[mapguide-commits] r1358 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Fri Mar 23 12:56:13 EDT 2007
Author: traianstanev
Date: 2007-03-23 12:56:13 -0400 (Fri, 23 Mar 2007)
New Revision: 1358
trunk/MgDev/Common/Stylization/StylizationEngine.cpp
Fixed bug in y coordinate scaling.
Modified: trunk/MgDev/Common/Stylization/StylizationEngine.cpp
--- trunk/MgDev/Common/Stylization/StylizationEngine.cpp 2007-03-23 13:06:23 UTC (rev 1357)
+++ trunk/MgDev/Common/Stylization/StylizationEngine.cpp 2007-03-23 16:56:13 UTC (rev 1358)
@@ -195,6 +195,9 @@
double mm2pxs = m_serenderer->GetPixelsPerMillimeterScreen();
double mm2pxw = m_serenderer->GetPixelsPerMillimeterWorld();
+ SE_Matrix w2s;
+ m_serenderer->GetWorldToScreenTransform(w2s);
SE_Rule*& rules = m_rules[style];
RuleCollection* rulecoll = style->GetRules();
int nRules = rulecoll->GetCount();
@@ -274,7 +277,14 @@
sym->scale[1].evaluate(executor),
sym->absOffset[0].evaluate(executor),
sym->absOffset[1].evaluate(executor) );
- xform.scale(mm2px, mm2px);
+ //??? symbol geometry needs to be inverted if the y coordinate in the renderer points down
+ //This is so that in symbol definitions y points up consistently no matter what the underlying
+ //renderer is doing. Normally we could just apply the world to screen transform to everything,
+ //but in some cases we only apply it to the position of the symbol and then offset the symbol
+ //geometry from there -- so the symbol geometry needs to be pre-inverted.
+ //TODO: check if all rotations still work in the right direction
+ xform.scale(mm2px, w2s.y1 < 0 ? -mm2px : mm2px);
//initialize the style evaluation context
SE_EvalContext cxt;
More information about the mapguide-commits
