[mapguide-commits] r4266 - in trunk/MgDev/Common:
MapGuideCommon/MapLayer PlatformBase/MapLayer
svn_mapguide at osgeo.org
Sun Sep 27 02:53:44 EDT 2009
Author: leaf
Date: 2009-09-27 02:53:43 -0400 (Sun, 27 Sep 2009)
New Revision: 4266
trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp
trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.h
trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.cpp
Ticket #1109: MgLayerBase bypass its subclasses
https://trac.osgeo.org/mapguide/ticket/1109
Submit on behalf of Christine Bao.
Modified: trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp
--- trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp 2009-09-26 22:31:04 UTC (rev 4265)
+++ trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp 2009-09-27 06:53:43 UTC (rev 4266)
@@ -26,6 +26,7 @@
MgLayer::MgLayer()
: MgLayerBase()
+ m_initIdProps = true;
@@ -34,6 +35,7 @@
MgLayer::MgLayer(MgResourceIdentifier* layerDefinition, MgResourceService* resourceService)
: MgLayerBase(layerDefinition, resourceService)
GetLayerInfoFromDefinition(resourceService);
@@ -43,6 +45,7 @@
MgLayer::MgLayer(MgResourceIdentifier* layerDefinition, MgResourceService* resourceService, bool initIdProps)
+ m_initIdProps = initIdProps;
if (initIdProps)
@@ -55,7 +58,8 @@
MgLayer::MgLayer(MgResourceIdentifier* layerDefinition, MgResourceService* resourceService, bool initIdProps, bool initLayerDefinition)
: MgLayerBase(layerDefinition, resourceService, initLayerDefinition)
- if (initIdProps)
+ if (initIdProps && initLayerDefinition)
@@ -96,47 +100,51 @@
void MgLayer::GetLayerInfoFromDefinition(MgResourceService* resourceService)
- MG_TRY()
+ MgLayerBase::GetLayerInfoFromDefinition(resourceService);
- // Generate Id field information for feature sources
- m_idProps.clear();
- if (!m_featureName.empty())
+ if(m_initIdProps && resourceService != NULL)
- // If we cannot pull the identity properties, silently ignore it.
- try
+ MG_TRY()
+ // Generate Id field information for feature sources
+ m_idProps.clear();
+ if (!m_featureName.empty())
- //TODO: Pull site connection directly from resource service
- Ptr<MgUserInformation> userInfo = resourceService->GetUserInfo();
- Ptr<MgSiteConnection> conn = new MgSiteConnection();
- conn->Open(userInfo);
+ // If we cannot pull the identity properties, silently ignore it.
+ try
+ //TODO: Pull site connection directly from resource service
+ Ptr<MgUserInformation> userInfo = resourceService->GetUserInfo();
+ Ptr<MgSiteConnection> conn = new MgSiteConnection();
+ conn->Open(userInfo);
- Ptr<MgFeatureService> featureService = dynamic_cast<MgFeatureService*>(conn->CreateService(MgServiceType::FeatureService));
- Ptr<MgResourceIdentifier> resId = new MgResourceIdentifier(m_featureSourceId);
+ Ptr<MgFeatureService> featureService = dynamic_cast<MgFeatureService*>(conn->CreateService(MgServiceType::FeatureService));
+ Ptr<MgResourceIdentifier> resId = new MgResourceIdentifier(m_featureSourceId);
- // If the class name is fully qualified (prefixed with a schema name),
- // then use it to determine the schema name.
- STRING className;
- STRING schemaName;
- ParseFeatureName(featureService, className, schemaName);
+ // If the class name is fully qualified (prefixed with a schema name),
+ // then use it to determine the schema name.
+ STRING className;
+ STRING schemaName;
+ ParseFeatureName(featureService, className, schemaName);
- // Get the identity properties
- Ptr<MgStringCollection> classNames = new MgStringCollection();
- classNames->Add(className);
- Ptr<MgClassDefinitionCollection> classDefs = featureService->GetIdentityProperties(resId, schemaName, classNames);
- if (NULL != classDefs.p && classDefs->GetCount() == 1)
+ // Get the identity properties
+ Ptr<MgStringCollection> classNames = new MgStringCollection();
+ classNames->Add(className);
+ Ptr<MgClassDefinitionCollection> classDefs = featureService->GetIdentityProperties(resId, schemaName, classNames);
+ if (NULL != classDefs.p && classDefs->GetCount() == 1)
+ Ptr<MgClassDefinition> classDef = classDefs->GetItem(0);
+ PopulateIdentityProperties(classDef);
+ catch (MgException* e)
- Ptr<MgClassDefinition> classDef = classDefs->GetItem(0);
- PopulateIdentityProperties(classDef);
+ e->Release();
+ // Do nothing here. A failure to pull selection id's is not critical at this point
- catch (MgException* e)
- e->Release();
- // Do nothing here. A failure to pull selection id's is not critical at this point
+ MG_CATCH_AND_THROW(L"MgLayer.GetLayerInfoFromDefinition")
- MG_CATCH_AND_THROW(L"MgLayer.GetLayerInfoFromDefinition")
Modified: trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.h
--- trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.h 2009-09-26 22:31:04 UTC (rev 4265)
+++ trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.h 2009-09-27 06:53:43 UTC (rev 4266)
@@ -307,6 +307,8 @@
MgMapBase* GetMap();
+ bool m_initIdProps;
CLASS_ID:
static const INT32 m_cls_id = MapGuide_MapLayer_Layer;
Modified: trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.cpp
--- trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.cpp 2009-09-26 22:31:04 UTC (rev 4265)
+++ trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.cpp 2009-09-27 06:53:43 UTC (rev 4266)
@@ -300,7 +300,7 @@
m_name = m_definition->GetName();
m_forceReadFromServer = true;
- MgLayerBase::GetLayerInfoFromDefinition(resourceService);
+ GetLayerInfoFromDefinition(resourceService);
m_forceReadFromServer = false;
if(m_layers != NULL)
@@ -330,7 +330,7 @@
m_resourceContent = resourceContent;
- MgLayerBase::GetLayerInfoFromDefinition(NULL);
+ GetLayerInfoFromDefinition(NULL);
m_layers->GetMap()->OnLayerDefinitionChanged(this);
More information about the mapguide-commits
