[mapguide-commits] r1343 - in trunk/MgDev/Oem/DWFTK7.1: . develop
develop/global develop/global/src
svn_mapguide at osgeo.org
Wed Mar 21 22:44:11 EDT 2007
Author: waltweltonlair
Date: 2007-03-21 22:44:11 -0400 (Wed, 21 Mar 2007)
New Revision: 1343
Removed:
trunk/MgDev/Oem/DWFTK7.1/Makefile
trunk/MgDev/Oem/DWFTK7.1/Makefile.am
trunk/MgDev/Oem/DWFTK7.1/develop/Makefile
trunk/MgDev/Oem/DWFTK7.1/develop/Makefile.am
trunk/MgDev/Oem/DWFTK7.1/develop/global/Makefile
trunk/MgDev/Oem/DWFTK7.1/develop/global/Makefile.am
trunk/MgDev/Oem/DWFTK7.1/develop/global/src/Makefile
trunk/MgDev/Oem/DWFTK7.1/develop/global/src/Makefile.am
The DWF Toolkit is built as part of build_oem, and should not participate in the normal make process.
Deleted: trunk/MgDev/Oem/DWFTK7.1/Makefile
--- trunk/MgDev/Oem/DWFTK7.1/Makefile 2007-03-22 02:43:41 UTC (rev 1342)
+++ trunk/MgDev/Oem/DWFTK7.1/Makefile 2007-03-22 02:44:11 UTC (rev 1343)
@@ -1,353 +0,0 @@
-# Makefile.in generated by automake 1.6.3 from Makefile.am.
-# Oem/DWFTK7.1/Makefile. Generated from Makefile.in by configure.
-# Copyright 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002
-# Free Software Foundation, Inc.
-# This Makefile.in is free software; the Free Software Foundation
-# gives unlimited permission to copy and/or distribute it,
-# with or without modifications, as long as this notice is preserved.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY, to the extent permitted by law; without
-# even the implied warranty of MERCHANTABILITY or FITNESS FOR A
-# PARTICULAR PURPOSE.
-SHELL = /bin/sh
-srcdir = .
-top_srcdir = ../..
-exec_prefix = ${prefix}
-bindir = ${exec_prefix}/bin
-sbindir = ${exec_prefix}/sbin
-libexecdir = ${exec_prefix}/libexec
-datadir = ${prefix}/share
-sysconfdir = ${prefix}/etc
-sharedstatedir = ${prefix}/com
-localstatedir = ${prefix}/var
-libdir = ${exec_prefix}/lib
-infodir = ${prefix}/info
-mandir = ${prefix}/man
-includedir = ${prefix}/include
-oldincludedir = /usr/include
-pkgdatadir = $(datadir)/mapguide
-pkglibdir = $(libdir)/mapguide
-pkgincludedir = $(includedir)/mapguide
-top_builddir = ../..
-ACLOCAL = ${SHELL} /home/strangt/MgDev/missing --run aclocal-1.6
-AUTOCONF = ${SHELL} /home/strangt/MgDev/missing --run autoconf
-AUTOMAKE = ${SHELL} /home/strangt/MgDev/missing --run automake-1.6
-AUTOHEADER = ${SHELL} /home/strangt/MgDev/missing --run autoheader
-am__cd = CDPATH="$${ZSH_VERSION+.}$(PATH_SEPARATOR)" && cd
-INSTALL = /usr/bin/install -c
-INSTALL_PROGRAM = ${INSTALL}
-INSTALL_DATA = ${INSTALL} -m 644
-install_sh_DATA = $(install_sh) -c -m 644
-install_sh_PROGRAM = $(install_sh) -c
-install_sh_SCRIPT = $(install_sh) -c
-INSTALL_SCRIPT = ${INSTALL}
-INSTALL_HEADER = $(INSTALL_DATA)
-transform = s,x,x,
-NORMAL_INSTALL = :
-PRE_INSTALL = :
-POST_INSTALL = :
-NORMAL_UNINSTALL = :
-PRE_UNINSTALL = :
-POST_UNINSTALL = :
-host_alias =
-host_triplet = i686-pc-linux-gnu
-EXEEXT =
-OBJEXT = o
-PATH_SEPARATOR = :
-prefix = /usr/local/mapguideopensource
-AMTAR = ${SHELL} /home/strangt/MgDev/missing --run tar
-AS = @AS@
-AWK = gawk
-CC = gcc
-CXX = g++
-CXXFLAGS = -O2 -g -pipe -march=i386 -mcpu=i686 -fno-use-cxa-atexit -fexceptions
-DEPDIR = .deps
-DLLTOOL = @DLLTOOL@
-ECHO = echo
-INSTALL_STRIP_PROGRAM = ${SHELL} $(install_sh) -c -s
-LIBTOOL = $(SHELL) $(top_builddir)/libtool
-LN_S = ln -s
-OBJDUMP = @OBJDUMP@
-PACKAGE = mapguide
-RANLIB = ranlib
-STRIP = strip
-VERSION = 1.0.0
-am__include = include
-am__quote =
-install_sh = /home/strangt/MgDev/install-sh
-map_coordsys_dir = CoordinateSystem
-map_coordsys_dir_path = Common/CoordinateSystem
-map_coordsys_include_path = Common/CoordinateSystem
-map_fdo_include = /usr/local/fdo-3.0.0/include
-map_fdo_lib = /usr/local/fdo-3.0.0/lib
-map_gdal_prefix =
-map_opt_oem_distsubdirs = gdal-1.3.0 proj-4.4.9
-map_opt_oem_subdirs = gdal-1.3.0 proj-4.4.9
-map_proj_prefix =
-map_srcdir = /home/strangt/MgDev
-map_toplevel_subdirs = Oem Common Server Web
-map_unittesting_dir = UnitTesting
-AUTOMAKE_OPTIONS = foreign
-SUBDIRS = develop
-subdir = Oem/DWFTK7.1
-mkinstalldirs = $(SHELL) $(top_srcdir)/mkinstalldirs
-CONFIG_CLEAN_FILES =
-DIST_SOURCES =
-RECURSIVE_TARGETS = info-recursive dvi-recursive install-info-recursive \
- uninstall-info-recursive all-recursive install-data-recursive \
- install-exec-recursive installdirs-recursive install-recursive \
- uninstall-recursive check-recursive installcheck-recursive
-DIST_COMMON = Makefile.am Makefile.in
-DIST_SUBDIRS = $(SUBDIRS)
-all: all-recursive
-.SUFFIXES:
-$(srcdir)/Makefile.in: Makefile.am $(top_srcdir)/configure.in $(ACLOCAL_M4)
- cd $(top_srcdir) && \
- $(AUTOMAKE) --foreign Oem/DWFTK7.1/Makefile
-Makefile: $(srcdir)/Makefile.in $(top_builddir)/config.status
- cd $(top_builddir) && $(SHELL) ./config.status $(subdir)/$@ $(am__depfiles_maybe)
-mostlyclean-libtool:
- -rm -f *.lo
-clean-libtool:
- -rm -rf .libs _libs
-distclean-libtool:
- -rm -f libtool
-uninstall-info-am:
-# This directory's subdirectories are mostly independent; you can cd
-# into them and run `make' without going through this Makefile.
-# To change the values of `make' variables: instead of editing Makefiles,
-# (1) if the variable is set in `config.status', edit `config.status'
-# (which will cause the Makefiles to be regenerated when you run `make');
-# (2) otherwise, pass the desired values on the `make' command line.
-$(RECURSIVE_TARGETS):
- @set fnord $$MAKEFLAGS; amf=$$2; \
- dot_seen=no; \
- target=`echo $@ | sed s/-recursive//`; \
- list='$(SUBDIRS)'; for subdir in $$list; do \
- echo "Making $$target in $$subdir"; \
- if test "$$subdir" = "."; then \
- dot_seen=yes; \
- local_target="$$target-am"; \
- else \
- local_target="$$target"; \
- fi; \
- (cd $$subdir && $(MAKE) $(AM_MAKEFLAGS) $$local_target) \
- || case "$$amf" in *=*) exit 1;; *k*) fail=yes;; *) exit 1;; esac; \
- done; \
- if test "$$dot_seen" = "no"; then \
- $(MAKE) $(AM_MAKEFLAGS) "$$target-am" || exit 1; \
- fi; test -z "$$fail"
-mostlyclean-recursive clean-recursive distclean-recursive \
-maintainer-clean-recursive:
- dot_seen=no; \
- case "$@" in \
- distclean-* | maintainer-clean-*) list='$(DIST_SUBDIRS)' ;; \
- *) list='$(SUBDIRS)' ;; \
- esac; \
- rev=''; for subdir in $$list; do \
- if test "$$subdir" = "."; then :; else \
- rev="$$subdir $$rev"; \
- fi; \
- done; \
- rev="$$rev ."; \
- for subdir in $$rev; do \
- else \
- fi; \
- done && test -z "$$fail"
-tags-recursive:
- test "$$subdir" = . || (cd $$subdir && $(MAKE) $(AM_MAKEFLAGS) tags); \
- done
-ETAGS = etags
-ETAGSFLAGS =
-tags: TAGS
-ID: $(HEADERS) $(SOURCES) $(LISP) $(TAGS_FILES)
- list='$(SOURCES) $(HEADERS) $(LISP) $(TAGS_FILES)'; \
- unique=`for i in $$list; do \
- if test -f "$$i"; then echo $$i; else echo $(srcdir)/$$i; fi; \
- done | \
- $(AWK) ' { files[$$0] = 1; } \
- END { for (i in files) print i; }'`; \
- mkid -fID $$unique
-TAGS: tags-recursive $(HEADERS) $(SOURCES) $(TAGS_DEPENDENCIES) \
- $(TAGS_FILES) $(LISP)
- tags=; \
- here=`pwd`; \
- if test "$$subdir" = .; then :; else \
- test -f $$subdir/TAGS && tags="$$tags -i $$here/$$subdir/TAGS"; \
- fi; \
- done; \
- done | \
- test -z "$(ETAGS_ARGS)$$tags$$unique" \
- || $(ETAGS) $(ETAGSFLAGS) $(AM_ETAGSFLAGS) $(ETAGS_ARGS) \
- $$tags $$unique
-GTAGS:
- here=`$(am__cd) $(top_builddir) && pwd` \
- && cd $(top_srcdir) \
- && gtags -i $(GTAGS_ARGS) $$here
-distclean-tags:
- -rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH
-DISTFILES = $(DIST_COMMON) $(DIST_SOURCES) $(TEXINFOS) $(EXTRA_DIST)
-top_distdir = ../..
-distdir = $(top_distdir)/$(PACKAGE)-$(VERSION)
-distdir: $(DISTFILES)
- @list='$(DISTFILES)'; for file in $$list; do \
- if test -f $$file || test -d $$file; then d=.; else d=$(srcdir); fi; \
- dir=`echo "$$file" | sed -e 's,/[^/]*$$,,'`; \
- if test "$$dir" != "$$file" && test "$$dir" != "."; then \
- dir="/$$dir"; \
- $(mkinstalldirs) "$(distdir)$$dir"; \
- else \
- dir=''; \
- fi; \
- if test -d $$d/$$file; then \
- if test -d $(srcdir)/$$file && test $$d != $(srcdir); then \
- cp -pR $(srcdir)/$$file $(distdir)$$dir || exit 1; \
- fi; \
- cp -pR $$d/$$file $(distdir)$$dir || exit 1; \
- else \
- test -f $(distdir)/$$file \
- || cp -p $$d/$$file $(distdir)/$$file \
- || exit 1; \
- fi; \
- done
- test -d $(distdir)/$$subdir \
- || mkdir $(distdir)/$$subdir \
- || exit 1; \
- (cd $$subdir && \
- $(MAKE) $(AM_MAKEFLAGS) \
- top_distdir="$(top_distdir)" \
- distdir=../$(distdir)/$$subdir \
- distdir) \
- || exit 1; \
- fi; \
- done
-check-am: all-am
-check: check-recursive
-all-am: Makefile
-installdirs: installdirs-recursive
-installdirs-am:
-install: install-recursive
-install-exec: install-exec-recursive
-install-data: install-data-recursive
-uninstall: uninstall-recursive
-install-am: all-am
- @$(MAKE) $(AM_MAKEFLAGS) install-exec-am install-data-am
-installcheck: installcheck-recursive
-install-strip:
- $(MAKE) $(AM_MAKEFLAGS) INSTALL_PROGRAM="$(INSTALL_STRIP_PROGRAM)" \
- INSTALL_STRIP_FLAG=-s \
- `test -z '$(STRIP)' || \
- echo "INSTALL_PROGRAM_ENV=STRIPPROG='$(STRIP)'"` install
-mostlyclean-generic:
-clean-generic:
-distclean-generic:
- -rm -f Makefile $(CONFIG_CLEAN_FILES)
-maintainer-clean-generic:
- @echo "This command is intended for maintainers to use"
- @echo "it deletes files that may require special tools to rebuild."
-clean: clean-recursive
-clean-am: clean-generic clean-libtool mostlyclean-am
-distclean: distclean-recursive
-distclean-am: clean-am distclean-generic distclean-libtool \
- distclean-tags
-dvi: dvi-recursive
-dvi-am:
-info: info-recursive
-info-am:
-install-data-am:
-install-exec-am:
-install-info: install-info-recursive
-install-man:
-installcheck-am:
-maintainer-clean: maintainer-clean-recursive
-maintainer-clean-am: distclean-am maintainer-clean-generic
-mostlyclean: mostlyclean-recursive
-mostlyclean-am: mostlyclean-generic mostlyclean-libtool
-uninstall-am: uninstall-info-am
-uninstall-info: uninstall-info-recursive
-.PHONY: $(RECURSIVE_TARGETS) GTAGS all all-am check check-am clean \
- clean-generic clean-libtool clean-recursive distclean \
- distclean-generic distclean-libtool distclean-recursive \
- distclean-tags distdir dvi dvi-am dvi-recursive info info-am \
- info-recursive install install-am install-data install-data-am \
- install-data-recursive install-exec install-exec-am \
- install-exec-recursive install-info install-info-am \
- install-info-recursive install-man install-recursive \
- install-strip installcheck installcheck-am installdirs \
- installdirs-am installdirs-recursive maintainer-clean \
- maintainer-clean-generic maintainer-clean-recursive mostlyclean \
- mostlyclean-generic mostlyclean-libtool mostlyclean-recursive \
- tags tags-recursive uninstall uninstall-am uninstall-info-am \
- uninstall-info-recursive uninstall-recursive
-# Tell versions [3.59,3.63) of GNU make to not export all variables.
-# Otherwise a system limit (for SysV at least) may be exceeded.
-.NOEXPORT:
Deleted: trunk/MgDev/Oem/DWFTK7.1/Makefile.am
--- trunk/MgDev/Oem/DWFTK7.1/Makefile.am 2007-03-22 02:43:41 UTC (rev 1342)
+++ trunk/MgDev/Oem/DWFTK7.1/Makefile.am 2007-03-22 02:44:11 UTC (rev 1343)
@@ -1,4 +0,0 @@
-prefix=@prefix@
-SUBDIRS = develop
Deleted: trunk/MgDev/Oem/DWFTK7.1/develop/Makefile
--- trunk/MgDev/Oem/DWFTK7.1/develop/Makefile 2007-03-22 02:43:41 UTC (rev 1342)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/Makefile 2007-03-22 02:44:11 UTC (rev 1343)
@@ -1,353 +0,0 @@
-# Oem/DWFTK7.1/develop/Makefile. Generated from Makefile.in by configure.
-SHELL = /bin/sh
-srcdir = .
-top_srcdir = ../../..
-top_builddir = ../../..
-transform = s,x,x,
-NORMAL_INSTALL = :
-PRE_INSTALL = :
-POST_INSTALL = :
-PRE_UNINSTALL = :
-POST_UNINSTALL = :
-host_alias =
-EXEEXT =
-OBJEXT = o
-PATH_SEPARATOR = :
-AS = @AS@
-AWK = gawk
-CC = gcc
-CXX = g++
-DEPDIR = .deps
-ECHO = echo
-LN_S = ln -s
-PACKAGE = mapguide
-RANLIB = ranlib
-STRIP = strip
-VERSION = 1.0.0
-am__quote =
-map_gdal_prefix =
-map_proj_prefix =
-SUBDIRS = global
-subdir = Oem/DWFTK7.1/develop
-DIST_SOURCES =
-all: all-recursive
-.SUFFIXES:
- $(AUTOMAKE) --foreign Oem/DWFTK7.1/develop/Makefile
- -rm -f *.lo
-clean-libtool:
-distclean-libtool:
- -rm -f libtool
-uninstall-info-am:
- dot_seen=no; \
- dot_seen=yes; \
- else \
- fi; \
- done; \
- dot_seen=no; \
- case "$@" in \
- esac; \
- fi; \
- done; \
- rev="$$rev ."; \
- else \
- fi; \
-tags-recursive:
- done
-ETAGS = etags
-ETAGSFLAGS =
-tags: TAGS
- done | \
- tags=; \
- here=`pwd`; \
- fi; \
- done; \
- done | \
- $$tags $$unique
-GTAGS:
-distclean-tags:
-top_distdir = ../../..
- dir="/$$dir"; \
- else \
- dir=''; \
- fi; \
- fi; \
- else \
- || exit 1; \
- fi; \
- done
- || exit 1; \
- (cd $$subdir && \
- distdir) \
- || exit 1; \
- fi; \
- done
-check-am: all-am
-all-am: Makefile
-installdirs-am:
-install-am: all-am
-install-strip:
-clean-generic:
-distclean-generic:
- distclean-tags
-dvi: dvi-recursive
-dvi-am:
-info-am:
-install-data-am:
-install-exec-am:
-install-man:
-installcheck-am:
-.NOEXPORT:
Deleted: trunk/MgDev/Oem/DWFTK7.1/develop/Makefile.am
--- trunk/MgDev/Oem/DWFTK7.1/develop/Makefile.am 2007-03-22 02:43:41 UTC (rev 1342)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/Makefile.am 2007-03-22 02:44:11 UTC (rev 1343)
@@ -1,4 +0,0 @@
-prefix=@prefix@
-SUBDIRS = global
Deleted: trunk/MgDev/Oem/DWFTK7.1/develop/global/Makefile
--- trunk/MgDev/Oem/DWFTK7.1/develop/global/Makefile 2007-03-22 02:43:41 UTC (rev 1342)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/global/Makefile 2007-03-22 02:44:11 UTC (rev 1343)
@@ -1,353 +0,0 @@
-# Oem/DWFTK7.1/develop/global/Makefile. Generated from Makefile.in by configure.
-SHELL = /bin/sh
-srcdir = .
-top_srcdir = ../../../..
-top_builddir = ../../../..
-transform = s,x,x,
-NORMAL_INSTALL = :
-PRE_INSTALL = :
-POST_INSTALL = :
-PRE_UNINSTALL = :
-POST_UNINSTALL = :
-host_alias =
-EXEEXT =
-OBJEXT = o
-PATH_SEPARATOR = :
-AS = @AS@
-AWK = gawk
-CC = gcc
-CXX = g++
-DEPDIR = .deps
-ECHO = echo
-LN_S = ln -s
-PACKAGE = mapguide
-RANLIB = ranlib
-STRIP = strip
-VERSION = 1.0.0
-am__quote =
-map_gdal_prefix =
-map_proj_prefix =
-SUBDIRS = src
-subdir = Oem/DWFTK7.1/develop/global
-DIST_SOURCES =
-all: all-recursive
-.SUFFIXES:
- $(AUTOMAKE) --foreign Oem/DWFTK7.1/develop/global/Makefile
- -rm -f *.lo
-clean-libtool:
-distclean-libtool:
- -rm -f libtool
-uninstall-info-am:
- dot_seen=no; \
- dot_seen=yes; \
- else \
- fi; \
- done; \
- dot_seen=no; \
- case "$@" in \
- esac; \
- fi; \
- done; \
- rev="$$rev ."; \
- else \
- fi; \
-tags-recursive:
- done
-ETAGS = etags
-ETAGSFLAGS =
-tags: TAGS
- done | \
- tags=; \
- here=`pwd`; \
- fi; \
- done; \
- done | \
- $$tags $$unique
-GTAGS:
-distclean-tags:
-top_distdir = ../../../..
- dir="/$$dir"; \
- else \
- dir=''; \
- fi; \
- fi; \
- else \
- || exit 1; \
- fi; \
- done
- || exit 1; \
- (cd $$subdir && \
- distdir) \
- || exit 1; \
- fi; \
- done
-check-am: all-am
-all-am: Makefile
-installdirs-am:
-install-am: all-am
-install-strip:
-clean-generic:
-distclean-generic:
- distclean-tags
-dvi: dvi-recursive
-dvi-am:
-info-am:
-install-data-am:
-install-exec-am:
-install-man:
-installcheck-am:
-.NOEXPORT:
Deleted: trunk/MgDev/Oem/DWFTK7.1/develop/global/Makefile.am
--- trunk/MgDev/Oem/DWFTK7.1/develop/global/Makefile.am 2007-03-22 02:43:41 UTC (rev 1342)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/global/Makefile.am 2007-03-22 02:44:11 UTC (rev 1343)
@@ -1,4 +0,0 @@
-prefix=@prefix@
-SUBDIRS = src
Deleted: trunk/MgDev/Oem/DWFTK7.1/develop/global/src/Makefile
--- trunk/MgDev/Oem/DWFTK7.1/develop/global/src/Makefile 2007-03-22 02:43:41 UTC (rev 1342)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/global/src/Makefile 2007-03-22 02:44:11 UTC (rev 1343)
@@ -1,353 +0,0 @@
-# Oem/DWFTK7.1/develop/global/src/Makefile. Generated from Makefile.in by configure.
-SHELL = /bin/sh
-srcdir = .
-top_srcdir = ../../../../..
-top_builddir = ../../../../..
-transform = s,x,x,
-NORMAL_INSTALL = :
-PRE_INSTALL = :
-POST_INSTALL = :
-PRE_UNINSTALL = :
-POST_UNINSTALL = :
-host_alias =
-EXEEXT =
-OBJEXT = o
-PATH_SEPARATOR = :
-AS = @AS@
-AWK = gawk
-CC = gcc
-CXX = g++
-DEPDIR = .deps
-ECHO = echo
-LN_S = ln -s
-PACKAGE = mapguide
-RANLIB = ranlib
-STRIP = strip
-VERSION = 1.0.0
-am__quote =
-map_gdal_prefix =
-map_proj_prefix =
-SUBDIRS = dwfcore dwf dwfemap
-subdir = Oem/DWFTK7.1/develop/global/src
-DIST_SOURCES =
-all: all-recursive
-.SUFFIXES:
- $(AUTOMAKE) --foreign Oem/DWFTK7.1/develop/global/src/Makefile
- -rm -f *.lo
-clean-libtool:
-distclean-libtool:
- -rm -f libtool
-uninstall-info-am:
- dot_seen=no; \
- dot_seen=yes; \
- else \
- fi; \
- done; \
- dot_seen=no; \
- case "$@" in \
- esac; \
- fi; \
- done; \
- rev="$$rev ."; \
- else \
- fi; \
-tags-recursive:
- done
-ETAGS = etags
-ETAGSFLAGS =
-tags: TAGS
- done | \
- tags=; \
- here=`pwd`; \
- fi; \
- done; \
- done | \
- $$tags $$unique
-GTAGS:
-distclean-tags:
-top_distdir = ../../../../..
- dir="/$$dir"; \
- else \
- dir=''; \
- fi; \
- fi; \
- else \
- || exit 1; \
- fi; \
- done
- || exit 1; \
- (cd $$subdir && \
- distdir) \
- || exit 1; \
- fi; \
- done
-check-am: all-am
-all-am: Makefile
-installdirs-am:
-install-am: all-am
-install-strip:
-clean-generic:
-distclean-generic:
- distclean-tags
-dvi: dvi-recursive
-dvi-am:
-info-am:
-install-data-am:
-install-exec-am:
-install-man:
-installcheck-am:
-.NOEXPORT:
Deleted: trunk/MgDev/Oem/DWFTK7.1/develop/global/src/Makefile.am
--- trunk/MgDev/Oem/DWFTK7.1/develop/global/src/Makefile.am 2007-03-22 02:43:41 UTC (rev 1342)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/global/src/Makefile.am 2007-03-22 02:44:11 UTC (rev 1343)
@@ -1,4 +0,0 @@
-prefix=@prefix@
More information about the mapguide-commits
