[mapguide-commits] r4481 - in trunk/Tools/Maestro:
Localization/da-DK/Maestro/ResourceEditors/FeatureSourceEditors
Localization/da-DK/Maestro/ResourceEditors/FeatureSourceEditors/MSSQLSpatial
Localization/da-DK/Maestro/ResourceEditors/FeatureSourceEditors/OGR
Localization/da-DK/Maestro/ResourceEditors/FeatureSourceEditors/OGR/Strings
Localization/da-DK/Maestro/ResourceEditors/GeometryStyleEditors/Strings
Localization/da-DK/Maestro/ResourceEditors/Resources
Localization/es-ES/Maestro/ResourceEditors/FeatureSourceEditors
Localization/es-ES/Maestro/ResourceEditors/FeatureSourceEditors/MSSQLSpatial
Localization/es-ES/Maestro/ResourceEditors/FeatureSourceEditors/OGR
Localization/es-ES/Maestro/ResourceEditors/FeatureSourceEditors/OGR/Strings
Localization/es-ES/Maestro/ResourceEditors/GeometryStyleEditors/Strings
Localization/fr-FR/Maestro/ResourceEditors/FeatureSourceEditors
Localization/fr-FR/Maestro/ResourceEditors/FeatureSourceEditors/MSSQLSpatial
Localization/fr-FR/Maestro/ResourceEditors/FeatureSourceEditors/OGR
Localization/fr-FR/Maestro/ResourceEditors/FeatureSourceEditors/OGR/Strings
Localization/fr-FR/Maestro/ResourceEditors/GeometryStyleEditors/Strings
Maestro
svn_mapguide at osgeo.org
Tue Jan 5 14:25:47 EST 2010
Author: ksgeograf
Date: 2010-01-05 14:25:46 -0500 (Tue, 05 Jan 2010)
New Revision: 4481
Added:
trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceEditors/FeatureSourceEditors/MSSQLSpatial/
trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceEditors/FeatureSourceEditors/MSSQLSpatial/FeatureSourceEditorMSSQLSpatial.da-DK.resx
trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceEditors/FeatureSourceEditors/OGR/Strings/
trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceEditors/FeatureSourceEditors/OGR/Strings/Managed.da-DK.resx
trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceEditors/GeometryStyleEditors/Strings/FontStyleEditor.da-DK.resx
trunk/Tools/Maestro/Localization/es-ES/Maestro/ResourceEditors/FeatureSourceEditors/MSSQLSpatial/
trunk/Tools/Maestro/Localization/es-ES/Maestro/ResourceEditors/FeatureSourceEditors/MSSQLSpatial/FeatureSourceEditorMSSQLSpatial.es-ES.resx
trunk/Tools/Maestro/Localization/es-ES/Maestro/ResourceEditors/FeatureSourceEditors/OGR/Strings/
trunk/Tools/Maestro/Localization/es-ES/Maestro/ResourceEditors/FeatureSourceEditors/OGR/Strings/Managed.es-ES.resx
trunk/Tools/Maestro/Localization/es-ES/Maestro/ResourceEditors/GeometryStyleEditors/Strings/FontStyleEditor.es-ES.resx
trunk/Tools/Maestro/Localization/fr-FR/Maestro/ResourceEditors/FeatureSourceEditors/MSSQLSpatial/
trunk/Tools/Maestro/Localization/fr-FR/Maestro/ResourceEditors/FeatureSourceEditors/MSSQLSpatial/FeatureSourceEditorMSSQLSpatial.fr-FR.resx
trunk/Tools/Maestro/Localization/fr-FR/Maestro/ResourceEditors/FeatureSourceEditors/OGR/Strings/
trunk/Tools/Maestro/Localization/fr-FR/Maestro/ResourceEditors/FeatureSourceEditors/OGR/Strings/Managed.fr-FR.resx
trunk/Tools/Maestro/Localization/fr-FR/Maestro/ResourceEditors/GeometryStyleEditors/Strings/FontStyleEditor.fr-FR.resx
trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceEditors/Resources/GeometryStyleComboDataset.xml
trunk/Tools/Maestro/Maestro/FormAbout.cs
Maestro:
More minor fixes to the translation.
Added: trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceEditors/FeatureSourceEditors/MSSQLSpatial/FeatureSourceEditorMSSQLSpatial.da-DK.resx
--- trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceEditors/FeatureSourceEditors/MSSQLSpatial/FeatureSourceEditorMSSQLSpatial.da-DK.resx (rev 0)
+++ trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceEditors/FeatureSourceEditors/MSSQLSpatial/FeatureSourceEditorMSSQLSpatial.da-DK.resx 2010-01-05 19:25:46 UTC (rev 4481)
@@ -0,0 +1,120 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+</root>
\ No newline at end of file
Added: trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceEditors/FeatureSourceEditors/OGR/Strings/Managed.da-DK.resx
--- trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceEditors/FeatureSourceEditors/OGR/Strings/Managed.da-DK.resx (rev 0)
+++ trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceEditors/FeatureSourceEditors/OGR/Strings/Managed.da-DK.resx 2010-01-05 19:25:46 UTC (rev 4481)
@@ -0,0 +1,124 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+ <data name="UseAllFilesTooltip" xml:space="preserve">
+ <value>Brug alle filer i mappen som datakilde</value>
+ <comment>A tooltip displayed for the button that enables the use of the folder as the resource</comment>
+ </data>
+</root>
Added: trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceEditors/GeometryStyleEditors/Strings/FontStyleEditor.da-DK.resx
--- trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceEditors/GeometryStyleEditors/Strings/FontStyleEditor.da-DK.resx (rev 0)
+++ trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceEditors/GeometryStyleEditors/Strings/FontStyleEditor.da-DK.resx 2010-01-05 19:25:46 UTC (rev 4481)
@@ -0,0 +1,124 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+ <data name="ExpressionItem" xml:space="preserve">
+ <value>Udtryk...</value>
+ <comment>A value displayed in the combobox to activate the expression builder</comment>
+ </data>
+</root>
Modified: trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceEditors/Resources/GeometryStyleComboDataset.xml
--- trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceEditors/Resources/GeometryStyleComboDataset.xml 2010-01-04 22:32:11 UTC (rev 4480)
+++ trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceEditors/Resources/GeometryStyleComboDataset.xml 2010-01-05 19:25:46 UTC (rev 4481)
@@ -130,8 +130,8 @@
<Value>'Top'</Value>
</Vertical>
<Vertical>
- <Display>Expression...</Display>
- <Value>Udtryk...</Value>
+ <Display>Udtryk...</Display>
+ <Value>Expression...</Value>
</Vertical>
<Horizontal>
Added: trunk/Tools/Maestro/Localization/es-ES/Maestro/ResourceEditors/FeatureSourceEditors/MSSQLSpatial/FeatureSourceEditorMSSQLSpatial.es-ES.resx
--- trunk/Tools/Maestro/Localization/es-ES/Maestro/ResourceEditors/FeatureSourceEditors/MSSQLSpatial/FeatureSourceEditorMSSQLSpatial.es-ES.resx (rev 0)
+++ trunk/Tools/Maestro/Localization/es-ES/Maestro/ResourceEditors/FeatureSourceEditors/MSSQLSpatial/FeatureSourceEditorMSSQLSpatial.es-ES.resx 2010-01-05 19:25:46 UTC (rev 4481)
@@ -0,0 +1,120 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+</root>
Added: trunk/Tools/Maestro/Localization/es-ES/Maestro/ResourceEditors/FeatureSourceEditors/OGR/Strings/Managed.es-ES.resx
--- trunk/Tools/Maestro/Localization/es-ES/Maestro/ResourceEditors/FeatureSourceEditors/OGR/Strings/Managed.es-ES.resx (rev 0)
+++ trunk/Tools/Maestro/Localization/es-ES/Maestro/ResourceEditors/FeatureSourceEditors/OGR/Strings/Managed.es-ES.resx 2010-01-05 19:25:46 UTC (rev 4481)
@@ -0,0 +1,124 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+ <value>Use all files in the feature source as data source</value>
+ </data>
+</root>
Added: trunk/Tools/Maestro/Localization/es-ES/Maestro/ResourceEditors/GeometryStyleEditors/Strings/FontStyleEditor.es-ES.resx
--- trunk/Tools/Maestro/Localization/es-ES/Maestro/ResourceEditors/GeometryStyleEditors/Strings/FontStyleEditor.es-ES.resx (rev 0)
+++ trunk/Tools/Maestro/Localization/es-ES/Maestro/ResourceEditors/GeometryStyleEditors/Strings/FontStyleEditor.es-ES.resx 2010-01-05 19:25:46 UTC (rev 4481)
@@ -0,0 +1,124 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+ <value>Expression...</value>
+ </data>
+</root>
Added: trunk/Tools/Maestro/Localization/fr-FR/Maestro/ResourceEditors/FeatureSourceEditors/MSSQLSpatial/FeatureSourceEditorMSSQLSpatial.fr-FR.resx
--- trunk/Tools/Maestro/Localization/fr-FR/Maestro/ResourceEditors/FeatureSourceEditors/MSSQLSpatial/FeatureSourceEditorMSSQLSpatial.fr-FR.resx (rev 0)
+++ trunk/Tools/Maestro/Localization/fr-FR/Maestro/ResourceEditors/FeatureSourceEditors/MSSQLSpatial/FeatureSourceEditorMSSQLSpatial.fr-FR.resx 2010-01-05 19:25:46 UTC (rev 4481)
@@ -0,0 +1,120 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+</root>
Added: trunk/Tools/Maestro/Localization/fr-FR/Maestro/ResourceEditors/FeatureSourceEditors/OGR/Strings/Managed.fr-FR.resx
--- trunk/Tools/Maestro/Localization/fr-FR/Maestro/ResourceEditors/FeatureSourceEditors/OGR/Strings/Managed.fr-FR.resx (rev 0)
+++ trunk/Tools/Maestro/Localization/fr-FR/Maestro/ResourceEditors/FeatureSourceEditors/OGR/Strings/Managed.fr-FR.resx 2010-01-05 19:25:46 UTC (rev 4481)
@@ -0,0 +1,124 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+ </data>
+</root>
Added: trunk/Tools/Maestro/Localization/fr-FR/Maestro/ResourceEditors/GeometryStyleEditors/Strings/FontStyleEditor.fr-FR.resx
--- trunk/Tools/Maestro/Localization/fr-FR/Maestro/ResourceEditors/GeometryStyleEditors/Strings/FontStyleEditor.fr-FR.resx (rev 0)
+++ trunk/Tools/Maestro/Localization/fr-FR/Maestro/ResourceEditors/GeometryStyleEditors/Strings/FontStyleEditor.fr-FR.resx 2010-01-05 19:25:46 UTC (rev 4481)
@@ -0,0 +1,124 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+ </data>
+</root>
Modified: trunk/Tools/Maestro/Maestro/FormAbout.cs
--- trunk/Tools/Maestro/Maestro/FormAbout.cs 2010-01-04 22:32:11 UTC (rev 4480)
+++ trunk/Tools/Maestro/Maestro/FormAbout.cs 2010-01-05 19:25:46 UTC (rev 4481)
@@ -260,10 +260,17 @@
#endregion
+ /// <summary>
+ /// Dummy function used to create a thread to read the default locale from
+ /// </summary>
+ private void dummy_function() { }
private void FormAbout_Load(object sender, System.EventArgs e)
+ System.Threading.Thread tmp = new System.Threading.Thread(new System.Threading.ThreadStart(dummy_function));
Version.Text = string.Format(Strings.FormAbout.VersionLabel, Application.ProductVersion);
- Localization.Text = string.Format(Strings.FormAbout.LanguageLabel, System.Threading.Thread.CurrentThread.CurrentUICulture, System.Globalization.CultureInfo.InstalledUICulture);
+ Localization.Text = string.Format(Strings.FormAbout.LanguageLabel, System.Threading.Thread.CurrentThread.CurrentUICulture, tmp.CurrentUICulture);
string match = "unknown version";
for(int i = 0; i < MaestroAPI.SiteVersions.SiteVersionNumbers.Length; i++)
More information about the mapguide-commits
