[mapguide-commits] r1383 - in trunk/MgDev/Server/src:
Common/Manager Services/Resource UnitTesting
svn_mapguide at osgeo.org
Tue Mar 27 13:21:14 EDT 2007
Author: brucedechant
Date: 2007-03-27 13:21:14 -0400 (Tue, 27 Mar 2007)
New Revision: 1383
trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp
trunk/MgDev/Server/src/Common/Manager/ServiceManager.cpp
trunk/MgDev/Server/src/Services/Resource/ResourceContentManager.cpp
trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp
trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp
Update to feature source and FDO connection caching.
Modified: trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp 2007-03-27 16:39:53 UTC (rev 1382)
+++ trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp 2007-03-27 17:21:14 UTC (rev 1383)
@@ -1042,19 +1042,6 @@
SAFE_RELEASE(e);
- // Remove Feature Source cache entry
- FeatureSourceCache::iterator iterFeatureSource = m_FeatureSourceCache.find(key);
- if(m_FeatureSourceCache.end() != iterFeatureSource)
- MdfModel::FeatureSource* featureSource = iterFeatureSource->second;
- if(featureSource)
- delete featureSource;
- m_FeatureSourceCache.erase(iterFeatureSource);
fdoConnectionCache->erase(iter++);
connectionsRemoved++;
@@ -1088,6 +1075,19 @@
iterFdoConnectionCacheCollection++;
+ // Remove Feature Source cache entry
+ FeatureSourceCache::iterator iterFeatureSource = m_FeatureSourceCache.find(key);
+ if(m_FeatureSourceCache.end() != iterFeatureSource)
+ MdfModel::FeatureSource* featureSource = iterFeatureSource->second;
+ if(featureSource)
+ delete featureSource;
+ m_FeatureSourceCache.erase(iterFeatureSource);
MG_FDOCONNECTION_MANAGER_CATCH_AND_THROW(L"MgFdoConnectionManager.RemoveCachedFdoConnection")
return (connections == connectionsRemoved);
Modified: trunk/MgDev/Server/src/Common/Manager/ServiceManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/ServiceManager.cpp 2007-03-27 16:39:53 UTC (rev 1382)
+++ trunk/MgDev/Server/src/Common/Manager/ServiceManager.cpp 2007-03-27 17:21:14 UTC (rev 1383)
@@ -392,6 +392,15 @@
void MgServiceManager::NotifyResourcesChanged(MgSerializableCollection* resources)
+ // Remove the Feature Service cache entries associated with the changed resources
+ Ptr<MgServerFeatureService> featureService = dynamic_cast<MgServerFeatureService*>(
+ RequestLocalService(MgServiceType::FeatureService));
+ if (featureService != NULL)
+ featureService->RemoveFeatureServiceCacheEntries(resources);
if (m_loadBalanceManager->m_localServerInfo->IsServiceEnabled(
MgServiceType::TileService))
@@ -433,15 +442,6 @@
resourceService->EnumerateParentMapDefinitions(changedResources);
m_loadBalanceManager->DispatchResourceChangeNotifications(changedMaps);
- // Remove the Feature Service cache entries associated with the changed resources
- Ptr<MgServerFeatureService> featureService = dynamic_cast<MgServerFeatureService*>(
- RequestLocalService(MgServiceType::FeatureService));
- if (featureService != NULL)
- featureService->RemoveFeatureServiceCacheEntries(changedResources);
Modified: trunk/MgDev/Server/src/Services/Resource/ResourceContentManager.cpp
--- trunk/MgDev/Server/src/Services/Resource/ResourceContentManager.cpp 2007-03-27 16:39:53 UTC (rev 1382)
+++ trunk/MgDev/Server/src/Services/Resource/ResourceContentManager.cpp 2007-03-27 17:21:14 UTC (rev 1383)
@@ -266,9 +266,6 @@
const size_t sourcePathLength = sourcePathname.length();
XmlValue xmlValue;
- MgFdoConnectionManager* fdoConnectionManager = MgFdoConnectionManager::GetInstance();
- ACE_ASSERT(NULL != fdoConnectionManager);
while (results.next(xmlValue))
XmlDocument currDoc = xmlValue.asDocument();
@@ -277,28 +274,6 @@
CheckParentPermission(currResource, MgResourcePermission::ReadWrite);
- STRING resourceType = currResource.GetResourceType();
- if(MgResourceType::FeatureSource == resourceType)
- // Need to check the FDO connection manager to see if there is a cached
- // connection to this data and remove it if possible.
- // If there is and it is not in use then we can remove it from the cache
- // and allow the copy.
- if (NULL != fdoConnectionManager)
- if(!fdoConnectionManager->RemoveCachedFdoConnection(currResource.ToString()))
- // Could not remove the cached FDO connection because it is in use.
- MgStringCollection arguments;
- arguments.Add(currResource.ToString());
- throw new MgResourceBusyException(
- L"MgResourceContentManager.MoveResource",
- __LINE__, __WFILE__, &arguments, L"", NULL);
if (sourceResourceIsFolder)
currPathname.replace(0, sourcePathLength, destPathname);
@@ -436,9 +411,6 @@
XmlValue xmlValue;
const XmlDocument& currDoc = xmlValue.asDocument();
@@ -447,28 +419,6 @@
sourceResourceContentMan->CheckPermission(currResource, MgResourcePermission::ReadOnly);
- L"MgResourceContentManager.CopyResource",
Modified: trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp
--- trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp 2007-03-27 16:39:53 UTC (rev 1382)
+++ trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp 2007-03-27 17:21:14 UTC (rev 1383)
@@ -2192,9 +2192,26 @@
ACE_MT(ACE_GUARD(ACE_Recursive_Thread_Mutex, ace_mon, sm_mutex));
+ // Need to clear the FDO connection cache
+ MgFdoConnectionManager* fdoConnectionManager = MgFdoConnectionManager::GetInstance();
+ ACE_ASSERT(NULL != fdoConnectionManager);
for (set<STRING>::const_iterator i = resources.begin();
i != resources.end(); ++i)
+ Ptr<MgResourceIdentifier> resource = new MgResourceIdentifier(*i);
+ STRING resourceType = resource->GetResourceType();
+ if(MgResourceType::FeatureSource == resourceType)
+ // Need to check the FDO connection manager to see if there is a cached
+ // connection to this data and remove it if possible.
+ if (NULL != fdoConnectionManager)
+ fdoConnectionManager->RemoveCachedFdoConnection(*i);
sm_changedResources.insert(*i);
Modified: trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp 2007-03-27 16:39:53 UTC (rev 1382)
+++ trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp 2007-03-27 17:21:14 UTC (rev 1383)
@@ -46,7 +46,7 @@
const STRING Projected_UTM18_NAD83 = L"PROJCS[\"UTM Zone 18, Northern Hemisphere\",GEOGCS[\"GRS 1980(IUGG, 1980)\",DATUM[\"unknown\",SPHEROID[\"GRS80\",6378137,298.257222101]],PRIMEM[\"Greenwich\",0],UNIT[\"degree\",0.0174532925199433]],PROJECTION[\"Transverse_Mercator\"],PARAMETER[\"latitude_of_origin\",0],PARAMETER[\"central_meridian\",-75],PARAMETER[\"scale_factor\",0.9996],PARAMETER[\"false_easting\",500000],PARAMETER[\"false_northing\",0],UNIT[\"Meter\",1]]";
const STRING EPSG_4326_Wkt = L"GEOGCS[\"WGS 84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS 84\",6378137,298.257223563,AUTHORITY[\"EPSG\",\"7030\"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY[\"EPSG\",\"6326\"]],PRIMEM[\"Greenwich\",0,AUTHORITY[\"EPSG\",\"8901\"]],UNIT[\"degree\",0.0174532925199433,AUTHORITY[\"EPSG\",\"9108\"]],AXIS[\"Lat\",NORTH],AXIS[\"Long\",EAST],AUTHORITY[\"EPSG\",\"4326\"]]";
-const STRING EPSG_4326_Wkt_Alt = L"GEOGCS[\"WGS 84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS 84\",6378137,298.257223563,AUTHORITY[\"EPSG\",\"7030\"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY[\"EPSG\",\"6326\"]],PRIMEM[\"Greenwich\",0,AUTHORITY[\"EPSG\",\"8901\"]],UNIT[\"degree\",0.01745329251994328,AUTHORITY[\"EPSG\",\"9122\"]],AUTHORITY[\"EPSG\",\"4326\"]]";
+const STRING EPSG_4326_Wkt_Alt = L"GEOGCS[\"WGS 84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS 84\",6378137,298.257223563,AUTHORITY[\"EPSG\",\"7030\"]],AUTHORITY[\"EPSG\",\"6326\"]],PRIMEM[\"Greenwich\",0,AUTHORITY[\"EPSG\",\"8901\"]],UNIT[\"degree\",0.01745329251994328,AUTHORITY[\"EPSG\",\"9122\"]],AUTHORITY[\"EPSG\",\"4326\"]]";
const STRING TEST_LOCALE = L"en";
More information about the mapguide-commits
