[mapguide-commits] r5083 - in sandbox/maestro-3.0/Maestro.Base: .
Commands/SiteExplorer Properties Resources UI
svn_mapguide at osgeo.org
Wed Aug 11 07:10:29 EDT 2010
Author: jng
Date: 2010-08-11 11:10:29 +0000 (Wed, 11 Aug 2010)
New Revision: 5083
Added:
sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/DeleteSelectedItemsCommand.cs
sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/NewFolderCommand.cs
sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/RenameCommand.cs
sandbox/maestro-3.0/Maestro.Base/Resources/folder--plus.png
sandbox/maestro-3.0/Maestro.Base/UI/RenameItemDialog.Designer.cs
sandbox/maestro-3.0/Maestro.Base/UI/RenameItemDialog.cs
sandbox/maestro-3.0/Maestro.Base/UI/RenameItemDialog.resx
sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/RefreshCommand.cs
sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
sandbox/maestro-3.0/Maestro.Base/UI/ISiteExplorer.cs
sandbox/maestro-3.0/Maestro.Base/UI/RepositoryTreeModel.cs
sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.Designer.cs
sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.cs
This submission enables functionality to modify/update the repository tree model. The following commands have been now added/enabled:
- Delete Selected Items
- Rename (there is a problem involving child folder expansion of renamed items that is yet to be fixed)
- New Folder
- Refresh
Added: sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/DeleteSelectedItemsCommand.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/DeleteSelectedItemsCommand.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/DeleteSelectedItemsCommand.cs 2010-08-11 11:10:29 UTC (rev 5083)
@@ -0,0 +1,108 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using ICSharpCode.Core;
+using Maestro.Base.Services;
+using Maestro.Shared.UI;
+using Maestro.Base.UI;
+namespace Maestro.Base.Commands.SiteExplorer
+ internal class DeleteSelectedItemsCommand : AbstractMenuCommand
+ public override void Run()
+ var wb = Workbench.Instance;
+ var svc = ServiceRegistry.GetService<ServerConnectionManager>();
+ var exp = wb.ActiveSiteExplorer;
+ if (exp != null)
+ var conn = svc.GetConnection(exp.ConnectionName);
+ var resSvc = conn.ResourceService;
+ var items = exp.SelectedItems;
+ if (items.Length > 0)
+ if (MessageService.AskQuestion(Properties.Resources.ConfirmDelete))
+ DoDelete(wb, resSvc, items);
+ private void DoDelete(Workbench wb, OSGeo.MapGuide.MaestroAPI.Services.IResourceService resSvc, RepositoryItem[] items)
+ var pdlg = new ProgressDialog();
+ pdlg.CancelAbortsThread = true;
+ string[] args = new string[items.Length];
+ for (int i = 0; i < items.Length; i++)
+ args[i] = items[i].ResourceId;
+ var work = new Maestro.Shared.UI.ProgressDialog.DoBackgroundWork((worker, e, target) =>
+ int deleted = 0;
+ if (target == null || target.Length == 0)
+ return deleted;
+ int step = 100 / target.Length;
+ int current = 0;
+ foreach (RepositoryItem item in target)
+ if (worker.CancellationPending || e.Cancel)
+ return deleted;
+ current += step;
+ if (item.IsRoot) //Wait a minute...!
+ continue;
+ else
+ resSvc.DeleteResource(item.ResourceId);
+ deleted++;
+ worker.ReportProgress(current, item.ResourceId);
+ //collect affected parents and update the model
+ var parent = item.Parent;
+ if (parent != null)
+ parent.RemoveChild(item);
+ return deleted;
+ pdlg.RunOperationAsync(wb, work, items);
Added: sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/NewFolderCommand.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/NewFolderCommand.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/NewFolderCommand.cs 2010-08-11 11:10:29 UTC (rev 5083)
@@ -0,0 +1,56 @@
+#endregion
+using System;
+using System.Text;
+ internal class NewFolderCommand : AbstractMenuCommand
+ var connMgr = ServiceRegistry.GetService<ServerConnectionManager>();
+ var conn = connMgr.GetConnection(exp.ConnectionName);
+ if (exp.SelectedItems.Length == 1)
+ var item = exp.SelectedItems[0];
+ if (item.IsFolder)
+ string defaultName = "New Folder";
+ string name = defaultName;
+ int counter = -1;
+ while (item.Contains(name))
+ counter++;
+ name = defaultName + counter;
+ conn.ResourceService.CreateFolder(item.ResourceId + name);
+ var path = item.Model.GetPath(item);
+ item.Model.RaiseStructureChanged(new Aga.Controls.Tree.TreeModelEventArgs(path, new object[0]));
Modified: sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/RefreshCommand.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/RefreshCommand.cs 2010-08-11 05:18:46 UTC (rev 5082)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/RefreshCommand.cs 2010-08-11 11:10:29 UTC (rev 5083)
@@ -20,10 +20,20 @@
using System;
using System.Text;
- internal class RefreshCommand : NotImplementedCommand
+ internal class RefreshCommand : AbstractMenuCommand
+ if (exp != null)
+ exp.RefreshModel();
Added: sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/RenameCommand.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/RenameCommand.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/RenameCommand.cs 2010-08-11 11:10:29 UTC (rev 5083)
@@ -0,0 +1,89 @@
+#endregion
+using System;
+using System.Text;
+ internal class RenameCommand : AbstractMenuCommand
+ var current = exp.SelectedItems[0];
+ var parent = current.Parent;
+ List<string> names = new List<string>();
+ foreach (var item in parent.Children)
+ if (item != exp.SelectedItems[0])
+ names.Add(item.Name);
+ var dlg = new RenameItemDialog(current.Name, names);
+ if (dlg.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+ string oldid = string.Empty;
+ string newid = string.Empty;
+ if (current.IsFolder)
+ oldid = parent.ResourceId + current.Name + "/";
+ newid = parent.ResourceId + dlg.NewName + "/";
+ else
+ oldid = parent.ResourceId + current.Name + "." + current.ResourceType;
+ newid = parent.ResourceId + dlg.NewName + "." + current.ResourceType;
+ //Perform the operation
+ if (dlg.UpdateReferences)
+ conn.ResourceService.MoveFolderWithReferences(oldid, newid, null, null);
+ else
+ conn.ResourceService.MoveFolder(oldid, newid, dlg.Overwrite);
+ else
+ conn.ResourceService.MoveResourceWithReferences(oldid, newid, null, null);
+ else
+ conn.ResourceService.MoveResource(oldid, newid, dlg.Overwrite);
+ current.Name = dlg.NewName;
+ if (dlg.Overwrite)
+ parent.RemoveChild(parent[dlg.NewName]);
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin 2010-08-11 05:18:46 UTC (rev 5082)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin 2010-08-11 11:10:29 UTC (rev 5083)
@@ -255,7 +255,7 @@
</Condition>
<ToolbarItem id="SiteExplorer_Refresh"
icon="arrow-circle-045-left"
- class="Maestro.Base.Commands.NotImplementedCommand" />
+ class="Maestro.Base.Commands.SiteExplorer.RefreshCommand" />
<ToolbarItem id="SiteExplorer_Disconnect"
icon="plug--minus"
class="Maestro.Base.Commands.SiteExplorer.DisconnectCommand" />
@@ -270,6 +270,14 @@
label="${res:Menu_File_NewResource}"
tooltip="${res:Menu_File_NewResource}"
class="Maestro.Base.Commands.NewItemCommand" />
+ <MenuItem id="NewItem"
+ icon="folder__plus"
+ label="${res:SiteExplorer_NewFolder}"
+ tooltip="${res:SiteExplorer_NewFolder}"
+ class="Maestro.Base.Commands.SiteExplorer.NewFolderCommand" />
+ <MenuItem id="Rename"
+ label="${res:SiteExplorer_SelectedItem_Rename}"
+ class="Maestro.Base.Commands.SiteExplorer.RenameCommand" />
<MenuItem type="Separator" />
<MenuItem id="CreatePackage"
label="${res:SiteExplorer_SelectedFolder_CreatePackage}"
@@ -293,7 +301,7 @@
<Condition action="Disable" name="IsNotRoot">
<MenuItem id="Delete"
label="${res:SiteExplorer_SelectedItem_Delete}"
+ class="Maestro.Base.Commands.SiteExplorer.DeleteSelectedItemsCommand" />
</Condition>
<MenuItem id="Validate"
label="${res:SiteExplorer_ValidateResources}"
@@ -334,7 +342,7 @@
class="Maestro.Base.Commands.SiteExplorer.OpenWithXmlEditorCommand" />
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj 2010-08-11 05:18:46 UTC (rev 5082)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj 2010-08-11 11:10:29 UTC (rev 5083)
@@ -62,10 +62,13 @@
<Compile Include="Commands\QuitCommand.cs" />
<Compile Include="Commands\SaveResourceAsCommand.cs" />
<Compile Include="Commands\SaveResourceCommand.cs" />
+ <Compile Include="Commands\SiteExplorer\DeleteSelectedItemsCommand.cs" />
<Compile Include="Commands\SiteExplorer\DisconnectCommand.cs" />
+ <Compile Include="Commands\SiteExplorer\NewFolderCommand.cs" />
<Compile Include="Commands\SiteExplorer\OpenResourceCommand.cs" />
<Compile Include="Commands\SiteExplorer\OpenWithXmlEditorCommand.cs" />
<Compile Include="Commands\SiteExplorer\RefreshCommand.cs" />
+ <Compile Include="Commands\SiteExplorer\RenameCommand.cs" />
<Compile Include="Commands\SiteExplorer\ResourcePropertiesCommand.cs" />
<Compile Include="Commands\SiteExplorer\ValidateCommand.cs" />
<Compile Include="Commands\StartupCommand.cs" />
@@ -197,6 +200,12 @@
<Compile Include="UI\NewResourceDialog.Designer.cs">
<DependentUpon>NewResourceDialog.cs</DependentUpon>
</Compile>
+ <Compile Include="UI\RenameItemDialog.cs">
+ <SubType>Form</SubType>
+ </Compile>
+ <Compile Include="UI\RenameItemDialog.Designer.cs">
+ <DependentUpon>RenameItemDialog.cs</DependentUpon>
+ </Compile>
<Compile Include="UI\RepositoryTreeModel.cs" />
<Compile Include="UI\ResourceIconCache.cs" />
<Compile Include="UI\ResourcePropertiesDialog.cs">
@@ -252,6 +261,7 @@
</ItemGroup>
<ItemGroup>
<Content Include="Maestro.Base.addin" />
+ <None Include="Resources\folder--plus.png" />
<None Include="Resources\cross.png" />
<None Include="Resources\blueprints.png" />
<None Include="Resources\folder-horizontal.png" />
@@ -352,6 +362,9 @@
<SubType>Designer</SubType>
</EmbeddedResource>
+ <EmbeddedResource Include="UI\RenameItemDialog.resx">
+ </EmbeddedResource>
<EmbeddedResource Include="UI\ResourcePropertiesDialog.resx">
<DependentUpon>ResourcePropertiesDialog.cs</DependentUpon>
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs 2010-08-11 05:18:46 UTC (rev 5082)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs 2010-08-11 11:10:29 UTC (rev 5083)
@@ -260,6 +260,15 @@
/// <summary>
+ /// Looks up a localized string similar to Are you sure you want to delete?.
+ /// </summary>
+ internal static string ConfirmDelete {
+ get {
+ return ResourceManager.GetString("ConfirmDelete", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Messages.
/// </summary>
internal static string Content_Messages {
@@ -440,6 +449,13 @@
+ internal static System.Drawing.Bitmap folder__plus {
+ get {
+ object obj = ResourceManager.GetObject("folder__plus", resourceCulture);
+ return ((System.Drawing.Bitmap)(obj));
internal static System.Drawing.Bitmap folder_horizontal {
get {
object obj = ResourceManager.GetObject("folder_horizontal", resourceCulture);
@@ -447,6 +463,15 @@
+ /// <summary>
+ /// Looks up a localized string similar to Question.
+ /// </summary>
+ internal static string Global_QuestionText {
+ get {
+ return ResourceManager.GetString("Global.QuestionText", resourceCulture);
internal static System.Drawing.Bitmap images_stack {
get {
object obj = ResourceManager.GetObject("images_stack", resourceCulture);
@@ -763,6 +788,15 @@
+ /// <summary>
+ /// Looks up a localized string similar to Rename to.
+ /// </summary>
+ internal static string RenameTo {
+ get {
+ return ResourceManager.GetString("RenameTo", resourceCulture);
internal static System.Drawing.Bitmap reports_stack {
get {
object obj = ResourceManager.GetObject("reports_stack", resourceCulture);
@@ -987,6 +1021,15 @@
/// <summary>
+ /// Looks up a localized string similar to New Folder.
+ /// </summary>
+ internal static string SiteExplorer_NewFolder {
+ get {
+ return ResourceManager.GetString("SiteExplorer_NewFolder", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Refresh.
/// </summary>
internal static string SiteExplorer_Refresh {
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx 2010-08-11 05:18:46 UTC (rev 5082)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx 2010-08-11 11:10:29 UTC (rev 5083)
@@ -628,4 +628,19 @@
<data name="Filter_Shp_Files" xml:space="preserve">
<value>ESRI Shapefile (*.shp)|*.shp</value>
</data>
+ <data name="ConfirmDelete" xml:space="preserve">
+ <value>Are you sure you want to delete?</value>
+ </data>
+ <data name="Global.QuestionText" xml:space="preserve">
+ <value>Question</value>
+ </data>
+ <data name="SiteExplorer_NewFolder" xml:space="preserve">
+ <value>New Folder</value>
+ </data>
+ <data name="folder__plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\folder--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="RenameTo" xml:space="preserve">
+ <value>Rename to</value>
+ </data>
</root>
\ No newline at end of file
Added: sandbox/maestro-3.0/Maestro.Base/Resources/folder--plus.png
(Binary files differ)
Property changes on: sandbox/maestro-3.0/Maestro.Base/Resources/folder--plus.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Modified: sandbox/maestro-3.0/Maestro.Base/UI/ISiteExplorer.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/ISiteExplorer.cs 2010-08-11 05:18:46 UTC (rev 5082)
+++ sandbox/maestro-3.0/Maestro.Base/UI/ISiteExplorer.cs 2010-08-11 11:10:29 UTC (rev 5083)
@@ -27,18 +27,9 @@
string ConnectionName { get; }
- /// <summary>
- /// Refreshes the contents of entire repository
- /// </summary>
- void Refresh();
+ void RefreshModel();
/// <summary>
- /// Refreshes the contents from the specified folder id
- /// </summary>
- /// <param name="folderID"></param>
- void Refresh(string folderID);
- /// <summary>
/// Gets the items currently selected
/// </summary>
RepositoryItem[] SelectedItems { get; }
Added: sandbox/maestro-3.0/Maestro.Base/UI/RenameItemDialog.Designer.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/RenameItemDialog.Designer.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/UI/RenameItemDialog.Designer.cs 2010-08-11 11:10:29 UTC (rev 5083)
@@ -0,0 +1,176 @@
+namespace Maestro.Base.UI
+ partial class RenameItemDialog
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Windows Form Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ this.label1 = new System.Windows.Forms.Label();
+ this.label2 = new System.Windows.Forms.Label();
+ this.chkOverwrite = new System.Windows.Forms.CheckBox();
+ this.chkUpdateRefs = new System.Windows.Forms.CheckBox();
+ this.btnRename = new System.Windows.Forms.Button();
+ this.btnCancel = new System.Windows.Forms.Button();
+ this.txtOld = new System.Windows.Forms.TextBox();
+ this.txtNew = new System.Windows.Forms.TextBox();
+ this.lblExists = new System.Windows.Forms.Label();
+ this.SuspendLayout();
+ // label1
+ this.label1.AutoSize = true;
+ this.label1.Location = new System.Drawing.Point(14, 20);
+ this.label1.Name = "label1";
+ this.label1.Size = new System.Drawing.Size(54, 13);
+ this.label1.TabIndex = 0;
+ this.label1.Text = "Old Name";
+ // label2
+ this.label2.AutoSize = true;
+ this.label2.Location = new System.Drawing.Point(13, 44);
+ this.label2.Name = "label2";
+ this.label2.Size = new System.Drawing.Size(60, 13);
+ this.label2.TabIndex = 1;
+ this.label2.Text = "New Name";
+ // chkOverwrite
+ this.chkOverwrite.AutoSize = true;
+ this.chkOverwrite.Location = new System.Drawing.Point(16, 77);
+ this.chkOverwrite.Name = "chkOverwrite";
+ this.chkOverwrite.Size = new System.Drawing.Size(153, 17);
+ this.chkOverwrite.TabIndex = 2;
+ this.chkOverwrite.Text = "Overwrite existing resource";
+ this.chkOverwrite.UseVisualStyleBackColor = true;
+ // chkUpdateRefs
+ this.chkUpdateRefs.AutoSize = true;
+ this.chkUpdateRefs.Checked = true;
+ this.chkUpdateRefs.CheckState = System.Windows.Forms.CheckState.Checked;
+ this.chkUpdateRefs.Location = new System.Drawing.Point(16, 101);
+ this.chkUpdateRefs.Name = "chkUpdateRefs";
+ this.chkUpdateRefs.Size = new System.Drawing.Size(209, 17);
+ this.chkUpdateRefs.TabIndex = 3;
+ this.chkUpdateRefs.Text = "Update any references to this resource";
+ this.chkUpdateRefs.UseVisualStyleBackColor = true;
+ this.chkUpdateRefs.CheckedChanged += new System.EventHandler(this.chkUpdateRefs_CheckedChanged);
+ // btnRename
+ this.btnRename.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Right)));
+ this.btnRename.Enabled = false;
+ this.btnRename.Location = new System.Drawing.Point(173, 129);
+ this.btnRename.Name = "btnRename";
+ this.btnRename.Size = new System.Drawing.Size(75, 23);
+ this.btnRename.TabIndex = 4;
+ this.btnRename.Text = "Rename";
+ this.btnRename.UseVisualStyleBackColor = true;
+ this.btnRename.Click += new System.EventHandler(this.btnRename_Click);
+ // btnCancel
+ this.btnCancel.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Right)));
+ this.btnCancel.DialogResult = System.Windows.Forms.DialogResult.Cancel;
+ this.btnCancel.Location = new System.Drawing.Point(254, 129);
+ this.btnCancel.Name = "btnCancel";
+ this.btnCancel.Size = new System.Drawing.Size(75, 23);
+ this.btnCancel.TabIndex = 5;
+ this.btnCancel.Text = "Cancel";
+ this.btnCancel.UseVisualStyleBackColor = true;
+ this.btnCancel.Click += new System.EventHandler(this.btnCancel_Click);
+ // txtOld
+ this.txtOld.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ | System.Windows.Forms.AnchorStyles.Right)));
+ this.txtOld.Location = new System.Drawing.Point(91, 17);
+ this.txtOld.Name = "txtOld";
+ this.txtOld.ReadOnly = true;
+ this.txtOld.Size = new System.Drawing.Size(238, 20);
+ this.txtOld.TabIndex = 6;
+ // txtNew
+ this.txtNew.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.txtNew.Location = new System.Drawing.Point(91, 41);
+ this.txtNew.Name = "txtNew";
+ this.txtNew.Size = new System.Drawing.Size(238, 20);
+ this.txtNew.TabIndex = 7;
+ this.txtNew.TextChanged += new System.EventHandler(this.txtNew_TextChanged);
+ this.txtNew.MouseLeave += new System.EventHandler(this.txtNew_MouseLeave);
+ // lblExists
+ this.lblExists.AutoSize = true;
+ this.lblExists.ForeColor = System.Drawing.Color.Red;
+ this.lblExists.Location = new System.Drawing.Point(14, 134);
+ this.lblExists.Name = "lblExists";
+ this.lblExists.Size = new System.Drawing.Size(104, 13);
+ this.lblExists.TabIndex = 8;
+ this.lblExists.Text = "Name already exists!";
+ this.lblExists.Visible = false;
+ // RenameItemDialog
+ this.AcceptButton = this.btnRename;
+ this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.CancelButton = this.btnCancel;
+ this.ClientSize = new System.Drawing.Size(341, 164);
+ this.ControlBox = false;
+ this.Controls.Add(this.lblExists);
+ this.Controls.Add(this.txtNew);
+ this.Controls.Add(this.txtOld);
+ this.Controls.Add(this.btnCancel);
+ this.Controls.Add(this.btnRename);
+ this.Controls.Add(this.chkUpdateRefs);
+ this.Controls.Add(this.chkOverwrite);
+ this.Controls.Add(this.label2);
+ this.Controls.Add(this.label1);
+ this.Name = "RenameItemDialog";
+ this.StartPosition = System.Windows.Forms.FormStartPosition.CenterParent;
+ this.Text = "Rename Item";
+ this.ResumeLayout(false);
+ this.PerformLayout();
+ #endregion
+ private System.Windows.Forms.Label label1;
+ private System.Windows.Forms.Label label2;
+ private System.Windows.Forms.CheckBox chkOverwrite;
+ private System.Windows.Forms.CheckBox chkUpdateRefs;
+ private System.Windows.Forms.Button btnRename;
+ private System.Windows.Forms.Button btnCancel;
+ private System.Windows.Forms.TextBox txtOld;
+ private System.Windows.Forms.TextBox txtNew;
+ private System.Windows.Forms.Label lblExists;
Added: sandbox/maestro-3.0/Maestro.Base/UI/RenameItemDialog.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/RenameItemDialog.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/UI/RenameItemDialog.cs 2010-08-11 11:10:29 UTC (rev 5083)
@@ -0,0 +1,87 @@
+#endregion
+using System;
+using System.ComponentModel;
+using System.Data;
+using System.Drawing;
+using System.Text;
+using System.Windows.Forms;
+ public partial class RenameItemDialog : Form
+ private RenameItemDialog()
+ InitializeComponent();
+ public RenameItemDialog(string oldName, IEnumerable<string> names)
+ : this()
+ txtOld.Text = oldName;
+ existingNames.AddRange(names);
+ public string NewName
+ get { return txtNew.Text; }
+ public bool UpdateReferences
+ get { return chkUpdateRefs.Checked; }
+ public bool Overwrite
+ get { return chkOverwrite.Checked; }
+ private List<string> existingNames = new List<string>();
+ private void btnCancel_Click(object sender, EventArgs e)
+ this.DialogResult = DialogResult.Cancel;
+ private void btnRename_Click(object sender, EventArgs e)
+ this.DialogResult = DialogResult.OK;
+ private void txtNew_TextChanged(object sender, EventArgs e)
+ btnRename.Enabled = (txtNew.Text.Length > 0) && (txtNew.Text != txtOld.Text);
+ private void txtNew_MouseLeave(object sender, EventArgs e)
+ lblExists.Visible = existingNames.Contains(txtNew.Text);
+ private void chkUpdateRefs_CheckedChanged(object sender, EventArgs e)
+ if (chkUpdateRefs.Checked)
+ chkOverwrite.Checked = true;
Added: sandbox/maestro-3.0/Maestro.Base/UI/RenameItemDialog.resx
--- sandbox/maestro-3.0/Maestro.Base/UI/RenameItemDialog.resx (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/UI/RenameItemDialog.resx 2010-08-11 11:10:29 UTC (rev 5083)
@@ -0,0 +1,120 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+</root>
Modified: sandbox/maestro-3.0/Maestro.Base/UI/RepositoryTreeModel.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/RepositoryTreeModel.cs 2010-08-11 05:18:46 UTC (rev 5082)
+++ sandbox/maestro-3.0/Maestro.Base/UI/RepositoryTreeModel.cs 2010-08-11 11:10:29 UTC (rev 5083)
@@ -26,6 +26,7 @@
using System.Diagnostics;
using OSGeo.MapGuide.MaestroAPI.Resource;
+using System.Collections.ObjectModel;
@@ -34,13 +35,141 @@
/// </summary>
public class RepositoryItem
- private IRepositoryItem _item;
+ private Dictionary<string, RepositoryItem> _children;
+ private bool _notify = false;
public RepositoryItem(IRepositoryItem item)
- _item = item;
+ _name = string.Empty;
+ _children = new Dictionary<string, RepositoryItem>();
+ this.CreatedDate = item.CreatedDate;
+ this.ModifiedDate = item.ModifiedDate;
+ this.Owner = item.Owner;
+ this.ResourceId = item.ResourceId;
+ this.ResourceType = item.ResourceType.ToString();
+ this.Name = item.Name; //set name last because update logic requires other properties be set already
+ if (this.IsRoot)
+ this.Icon = Properties.Resources.server;
+ else
+ switch (item.ResourceType)
+ case ResourceTypes.DrawingSource:
+ this.Icon = Properties.Resources.blueprints;
+ break;
+ case ResourceTypes.FeatureSource:
+ this.Icon = Properties.Resources.database_share;
+ break;
+ case ResourceTypes.Folder:
+ this.Icon = Properties.Resources.folder_horizontal;
+ break;
+ case ResourceTypes.LayerDefinition:
+ this.Icon = Properties.Resources.layer;
+ break;
+ case ResourceTypes.MapDefinition:
+ this.Icon = Properties.Resources.map;
+ break;
+ case ResourceTypes.WebLayout:
+ this.Icon = Properties.Resources.application_browser;
+ break;
+ case ResourceTypes.ApplicationDefinition:
+ this.Icon = Properties.Resources.applications_stack;
+ break;
+ case ResourceTypes.SymbolLibrary:
+ this.Icon = Properties.Resources.images_stack;
+ break;
+ case ResourceTypes.PrintLayout:
+ this.Icon = Properties.Resources.printer;
+ break;
+ default:
+ this.Icon = Properties.Resources.document;
+ break;
+ _notify = true;
+ public bool Contains(string name)
+ return _children.ContainsKey(name);
+ public RepositoryItem this[string name]
+ get { return _children[name]; }
+ internal RepositoryTreeModel Model
+ get;
+ set;
+ public RepositoryItem Parent
+ get;
+ private set;
+ public IEnumerable<RepositoryItem> Children
+ get { return _children.Values; }
+ public string NameQualified
+ get
+ if (this.ResourceType == ResourceTypes.Folder.ToString())
+ return this.Name;
+ else
+ return this.Name + "." + this.ResourceType;
+ internal void AddChildWithoutNotification(RepositoryItem item)
+ item.Parent = this;
+ _children.Add(item.NameQualified, item);
+ internal void RemoveChildWithoutNotification(RepositoryItem item)
+ if (_children.ContainsKey(item.NameQualified) && item.Parent == this)
+ if (_children.Remove(item.NameQualified))
+ item.Parent = null;
+ public void AddChild(RepositoryItem item)
+ NotifyStructureChanged();
+ public void RemoveChild(RepositoryItem item)
public bool IsRoot
get { return this.ResourceId == "Library://"; }
@@ -48,75 +177,126 @@
public string ResourceId
- get { return _item.ResourceId; }
+ get;
+ internal set;
+ private string _name;
public string Name
- get { return _item.Name; }
+ get { return _name; }
+ set
+ var oldq = this.NameQualified;
+ _name = value;
+ if (!oldq.Equals(this.NameQualified))
+ if (IsRoot)
+ return;
+ string parentid = ResourceIdentifier.GetParentFolder(this.ResourceId);
+ this.ResourceId = parentid + this.NameQualified + ((IsFolder) ? "/" : "");
+ NotifyNodesChanged();
+ /// <summary>
+ /// Finds the first attached model
+ /// </summary>
+ /// <returns></returns>
+ private RepositoryTreeModel FindModel()
+ RepositoryItem item = this;
+ while (item != null)
+ if (item.Model != null)
+ return item.Model;
+ item = item.Parent;
+ return null;
+ private void NotifyNodesChanged()
+ if (!_notify)
+ return;
+ var model = FindModel();
+ if (model != null)
+ TreePath path = model.GetPath(this);
+ if (path != null)
+ var args = new TreeModelEventArgs(path, new object[] { this });
+ model.RaiseNodesChanged(args);
+ private void NotifyStructureChanged()
+ if (!_notify)
+ return;
+ if (model != null && this.Parent != null)
+ TreePath path = model.GetPath(this.Parent);
+ if (path != null)
+ model.RaiseStructureChanged(args);
public string ResourceType
- get { return _item.ResourceType.ToString(); }
+ get;
+ internal set;
+ private string _owner;
public string Owner
- get { return _item.Owner; }
+ get { return _owner; }
+ set
+ _owner = value;
public DateTime CreatedDate
- get { return _item.CreatedDate; }
+ get;
+ internal set;
public DateTime ModifiedDate
- get { return _item.ModifiedDate; }
+ get;
+ internal set;
public bool IsFolder
- get { return _item.IsFolder; }
+ get { return this.ResourceId.EndsWith("/"); }
public Image Icon
- get
- if (IsRoot)
- return Properties.Resources.server;
- else
- switch (_item.ResourceType)
- case ResourceTypes.DrawingSource:
- return Properties.Resources.blueprints;
- case ResourceTypes.FeatureSource:
- return Properties.Resources.database_share;
- case ResourceTypes.Folder:
- return Properties.Resources.folder_horizontal;
- case ResourceTypes.LayerDefinition:
- return Properties.Resources.layer;
- case ResourceTypes.MapDefinition:
- return Properties.Resources.map;
- case ResourceTypes.WebLayout:
- return Properties.Resources.application_browser;
- case ResourceTypes.ApplicationDefinition:
- return Properties.Resources.applications_stack;
- case ResourceTypes.SymbolLibrary:
- return Properties.Resources.images_stack;
- case ResourceTypes.PrintLayout:
- return Properties.Resources.printer;
- default:
- return Properties.Resources.document;
+ get;
+ internal set;
+ internal void ClearChildrenWithoutNotification()
+ _children.Clear();
public class RepositoryItemToolTipProvider : IToolTipProvider
@@ -136,8 +316,10 @@
/// <summary>
/// Defines the repository model for the treeview
/// </summary>
- public class RepositoryTreeModel : ITreeModel
+ public class RepositoryTreeModel : TreeModelBase
+ private RepositoryItem _rootNode;
private IServerConnection _conn;
public RepositoryTreeModel(IServerConnection conn)
@@ -153,6 +335,7 @@
foreach (var item in list.Children)
var it = new RepositoryItem(item);
+ it.Model = this;
if (it.IsFolder)
folders.Add(it.ResourceId, it);
else
@@ -168,67 +351,87 @@
- public System.Collections.IEnumerable GetChildren(TreePath treePath)
+ public override System.Collections.IEnumerable GetChildren(TreePath treePath)
if (treePath.IsEmpty())
var list = _conn.ResourceService.GetRepositoryResources("Library://", 0);
- return GetSorted(list);
+ if (list.Items.Count != 1)
+ throw new InvalidOperationException(); //Huh?
+ _rootNode = new RepositoryItem((IRepositoryItem)list.Items[0]);
+ _rootNode.Model = this;
+ yield return _rootNode;
else
var node = treePath.LastNode as RepositoryItem;
if (node != null && node.IsFolder) //Can't enumerate children of documents
+ node.ClearChildrenWithoutNotification();
var list = _conn.ResourceService.GetRepositoryResources(node.ResourceId, "", 1, false);
+ foreach (RepositoryItem item in GetSorted(list))
+ node.AddChildWithoutNotification(item);
+ yield return item;
else
- return new RepositoryItem[0];
+ yield break;
- public bool IsLeaf(TreePath treePath)
+ public override bool IsLeaf(TreePath treePath)
return !((RepositoryItem)treePath.LastNode).IsFolder;
- protected void OnNodesChanged(TreeModelEventArgs e)
+ internal void RaiseNodesChanged(TreeModelEventArgs args)
- var handler = this.NodesChanged;
- if (handler != null)
- handler(this, e);
+ base.OnNodesChanged(args);
- public event EventHandler<TreeModelEventArgs> NodesChanged;
- protected void OnNodesInserted(TreeModelEventArgs e)
+ internal TreePath GetPath(RepositoryItem node)
- var handler = this.NodesInserted;
- handler(this, e);
+ if (node == _rootNode)
+ return new TreePath(node);
+ else
+ Stack<object> stack = new Stack<object>();
+ while (node != _rootNode)
+ stack.Push(node);
+ node = node.Parent;
+ stack.Push(node);
+ return new TreePath(stack.ToArray());
- public event EventHandler<TreeModelEventArgs> NodesInserted;
- protected void OnNodesRemoved(TreeModelEventArgs e)
+ internal void RaiseStructureChanged(TreeModelEventArgs args)
- var handler = this.NodesRemoved;
- handler(this, e);
+ base.OnStructureChanged(args);
- public event EventHandler<TreeModelEventArgs> NodesRemoved;
- protected void OnStructureChanged(TreePathEventArgs e)
+ internal TreePath GetPathFromResourceId(string resId)
- var handler = this.StructureChanged;
- handler(this, e);
+ string[] components = ResourceIdentifier.GetPath(resId).Split('/');
+ if (!ResourceIdentifier.IsFolderResource(resId))
+ //Fix extension to last component
+ components[components.Length - 1] = components[components.Length - 1] + "." + ResourceIdentifier.GetResourceType(resId).ToString();
+ RepositoryItem current = _rootNode;
+ for (int i = 0; i < components.Length; i++)
+ current = current[components[i]];
+ return GetPath(current);
- public event EventHandler<TreePathEventArgs> StructureChanged;
Modified: sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.Designer.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.Designer.cs 2010-08-11 05:18:46 UTC (rev 5082)
+++ sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.Designer.cs 2010-08-11 11:10:29 UTC (rev 5083)
@@ -77,7 +77,6 @@
// ndResource
this.ndResource.DataPropertyName = "Name";
- this.ndResource.EditEnabled = true;
this.ndResource.IncrementalSearchEnabled = true;
this.ndResource.LeftMargin = 3;
this.ndResource.ParentColumn = null;
Modified: sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.cs 2010-08-11 05:18:46 UTC (rev 5082)
+++ sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.cs 2010-08-11 11:10:29 UTC (rev 5083)
@@ -65,6 +65,8 @@
this.ConnectionName = name;
+ private RepositoryTreeModel _model;
protected override void OnLoad(EventArgs e)
this.Title = Properties.Resources.Content_SiteExplorer;
@@ -76,8 +78,8 @@
var mgr = ServiceRegistry.GetService<ServerConnectionManager>();
_conn = mgr.GetConnection(this.ConnectionName);
- var model = new RepositoryTreeModel(_conn);
- trvResources.Model = model;
+ _model = new RepositoryTreeModel(_conn);
+ trvResources.Model = _model;
public override bool AllowUserClose
@@ -96,11 +98,43 @@
- public void Refresh(string folderID)
+ public void RefreshModel()
+ string resId = null;
+ if (this.SelectedItems.Length == 1)
+ resId = this.SelectedItems[0].ResourceId;
+ _model.Refresh();
+ ExpandRoot();
+ //This doesn't actually work yet :(
+ //if (!string.IsNullOrEmpty(resId))
+ // var path = _model.GetPathFromResourceId(resId);
+ // if (path != TreePath.Empty)
+ // var node = trvResources.FindNode(path);
+ // if (node != null)
+ // while (node.Parent != null)
+ // node = node.Parent;
+ // if (!node.IsExpanded)
+ // node.Expand();
+ private void ExpandRoot()
+ //"Root" of the model is actually the child of the tree root
+ trvResources.Root.Children[0].Expand();
private void trvResources_MouseDoubleClick(object sender, MouseEventArgs e)
TreeNodeAdv node = trvResources.GetNodeAt(new Point(e.X, e.Y));
More information about the mapguide-commits
