[mapguide-commits] r4253 -
sandbox/rfc60/MgDev/Server/src/Services/Tile
svn_mapguide at osgeo.org
Tue Sep 22 19:16:38 EDT 2009
Author: uvlite
Date: 2009-09-22 19:16:38 -0400 (Tue, 22 Sep 2009)
New Revision: 4253
sandbox/rfc60/MgDev/Server/src/Services/Tile/ServerTileService.cpp
sandbox/rfc60/MgDev/Server/src/Services/Tile/ServerTileService.h
comments and refactoring
Modified: sandbox/rfc60/MgDev/Server/src/Services/Tile/ServerTileService.cpp
--- sandbox/rfc60/MgDev/Server/src/Services/Tile/ServerTileService.cpp 2009-09-22 23:08:45 UTC (rev 4252)
+++ sandbox/rfc60/MgDev/Server/src/Services/Tile/ServerTileService.cpp 2009-09-22 23:16:38 UTC (rev 4253)
@@ -116,13 +116,15 @@
return found;
-MgByteReader* MgServerTileService::GetTile(
- MgResourceIdentifier* mapDefinition,
- CREFSTRING baseMapLayerGroupName,
- INT32 tileColumn,
- INT32 tileRow,
- INT32 scaleIndex)
+/// create tilename from mapDefinition, scaleIndex, row&col
+/// remove lockfile, look for the tile in the cache,
+/// if not in cache create lockfile and look for map in mapcache
+MgByteReader* MgServerTileService::GetTile( MgResourceIdentifier* mapDefinition,
+ CREFSTRING baseMapLayerGroupName,
+ INT32 tileColumn,
+ INT32 tileRow,
+ INT32 scaleIndex)
Ptr<MgByteReader> ret;
FILE* lockFile = NULL;
@@ -148,27 +150,10 @@
throw new MgInvalidArgumentException(L"MgServerTileService.GetTile",
__LINE__, __WFILE__, &arguments, L"MgInvalidScaleIndex", NULL);
- MgServiceManager* serviceMan = MgServiceManager::GetInstance();
- assert(NULL != serviceMan);
- // Get the service from service manager
- Ptr<MgResourceService> resourceService = dynamic_cast<MgResourceService*>(
- serviceMan->RequestService(MgServiceType::ResourceService));
- assert(NULL != resourceService);
- if (!resourceService->HasPermission(mapDefinition, MgResourcePermission::ReadOnly))
- MG_LOG_AUTHENTICATION_ENTRY(MgResources::PermissionDenied.c_str());
- MgStringCollection arguments;
- arguments.Add(mapDefinition->ToString());
- throw new MgPermissionDeniedException(
- L"MgServerTileService.GetTile",
- __LINE__, __WFILE__, &arguments, L"", NULL);
+ // Get the service from our helper method
+ Ptr<MgResourceService> resourceService = GetResourceServiceForMapDef(mapDefinition,
+ L"MgServerTileService.GetTile");
// Generate tile and lock pathnames.
m_tileCache->GeneratePathnames(mapDefinition, scaleIndex, baseMapLayerGroupName,
tileColumn, tileRow, tilePathname, lockPathname, false);
@@ -195,6 +180,7 @@
// Protect the serialized MgMap cache with a mutex. Stream reading is not
// thread safe so we need to deserialize the map within the mutex to ensure
// that a Rewind() is not called in the middle of a Deserialize()
+ // lockfile test and creation is in same protected scope
// Attemp to lock the tile file.
ACE_MT(ACE_GUARD_RETURN(ACE_Recursive_Thread_Mutex, ace_mon, sm_mutex, NULL));
@@ -214,7 +200,7 @@
if (NULL != ret)
- break;
+ break; // tile was in tileCache .. done.
// Create the lock file and close it right away.
@@ -225,9 +211,9 @@
arguments.Add(lockPathname);
+ // MgUnableToOpenTileFile???? sounds wrong.... lock file maybe?
throw new MgFileIoException(L"MgServerTileService.GetTile",
- __LINE__, __WFILE__, &arguments, L"MgUnableToOpenTileFile", NULL);
+ __LINE__, __WFILE__, &arguments, L"MgUnableToOpenLockFile", NULL);
else
@@ -263,7 +249,7 @@
map = new MgMap();
map->Deserialize(stream);
+ } // end of mutex scope
double scale = map->GetFiniteDisplayScaleAt(scaleIndex);
map->SetViewScale(scale);
@@ -284,8 +270,8 @@
return ret.Detach();
+/// look for the tile in the tilecache first
MgByteReader* MgServerTileService::GetTile(MgMap* map,
INT32 tileColumn,
@@ -388,7 +374,8 @@
+/// render a tile and store it in da cache
MgByteReader* MgServerTileService::GetTile(CREFSTRING tilePathname, MgMap* map, INT32 scaleIndex,
CREFSTRING baseMapLayerGroupName, INT32 tileColumn, INT32 tileRow)
@@ -421,7 +408,8 @@
return img.Detach();
+/// take a tile image and store it in the tilecache using lockfiles
void MgServerTileService::SetTile(MgByteReader* img,
MgMap* map,
INT32 scaleIndex,
@@ -496,8 +484,33 @@
MG_THROW()
+/// accessor method for resource service
+MgResourceService* MgServerTileService::GetResourceServiceForMapDef
+ (MgResourceIdentifier* mapDefinition, CREFSTRING funcName)
+ // get service Manager
+ MgServiceManager* serviceMan = MgServiceManager::GetInstance();
+ assert(NULL != serviceMan);
+ // Get the service from service manager
+ Ptr<MgResourceService> resourceService = dynamic_cast<MgResourceService*>(
+ serviceMan->RequestService(MgServiceType::ResourceService));
+ assert(NULL != resourceService);
+ if (!resourceService->HasPermission(mapDefinition, MgResourcePermission::ReadOnly))
+ MG_LOG_AUTHENTICATION_ENTRY(MgResources::PermissionDenied.c_str());
+ MgStringCollection arguments;
+ arguments.Add(mapDefinition->ToString());
+ throw new MgPermissionDeniedException(
+ funcName, __LINE__, __WFILE__, &arguments, L"", NULL);
+ return resourceService.Detach();
void MgServerTileService::ClearCache(MgMap* map)
MG_TRY()
Modified: sandbox/rfc60/MgDev/Server/src/Services/Tile/ServerTileService.h
--- sandbox/rfc60/MgDev/Server/src/Services/Tile/ServerTileService.h 2009-09-22 23:08:45 UTC (rev 4252)
+++ sandbox/rfc60/MgDev/Server/src/Services/Tile/ServerTileService.h 2009-09-22 23:16:38 UTC (rev 4253)
@@ -68,6 +68,8 @@
CREFSTRING baseMapLayerGroupName, INT32 tileColumn, INT32 tileRow);
void ClearMapCache(CREFSTRING mapName);
+ MgResourceService* GetResourceServiceForMapDef (MgResourceIdentifier* mapDefinition,
+ CREFSTRING funcName);
// member data
Ptr<MgTileCache> m_tileCache;
More information about the mapguide-commits
