[mapguide-commits] r4251 - in trunk/MgDev/Common: CoordinateSystem
Geometry/CoordinateSystem
svn_mapguide at osgeo.org
Tue Sep 22 19:03:52 EDT 2009
Author: NormOlsen
Date: 2009-09-22 19:03:51 -0400 (Tue, 22 Sep 2009)
New Revision: 4251
trunk/MgDev/Common/CoordinateSystem/MentorUtil.cpp
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformationMethod.h
Submitted in response to Trac ticket 1099. The CS-MAP repository was updated producing revision 1622. This submission to the MgDev repository adds the new geodetic transformation method ("CHENYX") to the coordinate system API.
Modified: trunk/MgDev/Common/CoordinateSystem/MentorUtil.cpp
--- trunk/MgDev/Common/CoordinateSystem/MentorUtil.cpp 2009-09-22 23:01:56 UTC (rev 4250)
+++ trunk/MgDev/Common/CoordinateSystem/MentorUtil.cpp 2009-09-22 23:03:51 UTC (rev 4251)
@@ -879,6 +879,7 @@
case MgCoordinateSystemGeodeticTransformationMethod::DHDN:
case MgCoordinateSystemGeodeticTransformationMethod::ETRF89:
case MgCoordinateSystemGeodeticTransformationMethod::Geocentric:
+ case MgCoordinateSystemGeodeticTransformationMethod::CHENYX:
return true;
default:
return false;
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformationMethod.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformationMethod.h 2009-09-22 23:01:56 UTC (rev 4250)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformationMethod.h 2009-09-22 23:03:51 UTC (rev 4251)
@@ -64,7 +64,8 @@
static const INT32 DHDN = 23; // DHDN<->ETRF89 via Grid Files
static const INT32 ETRF89 = 24; // Is ETRF89, no shift required
static const INT32 Lclgrf = 99; // Local Geodetic Reference System
- static const INT32 Geocentric = 25; // Three Parameter Transformation
+ static const INT32 Geocentric = 25; // Geocentric Translation
+ static const INT32 CHENYX = 26 // Swiss Ch1903 to CH1903+
More information about the mapguide-commits
