[mapguide-commits] r4301 - trunk/MgDev/Common/CoordinateSystem
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Oct 16 19:07:15 EDT 2009
Author: NormOlsen
Date: 2009-10-16 19:07:14 -0400 (Fri, 16 Oct 2009)
New Revision: 4301
   trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp
Submission for RFC 76.  Corrected the tic placement algorithm coded in CoordSysTransform::PositionOfValue function.  Previously, the algorithm selected a position which precisely represented the ordinate value which was being ticked which produced ticks which meandered in and out of the boundary region of a map.  This algorithm was replaced with an algoirthm which always places the tick mark precisely on the boiundary line and the expense of an imprecision of the placement which is on the order of 1 part in 10 million max.
RFC 76 is in pretty good shape at this point, testing continues.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp	2009-10-16 22:57:39 UTC (rev 4300)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp	2009-10-16 23:07:14 UTC (rev 4301)
@@ -1204,42 +1204,77 @@
     return lineString.Detach ();
-// Returns integer status, two values currently supported.  Zero return
-// indicates that no position is returned for whatever reason.  Zero
-// return indicates that a position is returend.
+// Given a straight line segment in source coordinate system coordinates, this
+// function retuns a position precisely on that line segment such that the
+// indicated ordinate in the target coordinate system equals (very closely) the
+// provided value.
+// The function was devised to position tick marks on a viewport frame boundary
+// where the ordinate values selected are (of course) the ordinate values of the
+// grid coordinate system.  So, while rather general in nature, some of the
+// graticule/grid nomenclature has unavoidably crept into the comments describing
+// this function.
+// Returns integer status, four values currently supported.
+//  0 ==> Success!  A point with the provided ordinate value did exists on the
+//        provided line segment and the position of that point has been returned
+//        in the 'position' argument.
+//  1 ==> The provided ordinate value did not occur within the domain of the line
+//        segment provided.
+//  2 ==> While the provided ordinate value did occur within the domain of the line
+//        segment provided, the slope of the line is such that calculation to
+//        determine the desired point would be unstable and was not attempted.
+// -1 ==> An exception was thrown during the calculation of the position,
+//        which _usually_ indicates that the data provided is inappropriate for
+//        one (or both) of the coordinates systems involved in this Transform.
 INT32 CCoordinateSystemTransform::PositionOfValue (MgCoordinate* position,double ordinateValue,INT32 orientation,MgCoordinate* from,MgCoordinate* to)
     INT32 status;
+    INT32 killer;
     double ratio;
+    double magicFactor;
     double xx, yy;
-    double deltaX, deltaY;
+    double srcLength, trgLength;
+    double deltaRatio;
+    double srcDeltaX, srcDeltaY;
+    double trgDeltaX, trgDeltaY;
+    double cosine, sine;
     double minValue, maxValue;
     double tmpDbl;
-    Ptr<MgCoordinate> gridFrom;
-    Ptr<MgCoordinate> gridTo;
+    MgCoordinate* srcFrom;
+    MgCoordinate* srcTo;
+    Ptr<MgCoordinate> trgFrom;
+    Ptr<MgCoordinate> trgTo;
+    status = -1;        // Until we know different.
+    // We need copies of these pointers so we can swap then as necessary.
+    srcFrom = from;
+    srcTo = to;
     MG_TRY ()
-        status = 0;
+        // We begin our work in the target coordinate system realm.
         // Convert the from and to points to the grid coordinate system.
-        gridFrom = Transform (from);
-        gridTo = Transform (to);
+        trgFrom = Transform (from);
+        trgTo = Transform (to);
         // Extract the from and to ordinate values which will match the
         // ordinate value we've been provided.
         if (orientation == MgCoordinateSystemGridOrientation::EastWest)
             // Here if value is a easting ordinate.
-            minValue = gridFrom->GetX ();
-            maxValue = gridTo->GetX ();
+            minValue = trgFrom->GetX ();
+            maxValue = trgTo->GetX ();
         else if (orientation == MgCoordinateSystemGridOrientation::NorthSouth)
             // Here if value is a northing ordinate.
-            minValue = gridFrom->GetY ();
-            maxValue = gridTo->GetY ();
+            minValue = trgFrom->GetY ();
+            maxValue = trgTo->GetY ();
         else
@@ -1247,21 +1282,22 @@
             throw new MgInvalidArgumentException(L"MgCoordinateSystemTransform.PositionOfValue",
                                                  __LINE__, __WFILE__, NULL, L"", NULL);
         if (minValue > maxValue)
-            // We swap the points and min/max values to preserve our sanity.
-            // This makes the rest of this code almost trivial.
+            // The relationship between the source and target coordinate systems,
+            // with respect to the specific ordinate value we are seeking, is
+            // and inverse relationship.  To preserve our sanity, we adjust so
+            // that the relationship is direct and the algorithm below gets
+            // a lot simpler and thus (hopefully) more reliable.
             tmpDbl = minValue;
             minValue = maxValue;
             maxValue = tmpDbl;
-            xx = gridFrom->GetX ();
-            gridFrom->SetX (gridTo->GetX ());
-            gridTo->SetX (xx);
-            yy = gridFrom->GetY ();
-            gridFrom->SetY (gridTo->GetY ());
-            gridTo->SetY (yy);
+            srcFrom = to;
+            srcTo = from;
+            trgFrom = Transform (srcFrom);
+            trgTo = Transform (srcTo);
         // To prevent duplicate tics, we place a tick at the minPoint if appropriate,
@@ -1269,48 +1305,106 @@
         // the provided ordinate value on the line provided.
         if (ordinateValue >= minValue && ordinateValue < maxValue)
-            deltaX = gridTo->GetX () - gridFrom->GetX ();
-            deltaY = gridTo->GetY () - gridFrom->GetY ();
+            // It appears that the desired ordinate value does indeed exist on this
+            // line segment.  Until we have successfully calculated a position, the
+            // return status will be 2, i.e. the thing exists but the determination
+            // of its position failed.
+            status = 2;
+            // Get the geometry of the provided segment in target terms.  You're right,
+            // assuming that this segment in target coordinates is a straight line is
+            // a very bad assumption.  That's what all the code below is about.
+            trgDeltaX = trgTo->GetX () - trgFrom->GetX ();
+            trgDeltaY = trgTo->GetY () - trgFrom->GetY ();
+            trgLength = sqrt (trgDeltaX * trgDeltaX + trgDeltaY * trgDeltaY);
+            // Compute the magic factor.  This is essentially the amount we will
+            // move along the source line for each unit of deviation from the
+            // the provided ordinate in the traget coordinate space.  The 0.75
+            // factor is to prevent an oscillation around the desired value and
+            // ensure convergence of the interative calculation.  This value
+            // will be the subject of fine tuning in the future.
+            if (orientation == MgCoordinateSystemGridOrientation::EastWest)
+                magicFactor = 0.75 * (trgDeltaX / trgLength) / trgLength;
+            else
+                magicFactor = 0.75 * (trgDeltaY / trgLength) / trgLength;
+            srcDeltaX = srcTo->GetX () - srcFrom->GetX ();
+            srcDeltaY = srcTo->GetY () - srcFrom->GetY ();
             // We do not try to place northing ticks on a line which more horizontal than it
             // is vertical; and vice versa.
-            if ((deltaX > deltaY) && (orientation == MgCoordinateSystemGridOrientation::EastWest) ||
-                (deltaY > deltaX) && (orientation == MgCoordinateSystemGridOrientation::NorthSouth))
+            if ((trgDeltaX > trgDeltaY) && (orientation == MgCoordinateSystemGridOrientation::EastWest) ||
+                (trgDeltaY > trgDeltaX) && (orientation == MgCoordinateSystemGridOrientation::NorthSouth))
                 // Use some simple geomtery to calculate the approximate position of the
-                // the point on the provided line segment at which the indicated ordinate
-                // approximates the provided ordinate value.
+                // the ordinateValue on the provided line segment at which the indicated
+                // ordinate approximates the provided ordinate value.
                 ratio = (ordinateValue - minValue) / (maxValue - minValue);
-                xx = gridFrom->GetX () + deltaX * ratio;
-                yy = gridFrom->GetY () + deltaY * ratio;
-                // This member function was added as a private member as part
-                // of the RFC #76 development effort.  All the information to
-                // perform this functyion is present in this object.  It was
-                // made private as to do otherwise would change the public API,
-                // a change which was not approved as part of the RFC.
-                TransformInverse (xx,yy);
+                // Ratio is the magic number we will deal with in the following iterative
+                // loop.  Essentially, ratio indicates how far along the line between the
+                // source 'from' point and the source 'to' point is the current estimate of
+                // 'position'.  As we zero in on the desired point, we will be moving
+                // 'ratio' up and down.  The point here being, as long as ratio is between
+                // zero and one, we know that it represents a point which is precisely on
+                // the underlying line, which in this case is the provided line in the
+                // source coordinate system.  Also, the ratio approach is unitless, thus
+                // this makes it easier to determine when to terminate the iterative loop.
+                // Currently, we use 1 part in a million.
+                killer = 12;
+                deltaRatio = 0.0;
+                do
+                    ratio += deltaRatio;
+                    // Calculate the new 'position' estimate based on the current value
+                    // of 'ratio'.  N
+                    xx = srcFrom->GetX () + srcDeltaX * ratio;
+                    yy = srcFrom->GetY () + srcDeltaY * ratio;
-                // xx and yy are now an approximation (usually a pretty good
-                // one) of the position of the provided ordinate value on the
-                // provided line in frame corodinates.  We _could_ tighten this
-                // up a little but here; but for know we'll just go with this
-                // approximation until such time as we decide we like this
-                // algorithm well enough to invest more resources in it.
-                position->SetX (xx);
-                position->SetY (yy);
-                status = 0;
+                    // The TransformInverse function was added as a private member as part
+                    // of the RFC #76 development effort.  All the information to perform
+                    // this function is present in this object.  It was made private as to
+                    // do otherwise would change the public API, a change which was not
+                    // approved as part of the RFC.
+                    // Convert the proposed 'position' point back to the coordinates of
+                    // the target system (i.e. of the ordinate value argument).
+                    Transform (&xx,&yy);
+                    // Make an estimate as to how much, and what direction, we need to
+                    // move 'ratio' to achieve the desired result.
+                        deltaRatio = (ordinateValue - xx) * magicFactor;
+                    else
+                        deltaRatio = (ordinateValue - yy) * magicFactor;
+                    killer -= 1;
+                } while (fabs (deltaRatio) > 1.0E-08 && killer >= 0);
+                if (killer >= 0)
+                    position->SetX (xx);
+                    position->SetY (yy);
+                    status = 0;
-            else
-                status = 2;
         else
             status = 1;
-    MG_CATCH_AND_THROW(L"MgCoordinateSystemTransform.TransformM")
+    MG_CATCH (L"MgCoordinateSystemTransform.PositionOfValue")
     return status;
 void CCoordinateSystemTransform::IgnoreDatumShiftWarning(bool bIgnoreDatumShiftWarning)
More information about the mapguide-commits mailing list
