[mapguide-commits] r4262 - trunk/MgDev/Common/CoordinateSystem
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Sep 25 17:00:19 EDT 2009
Author: NormOlsen
Date: 2009-09-25 17:00:19 -0400 (Fri, 25 Sep 2009)
New Revision: 4262
   trunk/MgDev/Common/CoordinateSystem/CoordSysMathComparator.cpp
Upgrade CCoordinateSystemMathComparator: This submission addresses MapGuide Trac #1106.
Prior to this submission, the "SameDatum" member of this object would not actually compare the numeric qualities of the referenced ellipsoid, it would only compare the name of the ellipsoid referenced.  Thus, this member failed to live up to the name and purpose of this object.  With this submission, the "SameDatum" method will now call the "SameEllipsoid" method to determine if the two referenced ellipsoids are numerically identical.  Additionally, the numeric comparison of the two datums was updated to include several new features:
1> Recognizing when a datum definition is that of the null transform and reporting any two "null transforms", no matter how defined, as being numerically equivalent.
2> Comparing only those parameters used by a specific transformation technique.
3> Recognition that the GEOCENTRIC and MOLODENSKY transformations are numerically equivalent for the purposes of this object.
Similarly, and more importantly, the SameCoordinateSystem member of this object simply compared the names of the referenced datums and would not actually compare the numeric qualities of the two datums referenced by the two coordinate systems.  With this submission, the "SameDatum" member is called to compare the two datum references.  Thus, all three members of this object no live up to the name and purpose of this object.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysMathComparator.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysMathComparator.cpp	2009-09-24 14:12:23 UTC (rev 4261)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysMathComparator.cpp	2009-09-25 21:00:19 UTC (rev 4262)
@@ -147,28 +147,137 @@
     assert(pDefinition1);
     assert(pDefinition2);
     if (!pDefinition1 || !pDefinition2) return false;
     bool bResult;
+    unsigned paramCount;
+    unsigned orgDeltaZeroCount;
     cs_Dtdef_ def1, def2;
     bResult = BuildDtDefFromInterface(pDefinition1, def1);
     if (!bResult) return bResult;
     bResult = BuildDtDefFromInterface(pDefinition2, def2);
-    //??// the following should compare the actual ellipsoid definitions.  There are several ellipsoids
-    // which have different names yet are, essentially, the same ellipsoid.
-    if (0 != CS_stricmp(def1.ell_knm, def2.ell_knm)) return false;
-    // Delta values are always in meters.
-    if (!FloatEqual(def1.delta_X, def2.delta_X, kdEpsilonLinear)) return false;
-    if (!FloatEqual(def1.delta_Y, def2.delta_Y, kdEpsilonLinear)) return false;
-    if (!FloatEqual(def1.delta_Z, def2.delta_Z, kdEpsilonLinear)) return false;
-    // Rotations are always in arc-seconds.
-    if (!FloatEqual(def1.rot_X, def2.rot_X, kdEpsilonArcSec)) return false;
-    if (!FloatEqual(def1.rot_Y, def2.rot_Y, kdEpsilonArcSec)) return false;
-    if (!FloatEqual(def1.rot_Z, def2.rot_Z, kdEpsilonArcSec)) return false;
-    // Datum scale values are always in parts per million difference from unity.
-    if (!FloatEqual(def1.bwscale, def2.bwscale, kdEpsilonDatumScale)) return false;
+    // Check the ellipsoids for "numerical" equivalence.
+    Ptr<MgCoordinateSystemEllipsoid> pEllipsoid1 = pDefinition1->GetEllipsoidDefinition ();
+    Ptr<MgCoordinateSystemEllipsoid> pEllipsoid2 = pDefinition2->GetEllipsoidDefinition ();
+    if (!SameEllipsoid (pEllipsoid1,pEllipsoid2)) return false;
+    // Determine if the two definitions are both the null transformation.
+    orgDeltaZeroCount  = (def1.delta_X == 0.0);
+    orgDeltaZeroCount += (def1.delta_Y == 0.0);
+    orgDeltaZeroCount += (def1.delta_Z == 0.0);
+    bool def1IsNull = (def1.to84_via == cs_DTCTYP_WGS84  ||
+                       def1.to84_via == cs_DTCTYP_NAD83  ||
+                       def1.to84_via == cs_DTCTYP_GDA94  ||
+                       def1.to84_via == cs_DTCTYP_NZGD2K ||
+                       def1.to84_via == cs_DTCTYP_ETRF89 ||
+                       def1.to84_via == cs_DTCTYP_RGF93  ||
+                       (orgDeltaZeroCount == 3 &&
+                         (def1.to84_via == cs_DTCTYP_GEOCTR ||
+                          def1.to84_via == cs_DTCTYP_3PARM  ||
+                          def1.to84_via == cs_DTCTYP_MOLO
+    orgDeltaZeroCount  = (def2.delta_X == 0.0);
+    orgDeltaZeroCount += (def2.delta_Y == 0.0);
+    orgDeltaZeroCount += (def2.delta_Z == 0.0);
+    bool def2IsNull = (def2.to84_via == cs_DTCTYP_WGS84  ||
+                       def2.to84_via == cs_DTCTYP_NAD83  ||
+                       def2.to84_via == cs_DTCTYP_GDA94  ||
+                       def2.to84_via == cs_DTCTYP_NZGD2K ||
+                       def2.to84_via == cs_DTCTYP_ETRF89 ||
+                       def2.to84_via == cs_DTCTYP_RGF93  ||
+                         (def2.to84_via == cs_DTCTYP_GEOCTR ||
+                          def2.to84_via == cs_DTCTYP_3PARM  ||
+                          def2.to84_via == cs_DTCTYP_MOLO
+    if (def1IsNull && def2IsNull)
+        // Both definitions represent a null conversion; therefore, they
+        // are "numerically" identical.
+        return true;
+    // Determine if the conversion technique is "numerically" identical.
+    // The GEOCENTRIC and MOLODENSKY are essentially the same.  So, we
+    // convert the conversion technique to GEOCENTRIC.
+    if (def1.to84_via == cs_DTCTYP_MOLO)
+        def1.to84_via = cs_DTCTYP_GEOCTR;
+    if (def2.to84_via == cs_DTCTYP_MOLO)
+        def2.to84_via = cs_DTCTYP_GEOCTR;
     if (def1.to84_via != def2.to84_via) return false;
+    // Determine the number of parameters apply to this definition.
+    switch (def1.to84_via)
+        case cs_DTCTYP_MOLO:
+        case cs_DTCTYP_3PARM:
+        case cs_DTCTYP_GEOCTR:
+            paramCount = 3;
+            break;
+        case cs_DTCTYP_4PARM:
+            paramCount = 4;
+            break;
+        case cs_DTCTYP_6PARM:
+            paramCount = 6;
+            break;
+        case cs_DTCTYP_MREG:        // MREG will use paramaters for automatic fallback.
+        case cs_DTCTYP_BURS:
+        case cs_DTCTYP_7PARM:
+            paramCount = 7;
+            break;
+        case cs_DTCTYP_NAD27:
+        case cs_DTCTYP_NAD83:
+        case cs_DTCTYP_WGS84:
+        case cs_DTCTYP_WGS72:
+        case cs_DTCTYP_HPGN:
+        case cs_DTCTYP_AGD66:
+        case cs_DTCTYP_AGD84:
+        case cs_DTCTYP_NZGD49:
+        case cs_DTCTYP_ATS77:
+        case cs_DTCTYP_GDA94:
+        case cs_DTCTYP_NZGD2K:
+        case cs_DTCTYP_CSRS:
+        case cs_DTCTYP_TOKYO:
+        case cs_DTCTYP_RGF93:
+        case cs_DTCTYP_ED50:
+        case cs_DTCTYP_DHDN:
+        case cs_DTCTYP_ETRF89:
+        case cs_DTCTYP_CHENYX:
+        default:
+            paramCount = 0;
+            break;
+    // Check the appropriate number of parameters.
+    if (paramCount > 0)
+        // Delta values are always in meters.
+        if (!FloatEqual(def1.delta_X, def2.delta_X, kdEpsilonLinear)) return false;
+        if (!FloatEqual(def1.delta_Y, def2.delta_Y, kdEpsilonLinear)) return false;
+        if (!FloatEqual(def1.delta_Z, def2.delta_Z, kdEpsilonLinear)) return false;
+        if (paramCount == 4 || paramCount == 7)
+            // Datum scale values are always in parts per million difference from unity.
+            if (!FloatEqual(def1.bwscale, def2.bwscale, kdEpsilonDatumScale)) return false;
+        if (paramCount > 4)
+            // Rotations are always in arc-seconds.
+            if (!FloatEqual(def1.rot_X, def2.rot_X, kdEpsilonArcSec)) return false;
+            if (!FloatEqual(def1.rot_Y, def2.rot_Y, kdEpsilonArcSec)) return false;
+            if (!FloatEqual(def1.rot_Z, def2.rot_Z, kdEpsilonArcSec)) return false;
 #ifdef _DEBUG
     bResult = true;
 #endif
@@ -201,15 +310,43 @@
     bResult = BuildCsDefFromInterface(pDefinition2, def2);
-    if (0 != CS_stricmp(def1.dat_knm, def2.dat_knm)) return false;
-    if (0 != CS_stricmp(def1.elp_knm, def2.elp_knm)) return false;
+    if (def1.dat_knm [0] != '\0' && def2.dat_knm [0] != '\0')
+        Ptr<MgCoordinateSystemDatum> pDatum1 = pDefinition1->GetDatumDefinition ();
+        Ptr<MgCoordinateSystemDatum> pDatum2 = pDefinition2->GetDatumDefinition ();
+        if (!SameDatum (pDatum1,pDatum2))
+            return false;
+    else if ((def1.dat_knm [0] == '\0' && def2.dat_knm [0] == '\0') &&
+             (def1.elp_knm [0] != '\0' && def2.elp_knm [0] != '\0'))
+            return false;
+    else
+        // Type of reference differs.
+        return false;
+    //??// It is true that the unitsmust always match, but not necessarily
+    // true that the projection must match.  However, delaing with the
+    // various projection variations which are equivalent when certain
+    // parameters are present is a non-trivial issue which we cannot
+    // deal with at the current time.  SO we leave this alone for now.
     // projection and units must match
     if (0 != CS_stricmp(def1.prj_knm, def2.prj_knm)) return false;
     if (0 != CS_stricmp(def1.unit, def2.unit)) return false;
     // We have verified that the projections are the same.  Use def1
-    // to inofrmation aboutthe projection.
+    // to obtain information about the projection.
     pp=GetMentorProjectionObject(def1.prj_knm);
     if (pp == NULL)
@@ -257,11 +394,11 @@
                     case cs_PRMLTYP_ZNBR:             // UTM Zone Number
                         epsilon = 0.5;
                         break;
-                    case cs_PRMLTYP_GHGT:             // Geoid Height in meters
+                    case cs_PRMLTYP_GHGT:             // Geoid Height (always meters)
                         epsilon = kdEpsilonLinear;
                         break;
-                    case cs_PRMLTYP_ELEV:             // Elevation, system units.
-                    case cs_PRMLTYP_XYCRD:            // X/Y Coordinate
+                    case cs_PRMLTYP_ELEV:             // Elevation, in system units.
+                    case cs_PRMLTYP_XYCRD:            // X/Y Coordinate (always system units)
                         epsilon = kdEpsilonLinear * def1.unit_scl;
                         break;
                     case cs_PRMLTYP_SCALE:            // Scale value
@@ -277,26 +414,31 @@
-    // The following are standard parameters which are standard for most, BUT
-    // NOT ALL, parameters.
+    // The following are standard parameters which are standard for most,
+    // BUT NOT ALL, parameters.
     if ((prj_flags & cs_PRJFLG_ORGLNG) == 0)
+        // Always in degrees.
         if (!FloatEqual(def1.org_lng, def2.org_lng, kdEpsilonGeographic)) return false;
     if ((prj_flags & cs_PRJFLG_ORGLAT) == 0)
         if (!FloatEqual(def1.org_lat, def2.org_lat, kdEpsilonGeographic)) return false;
     if ((prj_flags & cs_PRJFLG_ORGFLS) == 0)
+        // Always in system units.
         if (!FloatEqual(def1.x_off, def2.x_off, epsilon)) return false;
         if (!FloatEqual(def1.y_off, def2.y_off, epsilon)) return false;
     if ((prj_flags & cs_PRJFLG_SCLRED) != 0)
+        // Always a simple ratio (i.e. 1:2500 == 0.9996)
         if (!FloatEqual(def1.scl_red, def2.scl_red, kdEpsilonScale)) return false;
+    // Map scale is rarely (if ever) used and us usally set to unity.
     if (!FloatEqual(def1.map_scl, def2.map_scl, kdEpsilonScale)) return false;
     //If the units match, the unit scale matches.
More information about the mapguide-commits mailing list
