[mapguide-commits] r4273 - in sandbox/adsk/2.1:
Common/PlatformBase/Services Server/src/Services/Feature
svn_mapguide at osgeo.org
Tue Sep 29 11:51:03 EDT 2009
Author: brucedechant
Date: 2009-09-29 11:51:01 -0400 (Tue, 29 Sep 2009)
New Revision: 4273
sandbox/adsk/2.1/Common/PlatformBase/Services/RasterPropertyDefinition.cpp
sandbox/adsk/2.1/Common/PlatformBase/Services/RasterPropertyDefinition.h
sandbox/adsk/2.1/Server/src/Services/Feature/JoinFeatureReader.cpp
sandbox/adsk/2.1/Server/src/Services/Feature/ServerDescribeSchema.cpp
sandbox/adsk/2.1/Server/src/Services/Feature/ServerGetFeatures.cpp
sandbox/adsk/2.1/Server/src/Services/Feature/ServerGwsGetFeatures.cpp
sandbox/adsk/2.1/Server/src/Services/Feature/TransformCache.cpp
Fix for trac ticket 600 - WMS - coordinate system overriding fails
http://trac.osgeo.org/mapguide/ticket/600
Submitted on behalf of Troy Louden
Notes:
- Added spatial context association for raster properties
Modified: sandbox/adsk/2.1/Common/PlatformBase/Services/RasterPropertyDefinition.cpp
--- sandbox/adsk/2.1/Common/PlatformBase/Services/RasterPropertyDefinition.cpp 2009-09-29 09:50:51 UTC (rev 4272)
+++ sandbox/adsk/2.1/Common/PlatformBase/Services/RasterPropertyDefinition.cpp 2009-09-29 15:51:01 UTC (rev 4273)
@@ -73,6 +73,19 @@
/// <summary>
+/// Gets the Spatial Context name associated to this raster property.
+/// </summary>
+/// <returns>
+/// Returns a String value representing the Spatial Context name.
+/// If empty then the geometric property is associated with all the Spatial Contexts
+/// in the datastore.
+/// </returns>
+STRING MgRasterPropertyDefinition::GetSpatialContextAssociation()
+ return m_associatedSCName;
+/// <summary>
/// Sets a Boolean value that specifies whether this geometric property is read-only.
/// </summary>
/// <param name="value">
@@ -115,6 +128,19 @@
m_sizeY = size;
+/// <summary>
+/// Sets/add a Spatial Context association to this raster property.
+/// </summary>
+/// <param name="value">
+/// Input the Spatial Context name to be added/set.
+/// Defaults to the active Spatial Context.
+/// </param>
+/// <returns>Returns nothing</returns>
+void MgRasterPropertyDefinition::SetSpatialContextAssociation(CREFSTRING spatialContextName)
+ m_associatedSCName = spatialContextName;
MgRasterPropertyDefinition::MgRasterPropertyDefinition()
Initialize();
@@ -128,6 +154,7 @@
stream->WriteInt32(m_sizeX);
stream->WriteInt32(m_sizeY);
stream->WriteString(m_serializedXml);
+ stream->WriteString(m_associatedSCName);
void MgRasterPropertyDefinition::Deserialize(MgStream* stream)
@@ -138,6 +165,7 @@
stream->GetInt32(m_sizeX);
stream->GetInt32(m_sizeY);
stream->GetString(m_serializedXml);
+ stream->GetString(m_associatedSCName);
void MgRasterPropertyDefinition::Initialize()
@@ -146,8 +174,11 @@
m_nullable = false;
m_sizeX = 0;
m_sizeY = 0;
+ m_serializedXml = L"";
+ m_associatedSCName = L"";
void MgRasterPropertyDefinition::ToXml(string& xmlStr, bool includeType)
Modified: sandbox/adsk/2.1/Common/PlatformBase/Services/RasterPropertyDefinition.h
--- sandbox/adsk/2.1/Common/PlatformBase/Services/RasterPropertyDefinition.h 2009-09-29 09:50:51 UTC (rev 4272)
+++ sandbox/adsk/2.1/Common/PlatformBase/Services/RasterPropertyDefinition.h 2009-09-29 15:51:01 UTC (rev 4273)
@@ -141,7 +141,32 @@
/// rows).
INT32 GetDefaultImageYSize(); /// __get, __set
+ /// \brief
+ /// Gets the Spatial Context name associated with this raster
+ /// property.
+ /// <!-- Syntax in .Net, Java, and PHP -->
+ /// \htmlinclude DotNetSyntaxTop.html
+ /// string GetSpatialContextAssociation();
+ /// \htmlinclude SyntaxBottom.html
+ /// \htmlinclude JavaSyntaxTop.html
+ /// String GetSpatialContextAssociation();
+ /// \htmlinclude PHPSyntaxTop.html
+ /// \return
+ /// Returns a String value representing the Spatial Context
+ /// name. If the value is empty then the raster property is
+ /// associated with all the spatial contexts in the datastore.
+ /// \see
+ /// MgFeatureService::GetSpatialContexts.
+ STRING GetSpatialContextAssociation(); /// __get, __set
/// \brief
/// Sets a Boolean value that specifies whether this property is
@@ -244,6 +269,36 @@
void SetDefaultImageYSize (INT32 size);
+ /// \brief
+ /// Sets a Spatial Context association for this raster
+ /// property.
+ /// \remarks
+ /// If not set, this name defaults to the Spatial Context name
+ /// active in the datastore.
+ /// void SetSpatialContextAssociation(string spatialContextName);
+ /// void SetSpatialContextAssociation(String spatialContextName);
+ /// \param spatialContextName (String/string)
+ /// The Spatial Context name to
+ /// be set.
+ /// \return
+ /// Returns nothing.
+ void SetSpatialContextAssociation(CREFSTRING spatialContextName);
INTERNAL_API:
MgRasterPropertyDefinition();
@@ -259,6 +314,7 @@
INT32 m_sizeX;
INT32 m_sizeY;
STRING m_serializedXml;
+ STRING m_associatedSCName;
INTERNAL_API:
Modified: sandbox/adsk/2.1/Server/src/Services/Feature/JoinFeatureReader.cpp
--- sandbox/adsk/2.1/Server/src/Services/Feature/JoinFeatureReader.cpp 2009-09-29 09:50:51 UTC (rev 4272)
+++ sandbox/adsk/2.1/Server/src/Services/Feature/JoinFeatureReader.cpp 2009-09-29 15:51:01 UTC (rev 4273)
@@ -838,7 +838,7 @@
fdoPropDef->SetHasMeasure(hasMeasure);
fdoPropDef->SetReadOnly(isReadOnly);
- if(spatialContextName.empty())
+ if(!spatialContextName.empty())
fdoPropDef->SetSpatialContextAssociation((FdoString*)spatialContextName.c_str());
@@ -868,6 +868,7 @@
bool isNullable = mgPropDef->GetNullable();
STRING qname = mgPropDef->GetQualifiedName();
bool isReadOnly = mgPropDef->GetReadOnly();
+ STRING spatialContextName = mgPropDef->GetSpatialContextAssociation();
//Set it for Fdo
if (!desc.empty())
@@ -881,6 +882,11 @@
//Cannot set qualified name in fdo
+ fdoPropDef->SetSpatialContextAssociation((FdoString*)spatialContextName.c_str());
MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgJoinFeatureReader.GetRasterPropertyDefinition")
return fdoPropDef.Detach();
Modified: sandbox/adsk/2.1/Server/src/Services/Feature/ServerDescribeSchema.cpp
--- sandbox/adsk/2.1/Server/src/Services/Feature/ServerDescribeSchema.cpp 2009-09-29 09:50:51 UTC (rev 4272)
+++ sandbox/adsk/2.1/Server/src/Services/Feature/ServerDescribeSchema.cpp 2009-09-29 15:51:01 UTC (rev 4273)
@@ -1133,6 +1133,7 @@
//Set it for Fdo
if (!desc.empty())
@@ -1146,6 +1147,11 @@
MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerDescribeSchema.GetRasterPropertyDefinition")
Modified: sandbox/adsk/2.1/Server/src/Services/Feature/ServerGetFeatures.cpp
--- sandbox/adsk/2.1/Server/src/Services/Feature/ServerGetFeatures.cpp 2009-09-29 09:50:51 UTC (rev 4272)
+++ sandbox/adsk/2.1/Server/src/Services/Feature/ServerGetFeatures.cpp 2009-09-29 15:51:01 UTC (rev 4273)
@@ -534,6 +534,7 @@
bool isNullable = fdoPropDef->GetNullable();
FdoStringP qname = fdoPropDef->GetQualifiedName();
bool isReadOnly = fdoPropDef->GetReadOnly();
+ FdoString* spatialContextName = fdoPropDef->GetSpatialContextAssociation();
// Set it for MapGuide
if (desc != NULL)
@@ -552,6 +553,11 @@
propDef->SetReadOnly(isReadOnly);
+ if (spatialContextName != NULL)
+ propDef->SetSpatialContextAssociation(STRING(spatialContextName));
return propDef.Detach();
Modified: sandbox/adsk/2.1/Server/src/Services/Feature/ServerGwsGetFeatures.cpp
--- sandbox/adsk/2.1/Server/src/Services/Feature/ServerGwsGetFeatures.cpp 2009-09-29 09:50:51 UTC (rev 4272)
+++ sandbox/adsk/2.1/Server/src/Services/Feature/ServerGwsGetFeatures.cpp 2009-09-29 15:51:01 UTC (rev 4273)
@@ -1297,6 +1297,7 @@
if (desc != NULL)
@@ -1315,6 +1316,11 @@
Modified: sandbox/adsk/2.1/Server/src/Services/Feature/TransformCache.cpp
--- sandbox/adsk/2.1/Server/src/Services/Feature/TransformCache.cpp 2009-09-29 09:50:51 UTC (rev 4272)
+++ sandbox/adsk/2.1/Server/src/Services/Feature/TransformCache.cpp 2009-09-29 15:51:01 UTC (rev 4273)
@@ -95,7 +95,7 @@
Ptr<MgClassDefinition> classDef = svcFeature->GetClassDefinition(resId, schemaName, className, false);
Ptr<MgPropertyDefinitionCollection> propDefCol = classDef->GetProperties();
- // Find the spatial context for the geometric property. Use the first one if there are many defined.
+ // Find the spatial context for the geometric or raster property. Use the first one if there are many defined.
for(int index=0;index<propDefCol->GetCount();index++)
Ptr<MgPropertyDefinition> propDef = propDefCol->GetItem(index);
@@ -106,6 +106,15 @@
spatialContextAssociation = geomProp->GetSpatialContextAssociation();
break;
+ else
+ if(propDef->GetPropertyType () == MgFeaturePropertyType::RasterProperty)
+ // We found the raster property
+ MgRasterPropertyDefinition* rasterProp = static_cast<MgRasterPropertyDefinition*>(propDef.p);
+ spatialContextAssociation = rasterProp->GetSpatialContextAssociation();
+ break;
// We want all of the spatial contexts
More information about the mapguide-commits
