[mapguide-commits] r4198 - trunk/MgDev/Web/src/HttpHandler
    svn_mapguide at osgeo.org
    Fri Aug 28 13:27:28 EDT 2009
Author: brucedechant
Date: 2009-08-28 13:27:28 -0400 (Fri, 28 Aug 2009)
New Revision: 4198
   trunk/MgDev/Web/src/HttpHandler/HttpGetIdentityProperties.cpp
Fix for trac ticket 1061 - HttpHandler's GetIdentityProperties throws an unimplemented exception
Notes:
- Updated HTTP API to use updated GetIdentityProperties() API change done in trac ticket 1002
Modified: trunk/MgDev/Web/src/HttpHandler/HttpGetIdentityProperties.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpGetIdentityProperties.cpp	2009-08-28 16:49:24 UTC (rev 4197)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGetIdentityProperties.cpp	2009-08-28 17:27:28 UTC (rev 4198)
@@ -60,11 +60,25 @@
     STRING schema = hrParam->GetParameterValue(MgHttpResourceStrings::reqFeatSchema);
     STRING className = hrParam->GetParameterValue(MgHttpResourceStrings::reqFeatClass);
+    // Throw on empty class name
+    if (className.empty())
+        throw new MgClassNotFoundException(L"MgHttpGetIdentityProperties.Execute", __LINE__, __WFILE__, NULL, L"", NULL);
     // Create Proxy Feature Service instance
     Ptr<MgFeatureService> service = (MgFeatureService*)(CreateService(MgServiceType::FeatureService));
     // call the C++ APIs
-    Ptr<MgPropertyDefinitionCollection> identityProps = service->GetIdentityProperties(&resId, schema, className);
+    Ptr<MgStringCollection> classNames = new MgStringCollection();
+    classNames->Add(className);
+    Ptr<MgClassDefinitionCollection> idClasses = service->GetIdentityProperties(&resId, schema, classNames);
+    if (idClasses.p == NULL || idClasses->GetCount() == 0)
+    Ptr<MgClassDefinition> idClass = idClasses->GetItem(0);
+    Ptr<MgPropertyDefinitionCollection> identityProps = idClass->GetIdentityProperties();
     Ptr<MgByteReader> byteReader = identityProps->ToXml();
     //Convert to alternate response format, if necessary
More information about the mapguide-commits
