[mapguide-commits] r4207 - in trunk/Tools/Maestro: . Maestro
svn_mapguide at osgeo.org
Mon Aug 31 12:56:17 EDT 2009
Author: ksgeograf
Date: 2009-08-31 12:56:17 -0400 (Mon, 31 Aug 2009)
New Revision: 4207
trunk/Tools/Maestro/Maestro/FormExpression.Designer.cs
trunk/Tools/Maestro/Maestro/FormExpression.cs
trunk/Tools/Maestro/UpdateVersionNumber.exe
Maestro: Fixed a minor iissue with the value lookup in the ExpressionEditor.
Modified: trunk/Tools/Maestro/Maestro/FormExpression.Designer.cs
--- trunk/Tools/Maestro/Maestro/FormExpression.Designer.cs 2009-08-30 16:22:35 UTC (rev 4206)
+++ trunk/Tools/Maestro/Maestro/FormExpression.Designer.cs 2009-08-31 16:56:17 UTC (rev 4207)
@@ -165,6 +165,7 @@
this.ColumnValue.Alignment = System.Windows.Forms.ToolStripItemAlignment.Right;
this.ColumnValue.DropDownStyle = System.Windows.Forms.ComboBoxStyle.DropDownList;
+ this.ColumnValue.DropDownWidth = 180;
this.ColumnValue.Enabled = false;
this.ColumnValue.Name = "ColumnValue";
this.ColumnValue.Size = new System.Drawing.Size(90, 25);
@@ -186,6 +187,7 @@
this.ColumnName.Alignment = System.Windows.Forms.ToolStripItemAlignment.Right;
this.ColumnName.DropDownStyle = System.Windows.Forms.ComboBoxStyle.DropDownList;
+ this.ColumnName.DropDownWidth = 180;
this.ColumnName.Name = "ColumnName";
this.ColumnName.Size = new System.Drawing.Size(90, 25);
this.ColumnName.ToolTipText = "Select the column to read values from";
@@ -195,7 +197,7 @@
// ExpressionText
this.ExpressionText.Dock = System.Windows.Forms.DockStyle.Fill;
- this.ExpressionText.Font = new System.Drawing.Font("Microsoft Sans Serif", 12F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
+ this.ExpressionText.Font = new System.Drawing.Font("Courier New", 12F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
this.ExpressionText.HideSelection = false;
this.ExpressionText.Location = new System.Drawing.Point(0, 25);
this.ExpressionText.Multiline = true;
Modified: trunk/Tools/Maestro/Maestro/FormExpression.cs
--- trunk/Tools/Maestro/Maestro/FormExpression.cs 2009-08-30 16:22:35 UTC (rev 4206)
+++ trunk/Tools/Maestro/Maestro/FormExpression.cs 2009-08-31 16:56:17 UTC (rev 4207)
@@ -728,9 +728,7 @@
private void ColumnName_SelectedIndexChanged(object sender, EventArgs e)
- if (ColumnName.SelectedIndex < 0)
- LookupValues.Enabled = ColumnName.SelectedIndex >= 0;
+ LookupValues.Enabled = ColumnName.SelectedIndex >= 0;
private void LookupValues_Click(object sender, EventArgs e)
Modified: trunk/Tools/Maestro/UpdateVersionNumber.exe
(Binary files differ)
More information about the mapguide-commits
