[mapguide-commits] r4242 - branches/2.1/MgDev/Common/MdfModel
svn_mapguide at osgeo.org
Mon Sep 21 11:27:32 EDT 2009
Author: uvlite
Date: 2009-09-21 11:27:31 -0400 (Mon, 21 Sep 2009)
New Revision: 4242
branches/2.1/MgDev/Common/MdfModel/VectorScaleRange.cpp
branches/2.1/MgDev/Common/MdfModel/VectorScaleRange.h
rfc60 add a string based color list to the VectorScaleRange
Modified: branches/2.1/MgDev/Common/MdfModel/VectorScaleRange.cpp
--- branches/2.1/MgDev/Common/MdfModel/VectorScaleRange.cpp 2009-09-21 15:26:01 UTC (rev 4241)
+++ branches/2.1/MgDev/Common/MdfModel/VectorScaleRange.cpp 2009-09-21 15:27:31 UTC (rev 4242)
@@ -22,7 +22,18 @@
#include "stdafx.h"
#include "VectorScaleRange.h"
+#include "AreaRule.h"
+#include "LineRule.h"
+#include "PointRule.h"
+#include "CompositeRule.h"
+#include "BlockSymbol.h"
+#include "FontSymbol.h"
+#include "ImageSymbol.h"
+#include "MarkSymbol.h"
+#include "TextSymbol.h"
+#include "W2DSymbol.h"
using namespace MDFMODEL_NAMESPACE;
// we must undefine the max macro so the limits max function compiles correctly
@@ -44,6 +55,7 @@
this->m_dMinScale = 0.0;
this->m_dMaxScale = MAX_MAP_SCALE;
this->m_elevationSettings = NULL;
+ this->m_usedColorList = NULL;
@@ -51,8 +63,11 @@
VectorScaleRange::~VectorScaleRange()
+ // delete members which are pointers explicitely
if (this->m_elevationSettings != NULL)
delete this->m_elevationSettings;
+ if (this->m_usedColorList != NULL)
+ delete this->m_usedColorList;
@@ -141,3 +156,112 @@
this->m_elevationSettings = elevationSettings;
+/// PURPOSE: Accessor method for the base colors defined in this Layer and scaleRange.
+/// RETURNS: A pointer to the list of colors of the collected colors (maybe empty but not null)
+PSTRCOLORLIST VectorScaleRange::GetUsedColorList()
+ // lazy instantiation
+ if (this->m_usedColorList) return this->m_usedColorList;
+ // this should be sufficiently thread safe as the object is created immediately
+ PSTRCOLORLIST usedColorList = this->m_usedColorList = new STRCOLORLIST();
+ // compute new color list by iterating through the featuretypecollection
+ FeatureTypeStyleCollection* pftsColl = this->GetFeatureTypeStyles();
+ int ftsccount = pftsColl->GetCount();
+ for (int j=0; j< ftsccount; j++)
+ FeatureTypeStyle* pfts = pftsColl->GetAt(j);
+ // iterate through the rulecollection
+ RuleCollection* ruleColl = pfts->GetRules();
+ int rccount = ruleColl->GetCount();
+ for (int k=0; k < rccount; k++)
+ Rule* rule = ruleColl->GetAt(k);
+ // get the label which will be the key in the color map
+ const MdfString& label = rule->GetLegendLabel();
+ // do the casting to access the relevant members
+ // this is bad style (instead of virtual functions GetColors() in each subclass)
+ // but we save touching too many different files
+ AreaRule* paRule = dynamic_cast<AreaRule*>(rule);
+ LineRule* plRule = dynamic_cast<LineRule*>(rule);
+ PointRule* ppRule = dynamic_cast<PointRule*>(rule);
+ //CompositeRule* pcRule = dynamic_cast<CompositeRule*>(rule); // no colors in there
+ // AreaRule Symbolization.....
+ if (paRule != NULL)
+ { AreaSymbolization2D* pasym = paRule->GetSymbolization();
+ if (pasym->GetFill() != NULL)
+ { // create copies of all strings!!! so we can safely delete the resulting list later
+ usedColorList->push_back(pasym->GetFill()->GetForegroundColor().substr());
+ usedColorList->push_back(pasym->GetFill()->GetBackgroundColor().substr());
+ if (pasym->GetEdge() != NULL)
+ usedColorList->push_back(pasym->GetEdge()->GetColor().substr());
+ // LineRule Symbolization.....
+ if (plRule != NULL)
+ LineSymbolizationCollection* plsymcol = plRule->GetSymbolizations();
+ // iterate through the linesymbolizations
+ int lsccount = plsymcol->GetCount();
+ for (int l=0; l < lsccount; l++)
+ LineSymbolization2D* plsym = plsymcol->GetAt(l);
+ if (plsym->GetStroke() != NULL)
+ usedColorList->push_back(plsym->GetStroke()->GetColor().substr());
+ // PointRule Symbolization.....
+ if (ppRule != NULL)
+ PointSymbolization2D* ppsym = ppRule->GetSymbolization();
+ if (ppsym)
+ Symbol *sym = ppsym->GetSymbol();
+ MdfModel::BlockSymbol* blockSymbol = dynamic_cast<MdfModel::BlockSymbol*>(sym);
+ MdfModel::FontSymbol* fontSymbol = dynamic_cast<MdfModel::FontSymbol*>(sym);
+ MdfModel::MarkSymbol* markSymbol = dynamic_cast<MdfModel::MarkSymbol*>(sym);
+ MdfModel::TextSymbol* textSymbol = dynamic_cast<MdfModel::TextSymbol*>(sym);
+ MdfModel::W2DSymbol* w2dSymbol = dynamic_cast<MdfModel::W2DSymbol*>(sym);
+ if (blockSymbol != NULL)
+ usedColorList->push_back(blockSymbol->GetBlockColor().substr());
+ usedColorList->push_back(blockSymbol->GetLayerColor().substr());
+ if (fontSymbol != NULL)
+ usedColorList->push_back(fontSymbol->GetForegroundColor().substr());
+ if (markSymbol != NULL)
+ if (markSymbol->GetEdge() != NULL)
+ usedColorList->push_back(markSymbol->GetEdge()->GetColor().substr());
+ if (markSymbol->GetFill() != NULL) {
+ usedColorList->push_back(markSymbol->GetFill()->GetForegroundColor().substr());
+ usedColorList->push_back(markSymbol->GetFill()->GetBackgroundColor().substr());
+ if (textSymbol != NULL)
+ usedColorList->push_back(textSymbol->GetForegroundColor().substr());
+ usedColorList->push_back(textSymbol->GetBackgroundColor().substr());
+ if (w2dSymbol != NULL)
+ usedColorList->push_back(w2dSymbol->GetFillColor().substr());
+ usedColorList->push_back(w2dSymbol->GetLineColor().substr());
+ usedColorList->push_back(w2dSymbol->GetTextColor().substr());
+ } // if pointSymbolization
+ } // end pointRule
+ } // for GetRules
+ } // for GetFeatureTypeStyles
+ return this->m_usedColorList;
Modified: branches/2.1/MgDev/Common/MdfModel/VectorScaleRange.h
--- branches/2.1/MgDev/Common/MdfModel/VectorScaleRange.h 2009-09-21 15:26:01 UTC (rev 4241)
+++ branches/2.1/MgDev/Common/MdfModel/VectorScaleRange.h 2009-09-21 15:27:31 UTC (rev 4242)
@@ -23,7 +23,11 @@
#include "FeatureTypeStyle.h"
#include "ElevationSettings.h"
#include "MdfRootObject.h"
+#include <list>
+typedef std::list<const MdfModel::MdfString> STRCOLORLIST;
+typedef STRCOLORLIST* PSTRCOLORLIST;
BEGIN_NAMESPACE_MDFMODEL
@@ -62,6 +66,9 @@
ElevationSettings* GetElevationSettings();
void AdoptElevationSettings(ElevationSettings* elevationSettings);
+ // Computed Property : UsedColorList
+ PSTRCOLORLIST GetUsedColorList();
private:
// Hidden copy constructor and assignment operator.
VectorScaleRange(const VectorScaleRange&);
@@ -79,6 +86,9 @@
// Extended data
ElevationSettings* m_elevationSettings;
+ // cached colorlist
+ PSTRCOLORLIST m_usedColorList;
typedef MdfOwnerCollection<VectorScaleRange> VectorScaleRangeCollection;
More information about the mapguide-commits
