[mapguide-commits] r4244 -
branches/2.1/MgDev/Server/src/Services/Rendering
svn_mapguide at osgeo.org
Mon Sep 21 11:34:17 EDT 2009
Author: uvlite
Date: 2009-09-21 11:34:17 -0400 (Mon, 21 Sep 2009)
New Revision: 4244
branches/2.1/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
branches/2.1/MgDev/Server/src/Services/Rendering/ServerRenderingService.h
rfc60 add code to RenderMapInternal to extract source map XML colors and pass onto renderer
Modified: branches/2.1/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
--- branches/2.1/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp 2009-09-21 15:32:33 UTC (rev 4243)
+++ branches/2.1/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp 2009-09-21 15:34:17 UTC (rev 4244)
@@ -37,7 +37,7 @@
static const INT32 FILTER_HASTOOLTIPS = 4;
IMPLEMENT_CREATE_SERVICE(MgServerRenderingService)
// used when we want to process a given number of features
bool StylizeThatMany(void* data)
@@ -48,7 +48,7 @@
return false;
MgServerRenderingService::MgServerRenderingService() : MgRenderingService()
m_pCSFactory = new MgCoordinateSystemFactory();
@@ -110,12 +110,12 @@
GDRenderer::s_bGeneralizeData = bGeneralizeData;
MgServerRenderingService::~MgServerRenderingService()
MgByteReader* MgServerRenderingService::RenderTile(MgMap* map,
CREFSTRING baseMapLayerGroupName,
INT32 tileColumn,
@@ -186,8 +186,8 @@
return ret.Detach();
+/// render a map using all layers from the baseGroup
MgLayerGroup* baseGroup,
INT32 scaleIndex,
@@ -257,7 +257,8 @@
+/// default arg bKeepSelection = true
MgByteReader* MgServerRenderingService::RenderDynamicOverlay(MgMap* map,
MgSelection* selection,
CREFSTRING format)
@@ -266,7 +267,8 @@
return RenderDynamicOverlay(map, selection, format, true);
CREFSTRING format,
@@ -278,7 +280,8 @@
return RenderDynamicOverlay(map, selection, &options);
+/// called from API (first call of AjaxPgPViewerSampleApplication)
MgRenderingOptions* options)
@@ -344,7 +347,8 @@
MgByteReader* MgServerRenderingService::RenderMap(MgMap* map,
CREFSTRING format)
@@ -353,7 +357,8 @@
return RenderMap(map, selection, format, true);
+/// default arg bClip = false
CREFSTRING format,
@@ -362,7 +367,10 @@
return RenderMap(map, selection, format, bKeepSelection, false);
+/// render complete map around center point in given scale
+/// using maps background color and display sizes as default arguments to call the real rendermap method
+/// default arg (bKeepSelection = true, bClip = false)
CREFSTRING format,
@@ -393,7 +401,8 @@
MgEnvelope* extents,
@@ -406,7 +415,9 @@
return RenderMap(map, selection, extents, width, height, backgroundColor, format, true);
+/// render the provided extent of the map and align aspect ratios to the provided window
@@ -501,8 +512,8 @@
+/// default argument bKeepSelection = true
MgCoordinate* center,
@@ -515,8 +526,8 @@
// Call updated RenderMap API
return RenderMap(map, selection, center, scale, width, height, backgroundColor, format, true);
+/// default arguments bClip = false
@@ -529,8 +540,9 @@
return RenderMap(map, selection, center, scale, width, height, backgroundColor, format, bKeepSelection, false);
+/// render map around center point in given scale
+/// (default args bKeepSelection = true, bClip = false, backgroundColor = map->backgroundColor, width = map->getDisplayWidth, height = map->getDisplayHeight)
@@ -589,7 +601,7 @@
MgFeatureInformation* MgServerRenderingService::QueryFeatures(MgMap* map,
MgStringCollection* layerNames,
MgGeometry* geometry,
@@ -600,7 +612,7 @@
return QueryFeatures(map, layerNames, geometry, selectionVariant, L"", maxFeatures, 3 /*visible and selectable*/);
@@ -691,7 +703,7 @@
MgBatchPropertyCollection* MgServerRenderingService::QueryFeatureProperties(MgMap* map,
MgGeometry* filterGeometry,
@@ -702,7 +714,7 @@
return QueryFeatureProperties(map, layerNames, filterGeometry, selectionVariant, L"", maxFeatures, 3 /*visible and selectable*/);
@@ -731,8 +743,8 @@
+/// pack options into object and forward call (select Selection AND Layers) maybe keepSelection
MgByteReader* MgServerRenderingService::RenderMapInternal(MgMap* map,
MgReadOnlyLayerCollection* roLayers,
@@ -750,7 +762,14 @@
return RenderMapInternal(map, selection, roLayers, dr, saveWidth, saveHeight, scale, b, expandExtents, &options);
+/// called from (indirectly):
+//// RenderMap(complete), RenderMap(extent)(roLayers == NULL)
+/// RenderTile (selection == NULL)
+/// render the map using from the provided rolayers
+///(this is the baseGroup layers for rendering tiles)
+/// render map using provided options object from before
+/// this is called for tiles and for dynamic overlays
@@ -804,9 +823,10 @@
// begin map stylization
dr->StartMap(&mapInfo, b, scale, map->GetDisplayDpi(), map->GetMetersPerUnit(), NULL);
+ MG_TRY()
// if no layer collection is supplied, then put all layers in a temporary collection
Ptr<MgReadOnlyLayerCollection> tempLayers = SAFE_ADDREF(roLayers);
- if (tempLayers == NULL)
+ if (tempLayers == NULL) // if called from renderMap not RenderTile
tempLayers = new MgReadOnlyLayerCollection();
Ptr<MgLayerCollection> layers = map->GetLayers();
@@ -877,8 +897,16 @@
modLayers, overrideFilters, &ds, dr, dstCs, false, false, scale, (behavior & MgRenderingOptions::KeepSelection) != 0);
+ MG_CATCH(L"MgServerRenderingService.RenderMapInternal-StylizeLayers")
- dr->EndMap();
+ dr->EndMap(); // cleanup??
+ if (mgException.p)
+ //throw mgException; // to skip tile we need to throw an exception as a NULL return
+ // // will cause a null pointer exception.
// draw a border around the tile - used for debugging
@@ -909,11 +937,29 @@
// Both AGG and GD expect the format to be an uppercase string
STRING format = MgUtil::ToUpper(imageFormat);
- if (wcscmp(m_rendererName.c_str(), L"AGG") == 0)
- data.reset(((AGGRenderer*)dr)->Save(format, saveWidth, saveHeight));
- else
- data.reset(((GDRenderer*)dr)->Save(format, saveWidth, saveHeight));
+ /// PNG8 code by UV
+ /// we examine the expressions collected from xml definitions of all layer.
+ /// the color Palette for the renderer is a vector<RSColor> allocated on the stack
+ RSCOLORS tileColorPalette(map->GetColorPalette()->size());
+ /// the map object has a list from all color entries found in the most recent Layerstylization
+ /// TODO currently they are interpreted as ffffffff 32 bit RGBA string values.
+ /// adding expresssions and other interpretations could be done here.
+ try {
+ ParseColorStrings (&tileColorPalette, map);
+ #ifdef _DEBUG_PNG8
+ printf("<<<<<<<<<<<<<<<<<<<<< MgServerRenderingService::ColorPalette->size(): %d\n", mapColorPalette->size());
+ #endif
+ // call the image renderer to create the image ----------------------------------------
+ if (wcscmp(m_rendererName.c_str(), L"AGG") == 0)
+ data.reset(((AGGRenderer*)dr)->Save(format, saveWidth, saveHeight, &tileColorPalette));
+ else
+ data.reset(((GDRenderer*)dr)->Save(format, saveWidth, saveHeight));
+ } catch (exception e) {
+ ACE_DEBUG((LM_DEBUG, L"(%t) %w caught in RenderingService ColorPaletteGeneration\n", e.what()));
+ throw e;
if (NULL != data.get())
// put this into a byte source
@@ -930,11 +976,46 @@
ret = bs->GetReader();
+ else throw new MgNullArgumentException(L"RenderMapInternal", __LINE__, __WFILE__, NULL, L"No data from Renderer", NULL);
+/// PNG8 code by UV
+/// we examine the expressions collected from xml definitions of all layer.
+/// the color Palette for the renderer is a list<RSColor>
+//// PRSCOLORLIST tileColorPalette = new RSCOLORLIST();
+/// the map object has a list from all color entries found in the most recent Layerstylization
+/// TODO currently they are interpreted as ffffffff 32 bit RGBA string values.
+/// adding expresssions and other interpretations could be done here.
+void MgServerRenderingService::ParseColorStrings (PRSCOLORS tileColorPalette, MgMap* map)
+ assert(tileColorPalette);
+ assert(map);
+ PSTRCOLORLIST mapColorList = map->GetColorPalette();
+ if (mapColorList && !mapColorList->empty()) // add them if they are available
+ // lets sort & uniquify the list
+ mapColorList->sort();
+ mapColorList->unique();
+ STRCOLORLIST::iterator it = mapColorList->begin();
+ for(int i=0; it != mapColorList->end(); it++,i++)
+ // string color reader for 0xAARRGGBB "%10X" XML color strings
+ // this is parsed and converted using the MgColor(string) ctor which also uses rgba order
+ // but it* is in argb order ergo => r=a, g=r, b=g, a=b
+ MgColor c(*it);
+ // set the RS_Color(r,g,b,a) assign the crossed over colors
+ tileColorPalette->at(i).red() = c.GetGreen();
+ tileColorPalette->at(i).green() = c.GetBlue();
+ tileColorPalette->at(i).blue() = c.GetAlpha();
+ tileColorPalette->at(i).alpha() = c.GetRed();
MgByteReader* MgServerRenderingService::RenderMapLegend(MgMap* map,
INT32 width,
INT32 height,
@@ -1020,8 +1101,7 @@
// A helper function that does most of the work for QueryFeatures
// and QueryFeatureProperties. Basically runs a rendering loop with
// a custom renderer supplied by the caller that accumulates selection
@@ -1379,13 +1459,13 @@
MG_THROW()
void MgServerRenderingService::SetConnectionProperties(MgConnectionProperties*)
// Do nothing. No connection properties are required for server-side service objects.
SE_Renderer* MgServerRenderingService::CreateRenderer(int width,
int height,
RS_Color& bgColor,
Modified: branches/2.1/MgDev/Server/src/Services/Rendering/ServerRenderingService.h
--- branches/2.1/MgDev/Server/src/Services/Rendering/ServerRenderingService.h 2009-09-21 15:32:33 UTC (rev 4243)
+++ branches/2.1/MgDev/Server/src/Services/Rendering/ServerRenderingService.h 2009-09-21 15:34:17 UTC (rev 4244)
@@ -18,6 +18,7 @@
#ifndef MGSERVERRENDERINGSERVICE_H
#define MGSERVERRENDERINGSERVICE_H
+#include "AGGRenderer.h"
#include "ServerRenderingDllExport.h"
class SE_Renderer;
@@ -203,6 +204,11 @@
bool requiresClipping,
bool localOverposting = false,
double tileExtentOffset = 0.0);
+ /// parse the expressions collected from xml definitions of all layer.
+ /// the color Palette passed to the renderer is a std::list<RSColor>
+ void ParseColorStrings (PRSCOLORS tileColorPalette, MgMap* map);
// member data
Ptr<MgFeatureService> m_svcFeature;
More information about the mapguide-commits
