[mapguide-commits] r1388 - branches/1.2.x/MgDev/Common/Schema
svn_mapguide at osgeo.org
Tue Mar 27 17:11:50 EDT 2007
Author: traianstanev
Date: 2007-03-27 17:11:50 -0400 (Tue, 27 Mar 2007)
New Revision: 1388
branches/1.2.x/MgDev/Common/Schema/SymbolDefinition-1.0.0.xsd
Switch text vertical alignment default back to Halfline.
Modified: branches/1.2.x/MgDev/Common/Schema/SymbolDefinition-1.0.0.xsd
--- branches/1.2.x/MgDev/Common/Schema/SymbolDefinition-1.0.0.xsd 2007-03-27 20:59:31 UTC (rev 1387)
+++ branches/1.2.x/MgDev/Common/Schema/SymbolDefinition-1.0.0.xsd 2007-03-27 21:11:50 UTC (rev 1388)
@@ -492,7 +492,7 @@
</xs:element>
<xs:element name="VerticalAlignment" type="xs:string" minOccurs="0">
<xs:annotation>
- <xs:documentation>The vertical alignment of the text box relative to its position. This must evaluate to one of: Bottom, Baseline (default), Halfline, Capline, or Top.</xs:documentation>
+ <xs:documentation>The vertical alignment of the text box relative to its position. This must evaluate to one of: Bottom, Baseline, Halfline (default), Capline, or Top.</xs:documentation>
</xs:annotation>
</xs:element>
<xs:element name="Justification" type="xs:string" minOccurs="0">
More information about the mapguide-commits
