[mapguide-commits] r4479 - in
trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceEditors:
Resources Strings
svn_mapguide at osgeo.org
Mon Jan 4 17:09:57 EST 2010
Author: ksgeograf
Date: 2010-01-04 17:09:56 -0500 (Mon, 04 Jan 2010)
New Revision: 4479
trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceEditors/Resources/GeometryStyleComboDataset.xml
trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceEditors/Strings/MapEditor.da-DK.resx
Maestro:
Fixed minor translation issues.
Modified: trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceEditors/Resources/GeometryStyleComboDataset.xml
--- trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceEditors/Resources/GeometryStyleComboDataset.xml 2010-01-04 21:48:07 UTC (rev 4478)
+++ trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceEditors/Resources/GeometryStyleComboDataset.xml 2010-01-04 22:09:56 UTC (rev 4479)
@@ -122,7 +122,7 @@
<Value>'Capline'</Value>
</Vertical>
<Vertical>
- <Display>Halfline</Display>
+ <Display>Halvlinie</Display>
<Value>'Halfline'</Value>
</Vertical>
<Vertical>
@@ -131,7 +131,7 @@
</Vertical>
<Vertical>
<Display>Expression...</Display>
- <Value>Expression...</Value>
+ <Value>Udtryk...</Value>
</Vertical>
<Horizontal>
@@ -139,7 +139,7 @@
<Value>'Center'</Value>
</Horizontal>
<Horizontal>
- <Display>Expression...</Display>
+ <Display>Udtryk...</Display>
</Horizontal>
</ComboBoxDataSet>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceEditors/Strings/MapEditor.da-DK.resx
--- trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceEditors/Strings/MapEditor.da-DK.resx 2010-01-04 21:48:07 UTC (rev 4478)
+++ trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceEditors/Strings/MapEditor.da-DK.resx 2010-01-04 22:09:56 UTC (rev 4479)
@@ -168,4 +168,21 @@
Vil du gemme kortet?</value>
<comment>A warning message that is displayed if the map contains baselayers, as that will result in all existing tiles being deleted</comment>
</data>
+ <data name="UseNewProjectionQuestion" xml:space="preserve">
+ <value>The data extent is in another projection than the map, do you also want to update the maps coordinate system?</value>
+ <comment>A question that is displayed if the maps projection differs from that of the featuresource</comment>
+ </data>
+ <data name="UseLayerProjectionQuestion" xml:space="preserve">
+ <value>Do you want to use the projection from the layer
+{0}?</value>
+ <comment>A question that is displayed if the user can choose to user the layer projection</comment>
+ </data>
+ <data name="NoProjectionFoundWarning" xml:space="preserve">
+ <value>The extent for the layer was found, but no coordinate system was found</value>
+ <comment>A warning message that is displayed if the layers projection could not be read</comment>
+ </data>
+ <data name="LayerProjectionReadError" xml:space="preserve">
+ <value>An error occured while reading the layers projection: {0}</value>
+ <comment>An error message that is displayed if an error occurs while reading the data projection</comment>
+ </data>
</root>
More information about the mapguide-commits
