[mapguide-commits] r4275 - trunk/MgDev/Server/src/Services/Feature
svn_mapguide at osgeo.org
Wed Sep 30 17:51:49 EDT 2009
Author: brucedechant
Date: 2009-09-30 17:51:48 -0400 (Wed, 30 Sep 2009)
New Revision: 4275
trunk/MgDev/Server/src/Services/Feature/ServerDataReader.cpp
trunk/MgDev/Server/src/Services/Feature/ServerFeatureConnection.cpp
trunk/MgDev/Server/src/Services/Feature/ServerFeatureConnection.h
trunk/MgDev/Server/src/Services/Feature/ServerFeatureReader.cpp
trunk/MgDev/Server/src/Services/Feature/ServerFeatureTransaction.cpp
trunk/MgDev/Server/src/Services/Feature/ServerGwsFeatureReader.cpp
trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp
trunk/MgDev/Server/src/Services/Feature/ServerSqlDataReader.cpp
Change internal API name from HasReader() to OwnReader() in order to be more clear on what the method actually does.
Modified: trunk/MgDev/Server/src/Services/Feature/ServerDataReader.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerDataReader.cpp 2009-09-30 17:43:31 UTC (rev 4274)
+++ trunk/MgDev/Server/src/Services/Feature/ServerDataReader.cpp 2009-09-30 21:51:48 UTC (rev 4275)
@@ -35,7 +35,7 @@
m_removeFromPoolOnDestruction = false;
// The reader takes ownership of the FDO connection
- m_connection->HasReader();
+ m_connection->OwnReader();
MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerDataReader.MgServerDataReader")
Modified: trunk/MgDev/Server/src/Services/Feature/ServerFeatureConnection.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerFeatureConnection.cpp 2009-09-30 17:43:31 UTC (rev 4274)
+++ trunk/MgDev/Server/src/Services/Feature/ServerFeatureConnection.cpp 2009-09-30 21:51:48 UTC (rev 4275)
@@ -177,7 +177,7 @@
return supports;
-void MgServerFeatureConnection::HasReader()
+void MgServerFeatureConnection::OwnReader()
if(! m_bCloseConnection)
FDO_SAFE_ADDREF(m_fdoConn);
Modified: trunk/MgDev/Server/src/Services/Feature/ServerFeatureConnection.h
--- trunk/MgDev/Server/src/Services/Feature/ServerFeatureConnection.h 2009-09-30 17:43:31 UTC (rev 4274)
+++ trunk/MgDev/Server/src/Services/Feature/ServerFeatureConnection.h 2009-09-30 21:51:48 UTC (rev 4275)
@@ -51,7 +51,7 @@
bool SupportsCommand(INT32 commandType);
- void HasReader();
+ void OwnReader();
private:
Modified: trunk/MgDev/Server/src/Services/Feature/ServerFeatureReader.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerFeatureReader.cpp 2009-09-30 17:43:31 UTC (rev 4274)
+++ trunk/MgDev/Server/src/Services/Feature/ServerFeatureReader.cpp 2009-09-30 21:51:48 UTC (rev 4275)
@@ -38,7 +38,7 @@
MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerFeatureReader.MgServerFeatureReader")
Modified: trunk/MgDev/Server/src/Services/Feature/ServerFeatureTransaction.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerFeatureTransaction.cpp 2009-09-30 17:43:31 UTC (rev 4274)
+++ trunk/MgDev/Server/src/Services/Feature/ServerFeatureTransaction.cpp 2009-09-30 21:51:48 UTC (rev 4275)
@@ -30,7 +30,7 @@
m_lastUsed = ACE_OS::gettimeofday();
// The transaction takes ownership of the FDO connection
MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerFeatureTransaction.MgServerFeatureTransaction")
Modified: trunk/MgDev/Server/src/Services/Feature/ServerGwsFeatureReader.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerGwsFeatureReader.cpp 2009-09-30 17:43:31 UTC (rev 4274)
+++ trunk/MgDev/Server/src/Services/Feature/ServerGwsFeatureReader.cpp 2009-09-30 21:51:48 UTC (rev 4275)
@@ -1927,7 +1927,7 @@
MgServerFeatureConnection* conn = (*iter).second;
if(conn)
- conn->HasReader();
+ conn->OwnReader();
Modified: trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp 2009-09-30 17:43:31 UTC (rev 4274)
+++ trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp 2009-09-30 21:51:48 UTC (rev 4275)
@@ -1370,7 +1370,7 @@
MG_FEATURE_SERVICE_CHECK_CONNECTION_CATCH_AND_THROW(featureSourceIdentifier, L"MgServerSelectFeatures.JoinFeatures")
- // Now that the reader has been created we will need to mark all of the connections it uses as HasReader() because the GWS reader will be
+ // Now that the reader has been created we will need to mark all of the connections it uses as OwnReader() because the GWS reader will be
// taking ownership of the connections. We have to do it this late in the code in case an exception is thrown somewhere before this.
// We want to avoid a deadlock of the connection :)
gwsFeatureReader->OwnsConnections();
Modified: trunk/MgDev/Server/src/Services/Feature/ServerSqlDataReader.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerSqlDataReader.cpp 2009-09-30 17:43:31 UTC (rev 4274)
+++ trunk/MgDev/Server/src/Services/Feature/ServerSqlDataReader.cpp 2009-09-30 21:51:48 UTC (rev 4275)
@@ -33,7 +33,7 @@
m_providerName = providerName;
MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerSqlDataReader.MgServerSqlDataReader")
More information about the mapguide-commits
