[mapguide-commits] r4223 - in trunk/MgDev/Common: CoordinateSystem
Geometry/CoordinateSystem
svn_mapguide at osgeo.org
Tue Sep 15 16:27:31 EDT 2009
Author: NormOlsen
Date: 2009-09-15 16:27:30 -0400 (Tue, 15 Sep 2009)
New Revision: 4223
trunk/MgDev/Common/CoordinateSystem/CoordSysProjectionInformation.cpp
trunk/MgDev/Common/CoordinateSystem/MentorUtil.cpp
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemProjectionCode.h
RE: MapGuide Trac #1090. This submission updates the CoordinateSystem API to include the three new projection variations recently submitted to CsMap (Trac # 42 and revision #1619). The three new projection variations are:
1> Popular Visualization Pseudo Mercator (ala Google Maps and Microsoft Virtual Earth)
2> Ellipsoidal form of the Equidistant Cylindrical
3> Direct implementation of the PLate Carree.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysProjectionInformation.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysProjectionInformation.cpp 2009-09-15 08:42:22 UTC (rev 4222)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysProjectionInformation.cpp 2009-09-15 20:27:30 UTC (rev 4223)
@@ -32,7 +32,7 @@
//MENTOR_MAINTENANCE: The following constant is the number of
//different projections supported by the Mentor library. It
//will need to be adjusted if Mentor adds additional projections.
-const long klNumProjections = 67;
+const long klNumProjections = 71;
//MENTOR_MAINTENANCE: This is a list of all projections that
@@ -105,7 +105,11 @@
MgCoordinateSystemProjectionCode::Teacyl,
MgCoordinateSystemProjectionCode::Trmrkrg,
MgCoordinateSystemProjectionCode::Winkl,
- MgCoordinateSystemProjectionCode::Vdgrntn
+ MgCoordinateSystemProjectionCode::Vdgrntn,
+ MgCoordinateSystemProjectionCode::Sys34_01,
+ MgCoordinateSystemProjectionCode::EdcylE,
+ MgCoordinateSystemProjectionCode::PlateCarree,
+ MgCoordinateSystemProjectionCode::PvMercator
Modified: trunk/MgDev/Common/CoordinateSystem/MentorUtil.cpp
--- trunk/MgDev/Common/CoordinateSystem/MentorUtil.cpp 2009-09-15 08:42:22 UTC (rev 4222)
+++ trunk/MgDev/Common/CoordinateSystem/MentorUtil.cpp 2009-09-15 20:27:30 UTC (rev 4223)
@@ -111,7 +111,7 @@
static const CCsPrjAdditionalInfo s_prjInfo[] = {
-// projtype org_lng org_lat scl_red quad offset
+// projtype org_lng org_lat scl_red quad offset
{ MgCoordinateSystemProjectionCode::Alber, true, true, false, true, true },
{ MgCoordinateSystemProjectionCode::Azede, true, true, false, true, true},
{ MgCoordinateSystemProjectionCode::Azmea, true, true, false, true, true },
@@ -179,6 +179,10 @@
{ MgCoordinateSystemProjectionCode::Winkl, true, false, false, true, true},
{ MgCoordinateSystemProjectionCode::Nrthsrt, false, false, false, true, true},
{ MgCoordinateSystemProjectionCode::Lmbrtaf, true, true, false, true, true},
+ { MgCoordinateSystemProjectionCode::Sys34_01, false, false, false, true, false },
+ { MgCoordinateSystemProjectionCode::EdcylE, true, true, false, true, true },
+ { MgCoordinateSystemProjectionCode::PlateCarree, true, true, false, true, true },
+ { MgCoordinateSystemProjectionCode::PvMercator, false, true, false, true, true },
{ MgCoordinateSystemProjectionCode::Unknown, false, false, false, false, false }
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemProjectionCode.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemProjectionCode.h 2009-09-15 08:42:22 UTC (rev 4222)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemProjectionCode.h 2009-09-15 20:27:30 UTC (rev 4223)
@@ -39,7 +39,7 @@
static const INT32 Eckert4 = 25; // Ekert Pseudocylindrical Projection; Number IV
static const INT32 Eckert6 = 26; // Ekert Pseudocylindrical Projection; Number VI
static const INT32 Edcnc = 12; // Equidistant Conic Projection; aka Simple Conic
- static const INT32 Edcyl = 20; // Equidistant Cylindrical Projection
+ static const INT32 Edcyl = 20; // Equidistant Cylindrical Projection (Spherical only)
static const INT32 GaussK = 46; // Gauss-Kruger: Transverse Mercator without scale reduction parameter.
static const INT32 Gnomonic = 19; // Gnomonic Projection
static const INT32 Goode = 28; // Goode Homolosine Projection
@@ -96,6 +96,10 @@
static const INT32 Winkl = 63; // Winkel-Tripel; variable standard latitude
static const INT32 Nrthsrt = 64; // Nerth with scale and rotation
static const INT32 Lmbrtaf = 65; // Lambert Conformal Conic with affine post-processor.
+ static const INT32 Sys34_01 = 66; // Combination of Transverse Mercator and polynomial expansion used in Denmark. Polynominals are of the 2001 vintage.
+ static const INT32 EdcylE = 67; // Equidistant Cylindrical Projection, Ellipsoidal or Spherical
+ static const INT32 PlateCarree = 68; // Inplementation of Plate Carree as a variation of the Equidistant Cylindrical
+ static const INT32 PvMercator = 69; // Popular Visualization Pseudo Mercator (aka Google Earth)
static const INT32 Unknown = 0;
More information about the mapguide-commits
