[mapguide-commits] r5071 - in trunk/MgDev/Web/src: ApacheAgent
IsapiAgent
svn_mapguide at osgeo.org
Thu Aug 5 13:38:22 EDT 2010
Author: brucedechant
Date: 2010-08-05 17:38:22 +0000 (Thu, 05 Aug 2010)
New Revision: 5071
trunk/MgDev/Web/src/ApacheAgent/ApacheAgent.cpp
trunk/MgDev/Web/src/IsapiAgent/IsapiAgent.cpp
Add missing exception handler to Apache and IIS agents.
Modified: trunk/MgDev/Web/src/ApacheAgent/ApacheAgent.cpp
--- trunk/MgDev/Web/src/ApacheAgent/ApacheAgent.cpp 2010-08-05 16:17:42 UTC (rev 5070)
+++ trunk/MgDev/Web/src/ApacheAgent/ApacheAgent.cpp 2010-08-05 17:38:22 UTC (rev 5071)
@@ -112,7 +112,10 @@
Initialize(r);
+ ApacheResponseHandler responseHandler(r);
+ MG_TRY()
// Construct self Url. It is embedded into the output stream
// of some requests (like GetMap). Use a fully qualified URL.
string serverName = GetServerVariable(r, MapAgentStrings::ServerName);
@@ -202,8 +205,6 @@
Ptr<MgPropertyCollection> paramList = params->GetParameters()->GetPropertyCollection();
if (paramList != NULL)
- ApacheResponseHandler responseHandler(r);
// Check to be sure that we have some kind of credentials before continuing. Either
// username/password or sessionid.
bool bValid = paramList->Contains(MgHttpResourceStrings::reqSession);
@@ -233,6 +234,13 @@
responseHandler.SendResponse(response);
+ MG_CATCH(L"ApacheAgent.mgmapagent_handler");
+ if (mgException != NULL)
+ responseHandler.SendError(mgException);
return OK;
Modified: trunk/MgDev/Web/src/IsapiAgent/IsapiAgent.cpp
--- trunk/MgDev/Web/src/IsapiAgent/IsapiAgent.cpp 2010-08-05 16:17:42 UTC (rev 5070)
+++ trunk/MgDev/Web/src/IsapiAgent/IsapiAgent.cpp 2010-08-05 17:38:22 UTC (rev 5071)
@@ -50,6 +50,10 @@
DWORD WINAPI HttpExtensionProc(EXTENSION_CONTROL_BLOCK *pECB)
+ IsapiResponseHandler responseHandler(pECB);
+ MG_TRY()
Initialize(pECB);
@@ -169,8 +173,6 @@
- IsapiResponseHandler responseHandler(pECB);
@@ -206,6 +208,13 @@
+ MG_CATCH(L"IsapiAgent.HttpExtensionProc");
return HSE_STATUS_SUCCESS;
More information about the mapguide-commits
