[mapguide-commits] r4333 - trunk/MgDev/Server/src/Services/Feature
svn_mapguide at osgeo.org
Fri Nov 6 13:12:37 EST 2009
Author: brucedechant
Date: 2009-11-06 13:12:36 -0500 (Fri, 06 Nov 2009)
New Revision: 4333
trunk/MgDev/Server/src/Services/Feature/ServerFeatureUtil.cpp
Fix for trac ticket 1135 - Feature Service API throws exception on executing some SQL's
http://trac.osgeo.org/mapguide/ticket/1135
Patch submitted on behalf of Aleck Sun
Notes:
- Changed to use the qualified property name directly.
Modified: trunk/MgDev/Server/src/Services/Feature/ServerFeatureUtil.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerFeatureUtil.cpp 2009-11-06 04:28:05 UTC (rev 4332)
+++ trunk/MgDev/Server/src/Services/Feature/ServerFeatureUtil.cpp 2009-11-06 18:12:36 UTC (rev 4333)
@@ -1777,13 +1777,6 @@
Ptr<MgNullableProperty> prop;
- STRING propName = qualifiedPropName.substr(qualifiedPropName.rfind(L".")+1);
- // If not qualified name specified, take qualifiedPropName as property name
- if (propName.empty())
- propName = qualifiedPropName;
switch(type)
case MgPropertyType::Boolean: /// Boolean true/false value
@@ -1791,13 +1784,13 @@
bool val = false;
bool isNull = true;
- if (!reader->IsNull(propName.c_str()))
+ if (!reader->IsNull(qualifiedPropName.c_str()))
- val = reader->GetBoolean(propName.c_str());
+ val = reader->GetBoolean(qualifiedPropName.c_str());
isNull = false;
- prop = new MgBooleanProperty(propName, val);
+ prop = new MgBooleanProperty(qualifiedPropName, val);
prop->SetNull(isNull);
break;
@@ -1806,13 +1799,13 @@
FdoByte val = 0;
bool isNull = true;
- val = reader->GetByte(propName.c_str());
+ val = reader->GetByte(qualifiedPropName.c_str());
isNull = false;
- prop = new MgByteProperty(propName, (BYTE)val);
+ prop = new MgByteProperty(qualifiedPropName, (BYTE)val);
break;
@@ -1821,13 +1814,13 @@
Ptr<MgDateTime> dateTime;
bool isNull = true;
- dateTime = reader->GetDateTime(propName.c_str());
+ dateTime = reader->GetDateTime(qualifiedPropName.c_str());
isNull = false;
- prop = new MgDateTimeProperty(propName, dateTime);
+ prop = new MgDateTimeProperty(qualifiedPropName, dateTime);
break;
@@ -1836,13 +1829,13 @@
float val = 0.0f;
bool isNull = true;
- val = reader->GetSingle(propName.c_str());
+ val = reader->GetSingle(qualifiedPropName.c_str());
isNull = false;
- prop = new MgSingleProperty(propName, (float)val);
+ prop = new MgSingleProperty(qualifiedPropName, (float)val);
break;
@@ -1851,13 +1844,13 @@
double val = 0.0;
bool isNull = true;
- val = reader->GetDouble(propName.c_str());
+ val = reader->GetDouble(qualifiedPropName.c_str());
isNull = false;
- prop = new MgDoubleProperty(propName, (double)val);
+ prop = new MgDoubleProperty(qualifiedPropName, (double)val);
break;
@@ -1866,13 +1859,13 @@
FdoInt16 val = 0;
bool isNull = true;
- val = reader->GetInt16(propName.c_str());
+ val = reader->GetInt16(qualifiedPropName.c_str());
isNull = false;
- prop = new MgInt16Property(propName, (INT16)val);
+ prop = new MgInt16Property(qualifiedPropName, (INT16)val);
break;
@@ -1881,13 +1874,13 @@
FdoInt32 val = 0;
bool isNull = true;
- val = reader->GetInt32(propName.c_str());
+ val = reader->GetInt32(qualifiedPropName.c_str());
isNull = false;
- prop = new MgInt32Property(propName, (INT32)val);
+ prop = new MgInt32Property(qualifiedPropName, (INT32)val);
break;
@@ -1896,13 +1889,13 @@
FdoInt64 val = 0;
bool isNull = true;
- val = reader->GetInt64(propName.c_str());
+ val = reader->GetInt64(qualifiedPropName.c_str());
isNull = false;
- prop = new MgInt64Property(propName, (INT64)val);
+ prop = new MgInt64Property(qualifiedPropName, (INT64)val);
break;
@@ -1911,7 +1904,7 @@
STRING val = L"";
bool isNull = true;
// A try/catch block is used here for case where the FDO computed
// property field is used. When the property value is null, the computed
@@ -1920,7 +1913,7 @@
// Instead, it will be handled by catching the exception and setting the isNull flag.
try
- val = reader->GetString(propName.c_str());
+ val = reader->GetString(qualifiedPropName.c_str());
isNull = false;
catch (FdoException* e)
@@ -1939,7 +1932,7 @@
- prop = new MgStringProperty(propName, val);
+ prop = new MgStringProperty(qualifiedPropName, val);
break;
@@ -1948,13 +1941,13 @@
Ptr<MgByteReader> val;
bool isNull = true;
isNull = false;
- val = reader->GetBLOB(propName.c_str());
+ val = reader->GetBLOB(qualifiedPropName.c_str());
- prop = new MgBlobProperty(propName, val);
+ prop = new MgBlobProperty(qualifiedPropName, val);
break;
@@ -1963,13 +1956,13 @@
bool isNull = true;
isNull = false;
- val = reader->GetCLOB(propName.c_str());
+ val = reader->GetCLOB(qualifiedPropName.c_str());
- prop = new MgClobProperty(propName, val);
+ prop = new MgClobProperty(qualifiedPropName, val);
break;
@@ -1978,13 +1971,13 @@
Ptr<MgFeatureReader> val;
bool isNull = true;
isNull = false;
- val = ((MgFeatureReader*)(reader))->GetFeatureObject(propName.c_str());
+ val = ((MgFeatureReader*)(reader))->GetFeatureObject(qualifiedPropName.c_str());
- prop = new MgFeatureProperty(propName, val);
+ prop = new MgFeatureProperty(qualifiedPropName, val);
break;
@@ -1993,13 +1986,13 @@
bool isNull = true;
- val = reader->GetGeometry(propName.c_str());
+ val = reader->GetGeometry(qualifiedPropName.c_str());
isNull = false;
- prop = new MgGeometryProperty(propName, val);
+ prop = new MgGeometryProperty(qualifiedPropName, val);
break;
@@ -2008,13 +2001,13 @@
Ptr<MgRaster> val;
bool isNull = true;
- val = reader->GetRaster(propName.c_str());
+ val = reader->GetRaster(qualifiedPropName.c_str());
isNull = false;
- prop = new MgRasterProperty(propName, val);
+ prop = new MgRasterProperty(qualifiedPropName, val);
break;
More information about the mapguide-commits
