[mapguide-commits] r4820 - in sandbox/adsk/2.1:
Common/MapGuideCommon/System Web/src Web/src/ApacheAgent
Web/src/CgiAgent Web/src/HttpHandler Web/src/IsapiAgent
Web/src/MapAgentCommon Web/src/WebSupport
svn_mapguide at osgeo.org
Fri Apr 30 17:50:02 EDT 2010
Author: brucedechant
Date: 2010-04-30 17:50:01 -0400 (Fri, 30 Apr 2010)
New Revision: 4820
sandbox/adsk/2.1/Common/MapGuideCommon/System/ConfigProperties.cpp
sandbox/adsk/2.1/Common/MapGuideCommon/System/ConfigProperties.h
sandbox/adsk/2.1/Web/src/ApacheAgent/ApacheAgent.cpp
sandbox/adsk/2.1/Web/src/CgiAgent/CgiAgent.cpp
sandbox/adsk/2.1/Web/src/HttpHandler/HttpUtil.cpp
sandbox/adsk/2.1/Web/src/HttpHandler/HttpUtil.h
sandbox/adsk/2.1/Web/src/IsapiAgent/IsapiAgent.cpp
sandbox/adsk/2.1/Web/src/MapAgentCommon/MapAgentCommon.cpp
sandbox/adsk/2.1/Web/src/MapAgentCommon/MapAgentCommon.h
sandbox/adsk/2.1/Web/src/WebSupport/InitializeWebTier.cpp
sandbox/adsk/2.1/Web/src/webconfig.ini
Fix for trac ticket 1337 - Web tier logging
http://trac.osgeo.org/mapguide/ticket/1337
Notes:
- Add support for web tier logging (Error and Request logs)
- The following changes were made to the webconfig.ini file:
Added the following NEW properties to the GeneralProperties section:
LogsPath
Added the following NEW properties to the AgentProperties section:
ErrorLogEnabled
ErrorLogFilename
RequestLogEnabled
RequestLogFilename
Modified: sandbox/adsk/2.1/Common/MapGuideCommon/System/ConfigProperties.cpp
--- sandbox/adsk/2.1/Common/MapGuideCommon/System/ConfigProperties.cpp 2010-04-30 20:59:58 UTC (rev 4819)
+++ sandbox/adsk/2.1/Common/MapGuideCommon/System/ConfigProperties.cpp 2010-04-30 21:50:01 UTC (rev 4820)
@@ -464,6 +464,14 @@
const STRING MgConfigProperties::AgentDisableAuthoring = L"DisableAuthoring";
const STRING MgConfigProperties::AgentDisableWfs = L"DisableWfs";
const STRING MgConfigProperties::AgentDisableWms = L"DisableWms";
+const STRING MgConfigProperties::AgentErrorLogEnabled = L"ErrorLogEnabled";
+const bool MgConfigProperties::DefaultAgentErrorLogEnabled = false;
+const STRING MgConfigProperties::AgentErrorLogFilename = L"ErrorLogFilename";
+const STRING MgConfigProperties::DefaultAgentErrorLogFilename = L"Error.log";
+const STRING MgConfigProperties::AgentRequestLogEnabled = L"RequestLogEnabled";
+const bool MgConfigProperties::DefaultAgentRequestLogEnabled = false;
+const STRING MgConfigProperties::AgentRequestLogFilename = L"RequestLogFilename";
+const STRING MgConfigProperties::DefaultAgentRequestLogFilename = L"Request.log";
// OGC Properties
@@ -704,6 +712,10 @@
{ MgConfigProperties::AgentDisableAuthoring , MgPropertyType::Boolean , 0 , 1 , L"" },
{ MgConfigProperties::AgentDisableWfs , MgPropertyType::Boolean , 0 , 1 , L"" },
{ MgConfigProperties::AgentDisableWms , MgPropertyType::Boolean , 0 , 1 , L"" },
+ { MgConfigProperties::AgentErrorLogEnabled , MgPropertyType::Boolean , 0 , 1 , L"" },
+ { MgConfigProperties::AgentErrorLogFilename , MgPropertyType::String , MG_CONFIG_MIN_FILE_NAME_LENGTH , MG_CONFIG_MAX_FILE_NAME_LENGTH , MG_CONFIG_FILE_NAME_RESERVED_CHARACTERS },
+ { MgConfigProperties::AgentRequestLogEnabled , MgPropertyType::Boolean , 0 , 1 , L"" },
+ { MgConfigProperties::AgentRequestLogFilename , MgPropertyType::String , MG_CONFIG_MIN_FILE_NAME_LENGTH , MG_CONFIG_MAX_FILE_NAME_LENGTH , MG_CONFIG_FILE_NAME_RESERVED_CHARACTERS },
{ L"" , 0 , 0.0 , 0.0 , L"" }
Modified: sandbox/adsk/2.1/Common/MapGuideCommon/System/ConfigProperties.h
--- sandbox/adsk/2.1/Common/MapGuideCommon/System/ConfigProperties.h 2010-04-30 20:59:58 UTC (rev 4819)
+++ sandbox/adsk/2.1/Common/MapGuideCommon/System/ConfigProperties.h 2010-04-30 21:50:01 UTC (rev 4820)
@@ -812,6 +812,22 @@
/// Disables Http operations used for OGC Wms
static const STRING AgentDisableWms; /// value("DisableWms")
+ /// Agent error log enabled
+ static const STRING AgentErrorLogEnabled; /// value("ErrorLogEnabled")
+ static const bool DefaultAgentErrorLogEnabled; /// value(false)
+ /// Agent error log filename
+ static const STRING AgentErrorLogFilename; /// value("ErrorLogFilename")
+ static const STRING DefaultAgentErrorLogFilename; /// value("Error.log")
+ /// Agent request log enabled
+ static const STRING AgentRequestLogEnabled; /// value("RequestLogEnabled")
+ static const bool DefaultAgentRequestLogEnabled; /// value(false)
+ static const STRING AgentRequestLogFilename; /// value("RequestLogFilename")
+ static const STRING DefaultAgentRequestLogFilename; /// value("Request.log")
/// OGC PROPERTIES SECTION -------------------------------------------------------------------------------------------
/// Ogc properties
Modified: sandbox/adsk/2.1/Web/src/ApacheAgent/ApacheAgent.cpp
--- sandbox/adsk/2.1/Web/src/ApacheAgent/ApacheAgent.cpp 2010-04-30 20:59:58 UTC (rev 4819)
+++ sandbox/adsk/2.1/Web/src/ApacheAgent/ApacheAgent.cpp 2010-04-30 21:50:01 UTC (rev 4820)
@@ -155,24 +155,25 @@
// check for CLIENTIP, if it's not there (and it shouldn't be),
// add it in using httpClientIp. httpXFF or remoteAddr
+ STRING clientIp = L"";
if (!params->ContainsParameter(L"CLIENTIP")) // NOXLATE
if (!httpClientIp.empty()
&& _stricmp(httpClientIp.c_str(), MapAgentStrings::Unknown) != 0)
- STRING wHttpClientIp = MgUtil::MultiByteToWideChar(httpClientIp);
- params->AddParameter(L"CLIENTIP", wHttpClientIp); // NOXLATE
+ clientIp = MgUtil::MultiByteToWideChar(httpClientIp);
+ params->AddParameter(L"CLIENTIP", clientIp); // NOXLATE
else if (!httpXFF.empty()
&& _stricmp(httpXFF.c_str(), MapAgentStrings::Unknown) != 0)
- STRING wHttpXFF = MgUtil::MultiByteToWideChar(httpXFF);
- params->AddParameter(L"CLIENTIP", wHttpXFF); // NOXLATE
+ clientIp = MgUtil::MultiByteToWideChar(httpXFF);
else if (!remoteAddr.empty())
- STRING wRemoteAddr = MgUtil::MultiByteToWideChar(remoteAddr);
- params->AddParameter(L"CLIENTIP", wRemoteAddr); // NOXLATE
+ clientIp = MgUtil::MultiByteToWideChar(remoteAddr);
@@ -187,6 +188,17 @@
gotAuth = MapAgentCommon::ParseAuth((char *)auth.c_str(), params);
+ // Log request information
+ string postData = "";
+ if (!requestMethod.empty() && requestMethod.find("POST") != string::npos) // NOXLATE
+ // Get the post xml data
+ postData = params->GetXmlPostData();
+ STRING client = params->GetParameterValue(MgHttpResourceStrings::reqClientAgent);
+ MapAgentCommon::LogRequest(client, clientIp, url, requestMethod, postData, query);
Ptr<MgPropertyCollection> paramList = params->GetParameters()->GetPropertyCollection();
if (paramList != NULL)
Modified: sandbox/adsk/2.1/Web/src/CgiAgent/CgiAgent.cpp
--- sandbox/adsk/2.1/Web/src/CgiAgent/CgiAgent.cpp 2010-04-30 20:59:58 UTC (rev 4819)
+++ sandbox/adsk/2.1/Web/src/CgiAgent/CgiAgent.cpp 2010-04-30 21:50:01 UTC (rev 4820)
@@ -165,24 +165,25 @@
if (NULL != httpClientIp && strlen(httpClientIp) > 0
&& _stricmp(httpClientIp, MapAgentStrings::Unknown) != 0)
else if (NULL != httpXFF && strlen(httpXFF) > 0
&& _stricmp(httpXFF, MapAgentStrings::Unknown) != 0)
else if (NULL != remoteAddr && strlen(remoteAddr) > 0)
@@ -197,6 +198,17 @@
gotAuth = ParseAuth(auth, params);
+ if (requestMethod && _stricmp(requestMethod, "POST") == 0) // NOXLATE
+ MapAgentCommon::LogRequest(client, clientIp, url, std::string(requestMethod), postData, std::string(query));
Modified: sandbox/adsk/2.1/Web/src/HttpHandler/HttpUtil.cpp
--- sandbox/adsk/2.1/Web/src/HttpHandler/HttpUtil.cpp 2010-04-30 20:59:58 UTC (rev 4819)
+++ sandbox/adsk/2.1/Web/src/HttpHandler/HttpUtil.cpp 2010-04-30 21:50:01 UTC (rev 4820)
@@ -17,3 +17,72 @@
#include "HttpHandler.h"
#include "HttpUtil.h"
+void MgHttpUtil::LogException(MgException* exception)
+ if(NULL != exception)
+ ACE_MT (ACE_GUARD(ACE_Recursive_Thread_Mutex, ace_mon, *ACE_Static_Object_Lock::instance()));
+ MgConfiguration* cfg = MgConfiguration::GetInstance();
+ // Is log enabled?
+ bool bLogEnabled = false;
+ cfg->GetBoolValue(MgConfigProperties::AgentPropertiesSection, MgConfigProperties::AgentErrorLogEnabled, bLogEnabled, MgConfigProperties::DefaultAgentErrorLogEnabled);
+ if(bLogEnabled)
+ // Get the logs path
+ STRING path = L"";
+ cfg->GetStringValue(MgConfigProperties::GeneralPropertiesSection, MgConfigProperties::GeneralPropertyLogsPath, path, MgConfigProperties::DefaultGeneralPropertyLogsPath);
+ // Check if path ends with a '/' if not, add one if needed
+ MgFileUtil::AppendSlashToEndOfPath(path);
+ STRING filename = L"";
+ cfg->GetStringValue(MgConfigProperties::AgentPropertiesSection, MgConfigProperties::AgentErrorLogFilename, filename, MgConfigProperties::DefaultAgentErrorLogFilename);
+ filename = path + filename;
+ FILE* fp = ACE_OS::fopen(MG_WCHAR_TO_TCHAR(filename), ACE_TEXT("a+"));
+ if (fp)
+ MgDateTime currentTime;
+ STRING strCurrentTime = currentTime.ToXmlString(false);
+ STRING message = exception->GetMessage();
+ STRING stackTrace = exception->GetStackTrace();
+ ACE_OS::fprintf(fp, ACE_TEXT("<%s>\n"), strCurrentTime.c_str());
+ ACE_OS::fprintf(fp, ACE_TEXT(" Error: %s\n"), message.c_str());
+ // Add the stack trace
+ // Do not log empty stack traces
+ if (!stackTrace.empty())
+ STRING entry = L"";
+ entry += L" " + MgResources::StackTrace + L":";
+ size_t size = stackTrace.size();
+ if (size > 0)
+ STRING trace = stackTrace.c_str();
+ // Get rid of extra \n at the end of the stack trace
+ if (trace[size-1] == L'\n')
+ trace.erase((size-1), 1);
+ // Make it look "pretty"
+ trace = MgUtil::ReplaceString(trace, L"\n", L"\n ");
+ entry += L"\n " + trace + L"\n";
+ ACE_OS::fprintf(fp, ACE_TEXT("%s"), entry.c_str());
+ ACE_OS::fclose(fp);
Modified: sandbox/adsk/2.1/Web/src/HttpHandler/HttpUtil.h
--- sandbox/adsk/2.1/Web/src/HttpHandler/HttpUtil.h 2010-04-30 20:59:58 UTC (rev 4819)
+++ sandbox/adsk/2.1/Web/src/HttpHandler/HttpUtil.h 2010-04-30 21:50:01 UTC (rev 4820)
@@ -25,15 +25,20 @@
#define MG_HTTP_HANDLER_CATCH(methodName) \
MG_CATCH(methodName) \
+ MgHttpUtil::LogException(mgException); \
#define MG_HTTP_HANDLER_THROW() \
MG_THROW() \
#define MG_HTTP_HANDLER_CATCH_AND_THROW(methodName) \
- MG_CATCH_AND_THROW(methodName) \
+ MG_CATCH(methodName) \
+ MG_THROW() \
#define MG_HTTP_HANDLER_CATCH_AND_THROW_EX(methodName) \
if (mgException != NULL) \
@@ -48,6 +53,7 @@
#define MG_HTTP_HANDLER_CATCH_AND_THROW_EX2(methodName, hResult, hRequest) \
@@ -60,4 +66,13 @@
mgException->Raise(); \
+class MgHttpUtil
+public:
+ MgHttpUtil();
+ ~MgHttpUtil();
+ static void LogException(MgException* exception);
#endif
Modified: sandbox/adsk/2.1/Web/src/IsapiAgent/IsapiAgent.cpp
--- sandbox/adsk/2.1/Web/src/IsapiAgent/IsapiAgent.cpp 2010-04-30 20:59:58 UTC (rev 4819)
+++ sandbox/adsk/2.1/Web/src/IsapiAgent/IsapiAgent.cpp 2010-04-30 21:50:01 UTC (rev 4820)
@@ -119,24 +119,25 @@
if (bHttpClientIp && NULL != httpClientIp && strlen(httpClientIp) > 0
else if (bHttpXFF && NULL != httpXFF && strlen(httpXFF) > 0
else if (bRemoteAddr && NULL != remoteAddr && strlen(remoteAddr) > 0)
@@ -154,6 +155,17 @@
gotAuth = MapAgentCommon::ParseAuth(auth, params);
Modified: sandbox/adsk/2.1/Web/src/MapAgentCommon/MapAgentCommon.cpp
--- sandbox/adsk/2.1/Web/src/MapAgentCommon/MapAgentCommon.cpp 2010-04-30 20:59:58 UTC (rev 4819)
+++ sandbox/adsk/2.1/Web/src/MapAgentCommon/MapAgentCommon.cpp 2010-04-30 21:50:01 UTC (rev 4820)
@@ -261,3 +261,53 @@
+void MapAgentCommon::LogRequest(CREFSTRING client, CREFSTRING clientIp, std::string &url, std::string &requestMethod, std::string &postData, std::string &query)
+ static INT32 requestId = 1;
+ cfg->GetBoolValue(MgConfigProperties::AgentPropertiesSection, MgConfigProperties::AgentRequestLogEnabled, bLogEnabled, MgConfigProperties::DefaultAgentRequestLogEnabled);
+ if(bLogEnabled)
+ cfg->GetStringValue(MgConfigProperties::AgentPropertiesSection, MgConfigProperties::AgentRequestLogFilename, filename, MgConfigProperties::DefaultAgentRequestLogFilename);
+ if (fp)
+ ACE_OS::fprintf(fp, ACE_TEXT("<%s> %d\t%s\t%s\t%s\t%s\n"), strCurrentTime.c_str(), requestId, client.c_str(), clientIp.c_str(), MgUtil::MultiByteToWideChar(requestMethod).c_str(), MgUtil::MultiByteToWideChar(url).c_str());
+ if (!postData.empty()) // NOXLATE
+ ACE_OS::fprintf(fp, ACE_TEXT(" Postdata: %s\n"), MgUtil::MultiByteToWideChar(postData).c_str());
+ if (!query.empty())
+ ACE_OS::fprintf(fp, ACE_TEXT(" Query : %s\n"), MgUtil::MultiByteToWideChar(query).c_str());
+ // Increment the request Id
+ requestId++;
Modified: sandbox/adsk/2.1/Web/src/MapAgentCommon/MapAgentCommon.h
--- sandbox/adsk/2.1/Web/src/MapAgentCommon/MapAgentCommon.h 2010-04-30 20:59:58 UTC (rev 4819)
+++ sandbox/adsk/2.1/Web/src/MapAgentCommon/MapAgentCommon.h 2010-04-30 21:50:01 UTC (rev 4820)
@@ -35,6 +35,8 @@
static void ScanHeaders(char* partHdrStart, char* partHdrEnd, STRING& paramName, STRING& paramType, bool& bIsFile);
static void PopulateData(char* partHdrEnd, char** curBuf, char* endBuf, string& dataEndTag,
STRING& paramName, STRING& paramType, MgHttpRequestParam* params, bool& bIsFile);
+ static void LogRequest(CREFSTRING client, CREFSTRING clientIp, std::string &url, std::string &requestMethod, std::string &postData, std::string &query);
#endif
Modified: sandbox/adsk/2.1/Web/src/WebSupport/InitializeWebTier.cpp
--- sandbox/adsk/2.1/Web/src/WebSupport/InitializeWebTier.cpp 2010-04-30 20:59:58 UTC (rev 4819)
+++ sandbox/adsk/2.1/Web/src/WebSupport/InitializeWebTier.cpp 2010-04-30 21:50:01 UTC (rev 4820)
@@ -51,6 +51,16 @@
resources->Initialize(resourcesPath);
resources->LoadResources(locale);
+ config->GetStringValue(MgConfigProperties::GeneralPropertiesSection, MgConfigProperties::GeneralPropertyLogsPath, path, MgConfigProperties::DefaultGeneralPropertyLogsPath);
+ // Try and create the directory. If it already exists this will error and not a problem
+ ACE_OS::mkdir(MG_WCHAR_TO_TCHAR(path));
m_bInitialized = true;
Modified: sandbox/adsk/2.1/Web/src/webconfig.ini
--- sandbox/adsk/2.1/Web/src/webconfig.ini 2010-04-30 20:59:58 UTC (rev 4819)
+++ sandbox/adsk/2.1/Web/src/webconfig.ini 2010-04-30 21:50:01 UTC (rev 4820)
@@ -39,12 +39,14 @@
# case and the last 2 characters must
# be upper case.
+# LogsPath Path where log files are stored
# ResourcesPath Path where the localization resource files are stored
# TcpIpMtu The TCP/IP maximum transmission unit
# 0 < Value <= 65535
# TempPath Path where the temporary files are stored
DefaultMessageLocale = en
+LogsPath = Logs/
ResourcesPath = Resources/
TcpIpMtu = 1460
TempPath = Temp/
@@ -115,11 +117,19 @@
# 0 = false and 1 = true
# DisableWms Disables OGC Wms HTTP requests
+# ErrorLogEnabled 0 = log disabled, 1 = log enabled
+# ErrorLogFilename Name of the log file
+# RequestLogEnabled 0 = log disabled, 1 = log enabled
+# RequestLogFilename Name of the log file
DebugPause = 0
DisableAuthoring = 0
DisableWfs = 0
DisableWms = 0
+ErrorLogEnabled = 1
+ErrorLogFilename = Error.log
+RequestLogEnabled = 0
+RequestLogFilename = Request.log
[OgcProperties]
More information about the mapguide-commits
