[mapguide-commits] r5066 - in trunk/MgDev:
Common/MapGuideCommon/Services Common/PlatformBase/Services
Server/src/Services/Feature
UnitTest/WebTier/MapAgent/MapAgentForms Web/src/HttpHandler
svn_mapguide at osgeo.org
Wed Aug 4 15:43:33 EDT 2010
Author: brucedechant
Date: 2010-08-04 19:43:32 +0000 (Wed, 04 Aug 2010)
New Revision: 5066
trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.cpp
trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.h
trunk/MgDev/Common/PlatformBase/Services/FeatureService.h
trunk/MgDev/Server/src/Services/Feature/OpGetCapabilities.cpp
trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp
trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.h
trunk/MgDev/Server/src/Services/Feature/ServerGetProviderCapabilities.cpp
trunk/MgDev/Server/src/Services/Feature/ServerGetProviderCapabilities.h
trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/getcapabilitiesform.html
trunk/MgDev/Web/src/HttpHandler/HttpGetCapabilities.cpp
trunk/MgDev/Web/src/HttpHandler/HttpGetCapabilities.h
Fix for trac ticket 1415 - Implement RFC 105
http://trac.osgeo.org/mapguide/ticket/1415
Notes:
- Enhance feature service GetCapabilities API with connection string support
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.cpp 2010-08-04 19:19:09 UTC (rev 5065)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.cpp 2010-08-04 19:43:32 UTC (rev 5066)
@@ -277,16 +277,21 @@
/// Subject to change with FDO R2
MgByteReader* MgProxyFeatureService::GetCapabilities(CREFSTRING providerName)
- Ptr<MgUserInformation> userInfo = m_connProp->GetUserInfo();
+ STRING connectionString = L"";
+ return GetCapabilities(providerName, connectionString);
+MgByteReader* MgProxyFeatureService::GetCapabilities(CREFSTRING providerName, CREFSTRING connectionString)
MgCommand cmd;
cmd.ExecuteCommand(m_connProp, // Connection
MgCommand::knObject, // Return type expected
MgFeatureServiceOpId::GetCapabilities_Id, // Command Code
- 1, // No of arguments
+ 2, // No of arguments
Feature_Service, // Service Id
- userInfo->GetApiVersion(), // Operation version
+ BUILD_VERSION(1,0,0), // Operation version
MgCommand::knString, &providerName, // Argument#1
+ MgCommand::knString, &connectionString, // Argument#2
MgCommand::knNone); // End of argument
SetWarning(cmd.GetWarningObject());
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.h
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.h 2010-08-04 19:19:09 UTC (rev 5065)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.h 2010-08-04 19:43:32 UTC (rev 5066)
@@ -207,6 +207,39 @@
/// \brief
+ /// This method returns capabilities of the provider applicable for the
+ /// specified connection string.
+ /// \remarks
+ /// This would provide details on the following
+ /// capabilities:
+ /// <ol>
+ /// <li>Connection</li>
+ /// <li>Schema</li>
+ /// <li>Command</li>
+ /// <li>Filter</li>
+ /// <li>Expression</li>
+ /// </ol>
+ /// \n
+ /// Schema Definition: FeatureProviderCapabilities.xsd
+ /// Sample XML: FeatureProviderCapabilities.xml
+ /// \param providerName
+ /// Input
+ /// Name of provider for which capabilities are requested
+ /// \param connectionString
+ /// Input
+ /// The connection string to use
+ /// \return
+ /// Byte array representing XML (or NULL)
+ /// \exception MgInvalidProviderNameException
+ MgByteReader* GetCapabilities(CREFSTRING providerName, CREFSTRING connectionString);
+ /// \brief
/// This method returns list of ALL schemas names available with
/// with the provider
Modified: trunk/MgDev/Common/PlatformBase/Services/FeatureService.h
--- trunk/MgDev/Common/PlatformBase/Services/FeatureService.h 2010-08-04 19:19:09 UTC (rev 5065)
+++ trunk/MgDev/Common/PlatformBase/Services/FeatureService.h 2010-08-04 19:43:32 UTC (rev 5066)
@@ -349,6 +349,46 @@
/// \brief
+ /// Gets the capabilities of an FDO Provider expressed in XML
+ /// according to the \link FdoProviderCapabilities_schema FdoProviderCapabilities \endlink schema.
+ /// \remarks
+ /// MgFeatureService derives most of its capabilities from the
+ /// FDO Provider to which it is connected. Capabilities vary
+ /// among providers. For example, the FDO Provider for ArcSDE
+ /// supports all of the spatial operators, and the FDO Provider
+ /// for Oracle supports only a subset. For a fuller discussion,
+ /// see \link ProviderCapabilities Provider Capabilities \endlink.
+ /// <!-- Syntax in .Net, Java, and PHP -->
+ /// \htmlinclude DotNetSyntaxTop.html
+ /// virtual MgByteReader GetCapabilities(string providerName);
+ /// \htmlinclude SyntaxBottom.html
+ /// \htmlinclude JavaSyntaxTop.html
+ /// virtual MgByteReader GetCapabilities(String providerName);
+ /// \htmlinclude PHPSyntaxTop.html
+ /// \param providerName (String/string)
+ /// The name of the FDO provider. Get the exact
+ /// form of the name from
+ /// MgFeatureService::GetFeatureProviders.
+ /// \param connectionString (String/string)
+ /// The connection string to use.
+ /// \return
+ /// Returns an MgByteReader containing the capabilities in XML
+ /// format (or NULL).
+ /// \exception MgInvalidArgumentException
+ /// \exception MgFdoException
+ virtual MgByteReader* GetCapabilities(CREFSTRING providerName, CREFSTRING connectionString) = 0;
+ /// \brief
/// Creates or updates a feature schema within the specified feature source.
Modified: trunk/MgDev/Server/src/Services/Feature/OpGetCapabilities.cpp
--- trunk/MgDev/Server/src/Services/Feature/OpGetCapabilities.cpp 2010-08-04 19:19:09 UTC (rev 5065)
+++ trunk/MgDev/Server/src/Services/Feature/OpGetCapabilities.cpp 2010-08-04 19:43:32 UTC (rev 5066)
@@ -82,6 +82,30 @@
// Write the response
EndExecution(byteReader);
+ else if (2 == m_packet.m_NumArguments)
+ // Get property name
+ STRING providerName;
+ m_stream->GetString(providerName);
+ STRING connectionString;
+ m_stream->GetString(connectionString);
+ BeginExecution();
+ MG_LOG_OPERATION_MESSAGE_PARAMETERS_START();
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(providerName.c_str());
+ MG_LOG_OPERATION_MESSAGE_ADD_SEPARATOR();
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(connectionString.c_str());
+ MG_LOG_OPERATION_MESSAGE_PARAMETERS_END();
+ Validate();
+ // Execute the operation
+ Ptr<MgByteReader> byteReader = m_service->GetCapabilities(providerName, connectionString);
+ // Write the response
+ EndExecution(byteReader);
else
Modified: trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp 2010-08-04 19:19:09 UTC (rev 5065)
+++ trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp 2010-08-04 19:43:32 UTC (rev 5066)
@@ -272,10 +272,19 @@
L"MgServerFeatureService.GetCapabilities", __LINE__, __WFILE__, NULL, L"", NULL);
- MgServerGetProviderCapabilities msgpc(providerName);
+ MgServerGetProviderCapabilities msgpc(providerName, connectionString);
return msgpc.GetProviderCapabilities();
+MgByteReader* MgServerFeatureService::GetCapabilities( CREFSTRING providerName, CREFSTRING connectionString )
+ MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::GetCapabilities()");
+ return msgpc.GetProviderCapabilities();
/// \brief
Modified: trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.h
--- trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.h 2010-08-04 19:19:09 UTC (rev 5065)
+++ trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.h 2010-08-04 19:43:32 UTC (rev 5066)
@@ -187,6 +187,34 @@
/// <summary>
+ /// connection. This would provide details on the following
+ /// capabilities:
+ /// 1. Connection
+ /// 2. Schema
+ /// 3. Command
+ /// 4. Filter
+ /// 5. Expression
+ /// </summary>
+ /// <param name="providerName">Input
+ /// Name of provider for which capabilities are being requested
+ /// </param>
+ /// <returns>
+ /// <param name="connectionString">Input
+ /// </param>
+ /// </returns>
+ /// EXCEPTIONS:
+ /// MgInvalidProviderNameException
+ /// <summary>
/// </summary>
Modified: trunk/MgDev/Server/src/Services/Feature/ServerGetProviderCapabilities.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerGetProviderCapabilities.cpp 2010-08-04 19:19:09 UTC (rev 5065)
+++ trunk/MgDev/Server/src/Services/Feature/ServerGetProviderCapabilities.cpp 2010-08-04 19:43:32 UTC (rev 5066)
@@ -38,7 +38,7 @@
bool MgServerGetProviderCapabilities::m_isInitialized = MgServerGetProviderCapabilities::Initialize();
-MgServerGetProviderCapabilities::MgServerGetProviderCapabilities(CREFSTRING providerName)
+MgServerGetProviderCapabilities::MgServerGetProviderCapabilities(CREFSTRING providerName, CREFSTRING connectionString)
if (providerName.empty())
@@ -64,6 +64,16 @@
// TODO: Should this connection be cached?
// use a smart pointer until the end in case there's an exception
FdoPtr<FdoIConnection> fdoConn = connManager->CreateConnection(providerNoVersion.c_str());
+ // Note: WFS doesn't return the proper capabilities if a connection is not opened to the actual server using a connection string.
+ // Check if a connection string was specified
+ if(!connectionString.empty())
+ fdoConn->SetConnectionString(connectionString.c_str());
+ fdoConn->Open();
CHECKNULL(fdoConn, L"MgServerGetProviderCapabilities.MgServerGetProviderCapabilities");
m_xmlUtil = new MgXmlUtil();
@@ -80,6 +90,12 @@
MgServerGetProviderCapabilities::~MgServerGetProviderCapabilities()
+ // Check if the connection needs to be closed
+ if(m_fdoConn->GetConnectionState() == FdoConnectionState_Open)
+ m_fdoConn->Close();
m_fdoConn = NULL;
if (NULL != m_xmlUtil)
Modified: trunk/MgDev/Server/src/Services/Feature/ServerGetProviderCapabilities.h
--- trunk/MgDev/Server/src/Services/Feature/ServerGetProviderCapabilities.h 2010-08-04 19:19:09 UTC (rev 5065)
+++ trunk/MgDev/Server/src/Services/Feature/ServerGetProviderCapabilities.h 2010-08-04 19:43:32 UTC (rev 5066)
@@ -26,7 +26,7 @@
class MgServerGetProviderCapabilities
public:
- MgServerGetProviderCapabilities(CREFSTRING providerName);
+ MgServerGetProviderCapabilities(CREFSTRING providerName, CREFSTRING connectionString);
~MgServerGetProviderCapabilities();
MgByteReader* GetProviderCapabilities();
Modified: trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/getcapabilitiesform.html
--- trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/getcapabilitiesform.html 2010-08-04 19:19:09 UTC (rev 5065)
+++ trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/getcapabilitiesform.html 2010-08-04 19:43:32 UTC (rev 5066)
@@ -20,6 +20,8 @@
<input type="text" name="CLIENTAGENT" value="MapGuide Developer" size="100">
<p> Provider:
<input type="text" name="PROVIDER" value="OSGeo.SDF" size="100" ID="Text5">
+ <p> Connection String: (optional)
+ <input type="text" name="CONNECTIONSTRING" value="" size="100" ID="Text6">
<p> Format:
<select name="FORMAT">
<option value="text/xml">text/xml</option>
Modified: trunk/MgDev/Web/src/HttpHandler/HttpGetCapabilities.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpGetCapabilities.cpp 2010-08-04 19:19:09 UTC (rev 5065)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGetCapabilities.cpp 2010-08-04 19:43:32 UTC (rev 5066)
@@ -35,7 +35,8 @@
InitializeCommonParameters(hRequest);
Ptr<MgHttpRequestParam> params = hRequest->GetRequestParam();
- this->m_providerName = params->GetParameterValue(MgHttpResourceStrings::reqFeatProvider);
+ m_providerName = params->GetParameterValue(MgHttpResourceStrings::reqFeatProvider);
+ m_connectionString = params->GetParameterValue(MgHttpResourceStrings::reqFeatConnectionString);
/// <summary>
@@ -58,7 +59,7 @@
Ptr<MgFeatureService> service = (MgFeatureService*)(CreateService(MgServiceType::FeatureService));
// call the C++ API
- Ptr<MgByteReader> byteReader = service->GetCapabilities(m_providerName);
+ Ptr<MgByteReader> byteReader = service->GetCapabilities(m_providerName, m_connectionString);
// Convert to requested response format, if necessary
ProcessFormatConversion(byteReader);
Modified: trunk/MgDev/Web/src/HttpHandler/HttpGetCapabilities.h
--- trunk/MgDev/Web/src/HttpHandler/HttpGetCapabilities.h 2010-08-04 19:19:09 UTC (rev 5065)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGetCapabilities.h 2010-08-04 19:43:32 UTC (rev 5066)
@@ -45,6 +45,7 @@
private:
STRING m_providerName;
+ STRING m_connectionString;
#endif // _FS_GET_CAPABILITIES_H
More information about the mapguide-commits
