[mapguide-commits] r1375 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Mon Mar 26 11:29:57 EDT 2007
Author: waltweltonlair
Date: 2007-03-26 11:29:56 -0400 (Mon, 26 Mar 2007)
New Revision: 1375
trunk/MgDev/Common/Stylization/DWFRenderer.cpp
trunk/MgDev/Common/Stylization/DWFRenderer.h
Add more symbolization support to DWFRenderer.
- The renderer now implements DrawScreenRaster which is used
for Image graphic elements. Currently only unrotated images
are handled. Rotation support will be added in my next
submission.
- While testing this with labels I noticed the viewer was
often crashing. I tracked this down to two things:
* a label W2D containing one or more empty macros
* an empty label W2D (no macros)
I ran into these cases because my label symbol contains
a text graphic, but the DWF Renderer doesn't yet support
the new text symbolizations, and so it wasn't adding any
DWF data for the labels.
I've updated DWFRenderer to check for both cases. It now
keeps track of how many drawables are serialized in between
the calls to BeginMacro and EndMacro, and stores this count
in a std::map for that macro index. If we call PlayMacro
on a macro with zero drawables then the call does nothing.
The call to PlayMacro also keeps track of how many macros
are played in the label W2D. In EndMap (and EndLayout) we
now save the label W2D only if it actually has macros.
Modified: trunk/MgDev/Common/Stylization/DWFRenderer.cpp
--- trunk/MgDev/Common/Stylization/DWFRenderer.cpp 2007-03-26 09:42:53 UTC (rev 1374)
+++ trunk/MgDev/Common/Stylization/DWFRenderer.cpp 2007-03-26 15:29:56 UTC (rev 1375)
@@ -163,29 +163,28 @@
-WT_Result my_open (WT_File & file)
+WT_Result my_open(WT_File & file)
//this is freed in EndMap() (loops over all layer streams)
DWFBufferOutputStream* bos = DWFCORE_ALLOC_OBJECT( DWFBufferOutputStream(100000));
file.set_stream_user_data(bos);
return WT_Result::Success;
-WT_Result my_close (WT_File & file)
+WT_Result my_close(WT_File & file)
file.set_stream_user_data(WD_Null);
-WT_Result my_read (WT_File & /*file*/, int /*desired_bytes*/, int & /*bytes_read*/, void * /*buffer*/)
+WT_Result my_read(WT_File & /*file*/, int /*desired_bytes*/, int & /*bytes_read*/, void * /*buffer*/)
//should never get called, overloaded for consistency
_ASSERT(false);
-WT_Result my_write (WT_File & file,int size,void const * buffer)
+WT_Result my_write(WT_File & file, int size, void const * buffer)
DWFBufferOutputStream* fp = (DWFBufferOutputStream*) file.stream_user_data();
fp->write(buffer, size);
@@ -228,8 +227,10 @@
m_pPage(NULL),
m_input(NULL),
m_xformer(NULL),
+ m_bHaveViewport(false),
m_bHaveLabels(false),
- m_bHaveViewport(false)
+ m_drawableCount(0),
+ m_labelMacroCount(0)
m_lLayerStreams.reserve(8);
m_lLabelStreams.reserve(8);
@@ -325,13 +326,13 @@
for (stream_list::iterator iter = m_lLayerStreams.begin();
iter != m_lLayerStreams.end(); iter++)
- DWFCORE_FREE_OBJECT ( *iter);
+ DWFCORE_FREE_OBJECT( *iter);
for (stream_list::iterator iter = m_lLabelStreams.begin();
iter != m_lLabelStreams.end(); iter++)
for (stream_list::iterator iter = m_lLayoutStreams.begin();
@@ -421,7 +422,7 @@
m_w2dFile->set_stream_close_action(my_close);
m_w2dFile->set_stream_read_action (my_read);
m_w2dFile->set_stream_seek_action (my_seek);
- m_w2dFile->set_stream_write_action (my_write);
+ m_w2dFile->set_stream_write_action(my_write);
m_w2dFile->set_stream_user_data(WD_Null);
//overload WHIP I/O functions with our memory streaming ones
@@ -429,7 +430,7 @@
m_w2dLabels->set_stream_close_action(my_close);
m_w2dLabels->set_stream_read_action (my_read);
m_w2dLabels->set_stream_seek_action (my_seek);
- m_w2dLabels->set_stream_write_action (my_write);
+ m_w2dLabels->set_stream_write_action(my_write);
m_w2dLabels->set_stream_user_data(WD_Null);
m_bHaveLabels = false;
@@ -460,6 +461,8 @@
m_imgID = 0;
+ m_drawableCount = 0;
+ m_labelMacroCount = 0;
// remember the layer info
m_layerInfo = legendInfo;
@@ -483,26 +486,22 @@
delete m_w2dFile;
m_w2dFile = NULL;
- if (m_w2dLabels)
+ if (m_bHaveLabels && m_labelMacroCount > 0)
- if (m_bHaveLabels)
- //only need to keep track of label w2d if
- //stream was opened -- which happens when there
- //is at least one label
- m_lLabelStreams.push_back((DWFBufferOutputStream*)m_w2dLabels->stream_user_data());
- else
- m_lLabelStreams.push_back(NULL);//add NULL for no labels
- m_w2dLabels->close();
- delete m_w2dLabels;
- m_w2dLabels = NULL;
- m_bHaveLabels = false;
+ //Only need to keep track of label w2d if the stream was opened,
+ //which happens when there is at least one label. The check for
+ //macros ensures that the w2d is not empty, since the viewer
+ //doesn't like it otherwise (i.e. it crashes).
+ m_lLabelStreams.push_back((DWFBufferOutputStream*)m_w2dLabels->stream_user_data());
else
m_lLabelStreams.push_back(NULL); //add NULL for no labels
+ m_w2dLabels->close();
+ delete m_w2dLabels;
+ m_w2dLabels = NULL;
+ m_bHaveLabels = false;
if (m_featureClass)
m_lAttributeResources.push_back(m_attributes);
@@ -549,11 +548,11 @@
void DWFRenderer::ProcessPolygon(LineBuffer* srclb, RS_FillStyle& fill)
- LineBuffer* workbuffer = srclb->Optimize(m_drawingScale, &m_lbPool);
+ LineBuffer* geom = srclb->Optimize(m_drawingScale, &m_lbPool);
- if (workbuffer->point_count() == 0)
+ if (geom->point_count() == 0)
- m_lbPool.FreeLineBuffer(workbuffer);
+ m_lbPool.FreeLineBuffer(geom);
return;
@@ -561,25 +560,21 @@
WriteFill(fill);
- _TransformPointsNoClamp(workbuffer->points(), workbuffer->point_count());
+ _TransformPointsNoClamp(geom->points(), geom->point_count());
- //just a polygon, no need for a contourset
- if (workbuffer->cntr_count() == 1)
+ if (geom->cntr_count() == 1)
- //fill
- WT_Polygon fillpoly(workbuffer->point_count(), m_wtPointBuffer, false);
- m_w2dFile->desired_rendition().fill() = true;
- m_w2dFile->desired_rendition().color() = Util_ConvertColor(fill.color());
- fillpoly.serialize(*m_w2dFile);
+ // just a polygon, no need for a contourset
+ WT_Polygon polygon(geom->point_count(), m_wtPointBuffer, false);
+ polygon.serialize(*m_w2dFile);
+ ++m_drawableCount;
- else //otherwise make a contour set
+ else
- //write out the fill (as a contour set)
- //TODO:::::: &cntrs.front() may not work and is not legal
- WT_Contour_Set cset(*m_w2dFile, workbuffer->cntr_count(), (WT_Integer32*)workbuffer->cntrs(),
- workbuffer->point_count(), m_wtPointBuffer, true);
+ // otherwise make a contour set
+ WT_Contour_Set cset(*m_w2dFile, geom->cntr_count(), (WT_Integer32*)geom->cntrs(), geom->point_count(), m_wtPointBuffer, true);
cset.serialize(*m_w2dFile);
@@ -589,7 +584,7 @@
//write out the polygon outline as a bunch of WT_Polylines
if (fill.outline().color().alpha() == 0)
return;
@@ -612,16 +607,16 @@
else
m_w2dFile->desired_rendition().line_pattern() = WT_Line_Pattern(WT_Line_Pattern::Solid);
- WritePolylines(workbuffer);
+ WritePolylines(geom);
//zero out the dash pattern -- must do when done with it
if (m_w2dFile->desired_rendition().dash_pattern() != WT_Dash_Pattern::kNull)
m_w2dFile->desired_rendition().dash_pattern() = WT_Dash_Pattern::kNull;
if (m_obsMesh)
- m_obsMesh->ProcessPoint(workbuffer->points()[0], workbuffer->points()[1]);
+ m_obsMesh->ProcessPoint(geom->points()[0], geom->points()[1]);
@@ -687,7 +682,7 @@
if (format != RS_ImageFormat_RGBA && format != RS_ImageFormat_PNG)
- //TODO:
+ //TODO: support other formats...
_ASSERT(false);
return;
@@ -719,6 +714,7 @@
false);
img.serialize(*m_w2dFile);
else if (format == RS_ImageFormat_PNG)
@@ -734,6 +730,7 @@
false);
@@ -934,6 +931,7 @@
file->desired_rendition().color() = WT_Color(255,0,0);
WT_Polyline symbol(npts, pts, true);
symbol.serialize(*file);
else
@@ -944,6 +942,7 @@
WT_Polygon symbolFill(npts, pts, true);
symbolFill.serialize(*file);
if (mdef.style().color().argb() == RS_Color::EMPTY_COLOR_ARGB)
file->desired_rendition().color() = WT_Color(127,127,127);
@@ -952,10 +951,11 @@
//end macro definition
- EndMacro(file);
+ EndMacro(file, 0);
PlayMacro(file, 0, rs_max(mdef.width(), mdef.height()), mdef.units(), x, y);
@@ -988,7 +988,7 @@
AddDWFContent(symbol, &trans, mdef.name(), RS_String(L""), RS_String(L""));
//end macro definition and play the macro
- EndMacro(file);
m_bIsSymbolW2D = false;
@@ -1052,14 +1052,16 @@
WT_Polyline excludearea(2, axisbox, true);
excludearea.serialize(*file);
else
WT_Polyline excludearea(4, pts, true);
- EndMacro(file);
+ EndMacro(file, 1);
//write the exclusion area
file->write("(Overpost All False True (");
@@ -1160,7 +1162,7 @@
ProcessMultilineText(file, text, info->tdef(), ioffx, ioffy);
- EndMacro(file);
+ EndMacro(file, i+1);
else
@@ -1171,7 +1173,7 @@
ProcessMultilineText(file, text, info->tdef(), 0, 0);
- EndMacro(file);
@@ -1294,17 +1296,26 @@
char temp[256];
sprintf(temp, "(Macro %d %d (", id, scale);
file->write(temp);
+ m_macroDrawableCounts[id] = m_drawableCount;
-void DWFRenderer::EndMacro(WT_File* file)
+void DWFRenderer::EndMacro(WT_File* file, int id)
//close the Define Macro opcode
file->write("))");
+ //update the number of drawables contained in this macro
+ m_macroDrawableCounts[id] = m_drawableCount - m_macroDrawableCounts[id];
void DWFRenderer::PlayMacro(WT_File* file, int id, double sizeMeters, RS_Units unit, double x, double y)
+ // don't play empty macro definitions
+ if (m_macroDrawableCounts[id] == 0)
+ return;
//play the macro at the given position with the given screen size
int size = (int)_MeterToW2DMacroUnit(unit, sizeMeters);
@@ -1318,6 +1329,10 @@
sprintf(temp, " G %d S %d M 1 %d,%d", id, size, ix, iy);
file->write(temp);
+ // keep track if this macro was played inside the label w2d
+ if (file == m_w2dLabels)
+ ++m_labelMacroCount;
@@ -1419,6 +1434,7 @@
WT_Logical_Point pt(x, y);
WT_Text wttext(pt, wtstr);
wttext.serialize(*file);
return;
@@ -1466,6 +1482,7 @@
WT_Logical_Point pt(xpos, ypos);
@@ -1590,18 +1607,17 @@
//save to dwf polylines
int index = 0;
for (int i=0; i<srclb->cntr_count(); i++)
int cntr_size = srclb->cntrs()[i];
if (cntr_size > 0)
_TransformPointsNoClamp(srclb->points()+index, cntr_size);
+ index += 2*cntr_size;
WT_Polyline polyline(cntr_size, m_wtPointBuffer, false);
polyline.serialize(*m_w2dFile);
- index += 2*cntr_size;
@@ -1680,7 +1696,7 @@
-// Serializes font and text alignement and rendering settings
+// Serializes font and text alignment and rendering settings
void DWFRenderer::WriteTextDef(WT_File* file, RS_TextDef& tdef)
@@ -2017,7 +2033,6 @@
//scale used to convert to DWF logical coordinates in the range [0, 2^30-1]
m_scale = (double)(INT_MAX/2) / rs_max(m_extents.width(), m_extents.height());
- //m_layerName = itemName;
m_w2dFile = new WT_File();
m_w2dLabels = new WT_File();
@@ -2026,7 +2041,7 @@
@@ -2034,7 +2049,7 @@
@@ -2042,6 +2057,8 @@
OpenW2D(m_w2dFile);
m_imgID = 0;
@@ -2057,21 +2074,21 @@
delete m_w2dFile;
m_w2dFile = NULL;
- if (m_w2dLabels)
- m_lLayoutLabelStreams.push_back((DWFBufferOutputStream*)m_w2dLabels->stream_user_data());
+ m_lLayoutLabelStreams.push_back((DWFBufferOutputStream*)m_w2dLabels->stream_user_data());
+ else
+ m_lLayoutLabelStreams.push_back(NULL); //add NULL for no labels
@@ -2129,11 +2146,11 @@
if (cntr_size > 0)
_TransformPoints(geom->points() + index, cntr_size, xform);
polyline.serialize(*file);
@@ -2165,16 +2182,16 @@
- WT_Polygon fillpoly(geom->point_count(), m_wtPointBuffer, false);
- fillpoly.serialize(*file);
+ polygon.serialize(*file);
else
- WT_Contour_Set cset(*file, geom->cntr_count(), (WT_Integer32*)geom->cntrs(),
- geom->point_count(), m_wtPointBuffer, true);
+ WT_Contour_Set cset(*file, geom->cntr_count(), (WT_Integer32*)geom->cntrs(), geom->point_count(), m_wtPointBuffer, true);
cset.serialize(*file);
// zero out the dash pattern -- must do when done with it
@@ -2183,18 +2200,64 @@
-void DWFRenderer::DrawScreenRaster(unsigned char* /*data*/,
- int /*length*/,
- RS_ImageFormat /*format*/,
- int /*native_width*/,
- int /*native_height*/,
- double /*x*/,
- double /*y*/,
- double /*w*/,
- double /*h*/,
- double /*angledeg*/)
+void DWFRenderer::DrawScreenRaster(unsigned char* data,
+ int length,
+ RS_ImageFormat format,
+ int native_width,
+ int native_height,
+ double x,
+ double y,
+ double w,
+ double h,
+ double angledeg)
- // TODO
+ if (format != RS_ImageFormat_RGBA && format != RS_ImageFormat_PNG)
+ _ASSERT(false);
+ return;
+ // draw to the active file if it's set
+ WT_File* file = m_w2dActive? m_w2dActive : m_w2dFile;
+ WT_Integer32 x0 = (WT_Integer32)(x - 0.5*w);
+ WT_Integer32 y0 = (WT_Integer32)(y - 0.5*h);
+ WT_Integer32 x1 = (WT_Integer32)(x + 0.5*w);
+ WT_Integer32 y1 = (WT_Integer32)(y + 0.5*h);
+ if (format == RS_ImageFormat_RGBA)
+ WT_Image img((WT_Unsigned_Integer16)native_height,
+ (WT_Unsigned_Integer16)native_width,
+ WT_Image::RGBA,
+ m_imgID++,
+ NULL,
+ length,
+ (WT_Byte*)data,
+ WT_Logical_Point(x0, y0),
+ WT_Logical_Point(x1, y1),
+ false);
+ img.serialize(*file);
+ else if (format == RS_ImageFormat_PNG)
+ WT_PNG_Group4_Image img((WT_Unsigned_Integer16)native_height,
+ WT_PNG_Group4_Image::PNG,
+ m_imgID++,
+ NULL,
+ length,
+ (WT_Byte*)data,
+ false);
@@ -2208,6 +2271,9 @@
// TODO
+// WT_File* file = m_w2dActive? m_w2dActive : m_w2dFile;
// WriteTextDef(file, info->tdef());
@@ -2318,7 +2384,7 @@
DrawSymbol(info->symbol->symbol, m, info->anglerad);
m_w2dActive = NULL;
- EndMacro(file);
// now play the label macros inside an overpost
Modified: trunk/MgDev/Common/Stylization/DWFRenderer.h
--- trunk/MgDev/Common/Stylization/DWFRenderer.h 2007-03-26 09:42:53 UTC (rev 1374)
+++ trunk/MgDev/Common/Stylization/DWFRenderer.h 2007-03-26 15:29:56 UTC (rev 1375)
@@ -192,6 +192,11 @@
bool m_bHaveLabels;
+ // used to track the number of drawables and macros
+ int m_drawableCount;
+ int m_labelMacroCount;
+ std::map<int, int> m_macroDrawableCounts;
ObservationMesh* m_obsMesh;
// map/layer info
@@ -224,7 +229,7 @@
private:
//macro/overpost opcode output -- done manually by writing to file
void BeginMacro(WT_File* file, int id, int scale);
- void EndMacro(WT_File* file);
+ void EndMacro(WT_File* file, int id);
void PlayMacro(WT_File* file, int id, double sizeMeters, RS_Units unit, double x, double y);
void BeginOverpostGroup(WT_File* file, RS_OverpostType type, bool render, bool exclude);
void EndOverpostGroup(WT_File* file);
More information about the mapguide-commits
