[mapguide-commits] r1360 - in trunk/MgDev/Oem: . LinuxApt
svn_mapguide at osgeo.org
Fri Mar 23 16:57:03 EDT 2007
Author: trevorwekel
Date: 2007-03-23 16:57:03 -0400 (Fri, 23 Mar 2007)
New Revision: 1360
Added:
trunk/MgDev/Oem/LinuxApt/
trunk/MgDev/Oem/LinuxApt/apache-tomcat-5.5.12.tar.gz
trunk/MgDev/Oem/LinuxApt/build_apt.sh
trunk/MgDev/Oem/LinuxApt/httpd-2.0.55.tar.gz
trunk/MgDev/Oem/LinuxApt/jakarta-tomcat-connectors-1.2.15-src.tar.gz
trunk/MgDev/Oem/LinuxApt/mod_fastcgi.tar.gz
trunk/MgDev/Oem/LinuxApt/php.ini-mapguide
trunk/MgDev/Oem/LinuxApt/server.xml
Add Linux Apache/PHP/Tomcat bundle to Subversion and build using Oem PHP
Added: trunk/MgDev/Oem/LinuxApt/apache-tomcat-5.5.12.tar.gz
(Binary files differ)
Property changes on: trunk/MgDev/Oem/LinuxApt/apache-tomcat-5.5.12.tar.gz
___________________________________________________________________
+ application/octet-stream
Added: trunk/MgDev/Oem/LinuxApt/build_apt.sh
--- trunk/MgDev/Oem/LinuxApt/build_apt.sh (rev 0)
+++ trunk/MgDev/Oem/LinuxApt/build_apt.sh 2007-03-23 20:57:03 UTC (rev 1360)
@@ -0,0 +1,472 @@
+#! /bin/bash
+# MapGuide Open Source Apache, Php, Tomcat Build Script
+# Initialization
+echo
+echo "MapGuide Open Source build/install script for Apache, Php, Tomcat"
+echo "-----------------------------------------------------------------"
+echo
+INSTALLDIR=/usr/local/mapguideopensource
+PORT=8008
+TOMCAT=0
+while [ $# -gt 0 ]; do # Until you run out of parameters . . .
+ case "$1" in
+ -port|--port)
+ PORT="$2"
+ shift
+ -prefix|--prefix)
+ INSTALLDIR="$2"
+ shift
+ -with-tomcat|--with-tomcat)
+ TOMCAT=1
+ shift
+ -help|--help)
+ echo "Usage: $0 (options)"
+ echo "Options:"
+ echo " --port [Apache port number]"
+ echo " --prefix [installation directory]"
+ echo " --with-tomcat Configure and install Tomcat"
+ echo " --help Display usage"
+ esac
+ shift # Check next set of parameters.
+done
+INSTALLWEB=$INSTALLDIR/webserverextensions
+echo "Apache will be built/installed to $INSTALLWEB/apache2."
+echo "Php will be built/installed to $INSTALLWEB/php."
+if [ "$TOMCAT" = "1" ]; then
+ echo "Tomcat will be installed to $INSTALLWEB/tomcat."
+fi
+echo
+echo "Apache will be configured to run on port $PORT."
+ echo "Tomcat will be configured to run on port 8080."
+fi
+# exit status of previous command
+#echo $?
+check_apache_build ()
+ if [ $? -ne 0 ]; then
+ error=$?
+ echo "Apache build failed ($error)."
+ exit $error
+ fi
+check_php_build ()
+ error=$?
+ echo "Php build failed ($error)."
+ exit $error
+ fi
+check_mod_build ()
+ error=$?
+ echo "Mod FastCGI build/install failed ($error)."
+ exit $error
+ fi
+check_apache_install ()
+ error=$?
+ echo "Apache install failed ($error)."
+ exit $error
+ fi
+check_php_install ()
+ error=$?
+ echo "Php install failed ($error)."
+ exit $error
+ fi
+check_tomcat_build ()
+ error=$?
+ echo "Tomcat build failed ($error)."
+ exit $error
+ fi
+check_tomcat_install ()
+ error=$?
+ echo "Tomcat install failed ($error)."
+ exit $error
+ fi
+# Apache build procedure
+# Notes: none
+echo Apache Httpd build started
+pushd httpd-2.0.55
+./configure --prefix=$INSTALLWEB/apache2 --enable-mods-shared=all \
+--with-port=$PORT
+check_apache_build
+make
+check_apache_build
+popd
+echo Apache Httpd build completed
+# Php build procedure
+# Notes: none
+echo Php build started
+pushd ../php
+./configure --prefix=$INSTALLWEB/php --enable-fastcgi --with-openssl \
+--with-curl --enable-xml --enable-wddx --enable-shared \
+--enable-safe-mode --with-zlib --enable-mbstring=all
+check_php_build
+make
+check_php_build
+popd
+echo Php build completed
+# Apache shutdown procedure
+# Notes: none
+echo Attempting to shutdown Apache
+pushd $INSTALLWEB/apache2/bin
+./apachectl stop
+popd
+echo Attempting to remove old Apache and Php
+pushd $INSTALLWEB
+rm -rf apache2
+rm -rf php
+popd
+echo Completed uninstall of Apache and Php
+# Apache install procedure
+# Notes: none
+echo Apache install started
+pushd httpd-2.0.55
+make install
+popd
+pushd $INSTALLWEB/apache2/conf
+# Prep httpd.conf to read mapguide configuration
+echo "" > tmpfile
+echo "Include conf/mapguide.conf" >> tmpfile
+cat httpd-std.conf tmpfile > httpd.conf
+popd
+echo Apache install completed
+# Apache FastCGI module build/install procedure
+# Notes: This is a work in progress and is not complete
+pushd mod_fastcgi
+cp -f Makefile.AP2 Makefile
+make top_dir=$INSTALLWEB/apache2
+check_mod_build
+make install top_dir=$INSTALLWEB/apache2
+check_mod_build
+popd
+cat > mapguide.conf <<END-OF-CONFIGURATION
+LoadModule fastcgi_module modules/mod_fastcgi.so
+FastCgiIpcDir /tmp/mapguideipc
+FastCgiConfig -idle-timeout 120 -startDelay 1 -minProcesses 4 -maxClassProcesses 4 -multiThreshold 100 -singleThreshold 100 -killInterval 600 -initial-env GDAL_DATA=$INSTALLDIR/share/gdal -initial-env PROJ_LIB=$INSTALLDIR/share/proj
+FastCgiServer "$INSTALLWEB/php/bin/php" -processes 4 -idle-timeout 120 -initial-env GDAL_DATA=$INSTALLDIR/share/gdal -initial-env PROJ_LIB=$INSTALLDIR/share/proj -initial-env PHP_FCGI_MAX_REQUESTS=500 -initial-env PHP_FCGI_CHILDREN=1
+END-OF-CONFIGURATION
+popd
+# Create symlink for FastCGI agent.
+mkdir -p $INSTALLWEB/www/mapagent
+mkdir $INSTALLWEB/bin
+pushd $INSTALLWEB/www/mapagent
+ln -s ../../bin/mapagent mapagent.fcgi
+popd
+# Php install procedure
+# Notes: none
+echo Php install started
+pushd ../php
+make install
+check_php_install
+popd
+echo Php install completed
+# Tomcat connector build/install procedure
+# Notes: none
+echo Tomcat connector build/install started
+pushd jakarta-tomcat-connectors-1.2.15-src/jk/native
+./configure --with-apxs=$INSTALLWEB/apache2/bin/apxs
+check_tomcat_build
+make
+check_tomcat_build
+make install
+popd
+echo Tomcat connector build/install completed
+fi
+# Tomcat install procedure
+# Notes: none
+echo Tomcat install started
+tar -zxf apache-tomcat-5.5.12.tar.gz -C $INSTALLWEB
+pushd $INSTALLWEB
+mv apache-tomcat-5.5.12 tomcat
+popd
+echo Tomcat install completed
+fi
+# Configuration file updates for Apache
+# Notes: none
+echo Apache configuration started
+echo "" > tmpfile
+popd
+# Required modifications to httpd.conf, append to mapguide.conf
+cat >> mapguide.conf <<END-OF-CONFIGURATION
+# Environment variables for MapGuide
+SetEnv LD_LIBRARY_PATH "$INSTALLWEB/lib:$INSTALLWEB/php/lib:$INSTALLDIR/lib"
+SetEnv GDAL_DATA $INSTALLDIR/share/gdal
+SetEnv PROJ_LIB $INSTALLDIR/share/proj
+#Start PHP FastCGI config
+ScriptAlias /php/ "$INSTALLWEB/php/bin/"
+<Directory "$INSTALLWEB/php/bin/">
+ Options ExecCGI
+ SetHandler fastcgi-script
+</Directory>
+Action application/x-httpd-php5 "/php/php"
+AddType application/x-httpd-php5 .php
+#End PHP FastCGI Config
+#START NormalCGI PHP configuration
+#ScriptAlias /php/ "$INSTALLWEB/php/bin/"
+#Action application/x-httpd-php "/php/php"
+#AddType application/x-httpd-php .php
+#END NormalCGI PHP configuration
+# MapViewer to MapViewerPhp aliases
+ScriptAlias /mapguide/mapagent/mapagent.fcgi "$INSTALLWEB/www/mapagent/mapagent.fcgi"
+AliasMatch ^/mapguide/mapviewerajax/([^\?])(.*)$ "$INSTALLWEB/www/mapviewerphp/\$1\$2"
+AliasMatch ^/mapguide/mapviewerajax/(.*)$ "$INSTALLWEB/www/mapviewerphp/ajaxviewer.php\$1"
+AliasMatch ^/mapguide/mapviewerdwf/([^\?])(.*)$ "$INSTALLWEB/www/mapviewerphp/\$1\$2"
+AliasMatch ^/mapguide/mapviewerdwf/(.*)$ "$INSTALLWEB/www/mapviewerphp/dwfviewer.php\$1"
+Alias /mapguide "$INSTALLWEB/www/"
+<Directory "$INSTALLWEB/www/">
+ AllowOverride All
+ Options All
+ Order allow,deny
+ Allow from all
+# START FastCGI MapAgent config
+ AddHandler fastcgi-script fcgi
+# END FastCGI MapAgent config
+ RewriteEngine on
+ RewriteRule .* - [E=REMOTE_USER:%{HTTP:Authorization},L]
+</Directory>
+popd
+echo "Apache configuration completed"
+# Tomcat configuration procedure
+# Notes: none
+echo Tomcat configuration started
+#Tomcat Integration
+#Taken from http://tomcat.apache.org/connectors-doc/howto/quick.html
+# Load mod_jk module
+# Update this path to match your modules location
+LoadModule jk_module modules/mod_jk.so
+# Declare the module for <IfModule directive> (remove this line on Apache 2.x)
+# AddModule mod_jk.c
+# Where to find workers.properties
+# Update this path to match your conf directory location (put workers.properties next to httpd.conf)
+JkWorkersFile "$INSTALLWEB/apache2/conf/workers.properties"
+# Where to put jk logs
+# Update this path to match your logs directory location (put mod_jk.log next to access_log)
+JkLogFile "$INSTALLWEB/apache2/logs/mod_jk.log"
+# Set the jk log level [debug/error/info]
+JkLogLevel info
+# Select the log format
+JkLogStampFormat "[%a %b %d %H:%M:%S %Y] "
+# JkOptions indicate to send SSL KEY SIZE,
+JkOptions +ForwardKeySize +ForwardURICompat -ForwardDirectories
+# JkRequestLogFormat set the request format
+JkRequestLogFormat "%w %V %T"
+# Send everything for context /examples to worker named worker1 (ajp13)
+JkMount /mapguide/mapviewerjava/* worker1
+JkMount /mapguide/javaviewersample/* worker1
+cat > workers.properties <<END-OF-CONFIGURATION
+# Define 1 real worker using ajp13
+worker.list=worker1
+# Set properties for worker1 (ajp13)
+worker.worker1.type=ajp13
+worker.worker1.host=localhost
+worker.worker1.port=8009
+worker.worker1.lbfactor=50
+worker.worker1.cachesize=10
+worker.worker1.cache_timeout=600
+worker.worker1.socket_keepalive=1
+worker.worker1.recycle_timeout=300
+popd
+pushd $INSTALLWEB/tomcat/conf/Catalina/localhost
+cat > mapguide.xml <<END_OF_CONFIGURATION
+ Context configuration file for the Tomcat Manager Web App
+ $Id: manager.xml,v 1.3 2004/08/26 17:03:34 remm Exp $
+<Context docBase="$INSTALLWEB/www"
+ privileged="true" antiResourceLocking="false" antiJARLocking="false">
+ <!-- Link to the user database we will get roles from -->
+ <ResourceLink name="users" global="UserDatabase"
+ type="org.apache.catalina.UserDatabase"/>
+</Context>
+END_OF_CONFIGURATION
+popd
+mv -f $INSTALLWEB/tomcat/conf/server.xml $INSTALLWEB/tomcat/conf/server_orig.xml
+cp -f server.xml $INSTALLWEB/tomcat/conf
+echo Tomcat configuration completed
+fi
+# Configuration file updates for Php
+# Notes: none
+# Required modifications to php.ini
+# Uses php.ini-mapguide as a template and replaces the ext path
+# with the appropriate installdir path
+# Note: Custom built PHP will look in php/lib for ini file
+echo "Php configuration started"
+BACKINSTALL=${INSTALLWEB//\//\\\/}
+cat php.ini-mapguide | sed "s/INSTALLDIR/$BACKINSTALL\/lib/g" > $INSTALLWEB/php/lib/php.ini
+echo "Php configuration completed"
+echo "Adding test pages"
+mkdir $INSTALLWEB/www
+cat >> $INSTALLWEB/www/index.html <<ENDOFINDEX
+<html>
+<body>
+<p>If you are seeing this page then Apache Httpd has been successfully
+configured and installed for MapGuide.
+</body>
+</html>
+ENDOFINDEX
+cat >> $INSTALLWEB/www/phpinfo.php <<ENDOFINFO
+<?php
+phpinfo();
+ENDOFINFO
+echo "Installation complete."
+# Start Apache
+# Notes: none
+echo "Bringing Apache online..."
+./apachectl start
+popd
+echo "Apache is now online."
+# Tomcat startup procedure
+# Notes: none
+echo Tomcat startup
+pushd $INSTALLWEB/tomcat/bin
+export LD_LIBRARY_PATH=$INSTALLWEB/lib:$INSTALLDIR/lib:$LD_LIBRARY_PATH
+export JAVA_OPTS="-Djava.library.path=$LD_LIBRARY_PATH"
+./startup.sh
+popd
+echo Tomcat startup completed
+fi
Property changes on: trunk/MgDev/Oem/LinuxApt/build_apt.sh
+ native
Added: trunk/MgDev/Oem/LinuxApt/httpd-2.0.55.tar.gz
Property changes on: trunk/MgDev/Oem/LinuxApt/httpd-2.0.55.tar.gz
Added: trunk/MgDev/Oem/LinuxApt/jakarta-tomcat-connectors-1.2.15-src.tar.gz
Property changes on: trunk/MgDev/Oem/LinuxApt/jakarta-tomcat-connectors-1.2.15-src.tar.gz
Added: trunk/MgDev/Oem/LinuxApt/mod_fastcgi.tar.gz
Property changes on: trunk/MgDev/Oem/LinuxApt/mod_fastcgi.tar.gz
Added: trunk/MgDev/Oem/LinuxApt/php.ini-mapguide
--- trunk/MgDev/Oem/LinuxApt/php.ini-mapguide (rev 0)
+++ trunk/MgDev/Oem/LinuxApt/php.ini-mapguide 2007-03-23 20:57:03 UTC (rev 1360)
@@ -0,0 +1,1261 @@
+[PHP]
+; About php.ini ;
+; This file controls many aspects of PHP's behavior. In order for PHP to
+; read it, it must be named 'php.ini'. PHP looks for it in the current
+; working directory, in the path designated by the environment variable
+; PHPRC, and in the path that was defined in compile time (in that order).
+; Under Windows, the compile-time path is the Windows directory. The
+; path in which the php.ini file is looked for can be overridden using
+; the -c argument in command line mode.
+; The syntax of the file is extremely simple. Whitespace and Lines
+; beginning with a semicolon are silently ignored (as you probably guessed).
+; Section headers (e.g. [Foo]) are also silently ignored, even though
+; they might mean something in the future.
+; Directives are specified using the following syntax:
+; directive = value
+; Directive names are *case sensitive* - foo=bar is different from FOO=bar.
+; The value can be a string, a number, a PHP constant (e.g. E_ALL or M_PI), one
+; of the INI constants (On, Off, True, False, Yes, No and None) or an expression
+; (e.g. E_ALL & ~E_NOTICE), or a quoted string ("foo").
+; Expressions in the INI file are limited to bitwise operators and parentheses:
+; | bitwise OR
+; & bitwise AND
+; ~ bitwise NOT
+; ! boolean NOT
+; Boolean flags can be turned on using the values 1, On, True or Yes.
+; They can be turned off using the values 0, Off, False or No.
+; An empty string can be denoted by simply not writing anything after the equal
+; sign, or by using the None keyword:
+; foo = ; sets foo to an empty string
+; foo = none ; sets foo to an empty string
+; foo = "none" ; sets foo to the string 'none'
+; If you use constants in your value, and these constants belong to a
+; dynamically loaded extension (either a PHP extension or a Zend extension),
+; you may only use these constants *after* the line that loads the extension.
+; About this file ;
+; This is the recommended, PHP 5-style version of the php.ini-dist file. It
+; sets some non standard settings, that make PHP more efficient, more secure,
+; and encourage cleaner coding.
+; The price is that with these settings, PHP may be incompatible with some
+; applications, and sometimes, more difficult to develop with. Using this
+; file is warmly recommended for production sites. As all of the changes from
+; the standard settings are thoroughly documented, you can go over each one,
+; and decide whether you want to use it or not.
+; For general information about the php.ini file, please consult the php.ini-dist
+; file, included in your PHP distribution.
+; This file is different from the php.ini-dist file in the fact that it features
+; different values for several directives, in order to improve performance, while
+; possibly breaking compatibility with the standard out-of-the-box behavior of
+; PHP. Please make sure you read what's different, and modify your scripts
+; accordingly, if you decide to use this file instead.
+; - register_globals = Off [Security, Performance]
+; Global variables are no longer registered for input data (POST, GET, cookies,
+; environment and other server variables). Instead of using $foo, you must use
+; you can use $_REQUEST["foo"] (includes any variable that arrives through the
+; request, namely, POST, GET and cookie variables), or use one of the specific
+; $_GET["foo"], $_POST["foo"], $_COOKIE["foo"] or $_FILES["foo"], depending
+; on where the input originates. Also, you can look at the
+; import_request_variables() function.
+; Note that register_globals is going to be depracated (i.e., turned off by
+; default) in the next version of PHP, because it often leads to security bugs.
+; Read http://php.net/manual/en/security.registerglobals.php for further
+; information.
+; - register_long_arrays = Off [Performance]
+; Disables registration of the older (and deprecated) long predefined array
+; variables ($HTTP_*_VARS). Instead, use the superglobals that were
+; introduced in PHP 4.1.0
+; - display_errors = Off [Security]
+; With this directive set to off, errors that occur during the execution of
+; scripts will no longer be displayed as a part of the script output, and thus,
+; will no longer be exposed to remote users. With some errors, the error message
+; content may expose information about your script, web server, or database
+; server that may be exploitable for hacking. Production sites should have this
+; directive set to off.
+; - log_errors = On [Security]
+; This directive complements the above one. Any errors that occur during the
+; execution of your script will be logged (typically, to your server's error log,
+; but can be configured in several ways). Along with setting display_errors to off,
+; this setup gives you the ability to fully understand what may have gone wrong,
+; without exposing any sensitive information to remote users.
+; - output_buffering = 4096 [Performance]
+; Set a 4KB output buffer. Enabling output buffering typically results in less
+; writes, and sometimes less packets sent on the wire, which can often lead to
+; better performance. The gain this directive actually yields greatly depends
+; on which Web server you're working with, and what kind of scripts you're using.
+; - register_argc_argv = Off [Performance]
+; Disables registration of the somewhat redundant $argv and $argc global
+; variables.
+; - magic_quotes_gpc = Off [Performance]
+; Input data is no longer escaped with slashes so that it can be sent into
+; SQL databases without further manipulation. Instead, you should use the
+; function addslashes() on each input element you wish to send to a database.
+; - variables_order = "GPCS" [Performance]
+; The environment variables are not hashed into the $_ENV. To access
+; environment variables, you can use getenv() instead.
+; - error_reporting = E_ALL [Code Cleanliness, Security(?)]
+; By default, PHP surpresses errors of type E_NOTICE. These error messages
+; are emitted for non-critical errors, but that could be a symptom of a bigger
+; problem. Most notably, this will cause error messages about the use
+; of uninitialized variables to be displayed.
+; - allow_call_time_pass_reference = Off [Code cleanliness]
+; It's not possible to decide to force a variable to be passed by reference
+; when calling a function. The PHP 4 style to do this is by making the
+; function require the relevant argument by reference.
+; Language Options ;
+; Enable the PHP scripting language engine under Apache.
+engine = On
+; Enable compatibility mode with Zend Engine 1 (PHP 4.x)
+zend.ze1_compatibility_mode = Off
+; Allow the <? tag. Otherwise, only <?php and <script> tags are recognized.
+; NOTE: Using short tags should be avoided when developing applications or
+; libraries that are meant for redistribution, or deployment on PHP
+; servers which are not under your control, because short tags may not
+; be supported on the target server. For portable, redistributable code,
+; be sure not to use short tags.
+short_open_tag = On
+; Allow ASP-style <% %> tags.
+asp_tags = Off
+; The number of significant digits displayed in floating point numbers.
+precision = 14
+; Enforce year 2000 compliance (will cause problems with non-compliant browsers)
+y2k_compliance = On
+; Output buffering allows you to send header lines (including cookies) even
+; after you send body content, at the price of slowing PHP's output layer a
+; bit. You can enable output buffering during runtime by calling the output
+; buffering functions. You can also enable output buffering for all files by
+; setting this directive to On. If you wish to limit the size of the buffer
+; to a certain size - you can use a maximum number of bytes instead of 'On', as
+; a value for this directive (e.g., output_buffering=4096).
+output_buffering = 4096
+; You can redirect all of the output of your scripts to a function. For
+; example, if you set output_handler to "mb_output_handler", character
+; encoding will be transparently converted to the specified encoding.
+; Setting any output handler automatically turns on output buffering.
+; Note: People who wrote portable scripts should not depend on this ini
+; directive. Instead, explicitly set the output handler using ob_start().
+; Using this ini directive may cause problems unless you know what script
+; is doing.
+; Note: You cannot use both "mb_output_handler" with "ob_iconv_handler"
+; and you cannot use both "ob_gzhandler" and "zlib.output_compression".
+; Note: output_handler must be empty if this is set 'On' !!!!
+; Instead you must use zlib.output_handler.
+;output_handler =
+; Transparent output compression using the zlib library
+; Valid values for this option are 'off', 'on', or a specific buffer size
+; to be used for compression (default is 4KB)
+; Note: Resulting chunk size may vary due to nature of compression. PHP
+; outputs chunks that are few hundreds bytes each as a result of
+; compression. If you prefer a larger chunk size for better
+; performance, enable output_buffering in addition.
+; Note: You need to use zlib.output_handler instead of the standard
+; output_handler, or otherwise the output will be corrupted.
+zlib.output_compression = Off
+; You cannot specify additional output handlers if zlib.output_compression
+; is activated here. This setting does the same as output_handler but in
+; a different order.
+;zlib.output_handler =
+; Implicit flush tells PHP to tell the output layer to flush itself
+; automatically after every output block. This is equivalent to calling the
+; PHP function flush() after each and every call to print() or echo() and each
+; and every HTML block. Turning this option on has serious performance
+; implications and is generally recommended for debugging purposes only.
+implicit_flush = Off
+; The unserialize callback function will be called (with the undefined class'
+; name as parameter), if the unserializer finds an undefined class
+; which should be instanciated.
+; A warning appears if the specified function is not defined, or if the
+; function doesn't include/implement the missing class.
+; So only set this entry, if you really want to implement such a
+; callback-function.
+unserialize_callback_func=
+; When floats & doubles are serialized store serialize_precision significant
+; digits after the floating point. The default value ensures that when floats
+; are decoded with unserialize, the data will remain the same.
+serialize_precision = 100
+; Whether to enable the ability to force arguments to be passed by reference
+; at function call time. This method is deprecated and is likely to be
+; unsupported in future versions of PHP/Zend. The encouraged method of
+; specifying which arguments should be passed by reference is in the function
+; declaration. You're encouraged to try and turn this option Off and make
+; sure your scripts work properly with it in order to ensure they will work
+; with future versions of the language (you will receive a warning each time
+; you use this feature, and the argument will be passed by value instead of by
+; reference).
+allow_call_time_pass_reference = Off
+; Safe Mode
+safe_mode = Off
+; By default, Safe Mode does a UID compare check when
+; opening files. If you want to relax this to a GID compare,
+; then turn on safe_mode_gid.
+safe_mode_gid = Off
+; When safe_mode is on, UID/GID checks are bypassed when
+; including files from this directory and its subdirectories.
+; (directory must also be in include_path or full path must
+; be used when including)
+safe_mode_include_dir =
+; When safe_mode is on, only executables located in the safe_mode_exec_dir
+; will be allowed to be executed via the exec family of functions.
+safe_mode_exec_dir =
+; Setting certain environment variables may be a potential security breach.
+; This directive contains a comma-delimited list of prefixes. In Safe Mode,
+; the user may only alter environment variables whose names begin with the
+; prefixes supplied here. By default, users will only be able to set
+; environment variables that begin with PHP_ (e.g. PHP_FOO=BAR).
+; Note: If this directive is empty, PHP will let the user modify ANY
+; environment variable!
+safe_mode_allowed_env_vars = PHP_
+; This directive contains a comma-delimited list of environment variables that
+; the end user won't be able to change using putenv(). These variables will be
+; protected even if safe_mode_allowed_env_vars is set to allow to change them.
+safe_mode_protected_env_vars = LD_LIBRARY_PATH
+; open_basedir, if set, limits all file operations to the defined directory
+; and below. This directive makes most sense if used in a per-directory
+; or per-virtualhost web server configuration file. This directive is
+; *NOT* affected by whether Safe Mode is turned On or Off.
+;open_basedir =
+; This directive allows you to disable certain functions for security reasons.
+; It receives a comma-delimited list of function names. This directive is
+disable_functions =
+; This directive allows you to disable certain classes for security reasons.
+; It receives a comma-delimited list of class names. This directive is
+disable_classes =
+; Colors for Syntax Highlighting mode. Anything that's acceptable in
+; <span style="color: ???????"> would work.
+;highlight.string = #DD0000
+;highlight.comment = #FF9900
+;highlight.keyword = #007700
+;highlight.bg = #FFFFFF
+;highlight.default = #0000BB
+;highlight.html = #000000
+; Misc
+; Decides whether PHP may expose the fact that it is installed on the server
+; (e.g. by adding its signature to the Web server header). It is no security
+; threat in any way, but it makes it possible to determine whether you use PHP
+; on your server or not.
+expose_php = On
+; Resource Limits ;
+max_execution_time = 60 ; Maximum execution time of each script, in seconds
+max_input_time = 60 ; Maximum amount of time each script may spend parsing request data
+memory_limit = 32M ; Maximum amount of memory a script may consume (8MB)
+; Error handling and logging ;
+; error_reporting is a bit-field. Or each number up to get desired error
+; reporting level
+; E_ALL - All errors and warnings (doesn't include E_STRICT)
+; E_ERROR - fatal run-time errors
+; E_WARNING - run-time warnings (non-fatal errors)
+; E_PARSE - compile-time parse errors
+; E_NOTICE - run-time notices (these are warnings which often result
+; from a bug in your code, but it's possible that it was
+; intentional (e.g., using an uninitialized variable and
+; relying on the fact it's automatically initialized to an
+; empty string)
+; E_STRICT - run-time notices, enable to have PHP suggest changes
+; to your code which will ensure the best interoperability
+; and forward compatibility of your code
+; E_CORE_ERROR - fatal errors that occur during PHP's initial startup
+; E_CORE_WARNING - warnings (non-fatal errors) that occur during PHP's
+; initial startup
+; E_COMPILE_ERROR - fatal compile-time errors
+; E_COMPILE_WARNING - compile-time warnings (non-fatal errors)
+; E_USER_ERROR - user-generated error message
+; E_USER_WARNING - user-generated warning message
+; E_USER_NOTICE - user-generated notice message
+; Examples:
+; - Show all errors, except for notices and coding standards warnings
+;error_reporting = E_ALL & ~E_NOTICE & ~E_STRICT
+; - Show only errors
+;error_reporting = E_COMPILE_ERROR|E_ERROR|E_CORE_ERROR
+error_reporting = E_ALL
+; Print out errors (as a part of the output). For production web sites,
+; you're strongly encouraged to turn this feature off, and use error logging
+; instead (see below). Keeping display_errors enabled on a production web site
+; may reveal security information to end users, such as file paths on your Web
+; server, your database schema or other information.
+display_errors = Off
+; Even when display_errors is on, errors that occur during PHP's startup
+; sequence are not displayed. It's strongly recommended to keep
+; display_startup_errors off, except for when debugging.
+display_startup_errors = Off
+; Log errors into a log file (server-specific log, stderr, or error_log (below))
+; As stated above, you're strongly advised to use error logging in place of
+; error displaying on production web sites.
+log_errors = On
+; Set maximum length of log_errors. In error_log information about the source is
+; added. The default is 1024 and 0 allows to not apply any maximum length at all.
+log_errors_max_len = 1024
+; Do not log repeated messages. Repeated errors must occur in same file on same
+; line until ignore_repeated_source is set true.
+ignore_repeated_errors = Off
+; Ignore source of message when ignoring repeated messages. When this setting
+; is On you will not log errors with repeated messages from different files or
+; sourcelines.
+ignore_repeated_source = Off
+; If this parameter is set to Off, then memory leaks will not be shown (on
+; stdout or in the log). This has only effect in a debug compile, and if
+; error reporting includes E_WARNING in the allowed list
+report_memleaks = On
+; Store the last error/warning message in $php_errormsg (boolean).
+track_errors = Off
+; Disable the inclusion of HTML tags in error messages.
+; Note: Never use this feature for production boxes.
+;html_errors = Off
+; If html_errors is set On PHP produces clickable error messages that direct
+; to a page describing the error or function causing the error in detail.
+; You can download a copy of the PHP manual from http://www.php.net/docs.php
+; and change docref_root to the base URL of your local copy including the
+; leading '/'. You must also specify the file extension being used including
+; the dot.
+;docref_root = "/phpmanual/"
+;docref_ext = .html
+; String to output before an error message.
+;error_prepend_string = "<font color=ff0000>"
+; String to output after an error message.
+;error_append_string = "</font>"
+; Log errors to specified file.
+;error_log = filename
+; Log errors to syslog (Event Log on NT, not valid in Windows 95).
+;error_log = syslog
+; Data Handling ;
+; Note - track_vars is ALWAYS enabled as of PHP 4.0.3
+; The separator used in PHP generated URLs to separate arguments.
+; Default is "&".
+;arg_separator.output = "&"
+; List of separator(s) used by PHP to parse input URLs into variables.
+; Default is "&".
+; NOTE: Every character in this directive is considered as separator!
+;arg_separator.input = ";&"
+; This directive describes the order in which PHP registers GET, POST, Cookie,
+; Environment and Built-in variables (G, P, C, E & S respectively, often
+; referred to as EGPCS or GPC). Registration is done from left to right, newer
+; values override older values.
+variables_order = "GPCS"
+; Whether or not to register the EGPCS variables as global variables. You may
+; want to turn this off if you don't want to clutter your scripts' global scope
+; with user data. This makes most sense when coupled with track_vars - in which
+; case you can access all of the GPC variables through the $HTTP_*_VARS[],
+; variables.
+; You should do your best to write your scripts so that they do not require
+; register_globals to be on; Using form variables as globals can easily lead
+; to possible security problems, if the code is not very well thought of.
+register_globals = Off
+; Whether or not to register the old-style input arrays, HTTP_GET_VARS
+; and friends. If you're not using them, it's recommended to turn them off,
+; for performance reasons.
+register_long_arrays = Off
+; This directive tells PHP whether to declare the argv&argc variables (that
+; would contain the GET information). If you don't use these variables, you
+; should turn it off for increased performance.
+register_argc_argv = Off
+; When enabled, the SERVER and ENV variables are created when they're first
+; used (Just In Time) instead of when the script starts. If these variables
+; are not used within a script, having this directive on will result in a
+; performance gain. The PHP directives register_globals, register_long_arrays,
+; and register_argc_argv must be disabled for this directive to have any affect.
+auto_globals_jit = On
+; Maximum size of POST data that PHP will accept.
+post_max_size = 32M
+; Magic quotes
+; Magic quotes for incoming GET/POST/Cookie data.
+magic_quotes_gpc = Off
+; Magic quotes for runtime-generated data, e.g. data from SQL, from exec(), etc.
+magic_quotes_runtime = Off
+; Use Sybase-style magic quotes (escape ' with '' instead of \').
+magic_quotes_sybase = Off
+; Automatically add files before or after any PHP document.
+auto_prepend_file =
+auto_append_file =
+; As of 4.0b4, PHP always outputs a character encoding by default in
+; the Content-type: header. To disable sending of the charset, simply
+; set it to be empty.
+; PHP's built-in default is text/html
+default_mimetype = "text/html"
+;default_charset = "iso-8859-1"
+; Always populate the $HTTP_RAW_POST_DATA variable.
+;always_populate_raw_post_data = On
+; Paths and Directories ;
+; UNIX: "/path1:/path2"
+;include_path = ".:/php/includes"
+; Windows: "\path1;\path2"
+;include_path = ".;c:\php\includes"
+; The root of the PHP pages, used only if nonempty.
+; if PHP was not compiled with FORCE_REDIRECT, you SHOULD set doc_root
+; if you are running php as a CGI under any web server (other than IIS)
+; see documentation for security issues. The alternate is to use the
+; cgi.force_redirect configuration below
+doc_root =
+; The directory under which PHP opens the script using /~username used only
+; if nonempty.
+user_dir =
+; Directory in which the loadable extensions (modules) reside.
+extension_dir = "INSTALLDIR"
+; Whether or not to enable the dl() function. The dl() function does NOT work
+; properly in multithreaded servers, such as IIS or Zeus, and is automatically
+; disabled on them.
+enable_dl = On
+; cgi.force_redirect is necessary to provide security running PHP as a CGI under
+; most web servers. Left undefined, PHP turns this on by default. You can
+; turn it off here AT YOUR OWN RISK
+; **You CAN safely turn this off for IIS, in fact, you MUST.**
+; cgi.force_redirect = 1
+; if cgi.nph is enabled it will force cgi to always sent Status: 200 with
+; every request.
+; cgi.nph = 1
+; if cgi.force_redirect is turned on, and you are not running under Apache or Netscape
+; (iPlanet) web servers, you MAY need to set an environment variable name that PHP
+; will look for to know it is OK to continue execution. Setting this variable MAY
+; cause security issues, KNOW WHAT YOU ARE DOING FIRST.
+; cgi.redirect_status_env = ;
+; FastCGI under IIS (on WINNT based OS) supports the ability to impersonate
+; security tokens of the calling client. This allows IIS to define the
+; security context that the request runs under. mod_fastcgi under Apache
+; does not currently support this feature (03/17/2002)
+; Set to 1 if running under IIS. Default is zero.
+; fastcgi.impersonate = 1;
+; Disable logging through FastCGI connection
+; fastcgi.log = 0
+; cgi.rfc2616_headers configuration option tells PHP what type of headers to
+; use when sending HTTP response code. If it's set 0 PHP sends Status: header that
+; is supported by Apache. When this option is set to 1 PHP will send
+; RFC2616 compliant header.
+; Default is zero.
+;cgi.rfc2616_headers = 0
+; File Uploads ;
+; Whether to allow HTTP file uploads.
+file_uploads = On
+; Temporary directory for HTTP uploaded files (will use system default if not
+; specified).
+;upload_tmp_dir =
+; Maximum allowed size for uploaded files.
+upload_max_filesize = 2M
+; Fopen wrappers ;
+; Whether to allow the treatment of URLs (like http:// or ftp://) as files.
+allow_url_fopen = On
+; Define the anonymous ftp password (your email address)
+;from="john at doe.com"
+; Define the User-Agent string
+; user_agent="PHP"
+; Default timeout for socket based streams (seconds)
+default_socket_timeout = 60
+; If your scripts have to deal with files from Macintosh systems,
+; or you are running on a Mac and need to deal with files from
+; unix or win32 systems, setting this flag will cause PHP to
+; automatically detect the EOL character in those files so that
+; fgets() and file() will work regardless of the source of the file.
+; auto_detect_line_endings = Off
+; Dynamic Extensions ;
+; If you wish to have an extension loaded automatically, use the following
+; syntax:
+; extension=modulename.extension
+; For example, on Windows:
+; extension=msql.dll
+; ... or under UNIX:
+; extension=msql.so
+; Note that it should be the name of the module only; no directory information
+; needs to go here. Specify the location of the extension with the
+; extension_dir directive above.
+;Windows Extensions
+;Note that ODBC support is built in, so no dll is needed for it.
+;extension=php_mbstring.dll
+;extension=php_bz2.dll
+;extension=php_cpdf.dll
+;extension=php_curl.dll
+;extension=php_dba.dll
+;extension=php_dbase.dll
+;extension=php_dbx.dll
+;extension=php_exif.dll
+;extension=php_fdf.dll
+;extension=php_filepro.dll
+;extension=php_gd2.dll
+;extension=php_gettext.dll
+;extension=php_ifx.dll
+;extension=php_iisfunc.dll
+;extension=php_imap.dll
+;extension=php_interbase.dll
+;extension=php_java.dll
+;extension=php_ldap.dll
+;extension=php_mcrypt.dll
+;extension=php_mhash.dll
+;extension=php_mime_magic.dll
+;extension=php_ming.dll
+;extension=php_mssql.dll
+;extension=php_msql.dll
+;extension=php_mysql.dll
+;extension=php_oci8.dll
+;extension=php_openssl.dll
+;extension=php_oracle.dll
+;extension=php_pdf.dll
+;extension=php_pgsql.dll
+;extension=php_shmop.dll
+;extension=php_snmp.dll
+;extension=php_sockets.dll
+;extension=php_sybase_ct.dll
+;extension=php_tidy.dll
+;extension=php_w32api.dll
+;extension=php_xmlrpc.dll
+;extension=php_xsl.dll
+;extension=php_yaz.dll
+;extension=php_zip.dll
+extension=libphp_MapGuideApi.so
+; Module Settings ;
+[Syslog]
+; Whether or not to define the various syslog variables (e.g. $LOG_PID,
+; $LOG_CRON, etc.). Turning it off is a good idea performance-wise. In
+; runtime, you can define these variables by calling define_syslog_variables().
+define_syslog_variables = Off
+[mail function]
+; For Win32 only.
+SMTP = localhost
+smtp_port = 25
+; For Win32 only.
+;sendmail_from = me at example.com
+; For Unix only. You may supply arguments as well (default: "sendmail -t -i").
+;sendmail_path =
+; Force the addition of the specified parameters to be passed as extra parameters
+; to the sendmail binary. These parameters will always replace the value of
+; the 5th parameter to mail(), even in safe mode.
+;mail.force_extra_parameters =
+[SQL]
+sql.safe_mode = Off
+[ODBC]
+;odbc.default_db = Not yet implemented
+;odbc.default_user = Not yet implemented
+;odbc.default_pw = Not yet implemented
+; Allow or prevent persistent links.
+odbc.allow_persistent = On
+; Check that a connection is still valid before reuse.
+odbc.check_persistent = On
+; Maximum number of persistent links. -1 means no limit.
+odbc.max_persistent = -1
+; Maximum number of links (persistent + non-persistent). -1 means no limit.
+odbc.max_links = -1
+; Handling of LONG fields. Returns number of bytes to variables. 0 means
+; passthru.
+odbc.defaultlrl = 4096
+; Handling of binary data. 0 means passthru, 1 return as is, 2 convert to char.
+; See the documentation on odbc_binmode and odbc_longreadlen for an explanation
+; of uodbc.defaultlrl and uodbc.defaultbinmode
+odbc.defaultbinmode = 1
+[MySQL]
+mysql.allow_persistent = On
+mysql.max_persistent = -1
+mysql.max_links = -1
+; Default port number for mysql_connect(). If unset, mysql_connect() will use
+; the $MYSQL_TCP_PORT or the mysql-tcp entry in /etc/services or the
+; compile-time value defined MYSQL_PORT (in that order). Win32 will only look
+; at MYSQL_PORT.
+mysql.default_port =
+; Default socket name for local MySQL connects. If empty, uses the built-in
+; MySQL defaults.
+mysql.default_socket =
+; Default host for mysql_connect() (doesn't apply in safe mode).
+mysql.default_host =
+; Default user for mysql_connect() (doesn't apply in safe mode).
+mysql.default_user =
+; Default password for mysql_connect() (doesn't apply in safe mode).
+; Note that this is generally a *bad* idea to store passwords in this file.
+; *Any* user with PHP access can run 'echo get_cfg_var("mysql.default_password")
+; and reveal this password! And of course, any users with read access to this
+; file will be able to reveal the password as well.
+mysql.default_password =
+; Maximum time (in secondes) for connect timeout. -1 means no limit
+mysql.connect_timeout = 60
+; Trace mode. When trace_mode is active (=On), warnings for table/index scans and
+; SQL-Errors will be displayed.
+mysql.trace_mode = Off
+[MySQLI]
+; Maximum number of links. -1 means no limit.
+mysqli.max_links = -1
+; Default port number for mysqli_connect(). If unset, mysqli_connect() will use
+; at MYSQL_PORT.
+mysqli.default_port = 3306
+; MySQL defaults.
+mysqli.default_socket =
+mysqli.default_host =
+mysqli.default_user =
+; Default password for mysqli_connect() (doesn't apply in safe mode).
+; *Any* user with PHP access can run 'echo get_cfg_var("mysqli.default_pw")
+mysqli.default_pw =
+; Allow or prevent reconnect
+mysqli.reconnect = Off
+[mSQL]
+msql.allow_persistent = On
+msql.max_persistent = -1
+; Maximum number of links (persistent+non persistent). -1 means no limit.
+msql.max_links = -1
+[PostgresSQL]
+pgsql.allow_persistent = On
+; Detect broken persistent links always with pg_pconnect().
+; Auto reset feature requires a little overheads.
+pgsql.auto_reset_persistent = Off
+pgsql.max_persistent = -1
+pgsql.max_links = -1
+; Ignore PostgreSQL backends Notice message or not.
+; Notice message logging require a little overheads.
+pgsql.ignore_notice = 0
+; Log PostgreSQL backends Noitce message or not.
+; Unless pgsql.ignore_notice=0, module cannot log notice message.
+pgsql.log_notice = 0
+[Sybase]
+sybase.allow_persistent = On
+sybase.max_persistent = -1
+sybase.max_links = -1
+;sybase.interface_file = "/usr/sybase/interfaces"
+; Minimum error severity to display.
+sybase.min_error_severity = 10
+; Minimum message severity to display.
+sybase.min_message_severity = 10
+; Compatability mode with old versions of PHP 3.0.
+; If on, this will cause PHP to automatically assign types to results according
+; to their Sybase type, instead of treating them all as strings. This
+; compatability mode will probably not stay around forever, so try applying
+; whatever necessary changes to your code, and turn it off.
+sybase.compatability_mode = Off
+[Sybase-CT]
+sybct.allow_persistent = On
+sybct.max_persistent = -1
+sybct.max_links = -1
+; Minimum server message severity to display.
+sybct.min_server_severity = 10
+; Minimum client message severity to display.
+sybct.min_client_severity = 10
+[dbx]
+; returned column names can be converted for compatibility reasons
+; possible values for dbx.colnames_case are
+; "unchanged" (default, if not set)
+; "lowercase"
+; "uppercase"
+; the recommended default is either upper- or lowercase, but
+; unchanged is currently set for backwards compatibility
+dbx.colnames_case = "lowercase"
+[bcmath]
+; Number of decimal digits for all bcmath functions.
+bcmath.scale = 0
+[browscap]
+;browscap = extra/browscap.ini
+[Informix]
+; Default host for ifx_connect() (doesn't apply in safe mode).
+ifx.default_host =
+; Default user for ifx_connect() (doesn't apply in safe mode).
+ifx.default_user =
+; Default password for ifx_connect() (doesn't apply in safe mode).
+ifx.default_password =
+ifx.allow_persistent = On
+ifx.max_persistent = -1
+ifx.max_links = -1
+; If on, select statements return the contents of a text blob instead of its id.
+ifx.textasvarchar = 0
+; If on, select statements return the contents of a byte blob instead of its id.
+ifx.byteasvarchar = 0
+; Trailing blanks are stripped from fixed-length char columns. May help the
+; life of Informix SE users.
+ifx.charasvarchar = 0
+; If on, the contents of text and byte blobs are dumped to a file instead of
+; keeping them in memory.
+ifx.blobinfile = 0
+; NULL's are returned as empty strings, unless this is set to 1. In that case,
+; NULL's are returned as string 'NULL'.
+ifx.nullformat = 0
+[Session]
+; Handler used to store/retrieve data.
+session.save_handler = files
+; Argument passed to save_handler. In the case of files, this is the path
+; where data files are stored. Note: Windows users have to change this
+; variable in order to use PHP's session functions.
+; As of PHP 4.0.1, you can define the path as:
+; session.save_path = "N;/path"
+; where N is an integer. Instead of storing all the session files in
+; /path, what this will do is use subdirectories N-levels deep, and
+; store the session data in those directories. This is useful if you
+; or your OS have problems with lots of files in one directory, and is
+; a more efficient layout for servers that handle lots of sessions.
+; NOTE 1: PHP will not create this directory structure automatically.
+; You can use the script in the ext/session dir for that purpose.
+; NOTE 2: See the section on garbage collection below if you choose to
+; use subdirectories for session storage
+; The file storage module creates files using mode 600 by default.
+; You can change that by using
+; session.save_path = "N;MODE;/path"
+; where MODE is the octal representation of the mode. Note that this
+; does not overwrite the process's umask.
+;session.save_path = "/tmp"
+; Whether to use cookies.
+session.use_cookies = 1
+; This option enables administrators to make their users invulnerable to
+; attacks which involve passing session ids in URLs; defaults to 0.
+; session.use_only_cookies = 1
+; Name of the session (used as cookie name).
+session.name = PHPSESSID
+; Initialize session on request startup.
+session.auto_start = 0
+; Lifetime in seconds of cookie or, if 0, until browser is restarted.
+session.cookie_lifetime = 0
+; The path for which the cookie is valid.
+session.cookie_path = /
+; The domain for which the cookie is valid.
+session.cookie_domain =
+; Handler used to serialize data. php is the standard serializer of PHP.
+session.serialize_handler = php
+; Define the probability that the 'garbage collection' process is started
+; on every session initialization.
+; The probability is calculated by using gc_probability/gc_divisor,
+; e.g. 1/100 means there is a 1% chance that the GC process starts
+; on each request.
+session.gc_probability = 1
+session.gc_divisor = 1000
+; After this number of seconds, stored data will be seen as 'garbage' and
+; cleaned up by the garbage collection process.
+session.gc_maxlifetime = 1440
+; NOTE: If you are using the subdirectory option for storing session files
+; (see session.save_path above), then garbage collection does *not*
+; happen automatically. You will need to do your own garbage
+; collection through a shell script, cron entry, or some other method.
+; For example, the following script would is the equivalent of
+; setting session.gc_maxlifetime to 1440 (1440 seconds = 24 minutes):
+; cd /path/to/sessions; find -cmin +24 | xargs rm
+; PHP 4.2 and less have an undocumented feature/bug that allows you to
+; to initialize a session variable in the global scope, albeit register_globals
+; is disabled. PHP 4.3 and later will warn you, if this feature is used.
+; You can disable the feature and the warning separately. At this time,
+; the warning is only displayed, if bug_compat_42 is enabled.
+session.bug_compat_42 = 0
+session.bug_compat_warn = 1
+; Check HTTP Referer to invalidate externally stored URLs containing ids.
+; HTTP_REFERER has to contain this substring for the session to be
+; considered as valid.
+session.referer_check =
+; How many bytes to read from the file.
+session.entropy_length = 0
+; Specified here to create the session id.
+session.entropy_file =
+;session.entropy_length = 16
+;session.entropy_file = /dev/urandom
+; Set to {nocache,private,public,} to determine HTTP caching aspects
+; or leave this empty to avoid sending anti-caching headers.
+session.cache_limiter = nocache
+; Document expires after n minutes.
+session.cache_expire = 180
+; trans sid support is disabled by default.
+; Use of trans sid may risk your users security.
+; Use this option with caution.
+; - User may send URL contains active session ID
+; to other person via. email/irc/etc.
+; - URL that contains active session ID may be stored
+; in publically accessible computer.
+; - User may access your site with the same session ID
+; always using URL stored in browser's history or bookmarks.
+session.use_trans_sid = 0
+; Select a hash function
+; 0: MD5 (128 bits)
+; 1: SHA-1 (160 bits)
+session.hash_function = 0
+; Define how many bits are stored in each character when converting
+; the binary hash data to something readable.
+; 4 bits: 0-9, a-f
+; 5 bits: 0-9, a-v
+; 6 bits: 0-9, a-z, A-Z, "-", ","
+session.hash_bits_per_character = 5
+; The URL rewriter will look for URLs in a defined set of HTML tags.
+; form/fieldset are special; if you include them here, the rewriter will
+; add a hidden <input> field with the info which is otherwise appended
+; to URLs. If you want XHTML conformity, remove the form entry.
+; Note that all valid entries require a "=", even if no value follows.
+url_rewriter.tags = "a=href,area=href,frame=src,input=src,form=fakeentry"
+[MSSQL]
+mssql.allow_persistent = On
+mssql.max_persistent = -1
+mssql.max_links = -1
+mssql.min_error_severity = 10
+mssql.min_message_severity = 10
+mssql.compatability_mode = Off
+; Connect timeout
+;mssql.connect_timeout = 5
+; Query timeout
+;mssql.timeout = 60
+; Valid range 0 - 2147483647. Default = 4096.
+;mssql.textlimit = 4096
+;mssql.textsize = 4096
+; Limits the number of records in each batch. 0 = all records in one batch.
+;mssql.batchsize = 0
+; Specify how datetime and datetim4 columns are returned
+; On => Returns data converted to SQL server settings
+; Off => Returns values as YYYY-MM-DD hh:mm:ss
+;mssql.datetimeconvert = On
+; Use NT authentication when connecting to the server
+mssql.secure_connection = Off
+; Specify max number of processes. Default = 25
+;mssql.max_procs = 25
+[Assertion]
+; Assert(expr); active by default.
+;assert.active = On
+; Issue a PHP warning for each failed assertion.
+;assert.warning = On
+; Don't bail out by default.
+;assert.bail = Off
+; User-function to be called if an assertion fails.
+;assert.callback = 0
+; Eval the expression with current error_reporting(). Set to true if you want
+; error_reporting(0) around the eval().
+;assert.quiet_eval = 0
+[Ingres II]
+ingres.allow_persistent = On
+ingres.max_persistent = -1
+; Maximum number of links, including persistents. -1 means no limit.
+ingres.max_links = -1
+; Default database (format: [node_id::]dbname[/srv_class]).
+ingres.default_database =
+; Default user.
+ingres.default_user =
+; Default password.
+ingres.default_password =
+[Verisign Payflow Pro]
+; Default Payflow Pro server.
+pfpro.defaulthost = "test-payflow.verisign.com"
+; Default port to connect to.
+pfpro.defaultport = 443
+; Default timeout in seconds.
+pfpro.defaulttimeout = 30
+; Default proxy IP address (if required).
+;pfpro.proxyaddress =
+; Default proxy port.
+;pfpro.proxyport =
+; Default proxy logon.
+;pfpro.proxylogon =
+; Default proxy password.
+;pfpro.proxypassword =
+[com]
+; path to a file containing GUIDs, IIDs or filenames of files with TypeLibs
+;com.typelib_file =
+; allow Distributed-COM calls
+;com.allow_dcom = true
+; autoregister constants of a components typlib on com_load()
+;com.autoregister_typelib = true
+; register constants casesensitive
+;com.autoregister_casesensitive = false
+; show warnings on duplicate constat registrations
+;com.autoregister_verbose = true
+[mbstring]
+; language for internal character representation.
+mbstring.language = UTF-8
+; internal/script encoding.
+; Some encoding cannot work as internal encoding.
+; (e.g. SJIS, BIG5, ISO-2022-*)
+mbstring.internal_encoding = UTF-8
+; http input encoding.
+mbstring.http_input = UTF-8
+; http output encoding. mb_output_handler must be
+; registered as output buffer to function
+;mbstring.http_output = SJIS
+; enable automatic encoding translation accoding to
+; mbstring.internal_encoding setting. Input chars are
+; converted to internal encoding by setting this to On.
+; Note: Do _not_ use automatic encoding translation for
+; portable libs/applications.
+mbstring.encoding_translation = Off
+; automatic encoding detection order.
+; auto means
+mbstring.detect_order = UTF-8
+; substitute_character used when character cannot be converted
+; one from another
+;mbstring.substitute_character = none;
+; overload(replace) single byte functions by mbstring functions.
+; mail(), ereg(), etc are overloaded by mb_send_mail(), mb_ereg(),
+; etc. Possible values are 0,1,2,4 or combination of them.
+; For example, 7 for overload everything.
+; 0: No overload
+; 1: Overload mail() function
+; 2: Overload str*() functions
+; 4: Overload ereg*() functions
+;mbstring.func_overload = 0
+[FrontBase]
+;fbsql.allow_persistent = On
+;fbsql.autocommit = On
+;fbsql.default_database =
+;fbsql.default_database_password =
+;fbsql.default_host =
+;fbsql.default_password =
+;fbsql.default_user = "_SYSTEM"
+;fbsql.generate_warnings = Off
+;fbsql.max_connections = 128
+;fbsql.max_links = 128
+;fbsql.max_persistent = -1
+;fbsql.max_results = 128
+;fbsql.batchSize = 1000
+[exif]
+; Exif UNICODE user comments are handled as UCS-2BE/UCS-2LE and JIS as JIS.
+; With mbstring support this will automatically be converted into the encoding
+; given by corresponding encode setting. When empty mbstring.internal_encoding
+; is used. For the decode settings you can distinguish between motorola and
+; intel byte order. A decode setting cannot be empty.
+;exif.encode_unicode = ISO-8859-15
+;exif.decode_unicode_motorola = UCS-2BE
+;exif.decode_unicode_intel = UCS-2LE
+;exif.encode_jis =
+;exif.decode_jis_motorola = JIS
+;exif.decode_jis_intel = JIS
+[Tidy]
+; The path to a default tidy configuration file to use when using tidy
+;tidy.default_config = /usr/local/lib/php/default.tcfg
+; Should tidy clean and repair output automatically?
+; WARNING: Do not use this option if you are generating non-html content
+; such as dynamic images
+tidy.clean_output = Off
+[soap]
+; Enables or disables WSDL caching feature.
+soap.wsdl_cache_enabled=1
+; Sets the directory name where SOAP extension will put cache files.
+soap.wsdl_cache_dir="/tmp"
+; (time to live) Sets the number of second while cached file will be used
+; instead of original one.
+soap.wsdl_cache_ttl=86400
+; Local Variables:
+; tab-width: 4
+; End:
Property changes on: trunk/MgDev/Oem/LinuxApt/php.ini-mapguide
+ native
Added: trunk/MgDev/Oem/LinuxApt/server.xml
--- trunk/MgDev/Oem/LinuxApt/server.xml (rev 0)
+++ trunk/MgDev/Oem/LinuxApt/server.xml 2007-03-23 20:57:03 UTC (rev 1360)
@@ -0,0 +1,383 @@
+<!-- Example Server Configuration File -->
+<!-- Note that component elements are nested corresponding to their
+ parent-child relationships with each other -->
+<!-- A "Server" is a singleton element that represents the entire JVM,
+ which may contain one or more "Service" instances. The Server
+ listens for a shutdown command on the indicated port.
+ Note: A "Server" is not itself a "Container", so you may not
+ define subcomponents such as "Valves" or "Loggers" at this level.
+<Server port="8005" shutdown="SHUTDOWN">
+ <!-- Comment these entries out to disable JMX MBeans support used for the
+ administration web application -->
+ <Listener className="org.apache.catalina.core.AprLifecycleListener" />
+ <Listener className="org.apache.catalina.mbeans.ServerLifecycleListener" />
+ <Listener className="org.apache.catalina.mbeans.GlobalResourcesLifecycleListener" />
+ <Listener className="org.apache.catalina.storeconfig.StoreConfigLifecycleListener"/>
+ <!-- Global JNDI resources -->
+ <GlobalNamingResources>
+ <!-- Test entry for demonstration purposes -->
+ <Environment name="simpleValue" type="java.lang.Integer" value="30"/>
+ <!-- Editable user database that can also be used by
+ UserDatabaseRealm to authenticate users -->
+ <Resource name="UserDatabase" auth="Container"
+ description="User database that can be updated and saved"
+ factory="org.apache.catalina.users.MemoryUserDatabaseFactory"
+ pathname="conf/tomcat-users.xml" />
+ </GlobalNamingResources>
+ <!-- A "Service" is a collection of one or more "Connectors" that share
+ a single "Container" (and therefore the web applications visible
+ within that Container). Normally, that Container is an "Engine",
+ but this is not required.
+ Note: A "Service" is not itself a "Container", so you may not
+ <!-- Define the Tomcat Stand-Alone Service -->
+ <Service name="Catalina">
+ <!-- A "Connector" represents an endpoint by which requests are received
+ and responses are returned. Each Connector passes requests on to the
+ associated "Container" (normally an Engine) for processing.
+ By default, a non-SSL HTTP/1.1 Connector is established on port 8080.
+ You can also enable an SSL HTTP/1.1 Connector on port 8443 by
+ following the instructions below and uncommenting the second Connector
+ entry. SSL support requires the following steps (see the SSL Config
+ HOWTO in the Tomcat 5 documentation bundle for more detailed
+ instructions):
+ * If your JDK version 1.3 or prior, download and install JSSE 1.0.2 or
+ later, and put the JAR files into "$JAVA_HOME/jre/lib/ext".
+ * Execute:
+ %JAVA_HOME%\bin\keytool -genkey -alias tomcat -keyalg RSA (Windows)
+ $JAVA_HOME/bin/keytool -genkey -alias tomcat -keyalg RSA (Unix)
+ with a password value of "changeit" for both the certificate and
+ the keystore itself.
+ By default, DNS lookups are enabled when a web application calls
+ request.getRemoteHost(). This can have an adverse impact on
+ performance, so you can disable it by setting the
+ "enableLookups" attribute to "false". When DNS lookups are disabled,
+ request.getRemoteHost() will return the String version of the
+ IP address of the remote client.
+ <!-- Define a non-SSL HTTP/1.1 Connector on port 8080 -->
+ <Connector port="8080" maxHttpHeaderSize="8192"
+ maxThreads="150" minSpareThreads="25" maxSpareThreads="75"
+ enableLookups="false" redirectPort="8443" acceptCount="100"
+ connectionTimeout="20000" disableUploadTimeout="true"
+ URIEncoding="UTF-8" useBodyEncodingForURI="true"/>
+ <!-- Note : To disable connection timeouts, set connectionTimeout value
+ to 0 -->
+ <!-- Note : To use gzip compression you could set the following properties :
+ compression="on"
+ compressionMinSize="2048"
+ noCompressionUserAgents="gozilla, traviata"
+ compressableMimeType="text/html,text/xml"
+ <!-- Define a SSL HTTP/1.1 Connector on port 8443 -->
+ <Connector port="8443" maxHttpHeaderSize="8192"
+ enableLookups="false" disableUploadTimeout="true"
+ acceptCount="100" scheme="https" secure="true"
+ clientAuth="false" sslProtocol="TLS" />
+ <!-- Define an AJP 1.3 Connector on port 8009 -->
+ <Connector port="8009"
+ enableLookups="false" redirectPort="8443" protocol="AJP/1.3"
+ URIEncoding="UTF-8" useBodyEncodingForURI="true" />
+ <!-- Define a Proxied HTTP/1.1 Connector on port 8082 -->
+ <!-- See proxy documentation for more information about using this. -->
+ <Connector port="8082"
+ enableLookups="false" acceptCount="100" connectionTimeout="20000"
+ proxyPort="80" disableUploadTimeout="true" />
+ <!-- An Engine represents the entry point (within Catalina) that processes
+ every request. The Engine implementation for Tomcat stand alone
+ analyzes the HTTP headers included with the request, and passes them
+ on to the appropriate Host (virtual host). -->
+ <!-- You should set jvmRoute to support load-balancing via AJP ie :
+ <Engine name="Standalone" defaultHost="localhost" jvmRoute="jvm1">
+ <!-- Define the top level container in our container hierarchy -->
+ <Engine name="Catalina" defaultHost="localhost">
+ <!-- The request dumper valve dumps useful debugging information about
+ the request headers and cookies that were received, and the response
+ headers and cookies that were sent, for all requests received by
+ this instance of Tomcat. If you care only about requests to a
+ particular virtual host, or a particular application, nest this
+ element inside the corresponding <Host> or <Context> entry instead.
+ For a similar mechanism that is portable to all Servlet 2.4
+ containers, check out the "RequestDumperFilter" Filter in the
+ example application (the source for this filter may be found in
+ "$CATALINA_HOME/webapps/examples/WEB-INF/classes/filters").
+ Request dumping is disabled by default. Uncomment the following
+ element to enable it. -->
+ <Valve className="org.apache.catalina.valves.RequestDumperValve"/>
+ <!-- Because this Realm is here, an instance will be shared globally -->
+ <!-- This Realm uses the UserDatabase configured in the global JNDI
+ resources under the key "UserDatabase". Any edits
+ that are performed against this UserDatabase are immediately
+ available for use by the Realm. -->
+ <Realm className="org.apache.catalina.realm.UserDatabaseRealm"
+ resourceName="UserDatabase"/>
+ <!-- Comment out the old realm but leave here for now in case we
+ need to go back quickly -->
+ <Realm className="org.apache.catalina.realm.MemoryRealm" />
+ <!-- Replace the above Realm with one of the following to get a Realm
+ stored in a database and accessed via JDBC -->
+ <Realm className="org.apache.catalina.realm.JDBCRealm"
+ driverName="org.gjt.mm.mysql.Driver"
+ connectionURL="jdbc:mysql://localhost/authority"
+ connectionName="test" connectionPassword="test"
+ userTable="users" userNameCol="user_name" userCredCol="user_pass"
+ userRoleTable="user_roles" roleNameCol="role_name" />
+ driverName="oracle.jdbc.driver.OracleDriver"
+ connectionURL="jdbc:oracle:thin:@ntserver:1521:ORCL"
+ connectionName="scott" connectionPassword="tiger"
+ driverName="sun.jdbc.odbc.JdbcOdbcDriver"
+ connectionURL="jdbc:odbc:CATALINA"
+ <!-- Define the default virtual host
+ Note: XML Schema validation will not work with Xerces 2.2.
+ <Host name="localhost" appBase="webapps"
+ unpackWARs="true" autoDeploy="true"
+ xmlValidation="false" xmlNamespaceAware="false">
+ <!-- Defines a cluster for this node,
+ By defining this element, means that every manager will be changed.
+ So when running a cluster, only make sure that you have webapps in there
+ that need to be clustered and remove the other ones.
+ A cluster has the following parameters:
+ className = the fully qualified name of the cluster class
+ name = a descriptive name for your cluster, can be anything
+ mcastAddr = the multicast address, has to be the same for all the nodes
+ mcastPort = the multicast port, has to be the same for all the nodes
+ mcastBindAddr = bind the multicast socket to a specific address
+ mcastTTL = the multicast TTL if you want to limit your broadcast
+ mcastSoTimeout = the multicast readtimeout
+ mcastFrequency = the number of milliseconds in between sending a "I'm alive" heartbeat
+ mcastDropTime = the number a milliseconds before a node is considered "dead" if no heartbeat is received
+ tcpThreadCount = the number of threads to handle incoming replication requests, optimal would be the same amount of threads as nodes
+ tcpListenAddress = the listen address (bind address) for TCP cluster request on this host,
+ in case of multiple ethernet cards.
+ auto means that address becomes
+ InetAddress.getLocalHost().getHostAddress()
+ tcpListenPort = the tcp listen port
+ tcpSelectorTimeout = the timeout (ms) for the Selector.select() method in case the OS
+ has a wakup bug in java.nio. Set to 0 for no timeout
+ printToScreen = true means that managers will also print to std.out
+ expireSessionsOnShutdown = true means that
+ useDirtyFlag = true means that we only replicate a session after setAttribute,removeAttribute has been called.
+ false means to replicate the session after each request.
+ false means that replication would work for the following piece of code: (only for SimpleTcpReplicationManager)
+ HashMap map = (HashMap)session.getAttribute("map");
+ map.put("key","value");
+ replicationMode = can be either 'pooled', 'synchronous' or 'asynchronous'.
+ * Pooled means that the replication happens using several sockets in a synchronous way. Ie, the data gets replicated, then the request return. This is the same as the 'synchronous' setting except it uses a pool of sockets, hence it is multithreaded. This is the fastest and safest configuration. To use this, also increase the nr of tcp threads that you have dealing with replication.
+ * Synchronous means that the thread that executes the request, is also the
+ thread the replicates the data to the other nodes, and will not return until all
+ nodes have received the information.
+ * Asynchronous means that there is a specific 'sender' thread for each cluster node,
+ so the request thread will queue the replication request into a "smart" queue,
+ and then return to the client.
+ The "smart" queue is a queue where when a session is added to the queue, and the same session
+ already exists in the queue from a previous request, that session will be replaced
+ in the queue instead of replicating two requests. This almost never happens, unless there is a
+ large network delay.
+ When configuring for clustering, you also add in a valve to catch all the requests
+ coming in, at the end of the request, the session may or may not be replicated.
+ A session is replicated if and only if all the conditions are met:
+ 1. useDirtyFlag is true or setAttribute or removeAttribute has been called AND
+ 2. a session exists (has been created)
+ 3. the request is not trapped by the "filter" attribute
+ The filter attribute is to filter out requests that could not modify the session,
+ hence we don't replicate the session after the end of this request.
+ The filter is negative, ie, anything you put in the filter, you mean to filter out,
+ ie, no replication will be done on requests that match one of the filters.
+ The filter attribute is delimited by ;, so you can't escape out ; even if you wanted to.
+ filter=".*\.gif;.*\.js;" means that we will not replicate the session after requests with the URI
+ ending with .gif and .js are intercepted.
+ The deployer element can be used to deploy apps cluster wide.
+ Currently the deployment only deploys/undeploys to working members in the cluster
+ so no WARs are copied upons startup of a broken node.
+ The deployer watches a directory (watchDir) for WAR files when watchEnabled="true"
+ When a new war file is added the war gets deployed to the local instance,
+ and then deployed to the other instances in the cluster.
+ When a war file is deleted from the watchDir the war is undeployed locally
+ and cluster wide
+ <Cluster className="org.apache.catalina.cluster.tcp.SimpleTcpCluster"
+ managerClassName="org.apache.catalina.cluster.session.DeltaManager"
+ expireSessionsOnShutdown="false"
+ useDirtyFlag="true"
+ notifyListenersOnReplication="true">
+ <Membership
+ className="org.apache.catalina.cluster.mcast.McastService"
+ mcastAddr="228.0.0.4"
+ mcastPort="45564"
+ mcastFrequency="500"
+ mcastDropTime="3000"/>
+ <Receiver
+ className="org.apache.catalina.cluster.tcp.ReplicationListener"
+ tcpListenAddress="auto"
+ tcpListenPort="4001"
+ tcpSelectorTimeout="100"
+ tcpThreadCount="6"/>
+ <Sender
+ className="org.apache.catalina.cluster.tcp.ReplicationTransmitter"
+ replicationMode="pooled"
+ ackTimeout="15000"/>
+ <Valve className="org.apache.catalina.cluster.tcp.ReplicationValve"
+ filter=".*\.gif;.*\.js;.*\.jpg;.*\.png;.*\.htm;.*\.html;.*\.css;.*\.txt;"/>
+ <Deployer className="org.apache.catalina.cluster.deploy.FarmWarDeployer"
+ tempDir="/tmp/war-temp/"
+ deployDir="/tmp/war-deploy/"
+ watchDir="/tmp/war-listen/"
+ watchEnabled="false"/>
+ <ClusterListener className="org.apache.catalina.cluster.session.ClusterSessionListener"/>
+ </Cluster>
+ <!-- Normally, users must authenticate themselves to each web app
+ individually. Uncomment the following entry if you would like
+ a user to be authenticated the first time they encounter a
+ resource protected by a security constraint, and then have that
+ user identity maintained across *all* web applications contained
+ in this virtual host. -->
+ <Valve className="org.apache.catalina.authenticator.SingleSignOn" />
+ <!-- Access log processes all requests for this virtual host. By
+ default, log files are created in the "logs" directory relative to
+ $CATALINA_HOME. If you wish, you can specify a different
+ directory with the "directory" attribute. Specify either a relative
+ (to $CATALINA_HOME) or absolute path to the desired directory.
+ <Valve className="org.apache.catalina.valves.AccessLogValve"
+ directory="logs" prefix="localhost_access_log." suffix=".txt"
+ pattern="common" resolveHosts="false"/>
+ This access log implementation is optimized for maximum performance,
+ but is hardcoded to support only the "common" and "combined" patterns.
+ <Valve className="org.apache.catalina.valves.FastCommonAccessLogValve"
+ This valve use NIO direct Byte Buffer to asynchornously store the
+ log.
+ <Valve className="org.apache.catalina.valves.ByteBufferAccessLogValve"
+ </Host>
+ </Engine>
+ </Service>
+</Server>
Property changes on: trunk/MgDev/Oem/LinuxApt/server.xml
___________________________________________________________________
+ native
More information about the mapguide-commits
