[mapguide-commits] r4196 - in trunk/MgDev:
Common/MapGuideCommon/Services Common/PlatformBase/Services
Server/src/Services/Resource
UnitTest/WebTier/MapAgent/MapAgentForms Web/src/HttpHandler
svn_mapguide at osgeo.org
Fri Aug 28 12:08:13 EDT 2009
Author: brucedechant
Date: 2009-08-28 12:08:13 -0400 (Fri, 28 Aug 2009)
New Revision: 4196
trunk/MgDev/Common/MapGuideCommon/Services/ProxyResourceService.cpp
trunk/MgDev/Common/MapGuideCommon/Services/ProxyResourceService.h
trunk/MgDev/Common/PlatformBase/Services/ResourceService.cpp
trunk/MgDev/Common/PlatformBase/Services/ResourceService.h
trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp
trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.h
trunk/MgDev/Server/src/Services/Resource/ApplicationResourceContentManager.cpp
trunk/MgDev/Server/src/Services/Resource/ApplicationResourceContentManager.h
trunk/MgDev/Server/src/Services/Resource/OpMoveResource.cpp
trunk/MgDev/Server/src/Services/Resource/ResourceOperationFactory.cpp
trunk/MgDev/Server/src/Services/Resource/ResourcePackageLoader.cpp
trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp
trunk/MgDev/Server/src/Services/Resource/ServerResourceService.h
trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/moveresourceform.html
trunk/MgDev/Web/src/HttpHandler/HttpMoveResource.cpp
trunk/MgDev/Web/src/HttpHandler/HttpMoveResource.h
trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.cpp
trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.h
Fix for trac ticket 1076 - Move or rename resource should avoid breaking links
Notes:
- This patch implements RFC 74
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc74
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyResourceService.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyResourceService.cpp 2009-08-28 01:06:33 UTC (rev 4195)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyResourceService.cpp 2009-08-28 16:08:13 UTC (rev 4196)
@@ -427,6 +427,61 @@
/// <summary>
+/// Moves an existing resource from this repository to another location.
+/// This function can serve multiple purposes:
+/// - Move a resource if resource path and name are different.
+/// - Rename a resource if resource path is the same and name is different.
+/// </summary>
+/// <param name="sourceResource">
+/// Resource identifier for the resource to be moved/renamed.
+/// This resource can be a document or folder.
+/// </param>
+/// <param name="destResource">
+/// Resource identifier describing where/what the resource should be moved/renamed to.
+/// </param>
+/// <param name="overwrite">
+/// Flag to determine whether or not the destination
+/// resource should be overwritten if it exists.
+/// </param>
+/// <param name="cascade">
+/// referencing resources should be updated.
+/// </param>
+/// <returns>
+/// Nothing.
+/// </returns>
+/// EXCEPTIONS:
+/// MgResourceNotFoundException
+/// MgDuplicateResourceException
+/// MgInvalidRepositoryTypeException
+/// MgInvalidRepositoryNameException
+/// MgInvalidResourcePathException
+/// MgInvalidResourceNameException
+/// MgInvalidResourceTypeException
+void MgProxyResourceService::MoveResource(MgResourceIdentifier* sourceResource,
+ MgResourceIdentifier* destResource, bool overwrite, bool cascade)
+ MgCommand cmd;
+ cmd.ExecuteCommand(m_connProp,
+ MgCommand::knVoid,
+ MgResourceService::opIdMoveResource,
+ 4,
+ Resource_Service,
+ BUILD_VERSION(2,2,0),
+ MgCommand::knObject, sourceResource,
+ MgCommand::knObject, destResource,
+ MgCommand::knInt8, (int)overwrite,
+ MgCommand::knInt8, (int)cascade,
+ MgCommand::knNone);
+ SetWarning(cmd.GetWarningObject());
+/// <summary>
/// Copies an existing resource to another location.
/// </summary>
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyResourceService.h
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyResourceService.h 2009-08-28 01:06:33 UTC (rev 4195)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyResourceService.h 2009-08-28 16:08:13 UTC (rev 4196)
@@ -449,6 +449,41 @@
/// \brief
+ /// Moves an existing resource from this repository to another location.
+ /// This function can serve multiple purposes:
+ /// - Move a resource if resource path and name are different.
+ /// - Rename a resource if resource path is the same and name is different.
+ /// \param sourceResource
+ /// Resource identifier for the resource to be moved/renamed.
+ /// This resource can be a document or folder.
+ /// \param destResource
+ /// Resource identifier describing where/what the resource should be moved/renamed to.
+ /// \param overwrite
+ /// Flag to determine whether or not the destination
+ /// resource should be overwritten if it exists.
+ /// \param cascade
+ /// referencing resources should be updated.
+ /// \return
+ /// Nothing.
+ /// \exception MgResourceNotFoundException
+ /// \exception MgDuplicateResourceException
+ /// \exception MgInvalidRepositoryTypeException
+ /// \exception MgInvalidRepositoryNameException
+ /// \exception MgInvalidResourcePathException
+ /// \exception MgInvalidResourceNameException
+ /// \exception MgInvalidResourceTypeException
+ virtual void MoveResource(MgResourceIdentifier* sourceResource,
+ MgResourceIdentifier* destResource, bool overwrite, bool cascade);
+ /// \brief
Modified: trunk/MgDev/Common/PlatformBase/Services/ResourceService.cpp
--- trunk/MgDev/Common/PlatformBase/Services/ResourceService.cpp 2009-08-28 01:06:33 UTC (rev 4195)
+++ trunk/MgDev/Common/PlatformBase/Services/ResourceService.cpp 2009-08-28 16:08:13 UTC (rev 4196)
@@ -108,6 +108,24 @@
__LINE__, __WFILE__, NULL, L"", NULL);
+/// \brief
+/// Moves an existing resource to another location.
+void MgResourceService::MoveResource(MgResourceIdentifier* sourceResource,
+ MgResourceIdentifier* destResource, bool overwrite)
+ throw new MgNotImplementedException(L"MgResourceService.MoveResource",
+ __LINE__, __WFILE__, NULL, L"", NULL);
/// <summary>
/// Gets the content of the specified resource.
Modified: trunk/MgDev/Common/PlatformBase/Services/ResourceService.h
--- trunk/MgDev/Common/PlatformBase/Services/ResourceService.h 2009-08-28 01:06:33 UTC (rev 4195)
+++ trunk/MgDev/Common/PlatformBase/Services/ResourceService.h 2009-08-28 16:08:13 UTC (rev 4196)
@@ -784,10 +784,96 @@
/// left intact.
- MgResourceIdentifier* destResource, bool overwrite) = 0;
+ MgResourceIdentifier* destResource, bool overwrite);
/// \brief
+ /// Moves an existing resource to another location.
+ /// \remarks
+ /// You can also use this method to rename a resource.
+ /// <!-- Syntax in .Net, Java, and PHP -->
+ /// \htmlinclude DotNetSyntaxTop.html
+ /// virtual void MoveResource(MgResourceIdentifier sourceResource, MgResourceIdentifier destResource, bool overwrite, bool cascade);
+ /// \htmlinclude SyntaxBottom.html
+ /// \htmlinclude JavaSyntaxTop.html
+ /// virtual void MoveResource(MgResourceIdentifier sourceResource, MgResourceIdentifier destResource, boolean overwrite, boolean cascade);
+ /// \htmlinclude PHPSyntaxTop.html
+ /// \param sourceResource (MgResourceIdentifier)
+ /// Resource to be moved. This can be a document
+ /// or folder.
+ /// <ul>
+ /// <li>If it is a folder, this method also moves the contents of the folder and all folders below it.</li>
+ /// <li>If it is a folder, you must include the trailing slash in the identifier.</li>
+ /// </ul>
+ /// \param destResource (MgResourceIdentifier)
+ /// Where the resource should be moved to.
+ /// \param overwrite (boolean/bool)
+ /// destination resource should be overwritten if
+ /// it exists.
+ /// \param cascade (boolean/bool)
+ /// \return
+ /// Returns nothing.
+ /// <!-- Example (PHP) -->
+ /// \htmlinclude PHPExampleTop.html
+ /// This example moves the file
+ /// Library://Geography/World.MapDefinition to
+ /// Library://Atlas/Oceans.MapDefinition:
+ /// \code
+ /// // Assuming $resourceService has already been initialized
+ /// $oldPath = new MgResourceIdentifier("Library://Geography/World.MapDefinition");
+ /// $newPath = new MgResourceIdentifier("Library://Atlas/Oceans.MapDefinition");
+ /// $resourceService->MoveResource($oldPath, $newPath, true, true);
+ /// \endcode
+ /// This example moves the folder Library://Geography/ to
+ /// Library://World Geography/:
+ /// \code
+ /// $oldPath = new MgResourceIdentifier("Library://Geography/");
+ /// $newPath = new MgResourceIdentifier("Library://World Geography/");
+ /// \endcode
+ /// This example renames Oceans.MapDefinition to Pacific
+ /// Ocean.MapDefinition:
+ /// \code
+ /// $oldPath = new MgResourceIdentifier("Library://Atlas/Oceans.MapDefinition");
+ /// $newPath = new MgResourceIdentifier("Library://Atlas/Pacific Ocean.MapDefinition");
+ /// $resourceService->MoveResource($oldPath, $newPath, true, false);
+ /// \endcode
+ /// \htmlinclude ExampleBottom.html
+ /// \note
+ /// When copying a folder with the "overwrite" flag turned on, if
+ /// the destination folder already exists, then only the children
+ /// in the destination folder that have the same names as those
+ /// in the source folder are overwritten. The rest should are
+ /// left intact.
+ /// \brief
Modified: trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp
--- trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp 2009-08-28 01:06:33 UTC (rev 4195)
+++ trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp 2009-08-28 16:08:13 UTC (rev 4196)
@@ -417,7 +417,7 @@
void MgApplicationRepositoryManager::MoveResource(
MgResourceIdentifier* sourceResource, MgResourceIdentifier* destResource,
- bool overwrite)
+ bool overwrite, bool cascade)
assert(NULL != sourceResource && NULL != destResource) ;
@@ -486,6 +486,15 @@
__LINE__, __WFILE__, &arguments, L"MgResourcesIdentical", NULL);
+ // If cascade update referencing resources, get the references and check permission.
+ // An MgUnauthorizedAccessException will throw if current user doesn't have write permission to any referencing resource.
+ Ptr<MgStringCollection> referencingIds = NULL;
+ if(cascade)
+ MgApplicationResourceContentManager* resourceContentMan = GetApplicationResourceContentManager();
+ referencingIds = resourceContentMan->EnumerateAllReferences(sourceResource, MgResourcePermission::ReadWrite);
// Move the resource and all of its children.
MgResourceHeaderManager* resourceHeaderMan = GetResourceHeaderManager();
@@ -504,6 +513,38 @@
resourceContentMan->MoveResource(sourceResource, destResource, overwrite);
+ // If cascade update referencing resources, update referencing resources' content,
+ // setting ResourceId from sourceResource to destResource
+ if(cascade && referencingIds != NULL && referencingIds->GetCount() != 0)
+ STRING source = sourceResource->ToString();
+ STRING dest = destResource->ToString();
+ STRING prefix = L"<ResourceId>";
+ for(int i = 0; i < referencingIds->GetCount(); i ++)
+ STRING referencingId = referencingIds->GetItem(i);
+ if(referencingId.find(source) != STRING::npos)
+ referencingId = referencingId.replace(0, source.size(), dest);
+ Ptr<MgResourceIdentifier> referenceResource = new MgResourceIdentifier(referencingId);
+ Ptr<MgByteReader> contentReader = GetResourceContent(referenceResource, L"");
+ STRING mimeType = contentReader->GetByteSource()->GetMimeType();
+ STRING content = contentReader->ToString();
+ size_t pos = content.find(prefix + source);
+ if(pos != STRING::npos)
+ content = content.replace(pos + prefix.size(), source.size(), dest);
+ string utf8Text = MgUtil::WideCharToMultiByte(content);
+ Ptr<MgByteSource> byteSource = new MgByteSource((BYTE_ARRAY_IN)utf8Text.c_str(), (INT32)utf8Text.length());
+ byteSource->SetMimeType(mimeType);
+ contentReader = byteSource->GetReader();
+ Ptr<MgByteReader> headerReader = GetResourceHeader(referenceResource);
+ SetResource(referenceResource, contentReader, headerReader);
UpdateDateModifiedResourceSet(sourceResource->GetFullPath(true));
UpdateDateModifiedResourceSet(destResource->GetFullPath(true));
Modified: trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.h
--- trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.h 2009-08-28 01:06:33 UTC (rev 4195)
+++ trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.h 2009-08-28 16:08:13 UTC (rev 4196)
@@ -65,7 +65,7 @@
virtual MgByteReader* GetResourceHeader(
MgResourceIdentifier* resource);
- MgResourceIdentifier* destResource, bool overwrite);
void CopyResource(MgResourceIdentifier* sourceResource,
MgByteReader* EnumerateReferences(MgResourceIdentifier* resource);
Modified: trunk/MgDev/Server/src/Services/Resource/ApplicationResourceContentManager.cpp
--- trunk/MgDev/Server/src/Services/Resource/ApplicationResourceContentManager.cpp 2009-08-28 01:06:33 UTC (rev 4195)
+++ trunk/MgDev/Server/src/Services/Resource/ApplicationResourceContentManager.cpp 2009-08-28 16:08:13 UTC (rev 4196)
@@ -124,6 +124,67 @@
return byteReader.Detach();
+/// <summary>
+/// Enumerates all resources which reference to a document or folder resource.
+/// </summary>
+/// <exceptions>
+/// MgDbXmlException, MgDbException, MgUnauthorizedAccessException
+/// </exceptions>
+MgStringCollection* MgApplicationResourceContentManager::EnumerateAllReferences(MgResourceIdentifier* resource, const STRING permission)
+ assert(NULL != resource);
+ Ptr<MgStringCollection> references = new MgStringCollection();
+ MG_RESOURCE_SERVICE_TRY()
+ string resourceId;
+ MgUtil::WideCharToMultiByte(resource->ToString(), resourceId);
+ // Set up an XQuery.
+ string query = "collection('";
+ query += m_container.getName();
+ query += "')";
+ query += "//*/ResourceId[starts-with(.,\"";
+ query += resourceId;
+ query += "\")]";
+ // Execute the XQuery.
+ XmlManager& xmlMan = m_container.getManager();
+ XmlQueryContext queryContext = xmlMan.createQueryContext();
+ XmlResults results = IsTransacted() ?
+ xmlMan.query(GetXmlTxn(), query, queryContext, 0) :
+ xmlMan.query(query, queryContext, 0);
+ // Get the resource and populate the resource reference list.
+ // this XML follows the ResourceReferenceList-1.0.0.xsd schema
+ MgResourceIdentifier currResource;
+ XmlValue xmlValue;
+ while (results.next(xmlValue)) // TODO: Need an XML writer
+ const XmlDocument& xmlDoc = xmlValue.asDocument();
+ // Check if the current user has a required permission.
+ currResource.SetResource(MgUtil::MultiByteToWideChar(xmlDoc.getName()));
+ if (CheckPermission(currResource, permission))
+ references->Add(currResource.ToString());
+ MG_RESOURCE_CONTAINER_CATCH_AND_THROW(L"MgApplicationResourceContentManager.EnumerateReferences")
+ return references.Detach();
/// \brief
/// Enumerate all the parent Map Definition resources of the specified
Modified: trunk/MgDev/Server/src/Services/Resource/ApplicationResourceContentManager.h
--- trunk/MgDev/Server/src/Services/Resource/ApplicationResourceContentManager.h 2009-08-28 01:06:33 UTC (rev 4195)
+++ trunk/MgDev/Server/src/Services/Resource/ApplicationResourceContentManager.h 2009-08-28 16:08:13 UTC (rev 4196)
@@ -45,7 +45,11 @@
// Resource Management APIs
+ // Enumerates all resources which reference the specified resource by ResourceId='***'
+ // Enumerates all resources which reference to a document or folder resource by starts-with(ResourceId,'***')
+ // If the reference resource doesn't have specific permission, through exception.
+ MgStringCollection* EnumerateAllReferences(MgResourceIdentifier* resource, const STRING permission);
void EnumerateParentMapDefinitions(
const set<string>& currSearchResources, set<string>& nextSearchResources,
set<string>& childResources, set<STRING>& parentResources);
Modified: trunk/MgDev/Server/src/Services/Resource/OpMoveResource.cpp
--- trunk/MgDev/Server/src/Services/Resource/OpMoveResource.cpp 2009-08-28 01:06:33 UTC (rev 4195)
+++ trunk/MgDev/Server/src/Services/Resource/OpMoveResource.cpp 2009-08-28 16:08:13 UTC (rev 4196)
@@ -62,7 +62,7 @@
ACE_ASSERT(m_stream != NULL);
- if (3 == m_packet.m_NumArguments)
+ if (3 == m_packet.m_NumArguments || 4 == m_packet.m_NumArguments)
Ptr<MgResourceIdentifier> sourceResource =
(MgResourceIdentifier*)m_stream->GetObject();
@@ -70,6 +70,11 @@
bool overwrite;
m_stream->GetBoolean(overwrite);
+ bool cascade = false;
+ if(4 == m_packet.m_NumArguments)
+ m_stream->GetBoolean(cascade);
BeginExecution();
@@ -79,11 +84,13 @@
MG_LOG_OPERATION_MESSAGE_ADD_STRING((NULL == destResource) ? L"MgResourceIdentifier" : destResource->ToString().c_str());
MG_LOG_OPERATION_MESSAGE_ADD_SEPARATOR();
MG_LOG_OPERATION_MESSAGE_ADD_BOOL(overwrite);
+ MG_LOG_OPERATION_MESSAGE_ADD_SEPARATOR();
+ MG_LOG_OPERATION_MESSAGE_ADD_BOOL(cascade);
MG_LOG_OPERATION_MESSAGE_PARAMETERS_END();
Validate();
- m_service->MoveResource(sourceResource, destResource, overwrite);
+ m_service->MoveResource(sourceResource, destResource, overwrite, cascade);
EndExecution();
Modified: trunk/MgDev/Server/src/Services/Resource/ResourceOperationFactory.cpp
--- trunk/MgDev/Server/src/Services/Resource/ResourceOperationFactory.cpp 2009-08-28 01:06:33 UTC (rev 4195)
+++ trunk/MgDev/Server/src/Services/Resource/ResourceOperationFactory.cpp 2009-08-28 16:08:13 UTC (rev 4196)
@@ -247,6 +247,7 @@
switch (VERSION_NO_PHASE(operationVersion))
case VERSION_SUPPORTED(1,0):
+ case VERSION_SUPPORTED(2,2):
handler.reset(new MgOpMoveResource());
break;
default:
Modified: trunk/MgDev/Server/src/Services/Resource/ResourcePackageLoader.cpp
--- trunk/MgDev/Server/src/Services/Resource/ResourcePackageLoader.cpp 2009-08-28 01:06:33 UTC (rev 4195)
+++ trunk/MgDev/Server/src/Services/Resource/ResourcePackageLoader.cpp 2009-08-28 16:08:13 UTC (rev 4196)
@@ -356,6 +356,9 @@
bool overwrite = ACE_OS::atoi(opInfo.GetParameter(
MgOperationParameter::Overwrite, false).GetValue().c_str()) != 0;
+ CREFSTRING paramCascade = opInfo.GetParameter(MgOperationParameter::Overwrite, false).GetValue();
+ bool cascade = !paramCascade.empty() && (ACE_OS::atoi(paramCascade.c_str()) != 0);
if (m_packageLogWriter != NULL)
MG_LOG_OPERATION_MESSAGE(L"MoveResource");
@@ -370,7 +373,7 @@
m_packageLogWriter->AddOperation(operationMessage);
- m_repositoryManager.MoveResource(srcResource, destResource, overwrite);
+ m_repositoryManager.MoveResource(srcResource, destResource, overwrite, cascade);
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgResourcePackageLoader.MoveResource")
Modified: trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp
--- trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp 2009-08-28 01:06:33 UTC (rev 4195)
+++ trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp 2009-08-28 16:08:13 UTC (rev 4196)
@@ -797,9 +797,14 @@
/// MgException
/// </exceptions>
+void MgServerResourceService::MoveResource(MgResourceIdentifier* sourceResource,
+ MoveResource(sourceResource, destResource, overwrite, false);
@@ -816,7 +821,7 @@
MG_RESOURCE_SERVICE_BEGIN_OPERATION(true)
- repositoryMan->MoveResource(sourceResource, destResource, overwrite);
+ repositoryMan->MoveResource(sourceResource, destResource, overwrite, cascade);
MG_RESOURCE_SERVICE_END_OPERATION(sm_retryAttempts)
Modified: trunk/MgDev/Server/src/Services/Resource/ServerResourceService.h
--- trunk/MgDev/Server/src/Services/Resource/ServerResourceService.h 2009-08-28 01:06:33 UTC (rev 4195)
+++ trunk/MgDev/Server/src/Services/Resource/ServerResourceService.h 2009-08-28 16:08:13 UTC (rev 4196)
@@ -81,6 +81,8 @@
virtual void DeleteResource(MgResourceIdentifier* resource);
virtual void CopyResource(MgResourceIdentifier* sourceResource,
virtual MgByteReader* GetResourceContent(
Modified: trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/moveresourceform.html
--- trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/moveresourceform.html 2009-08-28 01:06:33 UTC (rev 4195)
+++ trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/moveresourceform.html 2009-08-28 16:08:13 UTC (rev 4196)
@@ -9,7 +9,7 @@
<b>Operation:</b>
<input type="text" name="OPERATION" value="MOVERESOURCE" size="50">
<p> Version:
-<input type="text" name="VERSION" value="1.0.0" size="10">
+<input type="text" name="VERSION" value="2.2.0" size="10">
<p> Locale:
<input type="text" name="LOCALE" value="en" size="10">
<p> Client Agent:
@@ -20,6 +20,8 @@
<input type="text" name="DESTINATION" value="Library://Test/Sources/World2.FeatureSource" size="100">
<p> Overwrite:
<input type="text" name="OVERWRITE" value="0" size="10">
+<p> Cascade:
+<input type="text" name="CASCADE" value="1" size="10">
<p>
<input type="submit" value="Submit" onclick="SetActionTarget()"> <input type="reset">
</form>
Modified: trunk/MgDev/Web/src/HttpHandler/HttpMoveResource.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpMoveResource.cpp 2009-08-28 01:06:33 UTC (rev 4195)
+++ trunk/MgDev/Web/src/HttpHandler/HttpMoveResource.cpp 2009-08-28 16:08:13 UTC (rev 4196)
@@ -48,6 +48,12 @@
m_overwrite = ::atoi(MgUtil::WideCharToMultiByte(
hrParam->GetParameterValue(
MgHttpResourceStrings::reqOverwrite)).c_str()) != 0;
+ // In order to maintain backward compatibility, the Cascade flag
+ // will be set to false by default if it is not specified.
+ STRING cascadeParam = hrParam->GetParameterValue(MgHttpResourceStrings::reqCascade);
+ m_cascade = (!cascadeParam.empty() && 0 != MgUtil::StringToInt32(cascadeParam));
/// <summary>
@@ -76,7 +82,7 @@
MgResourceIdentifier mgrDestIdentifier(m_destResourceId);
// Run API command
- mgprService->MoveResource(&mgrSourceIdentifier, &mgrDestIdentifier, m_overwrite);
+ mgprService->MoveResource(&mgrSourceIdentifier, &mgrDestIdentifier, m_overwrite, m_cascade);
MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpMoveResource.Execute")
Modified: trunk/MgDev/Web/src/HttpHandler/HttpMoveResource.h
--- trunk/MgDev/Web/src/HttpHandler/HttpMoveResource.h 2009-08-28 01:06:33 UTC (rev 4195)
+++ trunk/MgDev/Web/src/HttpHandler/HttpMoveResource.h 2009-08-28 16:08:13 UTC (rev 4196)
@@ -47,6 +47,7 @@
STRING m_sourceResourceId;
STRING m_destResourceId;
bool m_overwrite;
+ bool m_cascade;
#endif
Modified: trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.cpp 2009-08-28 01:06:33 UTC (rev 4195)
+++ trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.cpp 2009-08-28 16:08:13 UTC (rev 4196)
@@ -97,6 +97,7 @@
const STRING MgHttpResourceStrings::reqOldDataName = L"OLDDATANAME";
const STRING MgHttpResourceStrings::reqNewDataName = L"NEWDATANAME";
const STRING MgHttpResourceStrings::reqOverwrite = L"OVERWRITE";
+const STRING MgHttpResourceStrings::reqCascade = L"CASCADE";
const STRING MgHttpResourceStrings::reqPackage = L"PACKAGE";
const STRING MgHttpResourceStrings::reqOwner = L"OWNER";
const STRING MgHttpResourceStrings::reqIncludeDescendants = L"INCLUDEDESCENDANTS";
Modified: trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.h
--- trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.h 2009-08-28 01:06:33 UTC (rev 4195)
+++ trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.h 2009-08-28 16:08:13 UTC (rev 4196)
@@ -101,6 +101,7 @@
static const STRING reqOldDataName;
static const STRING reqNewDataName;
static const STRING reqOverwrite;
+ static const STRING reqCascade;
static const STRING reqPackage;
static const STRING reqOwner;
static const STRING reqIncludeDescendants;
More information about the mapguide-commits
