[mapguide-commits] r4345 - in trunk/Tools/Maestro/MaestroAPI: . RuntimeClasses
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sun Nov 15 18:34:39 EST 2009
Author: ksgeograf
Date: 2009-11-15 18:34:39 -0500 (Sun, 15 Nov 2009)
New Revision: 4345
   trunk/Tools/Maestro/MaestroAPI/HttpServerConnection.cs
   trunk/Tools/Maestro/MaestroAPI/LocalNativeConnection.cs
   trunk/Tools/Maestro/MaestroAPI/RequestBuilder.cs
   trunk/Tools/Maestro/MaestroAPI/RuntimeClasses/RuntimeMap.cs
   trunk/Tools/Maestro/MaestroAPI/ServerConnectionBase.cs
   trunk/Tools/Maestro/MaestroAPI/ServerConnectionI.cs
Maestro:
Fixed issue #674, additional map rendering options
Modified: trunk/Tools/Maestro/MaestroAPI/HttpServerConnection.cs
--- trunk/Tools/Maestro/MaestroAPI/HttpServerConnection.cs	2009-11-15 23:10:34 UTC (rev 4344)
+++ trunk/Tools/Maestro/MaestroAPI/HttpServerConnection.cs	2009-11-15 23:34:39 UTC (rev 4345)
@@ -805,17 +805,17 @@
-		public override System.IO.Stream RenderRuntimeMap(string resourceId, double x, double y, double scale, int width, int height, int dpi, string format)
+		public override System.IO.Stream RenderRuntimeMap(string resourceId, double x, double y, double scale, int width, int height, int dpi, string format, bool clip)
             ResourceIdentifier.Validate(resourceId, ResourceTypes.RuntimeMap);
 			string mapname = resourceId.Substring(resourceId.IndexOf("//") + 2);
 			mapname = mapname.Substring(0, mapname.LastIndexOf("."));
 #if DEBUG
-			string s = m_reqBuilder.GetMapImageUrl(mapname, format, null, x, y, scale, dpi, width, height, null, null, null, null);
+			string s = m_reqBuilder.GetMapImageUrl(mapname, format, null, x, y, scale, dpi, width, height, clip, null, null, null, null);
 			return new System.IO.MemoryStream(this.DownloadData(s));
 #else
 			System.IO.MemoryStream ms = new System.IO.MemoryStream();
-			System.Net.WebRequest req = m_reqBuilder.GetMapImage(mapname, format, null, x, y, scale, dpi, width, height, null, null, null, null, ms);
+			System.Net.WebRequest req = m_reqBuilder.GetMapImage(mapname, format, null, x, y, scale, dpi, width, height, clip, null, null, null, null, ms);
             //Maksim reported that the rendering times out frequently, so now we wait 5 minutes
             req.Timeout = 5 * 60 * 1000;
@@ -830,17 +830,17 @@
 #endif
-        public override System.IO.Stream RenderRuntimeMap(string resourceId, double x1, double y1, double x2, double y2, int width, int height, int dpi, string format)
+        public override System.IO.Stream RenderRuntimeMap(string resourceId, double x1, double y1, double x2, double y2, int width, int height, int dpi, string format, bool clip)
 #if DEBUG
-            string s = m_reqBuilder.GetMapImageUrl(mapname, format, null, x1, y1, x2, y2, dpi, width, height, null, null, null, null);
+            string s = m_reqBuilder.GetMapImageUrl(mapname, format, null, x1, y1, x2, y2, dpi, width, height, clip, null, null, null, null);
 #else
-			System.Net.WebRequest req = m_reqBuilder.GetMapImage(mapname, format, null, x1, y1, x2, y2, dpi, width, height, null, null, null, null, ms);
+			System.Net.WebRequest req = m_reqBuilder.GetMapImage(mapname, format, null, x1, y1, x2, y2, dpi, width, height, clip, null, null, null, null, ms);
Modified: trunk/Tools/Maestro/MaestroAPI/LocalNativeConnection.cs
--- trunk/Tools/Maestro/MaestroAPI/LocalNativeConnection.cs	2009-11-15 23:10:34 UTC (rev 4344)
+++ trunk/Tools/Maestro/MaestroAPI/LocalNativeConnection.cs	2009-11-15 23:34:39 UTC (rev 4345)
@@ -485,7 +485,7 @@
 			res.MoveResource(new MgResourceIdentifier(oldpath), new MgResourceIdentifier(newpath), overwrite);
 			MgRenderingService rnd = this.Con.CreateService(MgServiceType.RenderingService) as MgRenderingService;
 			MgResourceService res = this.Con.CreateService(MgServiceType.ResourceService) as MgResourceService;
@@ -498,13 +498,14 @@
 			MgSelection sel = new MgSelection(map);
             //The color accepted by MgColor has alpha as the last value, but the returned has alpha first
 			MgColor color = new MgColor(Utility.ParseHTMLColor(map.GetBackgroundColor()));
-			object[] args = new object[] { map, sel, gf.CreateCoordinateXY(x, y), scale, width, height, color, format, true };
+            //TODO: The render method is missing the overload for the Clip parameter
+            object[] args = new object[] { map, sel, gf.CreateCoordinateXY(x, y), scale, width, height, color, format, true };
             Type[] types = new Type[] { args[0].GetType(), args[1].GetType(), args[2].GetType(), args[3].GetType(), args[4].GetType(), args[5].GetType(), args[6].GetType(), args[7].GetType(), args[8].GetType() };
 			return Utility.MgStreamToNetStream(rnd, rnd.GetType().GetMethod("RenderMap", types), args);
@@ -519,6 +520,8 @@
             MgEnvelope env = new MgEnvelope(gf.CreateCoordinateXY(x1, y1), gf.CreateCoordinateXY(x2, y2));
+            //TODO: The render is missing the clip param for the extent override method
             object[] args = new object[] { map, sel, env, width, height, color, format };
             Type[] types = new Type[] { args[0].GetType(), args[1].GetType(), args[2].GetType(), args[3].GetType(), args[4].GetType(), args[5].GetType(), args[6].GetType() };
Modified: trunk/Tools/Maestro/MaestroAPI/RequestBuilder.cs
--- trunk/Tools/Maestro/MaestroAPI/RequestBuilder.cs	2009-11-15 23:10:34 UTC (rev 4344)
+++ trunk/Tools/Maestro/MaestroAPI/RequestBuilder.cs	2009-11-15 23:34:39 UTC (rev 4345)
@@ -769,7 +769,7 @@
 			return m_hosturi + "?" + EncodeParameters(param);
-		public System.Net.WebRequest GetMapImage(string mapname, string format, string selectionXml, double centerX, double centerY, double scale, int dpi, int width, int height, string[] showlayers, string[] hidelayers, string[] showgroups, string[] hidegroups, System.IO.Stream outStream)
+		public System.Net.WebRequest GetMapImage(string mapname, string format, string selectionXml, double centerX, double centerY, double scale, int dpi, int width, int height, bool clip, string[] showlayers, string[] hidelayers, string[] showgroups, string[] hidegroups, System.IO.Stream outStream)
 			NameValueCollection param = new NameValueCollection();
 			param.Add("OPERATION", "GETMAPIMAGE");
@@ -800,6 +800,7 @@
 			if (hidegroups != null && hidegroups.Length > 0)
 				param.Add("HIDEGROUPS", string.Join(",", hidegroups));
+            param.Add("CLIP", clip ? "1" : "0");
 			//TODO: Find out if this actually works...
 			//param.Add("REFRESHLAYERS", ...)
@@ -811,7 +812,7 @@
 			return req;
-        public System.Net.WebRequest GetMapImage(string mapname, string format, string selectionXml, double x1, double y1, double x2, double y2, int dpi, int width, int height, string[] showlayers, string[] hidelayers, string[] showgroups, string[] hidegroups, System.IO.Stream outStream)
+        public System.Net.WebRequest GetMapImage(string mapname, string format, string selectionXml, double x1, double y1, double x2, double y2, int dpi, int width, int height, bool clip, string[] showlayers, string[] hidelayers, string[] showgroups, string[] hidegroups, System.IO.Stream outStream)
@@ -840,6 +841,7 @@
@@ -856,7 +858,7 @@
-		public string GetMapImageUrl(string mapname, string format, string selectionXml, double centerX, double centerY, double scale, int dpi, int width, int height, string[] showlayers, string[] hidelayers, string[] showgroups, string[] hidegroups)
+		public string GetMapImageUrl(string mapname, string format, string selectionXml, double centerX, double centerY, double scale, int dpi, int width, int height, bool clip, string[] showlayers, string[] hidelayers, string[] showgroups, string[] hidegroups)
@@ -890,10 +892,12 @@
-        public string GetMapImageUrl(string mapname, string format, string selectionXml, double x1, double y1, double x2, double y2, int dpi, int width, int height, string[] showlayers, string[] hidelayers, string[] showgroups, string[] hidegroups)
+        public string GetMapImageUrl(string mapname, string format, string selectionXml, double x1, double y1, double x2, double y2, int dpi, int width, int height, bool clip, string[] showlayers, string[] hidelayers, string[] showgroups, string[] hidegroups)
@@ -922,6 +926,8 @@
Modified: trunk/Tools/Maestro/MaestroAPI/RuntimeClasses/RuntimeMap.cs
--- trunk/Tools/Maestro/MaestroAPI/RuntimeClasses/RuntimeMap.cs	2009-11-15 23:10:34 UTC (rev 4344)
+++ trunk/Tools/Maestro/MaestroAPI/RuntimeClasses/RuntimeMap.cs	2009-11-15 23:34:39 UTC (rev 4345)
@@ -478,7 +478,29 @@
+        public System.IO.Stream RenderToStream(double x, double y, double scale, int width, int height, int dpi, string format, bool clip)
+            return m_serverConnection.RenderRuntimeMap(m_resourceID, x, y, scale, width, height, dpi, format, clip);
+        public System.IO.Stream RenderToStream(double x1, double y1, double x2, double y2, int width, int height, int dpi, string format, bool clip)
+            return m_serverConnection.RenderRuntimeMap(m_resourceID, x1, y1, x2, y2, width, height, dpi, format, clip);
+        public System.Drawing.Bitmap Render(double x, double y, double scale, int width, int height, int dpi, string format, bool clip)
+            using (System.IO.Stream s = m_serverConnection.RenderRuntimeMap(m_resourceID, x, y, scale, width, height, dpi, format, clip))
+                return new System.Drawing.Bitmap(s);
+        public System.Drawing.Bitmap Render(double x1, double y1, double x2, double y2, int width, int height, int dpi, string format, bool clip)
+            using (System.IO.Stream s = m_serverConnection.RenderRuntimeMap(m_resourceID, x1, y1, x2, y2, width, height, dpi, format, clip))
 	public class RuntimeMapGroup
@@ -1307,6 +1329,7 @@
 			base.InnerList.Insert(index, layer);
Modified: trunk/Tools/Maestro/MaestroAPI/ServerConnectionBase.cs
--- trunk/Tools/Maestro/MaestroAPI/ServerConnectionBase.cs	2009-11-15 23:10:34 UTC (rev 4344)
+++ trunk/Tools/Maestro/MaestroAPI/ServerConnectionBase.cs	2009-11-15 23:34:39 UTC (rev 4345)
@@ -1930,17 +1930,27 @@
         public virtual System.IO.Stream RenderRuntimeMap(string resourceId, double x, double y, double scale, int width, int height, int dpi)
-            return this.RenderRuntimeMap(resourceId, x, y, scale, width, height, dpi, "PNG");
+            return this.RenderRuntimeMap(resourceId, x, y, scale, width, height, dpi, "PNG", false);
         public virtual System.IO.Stream RenderRuntimeMap(string resourceId, double x1, double y1, double x2, double y2, int width, int height, int dpi)
-            return this.RenderRuntimeMap(resourceId, x1, y1, x2, y2, width, height, dpi, "PNG");
+            return this.RenderRuntimeMap(resourceId, x1, y1, x2, y2, width, height, dpi, "PNG", false);
-        public abstract System.IO.Stream RenderRuntimeMap(string resourceId, double x, double y, double scale, int width, int height, int dpi, string format);
-        public abstract System.IO.Stream RenderRuntimeMap(string resourceId, double x1, double y1, double x2, double y2, int width, int height, int dpi, string format);
+        public virtual System.IO.Stream RenderRuntimeMap(string resourceId, double x, double y, double scale, int width, int height, int dpi, string format)
+            return this.RenderRuntimeMap(resourceId, x, y, scale, width, height, dpi, format, false);
+        public virtual System.IO.Stream RenderRuntimeMap(string resourceId, double x1, double y1, double x2, double y2, int width, int height, int dpi, string format)
+            return this.RenderRuntimeMap(resourceId, x1, y1, x2, y2, width, height, dpi, format, false);
+        public abstract System.IO.Stream RenderRuntimeMap(string resourceId, double x, double y, double scale, int width, int height, int dpi, string format, bool clip);
+        public abstract System.IO.Stream RenderRuntimeMap(string resourceId, double x1, double y1, double x2, double y2, int width, int height, int dpi, string format, bool clip);
         public abstract System.IO.Stream GetTile(string mapdefinition, string baselayergroup, int col, int row, int scaleindex, string format);
Modified: trunk/Tools/Maestro/MaestroAPI/ServerConnectionI.cs
--- trunk/Tools/Maestro/MaestroAPI/ServerConnectionI.cs	2009-11-15 23:10:34 UTC (rev 4344)
+++ trunk/Tools/Maestro/MaestroAPI/ServerConnectionI.cs	2009-11-15 23:34:39 UTC (rev 4345)
@@ -181,6 +181,9 @@
+        System.IO.Stream RenderRuntimeMap(string resourceId, double x, double y, double scale, int width, int height, int dpi, string format, bool clip);
+        System.IO.Stream RenderRuntimeMap(string resourceId, double x1, double y1, double x2, double y2, int width, int height, int dpi, string format, bool clip);
 		/// <summary>
 		/// Saves a WebLayout, using its originating resourceId
 		/// </summary>
More information about the mapguide-commits mailing list
