[mapguide-commits] r4235 - trunk/MgDev/Common/Schema
svn_mapguide at osgeo.org
Fri Sep 18 17:44:31 EDT 2009
Author: tomfukushima
Date: 2009-09-18 17:44:29 -0400 (Fri, 18 Sep 2009)
New Revision: 4235
Added:
trunk/MgDev/Common/Schema/LoadProcedure-2.2.0.xsd
#1097 RFC 85 - Add SQLite as a load procedure type
Submitting the new schema for RFC 85. Created by Romica Dascalescu.
Added: trunk/MgDev/Common/Schema/LoadProcedure-2.2.0.xsd
--- trunk/MgDev/Common/Schema/LoadProcedure-2.2.0.xsd (rev 0)
+++ trunk/MgDev/Common/Schema/LoadProcedure-2.2.0.xsd 2009-09-18 21:44:29 UTC (rev 4235)
@@ -0,0 +1,391 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" attributeFormDefault="unqualified" version="2.2.0">
+ <xs:element name="LoadProcedure">
+ <xs:annotation>
+ <xs:documentation>Specification of a load procedure</xs:documentation>
+ </xs:annotation>
+ <xs:complexType>
+ <xs:complexContent>
+ <xs:extension base="LoadProcedureTypeType">
+ <xs:attribute name="version" type="xs:string" fixed="2.2.0"/>
+ </xs:extension>
+ </xs:complexContent>
+ </xs:complexType>
+ </xs:element>
+ <xs:complexType name="LoadProcedureTypeType">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:choice>
+ <xs:element name="SdfLoadProcedure" type="SdfLoadProcedureType">
+ <xs:annotation>
+ <xs:documentation>Load procedure for SDFs</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DwfLoadProcedure" type="DwfLoadProcedureType">
+ <xs:annotation>
+ <xs:documentation>Load procedure for DWFs</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ShpLoadProcedure" type="ShpLoadProcedureType">
+ <xs:annotation>
+ <xs:documentation>Load procedure for SHPs</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DwgLoadProcedure" type="DwgLoadProcedureType"/>
+ <xs:element name="RasterLoadProcedure" type="RasterLoadProcedureType"/>
+ <xs:element name="SQLiteLoadProcedure" type="SQLiteLoadProcedureType">
+ <xs:annotation>
+ <xs:documentation>Load procedure for SQLites</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:choice>
+ </xs:complexType>
+ <xs:complexType name="LoadProcedureType">
+ <xs:annotation>
+ <xs:documentation>Base type of the load procedures</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="SourceFile" type="xs:string" minOccurs="0" maxOccurs="unbounded">
+ <xs:annotation>
+ <xs:documentation>The list of input files for the load procedure</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="RootPath" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The path in the site repository where the resources are created</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="CoordinateSystem" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The default coordinate system to assign to the resulting data resources if none is found</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="GenerateSpatialDataSources" type="xs:boolean">
+ <xs:annotation>
+ <xs:documentation>Indicates whether or not to generate spatial data sources</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="SpatialDataSourcesPath" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The path to the folder in the site repository where the spatial data sources are created</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="SpatialDataSourcesFolder" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The folder in the site repository under the Spatial Data Sources Path where the spatial data sources are created</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="GenerateLayers" type="xs:boolean">
+ <xs:annotation>
+ <xs:documentation>Indicates whether or not to generate layers</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LayersPath" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The path to the folder in the site repository where the layers are created</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LayersFolder" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The folder in the site repository under the Layers Path where the layers are created</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="GenerateMaps" type="xs:boolean" minOccurs="0" maxOccurs="1">
+ <xs:annotation>
+ <xs:documentation>Indicates whether or not to generate maps</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="MapsPath" type="xs:string" minOccurs="0" maxOccurs="1">
+ <xs:annotation>
+ <xs:documentation>The path to the folder in the site repository where the maps are created</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="MapsFolder" type="xs:string" minOccurs="0" maxOccurs="1">
+ <xs:annotation>
+ <xs:documentation>The folder in the site repository under the Maps Path where the maps are created</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="GenerateSymbolLibraries" type="xs:boolean" minOccurs="0" maxOccurs="1">
+ <xs:annotation>
+ <xs:documentation>Indicates whether or not to generate symbol libraries</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="SymbolLibrariesPath" type="xs:string" minOccurs="0" maxOccurs="1">
+ <xs:annotation>
+ <xs:documentation>The path to the folder in the site repository where the symbol libraries are created</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="SymbolLibrariesFolder" type="xs:string" minOccurs="0" maxOccurs="1">
+ <xs:annotation>
+ <xs:documentation>The folder in the site repository under the Symbol Libraries Path where the symbol libraries are created</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ResourceId" type="xs:string" minOccurs="0" maxOccurs="unbounded">
+ <xs:annotation>
+ <xs:documentation>Zero or more ResourceIds that were created from the execution of the load procedure</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="SdfLoadProcedureType">
+ <xs:annotation>
+ <xs:documentation>Extension of LoadProcedure for SDFs</xs:documentation>
+ </xs:annotation>
+ <xs:extension base="LoadProcedureType">
+ <xs:sequence>
+ <xs:element name="Generalization" type="PercentageType">
+ <xs:annotation>
+ <xs:documentation>Reduces the point (or vertex) count of each map feature to the specified percentage of the original count</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="SdfKeyTreatment" type="SdfKeyTreatmentType">
+ <xs:annotation>
+ <xs:documentation>Specifies how the Sdf conversion step of an SdfLoadProcedure treats keys</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:simpleType name="SdfKeyTreatmentType">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:restriction base="xs:string">
+ <xs:enumeration value="AutogenerateAll">
+ <xs:annotation>
+ <xs:documentation>All keys in the original Sdf file are replaced in the converted Sdf file by an automatically generated unique key</xs:documentation>
+ </xs:annotation>
+ </xs:enumeration>
+ <xs:enumeration value="DiscardDuplicates">
+ <xs:annotation>
+ <xs:documentation>The keys in the original Sdf file are maintaind in the converted Sdf file, and only the first occurance of a feature associated with a duplicate key in the original Sdf file will be written to the converted Sdf file</xs:documentation>
+ </xs:annotation>
+ </xs:enumeration>
+ <xs:enumeration value="MergeDuplicates">
+ <xs:annotation>
+ <xs:documentation>The keys in the original Sdf file are maintaind in the converted Sdf file, and all of the features associated with a duplicate key in the original Sdf file will be merged into a single feature in the converted Sdf file</xs:documentation>
+ </xs:annotation>
+ </xs:enumeration>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:complexType name="SQLiteLoadProcedureType">
+ <xs:annotation>
+ <xs:documentation>Extension of LoadProcedure for SQLites</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:simpleType name="OverlapTreatmentType">
+ <xs:annotation>
+ <xs:documentation>Specifies how to treat edge overlap when merging bitonal images.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="None">
+ <xs:annotation>
+ <xs:documentation>No bitonal merge.</xs:documentation>
+ </xs:annotation>
+ </xs:enumeration>
+ <xs:enumeration value="ForegroundOn">
+ <xs:annotation>
+ <xs:documentation>Forground pixels are the on bits.</xs:documentation>
+ </xs:annotation>
+ </xs:enumeration>
+ <xs:enumeration value="ForegroundOff">
+ <xs:annotation>
+ <xs:documentation>Forground pixels are the off bits.</xs:documentation>
+ </xs:annotation>
+ </xs:enumeration>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:complexType name="DwfLoadProcedureType">
+ <xs:annotation>
+ <xs:documentation>Extension of LoadProcedure for DWFs</xs:documentation>
+ </xs:annotation>
+ <xs:extension base="LoadProcedureType"/>
+ </xs:complexType>
+ <xs:complexType name="ShpLoadProcedureType">
+ <xs:annotation>
+ <xs:documentation>Extension of LoadProcedure for SHPs</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ConvertToSdf" type="xs:boolean">
+ <xs:annotation>
+ <xs:documentation>Indicates whether or not to convert to an SDF feature source</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="GeoReferenceOverrideType">
+ <xs:annotation>
+ <xs:documentation>Override values to replace geo reference properties from the world file corresponding to the specified image source file.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="SourceFile" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The path of the source file to which these geo reference overrides apply.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LocationX" type="xs:double">
+ <xs:annotation>
+ <xs:documentation>The X-coordinate override of the location specified in the world file corresponding to the specified source file.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LocationY" type="xs:double">
+ <xs:annotation>
+ <xs:documentation>The Y-coordinate override of the location specified in the world file corresponding to the specified source file.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ScaleX" type="xs:double">
+ <xs:annotation>
+ <xs:documentation>the X-scale override to replace that specified in the world file corresponding to the specified source file.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ScaleY" type="xs:double">
+ <xs:annotation>
+ <xs:documentation>the Y-scale override to replace that specified in the world file corresponding to the specified source file.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="RasterLoadProcedureType">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="FeatureSourceName" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The base name of the FeatureSource to load.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="SubsampleFactor" type="xs:double">
+ <xs:annotation>
+ <xs:documentation>Subsample factor for reducing file size.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="OverlapTreatmentType" type="OverlapTreatmentType">
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="GeoReferenceOverride" type="GeoReferenceOverrideType" minOccurs="0" maxOccurs="unbounded">
+ <xs:annotation>
+ <xs:documentation>The list of geo reference overrides.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:simpleType name="PercentageType">
+ <xs:annotation>
+ <xs:documentation>A percentage value</xs:documentation>
+ </xs:annotation>
+ <xs:restriction base="xs:double">
+ <xs:minInclusive value="0"/>
+ <xs:maxInclusive value="100"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:complexType name="DwgLoadProcedureType">
+ <xs:annotation>
+ <xs:documentation>Extension of LoadProcedure for DWGs and DXFs</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="FileComponents">
+ <xs:annotation>
+ <xs:documentation>List of DWG files and their layers to be extracted, whether selected or not.</xs:documentation>
+ </xs:annotation>
+ <xs:complexType>
+ <xs:sequence>
+ <xs:element name="FileComponent" type="DwgFileComponentType" maxOccurs="unbounded">
+ <xs:annotation>
+ <xs:documentation>One DWG file and its layers</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ </xs:element>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ClosedPolylinesToPolygons" type="xs:boolean">
+ <xs:annotation>
+ <xs:documentation>Indicates whether to convert closed polyline features to polygons</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="DwgFileComponentType">
+ <xs:annotation>
+ <xs:documentation>Specifies a DWG file and its list of layers</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="Name" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The name of the DWG file</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LayerComponents">
+ <xs:annotation>
+ <xs:documentation>List of DWG layers</xs:documentation>
+ </xs:annotation>
+ <xs:complexType>
+ <xs:sequence>
+ <xs:element name="LayerComponent" type="DwgLayerComponentType" maxOccurs="unbounded">
+ <xs:annotation>
+ <xs:documentation>One DWG layer</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="DwgLayerComponentType">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ <xs:documentation>The name of the layer</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Selected" type="xs:boolean">
+ <xs:annotation>
+ <xs:documentation>Indicates whether this layer is to be extracted when executing the Load Procedure</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+</xs:schema>
Property changes on: trunk/MgDev/Common/Schema/LoadProcedure-2.2.0.xsd
___________________________________________________________________
Added: svn:eol-style
+ native
More information about the mapguide-commits
