[mapguide-commits] r4749 - in trunk/MgDev: Common/CoordinateSystem
Common/Foundation Common/Foundation/Exception
Common/Foundation/System Common/Geometry/CoordinateSystem
Common/MapGuideCommon/MapLayer Common/MapGuideCommon/Services
Common/PlatformBase/Services Server/src/Common/Base
Server/src/Common/Manager Server/src/Core
Server/src/Gws/GwsCommon Server/src/Gws/GwsCommon/inc
Server/src/Gws/Include Server/src/Services/Mapping
Server/src/Services/Rendering Server/src/Services/Tile
Server/src/UnitTesting Web/src/ApacheAgent Web/src/CgiAgent
Web/src/DotNetApi/Foundation Web/src/HttpHandler
Web/src/IsapiAgent Web/src/JavaApi/org/osgeo/mapguide Web/src/WebApp
svn_mapguide at osgeo.org
Wed Apr 7 13:16:25 EDT 2010
Author: brucedechant
Date: 2010-04-07 13:16:24 -0400 (Wed, 07 Apr 2010)
New Revision: 4749
trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSys.h
trunk/MgDev/Common/CoordinateSystem/CoordSysCatalog.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysDatum.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysDatum.h
trunk/MgDev/Common/CoordinateSystem/CoordSysEllipsoid.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysEllipsoid.h
trunk/MgDev/Common/CoordinateSystem/CoordSysFormatConverter.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformation.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysUtil.h
trunk/MgDev/Common/Foundation/Exception/ConfigurationLoadFailedException.cpp
trunk/MgDev/Common/Foundation/Exception/ConfigurationLoadFailedException.h
trunk/MgDev/Common/Foundation/Exception/Exception.cpp
trunk/MgDev/Common/Foundation/Exception/Exception.h
trunk/MgDev/Common/Foundation/Exception/InvalidArgumentException.cpp
trunk/MgDev/Common/Foundation/Exception/InvalidArgumentException.h
trunk/MgDev/Common/Foundation/Exception/ResourcesLoadFailedException.cpp
trunk/MgDev/Common/Foundation/Exception/ResourcesLoadFailedException.h
trunk/MgDev/Common/Foundation/Foundation.h
trunk/MgDev/Common/Foundation/System/Resources.cpp
trunk/MgDev/Common/Foundation/System/Resources.h
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystem.h
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemDatum.h
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemEllipsoid.h
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemFactory.cpp
trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h
trunk/MgDev/Common/MapGuideCommon/Services/PackageStatusInformation.cpp
trunk/MgDev/Common/MapGuideCommon/Services/SiteManager.cpp
trunk/MgDev/Common/PlatformBase/Services/Warnings.cpp
trunk/MgDev/Common/PlatformBase/Services/Warnings.h
trunk/MgDev/Server/src/Common/Base/ClientHandler.cpp
trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp
trunk/MgDev/Server/src/Common/Manager/CacheManager.cpp
trunk/MgDev/Server/src/Common/Manager/LoadBalanceManager.cpp
trunk/MgDev/Server/src/Common/Manager/LogManager.cpp
trunk/MgDev/Server/src/Common/Manager/LogThread.cpp
trunk/MgDev/Server/src/Common/Manager/PackageLogWriter.cpp
trunk/MgDev/Server/src/Common/Manager/WorkerThread.cpp
trunk/MgDev/Server/src/Core/OperationThread.cpp
trunk/MgDev/Server/src/Core/Server.cpp
trunk/MgDev/Server/src/Core/TimedEventHandler.cpp
trunk/MgDev/Server/src/Gws/GwsCommon/GwsException.cpp
trunk/MgDev/Server/src/Gws/GwsCommon/GwsObjectImpl.cpp
trunk/MgDev/Server/src/Gws/GwsCommon/inc/GwsStatus.h
trunk/MgDev/Server/src/Gws/Include/GwsCommon.h
trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
trunk/MgDev/Server/src/Services/Mapping/RSMgFeatureReader.cpp
trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
trunk/MgDev/Server/src/Services/Tile/ServerTileService.cpp
trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp
trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.h
trunk/MgDev/Server/src/UnitTesting/TestServerAdminService.cpp
trunk/MgDev/Web/src/ApacheAgent/ApacheResponseHandler.cpp
trunk/MgDev/Web/src/CgiAgent/CgiResponseHandler.cpp
trunk/MgDev/Web/src/DotNetApi/Foundation/ManagedException.cs
trunk/MgDev/Web/src/HttpHandler/HttpGetSiteInfo.cpp
trunk/MgDev/Web/src/HttpHandler/HttpGetSiteStatus.cpp
trunk/MgDev/Web/src/HttpHandler/HttpGetSiteVersion.cpp
trunk/MgDev/Web/src/HttpHandler/HttpResult.cpp
trunk/MgDev/Web/src/HttpHandler/HttpWmsGetMap.cpp
trunk/MgDev/Web/src/IsapiAgent/IsapiResponseHandler.cpp
trunk/MgDev/Web/src/JavaApi/org/osgeo/mapguide/AppThrowable.java
trunk/MgDev/Web/src/WebApp/WebInvokeScriptCommand.cpp
trunk/MgDev/Web/src/WebApp/WebInvokeScriptCommand.h
trunk/MgDev/Web/src/WebApp/WebLayout.cpp
Fix for trac ticket 1292 - Update to PHP 5.3
http://trac.osgeo.org/mapguide/ticket/1292
Notes:
- Implement RFC89 - http://trac.osgeo.org/mapguide/wiki/MapGuideRfc89
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -934,7 +934,7 @@
//Corresponds to cs_Csdef_::key_nm.
-STRING CCoordinateSystem::GetCode()
+STRING CCoordinateSystem::GetCsCode()
STRING sName;
@@ -942,11 +942,11 @@
wchar_t* pName = Convert_Ascii_To_Wide(m_csprm.csdef.key_nm);
if (NULL == pName)
- throw new MgOutOfMemoryException(L"MgCoordinateSystem.GetCode", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgOutOfMemoryException(L"MgCoordinateSystem.GetCsCode", __LINE__, __WFILE__, NULL, L"", NULL);
sName=pName;
delete[] pName;
- MG_CATCH_AND_THROW(L"MgCoordinateSystem.GetCode")
+ MG_CATCH_AND_THROW(L"MgCoordinateSystem.GetCsCode")
return sName;
@@ -956,27 +956,27 @@
//Throws an exception MgInvalidArgumentException if the provided string is not
//a legal coordinate system name.
-void CCoordinateSystem::SetCode(CREFSTRING sCode)
+void CCoordinateSystem::SetCsCode(CREFSTRING sCode)
MG_TRY()
if (Protected())
//Can't modify a read-only object.
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystem.SetCode", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
+ throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystem.SetCsCode", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
if (sCode.empty())
//null pointer is obviously not legal...
- throw new MgInvalidArgumentException(L"MgCoordinateSystem.SetCode", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgInvalidArgumentException(L"MgCoordinateSystem.SetCsCode", __LINE__, __WFILE__, NULL, L"", NULL);
//Convert to a C++ string, for Mentor's sake
char *pStr = Convert_Wide_To_Ascii(sCode.c_str()); //need to delete[] pStr
if (NULL == pStr)
- throw new MgOutOfMemoryException(L"MgCoordinateSystem.SetCode", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgOutOfMemoryException(L"MgCoordinateSystem.SetCsCode", __LINE__, __WFILE__, NULL, L"", NULL);
//Try to make a legal name. CS_nampp() legalizes the
@@ -988,7 +988,7 @@
//illegal string
delete [] pStr;
//Copy into the definition
@@ -999,13 +999,13 @@
delete [] pStr;
//And we're done!
- MG_CATCH_AND_THROW(L"MgCoordinateSystem.SetCode")
+ MG_CATCH_AND_THROW(L"MgCoordinateSystem.SetCsCode")
//Checks whether the specified string is a legal
//coordinate system key name.
-bool CCoordinateSystem::IsLegalCode(CREFSTRING sCode)
+bool CCoordinateSystem::IsLegalCsCode(CREFSTRING sCode)
return IsLegalMentorName(sCode.c_str());
@@ -1309,7 +1309,7 @@
Ptr<MgStringCollection> pCsNameColl=pEnumSystemsInCategory->NextName(1);
if (1 != pCsNameColl->GetCount()) break;
- if (GetCode()==pCsNameColl->GetItem(0))
+ if (GetCsCode()==pCsNameColl->GetItem(0))
//we are in this category, let's get it and move on to the next category
pCategoryNames->Add(pCtDef->GetName());
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSys.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSys.h 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSys.h 2010-04-07 17:16:24 UTC (rev 4749)
@@ -63,7 +63,7 @@
virtual double GetMinY(); /// __get
virtual double GetMaxX(); /// __get
virtual double GetMaxY(); /// __get
- virtual STRING GetCode(); /// __get
+ virtual STRING GetCsCode(); /// __get
virtual STRING GetDescription(); /// __get
virtual STRING GetProjection(); /// __get
virtual STRING GetProjectionDescription(); /// __get
@@ -76,8 +76,8 @@
virtual MgStringCollection* GetCategories();
virtual MgCoordinateSystemCatalog* GetCatalog();
virtual void SetCatalog(MgCoordinateSystemCatalog* pCatalog);
- virtual void SetCode(CREFSTRING sCode);
- virtual bool IsLegalCode(CREFSTRING sCode);
+ virtual void SetCsCode(CREFSTRING sCode);
+ virtual bool IsLegalCsCode(CREFSTRING sCode);
virtual bool IsValid();
virtual bool IsUsable(MgCoordinateSystemCatalog *pCatalog);
virtual bool IsSameAs(MgGuardDisposable *pDef);
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysCatalog.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysCatalog.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysCatalog.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -42,16 +42,10 @@
#include "csNameMapper.hpp" //for csReleaseNameMapper
#ifdef _WIN32
-#ifdef UNICODE
-#define GetMessage GetMessageW
-#else
-#define GetMessage GetMessageA
-#endif // !UNICODE
#include <atlbase.h>
#include <atlconv.h>
#include <tchar.h> //for _tsplitpath
#include <shlobj.h> //for SHGetFolderPath
-#undef GetMessage
#endif
//Global variables needed from Mentor
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysDatum.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysDatum.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysDatum.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -187,7 +187,7 @@
//Corresponds to cs_Dtdef_::key_nm.
-STRING CCoordinateSystemDatum::GetCode()
+STRING CCoordinateSystemDatum::GetDtCode()
STRING sCode;
@@ -195,11 +195,11 @@
wchar_t* pName = Convert_Ascii_To_Wide(m_DtDef.key_nm);
if (NULL == pName)
- throw new MgOutOfMemoryException(L"MgCoordinateSystemDatum.GetCode", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgOutOfMemoryException(L"MgCoordinateSystemDatum.GetDtCode", __LINE__, __WFILE__, NULL, L"", NULL);
sCode=pName;
delete[] pName;
- MG_CATCH_AND_THROW(L"MgCoordinateSystemDatum.GetCode")
+ MG_CATCH_AND_THROW(L"MgCoordinateSystemDatum.GetDtCode")
return sCode;
@@ -209,27 +209,27 @@
//if the provided string is not
//a legal datum name.
-void CCoordinateSystemDatum::SetCode(CREFSTRING sCode)
+void CCoordinateSystemDatum::SetDtCode(CREFSTRING sCode)
MG_TRY()
if (Protected())
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemDatum.SetCode", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemDatumProtectedException", NULL);
+ throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemDatum.SetDtCode", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemDatumProtectedException", NULL);
if (sCode.empty())
- throw new MgInvalidArgumentException(L"MgCoordinateSystemDatum.SetCode", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgInvalidArgumentException(L"MgCoordinateSystemDatum.SetDtCode", __LINE__, __WFILE__, NULL, L"", NULL);
if (NULL == pStr)
- throw new MgOutOfMemoryException(L"MgCoordinateSystemDatum.SetCode", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgOutOfMemoryException(L"MgCoordinateSystemDatum.SetDtCode", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -241,7 +241,7 @@
//illegal string
delete [] pStr;
//Copy into the definitions, dtdef and cs_datum_ must be in synch
@@ -255,12 +255,12 @@
delete [] pStr;
//And we're done!
- MG_CATCH_AND_THROW(L"MgCoordinateSystemDatum.SetCode")
+ MG_CATCH_AND_THROW(L"MgCoordinateSystemDatum.SetDtCode")
//Checks whether the specified string is a legal datum key name.
-bool CCoordinateSystemDatum::IsLegalCode(CREFSTRING sCode)
+bool CCoordinateSystemDatum::IsLegalDtCode(CREFSTRING sCode)
@@ -808,7 +808,7 @@
throw new MgNullArgumentException(L"MgCoordinateSystemDatum.SetEllipsoidDefinition", __LINE__, __WFILE__, NULL, L"", NULL);
- STRING sEllipsoid=pEllipsoidDef->GetCode();
+ STRING sEllipsoid=pEllipsoidDef->GetElCode();
//Make sure it's a legal datum name
if (!IsLegalMentorName(sEllipsoid.c_str()))
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysDatum.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysDatum.h 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysDatum.h 2010-04-07 17:16:24 UTC (rev 4749)
@@ -30,9 +30,9 @@
void InitFromCatalog(const cs_Dtdef_& def);
void GetMentorDef(cs_Dtdef_& def){def=m_DtDef;};
+ virtual STRING GetDtCode();
+ virtual void SetDtCode(CREFSTRING sCode);
+ virtual bool IsLegalDtCode(CREFSTRING sCode);
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysEllipsoid.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysEllipsoid.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysEllipsoid.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -59,26 +59,26 @@
if (NULL==pDest)
- throw new MgNullArgumentException(L"MgCoordinateSystemEllipsoidEllipsoid.SetString", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullArgumentException(L"MgCoordinateSystemEllipsoid.SetString", __LINE__, __WFILE__, NULL, L"", NULL);
if (Protected())
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemEllipsoidEllipsoid.SetString", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemEllipsoidProtectedException", NULL);
+ throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemEllipsoid.SetString", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemEllipsoidProtectedException", NULL);
if (!IsLegalString(sSrc.c_str(), nMaxSize))
//Can't set string, caller gave us an illegal value
- throw new MgInvalidArgumentException(L"MgCoordinateSystemEllipsoidEllipsoid.SetString", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgInvalidArgumentException(L"MgCoordinateSystemEllipsoid.SetString", __LINE__, __WFILE__, NULL, L"", NULL);
char *pStr = Convert_Wide_To_Ascii(sSrc.c_str()); //need to delete[] pStr
if (NULL == pStr)
- throw new MgOutOfMemoryException(L"MgCoordinateSystemEllipsoidEllipsoid.SetString", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgOutOfMemoryException(L"MgCoordinateSystemEllipsoid.SetString", __LINE__, __WFILE__, NULL, L"", NULL);
//Copy it in
@@ -87,7 +87,7 @@
//Clean up and return success.
delete [] pStr;
- MG_CATCH_AND_THROW(L"MgCoordinateSystemEllipsoidEllipsoid.SetString")
+ MG_CATCH_AND_THROW(L"MgCoordinateSystemEllipsoid.SetString")
//Private function that evaluates the protect data member of m_def
@@ -111,7 +111,7 @@
//Corresponds to cs_Eldef_::key_nm.
-STRING CCoordinateSystemEllipsoid::GetCode()
+STRING CCoordinateSystemEllipsoid::GetElCode()
STRING sName;
@@ -120,11 +120,11 @@
wchar_t *pName = Convert_Ascii_To_Wide(m_def.key_nm);
if (NULL == pName)
- throw new MgOutOfMemoryException(L"MgCoordinateSystemEllipsoidEllipsoid.GetCode", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgOutOfMemoryException(L"MgCoordinateSystemEllipsoid.GetElCode", __LINE__, __WFILE__, NULL, L"", NULL);
sName=pName;
delete[] pName;
- MG_CATCH_AND_THROW(L"MgCoordinateSystemEllipsoidEllipsoid.SetProjectionCode")
+ MG_CATCH_AND_THROW(L"MgCoordinateSystemEllipsoid.GetElCode")
return sName;
@@ -132,26 +132,26 @@
//Sets the key name of the ellipsoid.
//Throws an exception if the provided string is not
//a legal ellipsoid name.
-void CCoordinateSystemEllipsoid::SetCode(CREFSTRING sCode)
+void CCoordinateSystemEllipsoid::SetElCode(CREFSTRING sCode)
MG_TRY()
if (Protected())
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemEllipsoid.SetCode", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemEllipsoidProtectedException", NULL);
+ throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemEllipsoid.SetElCode", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemEllipsoidProtectedException", NULL);
if (sCode.empty())
- throw new MgInvalidArgumentException(L"MgCoordinateSystemEllipsoid.SetCode", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgInvalidArgumentException(L"MgCoordinateSystemEllipsoid.SetElCode", __LINE__, __WFILE__, NULL, L"", NULL);
if (NULL == pStr)
- throw new MgOutOfMemoryException(L"MgCoordinateSystemEllipsoid.SetCode", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgOutOfMemoryException(L"MgCoordinateSystemEllipsoid.SetElCode", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -163,7 +163,7 @@
//illegal string
delete [] pStr;
@@ -174,11 +174,11 @@
delete [] pStr;
//And we're done!
- MG_CATCH_AND_THROW(L"MgCoordinateSystemEllipsoid.SetCode")
+ MG_CATCH_AND_THROW(L"MgCoordinateSystemEllipsoid.SetElCode")
//Checks whether the specified string is a legal ellipsoid key name.
-bool CCoordinateSystemEllipsoid::IsLegalCode(CREFSTRING sCode)
+bool CCoordinateSystemEllipsoid::IsLegalElCode(CREFSTRING sCode)
@@ -599,13 +599,13 @@
assert(dFlatteningRatio < 1.0);
if ((dFlatteningRatio < 0.0) || (dFlatteningRatio >= 1.0))
- throw new MgInvalidArgumentException(L"MgCoordinateSystemEllipsoid.EquatorialFromPolarFlat", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgInvalidArgumentException(L"MgCoordinateSystemEllipsoid.EquatorialRadiusFromPolarRadiusFlatteningRatio", __LINE__, __WFILE__, NULL, L"", NULL);
dEquatorialRadius = dPolarRadius / (1.0 - dFlatteningRatio);
assert(FloatEqual(dFlatteningRatio, FlatteningRatio(dEquatorialRadius, dPolarRadius)));
- MG_CATCH_AND_THROW(L"MgCoordinateSystemEllipsoid.EquatorialFromPolarFlat")
+ MG_CATCH_AND_THROW(L"MgCoordinateSystemEllipsoid.EquatorialRadiusFromPolarRadiusFlatteningRatio")
return dEquatorialRadius;
@@ -624,13 +624,13 @@
- throw new MgInvalidArgumentException(L"MgCoordinateSystemEllipsoid.PolarFromEquatorialFlat", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgInvalidArgumentException(L"MgCoordinateSystemEllipsoid.PolarRadiusFromEquatorialRadiusFlatteningRatio", __LINE__, __WFILE__, NULL, L"", NULL);
dPolarRadius = dEquatorialRadius * (1.0 - dFlatteningRatio);
- MG_CATCH_AND_THROW(L"MgCoordinateSystemEllipsoid.PolarFromEquatorialFlat")
+ MG_CATCH_AND_THROW(L"MgCoordinateSystemEllipsoid.PolarRadiusFromEquatorialRadiusFlatteningRatio")
return dPolarRadius;
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysEllipsoid.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysEllipsoid.h 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysEllipsoid.h 2010-04-07 17:16:24 UTC (rev 4749)
@@ -30,9 +30,9 @@
void GetMentorDef(cs_Eldef_& def){def=m_def;};
//MgCoordinateSystemEllipsoid
+ virtual STRING GetElCode(); /// __get
+ virtual void SetElCode(CREFSTRING sCode);
+ virtual bool IsLegalElCode(CREFSTRING sCode);
virtual bool IsUsable();
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysFormatConverter.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysFormatConverter.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysFormatConverter.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -300,7 +300,7 @@
if (NULL != pCsFromDict.p)
- sCsNameFromDict=pCsFromDict->GetCode();
+ sCsNameFromDict=pCsFromDict->GetCsCode();
sDtNameFromDict=pCsFromDict->GetDatum();
sElNameFromDict=pCsFromDict->GetEllipsoid();
@@ -744,7 +744,7 @@
//get the name of the source system
- STRING sCsSource=pSource->GetCode();
+ STRING sCsSource=pSource->GetCsCode();
if (sCsSource.empty())
throw new MgInvalidArgumentException(L"MgCoordinateSystemFormatConverter.DefinitionToCode", __LINE__, __WFILE__, NULL, L"", NULL);
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformation.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformation.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformation.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -402,7 +402,7 @@
return false;
//if not WGS84 for the target system, bye bye!
- if (m_pDtTarget->GetCode()!=kpWGS84Datum)
+ if (m_pDtTarget->GetDtCode()!=kpWGS84Datum)
return false;
@@ -491,7 +491,7 @@
throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemGeodeticTransformation.SetOffset", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemGeodeticTransformation.SetOffset", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemMismatchException", NULL);
@@ -630,7 +630,7 @@
throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemGeodeticTransformation.SetBursaWolfeTransform", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemGeodeticTransformation.SetBursaWolfeTransform", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemMismatchException", NULL);
@@ -712,7 +712,7 @@
throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemGeodeticTransformation.SetGeodeticTransformationMethod", __LINE__, __WFILE__, NULL, L"", NULL);
throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemGeodeticTransformation.SetGeodeticTransformationMethod", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemMismatchException", NULL);
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -455,7 +455,7 @@
// Leave commented except for temporary debugging. The printf output gets
// sent to stdout and ends up being included in the web-tier HTTP response.
- // printf("\nTransform(envelope) -- Source: %S Dest: %S\n", m_pCsSource->GetCode().c_str(), m_pCsTarget->GetCode().c_str());
+ // printf("\nTransform(envelope) -- Source: %S Dest: %S\n", m_pCsSource->GetCsCode().c_str(), m_pCsTarget->GetCsCode().c_str());
MG_TRY()
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysUtil.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysUtil.h 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysUtil.h 2010-04-07 17:16:24 UTC (rev 4749)
@@ -30,8 +30,6 @@
#ifdef _WIN32
#include "windows.h"
-// To undefine GetMessage macro defined in windows
-#undef GetMessage
#endif
// Mentor specific information
Modified: trunk/MgDev/Common/Foundation/Exception/ConfigurationLoadFailedException.cpp
--- trunk/MgDev/Common/Foundation/Exception/ConfigurationLoadFailedException.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/Foundation/Exception/ConfigurationLoadFailedException.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -43,7 +43,7 @@
/// \brief
/// Retrieve the formatted exception message for the specified locale.
-STRING MgConfigurationLoadFailedException::GetMessage(CREFSTRING locale) throw()
+STRING MgConfigurationLoadFailedException::GetExceptionMessage(CREFSTRING locale) throw()
- return MgException::GetMessage(locale, MgResources::FailedToLoadConfigurationFile);
+ return MgException::GetExceptionMessage(locale, MgResources::FailedToLoadConfigurationFile);
Modified: trunk/MgDev/Common/Foundation/Exception/ConfigurationLoadFailedException.h
--- trunk/MgDev/Common/Foundation/Exception/ConfigurationLoadFailedException.h 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/Foundation/Exception/ConfigurationLoadFailedException.h 2010-04-07 17:16:24 UTC (rev 4749)
@@ -68,7 +68,7 @@
/// \return
/// Formatted exception message
- virtual STRING GetMessage(CREFSTRING locale) throw();
+ virtual STRING GetExceptionMessage(CREFSTRING locale) throw();
INTERNAL_API:
Modified: trunk/MgDev/Common/Foundation/Exception/Exception.cpp
--- trunk/MgDev/Common/Foundation/Exception/Exception.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/Foundation/Exception/Exception.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -17,10 +17,6 @@
#include "Foundation.h"
-#ifdef _WIN32
- #undef GetMessage
-#endif
IMPLEMENT_EXCEPTION_ABSTRACT(MgException)
@@ -437,7 +433,7 @@
/// This method should be called for critical errors when the configuration
/// or resource file has not been loaded.
-STRING MgException::GetMessage(CREFSTRING locale, CREFSTRING resourceStr) throw()
+STRING MgException::GetExceptionMessage(CREFSTRING locale, CREFSTRING resourceStr) throw()
// Format:
@@ -475,7 +471,7 @@
/// \brief
-STRING MgException::GetMessage(CREFSTRING locale) throw()
+STRING MgException::GetExceptionMessage(CREFSTRING locale) throw()
// Format:
@@ -535,7 +531,7 @@
if (m_details.empty())
- m_details = GetMessage(locale);
+ m_details = GetExceptionMessage(locale);
m_details += L"\n";
m_details += FormatDetails(locale);
@@ -579,9 +575,9 @@
/// \brief
-STRING MgException::GetMessage() throw()
+STRING MgException::GetExceptionMessage() throw()
- return GetMessage(GetLocale());
+ return GetExceptionMessage(GetLocale());
Modified: trunk/MgDev/Common/Foundation/Exception/Exception.h
--- trunk/MgDev/Common/Foundation/Exception/Exception.h 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/Foundation/Exception/Exception.h 2010-04-07 17:16:24 UTC (rev 4749)
@@ -20,11 +20,6 @@
/// \ingroup Exceptions_Module
-#ifdef _WIN32
- #undef GetMessage
-#endif
class MgByteReader;
class MgStringCollection;
@@ -45,20 +40,20 @@
/// <!-- Syntax in .Net, Java, and PHP -->
/// \htmlinclude DotNetSyntaxTop.html
- /// string GetMessage() throw();
+ /// string GetExceptionMessage() throw();
/// \htmlinclude SyntaxBottom.html
/// \htmlinclude JavaSyntaxTop.html
- /// String GetMessage() throw();
+ /// String GetExceptionMessage() throw();
/// \htmlinclude PHPSyntaxTop.html
/// \return
/// Localized exception message. See MgSiteConnection for information on specifying
/// the locale.
- STRING GetMessage() throw();
+ STRING GetExceptionMessage() throw();
/// \brief
@@ -120,7 +115,7 @@
/// \return
/// \brief
@@ -274,7 +269,7 @@
- STRING GetMessage(CREFSTRING locale, CREFSTRING resourceStr) throw();
+ STRING GetExceptionMessage(CREFSTRING locale, CREFSTRING resourceStr) throw();
private:
Modified: trunk/MgDev/Common/Foundation/Exception/InvalidArgumentException.cpp
--- trunk/MgDev/Common/Foundation/Exception/InvalidArgumentException.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/Foundation/Exception/InvalidArgumentException.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -45,7 +45,7 @@
/// <param name="nLocale">The locale identifier to format the message text.</param>
-STRING MgInvalidArgumentException::GetMessage(CREFSTRING locale) throw()
+STRING MgInvalidArgumentException::GetExceptionMessage(CREFSTRING locale) throw()
// Format:
Modified: trunk/MgDev/Common/Foundation/Exception/InvalidArgumentException.h
--- trunk/MgDev/Common/Foundation/Exception/InvalidArgumentException.h 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/Foundation/Exception/InvalidArgumentException.h 2010-04-07 17:16:24 UTC (rev 4749)
@@ -73,7 +73,7 @@
/// \return
CLASS_ID:
Modified: trunk/MgDev/Common/Foundation/Exception/ResourcesLoadFailedException.cpp
--- trunk/MgDev/Common/Foundation/Exception/ResourcesLoadFailedException.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/Foundation/Exception/ResourcesLoadFailedException.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -43,7 +43,7 @@
/// \brief
-STRING MgResourcesLoadFailedException::GetMessage(CREFSTRING locale) throw()
+STRING MgResourcesLoadFailedException::GetExceptionMessage(CREFSTRING locale) throw()
- return MgException::GetMessage(locale, MgResources::FailedToLoadResourcesFile);
+ return MgException::GetExceptionMessage(locale, MgResources::FailedToLoadResourcesFile);
Modified: trunk/MgDev/Common/Foundation/Exception/ResourcesLoadFailedException.h
--- trunk/MgDev/Common/Foundation/Exception/ResourcesLoadFailedException.h 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/Foundation/Exception/ResourcesLoadFailedException.h 2010-04-07 17:16:24 UTC (rev 4749)
@@ -76,7 +76,7 @@
/// \return
CLASS_ID:
Modified: trunk/MgDev/Common/Foundation/Foundation.h
--- trunk/MgDev/Common/Foundation/Foundation.h 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/Foundation/Foundation.h 2010-04-07 17:16:24 UTC (rev 4749)
@@ -68,7 +68,6 @@
#include "ace/Process_Manager.h"
#include "ace/Date_Time.h"
-#undef GetMessage
#undef GetObject
#include "FoundationDefs.h"
#include "System/FoundationClassId.h"
Modified: trunk/MgDev/Common/Foundation/System/Resources.cpp
--- trunk/MgDev/Common/Foundation/System/Resources.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/Foundation/System/Resources.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -592,7 +592,7 @@
/// \return
/// The formatted message string.
-STRING MgResources::GetMessage(CREFSTRING section, CREFSTRING resourceId,
+STRING MgResources::GetResourceMessage(CREFSTRING section, CREFSTRING resourceId,
MgStringCollection* arguments)
STRING message;
@@ -616,7 +616,7 @@
message = FormatMessage(resourceStr, arguments);
- MG_RESOURCES_CATCH_AND_THROW(L"MgResources.GetMessage")
+ MG_RESOURCES_CATCH_AND_THROW(L"MgResources.GetResourceMessage")
return message;
Modified: trunk/MgDev/Common/Foundation/System/Resources.h
--- trunk/MgDev/Common/Foundation/System/Resources.h 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/Foundation/System/Resources.h 2010-04-07 17:16:24 UTC (rev 4749)
@@ -161,7 +161,7 @@
/// \return
- STRING GetMessage(CREFSTRING section, CREFSTRING resourceId,
+ STRING GetResourceMessage(CREFSTRING section, CREFSTRING resourceId,
MgStringCollection* arguments);
/// Resource Components
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystem.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystem.h 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystem.h 2010-04-07 17:16:24 UTC (rev 4749)
@@ -49,7 +49,7 @@
virtual double GetMinY()=0; /// __get
virtual double GetMaxX()=0; /// __get
virtual double GetMaxY()=0; /// __get
- virtual STRING GetCode()=0; /// __get
+ virtual STRING GetCsCode()=0; /// __get
virtual STRING GetDescription()=0; /// __get
virtual STRING GetProjection()=0; /// __get
virtual STRING GetProjectionDescription()=0; /// __get
@@ -61,8 +61,8 @@
virtual MgCoordinateSystemMeasure* GetMeasure()=0;
virtual MgStringCollection* GetCategories()=0;
virtual MgCoordinateSystemCatalog* GetCatalog()=0;
- virtual void SetCode(CREFSTRING sCode)=0;
- virtual bool IsLegalCode(CREFSTRING sCode)=0;
+ virtual void SetCsCode(CREFSTRING sCode)=0;
+ virtual bool IsLegalCsCode(CREFSTRING sCode)=0;
virtual bool IsValid()=0;
virtual bool IsUsable(MgCoordinateSystemCatalog *pCatalog)=0;
virtual bool IsSameAs(MgGuardDisposable *pDef)=0;
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemDatum.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemDatum.h 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemDatum.h 2010-04-07 17:16:24 UTC (rev 4749)
@@ -26,9 +26,9 @@
DECLARE_CLASSNAME(MgCoordinateSystemDatum)
PUBLISHED_API:
+ virtual STRING GetDtCode()=0;
+ virtual void SetDtCode(CREFSTRING sCode)=0;
+ virtual bool IsLegalDtCode(CREFSTRING sCode)=0;
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemEllipsoid.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemEllipsoid.h 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemEllipsoid.h 2010-04-07 17:16:24 UTC (rev 4749)
@@ -23,9 +23,9 @@
DECLARE_CLASSNAME(MgCoordinateSystemEllipsoid)
PUBLISHED_API:
+ virtual STRING GetElCode()=0; /// __get
+ virtual void SetElCode(CREFSTRING sCode)=0;
+ virtual bool IsLegalElCode(CREFSTRING sCode)=0;
virtual bool IsUsable()=0;
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemFactory.cpp
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemFactory.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemFactory.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -402,7 +402,7 @@
// Coordinate system properties
// Add the Code
- pProperty = new MgStringProperty(CCoordinateSystem::CoordinateSystemCode, pCsDef->GetCode());
+ pProperty = new MgStringProperty(CCoordinateSystem::CoordinateSystemCode, pCsDef->GetCsCode());
pCoordSysProperties->Add(pProperty);
// Add the Description
Modified: trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h
--- trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h 2010-04-07 17:16:24 UTC (rev 4749)
@@ -119,7 +119,7 @@
/// catch (MgException $e)
-/// echo "ERROR: " . $e->GetMessage() . "n";
+/// echo "ERROR: " . $e->GetExceptionMessage() . "n";
/// echo $e->GetDetails() . "n";
/// echo $e->GetStackTrace() . "n";
Modified: trunk/MgDev/Common/MapGuideCommon/Services/PackageStatusInformation.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/PackageStatusInformation.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/MapGuideCommon/Services/PackageStatusInformation.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -246,7 +246,7 @@
else
- statusMessage = resources->GetMessage(MgResources::ResourceService,
+ statusMessage = resources->GetResourceMessage(MgResources::ResourceService,
resourceId, &arguments);
Modified: trunk/MgDev/Common/MapGuideCommon/Services/SiteManager.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/SiteManager.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/MapGuideCommon/Services/SiteManager.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -78,7 +78,7 @@
if(NULL != mgException.p)
// Exception was thrown
- STRING message = mgException->GetMessage();
+ STRING message = mgException->GetExceptionMessage();
Modified: trunk/MgDev/Common/PlatformBase/Services/Warnings.cpp
--- trunk/MgDev/Common/PlatformBase/Services/Warnings.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/PlatformBase/Services/Warnings.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -18,10 +18,6 @@
#include "PlatformBase.h"
#include <assert.h>
-#ifdef _WIN32
- #undef GetMessage
-#endif
MG_IMPL_DYNCREATE(MgWarnings);
Modified: trunk/MgDev/Common/PlatformBase/Services/Warnings.h
--- trunk/MgDev/Common/PlatformBase/Services/Warnings.h 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Common/PlatformBase/Services/Warnings.h 2010-04-07 17:16:24 UTC (rev 4749)
@@ -22,11 +22,6 @@
/// \ingroup Common_Module
-#ifdef _WIN32
- #undef GetMessage
-#endif
class MgWarnings;
template class MG_PLATFORMBASE_API Ptr<MgWarnings>;
Modified: trunk/MgDev/Server/src/Common/Base/ClientHandler.cpp
--- trunk/MgDev/Server/src/Common/Base/ClientHandler.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Server/src/Common/Base/ClientHandler.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -178,7 +178,7 @@
stream = new MgMapGuideStream( m_pStreamHelper );
// TODO: use locale from client connection
- mgException->GetMessage(MgResources::DefaultMessageLocale);
+ mgException->GetExceptionMessage(MgResources::DefaultMessageLocale);
mgException->GetDetails(MgResources::DefaultMessageLocale);
mgException->GetStackTrace(MgResources::DefaultMessageLocale);
Modified: trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp
--- trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -233,7 +233,7 @@
- STRING message = except->GetMessage(locale);
+ STRING message = except->GetExceptionMessage(locale);
STRING details = except->GetDetails(locale);
STRING stackTrace = except->GetStackTrace(locale);
@@ -609,7 +609,7 @@
m_currConnection->SetCurrentOperationStatus(MgConnection::OpFailed);
- except->GetMessage();
+ except->GetExceptionMessage();
except->GetDetails();
except->GetStackTrace();
Modified: trunk/MgDev/Server/src/Common/Manager/CacheManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/CacheManager.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Server/src/Common/Manager/CacheManager.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -234,7 +234,7 @@
MgResources* resources = MgResources::GetInstance();
ACE_ASSERT(NULL != resources);
- STRING message = resources->GetMessage(MgResources::FeatureService,
+ STRING message = resources->GetResourceMessage(MgResources::FeatureService,
L"MgInvalidFdoProvider", NULL);
MgStringCollection arguments;
arguments.Add(message);
Modified: trunk/MgDev/Server/src/Common/Manager/LoadBalanceManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/LoadBalanceManager.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Server/src/Common/Manager/LoadBalanceManager.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -678,7 +678,7 @@
ACE_DEBUG((LM_ERROR, ACE_TEXT("(%t) %W\n"), e->GetDetails(locale).c_str()));
MG_LOG_SYSTEM_ENTRY(LM_ERROR, e->GetDetails(locale).c_str());
- MG_LOG_EXCEPTION_ENTRY(e->GetMessage(locale).c_str(), e->GetStackTrace(locale).c_str());
+ MG_LOG_EXCEPTION_ENTRY(e->GetExceptionMessage(locale).c_str(), e->GetStackTrace(locale).c_str());
SAFE_RELEASE(e);
@@ -768,7 +768,7 @@
SAFE_RELEASE(e);
@@ -973,7 +973,7 @@
SAFE_RELEASE(e);
@@ -1579,7 +1579,7 @@
SAFE_RELEASE(e);
@@ -1649,7 +1649,7 @@
SAFE_RELEASE(e);
@@ -1751,7 +1751,7 @@
SAFE_RELEASE(e);
@@ -1778,7 +1778,7 @@
SAFE_RELEASE(e);
@@ -1845,7 +1845,7 @@
SAFE_RELEASE(e);
@@ -1873,7 +1873,7 @@
SAFE_RELEASE(e);
Modified: trunk/MgDev/Server/src/Common/Manager/LogManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/LogManager.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Server/src/Common/Manager/LogManager.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -2041,7 +2041,7 @@
if (mgException != NULL)
// Use default message with just the given info.
- logEntry = mgException->GetMessage();
+ logEntry = mgException->GetExceptionMessage();
QueueLogEntry(mltPerformance, logEntry, LM_INFO);
@@ -2198,7 +2198,7 @@
ACE_ASSERT(NULL != serverManager);
STRING locale = serverManager->GetDefaultMessageLocale();
Modified: trunk/MgDev/Server/src/Common/Manager/LogThread.cpp
--- trunk/MgDev/Server/src/Common/Manager/LogThread.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Server/src/Common/Manager/LogThread.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -98,7 +98,7 @@
MgServerManager* pServerManager = MgServerManager::GetInstance();
ACE_DEBUG ((LM_ERROR, ACE_TEXT("(%t) %W\n"), e->GetDetails(pServerManager->GetDefaultMessageLocale()).c_str()));
- MG_LOG_EXCEPTION_ENTRY(e->GetMessage(pServerManager->GetDefaultMessageLocale()).c_str(), e->GetStackTrace(pServerManager->GetDefaultMessageLocale()).c_str());
+ MG_LOG_EXCEPTION_ENTRY(e->GetExceptionMessage(pServerManager->GetDefaultMessageLocale()).c_str(), e->GetStackTrace(pServerManager->GetDefaultMessageLocale()).c_str());
SAFE_RELEASE(e);
@@ -118,7 +118,7 @@
mgException = new MgFdoException(L"MgLogThread.svc", __LINE__, __WFILE__, NULL, messageId, &arguments);
ACE_DEBUG ((LM_ERROR, ACE_TEXT("(%t) %W\n"), mgException->GetDetails(pServerManager->GetDefaultMessageLocale()).c_str()));
- MG_LOG_EXCEPTION_ENTRY(mgException->GetMessage(pServerManager->GetDefaultMessageLocale()).c_str(), mgException->GetStackTrace(pServerManager->GetDefaultMessageLocale()).c_str());
+ MG_LOG_EXCEPTION_ENTRY(mgException->GetExceptionMessage(pServerManager->GetDefaultMessageLocale()).c_str(), mgException->GetStackTrace(pServerManager->GetDefaultMessageLocale()).c_str());
FDO_SAFE_RELEASE(e);
@@ -128,7 +128,7 @@
mgException = MgSystemException::Create(e, L"MgLogThread.svc", __LINE__, __WFILE__);
catch(...)
@@ -136,7 +136,7 @@
mgException = new MgUnclassifiedException(L"MgLogThread.svc", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -152,7 +152,7 @@
SAFE_RELEASE(e);
@@ -164,7 +164,7 @@
nResult = -1;
@@ -174,7 +174,7 @@
nResult = -1;
Modified: trunk/MgDev/Server/src/Common/Manager/PackageLogWriter.cpp
--- trunk/MgDev/Server/src/Common/Manager/PackageLogWriter.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Server/src/Common/Manager/PackageLogWriter.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -53,7 +53,7 @@
else
m_statusInfo.SetStatusCode(MgPackageStatusCode::Failed);
- m_statusInfo.SetErrorMessage(except->GetMessage());
+ m_statusInfo.SetErrorMessage(except->GetExceptionMessage());
m_statusInfo.SetStackTrace(except->GetStackTrace());
Modified: trunk/MgDev/Server/src/Common/Manager/WorkerThread.cpp
--- trunk/MgDev/Server/src/Common/Manager/WorkerThread.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Server/src/Common/Manager/WorkerThread.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -104,7 +104,7 @@
SAFE_RELEASE(e);
@@ -124,7 +124,7 @@
mgException = new MgFdoException(L"MgWorkerThread.svc", __LINE__, __WFILE__, NULL, messageId, &arguments);
@@ -134,7 +134,7 @@
mgException = MgSystemException::Create(e, L"MgWorkerThread.svc", __LINE__, __WFILE__);
catch(...)
@@ -142,7 +142,7 @@
mgException = new MgUnclassifiedException(L"MgWorkerThread.svc", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -158,7 +158,7 @@
SAFE_RELEASE(e);
@@ -170,7 +170,7 @@
nResult = -1;
@@ -180,7 +180,7 @@
nResult = -1;
Modified: trunk/MgDev/Server/src/Core/OperationThread.cpp
--- trunk/MgDev/Server/src/Core/OperationThread.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Server/src/Core/OperationThread.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -151,7 +151,7 @@
MgServerManager* serverManager = MgServerManager::GetInstance();
STRING locale = (NULL == serverManager) ?
MgResources::DefaultMessageLocale : serverManager->GetDefaultMessageLocale();
- STRING message = mgException->GetMessage(locale);
+ STRING message = mgException->GetExceptionMessage(locale);
STRING details = mgException->GetDetails(locale);
STRING stackTrace = mgException->GetStackTrace(locale);
@@ -281,7 +281,7 @@
@@ -435,7 +435,7 @@
Modified: trunk/MgDev/Server/src/Core/Server.cpp
--- trunk/MgDev/Server/src/Core/Server.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Server/src/Core/Server.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -1121,7 +1121,7 @@
Modified: trunk/MgDev/Server/src/Core/TimedEventHandler.cpp
--- trunk/MgDev/Server/src/Core/TimedEventHandler.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Server/src/Core/TimedEventHandler.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -153,7 +153,7 @@
CREFSTRING locale = serverManager->GetDefaultMessageLocale();
ACE_DEBUG((LM_ERROR, ACE_TEXT("(%t) %W\n"), e.GetDetails(locale).c_str()));
- MG_LOG_EXCEPTION_ENTRY(e.GetMessage(locale).c_str(), e.GetStackTrace(locale).c_str());
+ MG_LOG_EXCEPTION_ENTRY(e.GetExceptionMessage(locale).c_str(), e.GetStackTrace(locale).c_str());
MG_CATCH_AND_RELEASE()
Modified: trunk/MgDev/Server/src/Gws/GwsCommon/GwsException.cpp
--- trunk/MgDev/Server/src/Gws/GwsCommon/GwsException.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Server/src/Gws/GwsCommon/GwsException.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -106,12 +106,12 @@
FdoString* CGwsException::GetExceptionMessage()
- return m_status.GetMessage ();
+ return m_status.GetErrorMessage ();
FdoString* CGwsException::ToString()
Modified: trunk/MgDev/Server/src/Gws/GwsCommon/GwsObjectImpl.cpp
--- trunk/MgDev/Server/src/Gws/GwsCommon/GwsObjectImpl.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Server/src/Gws/GwsCommon/GwsObjectImpl.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -75,7 +75,7 @@
return m_status;
-FdoString *CGwsStatus::GetMessage () const
+FdoString *CGwsStatus::GetErrorMessage () const
if (m_message.empty ()) {
CGwsResourceModule::GwsStatusMessage (m_status, ((CGwsStatus *)this)->m_message);
Modified: trunk/MgDev/Server/src/Gws/GwsCommon/inc/GwsStatus.h
--- trunk/MgDev/Server/src/Gws/GwsCommon/inc/GwsStatus.h 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Server/src/Gws/GwsCommon/inc/GwsStatus.h 2010-04-07 17:16:24 UTC (rev 4749)
@@ -40,7 +40,7 @@
GWS_COMMON_API
EGwsStatus GetStatus () const ;
GWS_COMMON_API
- FdoString* GetMessage () const;
+ FdoString* GetErrorMessage () const;
// get diagnostincs parameters
GWS_COMMON_API
Modified: trunk/MgDev/Server/src/Gws/Include/GwsCommon.h
--- trunk/MgDev/Server/src/Gws/Include/GwsCommon.h 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Server/src/Gws/Include/GwsCommon.h 2010-04-07 17:16:24 UTC (rev 4749)
@@ -641,7 +641,7 @@
/// Gets the message associated with the error if any.
/// </summary>
/// <returns>Returns the error message.</returns>
- virtual FdoString* GetMessage() const = 0;
+ virtual FdoString* GetErrorMessage() const = 0;
/// <summary>
/// Gets the name value pair at index. These values may be the name of the
Modified: trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
--- trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -253,7 +253,7 @@
Ptr<MgCoordinate> ur = new MgCoordinateXY(extent.maxx, extent.maxy);
Ptr<MgEnvelope> mapExt = new MgEnvelope(ll, ur);
Ptr<MgEnvelope> rasterExt;
- if (NULL != layerCs && NULL != mapCs && layerCs->GetCode() != mapCs->GetCode())
+ if (NULL != layerCs && NULL != mapCs && layerCs->GetCsCode() != mapCs->GetCsCode())
Ptr<MgCoordinateSystemFactory> csFactory = new MgCoordinateSystemFactory();
@@ -641,7 +641,7 @@
MgCSTrans* xformer = item? item->GetTransform() : NULL;
// Test if layer and map are using the same coordinate systems
- if (NULL == layerCs.p || NULL == dstCs || layerCs->GetCode() == dstCs->GetCode())
+ if (NULL == layerCs.p || NULL == dstCs || layerCs->GetCsCode() == dstCs->GetCsCode())
// No transform required
xformer = NULL;
@@ -825,12 +825,12 @@
// Get the reason why the layer failed to stylize
MgStringCollection argumentsWhy;
- argumentsWhy.Add(mgException->GetMessage(locale));
+ argumentsWhy.Add(mgException->GetExceptionMessage(locale));
Ptr<MgStylizeLayerFailedException> exception;
exception = new MgStylizeLayerFailedException(L"MgMappingUtil.StylizeLayers", __LINE__, __WFILE__, &arguments, L"MgFormatInnerExceptionMessage", &argumentsWhy);
- STRING message = exception->GetMessage(locale);
+ STRING message = exception->GetExceptionMessage(locale);
STRING stackTrace = exception->GetStackTrace(locale);
MG_LOG_EXCEPTION_ENTRY(message.c_str(), stackTrace.c_str());
@@ -1211,7 +1211,7 @@
Modified: trunk/MgDev/Server/src/Services/Mapping/RSMgFeatureReader.cpp
--- trunk/MgDev/Server/src/Services/Mapping/RSMgFeatureReader.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Server/src/Services/Mapping/RSMgFeatureReader.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -31,7 +31,7 @@
catch (MgException* ex) \
STRING message; \
- message = ex->GetMessage(); \
+ message = ex->GetExceptionMessage(); \
ex->Release(); \
throw FdoException::Create(message.c_str()); \
@@ -281,7 +281,7 @@
STRING message;
bool shouldThrow = (NULL == dynamic_cast<MgFdoException*>(ex));
ex->Release();
Modified: trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
--- trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -1436,7 +1436,7 @@
//is to select all features which appear on the screen and then
//do our own geometry math.
#ifdef _DEBUG
- STRING error = e->GetMessage();
+ STRING error = e->GetExceptionMessage();
ACE_DEBUG((LM_ERROR, ACE_TEXT("RenderForSelection() - Error: %S\n"), error.c_str()));
#endif
Modified: trunk/MgDev/Server/src/Services/Tile/ServerTileService.cpp
--- trunk/MgDev/Server/src/Services/Tile/ServerTileService.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Server/src/Services/Tile/ServerTileService.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -620,7 +620,7 @@
if (NULL != resources)
- message = resources->GetMessage(MgResources::ErrorDescription, L"MgMapCacheCleared", NULL);
+ message = resources->GetResourceMessage(MgResources::ErrorDescription, L"MgMapCacheCleared", NULL);
MG_LOG_ERROR_ENTRY(message.c_str());
Modified: trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -148,7 +148,7 @@
if(NULL != pCoordinateSystem)
#ifdef _DEBUG
- string strMessage = MG_WCHAR_TO_CHAR(pCoordinateSystem->GetCode());
+ string strMessage = MG_WCHAR_TO_CHAR(pCoordinateSystem->GetCsCode());
printf("%s - %lf, %lf, %lf, %lf\n", strMessage.c_str(), pCoordinateSystem->GetMinX(), pCoordinateSystem->GetMinY(), pCoordinateSystem->GetMaxX(), pCoordinateSystem->GetMaxY());
#endif
@@ -374,7 +374,7 @@
catch(MgException* e)
#ifdef _DEBUG
- STRING message = e->GetMessage(TEST_LOCALE);
+ STRING message = e->GetExceptionMessage(TEST_LOCALE);
// Extract the reason out of the message
size_t index = message.find(L"\n");
@@ -513,7 +513,7 @@
Ptr<MgCoordinateSystem> pCoordinateSystemAlt = factory.Create(pCoordinateSystem->ToString());
CPPUNIT_ASSERT(pCoordinateSystemAlt);
- CPPUNIT_ASSERT(pCoordinateSystem->GetCode() == pCoordinateSystemAlt->GetCode());
+ CPPUNIT_ASSERT(pCoordinateSystem->GetCsCode() == pCoordinateSystemAlt->GetCsCode());
@@ -1120,7 +1120,7 @@
-void TestCoordinateSystem::TestCase_Arbitrary_GetCode()
+void TestCoordinateSystem::TestCase_Arbitrary_GetCsCode()
try
@@ -1129,28 +1129,28 @@
Ptr<MgCoordinateSystem> pCoordinateSystem = factory.Create(ogcWkt);
CPPUNIT_ASSERT(pCoordinateSystem);
- STRING value = pCoordinateSystem->GetCode();
+ STRING value = pCoordinateSystem->GetCsCode();
CPPUNIT_ASSERT(_wcsicmp(L"XY-MI", value.c_str()) == 0);
ogcWkt = ArbitraryWkt_Alternate1;
- value = pCoordinateSystem->GetCode();
+ value = pCoordinateSystem->GetCsCode();
ogcWkt = ArbitraryWkt_Alternate2;
ogcWkt = ArbitraryWkt_Meter;
CPPUNIT_ASSERT(_wcsicmp(L"XY-M", value.c_str()) == 0);
@@ -2437,7 +2437,7 @@
-void TestCoordinateSystem::TestCase_Geographic_GetCode()
+void TestCoordinateSystem::TestCase_Geographic_GetCsCode()
try
@@ -2446,7 +2446,7 @@
CPPUNIT_ASSERT(_wcsicmp(L"LL84", value.c_str()) == 0);
@@ -2916,7 +2916,7 @@
-void TestCoordinateSystem::TestCase_Projected_GetCode()
+void TestCoordinateSystem::TestCase_Projected_GetCsCode()
try
@@ -2925,7 +2925,7 @@
CPPUNIT_ASSERT(_wcsicmp(L"GA-W", value.c_str()) == 0);
Modified: trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.h
--- trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.h 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.h 2010-04-07 17:16:24 UTC (rev 4749)
@@ -51,7 +51,7 @@
CPPUNIT_TEST(TestCase_Arbitrary_GetMinY);
CPPUNIT_TEST(TestCase_Arbitrary_GetMaxX);
CPPUNIT_TEST(TestCase_Arbitrary_GetMaxY);
- CPPUNIT_TEST(TestCase_Arbitrary_GetCode);
+ CPPUNIT_TEST(TestCase_Arbitrary_GetCsCode);
CPPUNIT_TEST(TestCase_Arbitrary_GetDescription);
CPPUNIT_TEST(TestCase_Arbitrary_GetProjection);
CPPUNIT_TEST(TestCase_Arbitrary_GetProjectionDescription);
@@ -79,7 +79,7 @@
CPPUNIT_TEST(TestCase_Geographic_GetMinY);
CPPUNIT_TEST(TestCase_Geographic_GetMaxX);
CPPUNIT_TEST(TestCase_Geographic_GetMaxY);
- CPPUNIT_TEST(TestCase_Geographic_GetCode);
+ CPPUNIT_TEST(TestCase_Geographic_GetCsCode);
CPPUNIT_TEST(TestCase_Geographic_GetDescription);
CPPUNIT_TEST(TestCase_Geographic_GetProjection);
CPPUNIT_TEST(TestCase_Geographic_GetProjectionDescription);
@@ -107,7 +107,7 @@
CPPUNIT_TEST(TestCase_Projected_GetMinY);
CPPUNIT_TEST(TestCase_Projected_GetMaxX);
CPPUNIT_TEST(TestCase_Projected_GetMaxY);
- CPPUNIT_TEST(TestCase_Projected_GetCode);
+ CPPUNIT_TEST(TestCase_Projected_GetCsCode);
CPPUNIT_TEST(TestCase_Projected_GetDescription);
CPPUNIT_TEST(TestCase_Projected_GetProjection);
CPPUNIT_TEST(TestCase_Projected_GetProjectionDescription);
@@ -261,7 +261,7 @@
void TestCase_Arbitrary_GetMinY();
void TestCase_Arbitrary_GetMaxX();
void TestCase_Arbitrary_GetMaxY();
- void TestCase_Arbitrary_GetCode();
+ void TestCase_Arbitrary_GetCsCode();
void TestCase_Arbitrary_GetDescription();
void TestCase_Arbitrary_GetProjection();
void TestCase_Arbitrary_GetProjectionDescription();
@@ -289,7 +289,7 @@
void TestCase_Geographic_GetMinY();
void TestCase_Geographic_GetMaxX();
void TestCase_Geographic_GetMaxY();
- void TestCase_Geographic_GetCode();
+ void TestCase_Geographic_GetCsCode();
void TestCase_Geographic_GetDescription();
void TestCase_Geographic_GetProjection();
void TestCase_Geographic_GetProjectionDescription();
@@ -317,7 +317,7 @@
void TestCase_Projected_GetMinY();
void TestCase_Projected_GetMaxX();
void TestCase_Projected_GetMaxY();
- void TestCase_Projected_GetCode();
+ void TestCase_Projected_GetCsCode();
void TestCase_Projected_GetDescription();
void TestCase_Projected_GetProjection();
void TestCase_Projected_GetProjectionDescription();
Modified: trunk/MgDev/Server/src/UnitTesting/TestServerAdminService.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestServerAdminService.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Server/src/UnitTesting/TestServerAdminService.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -578,7 +578,7 @@
message += e->GetStackTrace(TEST_LOCALE);
SAFE_RELEASE(e);
CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
@@ -640,7 +640,7 @@
SAFE_RELEASE(e);
@@ -715,7 +715,7 @@
SAFE_RELEASE(e);
@@ -768,7 +768,7 @@
SAFE_RELEASE(e);
@@ -822,7 +822,7 @@
SAFE_RELEASE(e);
@@ -877,7 +877,7 @@
SAFE_RELEASE(e);
Modified: trunk/MgDev/Web/src/ApacheAgent/ApacheResponseHandler.cpp
--- trunk/MgDev/Web/src/ApacheAgent/ApacheResponseHandler.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Web/src/ApacheAgent/ApacheResponseHandler.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -172,7 +172,7 @@
void ApacheResponseHandler::SendError(MgException *e)
MG_TRY()
- STRING shortError = e->GetMessage();
+ STRING shortError = e->GetExceptionMessage();
STRING longError = e->GetDetails();
STRING statusMessage = e->GetClassName();
Modified: trunk/MgDev/Web/src/CgiAgent/CgiResponseHandler.cpp
--- trunk/MgDev/Web/src/CgiAgent/CgiResponseHandler.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Web/src/CgiAgent/CgiResponseHandler.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -170,7 +170,7 @@
void CgiResponseHandler::SendError(MgException* e)
MG_TRY()
Modified: trunk/MgDev/Web/src/DotNetApi/Foundation/ManagedException.cs
--- trunk/MgDev/Web/src/DotNetApi/Foundation/ManagedException.cs 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Web/src/DotNetApi/Foundation/ManagedException.cs 2010-04-07 17:16:24 UTC (rev 4749)
@@ -39,7 +39,7 @@
get
- return ((MgException)this).GetMessage();
+ return ((MgException)this).GetExceptionMessage();
Modified: trunk/MgDev/Web/src/HttpHandler/HttpGetSiteInfo.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpGetSiteInfo.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGetSiteInfo.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -87,7 +87,7 @@
MG_HTTP_HANDLER_CATCH(L"MgHttpGetSiteInfo.Execute")
- message = mgException->GetMessage();
+ message = mgException->GetExceptionMessage();
Modified: trunk/MgDev/Web/src/HttpHandler/HttpGetSiteStatus.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpGetSiteStatus.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGetSiteStatus.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -82,7 +82,7 @@
MG_HTTP_HANDLER_CATCH(L"MgHttpGetSiteStatus.Execute")
Modified: trunk/MgDev/Web/src/HttpHandler/HttpGetSiteVersion.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpGetSiteVersion.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGetSiteVersion.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -86,7 +86,7 @@
Modified: trunk/MgDev/Web/src/HttpHandler/HttpResult.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpResult.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Web/src/HttpHandler/HttpResult.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -18,9 +18,6 @@
#include "HttpHandler.h"
#include "HttpResult.h"
-#ifdef _WIN32
- #undef GetMessage
-#endif
/// <summary>
@@ -211,7 +208,7 @@
// Map Mg exception to HTTP result.
httpStatusMessage = mgException->GetClassName();
- errorMessage = mgException->GetMessage();
+ errorMessage = mgException->GetExceptionMessage();
detailedMessage = mgException->GetDetails();
#ifdef _DEBUG
Modified: trunk/MgDev/Web/src/HttpHandler/HttpWmsGetMap.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpWmsGetMap.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Web/src/HttpHandler/HttpWmsGetMap.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -33,7 +33,7 @@
#define CATCH_MGEXCEPTION_HANDLE_AS_OGC(mg_exception_type,ogc_exception_code,ogc_server) \
catch (mg_exception_type* e) { \
- STRING sReport = e->GetMessage(); \
+ STRING sReport = e->GetExceptionMessage(); \
sReport += _("<details>"); \
sReport += e->GetDetails(); \
sReport += _("</details>"); \
Modified: trunk/MgDev/Web/src/IsapiAgent/IsapiResponseHandler.cpp
--- trunk/MgDev/Web/src/IsapiAgent/IsapiResponseHandler.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Web/src/IsapiAgent/IsapiResponseHandler.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -184,7 +184,7 @@
void IsapiResponseHandler::SendError(MgException* e)
MG_TRY()
DWORD status = 559;
Modified: trunk/MgDev/Web/src/JavaApi/org/osgeo/mapguide/AppThrowable.java
--- trunk/MgDev/Web/src/JavaApi/org/osgeo/mapguide/AppThrowable.java 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Web/src/JavaApi/org/osgeo/mapguide/AppThrowable.java 2010-04-07 17:16:24 UTC (rev 4749)
@@ -31,7 +31,7 @@
try
catch (MgException e)
Modified: trunk/MgDev/Web/src/WebApp/WebInvokeScriptCommand.cpp
--- trunk/MgDev/Web/src/WebApp/WebInvokeScriptCommand.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Web/src/WebApp/WebInvokeScriptCommand.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -28,7 +28,7 @@
// Returns the script code necessary to invoke the desired function
-STRING MgWebInvokeScriptCommand::GetCode()
+STRING MgWebInvokeScriptCommand::GetScriptCode()
return m_code;
@@ -36,7 +36,7 @@
// Set the javascript code
-void MgWebInvokeScriptCommand::SetCode(CREFSTRING code)
+void MgWebInvokeScriptCommand::SetScriptCode(CREFSTRING code)
m_code = code;
Modified: trunk/MgDev/Web/src/WebApp/WebInvokeScriptCommand.h
--- trunk/MgDev/Web/src/WebApp/WebInvokeScriptCommand.h 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Web/src/WebApp/WebInvokeScriptCommand.h 2010-04-07 17:16:24 UTC (rev 4749)
@@ -31,7 +31,7 @@
/// <returns>
/// Javascript code
/// </returns>
- STRING GetCode();
+ STRING GetScriptCode();
INTERNAL_API:
@@ -40,7 +40,7 @@
- void SetCode(CREFSTRING code);
+ void SetScriptCode(CREFSTRING code);
CLASS_ID:
static const INT32 m_cls_id = WebApp_InvokeScriptCommand;
Modified: trunk/MgDev/Web/src/WebApp/WebLayout.cpp
--- trunk/MgDev/Web/src/WebApp/WebLayout.cpp 2010-04-07 16:58:35 UTC (rev 4748)
+++ trunk/MgDev/Web/src/WebApp/WebLayout.cpp 2010-04-07 17:16:24 UTC (rev 4749)
@@ -858,7 +858,7 @@
else if (strName == L"Script") // NOXLATE
- cmd->SetCode(GetStringFromElement(elt));
+ cmd->SetScriptCode(GetStringFromElement(elt));
else
More information about the mapguide-commits
