[mapguide-commits] r4221 -
trunk/Tools/Maestro/Maestro/FusionEditor/CustomizedEditors
svn_mapguide at osgeo.org
Mon Sep 14 16:59:16 EDT 2009
Author: ksgeograf
Date: 2009-09-14 16:59:16 -0400 (Mon, 14 Sep 2009)
New Revision: 4221
trunk/Tools/Maestro/Maestro/FusionEditor/CustomizedEditors/Print.cs
Maestro: Fixed issue #1085.
Modified: trunk/Tools/Maestro/Maestro/FusionEditor/CustomizedEditors/Print.cs
--- trunk/Tools/Maestro/Maestro/FusionEditor/CustomizedEditors/Print.cs 2009-09-14 20:53:29 UTC (rev 4220)
+++ trunk/Tools/Maestro/Maestro/FusionEditor/CustomizedEditors/Print.cs 2009-09-14 20:59:16 UTC (rev 4221)
@@ -17,48 +17,48 @@
// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
#endregion
-using System;
-using System.Collections;
-using System.ComponentModel;
-using System.Drawing;
-using System.Windows.Forms;
-using OSGeo.MapGuide.MaestroAPI.ApplicationDefinition;
-namespace OSGeo.MapGuide.Maestro.FusionEditor.CustomizedEditors
- public class Print : FusionEditor.BasisWidgetEditor
+using System;
+using System.Collections;
+using System.ComponentModel;
+using System.Drawing;
+using System.Windows.Forms;
+using OSGeo.MapGuide.MaestroAPI.ApplicationDefinition;
+namespace OSGeo.MapGuide.Maestro.FusionEditor.CustomizedEditors
+ public class Print : FusionEditor.BasisWidgetEditor
private System.Windows.Forms.Label label5;
private System.Windows.Forms.TextBox PageTitle;
private System.Windows.Forms.CheckBox ShowNorthArrow;
private System.Windows.Forms.CheckBox ShowLegend;
private System.Windows.Forms.CheckBox ShowTitle;
- private System.Windows.Forms.CheckBox ShowPrintUI;
- private System.ComponentModel.IContainer components = null;
- public Print()
- // This call is required by the Windows Form Designer.
- InitializeComponent();
- // TODO: Add any initialization after the InitializeComponent call
- /// <summary>
- /// Clean up any resources being used.
- /// </summary>
- protected override void Dispose( bool disposing )
- if( disposing )
- if (components != null)
- components.Dispose();
- base.Dispose( disposing );
+ private System.Windows.Forms.CheckBox ShowPrintUI;
+ private System.ComponentModel.IContainer components = null;
+ public Print()
+ // This call is required by the Windows Form Designer.
+ InitializeComponent();
+ // TODO: Add any initialization after the InitializeComponent call
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ protected override void Dispose( bool disposing )
+ if( disposing )
+ if (components != null)
+ components.Dispose();
+ base.Dispose( disposing );
public override void SetItem(WidgetType w)
try
@@ -82,14 +82,14 @@
m_isUpdating = false;
- #region Designer generated code
- /// <summary>
- /// Required method for Designer support - do not modify
- /// the contents of this method with the code editor.
- /// </summary>
- private void InitializeComponent()
+ #region Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
this.PageTitle = new System.Windows.Forms.TextBox();
this.label5 = new System.Windows.Forms.Label();
this.ShowNorthArrow = new System.Windows.Forms.CheckBox();
@@ -125,7 +125,7 @@
this.ShowNorthArrow.Name = "ShowNorthArrow";
this.ShowNorthArrow.Size = new System.Drawing.Size(600, 16);
this.ShowNorthArrow.TabIndex = 25;
- this.ShowNorthArrow.Text = "Show Root Folder";
+ this.ShowNorthArrow.Text = "Show north arrow";
this.ShowNorthArrow.CheckedChanged += new System.EventHandler(this.ShowNorthArrow_CheckedChanged);
// ShowLegend
@@ -136,7 +136,7 @@
this.ShowLegend.Name = "ShowLegend";
this.ShowLegend.Size = new System.Drawing.Size(600, 16);
this.ShowLegend.TabIndex = 24;
- this.ShowLegend.Text = "Hide invisible layers";
+ this.ShowLegend.Text = "Show legend";
this.ShowLegend.CheckedChanged += new System.EventHandler(this.ShowLegend_CheckedChanged);
// ShowTitle
@@ -147,7 +147,7 @@
this.ShowTitle.Name = "ShowTitle";
this.ShowTitle.Size = new System.Drawing.Size(600, 16);
this.ShowTitle.TabIndex = 27;
- this.ShowTitle.Text = "Show Root Folder";
+ this.ShowTitle.Text = "Show title";
this.ShowTitle.CheckedChanged += new System.EventHandler(this.ShowTitle_CheckedChanged);
// ShowPrintUI
@@ -158,7 +158,7 @@
this.ShowPrintUI.Name = "ShowPrintUI";
this.ShowPrintUI.Size = new System.Drawing.Size(600, 16);
this.ShowPrintUI.TabIndex = 26;
- this.ShowPrintUI.Text = "Hide invisible layers";
+ this.ShowPrintUI.Text = "Show print UI";
this.ShowPrintUI.CheckedChanged += new System.EventHandler(this.ShowPrintUI_CheckedChanged);
// Print
@@ -173,7 +173,7 @@
this.Size = new System.Drawing.Size(616, 128);
this.ResumeLayout(false);
#endregion
private void PageTitle_TextChanged(object sender, System.EventArgs e)
@@ -214,7 +214,7 @@
return;
SetSettingValue("ShowTitle", ShowTitle.Checked.ToString().ToLower());
More information about the mapguide-commits
