[mapguide-commits] r1341 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Wed Mar 21 21:32:17 EDT 2007
Author: waltweltonlair
Date: 2007-03-21 21:32:16 -0400 (Wed, 21 Mar 2007)
New Revision: 1341
trunk/MgDev/Common/Stylization/DWFRenderer.cpp
trunk/MgDev/Common/Stylization/DWFRenderer.h
Updated DWFRenderer to support a subset of the new SE_Renderer interface.
DrawScreenPolyline and DrawScreenPolygon are now implemented, as is
ProcessLabelGroup. Maps using the new symbology now look pretty good
with DWF Viewer. The main pieces still missing are drawing support for
text and rasters, and support for exclusion regions.
Modified: trunk/MgDev/Common/Stylization/DWFRenderer.cpp
--- trunk/MgDev/Common/Stylization/DWFRenderer.cpp 2007-03-22 01:04:04 UTC (rev 1340)
+++ trunk/MgDev/Common/Stylization/DWFRenderer.cpp 2007-03-22 01:32:16 UTC (rev 1341)
@@ -72,11 +72,18 @@
-WT_Color Util_ConvertColor(RS_Color & color)
+WT_Color Util_ConvertColor(RS_Color& color)
- WT_Color ret(color.red(), color.green(), color.blue(), color.alpha());
+ return WT_Color(color.red(), color.green(), color.blue(), color.alpha());
- return ret;
+WT_Color Util_ConvertColor(unsigned int argb)
+ return WT_Color((argb >> 16) & 0xFF,
+ (argb >> 8) & 0xFF,
+ (argb ) & 0xFF,
+ (argb >> 24) & 0xFF);
@@ -200,8 +207,7 @@
DWFRenderer::DWFRenderer()
-: m_w2dFile(NULL),
- m_mapInfo(NULL),
+: m_mapInfo(NULL),
m_layerInfo(NULL),
m_featureClass(NULL),
m_attributes(NULL),
@@ -214,9 +220,11 @@
m_hatchFac(NULL),
m_fillFac(NULL),
m_obsMesh(NULL),
+ m_w2dFile(NULL),
m_w2dStream(NULL),
m_w2dLabels(NULL),
m_labelStream(NULL),
+ m_w2dActive(NULL),
m_pPage(NULL),
m_input(NULL),
m_xformer(NULL),
@@ -1134,7 +1142,7 @@
//symbol is device space
//we will need to place the label inside
- //a consant size macro at an offset
+ //a constant size macro at an offset
//corresponding to the constant size offset from the
//symbol center point
@@ -1179,30 +1187,30 @@
//we need to sync the rendition manually
//since we are about to play macros by writing
//to the file directly
- WT_Integer32 parts_to_sync = WT_Rendition::Color_Bit |
- // WT_Rendition::Color_Map_Bit |
- // WT_Rendition::Fill_Bit |
- // WT_Rendition::Fill_Pattern_Bit |
- // WT_Rendition::Merge_Control_Bit |
- // WT_Rendition::BlockRef_Bit |
- WT_Rendition::Visibility_Bit |
- // WT_Rendition::Line_Weight_Bit |
- WT_Rendition::Pen_Pattern_Bit |
- // WT_Rendition::Line_Pattern_Bit |
- // WT_Rendition::Line_Caps_Bit |
- // WT_Rendition::Line_Join_Bit |
- // WT_Rendition::Marker_Size_Bit |
- // WT_Rendition::Marker_Symbol_Bit |
- // WT_Rendition::URL_Bit |
- WT_Rendition::Layer_Bit |
- // WT_Rendition::Viewport_Bit |
- WT_Rendition::Font_Extension_Bit |
- WT_Rendition::Font_Bit |
- // WT_Rendition::Object_Node_Bit |
- WT_Rendition::Text_Background_Bit |
- WT_Rendition::Text_HAlign_Bit |
- WT_Rendition::Text_VAlign_Bit |
- WT_Rendition::Contrast_Color_Bit;
+ WT_Integer32 parts_to_sync = WT_Rendition::Color_Bit |
+ // WT_Rendition::Color_Map_Bit |
+ // WT_Rendition::Fill_Bit |
+ // WT_Rendition::Fill_Pattern_Bit |
+ // WT_Rendition::Merge_Control_Bit |
+ // WT_Rendition::BlockRef_Bit |
+ WT_Rendition::Visibility_Bit |
+ // WT_Rendition::Line_Weight_Bit |
+ WT_Rendition::Pen_Pattern_Bit |
+ // WT_Rendition::Line_Pattern_Bit |
+ // WT_Rendition::Line_Caps_Bit |
+ // WT_Rendition::Line_Join_Bit |
+ // WT_Rendition::Marker_Size_Bit |
+ // WT_Rendition::Marker_Symbol_Bit |
+ // WT_Rendition::URL_Bit |
+ WT_Rendition::Layer_Bit |
+ // WT_Rendition::Viewport_Bit |
+ WT_Rendition::Font_Extension_Bit |
+ WT_Rendition::Font_Bit |
+ // WT_Rendition::Object_Node_Bit |
+ WT_Rendition::Text_Background_Bit |
+ WT_Rendition::Text_HAlign_Bit |
+ WT_Rendition::Text_VAlign_Bit |
+ WT_Rendition::Contrast_Color_Bit;
file->desired_rendition().sync(*file, parts_to_sync);
@@ -1543,6 +1551,33 @@
+void DWFRenderer::_TransformPoints(double* src, int numpts, const SE_Matrix* xform)
+ EnsureBufferSize(numpts);
+ WT_Integer32* wpts = (WT_Integer32*)m_wtPointBuffer;
+ if (!xform)
+ for (int i=0; i<numpts; i++)
+ *wpts++ = (WT_Integer32)(*src++);
+ else
+ double x, y;
+ xform->transform(src[0], src[1], x, y);
+ *wpts++ = (WT_Integer32)x;
+ *wpts++ = (WT_Integer32)y;
+ src += 2;
// Writes multi-polyline geometry to W2D. Input is a LineBuffer
@@ -1559,10 +1594,10 @@
for (int i=0; i<srclb->cntr_count(); i++)
int cntr_size = srclb->cntrs()[i];
if (cntr_size > 0)
_TransformPointsNoClamp(srclb->points()+index, cntr_size);
WT_Polyline polyline(cntr_size, m_wtPointBuffer, false);
polyline.serialize(*m_w2dFile);
@@ -1743,7 +1778,6 @@
// Mapping Distance = Pixel Distance * (meters/pixel) * mapscale / (meters/map unit)
return (double)pixels * (0.0254 / renderer->GetDpi()) * renderer->GetMapScale() / renderer->GetMetersPerUnit();
@@ -1761,7 +1795,7 @@
if (unit == RS_Units_Device) // in meters, fixed size
- double w2dUnitsPerInch = 4096.0; //TODO: replace by 4096 when fixed
+ double w2dUnitsPerInch = 4096.0;
scale_factor = 100.0 / 2.54 * w2dUnitsPerInch;
else
@@ -1842,7 +1876,6 @@
//check if a piece of that feature has already been written
//by looking up the id in the node table
unsigned int* node = ((NodeTable*)m_hObjNodes)->find(sid);
if (node)
m_w2dFile->desired_rendition().object_node() = WT_Object_Node(*m_w2dFile, *node);
else
@@ -2069,28 +2102,113 @@
void DWFRenderer::DrawScreenPolyline(LineBuffer* geom, const SE_Matrix* xform, unsigned int color, double weight)
- // TODO
+ if (color == 0)
+ return;
+ // draw to the active file if it's set
+ WT_File* file = m_w2dActive? m_w2dActive : m_w2dFile;
+ file->desired_rendition().fill() = false;
+ file->desired_rendition().color() = Util_ConvertColor(color);
+ // the supplied weight is already in W2D units
+ int line_weight = (int)weight;
+ file->desired_rendition().line_weight() = WT_Line_Weight(line_weight);
+ // for now always draw solid lines
+ file->desired_rendition().line_pattern() = WT_Line_Pattern(WT_Line_Pattern::Solid);
+ // save to dwf polylines
+ int index = 0;
+ for (int i=0; i<geom->cntr_count(); i++)
+ int cntr_size = geom->cntrs()[i];
+ if (cntr_size > 0)
+ _TransformPoints(geom->points() + index, cntr_size, xform);
+ WT_Polyline polyline(cntr_size, m_wtPointBuffer, false);
+ polyline.serialize(*file);
+ index += 2*cntr_size;
+ // zero out the dash pattern -- must do when done with it
+// if (file->desired_rendition().dash_pattern() != WT_Dash_Pattern::kNull)
+// file->desired_rendition().dash_pattern() = WT_Dash_Pattern::kNull;
void DWFRenderer::DrawScreenPolygon(LineBuffer* geom, const SE_Matrix* xform, unsigned int fill)
- // TODO
+ if (fill == 0)
+ return;
+ file->desired_rendition().fill() = true;
+ file->desired_rendition().color() = Util_ConvertColor(fill);
+// file->desired_rendition().contrast_color() = Util_ConvertColor(fill.background()).rgba();
+ // for now always draw solid fills
+ file->desired_rendition().user_fill_pattern() = WT_User_Fill_Pattern(-1);
+ file->desired_rendition().user_hatch_pattern() = WT_User_Hatch_Pattern(-1);
+ // save to dwf polygons
+ _TransformPoints(geom->points(), geom->point_count(), xform);
+ if (geom->cntr_count() == 1)
+ // just a polygon, no need for a contourset
+ WT_Polygon fillpoly(geom->point_count(), m_wtPointBuffer, false);
+ fillpoly.serialize(*file);
+ else
+ // otherwise make a contour set
+ WT_Contour_Set cset(*file, geom->cntr_count(), (WT_Integer32*)geom->cntrs(),
+ geom->point_count(), m_wtPointBuffer, true);
+ cset.serialize(*file);
-void DWFRenderer::DrawScreenRaster(unsigned char* data, int length, RS_ImageFormat format, int native_width, int native_height,
- double x, double y, double w, double h, double angledeg)
+void DWFRenderer::DrawScreenRaster(unsigned char* /*data*/,
+ int /*length*/,
+ RS_ImageFormat /*format*/,
+ int /*native_width*/,
+ int /*native_height*/,
+ double /*x*/,
+ double /*y*/,
+ double /*w*/,
+ double /*h*/,
+ double /*angledeg*/)
// TODO
-void DWFRenderer::DrawScreenText(const RS_String& txt, RS_TextDef& tdef, double insx, double insy, double* path, int npts, double param_position)
+void DWFRenderer::DrawScreenText(const RS_String& /*txt*/,
+ RS_TextDef& /*tdef*/,
+ double /*insx*/,
+ double /*insy*/,
+ double* /*path*/,
+ int /*npts*/,
+ double /*param_position*/)
// TODO
+// WriteTextDef(file, info->tdef());
@@ -2144,22 +2262,116 @@
RS_FontEngine* DWFRenderer::GetFontEngine()
- // TODO
return NULL;
-void DWFRenderer::ProcessLabelGroup(SE_LabelInfo* labels,
- int nlabels,
- RS_OverpostType type,
- bool exclude,
- LineBuffer* path)
+void DWFRenderer::ProcessLabelGroup(SE_LabelInfo* labels,
+ int nlabels,
+ RS_OverpostType type,
+ bool exclude,
+ LineBuffer* /*path*/)
- // TODO
+ if (nlabels == 0)
+ return;
+ WT_File* file = m_w2dFile;
+ //check if it is a text layer or a feature label
+ //This is sufficient to check the overpost type
+ //to see if it matches that used only for a text layer,
+ //but nevertheless this is a hack and there should be a way to indicate
+ //a text feature (as opposed to a label)
+ if (type != RS_OverpostType_All)
+ //open the label W2D if it's not yet open
+ if (!m_bHaveLabels)
+ OpenW2D(m_w2dLabels);
+ m_bHaveLabels = true;
+ file = m_w2dLabels;
+ // define a macro for each candidate label
+ for (int i=0; i<nlabels; i++)
+ SE_LabelInfo* info = &labels[i];
+ // For the macro definition we only account for the symbol rotation.
+ // The translation is applied when we play the macro.
+ SE_Matrix m;
+ m.rotate(info->anglerad);
+ // For composite symbolization we will only use mapping-space macros,
+ // meaning the symbols will change size as you zoom dynamically.
+ // The symbols will always be redrawn at the correct size after any
+ // map update.
+ int scale = (int)_MeterToW2DMacroUnit(RS_Units_Model, 1.0);
+ // TODO: account for any symbol offset
+ BeginMacro(file, i+1, scale);
+ m_w2dActive = file;
+ DrawSymbol(info->symbol->symbol, m, info->anglerad);
+ m_w2dActive = NULL;
+ EndMacro(file);
+ // now play the label macros inside an overpost
+ BeginOverpostGroup(file, type, true, exclude);
+ //we need to sync the rendition manually
+ //since we are about to play macros by writing
+ //to the file directly
+ file->desired_rendition().sync(*file, parts_to_sync);
+ // PlayMacro expects a point in mapping units
+ double posx, posy;
+ this->ScreenToWorldPoint(info->x, info->y, posx, posy);
+ PlayMacro(file, i+1, 1.0, RS_Units_Model, posx, posy);
+ EndOverpostGroup(file);
-void DWFRenderer::AddExclusionRegion(RS_F_Point* fpts, int npts)
+void DWFRenderer::AddExclusionRegion(RS_F_Point* /*fpts*/, int /*npts*/)
// TODO
@@ -2179,11 +2391,11 @@
//into the current output W2D. The given coord sys
//transformation is applied and geometry will be clipped
//to the RS_Bounds context of the DWFRenderer
-void DWFRenderer::AddDWFContent(RS_InputStream* in,
- CSysTransformer* xformer,
- const RS_String& section,
- const RS_String& passwd,
- const RS_String& w2dfilter)
+void DWFRenderer::AddDWFContent(RS_InputStream* in,
+ CSysTransformer* xformer,
+ const RS_String& section,
+ const RS_String& passwd,
+ const RS_String& w2dfilter)
try
@@ -2324,7 +2536,6 @@
DWFCORE_FREE_OBJECT(iSection);
@@ -2336,6 +2547,7 @@
void DWFRenderer::AddW2DContent(RS_InputStream* in, CSysTransformer* xformer, const RS_String& w2dfilter)
WT_Result result;
@@ -2368,6 +2580,7 @@
m_input = NULL;
void DWFRenderer::SetActions(WT_File& file)
file.set_stream_open_action (simple_open);
@@ -2463,13 +2676,12 @@
// in a multipolygon or multipolyline, a pointer to a vector
// containing contour counts will also be returned.
// *** Both pointers are valid unit the next call to this function. ***
-const WT_Logical_Point* DWFRenderer::ProcessW2DPoints( WT_File& file,
- WT_Logical_Point* srcpts,
- int numpts,
- LineBuffer::GeomOperationType clipType,
- int& outNumpts,
- std::vector<int>** outCntrs
+const WT_Logical_Point* DWFRenderer::ProcessW2DPoints(WT_File& file,
+ WT_Logical_Point* srcpts,
+ int numpts,
+ LineBuffer::GeomOperationType clipType,
+ int& outNumpts,
+ std::vector<int>** outCntrs)
//This transformer may have been modified if a Viewport
//opcode was encountered in the source W2D. This is needed for
@@ -2660,8 +2872,7 @@
//scaling into account when carrying over things like line weight,
//font height, etc. this helper funtion determines and applies
//that scale
-WT_Integer32 DWFRenderer::ScaleW2DNumber(WT_File& file,
- WT_Integer32 number)
+WT_Integer32 DWFRenderer::ScaleW2DNumber(WT_File& file, WT_Integer32 number)
WT_Matrix xform = file.desired_rendition().drawing_info().units().dwf_to_application_adjoint_transform();
Modified: trunk/MgDev/Common/Stylization/DWFRenderer.h
--- trunk/MgDev/Common/Stylization/DWFRenderer.h 2007-03-22 01:04:04 UTC (rev 1340)
+++ trunk/MgDev/Common/Stylization/DWFRenderer.h 2007-03-22 01:32:16 UTC (rev 1341)
@@ -152,7 +152,7 @@
// SE_Renderer
- virtual void DrawScreenPolyline(LineBuffer* geom, const SE_Matrix* xform, unsigned int color, double weight); // px
+ virtual void DrawScreenPolyline(LineBuffer* geom, const SE_Matrix* xform, unsigned int color, double weight);
virtual void DrawScreenPolygon(LineBuffer* geom, const SE_Matrix* xform, unsigned int fill);
virtual void DrawScreenRaster(unsigned char* data, int length, RS_ImageFormat format, int native_width, int native_height,
double x, double y, double w, double h, double angledeg);
@@ -167,12 +167,7 @@
virtual RS_FontEngine* GetFontEngine();
- virtual void ProcessLabelGroup(SE_LabelInfo* labels,
- int nlabels,
- bool exclude,
- LineBuffer* path = NULL);
+ virtual void ProcessLabelGroup(SE_LabelInfo* labels, int nlabels, RS_OverpostType type, bool exclude, LineBuffer* path = NULL);
virtual void AddExclusionRegion(RS_F_Point* fpts, int npts);
protected:
@@ -192,6 +187,9 @@
// list of layout label w2d streams;
stream_list m_lLayoutLabelStreams;
+ // the active w2d to draw into
+ WT_File* m_w2dActive;
bool m_bHaveLabels;
ObservationMesh* m_obsMesh;
@@ -221,6 +219,7 @@
double _TX(double x);
double _TY(double y);
void _TransformPointsNoClamp(double* inpts, int numpts);
+ void _TransformPoints(double* inpts, int numpts, const SE_Matrix* xform);
private:
//macro/overpost opcode output -- done manually by writing to file
More information about the mapguide-commits
