[mapguide-commits] r5094 - trunk/MgDev/UnitTest/WebTier/Php
svn_mapguide at osgeo.org
Fri Aug 27 19:04:36 EDT 2010
Author: waltweltonlair
Date: 2010-08-27 23:04:36 +0000 (Fri, 27 Aug 2010)
New Revision: 5094
trunk/MgDev/UnitTest/WebTier/Php/HttpRequest.php
trunk/MgDev/UnitTest/WebTier/Php/RunTests.php
Port two web tier unit test fixes from the 2.2 code stream:
RunTests.php:
- Fix timezone warning issue
HttpRequest.php:
- Remove the Curl call that was causing the POST request to be changed into a GET request.
Note: The Curl documentation says that this shouldn't happen, but the new Curl extension with PHP 5.3 is changing it.
Modified: trunk/MgDev/UnitTest/WebTier/Php/HttpRequest.php
--- trunk/MgDev/UnitTest/WebTier/Php/HttpRequest.php 2010-08-27 22:59:08 UTC (rev 5093)
+++ trunk/MgDev/UnitTest/WebTier/Php/HttpRequest.php 2010-08-27 23:04:36 UTC (rev 5094)
@@ -60,7 +60,6 @@
curl_setopt($this->ch, CURLOPT_URL, $httpRequest);
curl_setopt($this->ch, CURLOPT_HEADER, true);
- curl_setopt($this->ch, CURLOPT_NOBODY, false);
curl_setopt($this->ch, CURLOPT_RETURNTRANSFER, true);
curl_setopt($this->ch, CURLOPT_USERPWD, "Administrator:admin");
Modified: trunk/MgDev/UnitTest/WebTier/Php/RunTests.php
--- trunk/MgDev/UnitTest/WebTier/Php/RunTests.php 2010-08-27 22:59:08 UTC (rev 5093)
+++ trunk/MgDev/UnitTest/WebTier/Php/RunTests.php 2010-08-27 23:04:36 UTC (rev 5094)
@@ -31,6 +31,7 @@
$isEnterprise = false;
$file = fopen("UnitTests.log", "w");
+ date_default_timezone_set("GMT-0");
$str = sprintf("Run started: %s\n\n",date("D M j G:i:s T Y"));
echo $str;
More information about the mapguide-commits
