[mapguide-commits] r4225 - trunk/MgDev/Server/src/Services/Feature
svn_mapguide at osgeo.org
Tue Sep 15 20:46:09 EDT 2009
Author: leaf
Date: 2009-09-15 20:46:08 -0400 (Tue, 15 Sep 2009)
New Revision: 4225
trunk/MgDev/Server/src/Services/Feature/ServerSqlCommand.cpp
Ticket #1073: Implement MapGuide RFC 80 - Parameter Binding.
This ticket is to fix one bug on MgSFeatureService::ExecuteNonQuery(). Out parameter doesn't work because we put MgServerFeatureUtil::UpdateParameterCollection(...) before fdoCommand->ExecuteNonQuery(). So after SQL statement is executed, parameter isn't updated.
Modified: trunk/MgDev/Server/src/Services/Feature/ServerSqlCommand.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerSqlCommand.cpp 2009-09-15 21:49:09 UTC (rev 4224)
+++ trunk/MgDev/Server/src/Services/Feature/ServerSqlCommand.cpp 2009-09-16 00:46:08 UTC (rev 4225)
@@ -109,13 +109,13 @@
MgServerFeatureUtil::FillFdoParameterCollection(params, fdoParams);
+ // Execute the command
+ rowsAffected = fdoCommand->ExecuteNonQuery();
// Update parameter whose direction is InputOutput, Output, or Return.
if (NULL != params && params->GetCount() > 0)
MgServerFeatureUtil::UpdateParameterCollection(fdoParams, params);
- // Execute the command
- rowsAffected = fdoCommand->ExecuteNonQuery();
MG_FEATURE_SERVICE_CHECK_CONNECTION_CATCH_AND_THROW(resource, L"MgServerSqlCommand.ExecuteQuery")
return rowsAffected;
More information about the mapguide-commits
