_expsyms_cmds=$lt_extract_expsyms_cmds
+# Symbols that should not be listed in the preloaded symbols.
+exclude_expsyms=$lt_exclude_expsyms_CXX
+# Symbols that must always be exported.
+include_expsyms=$lt_include_expsyms_CXX
+# ### END LIBTOOL TAG CONFIG: $tagname
+__EOF__
+else
+ # If there is no Makefile yet, we rely on a make rule to execute
+ # `config.status --recheck' to rerun these tests and create the
+ # libtool script then.
+ ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
+ if test -f "$ltmain_in"; then
+ test -f Makefile && make "$ltmain"
+ fi
+fi
+ac_ext=cc
+ac_cpp='$CXXCPP $CPPFLAGS'
+ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
+CC=$lt_save_CC
+LDCXX=$LD
+LD=$lt_save_LD
+GCC=$lt_save_GCC
+with_gnu_ldcxx=$with_gnu_ld
+with_gnu_ld=$lt_save_with_gnu_ld
+lt_cv_path_LDCXX=$lt_cv_path_LD
+lt_cv_path_LD=$lt_save_path_LD
+lt_cv_prog_gnu_ldcxx=$lt_cv_prog_gnu_ld
+lt_cv_prog_gnu_ld=$lt_save_with_gnu_ld
+ else
+ tagname=""
+ fi
+ F77)
+ if test -n "$F77" && test "X$F77" != "Xno"; then
+ac_ext=f
+ac_compile='$F77 -c $FFLAGS conftest.$ac_ext >&5'
+ac_link='$F77 -o conftest$ac_exeext $FFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_f77_compiler_gnu
+archive_cmds_need_lc_F77=no
+allow_undefined_flag_F77=
+always_export_symbols_F77=no
+archive_expsym_cmds_F77=
+export_dynamic_flag_spec_F77=
+hardcode_direct_F77=no
+hardcode_libdir_flag_spec_F77=
+hardcode_libdir_flag_spec_ld_F77=
+hardcode_libdir_separator_F77=
+hardcode_minus_L_F77=no
+hardcode_automatic_F77=no
+module_cmds_F77=
+module_expsym_cmds_F77=
+link_all_deplibs_F77=unknown
+old_archive_cmds_F77=$old_archive_cmds
+no_undefined_flag_F77=
+whole_archive_flag_spec_F77=
+enable_shared_with_static_runtimes_F77=no
+# Source file extension for f77 test sources.
+ac_ext=f
+# Object file extension for compiled f77 test sources.
+objext=o
+objext_F77=$objext
+# Code to be used in simple compile tests
+lt_simple_compile_test_code=" subroutine t\n return\n end\n"
+# Code to be used in simple link tests
+lt_simple_link_test_code=" program t\n end\n"
+# ltmain only uses $CC for tagged configurations so make sure $CC is set.
+# If no C compiler was specified, use CC.
+LTCC=${LTCC-"$CC"}
+# Allow CC to be a program name with arguments.
+compiler=$CC
+lt_save_CC="$CC"
+CC=${F77-"f77"}
+compiler=$CC
+compiler_F77=$CC
+cc_basename=`$echo X"$compiler" | $Xsed -e 's%^.*/%%'`
+echo "$as_me:$LINENO: checking if libtool supports shared libraries" >&5
+echo $ECHO_N "checking if libtool supports shared libraries... $ECHO_C" >&6
+echo "$as_me:$LINENO: result: $can_build_shared" >&5
+echo "${ECHO_T}$can_build_shared" >&6
+echo "$as_me:$LINENO: checking whether to build shared libraries" >&5
+echo $ECHO_N "checking whether to build shared libraries... $ECHO_C" >&6
+test "$can_build_shared" = "no" && enable_shared=no
+# On AIX, shared libraries and static libraries use the same namespace, and
+# are all built from PIC.
+case "$host_os" in
+aix3*)
+ test "$enable_shared" = yes && enable_static=no
+ if test -n "$RANLIB"; then
+ archive_cmds="$archive_cmds~\$RANLIB \$lib"
+ postinstall_cmds='$RANLIB $lib'
+ fi
+aix4* | aix5*)
+esac
+echo "$as_me:$LINENO: result: $enable_shared" >&5
+echo "${ECHO_T}$enable_shared" >&6
+echo "$as_me:$LINENO: checking whether to build static libraries" >&5
+echo $ECHO_N "checking whether to build static libraries... $ECHO_C" >&6
+# Make sure either enable_shared or enable_static is yes.
+test "$enable_shared" = yes || enable_static=yes
+echo "$as_me:$LINENO: result: $enable_static" >&5
+echo "${ECHO_T}$enable_static" >&6
+test "$ld_shlibs_F77" = no && can_build_shared=no
+GCC_F77="$G77"
+LD_F77="$LD"
+lt_prog_compiler_wl_F77=
+lt_prog_compiler_pic_F77=
+lt_prog_compiler_static_F77=
+ lt_prog_compiler_wl_F77='-Wl,'
+ lt_prog_compiler_static_F77='-static'
+ case $host_os in
+ aix*)
+ lt_prog_compiler_static_F77='-Bstatic'
+ fi
+ amigaos*)
+ # like `-m68040'.
+ lt_prog_compiler_pic_F77='-m68020 -resident32 -malways-restore-a4'
+ mingw* | pw32* | os2*)
+ lt_prog_compiler_pic_F77='-DDLL_EXPORT'
+ lt_prog_compiler_pic_F77='-fno-common'
+ msdosdjgpp*)
+ # Just because we use GCC doesn't mean we suddenly get shared libraries
+ # on systems that don't support them.
+ lt_prog_compiler_can_build_shared_F77=no
+ enable_shared=no
+ sysv4*MP*)
+ lt_prog_compiler_pic_F77=-Kconform_pic
+ fi
+ hpux*)
+ case "$host_cpu" in
+ hppa*64*|ia64*)
+ # +Z the default
+ lt_prog_compiler_pic_F77='-fPIC'
esac
- fi
- # $CC -shared without GNU ld will not create a library from C++
- # object files and a static libstdc++, better avoid it by now
- archive_cmds='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
- archive_expsym_cmds='$echo "{ global:" > $lib.exp~cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
- $LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
- hardcode_libdir_flag_spec='-R$libdir'
+ esac
+ else
+ # PORTME Check for flag to pass linker flags through the system compiler.
case $host_os in
- solaris2.[0-5] | solaris2.[0-5].*) ;;
- *) # Supported since Solaris 2.6 (maybe 2.5.1?)
- whole_archive_flag_spec='-z allextract$convenience -z defaultextract' ;;
- esac
+ aix*)
+ else
+ lt_prog_compiler_static_F77='-bnso -bI:/lib/syscalls.exp'
+ fi
- sunos4*)
- if test "x$host_vendor" = xsequent; then
- # Use $CC to link under sequent, because it throws in some extra .o
- # files that make .init and .fini sections work.
- archive_cmds='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
- else
- archive_cmds='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
- fi
- hardcode_direct=yes
- sysv4)
- case $host_vendor in
- sni)
- hardcode_direct=yes # is this really true???
+ hppa*64*|ia64*)
+ # +Z the default
+ lt_prog_compiler_pic_F77='+Z'
+ esac
+ # Is there a better lt_prog_compiler_static that works with the bundled CC?
+ lt_prog_compiler_static_F77='${wl}-a ${wl}archive'
+ # PIC (with -KPIC) is the default.
+ lt_prog_compiler_static_F77='-non_shared'
+ newsos6)
+ lt_prog_compiler_pic_F77='-KPIC'
+ linux*)
+ case $CC in
+ icc* | ecc*)
- siemens)
- ## LD is ld it makes a PLAMLIB
- ## CC just makes a GrossModule.
- archive_cmds='$LD -G -o $lib $libobjs $deplibs $linker_flags'
- reload_cmds='$CC -r -o $output$reload_objs'
- hardcode_direct=no
+ ccc*)
+ # All Alpha code is PIC.
- motorola)
- hardcode_direct=no #Motorola manual says yes, but my tests say they lie
+ esac
+ # All OSF/1 code is PIC.
+ sco3.2v5*)
+ lt_prog_compiler_pic_F77='-Kpic'
+ lt_prog_compiler_static_F77='-dn'
+ solaris*)
+ sunos4*)
+ lt_prog_compiler_wl_F77='-Qoption ld '
+ lt_prog_compiler_pic_F77='-PIC'
+ sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
+ sysv4*MP*)
+ lt_prog_compiler_pic_F77='-Kconform_pic'
+ fi
+ uts4*)
+ lt_prog_compiler_pic_F77='-pic'
esac
- runpath_var='LD_RUN_PATH'
+ fi
- sysv4.3*)
- export_dynamic_flag_spec='-Bexport'
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_F77" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_F77" >&6
- sysv5*)
- no_undefined_flag=' -z text'
+if test -n "$lt_prog_compiler_pic_F77"; then
+echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic_F77 works" >&5
+echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic_F77 works... $ECHO_C" >&6
+if test "${lt_prog_compiler_pic_works_F77+set}" = set; then
+else
+ lt_prog_compiler_pic_works_F77=no
+ lt_compiler_flag="$lt_prog_compiler_pic_F77"
+ (eval echo "\"\$as_me:13889: $lt_compile\"" >&5)
+ ac_status=$?
+ echo "$as_me:13893: \$? = $ac_status" >&5
+ lt_prog_compiler_pic_works_F77=yes
+ fi
+ fi
+ $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works_F77" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_works_F77" >&6
+if test x"$lt_prog_compiler_pic_works_F77" = xyes; then
+ case $lt_prog_compiler_pic_F77 in
+ *) lt_prog_compiler_pic_F77=" $lt_prog_compiler_pic_F77" ;;
+ esac
+else
+fi
+fi
+case "$host_os" in
+ *djgpp*)
+ lt_prog_compiler_pic_F77="$lt_prog_compiler_pic_F77"
+esac
- uts4*)
+if test "${lt_cv_prog_compiler_c_o_F77+set}" = set; then
+else
+ lt_cv_prog_compiler_c_o_F77=no
+ mkdir conftest
+ cd conftest
+ mkdir out
+ (eval echo "\"\$as_me:13949: $lt_compile\"" >&5)
+ ac_status=$?
+ echo "$as_me:13953: \$? = $ac_status" >&5
+ then
+ lt_cv_prog_compiler_c_o_F77=yes
+ fi
+ fi
+ chmod u+w .
+ $rm conftest*
+ cd ..
+ rmdir conftest
+ $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o_F77" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_c_o_F77" >&6
+if test "$lt_cv_prog_compiler_c_o_F77" = no && test "$need_locks" != no; then
+ hard_links=yes
+ $rm conftest*
+ touch conftest.a
+ need_locks=warn
+ fi
+else
+ need_locks=no
+fi
+echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
+echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
+ runpath_var=
+ allow_undefined_flag_F77=
+ enable_shared_with_static_runtimes_F77=no
+ archive_cmds_F77=
+ archive_expsym_cmds_F77=
+ old_archive_From_new_cmds_F77=
+ old_archive_from_expsyms_cmds_F77=
+ export_dynamic_flag_spec_F77=
+ whole_archive_flag_spec_F77=
+ thread_safe_flag_spec_F77=
+ hardcode_libdir_flag_spec_F77=
+ hardcode_libdir_flag_spec_ld_F77=
+ hardcode_libdir_separator_F77=
+ hardcode_direct_F77=no
+ hardcode_minus_L_F77=no
+ hardcode_shlibpath_var_F77=unsupported
+ link_all_deplibs_F77=unknown
+ hardcode_automatic_F77=no
+ module_cmds_F77=
+ module_expsym_cmds_F77=
+ always_export_symbols_F77=no
+ export_symbols_cmds_F77='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
+ # include_expsyms should be a list of space-separated symbols to be *always*
+ # included in the symbol list
+ include_expsyms_F77=
+ # exclude_expsyms can be an extended regexp of symbols to exclude
+ # it will be wrapped by ` (' and `)$', so one must not match beginning or
+ # end of line. Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
+ # as well as any symbol that contains `d'.
+ exclude_expsyms_F77="_GLOBAL_OFFSET_TABLE_"
+ # Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
+ # platforms (ab)use it in PIC code, but their linkers get confused if
+ # the symbol is explicitly referenced. Since portable code cannot
+ # rely on this symbol name, it's probably fine to never include it in
+ # preloaded symbol tables.
+ extract_expsyms_cmds=
+ case $host_os in
+ cygwin* | mingw* | pw32*)
+ # FIXME: the MSVC++ port hasn't been tested in a loooong time
+ # When not using gcc, we currently assume that we are using
+ # Microsoft Visual C++.
+ if test "$GCC" != yes; then
+ with_gnu_ld=no
+ fi
+ openbsd*)
+ with_gnu_ld=no
+ esac
- dgux*)
+ ld_shlibs_F77=yes
+ if test "$with_gnu_ld" = yes; then
+ # If archive_cmds runs LD, not CC, wlarc should be empty
+ wlarc='${wl}'
+ # See if GNU ld supports shared libraries.
+ case $host_os in
+ aix3* | aix4* | aix5*)
+ # On AIX/PPC, the GNU linker is very broken
+ if test "$host_cpu" != ia64; then
+ ld_shlibs_F77=no
+ cat <<EOF 1>&2
+*** Warning: the GNU linker, at least up to release 2.9.1, is reported
+*** to be unable to reliably create shared libraries on AIX.
+*** Therefore, libtool is disabling shared libraries support. If you
+*** really care for shared libraries, you may want to modify your PATH
+*** so that a non-GNU linker is found, and then restart.
+EOF
+ fi
+ amigaos*)
+ archive_cmds_F77='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
+ hardcode_libdir_flag_spec_F77='-L$libdir'
+ hardcode_minus_L_F77=yes
+ # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
+ # that the semantics of dynamic libraries on AmigaOS, at least up
+ # to version 4, is to share data among multiple programs linked
+ # with the same dynamic library. Since this doesn't match the
+ # behavior of shared libraries on other platforms, we can't use
+ # them.
+ ld_shlibs_F77=no
+ beos*)
+ if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+ allow_undefined_flag_F77=unsupported
+ # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
+ # support --undefined. This deserves some investigation. FIXME
+ archive_cmds_F77='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+ else
+ ld_shlibs_F77=no
+ fi
+ # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, F77) is actually meaningless,
+ # as there is no search path for DLLs.
+ enable_shared_with_static_runtimes_F77=yes
+ export_symbols_cmds_F77='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGS] /s/.* \([^ ]*\)/\1 DATA/'\'' | $SED -e '\''/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
+ if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
+ archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--image-base=0x10000000 ${wl}--out-implib,$lib'
+ # If the export-symbols file already is a .def file (1st line
+ # is EXPORTS), use it as is; otherwise, prepend...
+ archive_expsym_cmds_F77='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
+ cp $export_symbols $output_objdir/$soname.def;
+ else
+ echo EXPORTS > $output_objdir/$soname.def;
+ cat $export_symbols >> $output_objdir/$soname.def;
+ fi~
+ $CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--image-base=0x10000000 ${wl}--out-implib,$lib'
+ else
+ ld_shlibs=no
+ fi
+ netbsd*)
+ if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
+ archive_cmds_F77='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
+ wlarc=
+ else
+ archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+ archive_expsym_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+ fi
+ solaris* | sysv5*)
+ if $LD -v 2>&1 | grep 'BFD 2\.8' > /dev/null; then
+ ld_shlibs_F77=no
+ cat <<EOF 1>&2
+*** Warning: The releases 2.8.* of the GNU linker cannot reliably
+*** create shared libraries on Solaris systems. Therefore, libtool
+*** is disabling shared libraries support. We urge you to upgrade GNU
+*** binutils to release 2.9.1 or newer. Another option is to modify
+*** your PATH or compiler configuration so that the native linker is
+*** used, and then restart.
+EOF
+ elif $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+ else
+ ld_shlibs_F77=no
+ fi
+ sunos4*)
+ archive_cmds_F77='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+ wlarc=
+ hardcode_direct_F77=yes
+ hardcode_shlibpath_var_F77=no
+ linux*)
+ tmp_archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+ archive_cmds_F77="$tmp_archive_cmds"
+ supports_anon_versioning=no
+ case `$LD -v 2>/dev/null` in
+ *\ 01.* | *\ 2.[0-9].* | *\ 2.10.*) ;; # catch versions < 2.11
+ *\ 2.11.93.0.2\ *) supports_anon_versioning=yes ;; # RH7.3 ...
+ *\ 2.11.92.0.12\ *) supports_anon_versioning=yes ;; # Mandrake 8.2 ...
+ *\ 2.11.*) ;; # other 2.11 versions
+ *) supports_anon_versioning=yes ;;
+ esac
+ if test $supports_anon_versioning = yes; then
+ archive_expsym_cmds_F77='$echo "{ global:" > $output_objdir/$libname.ver~
+cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $output_objdir/$libname.ver~
+$echo "local: *; };" >> $output_objdir/$libname.ver~
+ $CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
+ else
+ archive_expsym_cmds_F77="$tmp_archive_cmds"
+ fi
+ else
+ ld_shlibs_F77=no
+ fi
- sysv4*MP*)
- if test -d /usr/nec; then
+ else
+ ld_shlibs_F77=no
+ fi
+ esac
+ if test "$ld_shlibs_F77" = yes; then
+ hardcode_libdir_flag_spec_F77='${wl}--rpath ${wl}$libdir'
+ export_dynamic_flag_spec_F77='${wl}--export-dynamic'
+ # ancient GNU ld didn't support --whole-archive et. al.
+ if $LD --help 2>&1 | grep 'no-whole-archive' > /dev/null; then
+ whole_archive_flag_spec_F77="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
+ else
+ fi
+ fi
+ else
+ # PORTME fill in a description of your system's linker (not GNU ld)
+ case $host_os in
+ aix3*)
+ always_export_symbols_F77=yes
+ archive_expsym_cmds_F77='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
+ # Note: this linker hardcodes the directories in LIBPATH if there
+ # are no directories specified by -L.
+ if test "$GCC" = yes && test -z "$link_static_flag"; then
+ # Neither direct hardcoding nor static linking is supported with a
+ # broken collect2.
+ hardcode_direct_F77=unsupported
+ fi
+ aix4* | aix5*)
+ if test "$host_cpu" = ia64; then
+ # On IA64, the linker does run time linking by default, so we don't
+ # have to do anything special.
+ aix_use_runtimelinking=no
+ exp_sym_flag='-Bexport'
+ no_entry_flag=""
+ else
+ # If we're using GNU nm, then we don't want the "-C" option.
+ # -C means demangle to AIX nm, but means don't demangle with GNU nm
+ if $NM -V 2>&1 | grep 'GNU' > /dev/null; then
+ export_symbols_cmds_F77='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+ else
+ export_symbols_cmds_F77='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+ fi
+ # Test if we are trying to use run time linking or normal
+ # AIX style linking. If -brtl is somewhere in LDFLAGS, we
+ # need to do runtime linking.
+ case $host_os in aix4.[23]|aix4.[23].*|aix5*)
+ for ld_flag in $LDFLAGS; do
+ if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
+ aix_use_runtimelinking=yes
+ break
+ fi
+ done
+ esac
+ exp_sym_flag='-bexport'
+ no_entry_flag='-bnoentry'
+ fi
+ # When large executables or shared objects are built, AIX ld can
+ # have problems creating the table of contents. If linking a library
+ # or program results in "error TOC overflow" add -mminimal-toc to
+ # CXXFLAGS/CFLAGS for g++/gcc. In the cases where that is not
+ # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
+ archive_cmds_F77=''
+ hardcode_libdir_separator_F77=':'
+ link_all_deplibs_F77=yes
+ case $host_os in aix4.012|aix4.012.*)
+ # We only want to do this on AIX 4.2 and lower, the check
+ # below for broken collect2 doesn't work under 4.3+
+ collect2name=`${CC} -print-prog-name=collect2`
+ if test -f "$collect2name" && \
+ strings "$collect2name" | grep resolve_lib_name >/dev/null
+ then
+ # We have reworked collect2
+ else
+ # We have old collect2
+ # It fails to find uninstalled libraries when the uninstalled
+ # path is not listed in the libpath. Setting hardcode_minus_L
+ # to unsupported forces relinking
+ fi
+ esac
+ shared_flag='-shared'
+ else
+ # not using gcc
+ # VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
+ # chokes on -Wl,-G. The following line is correct:
+ shared_flag='-G'
+ else
+ shared_flag='${wl}-G'
+ else
+ shared_flag='${wl}-bM:SRE'
+ fi
+ fi
+ fi
+ # It seems that -bexpall does not export symbols beginning with
+ # underscore (_), so it is better to generate a list of symbols to export.
+ # Warning - without using the other runtime loading flags (-brtl),
+ # -berok will link without error, but may produce a broken library.
+ allow_undefined_flag_F77='-berok'
+ # Determine the default libpath from the value encoded in an empty executable.
+ program main
+ end
+_ACEOF
+ ac_status=$?
+ cat conftest.err >&5
+ { ac_try='test -z "$ac_f77_werror_flag"
+ ac_status=$?
+ ac_status=$?
+aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
+# Check for a 64-bit object if we didn't find anything.
+if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
+}'`; fi
+else
+fi
+if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
+ hardcode_libdir_flag_spec_F77='${wl}-blibpath:$libdir:'"$aix_libpath"
+ archive_expsym_cmds_F77="\$CC"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols $shared_flag"
+ else
+ hardcode_libdir_flag_spec_F77='${wl}-R $libdir:/usr/lib:/lib'
+ allow_undefined_flag_F77="-z nodefs"
+ archive_expsym_cmds_F77="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols"
+ else
+ program main
+ end
+_ACEOF
+ ac_status=$?
+ ac_status=$?
+ ac_status=$?
+}'`; fi
+else
+fi
+ # Warning - without using the other run time loading flags,
+ no_undefined_flag_F77=' ${wl}-bernotok'
+ allow_undefined_flag_F77=' ${wl}-berok'
+ # -bexpall does not export symbols beginning with underscore (_)
+ # Exported symbols can be pulled into shared objects from archives
+ whole_archive_flag_spec_F77=' '
+ archive_cmds_need_lc_F77=yes
+ # This is similar to how AIX traditionally builds it's shared libraries.
+ archive_expsym_cmds_F77="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${wl}-bE:$export_symbols ${wl}-bnoentry${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
+ fi
+ fi
+ amigaos*)
+ # see comment about different semantics on the GNU ld section
+ ld_shlibs_F77=no
+ bsdi4*)
+ export_dynamic_flag_spec_F77=-rdynamic
+ # hardcode_libdir_flag_spec is actually meaningless, as there is
+ # no search path for DLLs.
+ hardcode_libdir_flag_spec_F77=' '
+ # Tell ltmain to make .lib files, not .a files.
+ libext=lib
+ # Tell ltmain to make .dll files, not .so files.
+ # FIXME: Setting linknames here is a bad hack.
+ archive_cmds_F77='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | $SED -e '\''s/ -lc$//'\''` -link -dll~linknames='
+ # The linker will automatically build a .lib file if we build a DLL.
+ old_archive_From_new_cmds_F77='true'
+ # FIXME: Should let the user specify the lib program.
+ old_archive_cmds_F77='lib /OUT:$oldlib$oldobjs$old_deplibs'
+ fix_srcfile_path='`cygpath -w "$srcfile"`'
+ darwin* | rhapsody*)
+ if test "$GXX" = yes ; then
+ archive_cmds_need_lc_F77=no
+ case "$host_os" in
+ rhapsody* | darwin1.[012])
+ allow_undefined_flag_F77='-undefined suppress'
+ *) # Darwin 1.3 on
+ if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
+ allow_undefined_flag_F77='-flat_namespace -undefined suppress'
+ else
+ case ${MACOSX_DEPLOYMENT_TARGET} in
+ 10.[012])
+ 10.*)
+ allow_undefined_flag_F77='-undefined dynamic_lookup'
+ esac
+ fi
+ esac
+ lt_int_apple_cc_single_mod=no
+ output_verbose_link_cmd='echo'
+ if $CC -dumpspecs 2>&1 | grep 'single_module' >/dev/null ; then
+ lt_int_apple_cc_single_mod=yes
+ fi
+ if test "X$lt_int_apple_cc_single_mod" = Xyes ; then
+ archive_cmds_F77='$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+ else
+ archive_cmds_F77='$CC -r ${wl}-bind_at_load -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+ fi
+ module_cmds_F77='$CC ${wl}-bind_at_load $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
+ # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin ld's
+ archive_expsym_cmds_F77='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+ else
+ archive_expsym_cmds_F77='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -r ${wl}-bind_at_load -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+ fi
+ module_expsym_cmds_F77='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+ hardcode_automatic_F77=yes
+ whole_archive_flag_spec_F77='-all_load $convenience'
+ else
+ ld_shlibs_F77=no
+ fi
+ dgux*)
+ archive_cmds_F77='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
+ freebsd1*)
+ ld_shlibs_F77=no
+ # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
+ # support. Future versions do this automatically, but an explicit c++rt0.o
+ # does not break anything, and helps significantly (at the cost of a little
+ # extra space).
+ freebsd2.2*)
+ archive_cmds_F77='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
+ hardcode_libdir_flag_spec_F77='-R$libdir'
+ # Unfortunately, older versions of FreeBSD 2 do not have this feature.
+ freebsd2*)
+ archive_cmds_F77='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+ # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
+ freebsd* | kfreebsd*-gnu)
+ archive_cmds_F77='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
+ hpux9*)
+ if test "$GCC" = yes; then
+ archive_cmds_F77='$rm $output_objdir/$soname~$CC -shared -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $libobjs $deplibs $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+ else
+ archive_cmds_F77='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+ fi
+ hardcode_libdir_flag_spec_F77='${wl}+b ${wl}$libdir'
+ hardcode_libdir_separator_F77=:
+ # hardcode_minus_L: Not really in the search PATH,
+ # but as the default location of the library.
+ export_dynamic_flag_spec_F77='${wl}-E'
+ hpux10* | hpux11*)
+ if test "$GCC" = yes -a "$with_gnu_ld" = no; then
+ hppa*64*|ia64*)
+ archive_cmds_F77='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ archive_cmds_F77='$CC -shared -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+ esac
+ else
+ hppa*64*|ia64*)
+ archive_cmds_F77='$LD -b +h $soname -o $lib $libobjs $deplibs $linker_flags'
+ archive_cmds_F77='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
+ esac
+ fi
+ if test "$with_gnu_ld" = no; then
+ hppa*64*)
+ hardcode_libdir_flag_spec_ld_F77='+b $libdir'
+ ia64*)
+ esac
+ fi
+ irix5* | irix6* | nonstopux*)
+ archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+ else
+ archive_cmds_F77='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+ hardcode_libdir_flag_spec_ld_F77='-rpath $libdir'
+ fi
+ hardcode_libdir_flag_spec_F77='${wl}-rpath ${wl}$libdir'
+ netbsd*)
+ archive_cmds_F77='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags' # a.out
+ else
+ archive_cmds_F77='$LD -shared -o $lib $libobjs $deplibs $linker_flags' # ELF
+ fi
+ newsos6)
+ openbsd*)
+ archive_cmds_F77='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
+ hardcode_libdir_flag_spec_F77='${wl}-rpath,$libdir'
+ else
+ case $host_os in
+ openbsd[01].* | openbsd2.[0-7] | openbsd2.[0-7].*)
+ esac
+ fi
+ os2*)
+ archive_cmds_F77='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
+ old_archive_From_new_cmds_F77='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
+ osf3*)
+ allow_undefined_flag_F77=' ${wl}-expect_unresolved ${wl}\*'
+ archive_cmds_F77='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+ else
+ allow_undefined_flag_F77=' -expect_unresolved \*'
+ archive_cmds_F77='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+ fi
+ osf4* | osf5*) # as osf3* with the addition of -msym flag
+ archive_cmds_F77='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+ else
+ archive_cmds_F77='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+ archive_expsym_cmds_F77='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
+ $LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${objdir}/so_locations -o $lib~$rm $lib.exp'
+ # Both c and cxx compiler support -rpath directly
+ hardcode_libdir_flag_spec_F77='-rpath $libdir'
+ fi
+ sco3.2v5*)
+ export_dynamic_flag_spec_F77='${wl}-Bexport'
+ runpath_var=LD_RUN_PATH
- ld_shlibs=yes
+ solaris*)
+ no_undefined_flag_F77=' -z text'
+ archive_cmds_F77='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ archive_expsym_cmds_F77='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
+ $CC -shared ${wl}-M ${wl}$lib.exp ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags~$rm $lib.exp'
+ else
+ archive_cmds_F77='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
+ $LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
+ fi
+ case $host_os in
+ solaris2.[0-5] | solaris2.[0-5].*) ;;
+ *) # Supported since Solaris 2.6 (maybe 2.5.1?)
+ whole_archive_flag_spec_F77='-z allextract$convenience -z defaultextract' ;;
+ esac
+ sunos4*)
+ if test "x$host_vendor" = xsequent; then
+ # Use $CC to link under sequent, because it throws in some extra .o
+ # files that make .init and .fini sections work.
+ archive_cmds_F77='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
+ else
+ archive_cmds_F77='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
+ fi
+ sysv4)
+ sni)
+ hardcode_direct_F77=yes # is this really true???
+ siemens)
+ ## LD is ld it makes a PLAMLIB
+ ## CC just makes a GrossModule.
+ archive_cmds_F77='$LD -G -o $lib $libobjs $deplibs $linker_flags'
+ reload_cmds_F77='$CC -r -o $output$reload_objs'
+ motorola)
+ hardcode_direct_F77=no #Motorola manual says yes, but my tests say they lie
+ esac
+ runpath_var='LD_RUN_PATH'
+ sysv4.3*)
+ export_dynamic_flag_spec_F77='-Bexport'
+ sysv4*MP*)
+ if test -d /usr/nec; then
+ hardcode_runpath_var=yes
+ ld_shlibs_F77=yes
+ fi
+ sysv4.2uw2*)
+ sysv5OpenUNIX8* | sysv5UnixWare7* | sysv5uw[78]* | unixware7*)
+ no_undefined_flag_F77='${wl}-z ${wl}text'
+ else
+ archive_cmds_F77='$CC -G ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ fi
+ sysv5*)
+ # $CC -shared without GNU ld will not create a library from C++
+ # object files and a static libstdc++, better avoid it by now
+ uts4*)
+ ld_shlibs_F77=no
+ esac
+ fi
+echo "$as_me:$LINENO: result: $ld_shlibs_F77" >&5
+echo "${ECHO_T}$ld_shlibs_F77" >&6
+variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
+if test "$GCC" = yes; then
+ variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
+fi
+# Do we need to explicitly link libc?
+case "x$archive_cmds_need_lc_F77" in
+x|xyes)
+ # Assume -lc should be added
+ if test "$enable_shared" = yes && test "$GCC" = yes; then
+ case $archive_cmds_F77 in
+ # FIXME: we may have to deal with multi-command sequences.
+ '$CC '*)
+ # Test whether the compiler implicitly links with -lc since on some
+ # systems, -lgcc has to come before -lc. If gcc already passes -lc
+ # to ld, don't add -lc before -lgcc.
+ echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
+echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
+ $rm conftest*
+ printf "$lt_simple_compile_test_code" > conftest.$ac_ext
+ if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+ (eval $ac_compile) 2>&5
+ ac_status=$?
+ (exit $ac_status); } 2>conftest.err; then
+ soname=conftest
+ lib=conftest
+ libobjs=conftest.$ac_objext
+ deplibs=
+ wl=$lt_prog_compiler_wl_F77
+ compiler_flags=-v
+ linker_flags=-v
+ verstring=
+ output_objdir=.
+ libname=conftest
+ lt_save_allow_undefined_flag=$allow_undefined_flag_F77
+ if { (eval echo "$as_me:$LINENO: \"$archive_cmds_F77 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
+ (eval $archive_cmds_F77 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
+ ac_status=$?
+ then
+ else
+ fi
+ allow_undefined_flag_F77=$lt_save_allow_undefined_flag
+ else
+ cat conftest.err 1>&5
+ fi
+ $rm conftest*
+ echo "$as_me:$LINENO: result: $archive_cmds_need_lc_F77" >&5
+echo "${ECHO_T}$archive_cmds_need_lc_F77" >&6
+ esac
+ fi
+esac
+echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
+echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
+libname_spec='lib$name'
+soname_spec=
+shrext_cmds=".so"
+postinstall_cmds=
+finish_cmds=
+finish_eval=
+shlibpath_var=
+shlibpath_overrides_runpath=unknown
+version_type=none
+dynamic_linker="$host_os ld.so"
+sys_lib_dlsearch_path_spec="/lib /usr/lib"
+ sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
+ if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
+ # if the path contains ";" then we assume it to be the separator
+ # otherwise default to the standard path separator (i.e. ":") - it is
+ # assumed that no part of a normal pathname contains ";" but that should
+ # okay in the real world where ";" in dirpaths is itself problematic.
+ sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
+ else
+ sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
+ fi
+else
+ sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
+fi
+need_lib_prefix=unknown
+hardcode_into_libs=no
+# when you set need_version to no, make sure it does not cause -set_version
+# flags to be left without arguments
+need_version=unknown
+case $host_os in
+aix3*)
+ version_type=linux
+ library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
+ shlibpath_var=LIBPATH
+ # AIX 3 has no versioning support, so we append a major version to the name.
+ soname_spec='${libname}${release}${shared_ext}$major'
+aix4* | aix5*)
+ need_lib_prefix=no
+ need_version=no
+ hardcode_into_libs=yes
+ # AIX 5 supports IA64
+ library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
+ shlibpath_var=LD_LIBRARY_PATH
+ else
+ # With GCC up to 2.95.x, collect2 would create an import file
+ # for dependence libraries. The import file would start with
+ # the line `#! .'. This would cause the generated library to
+ # depend on `.', always an invalid library. This was fixed in
+ # development snapshots of GCC prior to 3.0.
+ case $host_os in
+ aix4 | aix4.[01] | aix4.[01].*)
+ if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
+ echo ' yes '
+ echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
+ else
+ can_build_shared=no
+ fi
+ esac
+ # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
+ # soname into executable. Probably we can add versioning support to
+ # collect2, so additional links can be useful in future.
+ if test "$aix_use_runtimelinking" = yes; then
+ # If using run time linking (on AIX 4.2 or later) use lib<name>.so
+ # instead of lib<name>.a to let people know that these are not
+ # typical AIX shared libraries.
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
+ else
+ # We preserve .a as extension for shared libraries through AIX4.2
+ # and later when we are not doing run time linking.
+ library_names_spec='${libname}${release}.a $libname.a'
fi
+ fi
+amigaos*)
+ library_names_spec='$libname.ixlibrary $libname.a'
+ # Create ${libname}_ixlibrary.a entries in /sys/libs.
+ finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
+beos*)
+ library_names_spec='${libname}${shared_ext}'
+ dynamic_linker="$host_os ld.so"
+ shlibpath_var=LIBRARY_PATH
+bsdi4*)
+ need_version=no
+ finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
+ sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
+ sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
+ # the default ld.so.conf also contains /usr/contrib/lib and
+ # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
+ # libtool to hard-code these into programs
+cygwin* | mingw* | pw32*)
+ version_type=windows
+ shrext_cmds=".dll"
+ need_version=no
+ case $GCC,$host_os in
+ yes,cygwin* | yes,mingw* | yes,pw32*)
+ library_names_spec='$libname.dll.a'
+ # DLL is installed to $(libdir)/../bin by postinstall_cmds
+ postinstall_cmds='base_file=`basename \${file}`~
+ dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
+ dldir=$destdir/`dirname \$dlpath`~
+ test -d \$dldir || mkdir -p \$dldir~
+ $install_prog $dir/$dlname \$dldir/$dlname'
+ postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
+ dlpath=$dir/\$dldll~
+ $rm \$dlpath'
+ shlibpath_overrides_runpath=yes
+ case $host_os in
+ cygwin*)
+ # Cygwin DLLs use 'cyg' prefix rather than 'lib'
+ soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+ sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
+ mingw*)
+ # MinGW DLLs use traditional 'lib' prefix
+ soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+ if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
+ # It is most probably a Windows format PATH printed by
+ # mingw gcc, but we are running on Cygwin. Gcc prints its search
+ # path with ; separators, and with drive letters. We can handle the
+ # drive letters (cygwin fileutils understands them), so leave them,
+ # especially as we might pass files found there to a mingw objdump,
+ # which wouldn't understand a cygwinified path. Ahh.
+ else
+ fi
+ pw32*)
+ # pw32 DLLs use 'pw' prefix rather than 'lib'
+ library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/./-/g'`${versuffix}${shared_ext}'
+ esac
- sysv4.2uw2*)
- hardcode_minus_L=no
+ library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
+ esac
+ dynamic_linker='Win32 ld.exe'
+ # FIXME: first we should search . and the directory the executable is in
+ shlibpath_var=PATH
- sysv5uw7* | unixware7*)
- no_undefined_flag='${wl}-z ${wl}text'
- archive_cmds='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+darwin* | rhapsody*)
+ dynamic_linker="$host_os dyld"
+ version_type=darwin
+ need_version=no
+ library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
+ soname_spec='${libname}${release}${major}$shared_ext'
+ shlibpath_var=DYLD_LIBRARY_PATH
+ shrext_cmds='$(test .$module = .yes && echo .so || echo .dylib)'
+ # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
+ sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
+ else
+ sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
+ fi
+ sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
+dgux*)
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
+freebsd1*)
+ dynamic_linker=no
+kfreebsd*-gnu)
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
+ shlibpath_overrides_runpath=no
+ dynamic_linker='GNU ld.so'
+freebsd*)
+ objformat=`test -x /usr/bin/objformat && /usr/bin/objformat || echo aout`
+ version_type=freebsd-$objformat
+ case $version_type in
+ freebsd-elf*)
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
+ need_version=no
+ freebsd-*)
+ library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
+ need_version=yes
+ esac
+ case $host_os in
+ freebsd2*)
+ freebsd3.01* | freebsdelf3.01*)
+ *) # from 3.2 on
+ esac
+gnu*)
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
+hpux9* | hpux10* | hpux11*)
+ # Give a soname corresponding to the major version so that dld.sl refuses to
+ # link against other versions.
+ version_type=sunos
+ need_version=no
+ ia64*)
+ shrext_cmds='.so'
+ dynamic_linker="$host_os dld.so"
+ shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
+ if test "X$HPUX_IA64_MODE" = X32; then
+ sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
else
- archive_cmds='$CC -G ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
fi
+ sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
+ hppa*64*)
+ shrext_cmds='.sl'
+ dynamic_linker="$host_os dld.sl"
+ shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
+ sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
+ shrext_cmds='.sl'
+ shlibpath_var=SHLIB_PATH
+ shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
+ esac
+ # HP-UX runs *really* slowly unless shared libraries are mode 555.
+ postinstall_cmds='chmod 555 $lib'
+irix5* | irix6* | nonstopux*)
+ case $host_os in
+ nonstopux*) version_type=nonstopux ;;
+ if test "$lt_cv_prog_gnu_ld" = yes; then
+ else
+ version_type=irix
+ fi ;;
+ esac
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
+ case $host_os in
+ irix5* | nonstopux*)
+ libsuff= shlibsuff=
- ld_shlibs=no
+ case $LD in # libtool.m4 will add one of these switches to LD
+ *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
+ libsuff= shlibsuff= libmagic=32-bit;;
+ *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
+ libsuff=32 shlibsuff=N32 libmagic=N32;;
+ *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
+ libsuff=64 shlibsuff=64 libmagic=64-bit;;
+ *) libsuff= shlibsuff= libmagic=never-match;;
+ esac
esac
-fi
-echo "$as_me:$LINENO: result: $ld_shlibs" >&5
-echo "${ECHO_T}$ld_shlibs" >&6
-test "$ld_shlibs" = no && can_build_shared=no
+ shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
+ sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
+ sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
-# Check hardcoding attributes.
+# No shared lib support for Linux oldld, aout, or coff.
+linux*oldld* | linux*aout* | linux*coff*)
+ dynamic_linker=no
+# This must be Linux ELF.
+linux*)
+ need_version=no
+ finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
+ # This implies no fast_install, which is unacceptable.
+ # Some rework will be needed to allow for fast_install
+ # before this can be enabled.
+ # find out which ABI we are using
+ libsuff=
+ x86_64*|s390x*|powerpc64*)
+ echo '#line 15263 "configure"' > conftest.$ac_ext
+ ac_status=$?
+ echo "$as_me:$LINENO: \$? = $ac_status" >&5
+ (exit $ac_status); }; then
+ case `/usr/bin/file conftest.$ac_objext` in
+ *64-bit*)
+ libsuff=64
+ sys_lib_search_path_spec="/lib${libsuff} /usr/lib${libsuff} /usr/local/lib${libsuff}"
+ esac
+ fi
+ rm -rf conftest*
+ esac
+ # Append ld.so.conf contents to the search path
+ if test -f /etc/ld.so.conf; then
+ lt_ld_extra=`$SED -e 's/:,\t/ /g;s/=^=*$//;s/=^= * / /g' /etc/ld.so.conf | tr '\n' ' '`
+ sys_lib_dlsearch_path_spec="/lib${libsuff} /usr/lib${libsuff} $lt_ld_extra"
+ fi
+ # We used to test for /lib/ld.so.1 and disable shared libraries on
+ # powerpc, because MkLinux only supported shared libraries with the
+ # GNU dynamic linker. Since this was broken with cross compilers,
+ # most powerpc-linux boxes support dynamic linking these days and
+ # people can always --disable-shared, the test was removed, and we
+ # assume the GNU/Linux dynamic linker is in use.
+ dynamic_linker='GNU/Linux ld.so'
+knetbsd*-gnu)
+ need_version=no
+netbsd*)
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
+ finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
+ dynamic_linker='NetBSD (a.out) ld.so'
+ else
+ dynamic_linker='NetBSD ld.elf_so'
+ fi
+newsos6)
+nto-qnx*)
+ need_version=no
+openbsd*)
+ need_version=yes
+ if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
+ case $host_os in
+ openbsd2.[89] | openbsd2.[89].*)
+ esac
+ else
+ fi
+os2*)
+ libname_spec='$name'
+ library_names_spec='$libname${shared_ext} $libname.a'
+ dynamic_linker='OS/2 ld.exe'
+osf3* | osf4* | osf5*)
+ version_type=osf
+ need_version=no
+ sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
+ sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
+sco3.2v5*)
+ version_type=osf
+solaris*)
+ need_version=no
+ # ldd complains unless libraries are executable
+ postinstall_cmds='chmod +x $lib'
+sunos4*)
+ finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
+ fi
+ need_version=yes
+sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
+ case $host_vendor in
+ sni)
+ export_dynamic_flag_spec='${wl}-Blargedynsym'
+ siemens)
+ motorola)
+ need_version=no
+ sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
+ esac
+sysv4*MP*)
+ if test -d /usr/nec ;then
+ library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
+ soname_spec='$libname${shared_ext}.$major'
+ fi
+uts4*)
+ dynamic_linker=no
+esac
+echo "$as_me:$LINENO: result: $dynamic_linker" >&5
+echo "${ECHO_T}$dynamic_linker" >&6
+test "$dynamic_linker" = no && can_build_shared=no
echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
-hardcode_action=
-if test -n "$hardcode_libdir_flag_spec" || \
- test -n "$runpath_var"; then
+hardcode_action_F77=
+if test -n "$hardcode_libdir_flag_spec_F77" || \
+ test -n "$runpath_var F77" || \
+ test "X$hardcode_automatic_F77"="Xyes" ; then
# We can hardcode non-existant directories.
- if test "$hardcode_direct" != no &&
+ if test "$hardcode_direct_F77" != no &&
# If the only mechanism to avoid hardcoding is shlibpath_var, we
# have to relink, otherwise we might link with an installed library
# when we should be linking with a yet-to-be-installed one
- ## test "$hardcode_shlibpath_var" != no &&
- test "$hardcode_minus_L" != no; then
+ ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, F77)" != no &&
+ test "$hardcode_minus_L_F77" != no; then
# Linking always hardcodes the temporary library directory.
- hardcode_action=relink
+ hardcode_action_F77=relink
else
# We can link without hardcoding, and we can hardcode nonexisting dirs.
- hardcode_action=immediate
+ hardcode_action_F77=immediate
fi
else
# We cannot hardcode anything, or else we can only hardcode existing
# directories.
- hardcode_action=unsupported
+ hardcode_action_F77=unsupported
fi
-echo "$as_me:$LINENO: result: $hardcode_action" >&5
-echo "${ECHO_T}$hardcode_action" >&6
+echo "$as_me:$LINENO: result: $hardcode_action_F77" >&5
+echo "${ECHO_T}$hardcode_action_F77" >&6
+if test "$hardcode_action_F77" = relink; then
+ # Fast installation is not supported
+ enable_fast_install=no
+elif test "$shlibpath_overrides_runpath" = yes ||
+ test "$enable_shared" = no; then
+ # Fast installation is not necessary
+ enable_fast_install=needless
+fi
striplib=
old_striplib=
echo "$as_me:$LINENO: checking whether stripping libraries is possible" >&5
@@ -6618,19 +15507,1768 @@
echo "$as_me:$LINENO: result: yes" >&5
echo "${ECHO_T}yes" >&6
else
+# FIXME - insert some real tests, host_os isn't really good enough
+ case $host_os in
+ darwin*)
+ if test -n "$STRIP" ; then
+ striplib="$STRIP -x"
+ echo "$as_me:$LINENO: result: yes" >&5
+echo "${ECHO_T}yes" >&6
+ else
echo "$as_me:$LINENO: result: no" >&5
echo "${ECHO_T}no" >&6
fi
+ echo "$as_me:$LINENO: result: no" >&5
+echo "${ECHO_T}no" >&6
+ esac
+fi
-reload_cmds='$LD$reload_flag -o $output$reload_objs'
-test -z "$deplibs_check_method" && deplibs_check_method=unknown
-# PORTME Fill in your ld.so characteristics
+# The else clause should only fire when bootstrapping the
+# libtool distribution, otherwise you forgot to ship ltmain.sh
+# with your package, and you will get complaints that there are
+# no rules to generate ltmain.sh.
+if test -f "$ltmain"; then
+ # See if we are running on zsh, and set the options which allow our commands through
+ # without removal of \ escapes.
+ if test -n "${ZSH_VERSION+set}" ; then
+ setopt NO_GLOB_SUBST
+ fi
+ # Now quote all the things that may contain metacharacters while being
+ # careful not to overquote the AC_SUBSTed values. We take copies of the
+ # variables and quote the copies for generation of the libtool script.
+ for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC NM \
+ SED SHELL STRIP \
+ libname_spec library_names_spec soname_spec extract_expsyms_cmds \
+ old_striplib striplib file_magic_cmd finish_cmds finish_eval \
+ deplibs_check_method reload_flag reload_cmds need_locks \
+ lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
+ lt_cv_sys_global_symbol_to_c_name_address \
+ sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
+ old_postinstall_cmds old_postuninstall_cmds \
+ compiler_F77 \
+ CC_F77 \
+ LD_F77 \
+ lt_prog_compiler_wl_F77 \
+ lt_prog_compiler_pic_F77 \
+ lt_prog_compiler_static_F77 \
+ lt_prog_compiler_no_builtin_flag_F77 \
+ export_dynamic_flag_spec_F77 \
+ thread_safe_flag_spec_F77 \
+ whole_archive_flag_spec_F77 \
+ enable_shared_with_static_runtimes_F77 \
+ old_archive_cmds_F77 \
+ old_archive_from_new_cmds_F77 \
+ predep_objects_F77 \
+ postdep_objects_F77 \
+ predeps_F77 \
+ postdeps_F77 \
+ compiler_lib_search_path_F77 \
+ archive_cmds_F77 \
+ archive_expsym_cmds_F77 \
+ postinstall_cmds_F77 \
+ postuninstall_cmds_F77 \
+ old_archive_from_expsyms_cmds_F77 \
+ allow_undefined_flag_F77 \
+ no_undefined_flag_F77 \
+ export_symbols_cmds_F77 \
+ hardcode_libdir_flag_spec_F77 \
+ hardcode_libdir_flag_spec_ld_F77 \
+ hardcode_libdir_separator_F77 \
+ hardcode_automatic_F77 \
+ module_cmds_F77 \
+ module_expsym_cmds_F77 \
+ lt_cv_prog_compiler_c_o_F77 \
+ exclude_expsyms_F77 \
+ include_expsyms_F77; do
+ case $var in
+ old_archive_cmds_F77 | \
+ old_archive_from_new_cmds_F77 | \
+ archive_cmds_F77 | \
+ archive_expsym_cmds_F77 | \
+ module_cmds_F77 | \
+ module_expsym_cmds_F77 | \
+ old_archive_from_expsyms_cmds_F77 | \
+ export_symbols_cmds_F77 | \
+ extract_expsyms_cmds | reload_cmds | finish_cmds | \
+ postinstall_cmds | postuninstall_cmds | \
+ old_postinstall_cmds | old_postuninstall_cmds | \
+ sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
+ # Double-quote double-evaled strings.
+ eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
+ eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
+ esac
+ done
+ case $lt_echo in
+ *'\$0 --fallback-echo"')
+ lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
+ esac
+cfgfile="$ofile"
+ cat <<__EOF__ >> "$cfgfile"
+# ### BEGIN LIBTOOL TAG CONFIG: $tagname
+# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
+# Shell to use when invoking shell scripts.
+SHELL=$lt_SHELL
+# Whether or not to build shared libraries.
+build_libtool_libs=$enable_shared
+# Whether or not to build static libraries.
+build_old_libs=$enable_static
+# Whether or not to add -lc for building shared libraries.
+build_libtool_need_lc=$archive_cmds_need_lc_F77
+# Whether or not to disallow shared libs when runtime libs are static
+allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_F77
+# Whether or not to optimize for fast installation.
+fast_install=$enable_fast_install
+# The host system.
+host_alias=$host_alias
+host=$host
+# An echo program that does not interpret backslashes.
+echo=$lt_echo
+# The archiver.
+AR=$lt_AR
+AR_FLAGS=$lt_AR_FLAGS
+# A C compiler.
+LTCC=$lt_LTCC
+# A language-specific compiler.
+CC=$lt_compiler_F77
+# Is the compiler the GNU C compiler?
+with_gcc=$GCC_F77
+# An ERE matcher.
+EGREP=$lt_EGREP
+# The linker used to build libraries.
+LD=$lt_LD_F77
+# Whether we need hard or soft links.
+LN_S=$lt_LN_S
+# A BSD-compatible nm program.
+NM=$lt_NM
+# A symbol stripping program
+STRIP=$lt_STRIP
+# Used to examine libraries when file_magic_cmd begins "file"
+MAGIC_CMD=$MAGIC_CMD
+# Used on cygwin: DLL creation program.
+DLLTOOL="$DLLTOOL"
+# Used on cygwin: object dumper.
+OBJDUMP="$OBJDUMP"
+# Used on cygwin: assembler.
+AS="$AS"
+# The name of the directory that contains temporary libtool files.
+objdir=$objdir
+# How to create reloadable object files.
+reload_flag=$lt_reload_flag
+reload_cmds=$lt_reload_cmds
+# How to pass a linker flag through the compiler.
+wl=$lt_lt_prog_compiler_wl_F77
+# Object file suffix (normally "o").
+objext="$ac_objext"
+# Old archive suffix (normally "a").
+libext="$libext"
+# Shared library suffix (normally ".so").
+shrext_cmds='$shrext_cmds'
+# Executable file suffix (normally "").
+exeext="$exeext"
+# Additional compiler flags for building library objects.
+pic_flag=$lt_lt_prog_compiler_pic_F77
+pic_mode=$pic_mode
+# What is the maximum length of a command?
+max_cmd_len=$lt_cv_sys_max_cmd_len
+# Does compiler simultaneously support -c and -o options?
+compiler_c_o=$lt_lt_cv_prog_compiler_c_o_F77
+# Must we lock files when doing compilation ?
+need_locks=$lt_need_locks
+# Do we need the lib prefix for modules?
+need_lib_prefix=$need_lib_prefix
+# Do we need a version for libraries?
+need_version=$need_version
+# Whether dlopen is supported.
+dlopen_support=$enable_dlopen
+# Whether dlopen of programs is supported.
+dlopen_self=$enable_dlopen_self
+# Whether dlopen of statically linked programs is supported.
+dlopen_self_static=$enable_dlopen_self_static
+# Compiler flag to prevent dynamic linking.
+link_static_flag=$lt_lt_prog_compiler_static_F77
+# Compiler flag to turn off builtin functions.
+no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_F77
+# Compiler flag to allow reflexive dlopens.
+export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_F77
+# Compiler flag to generate shared objects directly from archives.
+whole_archive_flag_spec=$lt_whole_archive_flag_spec_F77
+# Compiler flag to generate thread-safe objects.
+thread_safe_flag_spec=$lt_thread_safe_flag_spec_F77
+# Library versioning type.
+version_type=$version_type
+# Format of library name prefix.
+libname_spec=$lt_libname_spec
+# List of archive names. First name is the real one, the rest are links.
+# The last name is the one that the linker finds with -lNAME.
+library_names_spec=$lt_library_names_spec
+# The coded name of the library, if different from the real name.
+soname_spec=$lt_soname_spec
+# Commands used to build and install an old-style archive.
+RANLIB=$lt_RANLIB
+old_archive_cmds=$lt_old_archive_cmds_F77
+old_postinstall_cmds=$lt_old_postinstall_cmds
+old_postuninstall_cmds=$lt_old_postuninstall_cmds
+# Create an old-style archive from a shared archive.
+old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_F77
+# Create a temporary old-style archive to link instead of a shared archive.
+old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_F77
+# Commands used to build and install a shared archive.
+archive_cmds=$lt_archive_cmds_F77
+archive_expsym_cmds=$lt_archive_expsym_cmds_F77
+postinstall_cmds=$lt_postinstall_cmds
+postuninstall_cmds=$lt_postuninstall_cmds
+# Commands used to build a loadable module (assumed same as above if empty)
+module_cmds=$lt_module_cmds_F77
+module_expsym_cmds=$lt_module_expsym_cmds_F77
+# Commands to strip libraries.
+old_striplib=$lt_old_striplib
+striplib=$lt_striplib
+# Dependencies to place before the objects being linked to create a
+# shared library.
+predep_objects=$lt_predep_objects_F77
+# Dependencies to place after the objects being linked to create a
+# shared library.
+postdep_objects=$lt_postdep_objects_F77
+# shared library.
+predeps=$lt_predeps_F77
+# shared library.
+postdeps=$lt_postdeps_F77
+# The library search path used internally by the compiler when linking
+# a shared library.
+compiler_lib_search_path=$lt_compiler_lib_search_path_F77
+# Method to check whether dependent libraries are shared objects.
+deplibs_check_method=$lt_deplibs_check_method
+# Command to use when deplibs_check_method == file_magic.
+file_magic_cmd=$lt_file_magic_cmd
+# Flag that allows shared libraries with undefined symbols to be built.
+allow_undefined_flag=$lt_allow_undefined_flag_F77
+# Flag that forces no undefined symbols.
+no_undefined_flag=$lt_no_undefined_flag_F77
+# Commands used to finish a libtool library installation in a directory.
+finish_cmds=$lt_finish_cmds
+# Same as above, but a single script fragment to be evaled but not shown.
+finish_eval=$lt_finish_eval
+# Take the output of nm and produce a listing of raw symbols and C names.
+global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
+# Transform the output of nm in a proper C declaration
+global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
+# Transform the output of nm in a C name address pair
+global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
+# This is the shared library runtime path variable.
+runpath_var=$runpath_var
+# This is the shared library path variable.
+shlibpath_var=$shlibpath_var
+# Is shlibpath searched before the hard-coded library search path?
+shlibpath_overrides_runpath=$shlibpath_overrides_runpath
+# How to hardcode a shared library path into an executable.
+hardcode_action=$hardcode_action_F77
+# Whether we should hardcode library paths into libraries.
+hardcode_into_libs=$hardcode_into_libs
+# Flag to hardcode \$libdir into a binary during linking.
+# This must work even if \$libdir does not exist.
+hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_F77
+# If ld is used when linking, flag to hardcode \$libdir into
+# a binary during linking. This must work even if \$libdir does
+# not exist.
+hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_F77
+# Whether we need a single -rpath flag with a separated argument.
+hardcode_libdir_separator=$lt_hardcode_libdir_separator_F77
+# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
+# resulting binary.
+hardcode_direct=$hardcode_direct_F77
+# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
+hardcode_minus_L=$hardcode_minus_L_F77
+# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
+# the resulting binary.
+hardcode_shlibpath_var=$hardcode_shlibpath_var_F77
+# Set to yes if building a shared library automatically hardcodes DIR into the library
+# and all subsequent libraries and executables linked against it.
+hardcode_automatic=$hardcode_automatic_F77
+# Variables whose values should be saved in libtool wrapper scripts and
+# restored at relink time.
+variables_saved_for_relink="$variables_saved_for_relink"
+# Whether libtool must link a program against all its dependency libraries.
+link_all_deplibs=$link_all_deplibs_F77
+# Compile-time system search path for libraries
+sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
+# Run-time system search path for libraries
+sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
+# Fix the shell variable \$srcfile for the compiler.
+fix_srcfile_path="$fix_srcfile_path_F77"
+# Set to yes if exported symbols are required.
+always_export_symbols=$always_export_symbols_F77
+# The commands to list exported symbols.
+export_symbols_cmds=$lt_export_symbols_cmds_F77
+# The commands to extract the exported symbol list from a shared archive.
+extract_expsyms_cmds=$lt_extract_expsyms_cmds
+# Symbols that should not be listed in the preloaded symbols.
+exclude_expsyms=$lt_exclude_expsyms_F77
+# Symbols that must always be exported.
+include_expsyms=$lt_include_expsyms_F77
+# ### END LIBTOOL TAG CONFIG: $tagname
+__EOF__
+else
+ # If there is no Makefile yet, we rely on a make rule to execute
+ # `config.status --recheck' to rerun these tests and create the
+ # libtool script then.
+ ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
+ if test -f "$ltmain_in"; then
+ test -f Makefile && make "$ltmain"
+ fi
+fi
+ac_ext=cc
+ac_cpp='$CXXCPP $CPPFLAGS'
+ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
+CC="$lt_save_CC"
+ else
+ tagname=""
+ fi
+ GCJ)
+ if test -n "$GCJ" && test "X$GCJ" != "Xno"; then
+# Source file extension for Java test sources.
+ac_ext=java
+# Object file extension for compiled Java test sources.
+objext=o
+objext_GCJ=$objext
+# Code to be used in simple compile tests
+lt_simple_compile_test_code="class foo {}\n"
+# Code to be used in simple link tests
+lt_simple_link_test_code='public class conftest { public static void main(String argv) {}; }\n'
+# ltmain only uses $CC for tagged configurations so make sure $CC is set.
+# If no C compiler was specified, use CC.
+LTCC=${LTCC-"$CC"}
+# Allow CC to be a program name with arguments.
+compiler=$CC
+lt_save_CC="$CC"
+CC=${GCJ-"gcj"}
+compiler=$CC
+compiler_GCJ=$CC
+# GCJ did not exist at the time GCC didn't implicitly link libc in.
+archive_cmds_need_lc_GCJ=no
+lt_prog_compiler_no_builtin_flag_GCJ=
+ lt_prog_compiler_no_builtin_flag_GCJ=' -fno-builtin'
+echo "$as_me:$LINENO: checking if $compiler supports -fno-rtti -fno-exceptions" >&5
+echo $ECHO_N "checking if $compiler supports -fno-rtti -fno-exceptions... $ECHO_C" >&6
+if test "${lt_cv_prog_compiler_rtti_exceptions+set}" = set; then
+ echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+ lt_cv_prog_compiler_rtti_exceptions=no
+ ac_outfile=conftest.$ac_objext
+ lt_compiler_flag="-fno-rtti -fno-exceptions"
+ # Insert the option either (1) after the last *FLAGS variable, or
+ # (2) before a word containing "conftest.", or (3) at the end.
+ # Note that $ac_compile itself does not contain backslashes and begins
+ # with a dollar sign (not a hyphen), so the echo should work correctly.
+ # The option is referenced via a variable to avoid confusing sed.
+ lt_compile=`echo "$ac_compile" | $SED \
+ -e 's:.*FLAGS}? :&$lt_compiler_flag :; t' \
+ -e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
+ -e 's:$: $lt_compiler_flag:'`
+ (eval echo "\"\$as_me:16004: $lt_compile\"" >&5)
+ (eval "$lt_compile" 2>conftest.err)
+ ac_status=$?
+ echo "$as_me:16008: \$? = $ac_status" >&5
+ if (exit $ac_status) && test -s "$ac_outfile"; then
+ # The compiler can only warn and ignore the option if not recognized
+ # So say no if there are warnings
+ if test ! -s conftest.err; then
+ lt_cv_prog_compiler_rtti_exceptions=yes
+ fi
+ fi
+ $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_rtti_exceptions" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_rtti_exceptions" >&6
+if test x"$lt_cv_prog_compiler_rtti_exceptions" = xyes; then
+ lt_prog_compiler_no_builtin_flag_GCJ="$lt_prog_compiler_no_builtin_flag_GCJ -fno-rtti -fno-exceptions"
+else
+fi
+fi
+lt_prog_compiler_wl_GCJ=
+lt_prog_compiler_pic_GCJ=
+lt_prog_compiler_static_GCJ=
+echo "$as_me:$LINENO: checking for $compiler option to produce PIC" >&5
+echo $ECHO_N "checking for $compiler option to produce PIC... $ECHO_C" >&6
+ lt_prog_compiler_wl_GCJ='-Wl,'
+ lt_prog_compiler_static_GCJ='-static'
+ case $host_os in
+ aix*)
+ # All AIX code is PIC.
+ # AIX 5 now supports IA64 processor
+ lt_prog_compiler_static_GCJ='-Bstatic'
+ fi
+ amigaos*)
+ # FIXME: we need at least 68020 code to build shared libraries, but
+ # adding the `-m68020' flag to GCC prevents building anything better,
+ # like `-m68040'.
+ lt_prog_compiler_pic_GCJ='-m68020 -resident32 -malways-restore-a4'
+ beos* | cygwin* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
+ # PIC is the default for these OSes.
+ mingw* | pw32* | os2*)
+ # This hack is so that the source file can tell whether it is being
+ # built for inclusion in a dll (and should export symbols for example).
+ lt_prog_compiler_pic_GCJ='-DDLL_EXPORT'
+ # PIC is the default on this platform
+ # Common symbols not allowed in MH_DYLIB files
+ lt_prog_compiler_pic_GCJ='-fno-common'
+ msdosdjgpp*)
+ # Just because we use GCC doesn't mean we suddenly get shared libraries
+ # on systems that don't support them.
+ lt_prog_compiler_can_build_shared_GCJ=no
+ enable_shared=no
+ sysv4*MP*)
+ lt_prog_compiler_pic_GCJ=-Kconform_pic
+ fi
+ hpux*)
+ # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
+ # not for PA HP-UX.
+ case "$host_cpu" in
+ hppa*64*|ia64*)
+ # +Z the default
+ lt_prog_compiler_pic_GCJ='-fPIC'
+ esac
+ esac
+ else
+ # PORTME Check for flag to pass linker flags through the system compiler.
+ case $host_os in
+ aix*)
+ else
+ lt_prog_compiler_static_GCJ='-bnso -bI:/lib/syscalls.exp'
+ fi
+ hpux9* | hpux10* | hpux11*)
+ hppa*64*|ia64*)
+ # +Z the default
+ lt_prog_compiler_pic_GCJ='+Z'
+ esac
+ # Is there a better lt_prog_compiler_static that works with the bundled CC?
+ lt_prog_compiler_static_GCJ='${wl}-a ${wl}archive'
+ # PIC (with -KPIC) is the default.
+ lt_prog_compiler_static_GCJ='-non_shared'
+ newsos6)
+ lt_prog_compiler_pic_GCJ='-KPIC'
+ linux*)
+ case $CC in
+ icc* | ecc*)
+ ccc*)
+ # All Alpha code is PIC.
+ esac
+ osf3* | osf4* | osf5*)
+ # All OSF/1 code is PIC.
+ sco3.2v5*)
+ lt_prog_compiler_pic_GCJ='-Kpic'
+ lt_prog_compiler_static_GCJ='-dn'
+ solaris*)
+ sunos4*)
+ lt_prog_compiler_wl_GCJ='-Qoption ld '
+ lt_prog_compiler_pic_GCJ='-PIC'
+ sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
+ sysv4*MP*)
+ lt_prog_compiler_pic_GCJ='-Kconform_pic'
+ fi
+ uts4*)
+ lt_prog_compiler_pic_GCJ='-pic'
+ esac
+ fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_GCJ" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_GCJ" >&6
+# Check to make sure the PIC flag actually works.
+if test -n "$lt_prog_compiler_pic_GCJ"; then
+echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic_GCJ works" >&5
+echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic_GCJ works... $ECHO_C" >&6
+if test "${lt_prog_compiler_pic_works_GCJ+set}" = set; then
+else
+ lt_prog_compiler_pic_works_GCJ=no
+ lt_compiler_flag="$lt_prog_compiler_pic_GCJ"
+ (eval echo "\"\$as_me:16237: $lt_compile\"" >&5)
+ ac_status=$?
+ echo "$as_me:16241: \$? = $ac_status" >&5
+ lt_prog_compiler_pic_works_GCJ=yes
+ fi
+ fi
+ $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works_GCJ" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_works_GCJ" >&6
+if test x"$lt_prog_compiler_pic_works_GCJ" = xyes; then
+ case $lt_prog_compiler_pic_GCJ in
+ *) lt_prog_compiler_pic_GCJ=" $lt_prog_compiler_pic_GCJ" ;;
+ esac
+else
+fi
+fi
+case "$host_os" in
+ # For platforms which do not support PIC, -DPIC is meaningless:
+ *djgpp*)
+ lt_prog_compiler_pic_GCJ="$lt_prog_compiler_pic_GCJ"
+esac
+echo "$as_me:$LINENO: checking if $compiler supports -c -o file.$ac_objext" >&5
+echo $ECHO_N "checking if $compiler supports -c -o file.$ac_objext... $ECHO_C" >&6
+if test "${lt_cv_prog_compiler_c_o_GCJ+set}" = set; then
+else
+ lt_cv_prog_compiler_c_o_GCJ=no
+ $rm -r conftest 2>/dev/null
+ mkdir conftest
+ cd conftest
+ mkdir out
+ lt_compiler_flag="-o out/conftest2.$ac_objext"
+ (eval echo "\"\$as_me:16297: $lt_compile\"" >&5)
+ (eval "$lt_compile" 2>out/conftest.err)
+ ac_status=$?
+ cat out/conftest.err >&5
+ echo "$as_me:16301: \$? = $ac_status" >&5
+ if (exit $ac_status) && test -s out/conftest2.$ac_objext
+ then
+ if test ! -s out/conftest.err; then
+ lt_cv_prog_compiler_c_o_GCJ=yes
+ fi
+ fi
+ chmod u+w .
+ $rm conftest*
+ # SGI C++ compiler will create directory out/ii_files/ for
+ # template instantiation
+ test -d out/ii_files && $rm out/ii_files/* && rmdir out/ii_files
+ $rm out/* && rmdir out
+ cd ..
+ rmdir conftest
+ $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o_GCJ" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_c_o_GCJ" >&6
+hard_links="nottested"
+if test "$lt_cv_prog_compiler_c_o_GCJ" = no && test "$need_locks" != no; then
+ # do not overwrite the value of need_locks provided by the user
+ echo "$as_me:$LINENO: checking if we can lock with hard links" >&5
+echo $ECHO_N "checking if we can lock with hard links... $ECHO_C" >&6
+ hard_links=yes
+ $rm conftest*
+ ln conftest.a conftest.b 2>/dev/null && hard_links=no
+ touch conftest.a
+ ln conftest.a conftest.b 2>&5 || hard_links=no
+ echo "$as_me:$LINENO: result: $hard_links" >&5
+echo "${ECHO_T}$hard_links" >&6
+ if test "$hard_links" = no; then
+ { echo "$as_me:$LINENO: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
+echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
+ need_locks=warn
+ fi
+else
+ need_locks=no
+fi
+echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
+echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
+ runpath_var=
+ allow_undefined_flag_GCJ=
+ enable_shared_with_static_runtimes_GCJ=no
+ archive_cmds_GCJ=
+ archive_expsym_cmds_GCJ=
+ old_archive_From_new_cmds_GCJ=
+ old_archive_from_expsyms_cmds_GCJ=
+ export_dynamic_flag_spec_GCJ=
+ whole_archive_flag_spec_GCJ=
+ thread_safe_flag_spec_GCJ=
+ hardcode_libdir_flag_spec_GCJ=
+ hardcode_libdir_flag_spec_ld_GCJ=
+ hardcode_libdir_separator_GCJ=
+ hardcode_direct_GCJ=no
+ hardcode_minus_L_GCJ=no
+ hardcode_shlibpath_var_GCJ=unsupported
+ link_all_deplibs_GCJ=unknown
+ hardcode_automatic_GCJ=no
+ module_cmds_GCJ=
+ module_expsym_cmds_GCJ=
+ always_export_symbols_GCJ=no
+ export_symbols_cmds_GCJ='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
+ # include_expsyms should be a list of space-separated symbols to be *always*
+ # included in the symbol list
+ include_expsyms_GCJ=
+ # exclude_expsyms can be an extended regexp of symbols to exclude
+ # it will be wrapped by ` (' and `)$', so one must not match beginning or
+ # end of line. Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
+ # as well as any symbol that contains `d'.
+ exclude_expsyms_GCJ="_GLOBAL_OFFSET_TABLE_"
+ # Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
+ # platforms (ab)use it in PIC code, but their linkers get confused if
+ # the symbol is explicitly referenced. Since portable code cannot
+ # rely on this symbol name, it's probably fine to never include it in
+ # preloaded symbol tables.
+ extract_expsyms_cmds=
+ case $host_os in
+ cygwin* | mingw* | pw32*)
+ # FIXME: the MSVC++ port hasn't been tested in a loooong time
+ # When not using gcc, we currently assume that we are using
+ # Microsoft Visual C++.
+ if test "$GCC" != yes; then
+ with_gnu_ld=no
+ fi
+ openbsd*)
+ with_gnu_ld=no
+ esac
+ ld_shlibs_GCJ=yes
+ if test "$with_gnu_ld" = yes; then
+ # If archive_cmds runs LD, not CC, wlarc should be empty
+ wlarc='${wl}'
+ # See if GNU ld supports shared libraries.
+ case $host_os in
+ aix3* | aix4* | aix5*)
+ # On AIX/PPC, the GNU linker is very broken
+ if test "$host_cpu" != ia64; then
+ ld_shlibs_GCJ=no
+ cat <<EOF 1>&2
+*** Warning: the GNU linker, at least up to release 2.9.1, is reported
+*** to be unable to reliably create shared libraries on AIX.
+*** Therefore, libtool is disabling shared libraries support. If you
+*** really care for shared libraries, you may want to modify your PATH
+*** so that a non-GNU linker is found, and then restart.
+EOF
+ fi
+ amigaos*)
+ archive_cmds_GCJ='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
+ hardcode_libdir_flag_spec_GCJ='-L$libdir'
+ hardcode_minus_L_GCJ=yes
+ # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
+ # that the semantics of dynamic libraries on AmigaOS, at least up
+ # to version 4, is to share data among multiple programs linked
+ # with the same dynamic library. Since this doesn't match the
+ # behavior of shared libraries on other platforms, we can't use
+ # them.
+ ld_shlibs_GCJ=no
+ beos*)
+ if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+ allow_undefined_flag_GCJ=unsupported
+ # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
+ # support --undefined. This deserves some investigation. FIXME
+ archive_cmds_GCJ='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+ else
+ ld_shlibs_GCJ=no
+ fi
+ # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, GCJ) is actually meaningless,
+ # as there is no search path for DLLs.
+ enable_shared_with_static_runtimes_GCJ=yes
+ export_symbols_cmds_GCJ='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGS] /s/.* \([^ ]*\)/\1 DATA/'\'' | $SED -e '\''/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
+ if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
+ archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--image-base=0x10000000 ${wl}--out-implib,$lib'
+ # If the export-symbols file already is a .def file (1st line
+ # is EXPORTS), use it as is; otherwise, prepend...
+ archive_expsym_cmds_GCJ='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
+ cp $export_symbols $output_objdir/$soname.def;
+ else
+ echo EXPORTS > $output_objdir/$soname.def;
+ cat $export_symbols >> $output_objdir/$soname.def;
+ fi~
+ $CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--image-base=0x10000000 ${wl}--out-implib,$lib'
+ else
+ ld_shlibs=no
+ fi
+ netbsd*)
+ if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
+ archive_cmds_GCJ='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
+ wlarc=
+ else
+ archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+ archive_expsym_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+ fi
+ solaris* | sysv5*)
+ if $LD -v 2>&1 | grep 'BFD 2\.8' > /dev/null; then
+ ld_shlibs_GCJ=no
+ cat <<EOF 1>&2
+*** Warning: The releases 2.8.* of the GNU linker cannot reliably
+*** create shared libraries on Solaris systems. Therefore, libtool
+*** is disabling shared libraries support. We urge you to upgrade GNU
+*** binutils to release 2.9.1 or newer. Another option is to modify
+*** your PATH or compiler configuration so that the native linker is
+*** used, and then restart.
+EOF
+ elif $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+ else
+ ld_shlibs_GCJ=no
+ fi
+ sunos4*)
+ archive_cmds_GCJ='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+ wlarc=
+ hardcode_direct_GCJ=yes
+ hardcode_shlibpath_var_GCJ=no
+ linux*)
+ tmp_archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+ archive_cmds_GCJ="$tmp_archive_cmds"
+ supports_anon_versioning=no
+ case `$LD -v 2>/dev/null` in
+ *\ 01.* | *\ 2.[0-9].* | *\ 2.10.*) ;; # catch versions < 2.11
+ *\ 2.11.93.0.2\ *) supports_anon_versioning=yes ;; # RH7.3 ...
+ *\ 2.11.92.0.12\ *) supports_anon_versioning=yes ;; # Mandrake 8.2 ...
+ *\ 2.11.*) ;; # other 2.11 versions
+ *) supports_anon_versioning=yes ;;
+ esac
+ if test $supports_anon_versioning = yes; then
+ archive_expsym_cmds_GCJ='$echo "{ global:" > $output_objdir/$libname.ver~
+cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $output_objdir/$libname.ver~
+$echo "local: *; };" >> $output_objdir/$libname.ver~
+ $CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
+ else
+ archive_expsym_cmds_GCJ="$tmp_archive_cmds"
+ fi
+ else
+ ld_shlibs_GCJ=no
+ fi
+ else
+ ld_shlibs_GCJ=no
+ fi
+ esac
+ if test "$ld_shlibs_GCJ" = yes; then
+ hardcode_libdir_flag_spec_GCJ='${wl}--rpath ${wl}$libdir'
+ export_dynamic_flag_spec_GCJ='${wl}--export-dynamic'
+ # ancient GNU ld didn't support --whole-archive et. al.
+ if $LD --help 2>&1 | grep 'no-whole-archive' > /dev/null; then
+ whole_archive_flag_spec_GCJ="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
+ else
+ fi
+ fi
+ else
+ # PORTME fill in a description of your system's linker (not GNU ld)
+ case $host_os in
+ aix3*)
+ always_export_symbols_GCJ=yes
+ archive_expsym_cmds_GCJ='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
+ # Note: this linker hardcodes the directories in LIBPATH if there
+ # are no directories specified by -L.
+ if test "$GCC" = yes && test -z "$link_static_flag"; then
+ # Neither direct hardcoding nor static linking is supported with a
+ # broken collect2.
+ hardcode_direct_GCJ=unsupported
+ fi
+ aix4* | aix5*)
+ if test "$host_cpu" = ia64; then
+ # On IA64, the linker does run time linking by default, so we don't
+ # have to do anything special.
+ aix_use_runtimelinking=no
+ exp_sym_flag='-Bexport'
+ no_entry_flag=""
+ else
+ # If we're using GNU nm, then we don't want the "-C" option.
+ # -C means demangle to AIX nm, but means don't demangle with GNU nm
+ if $NM -V 2>&1 | grep 'GNU' > /dev/null; then
+ export_symbols_cmds_GCJ='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+ else
+ export_symbols_cmds_GCJ='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+ fi
+ # Test if we are trying to use run time linking or normal
+ # AIX style linking. If -brtl is somewhere in LDFLAGS, we
+ # need to do runtime linking.
+ case $host_os in aix4.[23]|aix4.[23].*|aix5*)
+ for ld_flag in $LDFLAGS; do
+ if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
+ aix_use_runtimelinking=yes
+ break
+ fi
+ done
+ esac
+ exp_sym_flag='-bexport'
+ no_entry_flag='-bnoentry'
+ fi
+ # When large executables or shared objects are built, AIX ld can
+ # have problems creating the table of contents. If linking a library
+ # or program results in "error TOC overflow" add -mminimal-toc to
+ # CXXFLAGS/CFLAGS for g++/gcc. In the cases where that is not
+ # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
+ archive_cmds_GCJ=''
+ hardcode_libdir_separator_GCJ=':'
+ link_all_deplibs_GCJ=yes
+ case $host_os in aix4.012|aix4.012.*)
+ # We only want to do this on AIX 4.2 and lower, the check
+ # below for broken collect2 doesn't work under 4.3+
+ collect2name=`${CC} -print-prog-name=collect2`
+ if test -f "$collect2name" && \
+ strings "$collect2name" | grep resolve_lib_name >/dev/null
+ then
+ # We have reworked collect2
+ else
+ # We have old collect2
+ # It fails to find uninstalled libraries when the uninstalled
+ # path is not listed in the libpath. Setting hardcode_minus_L
+ # to unsupported forces relinking
+ fi
+ esac
+ shared_flag='-shared'
+ else
+ # not using gcc
+ # VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
+ # chokes on -Wl,-G. The following line is correct:
+ shared_flag='-G'
+ else
+ shared_flag='${wl}-G'
+ else
+ shared_flag='${wl}-bM:SRE'
+ fi
+ fi
+ fi
+ # It seems that -bexpall does not export symbols beginning with
+ # underscore (_), so it is better to generate a list of symbols to export.
+ # Warning - without using the other runtime loading flags (-brtl),
+ # -berok will link without error, but may produce a broken library.
+ allow_undefined_flag_GCJ='-berok'
+ # Determine the default libpath from the value encoded in an empty executable.
+ cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h. */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h. */
+int
+main ()
+ return 0;
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+ (eval $ac_link) 2>conftest.er1
+ ac_status=$?
+ grep -v '^ *+' conftest.er1 >conftest.err
+ rm -f conftest.er1
+ cat conftest.err >&5
+ (exit $ac_status); } &&
+ { ac_try='test -z "$ac_cxx_werror_flag"
+ || test ! -s conftest.err'
+ { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+ (eval $ac_try) 2>&5
+ ac_status=$?
+ (exit $ac_status); }; } &&
+ { ac_try='test -s conftest$ac_exeext'
+ ac_status=$?
+ (exit $ac_status); }; }; then
+aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
+# Check for a 64-bit object if we didn't find anything.
+if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
+}'`; fi
+else
+ echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+fi
+rm -f conftest.err conftest.$ac_objext \
+ conftest$ac_exeext conftest.$ac_ext
+if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
+ hardcode_libdir_flag_spec_GCJ='${wl}-blibpath:$libdir:'"$aix_libpath"
+ archive_expsym_cmds_GCJ="\$CC"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols $shared_flag"
+ else
+ hardcode_libdir_flag_spec_GCJ='${wl}-R $libdir:/usr/lib:/lib'
+ allow_undefined_flag_GCJ="-z nodefs"
+ archive_expsym_cmds_GCJ="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols"
+ else
+/* confdefs.h. */
+_ACEOF
+int
+main ()
+ return 0;
+_ACEOF
+ ac_status=$?
+ ac_status=$?
+ ac_status=$?
+}'`; fi
+else
+fi
+ # Warning - without using the other run time loading flags,
+ no_undefined_flag_GCJ=' ${wl}-bernotok'
+ allow_undefined_flag_GCJ=' ${wl}-berok'
+ # -bexpall does not export symbols beginning with underscore (_)
+ # Exported symbols can be pulled into shared objects from archives
+ whole_archive_flag_spec_GCJ=' '
+ archive_cmds_need_lc_GCJ=yes
+ # This is similar to how AIX traditionally builds it's shared libraries.
+ archive_expsym_cmds_GCJ="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${wl}-bE:$export_symbols ${wl}-bnoentry${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
+ fi
+ fi
+ amigaos*)
+ # see comment about different semantics on the GNU ld section
+ ld_shlibs_GCJ=no
+ bsdi4*)
+ export_dynamic_flag_spec_GCJ=-rdynamic
+ # hardcode_libdir_flag_spec is actually meaningless, as there is
+ # no search path for DLLs.
+ hardcode_libdir_flag_spec_GCJ=' '
+ # Tell ltmain to make .lib files, not .a files.
+ libext=lib
+ # Tell ltmain to make .dll files, not .so files.
+ # FIXME: Setting linknames here is a bad hack.
+ archive_cmds_GCJ='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | $SED -e '\''s/ -lc$//'\''` -link -dll~linknames='
+ # The linker will automatically build a .lib file if we build a DLL.
+ old_archive_From_new_cmds_GCJ='true'
+ # FIXME: Should let the user specify the lib program.
+ old_archive_cmds_GCJ='lib /OUT:$oldlib$oldobjs$old_deplibs'
+ fix_srcfile_path='`cygpath -w "$srcfile"`'
+ darwin* | rhapsody*)
+ if test "$GXX" = yes ; then
+ archive_cmds_need_lc_GCJ=no
+ case "$host_os" in
+ rhapsody* | darwin1.[012])
+ allow_undefined_flag_GCJ='-undefined suppress'
+ *) # Darwin 1.3 on
+ if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
+ allow_undefined_flag_GCJ='-flat_namespace -undefined suppress'
+ else
+ case ${MACOSX_DEPLOYMENT_TARGET} in
+ 10.[012])
+ 10.*)
+ allow_undefined_flag_GCJ='-undefined dynamic_lookup'
+ esac
+ fi
+ esac
+ lt_int_apple_cc_single_mod=no
+ output_verbose_link_cmd='echo'
+ if $CC -dumpspecs 2>&1 | grep 'single_module' >/dev/null ; then
+ lt_int_apple_cc_single_mod=yes
+ fi
+ if test "X$lt_int_apple_cc_single_mod" = Xyes ; then
+ archive_cmds_GCJ='$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+ else
+ archive_cmds_GCJ='$CC -r ${wl}-bind_at_load -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+ fi
+ module_cmds_GCJ='$CC ${wl}-bind_at_load $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
+ # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin ld's
+ archive_expsym_cmds_GCJ='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+ else
+ archive_expsym_cmds_GCJ='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -r ${wl}-bind_at_load -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+ fi
+ module_expsym_cmds_GCJ='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+ hardcode_automatic_GCJ=yes
+ whole_archive_flag_spec_GCJ='-all_load $convenience'
+ else
+ ld_shlibs_GCJ=no
+ fi
+ dgux*)
+ archive_cmds_GCJ='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
+ freebsd1*)
+ ld_shlibs_GCJ=no
+ # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
+ # support. Future versions do this automatically, but an explicit c++rt0.o
+ # does not break anything, and helps significantly (at the cost of a little
+ # extra space).
+ freebsd2.2*)
+ archive_cmds_GCJ='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
+ hardcode_libdir_flag_spec_GCJ='-R$libdir'
+ # Unfortunately, older versions of FreeBSD 2 do not have this feature.
+ freebsd2*)
+ archive_cmds_GCJ='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+ # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
+ freebsd* | kfreebsd*-gnu)
+ archive_cmds_GCJ='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
+ hpux9*)
+ if test "$GCC" = yes; then
+ archive_cmds_GCJ='$rm $output_objdir/$soname~$CC -shared -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $libobjs $deplibs $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+ else
+ archive_cmds_GCJ='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+ fi
+ hardcode_libdir_flag_spec_GCJ='${wl}+b ${wl}$libdir'
+ hardcode_libdir_separator_GCJ=:
+ # hardcode_minus_L: Not really in the search PATH,
+ # but as the default location of the library.
+ export_dynamic_flag_spec_GCJ='${wl}-E'
+ hpux10* | hpux11*)
+ if test "$GCC" = yes -a "$with_gnu_ld" = no; then
+ hppa*64*|ia64*)
+ archive_cmds_GCJ='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ archive_cmds_GCJ='$CC -shared -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+ esac
+ else
+ hppa*64*|ia64*)
+ archive_cmds_GCJ='$LD -b +h $soname -o $lib $libobjs $deplibs $linker_flags'
+ archive_cmds_GCJ='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
+ esac
+ fi
+ if test "$with_gnu_ld" = no; then
+ hppa*64*)
+ hardcode_libdir_flag_spec_ld_GCJ='+b $libdir'
+ ia64*)
+ esac
+ fi
+ irix5* | irix6* | nonstopux*)
+ archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+ else
+ archive_cmds_GCJ='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+ hardcode_libdir_flag_spec_ld_GCJ='-rpath $libdir'
+ fi
+ hardcode_libdir_flag_spec_GCJ='${wl}-rpath ${wl}$libdir'
+ netbsd*)
+ archive_cmds_GCJ='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags' # a.out
+ else
+ archive_cmds_GCJ='$LD -shared -o $lib $libobjs $deplibs $linker_flags' # ELF
+ fi
+ newsos6)
+ openbsd*)
+ archive_cmds_GCJ='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
+ hardcode_libdir_flag_spec_GCJ='${wl}-rpath,$libdir'
+ else
+ case $host_os in
+ openbsd[01].* | openbsd2.[0-7] | openbsd2.[0-7].*)
+ esac
+ fi
+ os2*)
+ archive_cmds_GCJ='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
+ old_archive_From_new_cmds_GCJ='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
+ osf3*)
+ allow_undefined_flag_GCJ=' ${wl}-expect_unresolved ${wl}\*'
+ archive_cmds_GCJ='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+ else
+ allow_undefined_flag_GCJ=' -expect_unresolved \*'
+ archive_cmds_GCJ='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+ fi
+ osf4* | osf5*) # as osf3* with the addition of -msym flag
+ archive_cmds_GCJ='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+ else
+ archive_cmds_GCJ='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+ archive_expsym_cmds_GCJ='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
+ $LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${objdir}/so_locations -o $lib~$rm $lib.exp'
+ # Both c and cxx compiler support -rpath directly
+ hardcode_libdir_flag_spec_GCJ='-rpath $libdir'
+ fi
+ sco3.2v5*)
+ export_dynamic_flag_spec_GCJ='${wl}-Bexport'
+ runpath_var=LD_RUN_PATH
+ hardcode_runpath_var=yes
+ solaris*)
+ no_undefined_flag_GCJ=' -z text'
+ archive_cmds_GCJ='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ archive_expsym_cmds_GCJ='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
+ $CC -shared ${wl}-M ${wl}$lib.exp ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags~$rm $lib.exp'
+ else
+ archive_cmds_GCJ='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
+ $LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
+ fi
+ case $host_os in
+ solaris2.[0-5] | solaris2.[0-5].*) ;;
+ *) # Supported since Solaris 2.6 (maybe 2.5.1?)
+ whole_archive_flag_spec_GCJ='-z allextract$convenience -z defaultextract' ;;
+ esac
+ sunos4*)
+ if test "x$host_vendor" = xsequent; then
+ # Use $CC to link under sequent, because it throws in some extra .o
+ # files that make .init and .fini sections work.
+ archive_cmds_GCJ='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
+ else
+ archive_cmds_GCJ='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
+ fi
+ sysv4)
+ sni)
+ hardcode_direct_GCJ=yes # is this really true???
+ siemens)
+ ## LD is ld it makes a PLAMLIB
+ ## CC just makes a GrossModule.
+ archive_cmds_GCJ='$LD -G -o $lib $libobjs $deplibs $linker_flags'
+ reload_cmds_GCJ='$CC -r -o $output$reload_objs'
+ motorola)
+ hardcode_direct_GCJ=no #Motorola manual says yes, but my tests say they lie
+ esac
+ runpath_var='LD_RUN_PATH'
+ sysv4.3*)
+ export_dynamic_flag_spec_GCJ='-Bexport'
+ sysv4*MP*)
+ if test -d /usr/nec; then
+ ld_shlibs_GCJ=yes
+ fi
+ sysv4.2uw2*)
+ sysv5OpenUNIX8* | sysv5UnixWare7* | sysv5uw[78]* | unixware7*)
+ no_undefined_flag_GCJ='${wl}-z ${wl}text'
+ else
+ archive_cmds_GCJ='$CC -G ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ fi
+ sysv5*)
+ # $CC -shared without GNU ld will not create a library from C++
+ # object files and a static libstdc++, better avoid it by now
+ uts4*)
+ ld_shlibs_GCJ=no
+ esac
+ fi
+echo "$as_me:$LINENO: result: $ld_shlibs_GCJ" >&5
+echo "${ECHO_T}$ld_shlibs_GCJ" >&6
+test "$ld_shlibs_GCJ" = no && can_build_shared=no
+variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
+if test "$GCC" = yes; then
+ variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
+fi
+# Do we need to explicitly link libc?
+case "x$archive_cmds_need_lc_GCJ" in
+x|xyes)
+ # Assume -lc should be added
+ if test "$enable_shared" = yes && test "$GCC" = yes; then
+ case $archive_cmds_GCJ in
+ # FIXME: we may have to deal with multi-command sequences.
+ '$CC '*)
+ # Test whether the compiler implicitly links with -lc since on some
+ # systems, -lgcc has to come before -lc. If gcc already passes -lc
+ # to ld, don't add -lc before -lgcc.
+ echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
+echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
+ $rm conftest*
+ printf "$lt_simple_compile_test_code" > conftest.$ac_ext
+ if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+ (eval $ac_compile) 2>&5
+ ac_status=$?
+ (exit $ac_status); } 2>conftest.err; then
+ soname=conftest
+ lib=conftest
+ libobjs=conftest.$ac_objext
+ deplibs=
+ wl=$lt_prog_compiler_wl_GCJ
+ compiler_flags=-v
+ linker_flags=-v
+ verstring=
+ output_objdir=.
+ libname=conftest
+ lt_save_allow_undefined_flag=$allow_undefined_flag_GCJ
+ if { (eval echo "$as_me:$LINENO: \"$archive_cmds_GCJ 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
+ (eval $archive_cmds_GCJ 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
+ ac_status=$?
+ then
+ else
+ fi
+ allow_undefined_flag_GCJ=$lt_save_allow_undefined_flag
+ else
+ cat conftest.err 1>&5
+ fi
+ $rm conftest*
+ echo "$as_me:$LINENO: result: $archive_cmds_need_lc_GCJ" >&5
+echo "${ECHO_T}$archive_cmds_need_lc_GCJ" >&6
+ esac
+ fi
+esac
echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
library_names_spec=
libname_spec='lib$name'
soname_spec=
+shrext_cmds=".so"
postinstall_cmds=
postuninstall_cmds=
finish_cmds=
@@ -6640,16 +17278,35 @@
version_type=none
dynamic_linker="$host_os ld.so"
sys_lib_dlsearch_path_spec="/lib /usr/lib"
-sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
+ sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
+ if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
+ # if the path contains ";" then we assume it to be the separator
+ # otherwise default to the standard path separator (i.e. ":") - it is
+ # assumed that no part of a normal pathname contains ";" but that should
+ # okay in the real world where ";" in dirpaths is itself problematic.
+ sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
+ else
+ sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
+ fi
+else
+ sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
+fi
+need_lib_prefix=unknown
+hardcode_into_libs=no
+# when you set need_version to no, make sure it does not cause -set_version
+# flags to be left without arguments
+need_version=unknown
case $host_os in
aix3*)
version_type=linux
- library_names_spec='${libname}${release}.so$versuffix $libname.a'
+ library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
shlibpath_var=LIBPATH
- # AIX has no versioning support, so we append a major version to the name.
- soname_spec='${libname}${release}.so$major'
+ # AIX 3 has no versioning support, so we append a major version to the name.
+ soname_spec='${libname}${release}${shared_ext}$major'
aix4* | aix5*)
@@ -6659,7 +17316,7 @@
hardcode_into_libs=yes
# AIX 5 supports IA64
- library_names_spec='${libname}${release}.so$major ${libname}${release}.so$versuffix $libname.so'
+ library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
else
# With GCC up to 2.95.x, collect2 would create an import file
@@ -6669,43 +17326,41 @@
# development snapshots of GCC prior to 3.0.
case $host_os in
aix4 | aix4.[01] | aix4.[01].*)
- if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
- echo ' yes '
- echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
- else
- can_build_shared=no
- fi
+ if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
+ echo ' yes '
+ echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
+ else
+ can_build_shared=no
+ fi
esac
- # AIX (on Power*) has no versioning support, so currently we can
- # not hardcode correct soname into executable. Probably we can
- # add versioning support to collect2, so additional links can
- # be useful in future.
+ # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
+ # soname into executable. Probably we can add versioning support to
+ # collect2, so additional links can be useful in future.
if test "$aix_use_runtimelinking" = yes; then
# If using run time linking (on AIX 4.2 or later) use lib<name>.so
# instead of lib<name>.a to let people know that these are not
# typical AIX shared libraries.
- library_names_spec='${libname}${release}.so$versuffix ${libname}${release}.so$major $libname.so'
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
else
# We preserve .a as extension for shared libraries through AIX4.2
# and later when we are not doing run time linking.
library_names_spec='${libname}${release}.a $libname.a'
fi
fi
- hardcode_into_libs=yes
amigaos*)
library_names_spec='$libname.ixlibrary $libname.a'
# Create ${libname}_ixlibrary.a entries in /sys/libs.
- finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "(cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a)"; (cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a) || exit 1; done'
+ finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
beos*)
- library_names_spec='${libname}.so'
+ library_names_spec='${libname}${shared_ext}'
shlibpath_var=LIBRARY_PATH
@@ -6713,13 +17368,12 @@
bsdi4*)
version_type=linux
need_version=no
finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
- export_dynamic_flag_spec=-rdynamic
# the default ld.so.conf also contains /usr/contrib/lib and
# /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
# libtool to hard-code these into programs
@@ -6727,29 +17381,55 @@
version_type=windows
+ shrext_cmds=".dll"
need_version=no
need_lib_prefix=no
case $GCC,$host_os in
- yes,cygwin*)
+ yes,cygwin* | yes,mingw* | yes,pw32*)
library_names_spec='$libname.dll.a'
- soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | sed -e 's/[.]/-/g'`${versuffix}.dll'
- postinstall_cmds='dlpath=`bash 2>&1 -c '\''. $dir/${file}i;echo \$dlname'\''`~
+ # DLL is installed to $(libdir)/../bin by postinstall_cmds
+ postinstall_cmds='base_file=`basename \${file}`~
+ dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
dldir=$destdir/`dirname \$dlpath`~
test -d \$dldir || mkdir -p \$dldir~
- $install_prog .libs/$dlname \$dldir/$dlname'
- postuninstall_cmds='dldll=`bash 2>&1 -c '\''. $file; echo \$dlname'\''`~
+ $install_prog $dir/$dlname \$dldir/$dlname'
+ postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
dlpath=$dir/\$dldll~
$rm \$dlpath'
+ shlibpath_overrides_runpath=yes
+ case $host_os in
+ cygwin*)
+ # Cygwin DLLs use 'cyg' prefix rather than 'lib'
+ soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+ sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
+ mingw*)
+ # MinGW DLLs use traditional 'lib' prefix
+ soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+ if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
+ # It is most probably a Windows format PATH printed by
+ # mingw gcc, but we are running on Cygwin. Gcc prints its search
+ # path with ; separators, and with drive letters. We can handle the
+ # drive letters (cygwin fileutils understands them), so leave them,
+ # especially as we might pass files found there to a mingw objdump,
+ # which wouldn't understand a cygwinified path. Ahh.
+ else
+ fi
+ pw32*)
+ # pw32 DLLs use 'pw' prefix rather than 'lib'
+ library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/./-/g'`${versuffix}${shared_ext}'
+ esac
- yes,mingw*)
- library_names_spec='${libname}`echo ${release} | sed -e 's/[.]/-/g'`${versuffix}.dll'
- sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | sed -e "s/^libraries://" -e "s/;/ /g" -e "s,=/,/,g"`
- yes,pw32*)
- library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | sed -e 's/./-/g'`${versuffix}.dll'
- library_names_spec='${libname}`echo ${release} | sed -e 's/[.]/-/g'`${versuffix}.dll $libname.lib'
+ library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
esac
dynamic_linker='Win32 ld.exe'
@@ -6762,30 +17442,56 @@
version_type=darwin
need_lib_prefix=no
need_version=no
- # FIXME: Relying on posixy $() will cause problems for
- # cross-compilation, but unfortunately the echo tests do not
- # yet detect zsh echo's removal of \ escapes.
- library_names_spec='${libname}${release}${versuffix}.$(test .$module = .yes && echo so || echo dylib) ${libname}${release}${major}.$(test .$module = .yes && echo so || echo dylib) ${libname}.$(test .$module = .yes && echo so || echo dylib)'
- soname_spec='${libname}${release}${major}.$(test .$module = .yes && echo so || echo dylib)'
+ library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
+ soname_spec='${libname}${release}${major}$shared_ext'
shlibpath_var=DYLD_LIBRARY_PATH
+ shrext_cmds='$(test .$module = .yes && echo .so || echo .dylib)'
+ # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
+ sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
+ else
+ sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
+ fi
+ sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
+dgux*)
+ version_type=linux
+ need_lib_prefix=no
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
+ shlibpath_var=LD_LIBRARY_PATH
freebsd1*)
dynamic_linker=no
+kfreebsd*-gnu)
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
+ shlibpath_overrides_runpath=no
+ hardcode_into_libs=yes
+ dynamic_linker='GNU ld.so'
freebsd*)
objformat=`test -x /usr/bin/objformat && /usr/bin/objformat || echo aout`
version_type=freebsd-$objformat
case $version_type in
freebsd-elf*)
- library_names_spec='${libname}${release}.so$versuffix ${libname}${release}.so $libname.so'
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
need_version=no
need_lib_prefix=no
freebsd-*)
- library_names_spec='${libname}${release}.so$versuffix $libname.so$versuffix'
+ library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
need_version=yes
esac
@@ -6794,7 +17500,11 @@
freebsd2*)
+ freebsd3.01* | freebsdelf3.01*)
+ *) # from 3.2 on
@@ -6805,8 +17515,8 @@
version_type=linux
need_lib_prefix=no
need_version=no
- library_names_spec='${libname}${release}.so$versuffix ${libname}${release}.so${major} ${libname}.so'
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
@@ -6814,14 +17524,45 @@
# Give a soname corresponding to the major version so that dld.sl refuses to
# link against other versions.
- dynamic_linker="$host_os dld.sl"
version_type=sunos
need_lib_prefix=no
need_version=no
- shlibpath_var=SHLIB_PATH
- shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
- library_names_spec='${libname}${release}.sl$versuffix ${libname}${release}.sl$major $libname.sl'
- soname_spec='${libname}${release}.sl$major'
+ ia64*)
+ shrext_cmds='.so'
+ dynamic_linker="$host_os dld.so"
+ shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
+ if test "X$HPUX_IA64_MODE" = X32; then
+ sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
+ else
+ sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
+ fi
+ sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
+ hppa*64*)
+ shrext_cmds='.sl'
+ dynamic_linker="$host_os dld.sl"
+ shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
+ sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
+ shrext_cmds='.sl'
+ shlibpath_var=SHLIB_PATH
+ shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
+ esac
# HP-UX runs *really* slowly unless shared libraries are mode 555.
postinstall_cmds='chmod 555 $lib'
@@ -6829,21 +17570,29 @@
case $host_os in
nonstopux*) version_type=nonstopux ;;
- *) version_type=irix ;;
+ if test "$lt_cv_prog_gnu_ld" = yes; then
+ else
+ version_type=irix
+ fi ;;
esac
need_lib_prefix=no
need_version=no
- library_names_spec='${libname}${release}.so$versuffix ${libname}${release}.so$major ${libname}${release}.so $libname.so'
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
case $host_os in
irix5* | nonstopux*)
libsuff= shlibsuff=
case $LD in # libtool.m4 will add one of these switches to LD
- *-32|*"-32 ") libsuff= shlibsuff= libmagic=32-bit;;
- *-n32|*"-n32 ") libsuff=32 shlibsuff=N32 libmagic=N32;;
- *-64|*"-64 ") libsuff=64 shlibsuff=64 libmagic=64-bit;;
+ *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
+ libsuff= shlibsuff= libmagic=32-bit;;
+ *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
+ libsuff=32 shlibsuff=N32 libmagic=N32;;
+ *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
+ libsuff=64 shlibsuff=64 libmagic=64-bit;;
*) libsuff= shlibsuff= libmagic=never-match;;
esac
@@ -6852,20 +17601,21 @@
sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
# No shared lib support for Linux oldld, aout, or coff.
-linux-gnuoldld* | linux-gnuaout* | linux-gnucoff*)
+linux*oldld* | linux*aout* | linux*coff*)
dynamic_linker=no
# This must be Linux ELF.
-linux-gnu*)
+linux*)
version_type=linux
need_lib_prefix=no
need_version=no
finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
@@ -6874,19 +17624,11 @@
# before this can be enabled.
- # We used to test for /lib/ld.so.1 and disable shared libraries on
- # powerpc, because MkLinux only supported shared libraries with the
- # GNU dynamic linker. Since this was broken with cross compilers,
- # most powerpc-linux boxes support dynamic linking these days and
- # people can always --disable-shared, the test was removed, and we
- # assume the GNU/Linux dynamic linker is in use.
- dynamic_linker='GNU/Linux ld.so'
- # Find out which ABI we are using (multilib Linux x86_64 hack).
+ # find out which ABI we are using
libsuff=
case "$host_cpu" in
- x86_64*|s390x*)
- echo '#line 6889 "configure"' > conftest.$ac_ext
+ x86_64*|s390x*|powerpc64*)
+ echo '#line 17631 "configure"' > conftest.$ac_ext
ac_status=$?
@@ -6895,29 +17637,52 @@
case `/usr/bin/file conftest.$ac_objext` in
*64-bit*)
libsuff=64
+ sys_lib_search_path_spec="/lib${libsuff} /usr/lib${libsuff} /usr/local/lib${libsuff}"
esac
fi
rm -rf conftest*
esac
- sys_lib_dlsearch_path_spec="/lib${libsuff} /usr/lib${libsuff}"
- sys_lib_search_path_spec="/lib${libsuff} /usr/lib${libsuff} /usr/local/lib${libsuff}"
+ # Append ld.so.conf contents to the search path
+ if test -f /etc/ld.so.conf; then
+ lt_ld_extra=`$SED -e 's/:,\t/ /g;s/=^=*$//;s/=^= * / /g' /etc/ld.so.conf | tr '\n' ' '`
+ sys_lib_dlsearch_path_spec="/lib${libsuff} /usr/lib${libsuff} $lt_ld_extra"
+ fi
+ # We used to test for /lib/ld.so.1 and disable shared libraries on
+ # powerpc, because MkLinux only supported shared libraries with the
+ # GNU dynamic linker. Since this was broken with cross compilers,
+ # most powerpc-linux boxes support dynamic linking these days and
+ # people can always --disable-shared, the test was removed, and we
+ # assume the GNU/Linux dynamic linker is in use.
+ dynamic_linker='GNU/Linux ld.so'
+knetbsd*-gnu)
+ need_version=no
netbsd*)
version_type=sunos
need_lib_prefix=no
need_version=no
- library_names_spec='${libname}${release}.so$versuffix ${libname}.so$versuffix'
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
dynamic_linker='NetBSD (a.out) ld.so'
else
- library_names_spec='${libname}${release}.so$versuffix ${libname}${release}.so$major ${libname}${release}.so ${libname}.so'
dynamic_linker='NetBSD ld.elf_so'
fi
@@ -6927,55 +17692,66 @@
newsos6)
version_type=linux
+nto-qnx*)
+ need_version=no
openbsd*)
version_type=sunos
need_lib_prefix=no
- need_version=no
+ need_version=yes
+ finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
- case "$host_os" in
- openbsd2.[89] | openbsd2.[89].*)
- shlibpath_overrides_runpath=yes
- esac
+ case $host_os in
+ openbsd2.[89] | openbsd2.[89].*)
+ esac
else
fi
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
- shlibpath_var=LD_LIBRARY_PATH
os2*)
libname_spec='$name'
need_lib_prefix=no
- library_names_spec='$libname.dll $libname.a'
+ library_names_spec='$libname${shared_ext} $libname.a'
dynamic_linker='OS/2 ld.exe'
version_type=osf
need_version=no
sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
sco3.2v5*)
version_type=osf
@@ -6983,8 +17759,8 @@
version_type=linux
need_lib_prefix=no
need_version=no
@@ -6994,7 +17770,7 @@
sunos4*)
version_type=sunos
finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
@@ -7006,8 +17782,8 @@
version_type=linux
case $host_vendor in
sni)
@@ -7028,31 +17804,22 @@
esac
-uts4*)
- version_type=linux
-dgux*)
- need_lib_prefix=no
- need_version=no
sysv4*MP*)
if test -d /usr/nec ;then
version_type=linux
- library_names_spec='$libname.so.$versuffix $libname.so.$major $libname.so'
- soname_spec='$libname.so.$major'
+ library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
+ soname_spec='$libname${shared_ext}.$major'
fi
+uts4*)
dynamic_linker=no
@@ -7061,44 +17828,35 @@
echo "${ECHO_T}$dynamic_linker" >&6
test "$dynamic_linker" = no && can_build_shared=no
-# Report the final consequences.
-echo "$as_me:$LINENO: checking if libtool supports shared libraries" >&5
-echo $ECHO_N "checking if libtool supports shared libraries... $ECHO_C" >&6
-echo "$as_me:$LINENO: result: $can_build_shared" >&5
-echo "${ECHO_T}$can_build_shared" >&6
+echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
+echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
+hardcode_action_GCJ=
+if test -n "$hardcode_libdir_flag_spec_GCJ" || \
+ test -n "$runpath_var GCJ" || \
+ test "X$hardcode_automatic_GCJ"="Xyes" ; then
-echo "$as_me:$LINENO: checking whether to build shared libraries" >&5
-echo $ECHO_N "checking whether to build shared libraries... $ECHO_C" >&6
-test "$can_build_shared" = "no" && enable_shared=no
-# On AIX, shared libraries and static libraries use the same namespace, and
-# are all built from PIC.
-case "$host_os" in
-aix3*)
- test "$enable_shared" = yes && enable_static=no
- if test -n "$RANLIB"; then
- archive_cmds="$archive_cmds~\$RANLIB \$lib"
- postinstall_cmds='$RANLIB $lib'
+ # We can hardcode non-existant directories.
+ if test "$hardcode_direct_GCJ" != no &&
+ # If the only mechanism to avoid hardcoding is shlibpath_var, we
+ # have to relink, otherwise we might link with an installed library
+ # when we should be linking with a yet-to-be-installed one
+ ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, GCJ)" != no &&
+ test "$hardcode_minus_L_GCJ" != no; then
+ # Linking always hardcodes the temporary library directory.
+ hardcode_action_GCJ=relink
+ else
+ # We can link without hardcoding, and we can hardcode nonexisting dirs.
+ hardcode_action_GCJ=immediate
fi
+else
+ # We cannot hardcode anything, or else we can only hardcode existing
+ # directories.
+ hardcode_action_GCJ=unsupported
+fi
+echo "$as_me:$LINENO: result: $hardcode_action_GCJ" >&5
+echo "${ECHO_T}$hardcode_action_GCJ" >&6
-aix4*)
- if test "$host_cpu" != ia64 && test "$aix_use_runtimelinking" = no ; then
- fi
-esac
-echo "$as_me:$LINENO: result: $enable_shared" >&5
-echo "${ECHO_T}$enable_shared" >&6
-echo "$as_me:$LINENO: checking whether to build static libraries" >&5
-echo $ECHO_N "checking whether to build static libraries... $ECHO_C" >&6
-# Make sure either enable_shared or enable_static is yes.
-test "$enable_shared" = yes || enable_static=yes
-echo "$as_me:$LINENO: result: $enable_static" >&5
-echo "${ECHO_T}$enable_static" >&6
-if test "$hardcode_action" = relink; then
+if test "$hardcode_action_GCJ" = relink; then
# Fast installation is not supported
enable_fast_install=no
elif test "$shlibpath_overrides_runpath" = yes ||
@@ -7107,10 +17865,34 @@
enable_fast_install=needless
fi
-variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
-if test "$GCC" = yes; then
- variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
+striplib=
+old_striplib=
+echo "$as_me:$LINENO: checking whether stripping libraries is possible" >&5
+echo $ECHO_N "checking whether stripping libraries is possible... $ECHO_C" >&6
+if test -n "$STRIP" && $STRIP -V 2>&1 | grep "GNU strip" >/dev/null; then
+ test -z "$old_striplib" && old_striplib="$STRIP --strip-debug"
+ test -z "$striplib" && striplib="$STRIP --strip-unneeded"
+ echo "$as_me:$LINENO: result: yes" >&5
+echo "${ECHO_T}yes" >&6
+else
+# FIXME - insert some real tests, host_os isn't really good enough
+ case $host_os in
+ darwin*)
+ if test -n "$STRIP" ; then
+ striplib="$STRIP -x"
+ else
+ echo "$as_me:$LINENO: result: no" >&5
+echo "${ECHO_T}no" >&6
fi
+ esac
+fi
if test "x$enable_dlopen" != xyes; then
enable_dlopen=unknown
@@ -7127,11 +17909,94 @@
lt_cv_dlopen_self=yes
- cygwin* | mingw* | pw32*)
+ mingw* | pw32*)
lt_cv_dlopen="LoadLibrary"
lt_cv_dlopen_libs=
+ cygwin*)
+ lt_cv_dlopen="dlopen"
+ lt_cv_dlopen_libs=
+ darwin*)
+ # if libdl is installed we need to link against it
+ echo "$as_me:$LINENO: checking for dlopen in -ldl" >&5
+echo $ECHO_N "checking for dlopen in -ldl... $ECHO_C" >&6
+if test "${ac_cv_lib_dl_dlopen+set}" = set; then
+else
+ ac_check_lib_save_LIBS=$LIBS
+LIBS="-ldl $LIBS"
+cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h. */
+_ACEOF
+/* Override any gcc2 internal prototype to avoid an error. */
+#ifdef __cplusplus
+extern "C"
+#endif
+/* We use char because int might match the return type of a gcc2
+ builtin and then its argument prototype would still apply. */
+char dlopen ();
+int
+main ()
+dlopen ();
+ return 0;
+_ACEOF
+ ac_status=$?
+ echo "$as_me:$LINENO: \$? = $ac_status" >&5
+ ac_status=$?
+ ac_status=$?
+ ac_cv_lib_dl_dlopen=yes
+else
+ac_cv_lib_dl_dlopen=no
+fi
+LIBS=$ac_check_lib_save_LIBS
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_dl_dlopen" >&5
+echo "${ECHO_T}$ac_cv_lib_dl_dlopen" >&6
+if test $ac_cv_lib_dl_dlopen = yes; then
+ lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-ldl"
+else
+ lt_cv_dlopen="dyld"
+ lt_cv_dlopen_self=yes
+fi
echo "$as_me:$LINENO: checking for shl_load" >&5
echo $ECHO_N "checking for shl_load... $ECHO_C" >&6
@@ -7615,7 +18480,7 @@
case $lt_cv_dlopen in
dlopen)
save_CPPFLAGS="$CPPFLAGS"
- test "x$ac_cv_header_dlfcn_h" = xyes && CPPFLAGS="$CPPFLAGS -DHAVE_DLFCN_H"
+ test "x$ac_cv_header_dlfcn_h" = xyes && CPPFLAGS="$CPPFLAGS -DHAVE_DLFCN_H"
save_LDFLAGS="$LDFLAGS"
eval LDFLAGS=\"\$LDFLAGS $export_dynamic_flag_spec\"
@@ -7631,10 +18496,10 @@
if test "$cross_compiling" = yes; then :
lt_cv_dlopen_self=cross
else
- lt_dlunknown=0; lt_dlno_uscore=1; lt_dlneed_uscore=2
+ lt_dlunknown=0; lt_dlno_uscore=1; lt_dlneed_uscore=2
lt_status=$lt_dlunknown
cat > conftest.$ac_ext <<EOF
-#line 7637 "configure"
+#line 18502 "configure"
#include "confdefs.h"
#if HAVE_DLFCN_H
@@ -7729,10 +18594,10 @@
lt_cv_dlopen_self_static=cross
else
-#line 7735 "configure"
+#line 18600 "configure"
#if HAVE_DLFCN_H
@@ -7836,109 +18701,522 @@
fi
-if test "$enable_shared" = yes && test "$GCC" = yes; then
- case $archive_cmds in
- # FIXME: we may have to deal with multi-command sequences.
- '$CC '*)
- # Test whether the compiler implicitly links with -lc since on some
- # systems, -lgcc has to come before -lc. If gcc already passes -lc
- # to ld, don't add -lc before -lgcc.
- echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
-echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
- if test "${lt_cv_archive_cmds_need_lc+set}" = set; then
- echo $ECHO_N "(cached) $ECHO_C" >&6
-else
- $rm conftest*
- echo 'static int dummy;' > conftest.$ac_ext
+# The else clause should only fire when bootstrapping the
+# libtool distribution, otherwise you forgot to ship ltmain.sh
+# with your package, and you will get complaints that there are
+# no rules to generate ltmain.sh.
+if test -f "$ltmain"; then
+ # See if we are running on zsh, and set the options which allow our commands through
+ # without removal of \ escapes.
+ if test -n "${ZSH_VERSION+set}" ; then
+ setopt NO_GLOB_SUBST
+ fi
+ # Now quote all the things that may contain metacharacters while being
+ # careful not to overquote the AC_SUBSTed values. We take copies of the
+ # variables and quote the copies for generation of the libtool script.
+ for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC NM \
+ SED SHELL STRIP \
+ libname_spec library_names_spec soname_spec extract_expsyms_cmds \
+ old_striplib striplib file_magic_cmd finish_cmds finish_eval \
+ deplibs_check_method reload_flag reload_cmds need_locks \
+ lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
+ lt_cv_sys_global_symbol_to_c_name_address \
+ sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
+ old_postinstall_cmds old_postuninstall_cmds \
+ compiler_GCJ \
+ CC_GCJ \
+ LD_GCJ \
+ lt_prog_compiler_wl_GCJ \
+ lt_prog_compiler_pic_GCJ \
+ lt_prog_compiler_static_GCJ \
+ lt_prog_compiler_no_builtin_flag_GCJ \
+ export_dynamic_flag_spec_GCJ \
+ thread_safe_flag_spec_GCJ \
+ whole_archive_flag_spec_GCJ \
+ enable_shared_with_static_runtimes_GCJ \
+ old_archive_cmds_GCJ \
+ old_archive_from_new_cmds_GCJ \
+ predep_objects_GCJ \
+ postdep_objects_GCJ \
+ predeps_GCJ \
+ postdeps_GCJ \
+ compiler_lib_search_path_GCJ \
+ archive_cmds_GCJ \
+ archive_expsym_cmds_GCJ \
+ postinstall_cmds_GCJ \
+ postuninstall_cmds_GCJ \
+ old_archive_from_expsyms_cmds_GCJ \
+ allow_undefined_flag_GCJ \
+ no_undefined_flag_GCJ \
+ export_symbols_cmds_GCJ \
+ hardcode_libdir_flag_spec_GCJ \
+ hardcode_libdir_flag_spec_ld_GCJ \
+ hardcode_libdir_separator_GCJ \
+ hardcode_automatic_GCJ \
+ module_cmds_GCJ \
+ module_expsym_cmds_GCJ \
+ lt_cv_prog_compiler_c_o_GCJ \
+ exclude_expsyms_GCJ \
+ include_expsyms_GCJ; do
- if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
- (eval $ac_compile) 2>&5
- ac_status=$?
- echo "$as_me:$LINENO: \$? = $ac_status" >&5
- (exit $ac_status); }; then
- soname=conftest
- lib=conftest
- libobjs=conftest.$ac_objext
- deplibs=
- wl=$lt_cv_prog_cc_wl
- compiler_flags=-v
- linker_flags=-v
- verstring=
- output_objdir=.
- libname=conftest
- save_allow_undefined_flag=$allow_undefined_flag
- allow_undefined_flag=
- if { (eval echo "$as_me:$LINENO: \"$archive_cmds 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
- (eval $archive_cmds 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
- ac_status=$?
- then
- lt_cv_archive_cmds_need_lc=no
- else
- lt_cv_archive_cmds_need_lc=yes
- fi
- allow_undefined_flag=$save_allow_undefined_flag
- else
- cat conftest.err 1>&5
- fi
-fi
+ case $var in
+ old_archive_cmds_GCJ | \
+ old_archive_from_new_cmds_GCJ | \
+ archive_cmds_GCJ | \
+ archive_expsym_cmds_GCJ | \
+ module_cmds_GCJ | \
+ module_expsym_cmds_GCJ | \
+ old_archive_from_expsyms_cmds_GCJ | \
+ export_symbols_cmds_GCJ | \
+ extract_expsyms_cmds | reload_cmds | finish_cmds | \
+ postinstall_cmds | postuninstall_cmds | \
+ old_postinstall_cmds | old_postuninstall_cmds | \
+ sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
+ # Double-quote double-evaled strings.
+ eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
+ eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
+ esac
+ done
- echo "$as_me:$LINENO: result: $lt_cv_archive_cmds_need_lc" >&5
-echo "${ECHO_T}$lt_cv_archive_cmds_need_lc" >&6
+ case $lt_echo in
+ *'\$0 --fallback-echo"')
+ lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
esac
-fi
-need_lc=${lt_cv_archive_cmds_need_lc-yes}
-# The second clause should only fire when bootstrapping the
-# libtool distribution, otherwise you forgot to ship ltmain.sh
-# with your package, and you will get complaints that there are
-# no rules to generate ltmain.sh.
-if test -f "$ltmain"; then
+cfgfile="$ofile"
+ cat <<__EOF__ >> "$cfgfile"
+# ### BEGIN LIBTOOL TAG CONFIG: $tagname
+# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
+# Shell to use when invoking shell scripts.
+SHELL=$lt_SHELL
+# Whether or not to build shared libraries.
+build_libtool_libs=$enable_shared
+# Whether or not to build static libraries.
+build_old_libs=$enable_static
+# Whether or not to add -lc for building shared libraries.
+build_libtool_need_lc=$archive_cmds_need_lc_GCJ
+# Whether or not to disallow shared libs when runtime libs are static
+allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_GCJ
+# Whether or not to optimize for fast installation.
+fast_install=$enable_fast_install
+# The host system.
+host_alias=$host_alias
+host=$host
+# An echo program that does not interpret backslashes.
+echo=$lt_echo
+# The archiver.
+AR=$lt_AR
+AR_FLAGS=$lt_AR_FLAGS
+# A C compiler.
+LTCC=$lt_LTCC
+# A language-specific compiler.
+CC=$lt_compiler_GCJ
+# Is the compiler the GNU C compiler?
+with_gcc=$GCC_GCJ
+# An ERE matcher.
+EGREP=$lt_EGREP
+# The linker used to build libraries.
+LD=$lt_LD_GCJ
+# Whether we need hard or soft links.
+LN_S=$lt_LN_S
+# A BSD-compatible nm program.
+NM=$lt_NM
+# A symbol stripping program
+STRIP=$lt_STRIP
+# Used to examine libraries when file_magic_cmd begins "file"
+MAGIC_CMD=$MAGIC_CMD
+# Used on cygwin: DLL creation program.
+DLLTOOL="$DLLTOOL"
+# Used on cygwin: object dumper.
+OBJDUMP="$OBJDUMP"
+# Used on cygwin: assembler.
+AS="$AS"
+# The name of the directory that contains temporary libtool files.
+objdir=$objdir
+# How to create reloadable object files.
+reload_flag=$lt_reload_flag
+reload_cmds=$lt_reload_cmds
+# How to pass a linker flag through the compiler.
+wl=$lt_lt_prog_compiler_wl_GCJ
+# Object file suffix (normally "o").
+objext="$ac_objext"
+# Old archive suffix (normally "a").
+libext="$libext"
+# Shared library suffix (normally ".so").
+shrext_cmds='$shrext_cmds'
+# Executable file suffix (normally "").
+exeext="$exeext"
+# Additional compiler flags for building library objects.
+pic_flag=$lt_lt_prog_compiler_pic_GCJ
+pic_mode=$pic_mode
+# What is the maximum length of a command?
+max_cmd_len=$lt_cv_sys_max_cmd_len
+# Does compiler simultaneously support -c and -o options?
+compiler_c_o=$lt_lt_cv_prog_compiler_c_o_GCJ
+# Must we lock files when doing compilation ?
+need_locks=$lt_need_locks
+# Do we need the lib prefix for modules?
+need_lib_prefix=$need_lib_prefix
+# Do we need a version for libraries?
+need_version=$need_version
+# Whether dlopen is supported.
+dlopen_support=$enable_dlopen
+# Whether dlopen of programs is supported.
+dlopen_self=$enable_dlopen_self
+# Whether dlopen of statically linked programs is supported.
+dlopen_self_static=$enable_dlopen_self_static
+# Compiler flag to prevent dynamic linking.
+link_static_flag=$lt_lt_prog_compiler_static_GCJ
+# Compiler flag to turn off builtin functions.
+no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_GCJ
+# Compiler flag to allow reflexive dlopens.
+export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_GCJ
+# Compiler flag to generate shared objects directly from archives.
+whole_archive_flag_spec=$lt_whole_archive_flag_spec_GCJ
+# Compiler flag to generate thread-safe objects.
+thread_safe_flag_spec=$lt_thread_safe_flag_spec_GCJ
+# Library versioning type.
+version_type=$version_type
+# Format of library name prefix.
+libname_spec=$lt_libname_spec
+# List of archive names. First name is the real one, the rest are links.
+# The last name is the one that the linker finds with -lNAME.
+library_names_spec=$lt_library_names_spec
+# The coded name of the library, if different from the real name.
+soname_spec=$lt_soname_spec
+# Commands used to build and install an old-style archive.
+RANLIB=$lt_RANLIB
+old_archive_cmds=$lt_old_archive_cmds_GCJ
+old_postinstall_cmds=$lt_old_postinstall_cmds
+old_postuninstall_cmds=$lt_old_postuninstall_cmds
+# Create an old-style archive from a shared archive.
+old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_GCJ
+# Create a temporary old-style archive to link instead of a shared archive.
+old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_GCJ
+# Commands used to build and install a shared archive.
+archive_cmds=$lt_archive_cmds_GCJ
+archive_expsym_cmds=$lt_archive_expsym_cmds_GCJ
+postinstall_cmds=$lt_postinstall_cmds
+postuninstall_cmds=$lt_postuninstall_cmds
+# Commands used to build a loadable module (assumed same as above if empty)
+module_cmds=$lt_module_cmds_GCJ
+module_expsym_cmds=$lt_module_expsym_cmds_GCJ
+# Commands to strip libraries.
+old_striplib=$lt_old_striplib
+striplib=$lt_striplib
+# Dependencies to place before the objects being linked to create a
+# shared library.
+predep_objects=$lt_predep_objects_GCJ
+# Dependencies to place after the objects being linked to create a
+# shared library.
+postdep_objects=$lt_postdep_objects_GCJ
+# shared library.
+predeps=$lt_predeps_GCJ
+# shared library.
+postdeps=$lt_postdeps_GCJ
+# The library search path used internally by the compiler when linking
+# a shared library.
+compiler_lib_search_path=$lt_compiler_lib_search_path_GCJ
+# Method to check whether dependent libraries are shared objects.
+deplibs_check_method=$lt_deplibs_check_method
+# Command to use when deplibs_check_method == file_magic.
+file_magic_cmd=$lt_file_magic_cmd
+# Flag that allows shared libraries with undefined symbols to be built.
+allow_undefined_flag=$lt_allow_undefined_flag_GCJ
+# Flag that forces no undefined symbols.
+no_undefined_flag=$lt_no_undefined_flag_GCJ
+# Commands used to finish a libtool library installation in a directory.
+finish_cmds=$lt_finish_cmds
+# Same as above, but a single script fragment to be evaled but not shown.
+finish_eval=$lt_finish_eval
+# Take the output of nm and produce a listing of raw symbols and C names.
+global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
+# Transform the output of nm in a proper C declaration
+global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
+# Transform the output of nm in a C name address pair
+global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
+# This is the shared library runtime path variable.
+runpath_var=$runpath_var
+# This is the shared library path variable.
+shlibpath_var=$shlibpath_var
+# Is shlibpath searched before the hard-coded library search path?
+shlibpath_overrides_runpath=$shlibpath_overrides_runpath
+# How to hardcode a shared library path into an executable.
+hardcode_action=$hardcode_action_GCJ
+# Whether we should hardcode library paths into libraries.
+hardcode_into_libs=$hardcode_into_libs
+# Flag to hardcode \$libdir into a binary during linking.
+# This must work even if \$libdir does not exist.
+hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_GCJ
+# If ld is used when linking, flag to hardcode \$libdir into
+# a binary during linking. This must work even if \$libdir does
+# not exist.
+hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_GCJ
+# Whether we need a single -rpath flag with a separated argument.
+hardcode_libdir_separator=$lt_hardcode_libdir_separator_GCJ
+# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
+# resulting binary.
+hardcode_direct=$hardcode_direct_GCJ
+# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
+hardcode_minus_L=$hardcode_minus_L_GCJ
+# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
+# the resulting binary.
+hardcode_shlibpath_var=$hardcode_shlibpath_var_GCJ
+# Set to yes if building a shared library automatically hardcodes DIR into the library
+# and all subsequent libraries and executables linked against it.
+hardcode_automatic=$hardcode_automatic_GCJ
+# Variables whose values should be saved in libtool wrapper scripts and
+# restored at relink time.
+variables_saved_for_relink="$variables_saved_for_relink"
+# Whether libtool must link a program against all its dependency libraries.
+link_all_deplibs=$link_all_deplibs_GCJ
+# Compile-time system search path for libraries
+sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
+# Run-time system search path for libraries
+sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
+# Fix the shell variable \$srcfile for the compiler.
+fix_srcfile_path="$fix_srcfile_path_GCJ"
+# Set to yes if exported symbols are required.
+always_export_symbols=$always_export_symbols_GCJ
+# The commands to list exported symbols.
+export_symbols_cmds=$lt_export_symbols_cmds_GCJ
+# The commands to extract the exported symbol list from a shared archive.
+extract_expsyms_cmds=$lt_extract_expsyms_cmds
+# Symbols that should not be listed in the preloaded symbols.
+exclude_expsyms=$lt_exclude_expsyms_GCJ
+# Symbols that must always be exported.
+include_expsyms=$lt_include_expsyms_GCJ
+# ### END LIBTOOL TAG CONFIG: $tagname
+__EOF__
else
# If there is no Makefile yet, we rely on a make rule to execute
# `config.status --recheck' to rerun these tests and create the
# libtool script then.
- test -f Makefile && make "$ltmain"
+ ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
+ if test -f "$ltmain_in"; then
+ test -f Makefile && make "$ltmain"
+ fi
fi
- trap "$rm \"${ofile}T\"; exit 1" 1 2 15
- $rm -f "${ofile}T"
- echo creating $ofile
+ac_ext=cc
+ac_cpp='$CXXCPP $CPPFLAGS'
+ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
+CC="$lt_save_CC"
+ else
+ tagname=""
+ fi
+ RC)
+# Source file extension for RC test sources.
+ac_ext=rc
+# Object file extension for compiled RC test sources.
+objext=o
+objext_RC=$objext
+# Code to be used in simple compile tests
+lt_simple_compile_test_code='sample MENU { MENUITEM "&Soup", 100, CHECKED }\n'
+# Code to be used in simple link tests
+lt_simple_link_test_code="$lt_simple_compile_test_code"
+# ltmain only uses $CC for tagged configurations so make sure $CC is set.
+# If no C compiler was specified, use CC.
+LTCC=${LTCC-"$CC"}
+# Allow CC to be a program name with arguments.
+compiler=$CC
+lt_save_CC="$CC"
+CC=${RC-"windres"}
+compiler=$CC
+compiler_RC=$CC
+lt_cv_prog_compiler_c_o_RC=yes
+ fi
- for var in echo old_CC old_CFLAGS SED \
- AR AR_FLAGS CC LD LN_S NM SHELL \
- reload_flag reload_cmds wl \
- pic_flag link_static_flag no_builtin_flag export_dynamic_flag_spec \
- thread_safe_flag_spec whole_archive_flag_spec libname_spec \
- library_names_spec soname_spec \
- RANLIB old_archive_cmds old_archive_from_new_cmds old_postinstall_cmds \
- old_postuninstall_cmds archive_cmds archive_expsym_cmds postinstall_cmds \
- postuninstall_cmds extract_expsyms_cmds old_archive_from_expsyms_cmds \
- old_striplib striplib file_magic_cmd export_symbols_cmds \
- deplibs_check_method allow_undefined_flag no_undefined_flag \
- finish_cmds finish_eval global_symbol_pipe global_symbol_to_cdecl \
- global_symbol_to_c_name_address \
- hardcode_libdir_flag_spec hardcode_libdir_separator \
+ SED SHELL STRIP \
- compiler_c_o compiler_o_lo need_locks exclude_expsyms include_expsyms; do
+ compiler_RC \
+ CC_RC \
+ LD_RC \
+ lt_prog_compiler_wl_RC \
+ lt_prog_compiler_pic_RC \
+ lt_prog_compiler_static_RC \
+ lt_prog_compiler_no_builtin_flag_RC \
+ export_dynamic_flag_spec_RC \
+ thread_safe_flag_spec_RC \
+ whole_archive_flag_spec_RC \
+ enable_shared_with_static_runtimes_RC \
+ old_archive_cmds_RC \
+ old_archive_from_new_cmds_RC \
+ predep_objects_RC \
+ postdep_objects_RC \
+ predeps_RC \
+ postdeps_RC \
+ compiler_lib_search_path_RC \
+ archive_cmds_RC \
+ archive_expsym_cmds_RC \
+ postinstall_cmds_RC \
+ postuninstall_cmds_RC \
+ old_archive_from_expsyms_cmds_RC \
+ allow_undefined_flag_RC \
+ no_undefined_flag_RC \
+ export_symbols_cmds_RC \
+ hardcode_libdir_flag_spec_RC \
+ hardcode_libdir_flag_spec_ld_RC \
+ hardcode_libdir_separator_RC \
+ hardcode_automatic_RC \
+ module_cmds_RC \
+ module_expsym_cmds_RC \
+ lt_cv_prog_compiler_c_o_RC \
+ exclude_expsyms_RC \
+ include_expsyms_RC; do
case $var in
- reload_cmds | old_archive_cmds | old_archive_from_new_cmds | \
+ old_archive_cmds_RC | \
+ old_archive_from_new_cmds_RC | \
+ archive_cmds_RC | \
+ archive_expsym_cmds_RC | \
+ module_cmds_RC | \
+ module_expsym_cmds_RC | \
+ old_archive_from_expsyms_cmds_RC | \
+ export_symbols_cmds_RC | \
- export_symbols_cmds | archive_cmds | archive_expsym_cmds | \
- extract_expsyms_cmds | old_archive_from_expsyms_cmds | \
- postinstall_cmds | postuninstall_cmds | \
- finish_cmds | sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
@@ -7948,47 +19226,17 @@
esac
done
- cat <<__EOF__ > "${ofile}T"
-#! $SHELL
+ case $lt_echo in
+ esac
-# `$echo "$ofile" | sed 's%^.*/%%'` - Provide generalized library-building support services.
-# Generated automatically by $PROGRAM (GNU $PACKAGE $VERSION$TIMESTAMP)
-# NOTE: Changes made to this file will be lost: look at ltmain.sh.
-# Copyright (C) 1996-2000 Free Software Foundation, Inc.
-# Originally by Gordon Matzigkeit <gord at gnu.ai.mit.edu>, 1996
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2 of the License, or
-# (at your option) any later version.
-# This program is distributed in the hope that it will be useful, but
-# WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-# General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-# As a special exception to the GNU General Public License, if you
-# distribute this file as part of a program that contains a
-# configuration script generated by Autoconf, you may include it under
-# the same distribution terms that you use for the rest of that program.
+cfgfile="$ofile"
-# A sed that does not truncate output.
-SED=$lt_SED
-# Sed that helps us avoid accidentally triggering echo(1) options like -n.
-Xsed="${SED} -e s/^X//"
-# The HP-UX ksh and POSIX shell print the target directory to stdout
-# if CDPATH is set.
-if test "X\${CDPATH+set}" = Xset; then CDPATH=:; export CDPATH; fi
-# ### BEGIN LIBTOOL CONFIG
@@ -8001,8 +19249,11 @@
-build_libtool_need_lc=$need_lc
+build_libtool_need_lc=$archive_cmds_need_lc_RC
+allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_RC
@@ -8017,14 +19268,20 @@
AR=$lt_AR
-# The default C compiler.
-CC=$lt_CC
+# A C compiler.
+LTCC=$lt_LTCC
+CC=$lt_compiler_RC
-with_gcc=$GCC
+with_gcc=$GCC_RC
+# An ERE matcher.
+EGREP=$lt_EGREP
-LD=$lt_LD
+LD=$lt_LD_RC
LN_S=$lt_LN_S
@@ -8033,7 +19290,7 @@
NM=$lt_NM
-STRIP=$STRIP
+STRIP=$lt_STRIP
@@ -8055,7 +19312,7 @@
-wl=$lt_wl
+wl=$lt_lt_prog_compiler_wl_RC
objext="$ac_objext"
@@ -8063,19 +19320,22 @@
libext="$libext"
exeext="$exeext"
-pic_flag=$lt_pic_flag
+pic_flag=$lt_lt_prog_compiler_pic_RC
pic_mode=$pic_mode
-compiler_c_o=$lt_compiler_c_o
+compiler_c_o=$lt_lt_cv_prog_compiler_c_o_RC
-# Can we write directly to a .lo ?
-compiler_o_lo=$lt_compiler_o_lo
@@ -8095,19 +19355,19 @@
-link_static_flag=$lt_link_static_flag
+link_static_flag=$lt_lt_prog_compiler_static_RC
-no_builtin_flag=$lt_no_builtin_flag
+no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_RC
-export_dynamic_flag_spec=$lt_export_dynamic_flag_spec
+export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_RC
-whole_archive_flag_spec=$lt_whole_archive_flag_spec
+whole_archive_flag_spec=$lt_whole_archive_flag_spec_RC
-thread_safe_flag_spec=$lt_thread_safe_flag_spec
+thread_safe_flag_spec=$lt_thread_safe_flag_spec_RC
@@ -8124,26 +19384,50 @@
RANLIB=$lt_RANLIB
-old_archive_cmds=$lt_old_archive_cmds
+old_archive_cmds=$lt_old_archive_cmds_RC
-old_archive_from_new_cmds=$lt_old_archive_from_new_cmds
+old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_RC
-old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds
+old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_RC
-archive_cmds=$lt_archive_cmds
-archive_expsym_cmds=$lt_archive_expsym_cmds
+archive_cmds=$lt_archive_cmds_RC
+archive_expsym_cmds=$lt_archive_expsym_cmds_RC
+module_cmds=$lt_module_cmds_RC
+module_expsym_cmds=$lt_module_expsym_cmds_RC
+# shared library.
+predep_objects=$lt_predep_objects_RC
+# shared library.
+postdep_objects=$lt_postdep_objects_RC
+# shared library.
+predeps=$lt_predeps_RC
+# shared library.
+postdeps=$lt_postdeps_RC
+compiler_lib_search_path=$lt_compiler_lib_search_path_RC
@@ -8151,10 +19435,10 @@
-allow_undefined_flag=$lt_allow_undefined_flag
+allow_undefined_flag=$lt_allow_undefined_flag_RC
-no_undefined_flag=$lt_no_undefined_flag
+no_undefined_flag=$lt_no_undefined_flag_RC
@@ -8163,13 +19447,13 @@
-global_symbol_pipe=$lt_global_symbol_pipe
-global_symbol_to_cdecl=$lt_global_symbol_to_cdecl
-global_symbol_to_c_name_address=$lt_global_symbol_to_c_name_address
@@ -8181,36 +19465,45 @@
-hardcode_action=$hardcode_action
+hardcode_action=$hardcode_action_RC
-hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec
+hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_RC
+# not exist.
+hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_RC
-hardcode_libdir_separator=$lt_hardcode_libdir_separator
+hardcode_libdir_separator=$lt_hardcode_libdir_separator_RC
-# Set to yes if using DIR/libNAME.so during linking hardcodes DIR into the
# resulting binary.
-hardcode_direct=$hardcode_direct
+hardcode_direct=$hardcode_direct_RC
# resulting binary.
-hardcode_minus_L=$hardcode_minus_L
+hardcode_minus_L=$hardcode_minus_L_RC
-hardcode_shlibpath_var=$hardcode_shlibpath_var
+hardcode_shlibpath_var=$hardcode_shlibpath_var_RC
+hardcode_automatic=$hardcode_automatic_RC
-link_all_deplibs=$link_all_deplibs
+link_all_deplibs=$link_all_deplibs_RC
@@ -8219,237 +19512,78 @@
-fix_srcfile_path="$fix_srcfile_path"
+fix_srcfile_path="$fix_srcfile_path_RC"
-always_export_symbols=$always_export_symbols
+always_export_symbols=$always_export_symbols_RC
-export_symbols_cmds=$lt_export_symbols_cmds
+export_symbols_cmds=$lt_export_symbols_cmds_RC
-exclude_expsyms=$lt_exclude_expsyms
+exclude_expsyms=$lt_exclude_expsyms_RC
-include_expsyms=$lt_include_expsyms
+include_expsyms=$lt_include_expsyms_RC
-# ### END LIBTOOL CONFIG
__EOF__
- case $host_os in
- aix3*)
- cat <<\EOF >> "${ofile}T"
-# AIX sometimes has problems with the GCC collect2 program. For some
-# reason, if we set the COLLECT_NAMES environment variable, the problems
-# vanish in a puff of smoke.
-if test "X${COLLECT_NAMES+set}" != Xset; then
- COLLECT_NAMES=
- export COLLECT_NAMES
+else
+ # If there is no Makefile yet, we rely on a make rule to execute
+ # `config.status --recheck' to rerun these tests and create the
+ # libtool script then.
+ fi
fi
-EOF
- esac
- case $host_os in
- cygwin* | mingw* | pw32* | os2*)
- cat <<'EOF' >> "${ofile}T"
- # This is a source program that is used to create dlls on Windows
- # Don't remove nor modify the starting and closing comments
-# /* ltdll.c starts here */
-# #define WIN32_LEAN_AND_MEAN
-# #include <windows.h>
-# #undef WIN32_LEAN_AND_MEAN
-# #include <stdio.h>
-# #ifndef __CYGWIN__
-# # ifdef __CYGWIN32__
-# # define __CYGWIN__ __CYGWIN32__
-# # endif
-# #endif
-# #ifdef __cplusplus
-# extern "C" {
-# #endif
-# BOOL APIENTRY DllMain (HINSTANCE hInst, DWORD reason, LPVOID reserved);
-# #endif
-# #ifdef __CYGWIN__
-# #include <cygwin/cygwin_dll.h>
-# DECLARE_CYGWIN_DLL( DllMain );
-# #endif
-# HINSTANCE __hDllInstance_base;
-# BOOL APIENTRY
-# DllMain (HINSTANCE hInst, DWORD reason, LPVOID reserved)
-# __hDllInstance_base = hInst;
-# return TRUE;
-# /* ltdll.c ends here */
- # This is a source program that is used to create import libraries
- # on Windows for dlls which lack them. Don't remove nor modify the
- # starting and closing comments
-# /* impgen.c starts here */
-# /* Copyright (C) 1999-2000 Free Software Foundation, Inc.
-# This file is part of GNU libtool.
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# GNU General Public License for more details.
-# #include <stdio.h> /* for printf() */
-# #include <unistd.h> /* for open(), lseek(), read() */
-# #include <fcntl.h> /* for O_RDONLY, O_BINARY */
-# #include <string.h> /* for strdup() */
-# /* O_BINARY isn't required (or even defined sometimes) under Unix */
-# #ifndef O_BINARY
-# #define O_BINARY 0
-# #endif
-# static unsigned int
-# pe_get16 (fd, offset)
-# int fd;
-# int offset;
-# unsigned char b[2];
-# lseek (fd, offset, SEEK_SET);
-# read (fd, b, 2);
-# return b[0] + (b[1]<<8);
-# pe_get32 (fd, offset)
-# int fd;
-# int offset;
-# unsigned char b[4];
-# read (fd, b, 4);
-# return b[0] + (b[1]<<8) + (b[2]<<16) + (b[3]<<24);
-# pe_as32 (ptr)
-# void *ptr;
-# unsigned char *b = ptr;
-# int
-# main (argc, argv)
-# int argc;
-# char *argv[];
-# int dll;
-# unsigned long pe_header_offset, opthdr_ofs, num_entries, i;
-# unsigned long export_rva, export_size, nsections, secptr, expptr;
-# unsigned long name_rvas, nexp;
-# unsigned char *expdata, *erva;
-# char *filename, *dll_name;
-# filename = argv[1];
-# dll = open(filename, O_RDONLY|O_BINARY);
-# if (dll < 1)
-# return 1;
-# dll_name = filename;
-# for (i=0; filename[i]; i++)
-# if (filename[i] == '/' || filename[i] == '\\' || filename[i] == ':')
-# dll_name = filename + i +1;
-# pe_header_offset = pe_get32 (dll, 0x3c);
-# opthdr_ofs = pe_header_offset + 4 + 20;
-# num_entries = pe_get32 (dll, opthdr_ofs + 92);
-# if (num_entries < 1) /* no exports */
-# return 1;
-# export_rva = pe_get32 (dll, opthdr_ofs + 96);
-# export_size = pe_get32 (dll, opthdr_ofs + 100);
-# nsections = pe_get16 (dll, pe_header_offset + 4 +2);
-# secptr = (pe_header_offset + 4 + 20 +
-# pe_get16 (dll, pe_header_offset + 4 + 16));
-# expptr = 0;
-# for (i = 0; i < nsections; i++)
-# char sname[8];
-# unsigned long secptr1 = secptr + 40 * i;
-# unsigned long vaddr = pe_get32 (dll, secptr1 + 12);
-# unsigned long vsize = pe_get32 (dll, secptr1 + 16);
-# unsigned long fptr = pe_get32 (dll, secptr1 + 20);
-# lseek(dll, secptr1, SEEK_SET);
-# read(dll, sname, 8);
-# if (vaddr <= export_rva && vaddr+vsize > export_rva)
-# expptr = fptr + (export_rva - vaddr);
-# if (export_rva + export_size > vaddr + vsize)
-# export_size = vsize - (export_rva - vaddr);
-# break;
-# expdata = (unsigned char*)malloc(export_size);
-# lseek (dll, expptr, SEEK_SET);
-# read (dll, expdata, export_size);
-# erva = expdata - export_rva;
-# nexp = pe_as32 (expdata+24);
-# name_rvas = pe_as32 (expdata+32);
-# printf ("EXPORTS\n");
-# for (i = 0; i<nexp; i++)
-# unsigned long name_rva = pe_as32 (erva+name_rvas+i*4);
-# printf ("\t%s @ %ld ;\n", erva+name_rva, 1+ i);
-# return 0;
-# /* impgen.c ends here */
-EOF
- esac
+ac_ext=cc
- # We use sed instead of cat because bash on DJGPP gets confused if
- # if finds mixed CR/LF and LF-only lines. Since sed operates in
- # text mode, it properly converts lines to CR/LF. This bash problem
- # is reportedly fixed, but why not run on old versions too?
- sed '$q' "$ltmain" >> "${ofile}T" || (rm -f "${ofile}T"; exit 1)
+CC="$lt_save_CC"
- mv -f "${ofile}T" "$ofile" || \
- (rm -f "$ofile" && cp "${ofile}T" "$ofile" && rm -f "${ofile}T")
- chmod +x "$ofile"
-fi
+ { { echo "$as_me:$LINENO: error: Unsupported tag name: $tagname" >&5
+echo "$as_me: error: Unsupported tag name: $tagname" >&2;}
+ { (exit 1); exit 1; }; }
+ esac
+ # Append the new tag name to the list of available tags.
+ if test -n "$tagname" ; then
+ available_tags="$available_tags $tagname"
+ fi
+ fi
+ done
+ IFS="$lt_save_ifs"
+ # Now substitute the updated list of available tags.
+ if eval "sed -e 's/^available_tags=.*\$/available_tags=\"$available_tags\"/' \"$ofile\" > \"${ofile}T\""; then
+ mv "${ofile}T" "$ofile"
+ chmod +x "$ofile"
+ else
+ rm -f "${ofile}T"
+ { { echo "$as_me:$LINENO: error: unable to update list of available tagged configurations." >&5
+echo "$as_me: error: unable to update list of available tagged configurations." >&2;}
+ fi
+fi
# This can be used to rebuild libtool when needed
LIBTOOL_DEPS="$ac_aux_dir/ltmain.sh"
@@ -8460,7 +19594,26 @@
# Check for std headers
echo "$as_me:$LINENO: checking for ANSI C header files" >&5
echo $ECHO_N "checking for ANSI C header files... $ECHO_C" >&6
if test "${ac_cv_header_stdc+set}" = set; then
@@ -9016,27 +20169,27 @@
if test $map_using_proj4 = "yes"; then
if test $map_proj_prefix = "DEFAULT"; then
- { echo "$as_me:$LINENO: Building proj-4.4.9 from /MgDev/Oem Directory" >&5
-echo "$as_me: Building proj-4.4.9 from /MgDev/Oem Directory" >&6;}
- map_opt_oem_subdirs="proj-4.4.9 $map_opt_oem_subdirs"
- map_opt_oem_distsubdirs="proj-4.4.9 $map_opt_oem_distsubdirs"
+ { echo "$as_me:$LINENO: Building proj-4.5.0 from /MgDev/Oem Directory" >&5
+echo "$as_me: Building proj-4.5.0 from /MgDev/Oem Directory" >&6;}
+ map_opt_oem_subdirs="proj-4.5.0 $map_opt_oem_subdirs"
+ map_opt_oem_distsubdirs="proj-4.5.0 $map_opt_oem_distsubdirs"
-subdirs="$subdirs Oem/proj-4.4.9"
+subdirs="$subdirs Oem/proj-4.5.0"
map_proj_prefix=""
else
- { echo "$as_me:$LINENO: Using proj-4.4.9 install dir prefix $map_proj_prefix" >&5
-echo "$as_me: Using proj-4.4.9 install dir prefix $map_proj_prefix" >&6;}
- { echo "$as_me:$LINENO: proj-4.4.9 include dir - $map_proj_prefix/include" >&5
-echo "$as_me: proj-4.4.9 include dir - $map_proj_prefix/include" >&6;}
+ { echo "$as_me:$LINENO: Using proj-4.5.0 install dir prefix $map_proj_prefix" >&5
+echo "$as_me: Using proj-4.5.0 install dir prefix $map_proj_prefix" >&6;}
+ { echo "$as_me:$LINENO: proj-4.5.0 include dir - $map_proj_prefix/include" >&5
+echo "$as_me: proj-4.5.0 include dir - $map_proj_prefix/include" >&6;}
fi
else
map_proj_prefix=""
- { echo "$as_me:$LINENO: disabling proj-4.4.9 build: is not used with custom CoordinateSystem" >&5
-echo "$as_me: disabling proj-4.4.9 build: is not used with custom CoordinateSystem" >&6;}
+ { echo "$as_me:$LINENO: disabling proj-4.5.0 build: is not used with custom CoordinateSystem" >&5
+echo "$as_me: disabling proj-4.5.0 build: is not used with custom CoordinateSystem" >&6;}
fi
@@ -9051,27 +20204,27 @@
fi;
if test $map_gdal_prefix = "DEFAULT"; then
- { echo "$as_me:$LINENO: Building gdal-1.3.0 from /MgDev/Oem Directory" >&5
-echo "$as_me: Building gdal-1.3.0 from /MgDev/Oem Directory" >&6;}
+ { echo "$as_me:$LINENO: Building gdal-1.4.0 from /MgDev/Oem Directory" >&5
+echo "$as_me: Building gdal-1.4.0 from /MgDev/Oem Directory" >&6;}
-subdirs="$subdirs Oem/gdal-1.3.0"
+subdirs="$subdirs Oem/gdal-1.4.0"
- map_opt_oem_subdirs="gdal-1.3.0 $map_opt_oem_subdirs"
- map_opt_oem_distsubdirs="gdal-1.3.0 $map_opt_oem_distsubdirs"
+ map_opt_oem_subdirs="gdal-1.4.0 $map_opt_oem_subdirs"
+ map_opt_oem_distsubdirs="gdal-1.4.0 $map_opt_oem_distsubdirs"
map_gdal_prefix=""
else
- { echo "$as_me:$LINENO: Using gdal-1.3.0 install dir prefix $map_gdal_prefix" >&5
-echo "$as_me: Using gdal-1.3.0 install dir prefix $map_gdal_prefix" >&6;}
- { echo "$as_me:$LINENO: gdal-1.3.0 include dir $map_gdal_prefix/include" >&5
-echo "$as_me: gdal-1.3.0 include dir $map_gdal_prefix/include" >&6;}
- { echo "$as_me:$LINENO: gdal-1.3.0 lib dir $map_gdal_prefix/include" >&5
-echo "$as_me: gdal-1.3.0 lib dir $map_gdal_prefix/include" >&6;}
+ { echo "$as_me:$LINENO: Using gdal-1.4.0 install dir prefix $map_gdal_prefix" >&5
+echo "$as_me: Using gdal-1.4.0 install dir prefix $map_gdal_prefix" >&6;}
+ { echo "$as_me:$LINENO: gdal-1.4.0 include dir $map_gdal_prefix/include" >&5
+echo "$as_me: gdal-1.4.0 include dir $map_gdal_prefix/include" >&6;}
+ { echo "$as_me:$LINENO: gdal-1.4.0 lib dir $map_gdal_prefix/include" >&5
+echo "$as_me: gdal-1.4.0 lib dir $map_gdal_prefix/include" >&6;}
fi
else
map_gdal_prefix=""
- { echo "$as_me:$LINENO: disabling gdal-1.3.0 build: is not used with custom CoordinateSystem" >&5
-echo "$as_me: disabling gdal-1.3.0 build: is not used with custom CoordinateSystem" >&6;}
+ { echo "$as_me:$LINENO: disabling gdal-1.4.0 build: is not used with custom CoordinateSystem" >&5
+echo "$as_me: disabling gdal-1.4.0 build: is not used with custom CoordinateSystem" >&6;}
fi
@@ -9332,6 +20485,34 @@
Usually this means the macro was only invoked conditionally." >&2;}
fi
+if test -z "${am__fastdepCC_TRUE}" && test -z "${am__fastdepCC_FALSE}"; then
+ { { echo "$as_me:$LINENO: error: conditional \"am__fastdepCC\" was never defined.
+Usually this means the macro was only invoked conditionally." >&5
+echo "$as_me: error: conditional \"am__fastdepCC\" was never defined.
+Usually this means the macro was only invoked conditionally." >&2;}
+fi
+fi
+if test -z "${am__fastdepCXX_TRUE}" && test -z "${am__fastdepCXX_FALSE}"; then
+ { { echo "$as_me:$LINENO: error: conditional \"am__fastdepCXX\" was never defined.
+echo "$as_me: error: conditional \"am__fastdepCXX\" was never defined.
+fi
+fi
: ${CONFIG_STATUS=./config.status}
ac_clean_files_save=$ac_clean_files
@@ -9904,6 +21085,7 @@
s, at INSTALL_PROGRAM@,$INSTALL_PROGRAM,;t t
s, at INSTALL_SCRIPT@,$INSTALL_SCRIPT,;t t
s, at INSTALL_DATA@,$INSTALL_DATA,;t t
+s, at CYGPATH_W@,$CYGPATH_W,;t t
s, at PACKAGE@,$PACKAGE,;t t
s, at VERSION@,$VERSION,;t t
s, at ACLOCAL@,$ACLOCAL,;t t
@@ -9911,13 +21093,17 @@
s, at AUTOMAKE@,$AUTOMAKE,;t t
s, at AUTOHEADER@,$AUTOHEADER,;t t
s, at MAKEINFO@,$MAKEINFO,;t t
-s, at AMTAR@,$AMTAR,;t t
s, at install_sh@,$install_sh,;t t
s, at STRIP@,$STRIP,;t t
s, at ac_ct_STRIP@,$ac_ct_STRIP,;t t
s, at INSTALL_STRIP_PROGRAM@,$INSTALL_STRIP_PROGRAM,;t t
+s, at mkdir_p@,$mkdir_p,;t t
s, at AWK@,$AWK,;t t
s, at SET_MAKE@,$SET_MAKE,;t t
+s, at am__leading_dot@,$am__leading_dot,;t t
+s, at AMTAR@,$AMTAR,;t t
+s, at am__tar@,$am__tar,;t t
+s, at am__untar@,$am__untar,;t t
s, at CC@,$CC,;t t
s, at CFLAGS@,$CFLAGS,;t t
s, at LDFLAGS@,$LDFLAGS,;t t
@@ -9932,10 +21118,14 @@
s, at AMDEP_FALSE@,$AMDEP_FALSE,;t t
s, at AMDEPBACKSLASH@,$AMDEPBACKSLASH,;t t
s, at CCDEPMODE@,$CCDEPMODE,;t t
+s, at am__fastdepCC_TRUE@,$am__fastdepCC_TRUE,;t t
+s, at am__fastdepCC_FALSE@,$am__fastdepCC_FALSE,;t t
s, at CXX@,$CXX,;t t
s, at CXXFLAGS@,$CXXFLAGS,;t t
s, at ac_ct_CXX@,$ac_ct_CXX,;t t
s, at CXXDEPMODE@,$CXXDEPMODE,;t t
+s, at am__fastdepCXX_TRUE@,$am__fastdepCXX_TRUE,;t t
+s, at am__fastdepCXX_FALSE@,$am__fastdepCXX_FALSE,;t t
s, at build@,$build,;t t
s, at build_cpu@,$build_cpu,;t t
s, at build_vendor@,$build_vendor,;t t
@@ -9944,12 +21134,18 @@
s, at host_cpu@,$host_cpu,;t t
s, at host_vendor@,$host_vendor,;t t
s, at host_os@,$host_os,;t t
+s, at EGREP@,$EGREP,;t t
s, at LN_S@,$LN_S,;t t
s, at ECHO@,$ECHO,;t t
+s, at AR@,$AR,;t t
+s, at ac_ct_AR@,$ac_ct_AR,;t t
s, at RANLIB@,$RANLIB,;t t
s, at ac_ct_RANLIB@,$ac_ct_RANLIB,;t t
+s, at CPP@,$CPP,;t t
s, at CXXCPP@,$CXXCPP,;t t
-s, at EGREP@,$EGREP,;t t
+s, at F77@,$F77,;t t
+s, at FFLAGS@,$FFLAGS,;t t
+s, at ac_ct_F77@,$ac_ct_F77,;t t
s, at LIBTOOL@,$LIBTOOL,;t t
s, at map_coordsys_dir@,$map_coordsys_dir,;t t
s, at map_coordsys_dir_path@,$map_coordsys_dir_path,;t t
@@ -10343,27 +21539,21 @@
else
continue
fi
- grep '^DEP_FILES *= *[^ #]' < "$mf" > /dev/null || continue
- # Extract the definition of DEP_FILES from the Makefile without
- # running `make'.
- DEPDIR=`sed -n -e '/^DEPDIR = / s///p' < "$mf"`
+ # Extract the definition of DEPDIR, am__include, and am__quote
+ # from the Makefile without running `make'.
+ DEPDIR=`sed -n 's/^DEPDIR = //p' < "$mf"`
test -z "$DEPDIR" && continue
+ am__include=`sed -n 's/^am__include = //p' < "$mf"`
+ test -z "am__include" && continue
+ am__quote=`sed -n 's/^am__quote = //p' < "$mf"`
# When using ansi2knr, U may be empty or an underscore; expand it
- U=`sed -n -e '/^U = / s///p' < "$mf"`
- test -d "$dirpart/$DEPDIR" || mkdir "$dirpart/$DEPDIR"
- # We invoke sed twice because it is the simplest approach to
- # changing $(DEPDIR) to its actual value in the expansion.
- for file in `sed -n -e '
- /^DEP_FILES = .*\\\\$/ {
- s/^DEP_FILES = //
- :loop
- s/\\\\$//
- p
- n
- /\\\\$/ b loop
- p
- /^DEP_FILES = / s/^DEP_FILES = //p' < "$mf" | \
+ U=`sed -n 's/^U = //p' < "$mf"`
+ # Find all dependency output files, they are included files with
+ # $(DEPDIR) in their names. We invoke sed twice because it is the
+ # simplest approach to changing $(DEPDIR) to its actual value in the
+ # expansion.
+ for file in `sed -n "
+ s/^$am__include $am__quote\(.*(DEPDIR).*\)$am__quote"'$/\1/p' <"$mf" | \
sed -e 's/\$(DEPDIR)/'"$DEPDIR"'/g' -e 's/\$U/'"$U"'/g'`; do
# Make sure the directory exists.
test -f "$dirpart/$file" && continue
Modified: trunk/MgDev/configure.in
--- trunk/MgDev/configure.in 2007-03-21 23:28:35 UTC (rev 1337)
+++ trunk/MgDev/configure.in 2007-03-21 23:34:03 UTC (rev 1338)
@@ -121,46 +121,46 @@
- AC_MSG_NOTICE([Building proj-4.4.9 from /MgDev/Oem Directory])
- AC_CONFIG_SUBDIRS(Oem/proj-4.4.9)
+ AC_MSG_NOTICE([Building proj-4.5.0 from /MgDev/Oem Directory])
+ AC_CONFIG_SUBDIRS(Oem/proj-4.5.0)
map_proj_prefix=""
else
- AC_MSG_NOTICE([Using proj-4.4.9 install dir prefix $map_proj_prefix])
- AC_MSG_NOTICE([proj-4.4.9 include dir - $map_proj_prefix/include])
+ AC_MSG_NOTICE([Using proj-4.5.0 install dir prefix $map_proj_prefix])
+ AC_MSG_NOTICE([proj-4.5.0 include dir - $map_proj_prefix/include])
fi
else
map_proj_prefix=""
- AC_MSG_NOTICE([disabling proj-4.4.9 build: is not used with custom CoordinateSystem])
+ AC_MSG_NOTICE([disabling proj-4.5.0 build: is not used with custom CoordinateSystem])
fi
AC_SUBST(map_proj_prefix)
dnl *******************************************************
-dnl GDAL-1.3.0 Configuration
+dnl gdal-1.4.0 Configuration
AC_ARG_WITH([gdal],
MAP_HELP_STRING([--with-gdal],
- [ignores Oem/gdal-1.3.0 specify install dir prefix [[default=no]]]),
+ [ignores Oem/gdal-1.4.0 specify install dir prefix [[default=no]]]),
[map_gdal_prefix=$withval],
[map_gdal_prefix="DEFAULT"])
- AC_MSG_NOTICE([Building gdal-1.3.0 from /MgDev/Oem Directory])
- AC_CONFIG_SUBDIRS(Oem/gdal-1.3.0)
+ AC_MSG_NOTICE([Building gdal-1.4.0 from /MgDev/Oem Directory])
+ AC_CONFIG_SUBDIRS(Oem/gdal-1.4.0)
map_gdal_prefix=""
else
- AC_MSG_NOTICE([Using gdal-1.3.0 install dir prefix $map_gdal_prefix])
- AC_MSG_NOTICE([gdal-1.3.0 include dir $map_gdal_prefix/include])
- AC_MSG_NOTICE([gdal-1.3.0 lib dir $map_gdal_prefix/include])
+ AC_MSG_NOTICE([Using gdal-1.4.0 install dir prefix $map_gdal_prefix])
+ AC_MSG_NOTICE([gdal-1.4.0 include dir $map_gdal_prefix/include])
+ AC_MSG_NOTICE([gdal-1.4.0 lib dir $map_gdal_prefix/include])
fi
else
map_gdal_prefix=""
- AC_MSG_NOTICE([disabling gdal-1.3.0 build: is not used with custom CoordinateSystem])
+ AC_MSG_NOTICE([disabling gdal-1.4.0 build: is not used with custom CoordinateSystem])
fi
AC_SUBST(map_gdal_prefix)
More information about the mapguide-commits
