[mapguide-commits] r4493 - in trunk/MgDev:
Common/MapGuideCommon/Services Server/src/Core
svn_mapguide at osgeo.org
Thu Jan 7 18:35:34 EST 2010
Author: brucedechant
Date: 2010-01-07 18:35:33 -0500 (Thu, 07 Jan 2010)
New Revision: 4493
trunk/MgDev/Common/MapGuideCommon/Services/SiteManager.cpp
trunk/MgDev/Common/MapGuideCommon/Services/SiteManager.h
trunk/MgDev/Server/src/Core/Server.cpp
Fix for trac ticket 1131 - Load balancing doesn't support fail over
http://trac.osgeo.org/mapguide/ticket/1131
Notes:
- Updated background check server(s) thread to shutdown faster
- Disabled starting the background check server(s) thread if we are running unit tests
Modified: trunk/MgDev/Common/MapGuideCommon/Services/SiteManager.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/SiteManager.cpp 2010-01-07 22:36:24 UTC (rev 4492)
+++ trunk/MgDev/Common/MapGuideCommon/Services/SiteManager.cpp 2010-01-07 23:35:33 UTC (rev 4493)
@@ -98,10 +98,18 @@
// Sleep the thread as thread resume/suspend is not supported on all platforms
- ACE_OS::sleep(sleepTime);
+ for(size_t i=0;i<sleepTime;i++)
+ ACE_OS::sleep(1);
- // Update whether we are done or not
- bDone = siteManager->GetCheckServersThreadDone();
+ // Update whether we are done or not
+ bDone = siteManager->GetCheckServersThreadDone();
+ if(bDone)
+ // We don't want to sleep anymore as we need to shutdown this thread ASAP
+ break;
return 0;
@@ -283,12 +291,6 @@
m_bCheckServersThreadDone = false;
- // Need a thread manager
- ACE_Thread_Manager* manager = ACE_Thread_Manager::instance();
- // Create the background thread
- manager->spawn(ACE_THR_FUNC(CheckServers), &m_threadData);
MG_CATCH_AND_THROW(L"MgSiteManager.Initialize")
@@ -553,3 +555,17 @@
ACE_MT(ACE_GUARD(ACE_Recursive_Thread_Mutex, ace_mon, m_mutex));
m_bCheckServersThreadDone = bDone;
+void MgSiteManager::StartCheckServersThread()
+ // Need a thread manager
+ ACE_Thread_Manager* manager = ACE_Thread_Manager::instance();
+ // Create the background thread
+ manager->spawn(ACE_THR_FUNC(CheckServers), &m_threadData);
+void MgSiteManager::StopCheckServersThread()
+ SetCheckServersThreadDone(true);
Modified: trunk/MgDev/Common/MapGuideCommon/Services/SiteManager.h
--- trunk/MgDev/Common/MapGuideCommon/Services/SiteManager.h 2010-01-07 22:36:24 UTC (rev 4492)
+++ trunk/MgDev/Common/MapGuideCommon/Services/SiteManager.h 2010-01-07 23:35:33 UTC (rev 4493)
@@ -79,6 +79,8 @@
bool GetCheckServersThreadDone();
void SetCheckServersThreadDone(bool bDone);
+ void StartCheckServersThread();
+ void StopCheckServersThread();
private:
Modified: trunk/MgDev/Server/src/Core/Server.cpp
--- trunk/MgDev/Server/src/Core/Server.cpp 2010-01-07 22:36:24 UTC (rev 4492)
+++ trunk/MgDev/Server/src/Core/Server.cpp 2010-01-07 23:35:33 UTC (rev 4493)
@@ -545,6 +545,10 @@
nResult = siteThreads.Activate();
if(nResult == 0)
+ // Let the site manager know that the check servers background thread needs to start
+ MgSiteManager* siteManager = MgSiteManager::GetInstance();
+ siteManager->StartCheckServersThread();
MG_LOG_TRACE_ENTRY(L"MgServer::svc() - Before Event Loop");
nResult = ACE_Reactor::instance()->run_reactor_event_loop();
MG_LOG_TRACE_ENTRY(L"MgServer::svc() - After Event Loop");
@@ -579,6 +583,9 @@
adminThreads.close();
siteThreads.close();
+ // Let the site manager know that the check servers background thread needs to stop
+ siteManager->StopCheckServersThread();
// Ensure the thread manager waits until all operation threads are done before closing
threadManager.wait();
threadManager.close();
More information about the mapguide-commits
