[mapguide-commits] r4328 - in sandbox/rfc60/MgDev:
Common/MapGuideCommon/MapLayer Common/MdfModel
Common/Stylization Server/src/Services/Mapping
Server/src/Services/Tile
svn_mapguide at osgeo.org
Sun Nov 1 18:24:53 EST 2009
Author: uvlite
Date: 2009-11-01 18:24:51 -0500 (Sun, 01 Nov 2009)
New Revision: 4328
sandbox/rfc60/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp
sandbox/rfc60/MgDev/Common/MapGuideCommon/MapLayer/Map.h
sandbox/rfc60/MgDev/Common/MdfModel/VectorScaleRange.cpp
sandbox/rfc60/MgDev/Common/MdfModel/VectorScaleRange.h
sandbox/rfc60/MgDev/Common/Stylization/DefaultStylizer.cpp
sandbox/rfc60/MgDev/Common/Stylization/DefaultStylizer.h
sandbox/rfc60/MgDev/Common/Stylization/FeatureTypeStyleVisitor.h
sandbox/rfc60/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
sandbox/rfc60/MgDev/Server/src/Services/Mapping/MappingUtil.h
sandbox/rfc60/MgDev/Server/src/Services/Tile/ServerTileService.cpp
RFC60 integrated symbol lookup
Modified: sandbox/rfc60/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp
--- sandbox/rfc60/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp 2009-11-01 22:36:48 UTC (rev 4327)
+++ sandbox/rfc60/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp 2009-11-01 23:24:51 UTC (rev 4328)
@@ -1121,22 +1121,30 @@
// ColorPalette Accessors
// used for the map colors collected from the stylization of the visible layers
-PSTRCOLORLIST MgMap::GetColorPalette(CREFSTRING baseMapLayerGroupName)
+PSTRCOLORLIST MgMap::GetColorPalette()
if (m_colorPalette == NULL)
m_colorPalette = new STRCOLORLIST();
return m_colorPalette;
-/// setter does sort and prune the list also
-void MgMap::SetColorPalette(PSTRCOLORLIST newColorPalette, CREFSTRING baseMapLayerGroupName)
+/// setter adds list and then sorts and prunes the map colorlist
+void MgMap::AddColors2Palette(PSTRCOLORLIST newColorPalette)
+ GetColorPalette();
// sort and delete duplicates if any coming in
if (newColorPalette != NULL && !newColorPalette->empty())
- newColorPalette->sort();
- newColorPalette->unique();
+ STRCOLORLIST::iterator it = newColorPalette->begin();
+ for(; it != newColorPalette->end(); it++)
+ if (*it != L"") // filter empty strings
+ { // uppercase the colorcodes (FFABDEFF) and filter empty strings
+ std::transform( (*it).begin(), (*it).end(), (*it).begin(), towupper);
+ m_colorPalette->push_back(*it);
- assert (m_colorPalette == newColorPalette); //make sure this is the same!
- m_colorPalette = newColorPalette;
+ m_colorPalette->sort();
+ m_colorPalette->unique();
Modified: sandbox/rfc60/MgDev/Common/MapGuideCommon/MapLayer/Map.h
--- sandbox/rfc60/MgDev/Common/MapGuideCommon/MapLayer/Map.h 2009-11-01 22:36:48 UTC (rev 4327)
+++ sandbox/rfc60/MgDev/Common/MapGuideCommon/MapLayer/Map.h 2009-11-01 23:24:51 UTC (rev 4328)
@@ -579,8 +579,8 @@
virtual void OnLayerParentChanged(MgLayerBase* layer, CREFSTRING parentId);
/// accessor for the colors as defined in the baseMap with given name
- PSTRCOLORLIST GetColorPalette(CREFSTRING baseMapLayerGroupName=L"");
- void SetColorPalette(PSTRCOLORLIST newColorPalette, CREFSTRING baseMapLayerGroupName=L"" );
+ PSTRCOLORLIST GetColorPalette();
+ void AddColors2Palette(PSTRCOLORLIST newColorPalette);
/// Bulk load identity properties
Modified: sandbox/rfc60/MgDev/Common/MdfModel/VectorScaleRange.cpp
--- sandbox/rfc60/MgDev/Common/MdfModel/VectorScaleRange.cpp 2009-11-01 22:36:48 UTC (rev 4327)
+++ sandbox/rfc60/MgDev/Common/MdfModel/VectorScaleRange.cpp 2009-11-01 23:24:51 UTC (rev 4328)
@@ -62,7 +62,7 @@
this->m_dMinScale = 0.0;
this->m_dMaxScale = MAX_MAP_SCALE;
this->m_elevationSettings = NULL;
- this->m_usedColorList = NULL;
+// this->m_usedColorList = NULL;
@@ -73,8 +73,8 @@
// delete members which are pointers explicitely
if (this->m_elevationSettings != NULL)
delete this->m_elevationSettings;
- if (this->m_usedColorList != NULL)
- delete this->m_usedColorList;
+// if (this->m_usedColorList != NULL)
+// delete this->m_usedColorList;
@@ -163,7 +163,7 @@
this->m_elevationSettings = elevationSettings;
/// PURPOSE: Accessor method for the base colors defined in this Layer and scaleRange.
/// RETURNS: A pointer to the list of colors of the collected colors (maybe empty but not null)
@@ -175,7 +175,6 @@
// this should be sufficiently thread safe as the object is created immediately
PSTRCOLORLIST usedColorList = this->m_usedColorList = new STRCOLORLIST();
struct Local // local declaration of helper function
/// overloaded helper for SimpleSymbolDefinition
@@ -382,3 +381,4 @@
} // for GetFeatureTypeStyles
return this->m_usedColorList;
\ No newline at end of file
Modified: sandbox/rfc60/MgDev/Common/MdfModel/VectorScaleRange.h
--- sandbox/rfc60/MgDev/Common/MdfModel/VectorScaleRange.h 2009-11-01 22:36:48 UTC (rev 4327)
+++ sandbox/rfc60/MgDev/Common/MdfModel/VectorScaleRange.h 2009-11-01 23:24:51 UTC (rev 4328)
@@ -67,7 +67,7 @@
void AdoptElevationSettings(ElevationSettings* elevationSettings);
// Computed Property : UsedColorList
- PSTRCOLORLIST GetUsedColorList();
+// PSTRCOLORLIST GetUsedColorList();
private:
// Hidden copy constructor and assignment operator.
@@ -88,7 +88,7 @@
ElevationSettings* m_elevationSettings;
// cached colorlist
- PSTRCOLORLIST m_usedColorList;
+// PSTRCOLORLIST m_usedColorList;
typedef MdfOwnerCollection<VectorScaleRange> VectorScaleRangeCollection;
Modified: sandbox/rfc60/MgDev/Common/Stylization/DefaultStylizer.cpp
--- sandbox/rfc60/MgDev/Common/Stylization/DefaultStylizer.cpp 2009-11-01 22:36:48 UTC (rev 4327)
+++ sandbox/rfc60/MgDev/Common/Stylization/DefaultStylizer.cpp 2009-11-01 23:24:51 UTC (rev 4328)
@@ -33,6 +33,7 @@
DefaultStylizer::DefaultStylizer(SE_SymbolManager* sman)
m_pRasterAdapter = NULL;
+ m_symbolmanager = sman;
m_styleEngine = new StylizationEngine(sman, &m_lbPool);
@@ -46,7 +47,7 @@
delete m_styleEngine;
void DefaultStylizer::StylizeVectorLayer(MdfModel::VectorLayerDefinition* layer,
Renderer* renderer,
RS_FeatureReader* features,
@@ -74,150 +75,18 @@
// check if we have any composite type styles - if we find at least
// one then we'll use it and ignore any other non-composite type styles
// TODO: confirm this is the behavior we want
- bool foundComposite = false;
- for (int i=0; i<ftsc->GetCount(); ++i)
- MdfModel::FeatureTypeStyle* fts = ftsc->GetAt(i);
- if (FeatureTypeStyleVisitor::DetermineFeatureTypeStyle(fts) == FeatureTypeStyleVisitor::ftsComposite)
- foundComposite = true;
- break;
// composite type styles are handled by the new style engine
- if (foundComposite)
+ if (FeatureTypeStyleVisitor::hasFeatureTypeStyleCollectionComposite(ftsc))
m_styleEngine->StylizeVectorLayer(layer, scaleRange, (SE_Renderer*)renderer, features, xformer, cancel, userData);
else
- int nFeatures = 0;
- // Here we check if the layer has a composite polyline style. If so,
- // we will make multiple feature queries and process the geometry
- // once for each line style. This makes things look much better.
- // We can render polylines with composite styles using this method
- // only if there is a single line style
- MdfModel::FeatureTypeStyle* fts = (ftsc->GetCount() > 0)? ftsc->GetAt(0) : NULL;
- if (NULL != fts
- && FeatureTypeStyleVisitor::DetermineFeatureTypeStyle(fts) == FeatureTypeStyleVisitor::ftsLine
- && renderer->RequiresCompositeLineStyleSeparation())
- MdfModel::RuleCollection* rules = fts->GetRules();
- // temporary holder for line styles
- std::vector<MdfModel::LineSymbolizationCollection*> tmpSyms;
- // For each rule transfer all line styles into a temporary collection
- // and away from the layer definition. Also obtain the maximum # of
- // styles for all the rules.
- int maxStyles = 0;
- for (int m=0; m<rules->GetCount(); ++m)
- MdfModel::LineRule* lr = (MdfModel::LineRule*)rules->GetAt(m);
- MdfModel::LineSymbolizationCollection* syms = lr->GetSymbolizations();
- // move composite line styles to a temporary collection away
- // from the one in the layer definition
- MdfModel::LineSymbolizationCollection* syms2 = new MdfModel::LineSymbolizationCollection();
- while (syms->GetCount() > 0)
- syms2->Adopt(syms->OrphanAt(0));
- tmpSyms.push_back(syms2);
- // keep track of the maximum # of styles
- maxStyles = rs_max(maxStyles, syms2->GetCount());
- // if there are no styles, we still want to render so that labels
- // draw even if we are not drawing the actual geometry
- if (maxStyles == 0)
- nFeatures = StylizeVLHelper(layer, scaleRange, renderer, features, true, xformer, cancel, userData);
- else
- // collection to store labels temporarily so that we add labels
- // to each feature just once
- std::vector<MdfModel::TextSymbol*> tmpLabels;
- // now for each separate line style - run a feature query
- // and stylization loop with that single style
- for (int i=0; i<maxStyles; ++i)
- // reset reader if this is not the first time we stylize the feature
- if (i > 0)
- features->Reset();
- // for each rule, transfer a single line style from the temporary
- // collection to the layer definition
- MdfModel::LineSymbolizationCollection* syms2 = tmpSyms[m];
- // remove label if this is not the first time we stylize
- // the feature
- if (i == 1)
- tmpLabels.push_back(lr->GetLabel()->OrphanSymbol());
- if (i < syms2->GetCount())
- syms->Adopt(syms2->GetAt(i));
- nFeatures += StylizeVLHelper(layer, scaleRange, renderer, features, i==0, xformer, cancel, userData);
- // clear line style from each rule in the layer definition
- // add back label if we removed it
- if (i > 0 && i == maxStyles-1)
- lr->GetLabel()->AdoptSymbol(tmpLabels[m]);
- if (syms->GetCount() > 0)
- syms->OrphanAt(0);
- // move composite line styles back to original layer definition
- // collection so that it frees them up when we destroy it
- while (syms2->GetCount() > 0)
- syms->Adopt(syms2->OrphanAt(0));
- delete syms2;
- else
- // composite line style separation not required
- #ifdef _DEBUG
- printf(" DefaultStylizer::StylizeVectorLayer() Layer: %S Features: %d\n", layer->GetFeatureName().c_str(), nFeatures);
- #endif
+ CompositeLineStyleHelper(layer, scaleRange, renderer, features, xformer, cancel, userData);
// need to get rid of these since they cache per layer theming
// information which may conflict with the next layer
ClearAdapters();
m_styleEngine->ClearCache();
int DefaultStylizer::StylizeVLHelper(MdfModel::VectorLayerDefinition* layer,
MdfModel::VectorScaleRange* scaleRange,
Renderer* renderer,
@@ -343,8 +212,7 @@
return nFeatures;
void DefaultStylizer::StylizeGridLayer(MdfModel::GridLayerDefinition* layer,
Renderer* renderer,
@@ -407,7 +275,7 @@
ClearAdapters();
void DefaultStylizer::StylizeDrawingLayer(MdfModel::DrawingLayerDefinition* layer,
Renderer* renderer,
RS_InputStream* dwfin,
@@ -426,7 +294,7 @@
// WARNING: given pointer to the new stylizer will be destroyed
// by the stylizer (in its destructor)
void DefaultStylizer::SetGeometryAdapter(FdoGeometryType type, GeometryAdapter* stylizer)
@@ -439,7 +307,7 @@
m_hGeomStylizers[type] = stylizer;
GeometryAdapter* DefaultStylizer::FindGeomAdapter(int geomType)
GeometryAdapter* adapter = m_hGeomStylizers[geomType];
@@ -488,7 +356,7 @@
return m_hGeomStylizers[geomType];
void DefaultStylizer::ClearAdapters()
std::map<int, GeometryAdapter*>::iterator sgiter = m_hGeomStylizers.begin();
@@ -507,3 +375,160 @@
+/// parse the rules and move linesyms from lineRules into tmpSyms
+int DefaultStylizer::CollectLineStyles(MdfModel::RuleCollection* rules, LSCPVECTOR &tmpSyms)
+ // For each rule transfer all line styles into a temporary collection
+ // and away from the layer definition. Also obtain the maximum # of
+ // styles for all the rules.
+ int maxStyles = 0;
+ for (int m=0; m < rules->GetCount(); ++m)
+ MdfModel::LineRule* lr = (MdfModel::LineRule*)rules->GetAt(m);
+ MdfModel::LineSymbolizationCollection* syms = lr->GetSymbolizations();
+ // move composite line styles to a temporary collection away
+ // from the one in the layer definition
+ MdfModel::LineSymbolizationCollection* syms2 = new MdfModel::LineSymbolizationCollection();
+ while (syms->GetCount() > 0)
+ syms2->Adopt(syms->OrphanAt(0));
+ tmpSyms.push_back(syms2);
+ // keep track of the maximum # of styles
+ maxStyles = rs_max(maxStyles, syms2->GetCount());
+ return maxStyles;
+/// move composite line styles back from tmpSyms to original layer definition collection
+/// so that it frees them up when we destroy it
+void DefaultStylizer::ReturnLineStyles(MdfModel::RuleCollection* rules, LSCPVECTOR &tmpSyms)
+ for (int m=0; m<rules->GetCount(); ++m)
+ MdfModel::LineSymbolizationCollection* syms2 = tmpSyms[m];
+ while (syms2->GetCount() > 0)
+ syms->Adopt(syms2->OrphanAt(0));
+ delete syms2;
+/// stylize multiple styles and remove labels in additional styles
+int DefaultStylizer::ProcessLineStyles(int maxStyles,
+ MdfModel::RuleCollection* rules,
+ LSCPVECTOR tmpSyms,
+ MdfModel::VectorLayerDefinition* layer,
+ MdfModel::VectorScaleRange* scaleRange,
+ Renderer* renderer,
+ RS_FeatureReader* features,
+ CSysTransformer* xformer,
+ CancelStylization cancel,
+ void* userData)
+ int nFeatures =0;
+ // collection to store labels temporarily so that we add labels
+ // to each feature just once
+ std::vector<MdfModel::TextSymbol*> tmpLabels;
+ // now for each separate line style - run a feature query
+ // and stylization loop with that single style
+ for (int i=0; i < maxStyles; ++i)
+ // reset reader if this is not the first time we stylize the feature
+ if (i > 0)
+ features->Reset();
+ // for each rule, transfer a single line style from the temporary
+ // collection to the layer definition
+ // remove label if this is not the first time we stylize the feature
+ if (i == 1)
+ tmpLabels.push_back(lr->GetLabel()->OrphanSymbol());
+ // add
+ if (i < syms2->GetCount())
+ syms->Adopt(syms2->GetAt(i));
+ /// call the helper
+ nFeatures += StylizeVLHelper(layer, scaleRange, renderer, features, i==0, xformer, cancel, userData);
+ // clear line style from each rule in the layer definition
+ // add back label if we removed it
+ if (i > 0 && i == maxStyles-1)
+ lr->GetLabel()->AdoptSymbol(tmpLabels[m]);
+ if (syms->GetCount() > 0)
+ syms->OrphanAt(0);
+ return nFeatures;
+/// Here we check if the layer has a composite polyline style. If so,
+/// we will make multiple feature queries and process the geometry
+/// once for each line style. This makes things look much better.
+void DefaultStylizer::CompositeLineStyleHelper(MdfModel::VectorLayerDefinition* layer,
+ void* userData)
+ // we have a valid scale range... we can now go over the
+ // features and apply the feature styles in that range
+ MdfModel::FeatureTypeStyleCollection* ftsc = scaleRange->GetFeatureTypeStyles();
+ int nFeatures = 0;
+ // We can render polylines with composite styles using this method
+ // only if there is a single line style
+ MdfModel::FeatureTypeStyle* fts = (ftsc->GetCount() > 0)? ftsc->GetAt(0) : NULL;
+ if (NULL != fts
+ && FeatureTypeStyleVisitor::DetermineFeatureTypeStyle(fts) == FeatureTypeStyleVisitor::ftsLine
+ && renderer->RequiresCompositeLineStyleSeparation())
+ MdfModel::RuleCollection* rules = fts->GetRules();
+ // temporary holder for line styles
+ LSCPVECTOR tmpSyms;
+ int maxStyles = CollectLineStyles(rules, tmpSyms);
+ // if there are no styles, we still want to render so that labels
+ // draw even if we are not drawing the actual geometry
+ if (maxStyles == 0)
+ nFeatures = StylizeVLHelper(layer, scaleRange, renderer, features, true, xformer, cancel, userData);
+ else
+ nFeatures = ProcessLineStyles(maxStyles, rules, tmpSyms, layer, scaleRange, renderer, features, xformer, cancel, userData);
+ ReturnLineStyles(rules, tmpSyms);
+ else // composite line style separation not required
+#ifdef _DEBUG
+printf(" DefaultStylizer::StylizeVectorLayer() Layer: %S Features: %d\n", layer->GetFeatureName().c_str(), nFeatures);
+#endif
Modified: sandbox/rfc60/MgDev/Common/Stylization/DefaultStylizer.h
--- sandbox/rfc60/MgDev/Common/Stylization/DefaultStylizer.h 2009-11-01 22:36:48 UTC (rev 4327)
+++ sandbox/rfc60/MgDev/Common/Stylization/DefaultStylizer.h 2009-11-01 23:24:51 UTC (rev 4328)
@@ -25,6 +25,8 @@
class StylizationEngine;
class SE_SymbolManager;
+typedef std::vector<MdfModel::LineSymbolizationCollection*> LSCPVECTOR;
// Stylizer used for all types of layers which do not have special
// Stylizer implementation, which is currently all of them.
@@ -59,8 +61,9 @@
STYLIZATION_API virtual void SetGeometryAdapter(FdoGeometryType type, GeometryAdapter* stylizer);
-private:
- int StylizeVLHelper(MdfModel::VectorLayerDefinition* layer,
+ STYLIZATION_API virtual SE_SymbolManager* GetSymbolManager() { return m_symbolmanager; }
+protected:
+ virtual int StylizeVLHelper(MdfModel::VectorLayerDefinition* layer,
Renderer* renderer,
@@ -68,6 +71,30 @@
void* userData);
+private:
+ void CompositeLineStyleHelper(MdfModel::VectorLayerDefinition* layer,
+ void* userData);
+ int CollectLineStyles(MdfModel::RuleCollection* rules, LSCPVECTOR &tmpSyms);
+ void ReturnLineStyles(MdfModel::RuleCollection* rules, LSCPVECTOR &tmpSyms);
+ int ProcessLineStyles(int maxStyles,
+ void* userData);
GeometryAdapter* FindGeomAdapter(int geomType);
void ClearAdapters();
@@ -80,6 +107,9 @@
//composite stylizer
StylizationEngine* m_styleEngine;
+ // keep a handle on the symbolmanager
+ SE_SymbolManager* m_symbolmanager;
SE_BufferPool m_lbPool;
Modified: sandbox/rfc60/MgDev/Common/Stylization/FeatureTypeStyleVisitor.h
--- sandbox/rfc60/MgDev/Common/Stylization/FeatureTypeStyleVisitor.h 2009-11-01 22:36:48 UTC (rev 4327)
+++ sandbox/rfc60/MgDev/Common/Stylization/FeatureTypeStyleVisitor.h 2009-11-01 23:24:51 UTC (rev 4328)
@@ -85,6 +85,20 @@
return vis.GetFeatureTypeStyle();
+ //static helper
+ static bool hasFeatureTypeStyleCollectionComposite(MdfModel::FeatureTypeStyleCollection* ftsc)
+ for (int i=0; i<ftsc->GetCount(); ++i)
+ MdfModel::FeatureTypeStyle* fts = ftsc->GetAt(i);
+ if (FeatureTypeStyleVisitor::DetermineFeatureTypeStyle(fts) == FeatureTypeStyleVisitor::ftsComposite)
+ return true;
+ return false;
private:
eFeatureTypeStyle m_type;
Modified: sandbox/rfc60/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
--- sandbox/rfc60/MgDev/Server/src/Services/Mapping/MappingUtil.cpp 2009-11-01 22:36:48 UTC (rev 4327)
+++ sandbox/rfc60/MgDev/Server/src/Services/Mapping/MappingUtil.cpp 2009-11-01 23:24:51 UTC (rev 4328)
@@ -22,6 +22,7 @@
#include "Renderer.h"
#include "AGGRenderer.h"
#include "Stylizer.h"
+#include "DefaultStylizer.h"
#include "SymbolVisitor.h"
#include "SLDSymbols.h"
#include "SE_StyleVisitor.h"
@@ -380,7 +381,7 @@
TransformCacheMap transformCache;
Ptr<MgStringCollection> layerIds = new MgStringCollection();
- // Get the layers' resource content in a single request
+ // Get the layers' resource content in a single request by adding them to a collection
for (int i = layers->GetCount()-1; i >= 0; i--)
Ptr<MgLayerBase> mapLayer = layers->GetItem(i);
@@ -405,6 +406,7 @@
layerIds->Add(mapLayer->GetLayerDefinition()->ToString());
+ // request the collection from resource service and add ResourceContent to the individual layers
if(layerIds->GetCount() != 0)
Ptr<MgStringCollection> layerContents = svcResource->GetResourceContents(layerIds, NULL);
@@ -421,7 +423,7 @@
+ // cycle over the layers and do stylization
auto_ptr<MdfModel::LayerDefinition> ldf;
@@ -438,7 +440,7 @@
MG_SERVER_MAPPING_SERVICE_TRY()
- //get layer definition
+ // get layer definition using SAX XML Parser
ldf.reset(MgLayerBase::GetLayerDefinition(mapLayer->GetLayerResourceContent()));
Ptr<MgLayerGroup> group = mapLayer->GetGroup();
@@ -472,7 +474,7 @@
MdfModel::DrawingLayerDefinition* dl = dynamic_cast<MdfModel::DrawingLayerDefinition*>(ldf.get());
MdfModel::GridLayerDefinition* gl = dynamic_cast<MdfModel::GridLayerDefinition*>(ldf.get());
- if (vl)
+ if (vl) //############################################################################ VECTORLAYER
#ifdef _DEBUG
long dwLayerStart = GetTickCount();
@@ -559,6 +561,7 @@
// create the reader we'll use
rsReader = ExecuteFeatureQuery(svcFeature, extent, vl, overrideFilter.c_str(), dstCs, layerCs, item);
+ // create an autoPtr around the reader
FdoPtr<FdoIFeatureReader> fdoReader = (NULL == rsReader) ? NULL : rsReader->GetInternalReader();
#ifdef _DEBUG
@@ -571,37 +574,8 @@
dr->StartLayer(&layerInfo, &fcinfo);
ds->StylizeVectorLayer(vl, dr, rsReader, xformer, scale, NULL, NULL);
dr->EndLayer();
- // COLORPALETTE CODE from UV for Ticket #813
- // add the colors from this scaleRange and vectorlayer to the map colors
- // (overrideFilters == NULL could tells us
- // that we have been called for rendering a map and not for selection)
- try {
- // the map object owns the color list so get a pointer from there
- PSTRCOLORLIST pStringColorPalette = map->GetColorPalette();
- PSTRCOLORLIST vLayerColors = scaleRange->GetUsedColorList();
- if (!vLayerColors->empty())
- assert (pStringColorPalette);
- // add the vectorLayer's Colors to the map's color list
- STRCOLORLIST::iterator it = vLayerColors->begin();
- for(; it != vLayerColors->end(); it++)
- { // uppercase the colorcodes (FFABDEFF) and filter empty strings
- if (*it == L"") continue;
- STRING upc = *it;
- std::transform( upc.begin(), upc.end(), upc.begin(), towupper);
- pStringColorPalette->push_back(upc);
- assert (pStringColorPalette == map->GetColorPalette());
- // the property setter canonicalizes the palette
- map->SetColorPalette(pStringColorPalette);
- } catch (exception e) {
- ACE_DEBUG((LM_DEBUG, L"(%t) %w caught in MappingUtil.ColorPaletteGeneration\n", e.what()));
- throw e;
+ ExtractColors(map, scaleRange, ds);
else // not scaleRange
@@ -614,7 +588,7 @@
printf(" StylizeLayers() **LAYEREND** -Vector- Name:%S Time:%6.4f (s)\n\n", (mapLayer->GetName()).c_str(), (GetTickCount()-dwLayerStart)/1000.0);
#endif
- else if (gl)
+ else if (gl) //############################################################################ GRAPHICS layer
// TODO: FDO RFP - Make FdoPtr's reference counter thread-safe.
static ACE_Recursive_Thread_Mutex sg_fdoRfpMutex;
@@ -755,7 +729,7 @@
printf(" StylizeLayers() **LAYEREND** -Grid- Name:%S Time:%6.4f (s)\n\n", (mapLayer->GetName()).c_str(), (GetTickCount()-dwLayerStart)/1000.0);
#endif
- else if (dl) //drawing layer
+ else if (dl) //############################################################################ drawing layer
#ifdef _DEBUG
@@ -817,7 +791,7 @@
#ifdef _DEBUG
printf(" StylizeLayers() **LAYEREND** -Drawing- Name:%S Time = %6.4f (s)\n\n", (mapLayer->GetName()).c_str(), (GetTickCount()-dwLayerStart)/1000.0);
#endif
+ } // end layer switch
MG_SERVER_MAPPING_SERVICE_CATCH(L"MgMappingUtil.StylizeLayers");
@@ -1165,7 +1139,7 @@
return NULL;
// transforms a given extent and returns the new extent in the new cs
MgEnvelope* MgMappingUtil::TransformExtent(MgEnvelope* extent, MgCoordinateSystemTransform* xform)
@@ -1230,3 +1204,226 @@
SetStylizerExceptionCallback(&MgMappingUtilExceptionTrap);
+/// PURPOSE: Accessor method for the base colors defined in this Layer and scaleRange.
+/// RETURNS: A pointer to the list of colors of the collected colors (maybe empty but not null)
+PSTRCOLORLIST MgMappingUtil::GetUsedColorsFromScaleRange(MdfModel::VectorScaleRange* vsr,
+ SE_SymbolManager* sman)
+ PSTRCOLORLIST usedColorList = new STRCOLORLIST();
+ // compute new color list by iterating through the featuretypecollection
+ FeatureTypeStyleCollection* pftsColl = vsr->GetFeatureTypeStyles();
+ int ftsccount = pftsColl->GetCount();
+ for (int j=0; j< ftsccount; j++)
+ FeatureTypeStyle* pfts = pftsColl->GetAt(j);
+ // iterate through the rulecollection
+ RuleCollection* ruleColl = pfts->GetRules();
+ int rccount = ruleColl->GetCount();
+ for (int k=0; k < rccount; k++)
+ Rule* rule = ruleColl->GetAt(k);
+ // get the label which will be the key in the color map
+ Label* label = rule->GetLabel();
+ // the legend label is just a string
+ // const MdfString& legendLabel = rule->GetLegendLabel();
+ // add colors of txtsymbols
+ TextSymbol* txtsym = label->GetSymbol();
+ if (txtsym) {
+ usedColorList->push_back(txtsym->GetForegroundColor().substr());
+ usedColorList->push_back(txtsym->GetBackgroundColor().substr());
+ // do the casting to access the relevant members
+ // this is bad style (instead of using the visitor pattern of the Mdfmodel)
+ // but it keeps it nice and compact and documents the structure better...
+ AreaRule* paRule = dynamic_cast<AreaRule*>(rule);
+ LineRule* plRule = dynamic_cast<LineRule*>(rule);
+ PointRule* ppRule = dynamic_cast<PointRule*>(rule);
+ CompositeRule* pcRule = dynamic_cast<CompositeRule*>(rule); // used for new stylization
+ // AreaRule Symbolization.....
+ if (paRule != NULL)
+ AreaSymbolization2D* pasym = paRule->GetSymbolization();
+ if (pasym->GetFill() != NULL)
+ { // create copies of all strings!!! so we can safely delete the resulting list later
+ usedColorList->push_back(pasym->GetFill()->GetForegroundColor().substr());
+ usedColorList->push_back(pasym->GetFill()->GetBackgroundColor().substr());
+ if (pasym->GetEdge() != NULL)
+ usedColorList->push_back(pasym->GetEdge()->GetColor().substr());
+ // LineRule Symbolization.....
+ if (plRule != NULL)
+ LineSymbolizationCollection* plsymcol = plRule->GetSymbolizations();
+ // iterate through the linesymbolizations
+ int lsccount = plsymcol->GetCount();
+ for (int l=0; l < lsccount; l++)
+ LineSymbolization2D* plsym = plsymcol->GetAt(l);
+ if (plsym->GetStroke() != NULL)
+ usedColorList->push_back(plsym->GetStroke()->GetColor().substr());
+ // PointRule Symbolization.....
+ if (ppRule != NULL)
+ PointSymbolization2D* ppsym = ppRule->GetSymbolization();
+ if (ppsym)
+ Symbol *sym = ppsym->GetSymbol();
+ MdfModel::BlockSymbol* blockSymbol = dynamic_cast<MdfModel::BlockSymbol*>(sym);
+ MdfModel::FontSymbol* fontSymbol = dynamic_cast<MdfModel::FontSymbol*>(sym);
+ MdfModel::MarkSymbol* markSymbol = dynamic_cast<MdfModel::MarkSymbol*>(sym);
+ MdfModel::TextSymbol* textSymbol = dynamic_cast<MdfModel::TextSymbol*>(sym);
+ MdfModel::W2DSymbol* w2dSymbol = dynamic_cast<MdfModel::W2DSymbol*>(sym);
+ if (blockSymbol != NULL)
+ usedColorList->push_back(blockSymbol->GetBlockColor().substr());
+ usedColorList->push_back(blockSymbol->GetLayerColor().substr());
+ if (fontSymbol != NULL)
+ usedColorList->push_back(fontSymbol->GetForegroundColor().substr());
+ if (markSymbol != NULL)
+ if (markSymbol->GetEdge() != NULL)
+ usedColorList->push_back(markSymbol->GetEdge()->GetColor().substr());
+ if (markSymbol->GetFill() != NULL) {
+ usedColorList->push_back(markSymbol->GetFill()->GetForegroundColor().substr());
+ usedColorList->push_back(markSymbol->GetFill()->GetBackgroundColor().substr());
+ if (textSymbol != NULL)
+ usedColorList->push_back(textSymbol->GetForegroundColor().substr());
+ usedColorList->push_back(textSymbol->GetBackgroundColor().substr());
+ if (w2dSymbol != NULL)
+ usedColorList->push_back(w2dSymbol->GetFillColor().substr());
+ usedColorList->push_back(w2dSymbol->GetLineColor().substr());
+ usedColorList->push_back(w2dSymbol->GetTextColor().substr());
+ } // if pointSymbolization
+ } // end pointRule
+ // CompositeRule Symbolization.....
+ if (pcRule != NULL)
+ CompositeSymbolization* pcsym = pcRule->GetSymbolization();
+ SymbolInstanceCollection* sic = pcsym->GetSymbolCollection();
+ int nInstances = sic->GetCount();
+ for (int i=0; i<nInstances; ++i)
+ {// bool isRef = false;
+ SymbolInstance* instance = sic->GetAt(i);
+ // get the symbol definition, either inlined or by reference
+ SymbolDefinition* symdef = instance->GetSymbolDefinition();
+ if (symdef) // inline
+ FindColorInSymDefHelper(usedColorList, symdef);
+ else
+ { // resourceId
+ const MdfString& symref = instance->GetResourceId(); // symbol reference
+ if (sman)
+ { // if we have a symbolmanager do the lookup
+ MdfModel::SymbolDefinition* symdef = sman->GetSymbolDefinition(symref.c_str());
+ } // for sym instances
+ } // for CompositeRule
+ } // for GetRules
+ } // for GetFeatureTypeStyles
+ return usedColorList;
+/// extract colors from the scalerange, lookup the referenceIds and store them with the map
+void MgMappingUtil::ExtractColors(MgMap* map, MdfModel::VectorScaleRange* scaleRange, Stylizer* sty)
+ // add the colors from this scaleRange and vectorlayer to the map colors
+ try {
+ DefaultStylizer* ds = dynamic_cast<DefaultStylizer*>(sty);
+ SE_SymbolManager* sman = ds?ds->GetSymbolManager():NULL;
+ // parse the scalerange
+ PSTRCOLORLIST vLayerColors = GetUsedColorsFromScaleRange(scaleRange, sman);
+ if (!vLayerColors->empty())
+ map->AddColors2Palette(vLayerColors); // the property setter canonicalizes the palette
+ } catch (exception e) {
+ ACE_DEBUG((LM_DEBUG, L"(%t) %w caught in MappingUtil.ExtractColors\n", e.what()));
+ throw e;
+/// overloaded helper for SimpleSymbolDefinition
+inline void MgMappingUtil::FindColorInSymDefHelper(PSTRCOLORLIST colorList, MdfModel::SimpleSymbolDefinition * symdef)
+ /// the visitor for the graphics
+ class GraphicElementVisitorImpl : public MdfModel::IGraphicElementVisitor
+ public:
+ PSTRCOLORLIST colorList;
+ void VisitPath (Path& path){
+ colorList->push_back(path.GetLineColor().substr());
+ colorList->push_back(path.GetFillColor().substr());
+ void VisitImage(Image& image){};
+ void VisitText (Text& text){};
+ } visitor;
+ if (symdef)
+ MdfModel::LineUsage* lineUsage = symdef->GetLineUsage();
+ if (lineUsage)
+ MdfModel::Path *path = lineUsage->GetDefaultPath();
+ if (path)
+ colorList->push_back(path->GetLineColor().substr());
+ colorList->push_back(path->GetFillColor().substr());
+ MdfModel::GraphicElementCollection* graphElems = symdef->GetGraphics();
+ int gInstances = graphElems->GetCount();
+ for (int i=0; i < gInstances; ++i)
+ MdfModel::GraphicElement* graphics = graphElems->GetAt(i);
+ if (graphics)
+ visitor.colorList = colorList; // use injection to pass reference to list
+ graphics->AcceptVisitor(visitor);
+/// overloaded helper for CompoundSymbolDefinition
+inline void MgMappingUtil::FindColorInSymDefHelper(PSTRCOLORLIST colorList, MdfModel::CompoundSymbolDefinition * symdef)
+ if (symdef)
+ MdfModel::SimpleSymbolCollection* simSymCol = symdef->GetSymbols();
+ int kInstances = simSymCol->GetCount();
+ for (int i=0; i < kInstances; ++i)
+ MdfModel::SimpleSymbol* simsym = simSymCol->GetAt(i);
+ if (simsym)
+ FindColorInSymDefHelper(colorList, simsym->GetSymbolDefinition());
+/// overloaded helper for SymbolDefinition
+inline void MgMappingUtil::FindColorInSymDefHelper(PSTRCOLORLIST colorList, MdfModel::SymbolDefinition * symdef)
+ FindColorInSymDefHelper(colorList, dynamic_cast<MdfModel::SimpleSymbolDefinition*>(symdef));
+ FindColorInSymDefHelper(colorList, dynamic_cast<MdfModel::CompoundSymbolDefinition*>(symdef));
Modified: sandbox/rfc60/MgDev/Server/src/Services/Mapping/MappingUtil.h
--- sandbox/rfc60/MgDev/Server/src/Services/Mapping/MappingUtil.h 2009-11-01 22:36:48 UTC (rev 4327)
+++ sandbox/rfc60/MgDev/Server/src/Services/Mapping/MappingUtil.h 2009-11-01 23:24:51 UTC (rev 4328)
@@ -20,6 +20,9 @@
#include "ServerMappingDllExport.h"
#include "MapGuideCommon.h"
+#include "SE_SymbolManager.h"
+#include "SymbolDefinition.h"
+#include "CompoundSymbolDefinition.h"
//fwd declare
class MgResourceService;
@@ -80,6 +83,16 @@
static void InitializeStylizerCallback();
static MgPolygon* GetPolygonFromEnvelope(MgEnvelope* extent);
+ // RFC60 addition
+ static void ExtractColors(MgMap* map, MdfModel::VectorScaleRange* scaleRange, Stylizer* ds);
+ static PSTRCOLORLIST GetUsedColorsFromScaleRange(MdfModel::VectorScaleRange* vsr, SE_SymbolManager* sm);
+ // helper
+ static void FindColorInSymDefHelper(PSTRCOLORLIST colorList, MdfModel::SymbolDefinition * symdef);
+ static void FindColorInSymDefHelper(PSTRCOLORLIST colorList, MdfModel::CompoundSymbolDefinition * symdef);
+ static void FindColorInSymDefHelper(PSTRCOLORLIST colorList, MdfModel::SimpleSymbolDefinition * symdef);
#endif
Modified: sandbox/rfc60/MgDev/Server/src/Services/Tile/ServerTileService.cpp
--- sandbox/rfc60/MgDev/Server/src/Services/Tile/ServerTileService.cpp 2009-11-01 22:36:48 UTC (rev 4327)
+++ sandbox/rfc60/MgDev/Server/src/Services/Tile/ServerTileService.cpp 2009-11-01 23:24:51 UTC (rev 4328)
@@ -224,6 +224,11 @@
if (sm_mapCache.end() != iter)
cachedMap = SAFE_ADDREF((*iter).second);
+ /// refactored from below
+ cachedMap->Rewind();
+ Ptr<MgStream> stream = new MgStream(cachedMap);
+ map = new MgMap();
+ map->Deserialize(stream);
else
@@ -241,14 +246,14 @@
sm_mapCache[mapString] = SAFE_ADDREF((MgMemoryStreamHelper*)cachedMap);
+ //if (!map)
+ // cachedMap->Rewind();
+ // Ptr<MgStream> stream = new MgStream(cachedMap);
+ // map = new MgMap();
+ // map->Deserialize(stream);
- if (!map)
- cachedMap->Rewind();
- Ptr<MgStream> stream = new MgStream(cachedMap);
- map = new MgMap();
- map->Deserialize(stream);
} // end of mutex scope
double scale = map->GetFiniteDisplayScaleAt(scaleIndex);
@@ -257,7 +262,7 @@
// Render the tile and cache it.
ret = GetTile(tilePathname, map, scaleIndex, baseMapLayerGroupName, tileColumn, tileRow);
break;
+ } // Call ~MgMap DTOR via Ptr<>
MG_CATCH(L"MgServerTileService.GetTile")
More information about the mapguide-commits
