[mapguide-commits] r4353 - in trunk/MgDev/Common: Renderers Stylization
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sun Nov 22 00:32:27 EST 2009
Author: waltweltonlair
Date: 2009-11-22 00:32:25 -0500 (Sun, 22 Nov 2009)
New Revision: 4353
   trunk/MgDev/Common/Renderers/KmlRenderer.cpp
   trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp
   trunk/MgDev/Common/Stylization/SE_RenderProxies.h
   trunk/MgDev/Common/Stylization/SE_Renderer.cpp
   trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp
   trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp
   trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.h
   trunk/MgDev/Common/Stylization/StylizationEngine.cpp
Keep variable names consistent with the schema names:
* AddToExclusionRegion
* CheckExclusionRegion
Modified: trunk/MgDev/Common/Renderers/KmlRenderer.cpp
--- trunk/MgDev/Common/Renderers/KmlRenderer.cpp	2009-11-22 04:51:35 UTC (rev 4352)
+++ trunk/MgDev/Common/Renderers/KmlRenderer.cpp	2009-11-22 05:32:25 UTC (rev 4353)
@@ -764,7 +764,7 @@
     RS_FillStyle fs;
     RS_MarkerDef mdef(RS_MarkerType_Marker, 1.0, 1.0, 0.5, 0.5, 0.0, RS_Units_Device, SLDType_Square, L"", L"", fs);
-    ProcessMarker(ctx->geometry, mdef, !style->addToExclusionRegions, bounds);
+    ProcessMarker(ctx->geometry, mdef, !style->addToExclusionRegion, bounds);
Modified: trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp
--- trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp	2009-11-22 04:51:35 UTC (rev 4352)
+++ trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp	2009-11-22 05:32:25 UTC (rev 4353)
@@ -473,7 +473,7 @@
         SE_RenderText* rt = (SE_RenderText*)rstyle->symbol[0];
         RS_LabelInfo info(0.0, 0.0, 0.0, 0.0, RS_Units_Device, rt->tdef);
-        return se_renderer->ProcessLabelGroup(&info, 1, rt->content, RS_OverpostType_AllFit, rstyle->addToExclusionRegions, geometry, 0.5);
+        return se_renderer->ProcessLabelGroup(&info, 1, rt->content, RS_OverpostType_AllFit, rstyle->addToExclusionRegion, geometry, 0.5);
     se_renderer->ProcessLineLabels(geometry, (SE_RenderLineStyle*)rstyle);
@@ -716,14 +716,14 @@
                         SE_RenderStyle* clonedStyle = se_renderer->CloneRenderStyle(rlStyle);
                         SE_LabelInfo info(symxf.x2, symxf.y2, RS_Units_Device, angleRad, clonedStyle);
-                        se_renderer->ProcessSELabelGroup(&info, 1, RS_OverpostType_AllFit, rlStyle->addToExclusionRegions, geometry);
+                        se_renderer->ProcessSELabelGroup(&info, 1, RS_OverpostType_AllFit, rlStyle->addToExclusionRegion, geometry);
                     else
                         se_renderer->DrawSymbol(symbolVectors[shieldIndex], symxf, angleRad);
                         // TODO: if this is ever needed ...
-//                      if (rlStyle->addToExclusionRegions)
+//                      if (rlStyle->addToExclusionRegion)
 //                          se_renderer->AddExclusionRegion(style, symxf, 0.0);
Modified: trunk/MgDev/Common/Stylization/SE_RenderProxies.h
--- trunk/MgDev/Common/Stylization/SE_RenderProxies.h	2009-11-22 04:51:35 UTC (rev 4352)
+++ trunk/MgDev/Common/Stylization/SE_RenderProxies.h	2009-11-22 05:32:25 UTC (rev 4353)
@@ -173,8 +173,8 @@
         : type(stype),
           renderPass(0),
           drawLast(false),
-          checkExclusionRegions(false),
-          addToExclusionRegions(false)
+          checkExclusionRegion(false),
+          addToExclusionRegion(false)
         bounds[0].x = bounds[3].x = +DBL_MAX;
         bounds[1].x = bounds[2].x = -DBL_MAX;
@@ -218,8 +218,8 @@
     int renderPass;
     bool drawLast;
-    bool checkExclusionRegions;
-    bool addToExclusionRegions;
+    bool checkExclusionRegion;
+    bool addToExclusionRegion;
Modified: trunk/MgDev/Common/Stylization/SE_Renderer.cpp
--- trunk/MgDev/Common/Stylization/SE_Renderer.cpp	2009-11-22 04:51:35 UTC (rev 4352)
+++ trunk/MgDev/Common/Stylization/SE_Renderer.cpp	2009-11-22 05:32:25 UTC (rev 4353)
@@ -214,7 +214,7 @@
         if (style->drawLast)
             AddLabel(featGeom, style, xform, angleRad);
         else
-            DrawSymbol(style->symbol, xform, angleRad, style->addToExclusionRegions);
+            DrawSymbol(style->symbol, xform, angleRad, style->addToExclusionRegion);
     if (bounds)
@@ -371,7 +371,7 @@
         xform = xformbase;
         xform.translate(pos->x, pos->y);
-        DrawSymbol(style->symbol, xform, baserot, style->addToExclusionRegions);
+        DrawSymbol(style->symbol, xform, baserot, style->addToExclusionRegion);
     LineBufferPool::FreeLineBuffer(m_pPool, spLB.release());
@@ -488,7 +488,7 @@
     SE_RenderStyle* clonedStyle = CloneRenderStyle(style);
     SE_LabelInfo info(xform.x2, xform.y2, RS_Units_Device, angleRad, clonedStyle);
-    ProcessSELabelGroup(&info, 1, RS_OverpostType_AllFit, style->addToExclusionRegions, geom);
+    ProcessSELabelGroup(&info, 1, RS_OverpostType_AllFit, style->addToExclusionRegion, geom);
@@ -566,10 +566,10 @@
     // copy all the common properties
     memcpy(ret->bounds, symbol->bounds, sizeof(ret->bounds));
-    ret->addToExclusionRegions = symbol->addToExclusionRegions;
-    ret->checkExclusionRegions = symbol->checkExclusionRegions;
-    ret->drawLast              = symbol->drawLast;
-    ret->renderPass            = symbol->renderPass;
+    ret->addToExclusionRegion = symbol->addToExclusionRegion;
+    ret->checkExclusionRegion = symbol->checkExclusionRegion;
+    ret->drawLast             = symbol->drawLast;
+    ret->renderPass           = symbol->renderPass;
     // copy the graphics for the symbol
     for (size_t i=0; i<symbol->symbol.size(); ++i)
@@ -1201,7 +1201,7 @@
                             // only draw symbols at the interior points
                             if (numDrawn > 0 && numDrawn < numSymbols-1)
-                                DrawSymbol(style->symbol, symxf, angleRad, style->addToExclusionRegions);
+                                DrawSymbol(style->symbol, symxf, angleRad, style->addToExclusionRegion);
                             // handle the centerline path at the group's end - only
                             // need to do this if we have at least one interior symbol
@@ -1633,7 +1633,7 @@
                                 AddLabel(geometry, style, symxf, angleRad);
                             else
                         ++numDrawn;
Modified: trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp
--- trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp	2009-11-22 04:51:35 UTC (rev 4352)
+++ trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp	2009-11-22 05:32:25 UTC (rev 4353)
@@ -847,8 +847,8 @@
         ParseStringExpression(instance->GetPositioningAlgorithm(), m_symbolInstance->positioningAlgorithm, SymbolInstance::sPositioningAlgorithmDefault, SymbolInstance::sPositioningAlgorithmValues);
         ParseBooleanExpression(instance->GetDrawLast(), m_symbolInstance->drawLast, false);
-        ParseBooleanExpression(instance->GetAddToExclusionRegion(), m_symbolInstance->addToExclusionRegions, false);
-        ParseBooleanExpression(instance->GetCheckExclusionRegion(), m_symbolInstance->checkExclusionRegions, false);
+        ParseBooleanExpression(instance->GetAddToExclusionRegion(), m_symbolInstance->addToExclusionRegion, false);
+        ParseBooleanExpression(instance->GetCheckExclusionRegion(), m_symbolInstance->checkExclusionRegion, false);
         ParseDoubleExpression(instance->GetScaleX(), m_symbolInstance->scale[0], 1.0);
         ParseDoubleExpression(instance->GetScaleY(), m_symbolInstance->scale[1], 1.0);
Modified: trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp
--- trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp	2009-11-22 04:51:35 UTC (rev 4352)
+++ trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp	2009-11-22 05:32:25 UTC (rev 4353)
@@ -892,7 +892,7 @@
         if (rplist.size() == 1
             && rplist[0]->type == SE_RenderPrimitive_Polyline
             && !style->drawLast
-            && !style->addToExclusionRegions)
+            && !style->addToExclusionRegion)
             SE_RenderPolyline* rp = (SE_RenderPolyline*)rplist[0];
             LineBuffer* lb = rp->geometry->xf_buffer();
@@ -1004,7 +1004,7 @@
             && rplist[0]->type == SE_RenderPrimitive_Polygon
             && !style->drawLast
             SE_RenderPolygon* rp = (SE_RenderPolygon*)rplist[0];
Modified: trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.h
--- trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.h	2009-11-22 04:51:35 UTC (rev 4352)
+++ trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.h	2009-11-22 05:32:25 UTC (rev 4353)
@@ -262,8 +262,8 @@
     MdfModel::SizeContext sizeContext;
     MdfModel::SymbolInstance::GeometryContext geomContext;
     SE_Boolean drawLast;
-    SE_Boolean checkExclusionRegions;
-    SE_Boolean addToExclusionRegions;
+    SE_Boolean checkExclusionRegion;
+    SE_Boolean addToExclusionRegion;
     SE_String positioningAlgorithm;
     SE_Integer renderPass;
Modified: trunk/MgDev/Common/Stylization/StylizationEngine.cpp
--- trunk/MgDev/Common/Stylization/StylizationEngine.cpp	2009-11-22 04:51:35 UTC (rev 4352)
+++ trunk/MgDev/Common/Stylization/StylizationEngine.cpp	2009-11-22 05:32:25 UTC (rev 4353)
@@ -649,8 +649,8 @@
                 // TODO: why are these in the symbol instance?
-                style->rstyle->addToExclusionRegions = sym->addToExclusionRegions.evaluate(exec);
-                style->rstyle->checkExclusionRegions = sym->checkExclusionRegions.evaluate(exec);
+                style->rstyle->addToExclusionRegion = sym->addToExclusionRegion.evaluate(exec);
+                style->rstyle->checkExclusionRegion = sym->checkExclusionRegion.evaluate(exec);
                 style->rstyle->drawLast = sym->drawLast.evaluate(exec);
                 const wchar_t* positioningAlgo = sym->positioningAlgorithm.evaluate(exec);
More information about the mapguide-commits mailing list
