[mapguide-commits] r4335 - in trunk/Tools/Maestro: MaestroAPI
MgCooker
svn_mapguide at osgeo.org
Mon Nov 9 13:26:32 EST 2009
Author: ksgeograf
Date: 2009-11-09 13:26:32 -0500 (Mon, 09 Nov 2009)
New Revision: 4335
trunk/Tools/Maestro/MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
trunk/Tools/Maestro/MgCooker/BatchSettings.cs
trunk/Tools/Maestro/MgCooker/MgCooker.sln
trunk/Tools/Maestro/MgCooker/Program.cs
trunk/Tools/Maestro/MgCooker/Progress.cs
trunk/Tools/Maestro/MgCooker/RenderThread.cs
trunk/Tools/Maestro/MgCooker/SetupRun.Designer.cs
trunk/Tools/Maestro/MgCooker/SetupRun.cs
trunk/Tools/Maestro/MgCooker/SetupRun.resx
Maestro, MgCooker fixes:
Fixed issue #1086, actually rowcount and columncount were swapped
Fixed issue #1087, Alternate Bounds
Fixed issue #1103, Chrash on large bounds
Modified: trunk/Tools/Maestro/MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
--- trunk/Tools/Maestro/MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2009-11-06 21:25:06 UTC (rev 4334)
+++ trunk/Tools/Maestro/MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2009-11-09 18:26:32 UTC (rev 4335)
@@ -1,7 +1,7 @@
<Project DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003" ToolsVersion="3.5">
<PropertyGroup>
<ProjectType>Local</ProjectType>
- <ProductVersion>8.0.50727</ProductVersion>
+ <ProductVersion>9.0.21022</ProductVersion>
<SchemaVersion>2.0</SchemaVersion>
<ProjectGuid>{290B027E-3649-4A60-A9BF-0544831435E2}</ProjectGuid>
<Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
@@ -27,6 +27,7 @@
<OldToolsVersion>2.0</OldToolsVersion>
<UpgradeBackupLocation>
</UpgradeBackupLocation>
+ <IsWebBootstrapper>true</IsWebBootstrapper>
<PublishUrl>http://localhost/OSGeo.MapGuide.MaestroAPI/</PublishUrl>
<Install>true</Install>
<InstallFrom>Web</InstallFrom>
@@ -39,7 +40,6 @@
<MapFileExtensions>true</MapFileExtensions>
<ApplicationRevision>0</ApplicationRevision>
<ApplicationVersion>1.0.0.%2a</ApplicationVersion>
- <IsWebBootstrapper>true</IsWebBootstrapper>
<UseApplicationTrust>false</UseApplicationTrust>
<BootstrapperEnabled>true</BootstrapperEnabled>
</PropertyGroup>
Modified: trunk/Tools/Maestro/MgCooker/BatchSettings.cs
--- trunk/Tools/Maestro/MgCooker/BatchSettings.cs 2009-11-06 21:25:06 UTC (rev 4334)
+++ trunk/Tools/Maestro/MgCooker/BatchSettings.cs 2009-11-09 18:26:32 UTC (rev 4335)
@@ -378,6 +378,26 @@
public string[] Groups { get { return m_groups; } }
/// <summary>
+ /// The number of tiles to offset the row counter with
+ /// </summary>
+ private int m_rowTileOffset = 0;
+ /// <summary>
+ /// The number of tiles to offset the col counter with
+ /// </summary>
+ private int m_colTileOffset = 0;
+ /// <summary>
+ /// The tile offset for row indexes for tiles
+ /// </summary>
+ public int RowTileOffset { get { return m_rowTileOffset; } }
+ /// <summary>
+ /// The tile offset for col indexes for tiles
+ /// </summary>
+ public int ColTileOffset { get { return m_colTileOffset; } }
+ /// <summary>
/// Constructs a new map to be processed
/// </summary>
/// <param name="parent">The parent entry</param>
@@ -416,7 +436,7 @@
return;
- MaestroAPI.Box2DType extents = m_maxExtent == null ? m_mapdefinition.Extents : m_maxExtent;
+ MaestroAPI.Box2DType extents = this.MaxExtent ?? m_mapdefinition.Extents;
double maxscale = m_maxscale;
m_dimensions = new long[this.Resolutions][];
@@ -436,9 +456,22 @@
//This is the algorithm proposed by the MapGuide team:
//http://www.nabble.com/Pre-Genererate--tiles-for-the-entire-map-at-all-pre-defined-zoom-scales-to6074037.html#a6078663
+ //The tile extent in meters
+ double tileWidth =((INCH_TO_METER / m_parent.Config.DPI * m_parent.Config.TileWidth) * (scale));
+ double tileHeight = ((INCH_TO_METER / m_parent.Config.DPI * m_parent.Config.TileHeight) * (scale));
//Using this algorithm, yields a negative number of columns/rows, if the max scale is larger than the max extent of the map.
- rows = Math.Max(1, (int)Math.Ceiling((width_in_meters / ((INCH_TO_METER / m_parent.Config.DPI * m_parent.Config.TileWidth) * (scale)))));
- cols = Math.Max(1, (int)Math.Ceiling((height_in_meters / ((INCH_TO_METER / m_parent.Config.DPI * m_parent.Config.TileHeight) * (scale)))));
+ rows = Math.Max(1, (int)Math.Ceiling((height_in_meters / tileHeight)));
+ cols = Math.Max(1, (int)Math.Ceiling((width_in_meters / tileWidth)));
+ if (m_maxExtent != null)
+ //The extent is overridden, so we need to adjust the start offsets
+ double offsetX = MaxExtent.MinX - m_mapdefinition.Extents.MinX;
+ double offsetY = MaxExtent.MinY - m_mapdefinition.Extents.MinY;
+ m_rowTileOffset = (int)Math.Ceiling(offsetY / tileHeight);
+ m_colTileOffset = (int)Math.Ceiling(offsetX / tileWidth);
else
@@ -447,18 +480,21 @@
//scale ranges. Eg. if max scale range is 1:200, then scale range 1:100 is twice the size,
//meaning the full map at 1:100 fills 3840x2560 pixels.
//The width/height is then used to calculate the number of rows and columns of 300x300 pixel tiles.
+ //The purpose of this method is to enabled tile generation without access to
+ //coordinate system properties
long pw = (long)(m_parent.Config.DisplayResolutionWidth * (1 / (scale / maxscale)));
long ph = (long)(m_parent.Config.DisplayResolutionHeight * (1 / (scale / maxscale)));
- rows = (pw + (m_parent.Config.TileWidth - 1)) / m_parent.Config.TileWidth;
- cols = (ph + (m_parent.Config.TileHeight - 1)) / m_parent.Config.TileHeight;
+ rows = (ph + (m_parent.Config.TileHeight - 1)) / m_parent.Config.TileHeight;
+ cols = (pw + (m_parent.Config.TileWidth - 1)) / m_parent.Config.TileWidth;
rows += rows % 2;
cols += cols % 2;
m_dimensions[i] = new long[] {rows, cols};
@@ -549,33 +585,14 @@
int rows = (int)m_dimensions[scaleindex][0];
int cols = (int)m_dimensions[scaleindex][1];
- RenderThreads settings = new RenderThreads(this, m_parent, m_scaleindexmap[scaleindex], group, m_mapdefinition.ResourceId);
+ //If the MaxExtents are different from the actual bounds, we need a start offset offset
- if (m_parent.Config.RandomizeTileSequence)
- List<KeyValuePair<int, int>> tmp = new List<KeyValuePair<int, int>>();
- for (int r = 0; r < rows; r++)
- for (int c = 0; c < cols; c++)
- tmp.Add(new KeyValuePair<int, int>(r, c));
+ RenderThreads settings = new RenderThreads(this, m_parent, m_scaleindexmap[scaleindex], group, m_mapdefinition.ResourceId, rows, cols, m_rowTileOffset, m_colTileOffset, m_parent.Config.RandomizeTileSequence);
+ settings.RunAndWait();
- Random ra = new Random();
- while (tmp.Count > 0)
- int j = ra.Next(0, tmp.Count);
- settings.TileSet.Enqueue(tmp[j]);
- tmp.RemoveAt(j);
- else
- settings.TileSet.Enqueue(new KeyValuePair<int, int>(r, c));
- settings.RunAndWait();
if (settings.TileSet.Count != 0 && !m_parent.Cancel)
- throw new Exception("One or more threads chrashed, and the tile set was only partially created");
+ throw new Exception("All or more threads chrashed, and the tile set was only partially created");
m_parent.InvokeFinishRendering(this, group, scaleindex);
Modified: trunk/Tools/Maestro/MgCooker/MgCooker.sln
--- trunk/Tools/Maestro/MgCooker/MgCooker.sln 2009-11-06 21:25:06 UTC (rev 4334)
+++ trunk/Tools/Maestro/MgCooker/MgCooker.sln 2009-11-09 18:26:32 UTC (rev 4335)
@@ -1,6 +1,6 @@
-Microsoft Visual Studio Solution File, Format Version 9.00
-# Visual Studio 2005
+Microsoft Visual Studio Solution File, Format Version 10.00
+# Visual Studio 2008
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "MgCooker", "MgCooker.csproj", "{C76FFEBF-F047-4BE8-983C-BF8BF3CFB3D9}"
EndProject
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "OSGeo.MapGuide.MaestroAPI", "..\MaestroAPI\OSGeo.MapGuide.MaestroAPI.csproj", "{290B027E-3649-4A60-A9BF-0544831435E2}"
Modified: trunk/Tools/Maestro/MgCooker/Program.cs
--- trunk/Tools/Maestro/MgCooker/Program.cs 2009-11-06 21:25:06 UTC (rev 4334)
+++ trunk/Tools/Maestro/MgCooker/Program.cs 2009-11-09 18:26:32 UTC (rev 4335)
@@ -58,6 +58,7 @@
//mapdefinition=
//scaleindex=0,1,2,3,4,5
//basegroups="x","y"
+ //extentoverride=minx,miny,maxx,maxy
string mapagent = "http://localhost/mapguide";
string username = "Anonymous";
@@ -75,7 +76,8 @@
string DPI = "";
string metersPerUnit = "";
+ MaestroAPI.Box2DType overrideExtents = null;
List<string> largs = new List<string>(args);
Dictionary<string, string> opts = CommandLineParser.ExtractOptions(largs);
if (opts.ContainsKey("mapagent"))
@@ -105,7 +107,32 @@
DPI = opts["DPI"];
if (opts.ContainsKey("metersperunit"))
metersPerUnit = opts["metersperunit"];
+ if (opts.ContainsKey("extentoverride"))
+ string[] parts = opts["extentoverride"].Split(',');
+ if (parts.Length == 4)
+ double minx;
+ double miny;
+ double maxx;
+ double maxy;
+ if (
+ double.TryParse(parts[0], System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture, out minx) &&
+ double.TryParse(parts[1], System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture, out miny) &&
+ double.TryParse(parts[2], System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture, out maxx) &&
+ double.TryParse(parts[3], System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture, out maxy)
+ overrideExtents = new OSGeo.MapGuide.MaestroAPI.Box2DType();
+ overrideExtents.MinX = minx;
+ overrideExtents.MinY = miny;
+ overrideExtents.MaxX = maxx;
+ overrideExtents.MaxY = maxy;
try
Console.Clear();
@@ -206,6 +233,10 @@
if (opts.ContainsKey("threadcount") && int.TryParse(opts["threadcount"], out x) && x > 0)
bx.Config.ThreadCount = x;
+ if (overrideExtents != null)
+ foreach (BatchMap bm in bx.Maps)
+ bm.MaxExtent = overrideExtents;
if (largs.IndexOf("/commandline") < 0 && largs.IndexOf("commandline") < 0)
Progress pg = new Progress(bx);
Modified: trunk/Tools/Maestro/MgCooker/Progress.cs
--- trunk/Tools/Maestro/MgCooker/Progress.cs 2009-11-06 21:25:06 UTC (rev 4334)
+++ trunk/Tools/Maestro/MgCooker/Progress.cs 2009-11-09 18:26:32 UTC (rev 4335)
@@ -30,7 +30,6 @@
public partial class Progress : Form
private BatchSettings m_bx;
- private long m_update;
private List<TimeSpan> m_tileRuns;
private long m_tileCount;
private DateTime m_lastUpdate;
Modified: trunk/Tools/Maestro/MgCooker/RenderThread.cs
--- trunk/Tools/Maestro/MgCooker/RenderThread.cs 2009-11-06 21:25:06 UTC (rev 4334)
+++ trunk/Tools/Maestro/MgCooker/RenderThread.cs 2009-11-09 18:26:32 UTC (rev 4335)
@@ -63,7 +63,15 @@
private string MapDefinition;
private BatchMap Invoker;
- public RenderThreads(BatchMap invoker, BatchSettings parent, int scale, string group, string mapdef)
+ private bool Randomize;
+ private int Rows;
+ private int Cols;
+ private int RowOffset;
+ private int ColOffset;
+ private bool FillerComplete = false;
+ public RenderThreads(BatchMap invoker, BatchSettings parent, int scale, string group, string mapdef, int rows, int cols, int rowOffset, int colOffset, bool randomize)
TileSet = new Queue<KeyValuePair<int, int>>();
SyncLock = new object();
@@ -75,10 +83,18 @@
this.Parent = parent;
this.MapDefinition = mapdef;
this.Invoker = invoker;
+ Randomize = randomize;
+ Rows = rows;
+ Cols = cols;
+ this.RowOffset = rowOffset;
+ this.ColOffset = colOffset;
public void RunAndWait()
+ System.Threading.ThreadPool.QueueUserWorkItem(
+ new System.Threading.WaitCallback(QueueFiller));
for (int i = 0; i < Parent.Config.ThreadCount; i++)
@@ -146,6 +162,91 @@
+ /// <summary>
+ /// Helper that fills the queue from a thread
+ /// </summary>
+ /// <param name="dummy">Unused parameter</param>
+ private void QueueFiller(object dummy)
+ try
+ if (Randomize)
+ Random ra = new Random();
+ List<int> rows = new List<int>();
+ int[] cols_full = new int[Cols];
+ for (int i = 0; i < Rows; i++)
+ rows.Add(i);
+ for (int i = 0; i < Cols; i++)
+ cols_full[i] = i;
+ //TODO: This is not really random, because we select
+ //a row, and then random columns
+ //Unfortunately, I have yet to find a truly random
+ //pair generation method that is space efficient :(
+ while (rows.Count > 0)
+ int ri = ra.Next(0, rows.Count);
+ int r = rows[ri];
+ rows.RemoveAt(ri);
+ List<int> cols = new List<int>(cols_full);
+ while (cols.Count > 0)
+ int ci = ra.Next(0, cols.Count);
+ int c = cols[ci];
+ cols.RemoveAt(ci);
+ AddPairToQueue(r + RowOffset, c + ColOffset);
+ else
+ //Non-random is straightforward
+ for (int r = 0; r < Rows; r++)
+ for (int c = 0; c < Cols; c++)
+ finally
+ lock(SyncLock)
+ FillerComplete = true;
+ /// <summary>
+ /// Helper to add a pair to the queue, but prevents huge queue lists
+ /// </summary>
+ /// <param name="r">The row component of the pair</param>
+ /// <param name="c">The column component of the pair</param>
+ private void AddPairToQueue(int r, int c)
+ bool added = false;
+ while (!added)
+ lock (SyncLock)
+ if (TileSet.Count < 500) //Keep at most 500 items in queue
+ TileSet.Enqueue(new KeyValuePair<int, int>(r, c));
+ added = true;
+ if (!added) //Prevent CPU spinning
+ System.Threading.Thread.Sleep(500);
+ /// <summary>
+ /// Invokes the render callback method
+ /// </summary>
private void ThreadRender(object dummy)
try
@@ -162,20 +263,24 @@
while (!Parent.Cancel)
- KeyValuePair<int, int> round;
+ KeyValuePair<int, int>? round = null;
lock (SyncLock)
- if (TileSet.Count == 0)
- return;
+ if (TileSet.Count == 0 && FillerComplete)
+ return; //No more data
- round = TileSet.Dequeue(); ;
+ if (TileSet.Count > 0)
+ round = TileSet.Dequeue();
if (Parent.Cancel)
return;
- RenderTile(ev, con, round.Key, round.Value, Scale, Group);
+ if (round == null) //No data, but producer is still running
+ else
+ RenderTile(ev, con, round.Value.Key, round.Value.Value, Scale, Group);
Modified: trunk/Tools/Maestro/MgCooker/SetupRun.Designer.cs
--- trunk/Tools/Maestro/MgCooker/SetupRun.Designer.cs 2009-11-06 21:25:06 UTC (rev 4334)
+++ trunk/Tools/Maestro/MgCooker/SetupRun.Designer.cs 2009-11-09 18:26:32 UTC (rev 4335)
@@ -34,10 +34,21 @@
this.button3 = new System.Windows.Forms.Button();
this.button2 = new System.Windows.Forms.Button();
this.button1 = new System.Windows.Forms.Button();
- this.treeView1 = new System.Windows.Forms.TreeView();
+ this.MapTree = new System.Windows.Forms.TreeView();
this.imageList1 = new System.Windows.Forms.ImageList(this.components);
this.saveFileDialog1 = new System.Windows.Forms.SaveFileDialog();
this.panel2 = new System.Windows.Forms.Panel();
+ this.BoundsOverride = new System.Windows.Forms.GroupBox();
+ this.ModfiedOverrideWarning = new System.Windows.Forms.Label();
+ this.ResetBounds = new System.Windows.Forms.Button();
+ this.txtUpperY = new System.Windows.Forms.TextBox();
+ this.label4 = new System.Windows.Forms.Label();
+ this.txtUpperX = new System.Windows.Forms.TextBox();
+ this.label5 = new System.Windows.Forms.Label();
+ this.txtLowerY = new System.Windows.Forms.TextBox();
+ this.label10 = new System.Windows.Forms.Label();
+ this.txtLowerX = new System.Windows.Forms.TextBox();
+ this.label11 = new System.Windows.Forms.Label();
this.groupBox1 = new System.Windows.Forms.GroupBox();
this.UseNativeAPI = new System.Windows.Forms.CheckBox();
this.Password = new System.Windows.Forms.TextBox();
@@ -64,6 +75,7 @@
this.toolTip1 = new System.Windows.Forms.ToolTip(this.components);
this.panel1.SuspendLayout();
this.panel2.SuspendLayout();
+ this.BoundsOverride.SuspendLayout();
this.groupBox1.SuspendLayout();
this.groupBox3.SuspendLayout();
((System.ComponentModel.ISupportInitialize)(this.ThreadCount)).BeginInit();
@@ -81,7 +93,7 @@
this.panel1.Controls.Add(this.button2);
this.panel1.Controls.Add(this.button1);
this.panel1.Dock = System.Windows.Forms.DockStyle.Bottom;
- this.panel1.Location = new System.Drawing.Point(0, 424);
+ this.panel1.Location = new System.Drawing.Point(0, 537);
this.panel1.Name = "panel1";
this.panel1.Size = new System.Drawing.Size(565, 41);
this.panel1.TabIndex = 0;
@@ -120,19 +132,19 @@
this.button1.UseVisualStyleBackColor = true;
this.button1.Click += new System.EventHandler(this.button1_Click);
- // treeView1
+ // MapTree
- this.treeView1.CheckBoxes = true;
- this.treeView1.Dock = System.Windows.Forms.DockStyle.Fill;
- this.treeView1.ImageIndex = 0;
- this.treeView1.ImageList = this.imageList1;
- this.treeView1.Location = new System.Drawing.Point(0, 0);
- this.treeView1.Name = "treeView1";
- this.treeView1.SelectedImageIndex = 0;
- this.treeView1.Size = new System.Drawing.Size(293, 424);
- this.treeView1.TabIndex = 1;
- this.treeView1.AfterCheck += new System.Windows.Forms.TreeViewEventHandler(this.treeView1_AfterCheck);
- this.treeView1.AfterSelect += new System.Windows.Forms.TreeViewEventHandler(this.treeView1_AfterSelect);
+ this.MapTree.CheckBoxes = true;
+ this.MapTree.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.MapTree.ImageIndex = 0;
+ this.MapTree.ImageList = this.imageList1;
+ this.MapTree.Location = new System.Drawing.Point(0, 0);
+ this.MapTree.Name = "MapTree";
+ this.MapTree.SelectedImageIndex = 0;
+ this.MapTree.Size = new System.Drawing.Size(293, 537);
+ this.MapTree.TabIndex = 1;
+ this.MapTree.AfterCheck += new System.Windows.Forms.TreeViewEventHandler(this.treeView1_AfterCheck);
+ this.MapTree.AfterSelect += new System.Windows.Forms.TreeViewEventHandler(this.MapTree_AfterSelect);
// imageList1
@@ -150,15 +162,126 @@
// panel2
+ this.panel2.Controls.Add(this.BoundsOverride);
this.panel2.Controls.Add(this.groupBox1);
this.panel2.Controls.Add(this.groupBox3);
this.panel2.Controls.Add(this.groupBox2);
this.panel2.Dock = System.Windows.Forms.DockStyle.Right;
this.panel2.Location = new System.Drawing.Point(293, 0);
this.panel2.Name = "panel2";
- this.panel2.Size = new System.Drawing.Size(272, 424);
+ this.panel2.Size = new System.Drawing.Size(272, 537);
this.panel2.TabIndex = 2;
+ // BoundsOverride
+ this.BoundsOverride.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ | System.Windows.Forms.AnchorStyles.Right)));
+ this.BoundsOverride.Controls.Add(this.ModfiedOverrideWarning);
+ this.BoundsOverride.Controls.Add(this.ResetBounds);
+ this.BoundsOverride.Controls.Add(this.txtUpperY);
+ this.BoundsOverride.Controls.Add(this.label4);
+ this.BoundsOverride.Controls.Add(this.txtUpperX);
+ this.BoundsOverride.Controls.Add(this.label5);
+ this.BoundsOverride.Controls.Add(this.txtLowerY);
+ this.BoundsOverride.Controls.Add(this.label10);
+ this.BoundsOverride.Controls.Add(this.txtLowerX);
+ this.BoundsOverride.Controls.Add(this.label11);
+ this.BoundsOverride.Enabled = false;
+ this.BoundsOverride.Location = new System.Drawing.Point(12, 424);
+ this.BoundsOverride.Name = "BoundsOverride";
+ this.BoundsOverride.Size = new System.Drawing.Size(248, 120);
+ this.BoundsOverride.TabIndex = 12;
+ this.BoundsOverride.TabStop = false;
+ this.BoundsOverride.Text = "Override bounds";
+ // ModfiedOverrideWarning
+ this.ModfiedOverrideWarning.AutoSize = true;
+ this.ModfiedOverrideWarning.Location = new System.Drawing.Point(8, 96);
+ this.ModfiedOverrideWarning.Name = "ModfiedOverrideWarning";
+ this.ModfiedOverrideWarning.Size = new System.Drawing.Size(105, 13);
+ this.ModfiedOverrideWarning.TabIndex = 19;
+ this.ModfiedOverrideWarning.Text = "Coordinates modified";
+ this.ModfiedOverrideWarning.Visible = false;
+ // ResetBounds
+ this.ResetBounds.Location = new System.Drawing.Point(136, 88);
+ this.ResetBounds.Name = "ResetBounds";
+ this.ResetBounds.Size = new System.Drawing.Size(88, 24);
+ this.ResetBounds.TabIndex = 18;
+ this.ResetBounds.Text = "Reset";
+ this.ResetBounds.UseVisualStyleBackColor = true;
+ this.ResetBounds.Click += new System.EventHandler(this.ResetBounds_Click);
+ // txtUpperY
+ this.txtUpperY.Location = new System.Drawing.Point(144, 56);
+ this.txtUpperY.Name = "txtUpperY";
+ this.txtUpperY.Size = new System.Drawing.Size(80, 20);
+ this.txtUpperY.TabIndex = 17;
+ this.txtUpperY.TextChanged += new System.EventHandler(this.CoordinateItem_TextChanged);
+ // label4
+ this.label4.FlatStyle = System.Windows.Forms.FlatStyle.System;
+ this.label4.Location = new System.Drawing.Point(120, 56);
+ this.label4.Name = "label4";
+ this.label4.Size = new System.Drawing.Size(16, 16);
+ this.label4.TabIndex = 16;
+ this.label4.Text = "Y";
+ // txtUpperX
+ this.txtUpperX.Location = new System.Drawing.Point(32, 56);
+ this.txtUpperX.Name = "txtUpperX";
+ this.txtUpperX.Size = new System.Drawing.Size(72, 20);
+ this.txtUpperX.TabIndex = 15;
+ this.txtUpperX.TextChanged += new System.EventHandler(this.CoordinateItem_TextChanged);
+ // label5
+ this.label5.FlatStyle = System.Windows.Forms.FlatStyle.System;
+ this.label5.Location = new System.Drawing.Point(8, 56);
+ this.label5.Name = "label5";
+ this.label5.Size = new System.Drawing.Size(16, 16);
+ this.label5.TabIndex = 14;
+ this.label5.Text = "X";
+ // txtLowerY
+ this.txtLowerY.Location = new System.Drawing.Point(144, 24);
+ this.txtLowerY.Name = "txtLowerY";
+ this.txtLowerY.Size = new System.Drawing.Size(80, 20);
+ this.txtLowerY.TabIndex = 13;
+ this.txtLowerY.TextChanged += new System.EventHandler(this.CoordinateItem_TextChanged);
+ // label10
+ this.label10.FlatStyle = System.Windows.Forms.FlatStyle.System;
+ this.label10.Location = new System.Drawing.Point(120, 24);
+ this.label10.Name = "label10";
+ this.label10.Size = new System.Drawing.Size(16, 16);
+ this.label10.TabIndex = 12;
+ this.label10.Text = "Y";
+ // txtLowerX
+ this.txtLowerX.Location = new System.Drawing.Point(32, 24);
+ this.txtLowerX.Name = "txtLowerX";
+ this.txtLowerX.Size = new System.Drawing.Size(72, 20);
+ this.txtLowerX.TabIndex = 11;
+ this.txtLowerX.TextChanged += new System.EventHandler(this.CoordinateItem_TextChanged);
+ // label11
+ this.label11.FlatStyle = System.Windows.Forms.FlatStyle.System;
+ this.label11.Location = new System.Drawing.Point(8, 24);
+ this.label11.Name = "label11";
+ this.label11.Size = new System.Drawing.Size(16, 16);
+ this.label11.TabIndex = 10;
+ this.label11.Text = "X";
// groupBox1
this.groupBox1.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
@@ -436,16 +559,18 @@
this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
- this.ClientSize = new System.Drawing.Size(565, 465);
- this.Controls.Add(this.treeView1);
+ this.ClientSize = new System.Drawing.Size(565, 578);
+ this.Controls.Add(this.MapTree);
this.Controls.Add(this.panel2);
this.Controls.Add(this.panel1);
this.Icon = ((System.Drawing.Icon)(resources.GetObject("$this.Icon")));
- this.MinimumSize = new System.Drawing.Size(449, 492);
+ this.MinimumSize = new System.Drawing.Size(581, 598);
this.Name = "SetupRun";
this.Text = "Setup a tile build";
this.panel1.ResumeLayout(false);
this.panel2.ResumeLayout(false);
+ this.BoundsOverride.ResumeLayout(false);
+ this.BoundsOverride.PerformLayout();
this.groupBox1.ResumeLayout(false);
this.groupBox1.PerformLayout();
this.groupBox3.ResumeLayout(false);
@@ -469,7 +594,7 @@
private System.Windows.Forms.Panel panel1;
private System.Windows.Forms.Button button2;
private System.Windows.Forms.Button button1;
- private System.Windows.Forms.TreeView treeView1;
+ private System.Windows.Forms.TreeView MapTree;
private System.Windows.Forms.Button button3;
private System.Windows.Forms.SaveFileDialog saveFileDialog1;
private System.Windows.Forms.ImageList imageList1;
@@ -498,5 +623,16 @@
private System.Windows.Forms.Panel TilesetLimitPanel;
private System.Windows.Forms.ToolTip toolTip1;
private System.Windows.Forms.CheckBox RandomTileOrder;
+ private System.Windows.Forms.GroupBox BoundsOverride;
+ private System.Windows.Forms.TextBox txtUpperY;
+ private System.Windows.Forms.Label label4;
+ private System.Windows.Forms.TextBox txtUpperX;
+ private System.Windows.Forms.Label label5;
+ private System.Windows.Forms.TextBox txtLowerY;
+ private System.Windows.Forms.Label label10;
+ private System.Windows.Forms.TextBox txtLowerX;
+ private System.Windows.Forms.Label label11;
+ private System.Windows.Forms.Button ResetBounds;
+ private System.Windows.Forms.Label ModfiedOverrideWarning;
\ No newline at end of file
Modified: trunk/Tools/Maestro/MgCooker/SetupRun.cs
--- trunk/Tools/Maestro/MgCooker/SetupRun.cs 2009-11-06 21:25:06 UTC (rev 4334)
+++ trunk/Tools/Maestro/MgCooker/SetupRun.cs 2009-11-09 18:26:32 UTC (rev 4335)
@@ -31,6 +31,8 @@
private MaestroAPI.ServerConnectionI m_connection;
private Dictionary<string, string> m_commandlineargs;
+ private Dictionary<string, MaestroAPI.Box2DType> m_coordinateOverrides;
+ private bool m_isUpdating = false;
private SetupRun()
@@ -43,6 +45,7 @@
m_connection = connection;
m_commandlineargs = args;
+ m_coordinateOverrides = new Dictionary<string, OSGeo.MapGuide.MaestroAPI.Box2DType>();
if (m_commandlineargs.ContainsKey("mapdefinitions"))
m_commandlineargs.Remove("mapdefinitions");
@@ -103,15 +106,16 @@
maps = tmp.ToArray();
- treeView1.Nodes.Clear();
+ MapTree.Nodes.Clear();
foreach (string m in maps)
MaestroAPI.MapDefinition mdef = m_connection.GetMapDefinition(m);
- if (mdef.BaseMapDefinition != null && mdef.BaseMapDefinition.FiniteDisplayScale != null && mdef.BaseMapDefinition.BaseMapLayerGroup != null)
+ if (mdef.BaseMapDefinition != null && mdef.BaseMapDefinition.FiniteDisplayScale != null && mdef.BaseMapDefinition.BaseMapLayerGroup != null && mdef.BaseMapDefinition.BaseMapLayerGroup.Count > 0)
- TreeNode mn = treeView1.Nodes.Add(m);
+ TreeNode mn = MapTree.Nodes.Add(m);
//mn.Checked = true;
- mn.ImageIndex = mn.SelectedImageIndex = 0;
+ mn.ImageIndex = mn.SelectedImageIndex = 0;
+ mn.Tag = mdef;
foreach (MaestroAPI.BaseMapLayerGroupCommonType g in mdef.BaseMapDefinition.BaseMapLayerGroup)
TreeNode gn = mn.Nodes.Add(g.Name);
@@ -129,7 +133,6 @@
mn.Expand();
@@ -205,6 +208,8 @@
BatchMap bm = new BatchMap(bx, c.MapDefinition);
bm.SetGroups(new string[] { c.Group });
bm.SetScales(c.ScaleIndexes);
+ if (c.ExtentOverride != null)
+ bm.MaxExtent = c.ExtentOverride;
bx.Maps.Add(bm);
@@ -221,7 +226,7 @@
private List<Config> ReadTree()
List<Config> lst = new List<Config>();
- foreach(TreeNode mn in treeView1.Nodes)
+ foreach(TreeNode mn in MapTree.Nodes)
if (mn.Checked)
foreach(TreeNode gn in mn.Nodes)
@@ -233,7 +238,7 @@
ix.Add(sn.Index);
if (ix.Count > 0)
- lst.Add(new Config(mn.Text, gn.Text, ix.ToArray()));
+ lst.Add(new Config(mn.Text, gn.Text, ix.ToArray(), (m_coordinateOverrides.ContainsKey(mn.Text) ? m_coordinateOverrides[mn.Text] : null)));
@@ -245,12 +250,14 @@
public string MapDefinition;
public string Group;
public int[] ScaleIndexes;
+ public MaestroAPI.Box2DType ExtentOverride = null;
- public Config(string MapDefinition, string Group, int[] ScaleIndexes)
+ public Config(string MapDefinition, string Group, int[] ScaleIndexes, MaestroAPI.Box2DType ExtentOverride)
this.MapDefinition = MapDefinition;
this.Group = Group;
this.ScaleIndexes = ScaleIndexes;
+ this.ExtentOverride = ExtentOverride;
@@ -323,6 +330,18 @@
sw.Write(c.ScaleIndexes[i].ToString());
+ sw.Write(" --extentoverride=");
+ sw.Write(c.ExtentOverride.MinX.ToString(System.Globalization.CultureInfo.InvariantCulture));
+ sw.Write(",");
+ sw.Write(c.ExtentOverride.MinY.ToString(System.Globalization.CultureInfo.InvariantCulture));
+ sw.Write(",");
+ sw.Write(c.ExtentOverride.MaxX.ToString(System.Globalization.CultureInfo.InvariantCulture));
+ sw.Write(",");
+ sw.Write(c.ExtentOverride.MaxY.ToString(System.Globalization.CultureInfo.InvariantCulture));
sw.Write(args.ToString());
sw.WriteLine();
@@ -383,11 +402,93 @@
private void UseOfficialMethod_CheckedChanged(object sender, EventArgs e)
OfficialMethodPanel.Enabled = UseOfficialMethod.Checked;
+ MapTree_AfterSelect(null, null);
- private void treeView1_AfterSelect(object sender, TreeViewEventArgs e)
+ private void MapTree_AfterSelect(object sender, TreeViewEventArgs e)
+ if (m_isUpdating)
+ return;
+ if (MapTree.SelectedNode == null || !UseOfficialMethod.Checked)
+ BoundsOverride.Enabled = false;
+ BoundsOverride.Tag = null;
+ else
+ BoundsOverride.Enabled = true;
+ TreeNode root = MapTree.SelectedNode;
+ while (root.Parent != null)
+ root = root.Parent;
+ MaestroAPI.Box2DType box;
+ if (m_coordinateOverrides.ContainsKey(root.Text))
+ box = m_coordinateOverrides[root.Text];
+ else
+ box = ((MaestroAPI.MapDefinition)root.Tag).Extents;
+ BoundsOverride.Tag = root;
+ try
+ m_isUpdating = true;
+ txtLowerX.Text = box.MinX.ToString(System.Globalization.CultureInfo.CurrentUICulture);
+ txtLowerY.Text = box.MinY.ToString(System.Globalization.CultureInfo.CurrentUICulture);
+ txtUpperX.Text = box.MaxX.ToString(System.Globalization.CultureInfo.CurrentUICulture);
+ txtUpperY.Text = box.MaxY.ToString(System.Globalization.CultureInfo.CurrentUICulture);
+ finally
+ m_isUpdating = false;
+ ModfiedOverrideWarning.Visible = m_coordinateOverrides.ContainsKey(root.Text);
+ private void ResetBounds_Click(object sender, EventArgs e)
+ if (BoundsOverride.Tag as TreeNode == null)
+ return;
+ TreeNode root = BoundsOverride.Tag as TreeNode;
+ m_coordinateOverrides.Remove(root.Text);
+ private void CoordinateItem_TextChanged(object sender, EventArgs e)
+ if (BoundsOverride.Tag as TreeNode == null || m_isUpdating)
+ return;
+ if (!m_coordinateOverrides.ContainsKey(root.Text))
+ MaestroAPI.Box2DType newbox = new OSGeo.MapGuide.MaestroAPI.Box2DType();
+ MaestroAPI.Box2DType origbox = ((MaestroAPI.MapDefinition)root.Tag).Extents;
+ newbox.MinX = origbox.MinX;
+ newbox.MinY = origbox.MinY;
+ newbox.MaxX = origbox.MaxX;
+ newbox.MaxY = origbox.MaxY;
+ m_coordinateOverrides.Add(root.Text, newbox);
+ double d;
+ if (double.TryParse(txtLowerX.Text, System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.CurrentUICulture, out d))
+ m_coordinateOverrides[root.Text].MinX = d;
+ if (double.TryParse(txtLowerY.Text, System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.CurrentUICulture, out d))
+ m_coordinateOverrides[root.Text].MinY = d;
+ if (double.TryParse(txtUpperX.Text, System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.CurrentUICulture, out d))
+ m_coordinateOverrides[root.Text].MaxX = d;
+ if (double.TryParse(txtUpperY.Text, System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.CurrentUICulture, out d))
+ m_coordinateOverrides[root.Text].MaxY = d;
Modified: trunk/Tools/Maestro/MgCooker/SetupRun.resx
--- trunk/Tools/Maestro/MgCooker/SetupRun.resx 2009-11-06 21:25:06 UTC (rev 4334)
+++ trunk/Tools/Maestro/MgCooker/SetupRun.resx 2009-11-09 18:26:32 UTC (rev 4335)
@@ -124,64 +124,61 @@
<value>
AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj0yLjAuMC4w
LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
- ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAABO
- DQAAAk1TRnQBSQFMAgEBBAEAAQkBAAEEAQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
- AwABIAMAAQEBAAEgBgABIP8A/wD/AP8A/wD/AP8A/wD/AP8A/wD/AP8A/wD/AP8AKgABHgIBASgBJgIB
- ATYBJgIBATYBJgIBATYBJgIBATYBJgIBATYBJgIBATYBJgIBATYBJgIBATYBJgIBATYBJgIBATYBJgIB
- ATYBHAIBASYcAAEXAgEBHgFiAhIBxgEfAgEBKgEDAgEBA6AAA/0B/wP9Af8D/QH/A/0B/wP9Af8D/QH/
- A/0B/wP9Af8D/QH/A/0B/wP9Af8D/QH/ARwCAQEmHAABnwJ/AfcB9AHmAeEB/wHlAdABzAH9AakBjgGN
- AfkBTQICAZEBEgIBAReYAAP9Af8B9QHoAeQB/wH0AeUB4AH/AfIB4gHdAf8B8QHgAdkB/wHwAd0B1gH/
- Ae8B2wHTAf8B7gHZAdEB/wHuAdgB0AH/Ae4B2AHQAf8B7gHYAdAB/wP9Af8BHAIBASYYAAEtAgEBQwH1
- AegB4wH/AfQB5gHhAf8B8wHkAd8B/wHyAeMB3QH/AfIB4QHbAf8B0AGwAawB+gGFAlgB8AE3AgEBWAEN
- AgEBDwwAAR8CAQEqAR8CAQEqIAABBwIBAQcBHwIBASoBHwIBASpMAAP9Af8B9wHtAekB/wH2AeoB5gH/
- AfQB5wHjAf8B3QG1AbAB/wG9AXQBbwH/Ab4BeAFzAf8B4wHCAbwB/wHvAdoB0gH/Ae4B2AHQAf8B7gHY
- AdAB/wP9Af8BHAIBASYYAAGqAY8BjgH4AfUB6AHjAf8B9AHmAeEB/wHzAeQB3wH/AfIB4wHdAf8B8gHh
- AdsB/wHxAd8B2QH/AfAB3QHXAf8B7wHcAdUB/wG2AaABnAH6AV0CDgHCCAADBAH/KAABMQIBAUwDBAH/
- TAAD/QH/AfgB8AHtAf8B7QHXAdIB/wG5AYkBcgH/AWIBkwEyAf8B6gGxAToB/wHoAa4BMQH/AesBwQFl
- Af8BsQFcAVcB/wHuAdkB0gH/Ae4B2QHSAf8D/QH/ARwCAQEmFAABQQIBAXAB9QHpAeUB/wH1AegB4wH/
- AfQB5gHhAf8B8wHkAd8B/wHyAeMB3QH/AfIB4QHbAf8B8QHfAdkB/wHwAd0B1wH/Ae8B3AHVAf8B7wHa
- AdMB/wE5AgEBXAgAAwQB/wgAAUcCAQF/AQIDAQEDAgEBAgFGAgEBfQQAASkCAQE8ASYCAQE3BAABMAIB
- AUoDBAH/DAABEgIBARcBTQIDAdEDBAH/ASkCAQE8EAABOQIBAVwDBAH/GAAD/QH/AfYB6gHmAf8B6AG/
- AZwB/wH7AcsBZQH/AT8BrQFMAf8BVwGdAS0B/wH+AcQBRQH/Af4BvgEwAf8B9gG2ASYB/wGXAXUBUgH/
- AfAB3QHWAf8D/QH/ARwCAQEmFAABugGcAZsB+AH1AekB5QH/AfUB6AHjAf8B9AHmAeEB/wHzAeQB3wH/
- AfIB4wHdAf8B8gHhAdsB/wHxAd8B2QH/AfAB3QHXAf8B7wHcAdUB/wGWAncB9gEGAgEBBggAAwQB/wgA
- AwQB/wFGAgEBfQFJAgIBhQMEAf8EAAMEAf8DBAH/BAABMAIBAUoDBAH/EAABQwIBAXQDBAH/FAABDgIB
- AREBSgIDAdUYAAP9Af8BuQFiAU0B/wH6Ac4BcQH/AaQBtgFZAf8BPwGtAU0B/wE+Aa0BTAH/AckBvwFb
- Af8B/gHEAUQB/wH+AcABNQH/AT0BpQFEAf8BvAF0AXEB/wP9Af8BHAIBASYQAAFTAgUBngH2AesB5wH/
- AfUB6QHlAf8B9QHoAeMB/wH0AeYB4QH/AfMB5AHfAf8B8gHjAd0B/wHyAeEB2wH/AfEB3wHZAf8B8AHd
- AdcB/wHaAcgBwwH8ASkCAQE8DAADBAH/KAABMAIBAUoDBAH/EAABQwIBAXQDBAH/NAAD/QH/AeoBwwGh
- Af8B/QHWAYQB/wGbAbYBXwH/AT0BnwEyAf8B8QHYAZEB/wH9AdEBdQH/AZwBsAFGAf8BPwGtAU0B/wE/
- Aa0BTQH/AZgBcAFPAf8D/QH/ARwCAQEmEAABxAGkAaEB9wH2AesB5wH/AfUB6QHlAf8B9QHoAeMB/wH0
- AeYB4QH/AfMB5AHfAf8B8gHjAd0B/wHyAeEB2wH/AfEB3wHZAf8B8AHdAdcB/wGBAU0BSwHrAQMCAQEC
- DAADBAH/KAABMAIBAUoDBAH/EAABQwIBAXQDBAH/FAABAwIBAQMBUQICAaEYAAP9Af8B+gHiAbkB/wFA
- AZoBKQH/AtQBmwH/Af0B4wG1Af8B/QHdAZ0B/wH9AdQBfgH/AeQByAFjAf8BPgGsAUsB/wFVAZwBKgH/
- AZ4BigFgAf8D/QH/ARwCAQEmDAABZgIXAckB9wHtAekB/wH2AesB5wH/AfUB6QHlAf8B9QHoAeMB/wH0
- AeYB4QH/AfMB5AHfAf8B8gHjAd0B/wHyAeEB2wH/AfEB3wHZAf8B1QG1Aa4B+gEcAgEBJhAAAwQB/ygA
- ATACAQFKAwQB/xAAAUMCAQF0AwQB/xQAAT8CAQFrAwQB/xgAA/0B/wFyAZABOgH/AT8BrQFNAf8BPwGt
- AU0B/wGvAcEBeQH/Af0B2wGVAf8B/QHTAXkB/wH+AcoBVwH/AUcBmgEpAf8BPQGXASQB/wGcAXIBUAH/
- A/0B/wEcAgEBJggAAQUCAQEFAdkBwgG/AfoB9wHtAekB/wH2AesB5wH/AfUB6QHlAf8B9QHoAeMB/wH0
- AeYB4QH/AfMB5AHfAf8B8gHjAd0B/wHyAeEB2wH/AfEB3wHZAf8BZgIcAdIUAAMEAf8oAAEwAgEBSgME
- Af8QAAFDAgEBdgMEAf80AAP9Af8BvgF0AVQB/wE/Aa0BTQH/AT4BowE7Af8BPgGtAUwB/wHAAcIBbAH/
- Af4BzgFnAf8B/gHGAUkB/wFeAZQBGwH/AcIBugFLAf8BxQGBAX0B/wP9Af8BHAIBASYIAAF/AkYB5wH4
- Ae4B6wH/AfcB7QHpAf8B9gHrAecB/wH1AekB5QH/AfUB6AHjAf8B9AHmAeEB/wHzAeQB3wH/AfIB4wHd
- Af8B8gHhAdsB/wHCAaIBnwH4ARQCAQEaFAADBAH/KAABMAIBAUoDBAH/DAABCgIBAQsBRAIEAd4DBAH/
- NAAD/QH/AfcB7QHpAf8BegGQAT4B/wGnAbUBUwH/AT8BkwEdAf8BqgG3AVUB/wFSAZ4BLgH/AfIBwgFG
- Af8B/gG9ASsB/wHFAX0BaQH/AfkB8QHuAf8D/QH/ARwCAQEmBAABFAIBARkB2wHGAcUB+gH4Ae4B6wH/
+ ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAACM
+ DAAAAk1TRnQBSQFMAgEBBAEAATQBAAE0AQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
+ AwABIAMAAQEBAAEgBgABIP8A/wD/AP8A/wD/AP8A/wD/AP8A/wD/AP8A/wD/AP8AKgADHAEoAyQBNgMk
+ ATYDJAE2AyQBNgMkATYDJAE2AyQBNgMkATYDJAE2AyQBNgMkATYDGwEmHAADFgEeAVsCVQHGAx0BKgMC
+ AQOgAAP9Af8D/QH/A/0B/wP9Af8D/QH/A/0B/wP9Af8D/QH/A/0B/wP9Af8D/QH/A/0B/wMbASYcAAGL
+ Am4B9wH0AeYB4QH/AdMBvgG9Af0BkgGIAYcB+QFNAkwBkQMRAReYAAP9Af8B9QHoAeQB/wH0AeUB4AH/
+ AfIB4gHdAf8B8QHgAdkB/wHwAd0B1gH/Ae8B2wHTAf8B7gHZAdEB/wHuAdgB0AH/Ae4B2AHQAf8B7gHY
+ AdAB/wP9Af8DGwEmGAABLAIrAUMB9QHoAeMB/wH0AeYB4QH/AfMB5AHfAf8B8gHjAd0B/wHyAeEB2wH/
+ AbMBoQGeAfoBbgJaAfABNgI1AVgDCwEPDAADHQEqAx0BKiAAAwUBBwMdASoDHQEqTAAD/QH/AfcB7QHp
+ Af8B9gHqAeYB/wH0AecB4wH/Ad0BtQGwAf8BvQFuAWkB/wG+AXIBbQH/AeMBwgG8Af8B7wHaAdIB/wHu
+ AdgB0AH/Ae4B2AHQAf8D/QH/AxsBJhgAAZcCfgH4AfUB6AHjAf8B9AHmAeEB/wHzAeQB3wH/AfIB4wHd
+ Af8B8gHhAdsB/wHxAd8B2QH/AfAB3QHXAf8B7wHcAdUB/wGkAZIBjAH6AVkCVgHCCwAB/ygAAzABTAMA
+ Af9MAAP9Af8B+AHwAe0B/wHtAdcB0gH/AbkBiQFsAf8BXAGTASwB/wHqAbEBNAH/AegBrgErAf8B6wHB
+ AV8B/wGxAVYBUQH/Ae4B2QHSAf8B7gHZAdIB/wP9Af8DGwEmFAADQAFwAfUB6QHlAf8B9QHoAeMB/wH0
+ AeYB4QH/AfMB5AHfAf8B8gHjAd0B/wHyAeEB2wH/AfEB3wHZAf8B8AHdAdcB/wHvAdwB1QH/Ae8B2gHT
+ Af8DOAFcCwAB/wgAAUYCRQF/AwAEAQECA0UBfQQAAygBPAMlATcEAAMvAUoDAAH/DAADEQEXAVgCVAHR
+ AwAB/wMoATwQAAM4AVwDAAH/GAAD/QH/AfYB6gHmAf8B6AG/AZwB/wH7AcsBXwH/ATkBrQFGAf8BUQGd
+ AScB/wH+AcQBPwH/Af4BvgEqAf8B9gG2ASAB/wGXAW8BTAH/AfAB3QHWAf8D/QH/AxsBJhQAAZ8BkAGO
+ AfgB9QHpAeUB/wH1AegB4wH/AfQB5gHhAf8B8wHkAd8B/wHyAeMB3QH/AfIB4QHbAf8B8QHfAdkB/wHw
+ Ad0B1wH/Ae8B3AHVAf8BgQJoAfYDBAEGCwAB/wsAAf8DRQF9A0gBhQMAAf8HAAH/AwAB/wQAAy8BSgMA
+ Af8QAANCAXQDAAH/FAADDQERAVoCVAHVGAAD/QH/AbkBXAFHAf8B+gHOAWsB/wGkAbYBUwH/ATkBrQFH
+ Af8BOAGtAUYB/wHJAb8BVQH/Af4BxAE+Af8B/gHAAS8B/wE3AaUBPgH/AbwBbgFrAf8D/QH/AxsBJhAA
+ A1ABngH2AesB5wH/AfUB6QHlAf8B9QHoAeMB/wH0AeYB4QH/AfMB5AHfAf8B8gHjAd0B/wHyAeEB2wH/
+ AfEB3wHZAf8B8AHdAdcB/wHFAbkBtQH8AygBPA8AAf8oAAMvAUoDAAH/EAADQgF0AwAB/zQAA/0B/wHq
+ AcMBoQH/Af0B1gGEAf8BmwG2AVkB/wE3AZ8BLAH/AfEB2AGRAf8B/QHRAW8B/wGcAbABQAH/ATkBrQFH
+ Af8BOQGtAUcB/wGYAWoBSQH/A/0B/wMbASYQAAGlAY4BjAH3AfYB6wHnAf8B9QHpAeUB/wH1AegB4wH/
+ AfQB5gHhAf8B8wHkAd8B/wHyAeMB3QH/AfIB4QHbAf8B8QHfAdkB/wHwAd0B1wH/AW4BWAFXAesDAQEC
+ DwAB/ygAAy8BSgMAAf8QAANCAXQDAAH/FAADAgEDA1EBoRgAA/0B/wH6AeIBuQH/AToBmgEjAf8C1AGb
+ Af8B/QHjAbUB/wH9Ad0BnQH/Af0B1AF4Af8B5AHIAV0B/wE4AawBRQH/AU8BnAEkAf8BngGKAVoB/wP9
+ Af8DGwEmDAABXAJWAckB9wHtAekB/wH2AesB5wH/AfUB6QHlAf8B9QHoAeMB/wH0AeYB4QH/AfMB5AHf
+ Af8B8gHjAd0B/wHyAeEB2wH/AfEB3wHZAf8BuAGjAaAB+gMbASYTAAH/KAADLwFKAwAB/xAAA0IBdAMA
+ Af8UAAM+AWsDAAH/GAAD/QH/AWwBkAE0Af8BOQGtAUcB/wE5Aa0BRwH/Aa8BwQFzAf8B/QHbAZUB/wH9
+ AdMBcwH/Af4BygFRAf8BQQGaASMB/wE3AZcBHgH/AZwBbAFKAf8D/QH/AxsBJggAAwQBBQG9AakBpwH6
AfcB7QHpAf8B9gHrAecB/wH1AekB5QH/AfUB6AHjAf8B9AHmAeEB/wHzAeQB3wH/AfIB4wHdAf8B8gHh
- AdsB/wFXAgYBrxgAAUICBAHfAUkCAgGHIAABDQIBAQ8BUwICAbcBQgIEAd9MAAP9Af8B+QHxAe4B/wHy
- AeEB2wH/Aa0BhgFaAf8B7gHYAYsB/wFTAZ4BLgH/AT4BrQFMAf8BRAGUASAB/wG7AWcBUwH/AfgB8AHt
- Af8B+QHxAe4B/wP9Af8BHAIBASYIAAEDAgEBAgFXAgcBpwG2AZ4BnAH5AfYB6wHnAf8B9QHpAeUB/wH1
- AegB4wH/AfQB5gHhAf8B8wHkAd8B/wHyAeMB3QH/AboBmgGWAfgBEAIBAROYAAP9Af8B+QHxAe4B/wH5
- AfEB7gH/AfkB8QHuAf8B7AHSAckB/wHSAZUBggH/AdQBmgGJAf8B8gHhAdwB/wH5AfEB7gH/AfkB8QHu
- Af8B+QHxAe4B/wP9Af8BHAIBASYUAAEeAgEBKQF6AT8BPgHkAcYBrQGqAfkB9AHmAeEB/wHzAeQB3wH/
- AfIB4wHdAf8BSgICAYicAAP9Af8B+gH2AfQB/wH6AfYB9AH/AfoB9gH0Af8B+gH2AfQB/wH6AfYB9AH/
- AfoB9gH0Af8B+gH2AfQB/wH6AfYB9AH/AfoB9gH0Af8B+gH2AfQB/wP9Af8BHAIBASYgAAE/AgEBawGn
- AZABjgH6AagBjQGMAfgBCQIBAQqcAAGlAqAB/wGkAaABnwH/AaQCnwH/AaMCngH/AaICnQH/AaECnAH/
- AaACmwH/AZ8CmgH/AZ0CmQH/AZwBmAGXAf8BmwKWAf8BmQKVAf/IAAFCAU0BPgcAAT4DAAEoAwABQAMA
- ASADAAEBAQABAQYAAQEWAAP/gQABwAEBAfwBPwT/AcABAQH8AQ8E/wHAAQEB+AEBAc8B8QL/AcABAQH4
- AQAB3wH5Av8BwAEBAfABAAHYAUkBwwHPAcABAQHwAQAB2AFJAecBzwHAAQEB4AEBAd8B+QHnAf8BwAEB
- AeABAQHfAfkB5wHPAcABAQHAAQMB3wH5AecBzwHAAQEBgAEHAd8B+QHnAf8BwAEBAYABBwHfAfkBxwH/
- AcABAQEAAQ8BzwHxAv8BwAEBAYABDwT/AcABAQHwAR8E/wHAAQEB/gEfBP8BwAEDBv8L
+ AdsB/wHxAd8B2QH/AV0CVgHSFwAB/ygAAy8BSgMAAf8QAANCAXYDAAH/NAAD/QH/Ab4BbgFOAf8BOQGt
+ AUcB/wE4AaMBNQH/ATgBrQFGAf8BwAHCAWYB/wH+Ac4BYQH/Af4BxgFDAf8BWAGUARUB/wHCAboBRQH/
+ AcUBgQF3Af8D/QH/AxsBJggAAWoCVQHnAfgB7gHrAf8B9wHtAekB/wH2AesB5wH/AfUB6QHlAf8B9QHo
+ AeMB/wH0AeYB4QH/AfMB5AHfAf8B8gHjAd0B/wHyAeEB2wH/AaYBlAGSAfgDEwEaFwAB/ygAAy8BSgMA
+ Af8MAAMIAQsBVgJOAd4DAAH/NAAD/QH/AfcB7QHpAf8BdAGQATgB/wGnAbUBTQH/ATkBkwEXAf8BqgG3
+ AU8B/wFMAZ4BKAH/AfIBwgFAAf8B/gG9ASUB/wHFAXcBYwH/AfkB8QHuAf8D/QH/AxsBJgQAAxIBGQG/
+ AawBqwH6AfgB7gHrAf8B9wHtAekB/wH2AesB5wH/AfUB6QHlAf8B9QHoAeMB/wH0AeYB4QH/AfMB5AHf
+ Af8B8gHjAd0B/wHyAeEB2wH/AVQCUwGvGAABVwJKAd8BSQJIAYcgAAMLAQ8DVQG3AVcCSgHfTAAD/QH/
+ AfkB8QHuAf8B8gHhAdsB/wGtAYYBVAH/Ae4B2AGLAf8BTQGeASgB/wE4Aa0BRgH/AT4BlAEaAf8BuwFh
+ AU0B/wH4AfAB7QH/AfkB8QHuAf8D/QH/AxsBJggAAwEBAgFSAlEBpwGhAo0B+QH2AesB5wH/AfUB6QHl
+ Af8B9QHoAeMB/wH0AeYB4QH/AfMB5AHfAf8B8gHjAd0B/wGfAY0BhwH4Aw4BE5gAA/0B/wH5AfEB7gH/
+ AfkB8QHuAf8B+QHxAe4B/wHsAdIByQH/AdIBlQGCAf8B1AGaAYkB/wHyAeEB3AH/AfkB8QHuAf8B+QHx
+ Ae4B/wH5AfEB7gH/A/0B/wMbASYUAAMdASkBZAJUAeQBrQGWAZIB+QH0AeYB4QH/AfMB5AHfAf8B8gHj
+ Ad0B/wFJAkgBiJwAA/0B/wH6AfYB9AH/AfoB9gH0Af8B+gH2AfQB/wH6AfYB9AH/AfoB9gH0Af8B+gH2
+ AfQB/wH6AfYB9AH/AfoB9gH0Af8B+gH2AfQB/wH6AfYB9AH/A/0B/wMbASYgAAM+AWsBmwJ+AfoBlwJ9
+ AfgDBwEKnAABpQKgAf8BpAGgAZ8B/wGkAp8B/wGjAp4B/wGiAp0B/wGhApwB/wGgApsB/wGfApoB/wGd
+ ApkB/wGcAZgBlwH/AZsClgH/AZkClQH/yAABQgFNAT4HAAE+AwABKAMAAUADAAEgAwABAQEAAQEGAAEB
+ FgAD/4EAAcABAQH8AT8E/wHAAQEB/AEPBP8BwAEBAfgBAQHPAfEC/wHAAQEB+AEAAd8B+QL/AcABAQHw
+ AQAB2AFJAcMBzwHAAQEB8AEAAdgBSQHnAc8BwAEBAeABAQHfAfkB5wH/AcABAQHgAQEB3wH5AecBzwHA
+ AQEBwAEDAd8B+QHnAc8BwAEBAYABBwHfAfkB5wH/AcABAQGAAQcB3wH5AccB/wHAAQEBAAEPAc8B8QL/
+ AcABAQGAAQ8E/wHAAQEB8AEfBP8BwAEBAf4BHwT/AcABAwb/Cw==
</value>
</data>
<metadata name="saveFileDialog1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
More information about the mapguide-commits
